TXC CORPORATION
4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan.
TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207
www.txccorp.com
SPECIFICATION FOR APPROVAL
CUSTOMER
PRODUCT TYPE
SMD GLASS SEALING X'TAL 3.2*2.5
NOMINAL FREQ.
27.000000MHz
TXC P/N
7V27000050
REVISION
A2
CUSTOMER P/N
PM / SALES
DATE
CUSTOMER SIGNATURE & Date
(1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance
of the attached specifications.
(2) Orders received and accepted by TXC after return of signed copy of specification will be produced per
these specifications.
(3) Any changes to these specifications must be agreed upon by both parties and new revision of the
Product Specification Sheet will be issued.
(4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets"
from customers will be regarded as the agreement on the contents of these specifications.
Attachment: Product Specification Sheet
1
2
3
4
5
FMT-DOC024
RoHS Compliant
Issue Data:12.15'08 VER.E
TXC CORPORATION
www.txccorp.com
PRODUCT SPECIFICATION SHEET
PRODUCT TYPE
NOMINAL FREQ.
27.000000MHz
TXC P/N
7V27000050
REVISION
A2
PE/RD
QA
MFG
4-May-09
4-May-09
4-May-09
NOTE:
(1)Lead Free Products are "Directive 2002/95/EC of The European Parliament of 27 January 2003
on the restriction of the use of certain hazardous substances (RoHS) in electrical and
electronic equipment" Compliant (Attachment: SGS Test Report).
(2)Revision "Sx" is for engineering samples only. PE/RD's approval required.
(3)Revision "Ax" is production ready. PE, QA and MFG's approval required.
RoHS Compliant
FMT-DOC024
TXC CORPORATION
Rev
Revise page
A1
N/A
A2
3
FMT-DOC024
TXC P/N:
Revise contents
7V27000050
A2
REVISION:
PAGE:
1
Date
Ref.No.
Reviser
Initial released
23-Dec-08
N/A
Xiaoyan Jiang
Marking Change
4-May-09
ECN-09N050404
Xiaoyan Jiang
TXC CORPORATION
7V27000050
TXC P/N:
A2
REVISION:
PAGE:
2
■ ELECTRICAL SPECIFICATIONS
Standard atmospheric conditions
Unless otherwise specified, the standard range of atmospheric conditions for making measurement
and tests are as follow:
Ambient temperature :
25±5℃
Relative humidity
40%~70%
If there is any doubt about the results, measurement shall be made within the following limits:
25±3℃
Relative humidity
40%~70%
Measure equipment
Electrical characteristics measured by HP E5100A or equivalent.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode).
Unit Weight:
0.018±0.001 g/pcs
Parameters
1 Nominal Frequency
2 Oscillation Mode
3 Load Capacitance
4 Frequency Tolerance
SYM.
Electrical Spec.
MIN
TYPE
FL
27.000000
MAX
Notes
UNITS
MHz
Fundamental
CL
10
pF
±10
ppm
at 25 ℃ ± 3 ℃
Rr
50
Ω
6 Operating Temperature Range
-20
70
7 Frequency Tolerance
5 Series Resonant Resistance
±10
8 Drive Level
DL
9 Shunt Capacitance
C0
100
10 Aging
11 Insulation Resistance
500
12 Storage Temperature Range
-40
FMT-DOC024
ppm
±3
Over Operating Temp. Range (Reference 25℃)
uW
pF
ppm
1st Year
MΩ
at DC 100V
85
TXC CORPORATION
TXC P/N:
7V27000050
A2
REVISION:
PAGE:
3
UNIT:mm
■ DIMENSIONS
■ MARKING
T□□□
TXC Logo
Frequency Code
ex:14.318180 MHz=143
Lot Code
Line Code
Date Code
Date Code
MONTH
YEAR
JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC
2001
2005
2009
2013
2017
A
B
C
D
E
F
G
H
J
K
L
M
2002
2006
2010
2014
2018
N
P
Q
R
S
T
U
V
W
X
Y
Z
2003
2007
2011
2015
2019
a
b
c
d
e
f
g
h
j
k
l
m
2004
2008
2012
2016
2020
n
p
q
r
s
t
u
v
w
x
y
z
This date code will be cycled every four years
■ SUGGESTED REFLOW PROFILE
Total time : 200 sec. Max.
Solder melting point :220 ℃
10 sec
260
220
180
150
Time (sec)
120 sec
FMT-DOC024
60 sec
TXC CORPORATION
TXC P/N:
7V27000050
REVISION:
A2
PAGE:
4
■ STRUCTURE ILLUSTRATION
NO
COMPONENTS
MATERIALS
FINISH/SPECIFICATIONS
1 Cap
Ceramic
Color black
2 Package
Ceramic
Color black
3 PAD
Au
4 Crystal blank
SiO2
5 Conductive adhesive Ag
Tungsten metalize
+ Ni plating
+ Au plating
Silicon resin
6 Electrode
Ag + Cr
7 Glass
FMT-DOC024
TXC CORPORATION
TXC P/N:
7V27000050
A2
REVISION:
PAGE:
5
■ PACKING : (EIA-481-2)
DIMENSIONS
A
B
C
D
E
F
G
H
1.40
3.40
2.70
4.00
8.00
4.00
1.50
1.75
(UNIT : mm)
REMARK :
Trailer
Parts
160mm(Min)
Leader
Empty Sealed
230mm(Min)
160mm(Min)
User direction of feed
W
W1
2.0
L1
DIMENSIONS
FMT-DOC024
L
L1
W
W1
178
13
11.5
8
L
pcs / Reel (UNIT : mm)
Standard Reel Quantity is 3,000 pcs per reel
TXC CORPORATTXC P/N: 7V27000050
REVISION:
PAGE:6
A2
■ RELIABILITY SPECIFICATIONS
1.Mechanical Endurance
No.
Test Item
Test Methods
CRITIREA
REF.DOC
1.1 Drop Test
100 cm height, 3 times on concrete floor.
△F/F
很抱歉,暂时无法提供与“7V27000050”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.30102
- 30+1.25456
- 100+1.20809
- 500+1.11516
- 1000+1.06870
- 2000+1.04082
