TXC CORPORATION
www.txccorp.com
SPECIFICATION FOR APPROVAL
CUSTOMER
PRODUCT TYPE
SMD SEAM SEALING CXO 3.2 × 2.5
NOMINAL FREQ.
27.000000MHz
TXC P/N
7X27000043
REVISION
A1
CUSTOMER P/N
PM / SALES
DATE
CUSTOMER
CONFIRMATION
(Singnature)
(Date)
(1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance
of the attached specifications.
(2) Orders received and accepted by TXC after return of signed copy of specification will be produced per
these specifications.
(3) Any changes to these specifications must be agreed upon by both parties and new revision of the
Product Specification Sheet will be issued.
(4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets"
from customers will be regarded as the agreement on the contents of these specifications.
MSL:Level 1
RoHS Compliant
(for glass crystal only:Pb used in sealing glass material is exempt from EU directive)
FMT-DOC024 VER.G
TXC confidential and proprietary document
TXC CORPORATION
www.txccorp.com
PRODUCT SPECIFICATION SHEET
PRODUCT TYPE
NOMINAL FREQ.
27.000000MHz
TXC P/N
7X27000043
REVISION
A1
PE/RD
QA
MFG
Oscar Chen
Alex Huang
Andrew Wei
16-Apr-18
16-Apr-18
16-Apr-18
NOTE:
(1) The green product standard set by TXC is based upon the international standards. Related information is publicly
described on the TXC's Website, and updated regularly. The document is compliant with the latest green product
quality system directives at the time.
(2) Revision "Sx" is for engineering samples only. PE/RD's approval required.
(3) Revision "Ax" is production ready. PE, QA and MFG's approval required.
MSL:Level 1
RoHS Compliant
FMT-DOC024 VER.G
TXC CORPORATION
Rev
Revise page
A1
N/A
FMT-DOC024 VER.G
TXC P/N: 7X27000043
Revise contents
Initial released
REVISION: A1
PAGE: 1
Date
Ref.No.
Reviser
16-Apr-18
N/A
Anny Cheng
TXC CORPORATION
TXC P/N: 7X27000043
REVISION: A1
PAGE: 2
■ ELECTRICAL SPECIFICATIONS
Standard atmospheric conditions
Unless otherwise specified, the standard range of atmospheric conditions for making measurement
and tests are as follow:
Ambient temperature :
25±5℃
Relative humidity
40%~70%
If there is any doubt about the results, measurement shall be made within the following limits:
25±3℃
Relative humidity
40%~70%
Measure equipment
Electrical characteristics measured by MD 37WX-05M or equivalent.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode).
Unit Weight:
0.025±0.002 g/pcs
Parameters
Symbol
Electrical Spec.
Min.
1 Nominal Frequency
Typ.
Max.
27.000000
MHz
ppm
3 Operating Temperature
Topr
-40
25
85
4 Storage Temperature
Tstg
-55
125
5 Supply Voltage
VDD
V
6
mA
2 Frequency Stability
Icc
6 Input Current
7 Enable Control
8 Output Load :
CMOS
±50
Notes
Units
3.3 ±10%
Yes
CL
15
pF
Pad 1
10 Output Voltage High
VoH
90%Vdd
V
11 Output Voltage Low
VoL
10%Vdd
V
11 Rise Time
Tr
5
ns
10%→90%VDD Level
12 Fall Time
Tf
5
ns
90%→10%VDD Level
13 Symmetry (Duty ratio)
TH/T
45
55
14 Start-up Time
Tosc
10
ms
16 Enable Voltage High
Vhi
70%Vdd
V
17 Disable Voltage Low
Vlo
30%Vdd
V
18 Aging
ppm/yr. 1st. Year at 25℃
±3
18 Output Disable Delay Time
T off
150
μS
19 Output Enable Delay Time
T on
150
μS
1
ps
20 RMS Phase Jitter
FMT-DOC024 VER.G
Integrated from 12KHz to 5MHz
TXC CORPORATION
TXC P/N:
7X27000043
REVISION: A1
PAGE: 3
■ DIMENSIONS
(Unit:mm)
1.00±0.10
3.20±0.10
3
PAD FUNCTION:
1: ENABLE CONTROL
2.50±0.10
4
2: GND
3: OUT
4: VDD
1
2
4
3
0.80 1.40
1.20
0.50
1
1.40
1.20
1.20±0.15
Suggested Layout
1.00±0.15
0.90±0.15
0.65±0.15
2
■ MARKING
T □□□
TXC Symbol
Pin 1 Index
Frequency
14.318180 MHz=143
ex:
125.000000 MHz=A25
Lot Code
Date Code
Output Level
Output Level:
VDD(V)
CODE
5.00 3.30 2.80 2.50 1.80 2.90 3.00 2.85 2.60 2.55 2.00 1.50 2.70 3.40 1.90 1.20 1.00
A
B
C
D
E
F
G
H
J
K
L
M
N
P
Q
R
S
Date Code:
MONTH
JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC
YEAR
2005
2009
2013
2017
2021
A
B
C
D
E
F
G
H
J
K
L
M
2006
2010
2014
2018
2022
N
P
Q
R
S
T
U
V
W
X
Y
Z
2007
2011
2015
2019
2023
a
b
c
d
e
f
g
h
j
k
l
m
2008
2012
2016
2020
2024
n
p
q
r
s
t
u
v
w
x
y
z
*This date code will be cycled every four years
Production location:Taiwan
FMT-DOC024 VER.G
TXC CORPORATION
TXC P/N:
7X27000043
■ TEST DIAGRAM
Control input (output enable/disable)
Logic 1 or open on pad 1: Oscillator output
Logic 0 on pad 1 : Disable output to high impedance
■ WAVEFORM CONDITIONS
Waveform measurement system should
have a min. bandwidth of 5 times the
frequency being tested.
FMT-DOC024 VER.G
REVISION: A1
PAGE: 4
TXC CORPORATION
TXC P/N:
7X27000043
REVISION: A1
PAGE: 5
■ OUTPUT ENABLE / DISABLE DELAY
The following figure shows the oscillator timing during normal operation . Note that when the device is in standby,
the oscillator stops. When standby is released, the oscillator starts and stable oscillator output occurs after a
short delay.
■ SUGGESTED REFLOW PROFILE
Total time : 600 sec. Max.
Solder melting point :220 ℃
FMT-DOC024 VER.G
TXC CORPORATION
TXC P/N:
7X27000043
REVISION: A1
PAGE: 6
■ STRUCTURE ILLUSTRATION
6
5
3
1
4
NO
7
COMPONENTS
8
2
MATERIALS
FINISH/SPECIFICATIONS
1 Lid
Kovar (Fe/Co/Ni)
2 Base (Package)
Ceramic (AI2O3) + Kovar (Fe/Co/Ni)+ Ag/Cu
3 IC chip
4 Crystal blank
SiO2
5 Conductive adhesive Ag
Silicon resin
6 Electrode
Noble Metal
7 Die attached
Epoxy
8 Bonding wire
FMT-DOC024 VER.G
Pad 1 options : NC is 5 wires ,
Au
EN is 6 wires.
TXC CORPORATION
TXC P/N:
7X27000043 REVISION: A1
PAGE: 7
■ EMBOSS CARRIER TAPE & REEL
A
B
C
D
E
F
G
H
1.65
3.40
2.70
4.00
8.00
4.00
1.55
1.75
±0.10
±0.10
±0.10
±0.10
±0.20
±0.10
±0.05
±0.10
DIMENSIONS
(UNIT:mm)
REMARK :
DIMENSIONS
FMT-DOC024 VER.G
L
178
±1.00
L1
60.2
±0.50
W
11.5
±0.2
W1
8
+1/-0
Standard Reel Quantity is 3,000 pcs per reel
(UNIT:mm)
TXC CORPORATION
TXC P/N:
7X27000043
REVISION: A1
PAGE: 8
■ RELIABILITY SPECIFICATIONS
1.Mechanical Endurance
No.
Test Item
1.1 Drop Test
Test Methods
75 cm height,3 times on concrete floor .
1.2 Mechanical Shock
1.3 Vibration
Device are shocked to half sine wave ( 1000 G ) three mutually
perpendicular axes each 3 times. 0.5m sec. duration time
Frequency range
10 ~ 2000 Hz
Amplitude
1.52 mm/20G
Sweep time
20 minutes
perpendicular axes each test time
4 Hrs
REF. DOC
JIS C6701
MIL-STD-202
MIL-STD-883
(Total test time 12 Hrs)
1.4 Gross Leak
Standard Sample For Automatic Gross Leak Detector, Test Pressure: 2kg / cm2
1.5 Fine Leak
Helium Bomging 4.5 kgf / cm 2 for 2 Hrs
1.6 Solderability
Temperature
245 ℃ ± 5℃
Immersing depth
0.5 mm minimum
Immersion time
5 ± 1 seconds
Flux
MIL-STD-883
MIL-STD-883
Rosin resin methyl alcohol
solvent ( 1 : 4 )
2.Environmental Endurance
No.
Test Item
2.1 Resistance To Soldering Heat
Test Methods
Pre-heat temperature
125 ℃
Pre-heat time
60 ~ 120 sec.
Test temperature
260 ± 5 ℃
Test time
10 ± 1 sec.
2.2 High Temp. Storage
+ 125 ℃ ± 3 ℃ for 1000 ± 12 Hrs
2.3 Low Temp. Storage
- 40 ℃ ± 3 ℃ for 1000 ± 12 Hrs
REF. DOC
MIL-STD-202
MIL-STD-883
Total 100 cycles of the following temperature cycle
2.4 Thermal Shock
MIL-STD-883
2.5 High Temp&Humidity
85℃ ± 3℃, RH 85% , 1000 Hrs
JIS C5023
2.6 Pressure Cooker Storage
121 ± 3℃ , RH100% , 2 bar , 240 Hrs
JIS C6701
FMT-DOC024 VER.G
很抱歉,暂时无法提供与“7X27000043”相匹配的价格&库存,您可以联系我们找货
