7Z26003005
7Z26003005
    TXC(台晶)
    SMD2016-4P
7Z26003005 数据手册
come visit our site http://www.txccorp.com SMD TCXO 2.0 x 1.6 x 0.75 mm 7Z Series Oscillators Series Think of Frequency Think of Features .Temperature Stability: ± 0.5 ppm ~ ± 2.0 ppm. .Operating Temperature Range: - 30 ℃ ~ 85 ℃. * BC 9 TA A0 26 .Supply Voltage: 1.8 V ~ 3.3 V. .Voltage Control Function Available. .World's Thinnest Package. .Frequencies: 26 MHz, 33.6 MHz, 38.4 MHz, 40 MHz, 52 MHz. .Applications: GPS, WiMAX, Cellular and Wireless Communications. .RoHS Compliant / Pb Free. Electrical Specifications 7Z Clipped Sinewave Output Load 10KΩ // 10 pF Oscillation Mode Fundamental Supply Voltage 1.8 ~ 3.3 V Frequency Range 26 ~ 52 MHz Clipped Sinewave Output Voltage Vs. Temperature ( - 30 ~ + 85 ℃ ) Frequency Stability 0.8 Vp-p typical ± 0.5 / ± 2.0 ppm Vs. Load ( Load varies ± 10 % ) ± 0.2 ppm Max. Vs. Supply Voltage ( Vcc = Typical ± 0.1 V ) ± 0.2 ppm Max. Frequency Tolerance at 25 ℃ after 2 Reflows with Typical Applied to Auto Frequency Control Pin Slope of Frequency Drift Storage Temperature Range Auto Frequency Control ( AFC ) Range * Supply Current Start-up Time ± 2.5 ppm Max. ± 0.1 ppm / ℃ Typical ; ± 0.5 ppm / ℃ Max. - 40 ~ + 85 ℃ ± 7 ~ ± 16 ppm (1.4±1V) 2.0 mA Max. 5 ms Max. Harmonics - 5 dBc Max. Phase Noise at 1 kHz offset - 130 dBc / Hz Aging ( at 25 ℃ ) Dimensions ± 1 ppm / year Max. * AFC Range is selective and disable is acceptable. Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com Item / Type Output Type Units: mm 89
7Z26003005 价格&库存
很抱歉,暂时无法提供与“7Z26003005”相匹配的价格&库存,您可以联系我们找货
