8Q26000004
8Q26000004
    TXC(台晶)
    SMD1612_4P
    无源晶振 SMD1612_4P
8Q26000004 数据手册
TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com SPECIFICATION FOR APPROVAL CUSTOMER : PRODUCT TYPE : SMD Crystal 1.6×1.2 NOMINAL FREQ. : 26.000000MHz TXC P/N : 8Q26000004 REVISION : S3 CUSTOMER P/N : PM / SALES : DATE : CUSTOMER SIGNATURE & Date (1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance of the attached specifications. (2) Orders received and accepted by TXC after return of signed copy of specification will be produced per these specifications. (3) Any changes to these specifications must be agreed upon by both parties and new revision of the Product Specification Sheet will be issued. (4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. Attachment: Product Specification Sheet 1 2 3 4 5 FMT-DOC024 RoHS Compliant Issue Date: 02.20'14 VER.F TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com PRODUCT SPECIFICATION SHEET PRODUCT TYPE : SMD Crystal 1.6×1.2 NOMINAL FREQ. : 26.000000MHz TXC P/N : 8Q26000004 REVISION : S3 PE/RD QA MFG Mike Chiu Chester Ho Rick Lo 17-Nov-15 NOTE: (1) The green product standard set by TXC is based upon the international standards. Related information is publicly described on the TXC's Website, and updated regularly. The document is compliant with the latest green product quality system directives at the time. (2) Revision "Sx" is for engineering samples only. PE/RD's approval required. (3) Revision "Ax" is production ready. PE, QA and MFG's approval required. RoHS Compliant FMT-DOC024 Issue Date: 02.20'14 VER.F TXC CORPORATION Rev Revise page S1 N/A S2 S3 FMT-DOC024 TXC P/N: 8Q26000004 Revise contents REVISION: S3 PAGE: 1 Date Ref.No. Reviser Initial released 24-Oct-14 N/A Yachuan Miao 2 Change ESR Max:80 ohms to 60 ohms 15-Jan-15 PNR15010907 Yachuan Miao 2 Change ESR Max:60 ohms to 80 ohms 17-Nov-15 PNR15111125 Yachuan Miao Issue Date: 02.20'14 VER.F TXC CORPORATION 8Q26000004 TXC P/N: REVISION: S3 PAGE: 2 ■ ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature : 25±10℃ Relative humidity 40%~70% : If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature : 25±3℃ Relative humidity 40%~70% : Measure equipment Electrical characteristics measured by S&A 250B or equivalent. Crystal cutting type The crystal is using AT CUT (thickness shear mode). Unit Weight: 0.0029±0.0010 g/pcs Parameters 1 Nominal Frequency Symbol Electrical Spec. Min. Typ. FL 26.000000 Max. Notes Units - MHz - Fundamental - - CL 9 pF - 4 Frequency Tolerance - ±10 ppm at 25 ℃ ± 3 ℃ 5 Frequency Stability - ±10 ppm Over Operating Temp. Range (Reference 25℃) 6 Operating Temperature - 7 Aging - 2 Oscillation Mode 3 Load Capacitance -20 ~ 75 ±3 - ℃ ppm 1st Year DL - 100 - uW - ESR - - 80 Ω - 10 Insulation Resistance - 500 - - MΩ 11 Storage Temperature Range - -40 ~ 85 ℃ 8 Drive Level 9 Equivalent Series Resistance FMT-DOC024 at DC 100V - Issue Date: 02.20'14 VER.F TXC CORPORATION ■ DIMENSIONS (Unit:mm) TXC P/N: 8Q26000004 1.60±0.10 NC 4 3 PAGE: 3 Connection 3 1.20±0.10 4 REVISION: S3 Suggested Layout 0.20 0.60 0.75 0.30 0.75 0.55±0.10 0.60 0.50±0.10 2 GND 1 0.35±0.05 2 0.30±0.10 0.45±0.10 1 ■ MARKING   T□□□ TXC Logo Pin 1 Location ■ □□□□ Frequency Code ex:37.400000 MHz=374 Tracking Code Production location:Taiwan/China ■ SUGGESTED REFLOW PROFILE Total time : 200 sec. Max. Solder melting point :220 ℃ FMT-DOC024 Issue Date: 02.20'14 VER.F TXC CORPORATION TXC P/N: 8Q26000004 REVISION: S3 PAGE: 4 ■ STRUCTURE ILLUSTRATION NO COMPONENTS 1 Lid MATERIALS Kovar FINISH/SPECIFICATIONS - 2 Base(Package) Ceramic (AI2O3)+Pad (Au) Alumina ceramics 3 Crystal blank SiO2 - 4 Conductive adhesive Ag Silicone resin 5 Electrode Noble Metal - FMT-DOC024 Issue Date: 02.20'14 VER.F TXC CORPORATION TXC P/N: 8Q26000004 REVISION: S3 PAGE: 5 ■ PACKING TOP VIEW INDEX MARK DIMENSIONS A B C D E F G H I 0.75 1.85 1.45 4.00 8.00 4.00 1.55 1.75 3.50 ± 0.15 ± 0.1 ± 0.1 ± 0.1 ±0.2 ± 0.1 ± 0.05 ± 0.1 ±0.05 (UNIT : mm) REMARK : DIMENSIONS FMT-DOC024 L 178 L1 60.2 W 11.5 W1 8 ±1.00 ±0.50 ±0.2 +1/-0 Standard Reel Quantity is 3,000 pcs per reel (UNIT:mm) Issue Date: 02.20'14 VER.F TXC CORPORATION TXC P/N: 8Q26000004 REVISION: S3 PAGE: 6 ■ RELIABILITY SPECIFICATIONS 1.Mechanical Endurance No. Test Item 1.1 Drop Test Test Methods REF.DOC MIL-STD-202 150 cm height, 3 times on concrete floor. 1.2 Mechanical Shock 1.3 Vibration Device are shocked to half sine wave ( 1000 G ) three mutually perpendicular axes each 3 times. 0.5m sec. duration time Frequency range 10 ~ 2000 Hz Amplitude 1.52 mm/20G Sweep time 20 minute perpendicular axes each test time MIL-STD-202 MIL-STD-883 4 hours (Total test time 12 hours) 1.4 Gross Leak Standard Sample For Automatic Gross Leak Detector, Test 2 Pressure: 2Kg / cm MIL-STD-883 2 1.5 Fine Leak Helium Bombing 4.5 Kg/ cm for 2 hr Temperature 1.6 Solder ability 245 ℃ ± 5℃ Immersing depth 0.5 mm minimum Immersion time 5 ± 1 seconds Flux Rosin resin methyl alcohol MIL-STD-883 solvent ( 1 : 4 ) 2.Environmental Endurance No. Test Item 2.1 Resistance To Soldering Heat Test Methods Pre-heat temperature 125 ℃ Pre-heat time 60 ~ 120 sec. Test temperature 260 ± 5 ℃ Test time 10 ± 1 sec. 2.2 High Temp. Storage + 125 ℃ ± 3 ℃ for 500 ± 12 hours 2.3 Low Temp. Storage - 40 ℃ ± 3 ℃ for 500 ± 12 hours REF. DOC MIL-STD-202 MIL-STD-883 Total 100 cycles of the following temperature cycle 1 cycle 125 ± 3 ℃ 2.4 Thermal Shock MIL-STD-883 25 ℃ -55 ± 3 ℃ 30 min. 30 min. 10 min. max. 2.5 High Temp&Humidity 85℃ ± 3℃, RH 85% , 500Hrs EIA-JESD22 2.6 Pressure Cooker Storage 121 ± 3℃ , RH100% , 2 bar , 240Hrs EIA-JESD22 FMT-DOC024 Issue Date: 02.20'14 VER.F
8Q26000004 价格&库存
很抱歉,暂时无法提供与“8Q26000004”相匹配的价格&库存,您可以联系我们找货
