9B12070003
9B12070003
    TXC(台晶)
    HC49S
    无源晶振 HC49S
9B12070003 数据手册
TXC CORPORATION www.txccorp.com SPECIFICATION FOR APPROVAL CUSTOMER : PRODUCT TYPE : HC-49/S NOMINAL FREQ. : 12.000000MHz TXC P/N : 9B12070003 REVISION : S1 CUSTOMER P/N : PM / SALES : DATE : CUSTOMER CONFIRMATION : (Singnature) (Date) RoHS Compliant FMT-DOC024 VER.G TXC confidential and proprietary document TXC CORPORATION www.txccorp.com SPECIFICATION FOR APPROVAL PRODUCT TYPE : HC-49/S NOMINAL FREQ. : 12.000000MHz TXC P/N : 9B12070003 REVISION : S1 PE/RD QA MFG Simon Wang Randy Chiang Shu-Chen Ko 2017/2/17 2017/2/17 2017/2/17 RoHS Compliant FMT-DOC024 VER.G TXC confidential and proprietary document TXC P/N: TXC CORPORATION Rev Revise page S1 N/A FMT-DOC024 VER.G Revise contents Initial Release 9B12070003 REVISION: S1 PAGE: 1 Date Ref.No. Reviser 2017/2/17 N/A Shu-Chen Ko TXC confidential and proprietary document TXC CORPORATION TXC P/N: 9B12070003 REVISION: S1 PAGE: 2 Spec Sheet Contents No. Content 1 Page ELECTRICAL SPECIFICATIONS P.3 DIMENSIONS 2 MARKING SUGGESTED REFLOW PROFILE& MANUAL SOLDER CONDITION P.4 3 STRUCTURE ILLUSTRATION P.5 4 PACKING P.6 5 RELIABILITY SPECIFICATIONS 6 NOTE FMT-DOC024 VER.G P.7 P.8 P.8 TXC confidential and proprietary document TXC P/N: TXC CORPORATION 9B12070003 REVISION: S1 PAGE: 3 ■ ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature: 25+/-5oC Relative humidity 40%~70% : If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature: 25+/-1oC Relative humidity 40%~70% : Measure equipment SAUNDERS 250B CRYSTAL IMPEDANCE METER. Crystal cutting type The crystal is using AT CUT (thickness shear mode). Unit Weight : 0.54 g +/- 0.05g please refer to marking code page Parameters SYM. 1 Nominal Frequency 2 Oscillation Mode Electrical Spec. MIN. TYP. MAX. Notes UNITS FL 12.000000 MHz - - Fundamental - - pF - 3 Load Capacitance CL 4 Frequency Tolerance FT -10 +10 ppm at 25 oC +/- 3 oC 5 Frequency Stability ST -10 +10 ppm Over Operating Temp. Range (Reference 25 oC) 6 Operating Temperature OT -20 - -5 8 Drive level DL - 9 Effective Resistance Rr 10 Shunt Capacitance 7 Aging 11 Insulation Resisstance 13 SPDB(+/-5000ppm) ~ +70 o C - +5 ppm 1st Year 100 500 uW - - - 60 Ω - C0 - - 7 pF - - 500 - - MΩ at DC 100V - 12 Storage Tempeature Range 18 SPDB -40 ~ +85 ~ -3 o C - dB - ■ FACTORY LOCATION : CHINA FMT-DOC024 VER.G TXC confidential and proprietary document TXC P/N: TXC CORPORATION 9B12070003 S1 REVISION: PAGE: 4 ■ DIMENSIONS (Unit:mm) 11.5 Max. TXC G 5.0 Max. 4.88+/-0.25 10.7 max. 3.8 max. 3.68 max. 0.43+/-0.125 13.2+/-0.5 ■ MARKING   TXC TXC Symbol G Pb Free Product Frequency Frequency Ex.: 12.000000 MHz = Lot Code(2 digits) Date Code Production control Code Date Code: MONTH JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC YEAR 2013 2017 2021 2025 2029 A B C D E F G H J K L M 2014 2015 2018 2022 2026 2030 N P Q R S T U V W X Y Z 2019 2023 2027 2031 2016 a b c d e f g h j k l m 2020 2024 2028 2032 n p q r s t u v w x y z *This date code will be cycled every four years. ■ SUGGESTED REFLOW PROFILE Solder melting point :220+/-10 oC, 60 sec. Min. Peak Temperature: 260 +/- 5 oC, 10 sec. Max. ■ SUGGESTED MANUAL SOLDER CONDITION Temperature: 350 +/- 10 oC Time: 3 sec. Re-solder times: twice FMT-DOC024 VER.G TXC confidential and proprietary document 12.0 TXC CORPORATION TXC P/N: 9B12070003 REVISION: S1 ■ STRUCTURE ILLUSTRATION NO 1 2 COMPONENTS CRYSTAL BLANK MATERIALS FINISH/SPECIFICATIONS / QUARTZ (SiO2) Ni PLATED 2.1 HOLDER SPCC 2.2 SUPPORTER NICKEL SILVER / GLASS / CRYSTAL 2.3 GLASS BASE 2.4 3 4 5 LEAD COVER KOVAR / (Coating : Sn/Cu) NICKEL SILVER / CONDUCTIVE ADHESIVE Ag + RESIN / ELECTRODE / FMT-DOC024 VER.G Noble Metal TXC confidential and proprietary document PAGE: 5 TXC CORPORATION TXC P/N: 9B12070003 REVISION: S1 PAGE: 6 Packing For Pb Free Parts : 1.INNER BOX:(Unit:mm) 5bagx200pcs =1000pcs/box 200pcs/bag PUT IN PUT IN 2.LOGO STICKER(CARTON and INNER BOX):(Unit:mm) 150+/-10 190+/-10 42+/-10 PUT IN # (1) Put in stuff between space. [STORAGE] 1.Don't be caught in the rain. 2.The storage environment shall be 5oC ~40oC temperature and 30% ~ 75%RH humidity and free from the sun shine. 3.If customers have special requirements, we can paste labels according to it. FMT-DOC024 VER.G TXC confidential and proprietary document TXC P/N: TXC CORPORATION 9B12070003 REVISION: S1 PAGE: 7 ■ RELIABILITY SPECIFICATIONS 1.Mechanical Endurance No. Test Item Test Criteria Test Methods 1.1 Drop test 50 cm Height, Fall freely onto firm wood for 3 times. BC 1.2 Mechanical Shock 1000 G , 0.5 m Sec. , 3 times for all 3 directions. BC 1.3 Vibration Frequency range 10 ~ 2000 Hz Acceleration 5G Sweep time 20 minute Pendicular axes each test time 4 hours BC (Total test time 12 hours) 1.4 Terminal Strength 1.5 Solderability 17.7N force for 60sec +/-1sec. F Pb free :Temperature 235+/-5 oC,Immersion time:5+/-1sec Pb :Temperature 215+/-5 oC,Immersion time:5+/-1sec E 2.Environmental Endurance No. Test Methods Test Item Test temperature 2.1 Resistance To Soldering Heat 2.2 High Temp. Storage 2.3 Low Temp. Storage SPEC o 260 +/- 5 C Test time 10 +/- 1 sec. Emersion Rate 25 +/- 6 mm/s Immersed of specimen 1.5mm ACD o o ACD o o ACD + 85 C +/- 3 C for 500 +/- 12 Hrs - 40 C +/- 3 C for 500 +/-12 Hrs o o -40 C~85 C,for 300 cycles. 1 cycle 85+/-3 oC 2.4 Temperature cycle ACD 25 oC -40+/-3 oC 30 min. 30 min. 5 min. 2.5 High Temp&Humidity 85oC +/- 3oC , RH 85% , 500 Hrs ■HANDING CAUTIONS Prohibit the use of ultrasonic welding in Assemblying FMT-DOC024 VER.G TXC confidential and proprietary document ACD TXC CORPORATION TXC P/N: 9B12070003 REVISION: S1 PAGE: 8 ■ RELIABILITY SPECIFICATIONS Specifications A Frequency change: Within +/-20ppm or in customer's specification. B Frequency change: Within +/-10ppm or in customer's specification. C Equivalent series resistance(E.S.R) change: Within +/-15% or 10Ω(larger value). D After conditioning , quartz crystal units shall be subjected to standard atmospheric conditions for 24 hour, and measured. E Minimum 95% of immersed terminal shall be covered with new uniform solder. F No damage on specimen Measurement condition Electrical characteristics measured by S&A250B or equivalent. NOTE: 1. TXC requires one copy returned with signature and title of authorized individual that signifies acceptance of the attached specifications. 2. Orders received and accepted by TXC after return of signed copy of specification will be produced per these specifications. 3. Any changes to these specifications must be agreed upon by both parties and new revision of the "Product Specification Sheet" will be issued. 4. Any issuance of purchase order prior to consigning back the approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. 5. The green product standard set by TXC is based upon the international standards.Related information is publicly described on the TXC's website, and updated regularly. The document is compliant with the latest green product quality system directives at the time. 6. Revision "Sx" is for engineering samples only. PE/RD's approval required. 7. Revision "Ax" is production ready. PE, QA and MFG's approval required. 8. Inform TXC in advance if you use ultrasonic welding in assembling process . FMT-DOC024 VER.G TXC confidential and proprietary document
9B12070003 价格&库存
很抱歉,暂时无法提供与“9B12070003”相匹配的价格&库存,您可以联系我们找货
