TXC CORPORATION
5F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan.
TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207
www.txccorp.com
SPECIFICATION FOR APPROVAL
CUSTOMER
PRODUCT TYPE
SMD SEAM SEALING CXO 7.0*5.0
NOMINAL FREQ.
26.000000MHz
TXC P/N
7W26000029
REVISION
S1
CUSTOMER P/N
PM / SALES
DATE
CUSTOMER SIGNATURE & Date
(1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance
of the attached specifications.
(2) Orders received and accepted by TXC after return of signed copy of specification will be produced per
these specifications.
(3) Any changes to these specifications must be agreed upon by both parties and new revision of the
Product Specification Sheet will be issued.
(4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets"
from customers will be regarded as the agreement on the contents of these specifications.
Attachment: Product Specification Sheet
1
2
3
4
5
RoHS Compliant
FMT-DOC024
Issue Date: 03.09'06 VER.D
TXC CORPORATION
www.txccorp.com
PRODUCT SPECIFICATION SHEET
PRODUCT TYPE
NOMINAL FREQ.
26.000000MHz
TXC P/N
7W26000029
REVISION
S1
PE/RD
QA
MFG
14-Jul-06
NOTE:
(1)Lead Free Products are "Directive 2002/95/EC of The European Parliament of 27 January 2003
on the restriction of the use of certain hazardous substances (RoHS) in electrical and
electronic equipment" Compliant (Attachment: SGS Test Report).
(2)Revision "Sx" is for engineering samples only. PE/RD's approval required.
(3)Revision "Ax" is production ready. PE, QA and MFG's approval required.
RoHS Compliant
FMT-DOC024
TXC CORPORATION
Rev
Revise page
S1
N/A
FMT-DOC024
TXC P/N: 7W26000029
Revise contents
Initial released
REVISION:
S1
PAGE:
1
Date
Ref.No.
Reviser
14-Jul-06
N/A
Yachuan Miao
TXC CORPORATION
TXC P/N: 7W26000029
REVISION:
S1
PAGE:
2
■ ELECTRICAL SPECIFICATIONS
Standard atmospheric conditions
Unless otherwise specified, the standard range of atmospheric conditions for making measurement
and tests are as follow:
Ambient temperature :
25±5℃
Relative humidity
40%~70%
If there is any doubt about the results, measurement shall be made within the following limits:
25±3℃
Relative humidity
40%~70%
Measure equipment
Electrical characteristics measured by MD 37WX-05M or equivalent.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode).
Unit Weight:
0.152±0.001 g/pcs
Parameters
SYM.
Electrical Spec.
MIN
TYPE
MAX
Notes
UNITS
1 Nominal Frequency
26.000000
MHz
2 Frequency Stability
±20
ppm
Topr
-20
4 Storage Temperature
Tstg
-55
5 Supply Voltage
VDD
3 Operating Temperature
Icc
6 Input Current
7 Enable Control
8 Output Load :
CMOS
25
70
125
V
mA
3.3 ±10%
10
Yes
CL
15
pF
Pad 1
9 Output Voltage High
VoH
2.97
V
10 Output Voltage Low
VoL
0.33
V
11 Rise Time
Tr
5
ns
10%→90%VDD Level
12 Fall Time
Tf
5
ns
90%→10%VDD Level
13 Symmetry (Duty ratio)
TH/T
45
55
14 Start-up Time
Tosc
10
ms
15 Enable Voltage High
Vhi
70%Vdd
V
16 Disable Voltage Low
Vlo
30%Vdd
V
17 Aging
±3
ppm/yr. 1st. Year at 25℃
18 Output Disable Delay Time
T off
100
nS
19 Output Enable Delay Time
T on
100
nS
FMT-DOC024
TXC CORPORATION
TXC P/N: 7W26000029
S1
REVISION:
PAGE:
3
■ DIMENSIONS
7.0 ± 0.2
1.3 ± 0.115
5.0± 0.2
Pin Function:
1:ENABLE
CONTROL
2:GND
3:OUT
4:VDD
1.4
4.2
2.6
2
5.08
1.1
1.8
4
5.08
Suggested Layout
Units:mm
■ MARKING
Output Level
Line Code
Date Code
TXC XXXXX
Logo
Lot Code
#1 Pin Location
XX.XXX -
Administrative Symbol
Frequency(MHz)
ex:14.318180=14.318
Production location:Taiwan
Output Level:
VDD
5.0V
3.3V
2.8V
2.5V
1.8V
2.9V
3.0V
2.85V
2.6V
CODE
A
B
C
D
E
F
G
H
J
Date Code
MONTH
YEAR
JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC
2001
2005
2009
2013
2017
A
B
C
D
E
F
G
H
J
K
L
M
2002
2006
2010
2014
2018
N
P
Q
R
S
T
U
V
W
X
Y
Z
2003
2007
2011
2015
2019
a
b
c
d
e
f
g
h
j
k
l
m
2004
2008
2012
2016
2020
n
p
q
r
s
t
u
v
w
x
y
z
This date code will be cycled every four years
FMT-DOC024
TXC CORPORATION
TXC P/N: 7W26000029
REVISION:
S1
PAGE:
4
■ TEST DIAGRAM
Control input (output enable/disable)
Logic 1 or open on pad 1: Oscillator output
Logic 0 on pad 1 : Disable output to high impedance
A
Supply Voltage
4
3
VDD
OUT
0.01 OE
uF
V
GND
1
2
TEST POINT
CL: Output Load
Same Output
Load of Electrical Specifications
(Including Probe
and Fixture
Capacitance)
■ WAVEFORM CONDITIONS
Waveform measurement system should
have a min. bandwidth of 5 times the
frequency being tested.
Tr
Tf
Symmetry=TH/Tx100(%)
VDD
90% VDD
1/2 VDD
10% VDD
GND
TH
T
FMT-DOC024
VOH
VOL
TXC CORPORATION
TXC P/N: 7W26000029
REVISION:
S1
PAGE:
5
■ OUTPUT ENABLE / DISABLE DELAY
The following figure shows the oscillator timing during normal operation . Note that when the device is in standby,
the oscillator stops. When standby is released, the oscillator starts and stable oscillator output occurs after a
short delay.
Pin 1:Enable Control
Vdd 50 %
Vdd 10 %
T on
T off
Vdd 90 %
Q output
■ SUGGESTED REFLOW PROFILE
Total time : 200 sec. Max.
Solder melting point :220 ℃
10 sec
260
220
180
150
Time (sec)
120 sec
FMT-DOC024
60 sec
TXC CORPORATION
TXC P/N: 7W26000029
S1
REVISION:
PAGE:
6
■ STRUCTURE ILLUSTRATION
NO
COMPONENTS
MATERIALS
QTY
1
FINISH/SPECIFICATIONS
1 Lid
Kovar (Fe/Co/Ni)
2 Base(Package)
Ceramic (AI2O3) + Kovar (Fe/Co/Ni)+ Ag/Cu 1
Color black
3 PAD
Au
Tungsten metalize
4
+ Ni plating
+ Au plating
4 IC chip
1
5 Bonding wire
Au
5 or 6
Pad 1 options : NC is 5 wires ,
6 Crystal blank
SiO2
1
7 Conductive adhesive
Ag
4
Silicon resin
8 Electrode
Cr & Ag
2
9 Conductive adhesive
Ag
1
Epoxy resin
EN is 6 wires.
FMT-DOC024
TXC CORPORATION
TXC P/N: 7W26000029
S1
REVISION:
PAGE:
7
■ PACKING : (EIA-481-2)
F
G
B
E
H
INDEX MARK
A
DIMENSIONS
C
Feeding
D
A
B
C
D
E
F
G
H
2.00
7.90
5.45
8.00
16.00
4.00
1.50
1.75
(UNIT : mm)
REMARK :
Trailer
Parts
160mm(Min)
Empty Sealed
Leader
230mm(Min)
160mm(Min)
User direction of feed
W
W1
2.0
L1
DIMENSIONS
FMT-DOC024
L
L
L1
W
W1
pcs / Reel (UNIT : mm)
180
13
20.5
16
Standard Reel Quantity is 1,000 pcs per reel
TXC CORPORATION
TXC P/N: 7W26000029
REVISION:
S1
PAGE:
8
■ RELIABILITY SPECIFICATIONS
1.Mechanical Endurance
No.
Test Item
1.1 Drop Test
Test Methods
REF. DOC
JIS C6701
75 cm height,3 times on concrete floor .
1.2 Mechanical Shock
1.3 Vibration
Device are shocked to half sine wave ( 1000 G ) three mutually
perpendicular axes each 3 times. 0.5m sec. duration time
Frequency range
10 ~ 2000 Hz
Amplitude
1.52 mm/20G
Sweep time
20 minute
Perpendicular axes each test time
4 hours
MIL-STD-202F
MIL-STD-883E
(Total test time 12 hours)
1.4 Gross Leak
Standard Sample For Automatic Gross Leak Detector, Test Pressure: 2Kg / cm2
1.5 Fine Leak
Helium Bomging 4.5 Kgf / cm 2 for 2 hr
1.6 Solderability
MIL-STD-883E
Temperature
260 ℃ ± 5℃
Immersing depth
0.5 mm minimum
Immersion time
5 ± 1 seconds
Flux
Rosin resin methyl alcohol
MIL-STD-883E
solvent ( 1 : 4 )
2.Environmental Endurance
No.
Test Item
2.1 Resistance To Soldering Heat
Test Methods
Pre-heat temperature
125 ℃
Pre-heat time
60 ~ 120 sec.
Test temperature
260 ± 5 ℃
Test time
10 ± 1 sec.
2.2 High Temp. Storage
+ 125 ℃ ± 3 ℃ for 1000 ± 12 hours
2.3 Low Temp. Storage
- 40 ℃ ± 3 ℃ for 1000 ± 12 hours
REF. DOC
MIL-STD-202F
MIL-STD-883E
Total 100 cycles of the following temperature cycle
1 cycle
125 ± 3 ℃
2.4 Thermal Shock
MIL-STD-883E
25 ℃
-55 ± 3 ℃
10 min.
10 min.
10 min. max.
2.5 Pressure Cooker Storage
121 ± 3℃ , RH100% , 2 bar , 240Hrs
JIS C6701
2.6 High Temp&Humidity
85℃ ± 3℃, RH 85% , 1000Hrs
JIS C5023
FMT-DOC024
很抱歉,暂时无法提供与“7W26000029”相匹配的价格&库存,您可以联系我们找货
