7V24580012
7V24580012
    TXC(台晶)
    SMD3225_4P
    无源晶振 SMD3225_4P
7V24580012 数据手册
: Serial No. TXC CORPORATION Issue Date 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com SPECIFICATION CUSTOMER : PRODUCT TYPE : SMD GLASS SEALING XTAL 3.2 × 2.5 NOMINAL FREQ. : 24.576000MHz TXC P/N : 7V24580012 REVISION : A1 CUSTOMER P/N : Customer Signature & Date (1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance of the attached specifications. (2) Orders received and accepted by TXC after return of signed copy of specification will be produced per these specifications. (3) Any changes to these specifications must be agreed upon by both parties and new revision of the Product Specification Sheet will be issued. (4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. PE/RD PREPA Robin Huang QA MFG PREPA P PRE PREPA PREPA P PRE PREPA Samson Xiong Jake Liu RoHS Compliant FMT-R&D039 Issue Date: 10.16'08 VER.B TXC CORPORATION Rev Revise page S1 N/A A1 N/A FMT-DOC024 TXC P/N: Revise contents 7V24580012 REVISION: A1 PAGE: 1 Date Ref.No. Reviser Initial released 11-Mar-14 N/A Xiaoyan Jiang S Turn A 15-Apr-14 N/A Xiaoyan Jiang Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 7V24580012 REVISION: A1 PAGE: 2 Spec Sheet Contents No. Content Page 1 ELECTRICAL SPECIFICATIONS P.3 2 FACTORY LOCATION P.3 3 DIMENSIONS P.4 4 MARKING P.4 5 SUGGESTED REFLOW PROFILE& MANUAL SOLDER CONDITION P.4 6 STRUCTURE ILLUSTRATION P.5 7 EMBOSS CARRIER TAPE & REEL P.6 8 PACKING P.7 9 RELIABILITY SPECIFICATIONS FMT-DOC024 P.8~9 Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 7V24580012 REVISION: A1 PAGE: 3 ■ ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature : 25±5℃ Relative humidity 40%~70% : If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature : 25±3℃ Relative humidity 40%~70% : Measure equipment Electrical characteristics measured by S&A250B or equivalent. Crystal cutting type The crystal is using AT CUT (thickness shear mode). Unit Weight: 0.018±0.001 g/pcs Parameters 1 Nominal Frequency SYM. Electrical Spec. MIN TYP MAX Notes UNITS FL 24.576000 MHz - - Fundamental - - CL 9 pF - 4 Frequency Tolerance - ±15 ppm at 25 ± 3 ℃ 5 Frequency Stability - ±20 ppm Over Operating Temp. Range (Reference 25℃) 6 Operating Temperature - -20 ~ 85 ℃ 7 Aging - -15 ~ 5 ppm 8 Drive Level DL - 100 300 uW - 9 Equivalent Resistance Rr Rr - - 50 Ω - 10 Shunt Capacitance C0 C0 - - 3 pF - 11 Insulation Resistance - 500 - - MΩ 12 Storage Temperature Range - -40 ~ 85 ℃ 2 Oscillation Mode 3 Load Capacitance 10Years at DC 100V - ■ FACTORY LOCATION TXC (NINGBO) CORPORATION NO.189 Huang Shan West Road, Beilun District, Ningbo Zhejiang China FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 7V24580012 REVISION: A1 PAGE: 4 ■ DIMENSIONS (Unit:mm) *Coplanarity of solderable areas Camber 0.10 mm Max ■ MARKING   T□□□ TXC Logo Frequency Code Ex.: 24.576000 MHz = 245 □□□ Lot Code Date Code Line Code Date Code: MONTH YEAR JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC 2005 2009 2013 2017 A B C D E F G H J K L 2006 2010 2014 2018 N P Q R S T U V W X Y Z 2007 2011 2015 2019 a b c d e f g h j k l m 2008 2012 2016 2020 n p q r s t u v w x y z M *This date code will be cycled every four years (℃) ■ SUGGESTED REFLOW PROFILE Solder melting point :220±10 ℃, 60 sec. Min. Peak Temperature: 260 ± 5 ℃, 10 sec. Max. 10 sec 260 220 180 150 ■ SUGGESTED MANUAL SOLDER CONDITION Temperature: 350 ± 10 ℃ Time: 3 sec. Time (sec) 120 sec 60 sec Re-solder times: twice FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 7V24580012 REVISION: A1 PAGE: 5 ■ STRUCTURE ILLUSTRATION 5 4 6 1 7 2 3 NO COMPONENTS MATERIALS FINISH/SPECIFICATIONS 1 Cap Ceramic (AI2O3) - 2 Package Ceramic (AI2O3) - 3 PAD Au Tungsten metalize + Ni plating + Au plating 4 Crystal blank SiO2 - 5 Conductive adhesive Resin+Ag - 6 Electrode Ag+Cr - 7 Sealing Glass Glass(PbO) - FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 7V24580012 A1 REVISION: PAGE: 6 ■ EMBOSS CARRIER TAPE & REEL DIMENSIONS A B C D E F G H I J T1 T2 1.65±0.10 3.40±0.10 2.70±0.10 4.00±0.10 8.00±0.20 4.00±0.10 1.55±0.10 1.75±0.10 3.50±0.10 2.00±0.10 0.25±0.05 0.06±0.02 (UNIT:mm) REMARK : Products put in 3000pcs Trailer 160mm(Min) Empty Sealed Leader 160mm(Min) 230mm(Min) User direction of feed W W1 2.0 L1 DIMENSIONS FMT-DOC024 L L1 178±1.00 13±0.50 W W1 11.5±0.20 8±0.10 L (UNIT:mm) Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 7V24580012 REVISION: A1 PAGE: 7 ■ PACKING Reel Quantity : 1. Reel X 6 (6 Reels) 2. Reel X 12 (12 Reels) 3. Reel X 25 (12 Reels + 13 Reels) 4. Reel X 50 ( 12 Reelsx2 + 13 Reelsx2 ) Label B C-3 Box Size: 1. L200 X W200 X H140mm 2. L200 X W200 X H250mm 3. L400 X W200 X H250mm 4. L400 X W400 X H280mm Tape Tape Label B QA Pass (Label C-3) Size:75 X 50mm (Lable B) Size:80 X 40mm [STORAGE] 1.The storage time to be 1 year maximum. 2.Don't be caught in the rain. 3.The storage environment shall be 5℃ ~40℃ temperature and 30% ~ 75%RH humidity and free from the sun shine. 4.If customers have special requirements, we can paste labels according to it. FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 7V24580012 REVISION: A1 PAGE: 8 ■ RELIABILITY SPECIFICATIONS ■ Endurance characteristics Items Conditions Specifications Apply pressure in the direction of the arrow at a rate of about 0.5 mm/s until bent width reaches 3 mm and hold for 5 s. Refer to Sub-clause 6.1 "Electrode strength (Bending strength)", STM-1150 "Surface Mount Devices-Parts Design Standard." Substrate bending test 1 (Bond strength of the end face plating) 1.Frequency change: Within ±10ppm and in customer's specification. 2.Equivalent series resistance(E.S.R) change: Within ±15% or 5Ω(larger value)and in customer's specification. Φ5 A static load of 10 N using a R 0.5 scratch tool shall be applied on the core of the component and in the direction of the arrow and held for 10 s. Refer to Sub-clause 6.3 "Part body strength", STM-1150 "Surface Mount Devices-Parts Design Standard." 2 Core body strength 1.Frequency change: Within ±10ppm and in customer's specification. 2.Equivalent series resistance(E.S.R) change: Within ±15% or 5Ω(larger value)and in customer's specification. Applied Force: 1.8 kg , Duration Time: 60 ±1 Sec Refer to AEC_Q200 METHOD - 006 3 Adhension(Electrode peeling strength) FMT-DOC024 1.Frequency change: Within ±10ppm and in customer's specification. 2.Equivalent series resistance(E.S.R) change: Within ±15% or 5Ω(larger value)and in customer's specification. Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 7V24580012 REVISION: A1 PAGE: 9 ■ RELIABILITY SPECIFICATIONS ■ Endurance characteristics Items 1 Solderability Conditions Specifications Pb free:245℃±5℃ , 5 Sec. ( 125℃ , 120Sec. PREHEATED) Check by Magnification 50 X Minimum 95% of immersed terminal shall Refer to STM-1254-02 "Test Methods for electronic Components, Lead-Free Soldering arts Design Standard Part be covered with new uniform solder. 2: Solderability Test for SMDs, Lead-Free Soldering." Pre-heating 130〜170℃/40〜90s, Heat 225℃ or more,20〜 30sec, Peak 230±2℃,on PC Board 2 Self alignment effect 3 This item is applied when the 3-3-11 clause cannot be examined. Refer to STM-1254-03 "Test Methods for Electronic Components, Lead-Free Soldering Parts Design Standards Part 3: Mounting Quality Test for SMDs Lead-Free Soldering." Refer MSL report (SMD) Resistance to soldering heat (℃) Temperature 240 200 150 100 50 FMT-DOC024 10~20 sec 180℃ 260℃ 250℃ Self alignment effect shall exist, and the electrode shall return inside land. 1. Appearance inspection 2.Frequency change: Within ±10ppm and in customer's specification. 3.Equivalent series resistance(E.S.R) change: Within ±15% or 5Ω(larger value)and in customer's specification. 150℃ 80~120 sec Heating time Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 7V24580012 REVISION: A1 PAGE: 10 ■ RELIABILITY SPECIFICATIONS ■ Endurance characteristics Items 4 5 Sealing Elecrical resistance to solvents Conditions He bombing 4.5kg/cm3 for 2 hours
7V24580012 价格&库存
很抱歉,暂时无法提供与“7V24580012”相匹配的价格&库存,您可以联系我们找货
7V24580012
    • 1+0.51840
    库存:2520
