TXC CORPORATION
4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan.
TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207
www.txccorp.com
SPECIFICATION FOR APPROVAL
CUSTOMER
PRODUCT TYPE
SMD GLASS SEALING XTAL 5.0*3.2
NOMINAL FREQ.
13.560000MHz
TXC P/N
AA13500001
REVISION
S4
CUSTOMER P/N
PM / SALES
DATE
CUSTOMER SIGNATURE & Date
(1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance
of the attached specifications.
(2) Orders received and accepted by TXC after return of signed copy of specification will be produced per
these specifications.
(3) Any changes to these specifications must be agreed upon by both parties and new revision of the
Product Specification Sheet will be issued.
(4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets"
from customers will be regarded as the agreement on the contents of these specifications.
Attachment: Product Specification Sheet
1
2
3
4
5
RoHS Compliant
Pb used in sealing glass material is exempt from EU directive
FMT-DOC024
Issue Date: 12.15'08 VER.E
TXC CORPORATION
www.txccorp.com
PRODUCT SPECIFICATION SHEET
PRODUCT TYPE
NOMINAL FREQ.
13.560000MHz
TXC P/N
AA13500001
REVISION
S4
PE/RD
QA
MFG
18-Jun-09
NOTE:
(1)Lead Free Products are "Directive 2002/95/EC of The European Parliament of 27 January 2003
on the restriction of the use of certain hazardous substances (RoHS) in electrical and
electronic equipment" Compliant (Attachment: SGS Test Report).
(2)Revision "Sx" is for engineering samples only. PE/RD's approval required.
(3)Revision "Ax" is production ready. PE, QA and MFG's approval required.
RoHS Compliant
FMT-DOC024
TXC CORPORATION
Rev
Revise page
S1
N/A
S2
Page 3
S3
N/A
S4
Page 3
FMT-DOC024
TXC P/N: AA13500001
REVISION: S4
PAGE: 1
Date
Ref.No.
Reviser
Initial released
22-Oct-08
N/A
Chao Kang
Change the inaccuracy of the
electrodes from ±0.15mm to ±0.1mm
8-Dec-08
N/A
Chao Kang
Version Change "E"
16-Apr-09
Production Drawing changed
18-Jun-09
Revise contents
ECN-08P112702 Xiaoyan Jiang
N/A
Xiaoyan Jiang
TXC P/N: AA13500001
TXC CORPORATION
REVISION: S4
PAGE: 2
■ ELECTRICAL SPECIFICATIONS
Standard atmospheric conditions
Unless otherwise specified, the standard range of atmospheric conditions for making measurement
and tests are as follow:
Ambient temperature :
25±5℃
Relative humidity
40%~70%
If there is any doubt about the results, measurement shall be made within the following limits:
25±3℃
Relative humidity
40%~70%
Measure equipment
Electrical characteristics measured by Saunders 250B Network Analyzer.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode).
Unit Weight:
0.054±0.05 g/pcs
Parameters
SYM.
Electrical Spec.
MIN
TYPE
MAX
Notes
UNITS
FL
13.560000
MHz
Fundamental
CL
12
pF
4 Frequency Tolerance
±15
ppm
at 25 ℃ ± 3 ℃
5 Frequency Stability
±30
ppm
Over Operating Temp. Range (Reference 25℃)
6 Operating Temperature
7 Aging
1 Nominal Frequency
2 Oscillation Mode
3 Load Capacitance
-40
85
±3
ppm
1st Year
8 Drive Level
DL
10
100
uW
9 Effective Resistance (Rr)
Rr
100
Ω
10 Shunt Capacitance (C0)
C0
2.0
pF
11 Drive Level Dependency (DLD2 DLD2
5
Ω
12 Insulation Resistance
500
MΩ
13 Storage Temperature Range
-40
105
FMT-DOC024
Sweep from 10nW to 100uW
at DC 100V
TXC P/N: AA13500001
TXC CORPORATION
REVISION: S4
PAGE: 3
■ DIMENSIONS
■ MARKING
TXC □□□□
TXC Logo
Frequency Code
ex:14.318180 MHz=14.3
Line Code
Date Code
Lot Code
Date Code:
MONTH
YEAR
JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC
2005
2009
2013
2017
A
B
C
D
E
F
G
H
J
K
L
M
2006
2010
2014
2018
N
P
Q
R
S
T
U
V
W
X
Y
Z
2007
2011
2015
2019
a
b
c
d
e
f
g
h
j
k
l
m
2008
2012
2016
2020
n
p
q
r
s
t
u
v
w
x
y
z
*This date code will be cycled every four years
Production location: China
■ SUGGESTED REFLOW PROFILE
Total time : 200 sec. Max.
Solder melting point :220 ℃
10 sec
260
220
180
150
Time (sec)
120 sec
FMT-DOC024
60 sec
TXC P/N: AA13500001
TXC CORPORATION
REVISION: S4
PAGE: 4
■ STRUCTURE ILLUSTRATION
NO
COMPONENTS
1 Cap
MATERIALS
Ceramic
2 Base(Package)
Ceramic (AI2O3)
3 PAD
Au
FINISH/SPECIFICATIONS
Color black
Tungsten metalize
+ Ni plating
+ Au plating
4 Crystal blank
SiO2
5 Conductive adhesive
Ag
6 Electrode
Noble Metal
7 Glass
FMT-DOC024
Silicon resin
TXC CORPORATION
TXC P/N: AA13500001
REVISION: S4
PAGE: 5
■ PACKING : (EIA-481-2)
F
E
B
H
G
C
A
DIMENSIONS
D
Feeding
A
B
C
D
E
F
G
H
1.40
5.40
3.60
8.00
12.00
4.00
1.55
1.75
(UNIT : mm)
REMARK :
Trailer
Parts
Leader
Empty Sealed
160mm(Min)
230mm(Min)
160mm(Min)
User direction of feed
W
W1
2.0
L1
DIMENSIONS
FMT-DOC024
L
L
L1
W
W1
pcs / Reel (UNIT : mm)
180
13
16.5
12
Standard Reel Quantity is 1,000 pcs per reel
TXC CORPORATION
TXC P/N:
AA13500001
REVISION:
S4
PAGE:
6
■ RELIABILITY SPECIFICATIONS
1.Mechanical Endurance
Test Methods
REF.DOC
1.1 Drop Test
120 cm height,3 times on concrete floor .
JIS C6701
1.2 Mechanical Shock
5000G, 0.3 mSec. duration time, 3 times for all 3 directions.
No.
Test Item
1.3 Vibration
Frequency range
10 ~ 2000 Hz
Amplitude
1.52 mm/20G
Sweep time
20 minutes
Perpendicular axes each test time
4 hours
MIL-STD-202F
MIL-STD-883E
(Total test time 12 hours)
1.4 Solderability
Temperature
245 ℃ ± 5℃
Immersing depth
0.5 mm minimum
Immersion time
5 ± 1 seconds
Flux
Rosin resin methyl alcohol
J-STD-002
solvent ( 1 : 4 )
1.5 Terminal Strength
Mount on PCB board and shear strength 1.8kg for 60 sec.
MIL-STD-883E
2.Environmental Endurance
No.
Test Item
2.1 Resistance To Soldering Heat
Test Methods
Pre-heat temperature
125 ℃
Pre-heat time
60 ~ 120 sec.
Test temperature
260 ± 5 ℃
Test time
10 ± 1 sec.
2.2 High Temp. Storage
+ 125 ℃ ± 3 ℃ for 1000 ± 12 hours
2.3 Low Temp. Storage
- 40 ℃ ± 3 ℃ for 1000 ± 12 hours
REF. DOC
MIL-STD-202F
MIL-STD-883E
Total 1000 cycles of the following Thermal Shock
2.4 Thermal Shock
MIL-STD-883E
2.5 Temperature Cycle
Total 1000 cycles of the following temperature cycle
- 40℃ ± 3 to 125℃ ± 3 , Dwell time 15min. ,
2.6 High Temp&Humidity
85℃ ± 3℃ , RH 85% , 1000hours
2.7 Moisture Resistance
10 cycles ( +25℃~65℃ , 80%~100% RH) , 24hrs/cycle
2.8 Operational Life
+125℃±3℃ for 1000±12 hours ,rated V:1MΩ
FMT-DOC024
EIA-JESD22-A101B
MIL-STD-202F
JIS C6701
很抱歉,暂时无法提供与“AA13500001”相匹配的价格&库存,您可以联系我们找货
