AM24500002
AM24500002
    TXC(台晶)
    SMD3225_4P
    无源晶振 SMD3225_4P
AM24500002 数据手册
TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com SPECIFICATION FOR APPROVAL CUSTOMER : PRODUCT TYPE : SMD SEAM SEALING X'TAL 3.2×2.5 NOMINAL FREQ. : 24.545400MHz TXC P/N : AM24500002 REVISION : S1 CUSTOMER P/N : PM / SALES : DATE : CUSTOMER SIGNATURE & Date (1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance of the attached specifications. (2) Orders received and accepted by TXC after return of signed copy of specification will be produced per these specifications. (3) Any changes to these specifications must be agreed upon by both parties and new revision of the Product Specification Sheet will be issued. (4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. Attachment: Product Specification Sheet 1 2 3 4 5 FMT-DOC024 RoHS Compliant Issue Date: 12.15'08 VER.E TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com PRODUCT SPECIFICATION SHEET PRODUCT TYPE : SMD SEAM SEALING X'TAL 3.2×2.5 NOMINAL FREQ. : 24.545400MHz TXC P/N : AM24500002 REVISION : S1 PE/RD QA MFG 4-Nov-09 NOTE: (1)Lead Free Products are "Directive 2002/95/EC of The European Parliament of 27 January 2003 on the restriction of the use of certain hazardous substances (RoHS) in electrical and electronic equipment" Compliant (Attachment: SGS Test Report). (2)Revision "Sx" is for engineering samples only. PE/RD's approval required. (3)Revision "Ax" is production ready. PE, QA and MFG's approval required RoHS Compliant FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION Rev Revise page S1 N/A FMT-DOC024 TXC P/N: Revise contents Initial released AM24500002 REVISION: S1 PAGE: 1 Date Ref.No. Reviser 4-Nov-09 N/A Jane Lee Issue Date: 12.15'08 VER.E TXC CORPORATION AM24500002 TXC P/N: REVISION: S1 PAGE: 2 ■ ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature : 25±5℃ Relative humidity 40%~70% : If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature : 25±3℃ Relative humidity 40%~70% : Measure equipment Electrical characteristics measured by HP E5100A or equivalent. Crystal cutting type The crystal is using AT CUT (thickness shear mode). Unit Weight: 0.018±0.001 g/pcs Parameters 1 Nominal Frequency SYM. Electrical Spec. MIN TYPE FL 24.545400 MAX Notes UNITS - MHz - Fundamental - - CL 20 pF - 4 Frequency Tolerance - ±30 ppm at 25 ℃ ± 3 ℃ 5 Frequency Stability - ±30 ppm Over Operating Temp. Range (Reference 25℃) 6 Operating Temperature - 7 Aging - 2 Oscillation Mode 3 Load Capacitance -40 ~ 85 ±3 - ℃ ppm 1st Year 8 Drive Level DL - 100 - μW - 9 Effective Resistance Rr Rr - - 150 Ω - 10 Shunt Capacitance C0 C0 - - 5 pF 11 Insulation Resistance - 500 - - MΩ 12 Storage Temperature Range - -40 ~ 125 ℃ FMT-DOC024 at DC 100V - Issue Date: 12.15'08 VER.E TXC CORPORATION REVISION: S1 AM24500002 TXC P/N: ■ DIMENSIONS PAGE: 3 Unit:mm (Unit:mm) 0.70 ± 0.10 3.20 ± 0.10 GND 3 3 4 2.50 ± 0.10 4 1 GND 2 1 2 1.00±0.10 1.20±0.10 4 3 1.40 0.80 1.40 0.70±0.10 1.20 0.50 1.20 1 2 0.90±0.10 Internal View Connection Bottom View Suggested Layout ■ MARKING   T□□□ TXC Logo Pin 1 Location ■ Frequency Code ex:14.318180 MHz=143 □□□□ Lot Code Date Code Line Code Date Code: MONTH YEAR 2005 2009 2013 JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC 2017 A B C D E F G H J K L M 2006 2010 2014 2018 N P Q R S T U V W X Y Z 2007 2011 2015 2019 a b c d e f g h j k l m 2008 2012 2016 2020 n p q r s t u v w x y z *This date code will be cycled every four years Production location:Taiwan (℃) ■ SUGGESTED REFLOW PROFILE 10 sec 260 Total time : 200 sec. Max. Solder melting point :220 ℃ 220 180 150 Time (sec) 120 sec FMT-DOC024 60 sec Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: AM24500002 REVISION: S1 PAGE: 4 ■ STRUCTURE ILLUSTRATION A-A' sectional drawing B-B' sectional drawing NO COMPONENTS C-C' sectional drawing MATERIALS FINISH/SPECIFICATIONS 1 Lid Kovar (Fe/Co/Ni) - 2 Base(Package) Ceramic (AI2O3) + Kovar (Fe/Co/Ni)+ Ag/Cu Color black 3 PAD Au Tungsten metalize + Ni plating + Au plating 4 Crystal blank SiO2 - 5 Conductive adhesive Ag Silicon resin 6 Electrode - FMT-DOC024 Noble Metal Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: AM24500002 REVISION: S1 PAGE: 5 ■ PACKING F G B E H INDEX MARK A DIMENSIONS C Feeding D A B C D E F G H 1.65 3.4 2.7 4 8 4 1.5 1.75 (UNIT : mm) REMARK : W W1 2.0 L1 DIMENSIONS FMT-DOC024 L L1 W W1 178 13 11.5 8 L pcs / Reel (UNIT : mm) Standard Reel Quantity is 3,000 pcs per reel Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: AM24500002 REVISION: S1 PAGE: 6 ■ RELIABILITY SPECIFICATIONS 1.Mechanical Endurance Test Item No. 1.1 Drop Test Test Methods REF.DOC JIS C6701 120 cm height,5 times on ceramic surface . 1.2 Mechanical Shock 1.3 Vibration Device are shocked to half sine wave ( 3000 G ) three mutually perpendicular axes each 3 times. 0.3m sec. duration time Frequency range 10 ~ 2000 Hz~10 Hz Amplitude 1.52 mm/10G Sweep time 20 minute Perpendicular axes each test time 4 Hrs MIL-STD-202F Method 213B MIL-STD-202F Method 204D (Total test time 12 Hrs) 1.4 Solderability Temperature 245 ℃ ± 5℃ Immersing depth 0.5 mm minimum Immersion time 5 ± 1 seconds Flux Rosin resin methyl alcohol J-STD-002 solvent ( 1 : 4 ) 1.5 Terminal Strength Mount on PCB board and shear strength 1.8kg for 60 sec. AEC-Q200-006 2.Environmental Endurance Test Item No. Test Methods Resistance To Soldering Heat Pre-heat temperature 2.1 REF. DOC 125 ℃ Pre-heat time 60 ~ 120 sec. Test temperature 260 ± 5 ℃ Test time 20 ± 1 sec. MIL-STD 202F Method 210E 2.2 High Temp. Storage + 85 ℃ ± 3 ℃ for 1000 ± 12 Hrs MIL-STD-202F Method 108A 2.3 Low Temp. Storage - 40 ℃ ± 3 ℃ for 1000 ± 12 Hrs TABEI ESPEC Total 1000 cycles of the following Thermal Shock MLD-STD-202F Method 107G 2.4 Thermal Shock 2.5 Temperature Cycle Total 1000 cycles of the following temperature cycle - 40℃ ± 3 to 85℃ ± 3 , Dwell time
AM24500002 价格&库存
很抱歉,暂时无法提供与“AM24500002”相匹配的价格&库存,您可以联系我们找货
