AT04000004
AT04000004
    TXC(台晶)
    HC-49S/SMD
    无源晶振 HC-49S/SMD
AT04000004 数据手册
TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com SPECIFICATION FOR APPROVAL CUSTOMER : PRODUCT TYPE : HC-49/S SMD NOMINAL FREQ. : 4.000000MHz TXC P/N : AT04000004 REVISION : A1 CUSTOMER P/N : PM / SALES : DATE : CUSTOMER SIGNATURE & Date (1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance of the attached specifications. (2) Orders received and accepted by TXC after return of signed copy of specification will be produced per these specifications. (3) Any changes to these specifications must be agreed upon by both parties and new revision of the Product Specification Sheet will be issued. (4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. Attachment: Product Specification Sheet 1 2 3 4 5 RoHS Compliant FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com PRODUCT SPECIFICATION SHEET PRODUCT TYPE : HC-49/S SMD NOMINAL FREQ. : 4.000000MHz TXC P/N : AT04000004 REVISION : A1 PE/RD QA MFG 2011/12/17 2011/12/17 2011/12/17 NOTE: (1)Lead Free Products are "Directive 2002/95/EC of The European Parliament of 27 January 2003 on the restriction of the use of certain hazardous substances (RoHS) in electrical and electronic equipment" Compliant (Attachment: SGS Test Report). (2)Revision "Sx" is for engineering samples only. PE/RD's approval required. (3)Revision "Ax" is production ready. PE, QA and MFG's approval required RoHS Compliant FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION Rev Revise page A1 N/A FMT-DOC024 TXC P/N: AT04000004 Revise contents Initial Released REVISION:A1 PAGE: 1 Date Ref.No. Reviser 2011/12/17 N/A Xiaoyan Jiang Issue Date: 12.15'08 VER.E TXC P/N: TXC CORPORATION AT04000004 REVISION: A1 PAGE: 2 Spec Sheet Contents No. Page Content 1 ELECTRICAL SPECIFICATIONS P.3 2 FACTORY LOCATION P.3 3 DIMENSIONS P.4 4 SUGGESTED REFLOW PROFILE& MANUAL SOLDER CONDITION P.4 5 MARKING P.5 6 STRUCTURE ILLUSTRATION P.6 7 EMBOSS CARRIER TAPE & REEL P.7 8 PACKING P.7 9 RELIABILITY SPECIFICATIONS P.8~9 ATTACHMENT(S) (optional) TESTING DATA FMT-DOC024 • ELECTRICAL CHARACTERISTICS TEST A YES NO • TEMPERATURE CHARACTERISTICS TEST B YES NO Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: AT04000004 REVISION: A1 PAGE: 3 ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature : 25+/-5oC Relative humidity 40%~70% : If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature : 25+/-1oC Relative humidity 40%~70% : Measure equipment SAUNDERS 250A/250B CRYSTAL IMPEDANCE METER. Crystal cutting type The crystal is using AT CUT (thickness shear mode). Unit Weight: 0.58±0.050 g/pcs please refer to marking code page Parameters 1 Nominal Frequency 2 Oscillation Mode 3 Load Capacitance SYM. Electrical Spec. MIN TYPE MAX Notes UNITS FL 4.000000 MHz - - Fundamental - - CL 9 pF - 4 Frequency Tolerance - ±20 ppm at 25 ℃ ± 3 ℃ 5 Frequency Tolerance - ±30 ppm Over Operating Temp. Range (Reference 25℃) 6 Operating Temperature - 7 Aging - -40 ~ 85 ±5 - ℃ ppm 1st Year 8 Drive Level DL 10 100 300 uW - 9 Effective Resistance Rr Rr - - 90 Ω - 10 Shunt Capacitance C0 C0 pF - 11 Motional Capacitance (C1) 1.7+/-30% C1 3.8+/-30% fF - 12 L1 - 420+/-30% mH - 13 TS - - - 30 ppm/pF 14 Insulation Resistance - 500 - - MΩ 15 Storage Temperature Range - -40 ~ 125 ℃ at DC 100V - ■ FACTORY LOCATION TXC (NINGBO) CORPORATION NO.189 Huang Shan West Road, Beilun District, Ningbo Zhejiang China FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: AT04000004 REVISION: A1 UNIT:mm DIMENSIONS 4.35+/-0.5 0.2+/-0.1 11.4+/-0.2 10.15 Max 3.75 Max 1.0 Max 0.65+/-0.1 2.5+/-0.2 4.5 Max 0.4+/-0.2 0.3+/-0.1 0.4+/-0.3 0.4+/-0.3 +0.1 0.8+/-0.2 4.8 Max 4.5 Max PAGE: 4 4.3+/-0.4 -0.2 4.5 Max 12.25+/-0.5 Solder Coating (Sn-Ag-Cu Pb Free Coating) Suggested Layout 4 5.5 (x2) 2.0 (x2) ■ SUGGESTED REFLOW PROFILE Solder melting point :220±10 ℃, 60 sec. Min. Peak Temperature: 260 ± 5 ℃, 10 sec. Max. (℃) 10 sec 260 220 180 ■ SUGGESTED MANUAL SOLDER CONDITION 150 Temperature: 350 ± 10 ℃ Time: 3 sec. Re-solder times: twice FMT-DOC024 Time (sec) 120 sec 60 sec Issue Date: 12.15'08 VER.E TXC P/N: AT04000004 TXC CORPORATION REVISION: A1 PAGE: 5 MARKING Marking For Pb Free Parts: TXC TXC Logo Pb Free Product G Lot Code (2 digits) Frequency Code Production Line Code Date Code Date Code: MONTH JAN FEB MAR APR MAY YEAR 2001 2005 2009 2013 2017 A B C D E 2002 2006 2010 2014 2018 N P Q R S 2003 2007 2011 2015 2019 a b c d e 2004 2008 2012 2016 2020 n p q r s *This date code will be cycled every four years. For example : JUN JUL AUG SEP OCT NOV DEC F T f t G U g u H J V W h j v w K X k x L Y l y M Z m z Marking TXC G 4.00Mn01 FMT-DOC024 Pb Free Product Introduction: 49S/SMD 4.000 MHz Made in NGB 2008/JAN 01Lot Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: AT04000004 REVISION: A1 PAGE: 6 ■ STRUCTURE ILLUSTRATION NO COMPONENTS MATERIALS FINISH/SPECIFICATIONS 1 CRYSTAL BLANK SiO2 - 2 SUPPORTER Nickel Silver(Cu/Zn/Ni) - 3 BASE Fe Ni Plated 4 CAN Nickel Silver(Cu/Zn/Ni) - 5 LEAD Kovar (Fe/Co/Ni) 6 GLASS GLASS Ni Plated+Solder( Sn/Ag/Cu) Dipped - 7 CONDUCTIVE ADHESIVEResin + Ag - 8 ELECTRODE Ag - 9 INSULATION PAD PPS - FMT-DOC024 Issue Date: 12.15'08 VER.E TXC P/N: AT04000004 TXC CORPORATION REVISION: A1 PAGE: 7 (A) Tape and reel configuration:(Unit:mm) ( a)Emboss taping configuration. (per EIA-481-2) 5o max. H (+/-0.1) 4.35 3.5 5.0+/-0.1 5o max. H 11.5+/-0.1 TYP. S3 S2 0.4+/-0.1 24.0+/-0.15 +0.1 1.5 -0.0 2.0+/-0.1 15+/-0.1 1.75+/-0.1 40(10P)+/-0.2 4.0+/-0.1 12.0+/-0.1 1.5 Min Direction of start NONE NONE 22.0 Max. Products put in 1000 pcs Max. COVER TAPE 160 Min 230 Min. 160 Min 390 Min ( b)Reel configuration. (B) Packing & Label :(Unit:mm) COVER TAPE 120° 24.4+/-0.2 75+/-3 14.0+/-0.2 ● ● ● ● ● ● ● ● ● ● ● ● ● ● 22.0+/-0.4 330+/-1 B 2.3+/-0.2 3.3+/-0.2 3.3+/-0.2 PUT IN 330+/-5 Label B ( Example ) B 330+/-5 35+/-5 PUT IN Label C ( Example ) C B # (1) Put in stuff between space. (2) Tie Up the Carton with 4 Packthreads. [STORAGE] 1.The storage time to be 1 year maximum. 2.Don't be caught in the rain. 3.The storage environment shall be 5℃ ~40℃ temperature and 30% ~ 75%RH humidity and free from the sun shine. 4.If customers have special requirements, we can paste labels according to it. FMT-DOC024 Issue Date: 12.15'08 VER.E TXC P/N: TXC CORPORATION AT04000004 REVISION: A1 PAGE: 8 ■ RELIABILITY SPECIFICATIONS 1.Mechanical Endurance Test Item No. 1.1 1.2 Mechanical Shock Vibration Test Methods Test Criteria 1000 G , 0.5 m Sec. , 3 times for all 3 directions. Frequency range 10 ~ 2000 Hz Acceleration 5G Sweep time 20 minute Pendicular axes each test time 4 hours BC BC (Total test time 12 hours) 1.3 Terminal Strength 17.7N force for 60sec +/-1sec. 1.4 Board Flex Duration time:60 Sec Minimum,Deviation:3mm F BC 2.Environmental Endurance Test Item No. 2.1 2.2 Solderability Resistance To Soldering Heat Test Methods SPEC Pb free :Temperature 235±5℃,Immersion time:5±1sec E Pb :Temperature 215±5℃,Immersion time:5±1sec Test temperature 260 +/- 5 oC Test time 10 +/- 1 sec. Emersion Rate 25 ± 6 mm/s Immersed of specimen 1.5mm ACD 2.3 High Temp. Storage + 85℃ ± 3 ℃ for 1000 ± 12 Hrs ACD 2.4 Low Temp. Storage - 40 ℃ ± 3 ℃ for 1000 ± 12 Hrs ACD -40℃~85℃,for 1000 cycles. B C D 1 cycle 85+/-3 0C 2.5 Thermal Shock 25 0C -40+/-3 0C ACD 5 min. 5 min. 10 Sec. 1000 hrs @ 85± 3°C. Rated VDD applied with 1 MΩ. 2.6 Operational Life 2.7 High Temp&Humidity 85℃ ± 3℃ , RH 85% , 1000 Hrs FMT-DOC024 ACD ACD Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: AT04000004 REVISION A1 PAGE: 9 RELIABILITY SPECIFICATIONS Specifications A Frequency change: Within ±20ppm or in customer's specification. B Frequency change: Within ±10ppm or in customer's specification. C Equivalent series resistance(E.S.R) change: Within ±15% or 10Ω(larger value). D After conditioning , quartz crystal units shall be subjected to standard atmospheric conditions for 24 hour, and measured. E Minimum 95% of immersed terminal shall be covered with new uniform solder. F No damage on specimen Measurement condition Measurements are carried out with Network-analyzer( S&A 250B or equivalent). FMT-DOC024 Issue Date: 12.15'08 VER.E
AT04000004
- 物料型号:HC-49/S SMD - 器件简介:文档中未提供详细的器件简介,但提到了该器件是符合RoHS标准的无铅产品。 - 引脚分配:文档中没有明确提供引脚分配图,但提供了结构示意图,包括晶体空白、支撑器、底座、罐、引线、玻璃、导电胶、电极和绝缘垫。 - 参数特性: - 标称频率:4.000000MHz - 振荡模式:基频 - 负载电容:9pF - 频率容差:+20ppm(25°C±3°C时)和±30ppm(整个工作温度范围,参考25°C) - 工作温度:-40℃至85℃ - 老化率:首年±5ppm - 驱动电平:10uW至300uW - 有效电阻Rr:90pΩ - 并联电容Co:1.7pF(±30%) - 动态电容C1:3.8fF(±30%) - L1:420mH(±30%) - TS:30ppm/pF - 绝缘电阻:500MΩ(在DC 100V下) - 存储温度范围:-40℃至125℃ - 功能详解:文档中未提供详细的功能详解,但提供了电气规格和可靠性规格。 - 应用信息:文档中未明确提供应用信息,但根据器件的规格和特性,可以推断它可能用于需要精确时钟信号的电子设备。 - 封装信息:提供了尺寸信息和建议的回流焊接配置。
AT04000004 价格&库存
很抱歉,暂时无法提供与“AT04000004”相匹配的价格&库存,您可以联系我们找货
