TXC CORPORATION
4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan.
TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207
www.txccorp.com
SPECIFICATION FOR APPROVAL
CN:
1408001237
CUSTOMER
Tecvox
PRODUCT TYPE
SMD GLASS SEALING X'TAL 3.2*2.5
NOMINAL FREQ.
24.000000MHz
TXC P/N
AV24070003
REVISION
S1
CUSTOMER P/N
PM / SALES
John Lin (johnlin@txc.com.tw)
DATE
13-Aug-14
CUSTOMER SIGNATURE & Date
(1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance
of the attached specifications.
(2) Orders received and accepted by TXC after return of signed copy of specification will be produced per
these specifications.
(3) Any changes to these specifications must be agreed upon by both parties and new revision of the
Product Specification Sheet will be issued.
(4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets"
from customers will be regarded as the agreement on the contents of these specifications.
MSL:Level 1
RoHS Compliant
Pb used in sealing glass material is exempt from EU directive
FMT-DOC015
Issue Date: 03.18'14 VER.B
TXC CORPORATION
www.txccorp.com
PRODUCT SPECIFICATION SHEET
CN:
1408001237
PRODUCT TYPE
NOMINAL FREQ.
24.000000MHz
TXC P/N
AV24070003
REVISION
S1
PE/RD
QA
MFG
ZhongLin Wu
13-Aug-14
NOTE:
(1)The green product standard set by TXC is based upon the international standards. Related information is
publicly described on the TXC's Website, and updated regularly. The document is compliant with the latest green
product quality system directives at the time.
(2)Revision "Sx" is for engineering samples only. PE/RD's approval required.
(3)Revision "Ax" is production ready. PE, QA and MFG's approval required
MSL:Level 1
RoHS Compliant
FMT-DOC015
TXC P/N:
TXC CORPORATION
Rev
Revise page
S1
N/A
FMT-DOC015
Revise contents
Initial released
AV24070003
S1
REVISION:
PAGE:
1
Date
Ref.No.
Reviser
13-Aug-14
N/A
Xiaoyan Jiang
TXC CORPORATION
TXC P/N:
AV24070003
REVISION:
S1
PAGE:
2
Spec Sheet Contents
No.
Content
Page
1
ELECTRICAL SPECIFICATIONS
P.3
2
FACTORY LOCATION
P.3
3
DIMENSIONS
P.4
4
MARKING
P.4
5
SUGGESTED REFLOW PROFILE& MANUAL SOLDER CONDITION
P.4
6
STRUCTURE ILLUSTRATION
P.5
7
EMBOSS CARRIER TAPE & REEL
P.6
8
PACKING
P.7
9
RELIABILITY SPECIFICATIONS
FMT-DOC015
P.8~9
TXC P/N: AV24070003
TXC CORPORATION
REVISION:
S1
PAGE: 3
■ ELECTRICAL SPECIFICATIONS
Standard atmospheric conditions
Unless otherwise specified, the standard range of atmospheric conditions for making measurement
and tests are as follow:
Ambient temperature :
25±5℃
Relative humidity
40%~70%
If there is any doubt about the results, measurement shall be made within the following limits:
25±3℃
Relative humidity
40%~70%
Measure equipment
Electrical characteristics measured by S&A250B or equivalent.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode).
Unit Weight:
0.018±0.005 g/pcs
Parameters
1
Nominal Frequency
2
Oscillation Mode
3
Load Capacitance
4
SYM.
Electrical Spec.
MIN
TYP
FL
24.000000
MAX
Notes
UNITS
MHz
Fundamental
CL
18
pF
Frequency Tolerance
±30
ppm
at 25 ℃ ± 3 ℃
5
Frequency Stability
±50
ppm
Over Operating Temp. Range(Reference 25℃)
6
Operating Temperature
7
Aging
8
Drive Level
9
Series Resonant Resistance
DL
-40
105
±5
100
ppm
1st Year
uW
Rr
60
Ω
C0
3
pF
11 Insulation Resistance
500
MΩ
12 Storage Temperature Range
-40
105
10 Shunt Capacitance
at DC 100V
■ FACTORY LOCATION
TXC (NINGBO) CORPORATION
NO.189 Huang Shan West Road, Beilun District,
Ningbo Zhejiang China
FMT-DOC015
TXC P/N:
TXC CORPORATION
AV24070003
REVISION:
■ DIMENSIONS
(Unit:mm)
S1
PAGE:
4
Connection
#2 & #4 are not internally connected
Suggested Layout
*Coplanarity of solderable areas Camber 0.10 mm Max
■ MARKING
T□□□
TXC Logo
Frequency Code
Ex.: 24.000000 MHz = 240
Lot Code
Date Code
Line Code
Date Code:
MONTH
YEAR
JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC
2005
2009
2013
2017
A
B
C
D
E
F
G
H
J
K
L
M
2006
2010
2014
2018
N
P
Q
R
S
T
U
V
W
X
Y
Z
2007
2011
2015
2019
a
b
c
d
e
f
g
h
j
k
l
m
2008
2012
2016
2020
n
p
q
r
s
t
u
v
w
x
y
z
*This date code will be cycled every four years
■ SUGGESTED REFLOW PROFILE
Solder melting point :220±10 ℃, 60 sec. Min.
Peak Temperature: 260 ± 5 ℃, 10 sec. Max.
10 sec
260
220
180
150
■ SUGGESTED MANUAL SOLDER CONDITION
Temperature: 350 ± 10 ℃
Time: 3 sec.
Time (sec)
120 sec
60 sec
Re-solder times: twice
FMT-DOC015
AV24070003
TXC P/N:
TXC CORPORATION
S1
REVISION:
PAGE:
5
■ STRUCTURE ILLUSTRATION
5
4
6
1
7
2
3
COMPONENTS
NO
MATERIALS
FINISH/SPECIFICATIONS
1
Cap
Ceramic (AI2O3)
2
Package
Ceramic (AI2O3)
3
PAD
Au
Tungsten metalize
+ Ni plating
+ Au plating
4
Crystal blank
SiO2
5
Conductive adhesive
Resin+Ag
6
Electrode
Noble Metal
7
Sealing Glass
Glass(PbO)
FMT-DOC015
TXC P/N:
TXC CORPORATION
AV24070003
REVISION:
S1
PAGE: 6
■ EMBOSS CARRIER TAPE & REEL
F
E
B
H
G
DIMENSIONS
A
1.65±0.10
B
Feeding
D
C
A
C
D
E
F
G
H
3.40±0.10 2.70±0.10 4.00±0.10 8.00±0.20 4.00±0.10 1.55±0.10 1.75±0.10 (UNIT:mm)
REMARK :
Products put in 3000pcs
Trailer
160mm(Min)
Empty Sealed
Leader
160mm(Min)
230mm(Min)
User direction of feed
DIMENSIONS
FMT-DOC015
L
L1
W
W1
178±1.00
13±0.50
11.5±0.20
8±0.10
(UNIT:mm)
TXC CORPORATION
TXC P/N:
AV24070003
REVISION:
S1
PAGE:
7
■ PACKING
Reel Quantity :
1. Reel X 6 (6 Reels)
2. Reel X 12 (12 Reels)
3. Reel X 25 (12 Reels + 13 Reels)
4. Reel X 50 ( 12 Reelsx2 + 13 Reelsx2 )
Label B
Box Size:
1. L200 X W200 X H140mm
2. L200 X W200 X H250mm
3. L400 X W200 X H250mm
4. L400 X W400 X H280mm
Tape
Tape
Label A
Label B
QA Pass
(Label A) Size:100 X 100mm
(Lable B) Size:80 X 40mm
[STORAGE]
1.The storage time to be 1 year maximum.
2.Don't be caught in the rain.
3.The storage environment shall be 5℃ ~40℃ temperature and 30% ~ 75%RH humidity and free from the sun shine.
4.If customers have special requirements, we can paste labels according to it.
FMT-DOC015
AV24070003
TXC P/N:
TXC CORPORATION
S1
REVISION:
PAGE:
8
■ RELIABILITY SPECIFICATIONS (Conforms to AEC-Q200)
1.Mechanical Endurance
No.
1.1
1.2
Test Item
Mechanical Shock
Vibration
Test Methods
Test Criteria
2000 G , 0.3 m Sec. ,3 times for all 3 directions.
Frequency range
10 ~ 2000 Hz
Acceleration
20G
Amplitude
1.52mm
Sweep time
20 minute
Pendicular axes each test time
4 hours
BC
BC
(Total test time 12 hours)
1.3
Terminal Strength
17.7N force for 60sec +/-1sec.
1.4
Board Flex
Duration time:60 Sec Minimum,Deviation:3mm
128 Solderability
F
BC
Temperature
245 oC +/- 5oC
Immersing depth
0.5 mm minimum
Immersion time
5 +/- 0.5 seconds
Flux
Rosin resin methyl alcohol
E
solvent ( 1 : 4 )
2.Environmental Endurance
No.
Test Item
Test Methods
SPEC
Test temperature
260 +/- 5 oC
10 +/- 1 sec.
2.1
Resistance To
Soldering Heat
Test time
2.2
High Temp. Storage
+ 105℃ ± 3 ℃ for 1000 ± 12 Hrs
BCD
2.3
Low Temp. Storage
- 40 ℃ ± 3 ℃ for 1000 ± 12 Hrs
BCD
BCD
-40℃~105℃,for 1000 cycles.
B C D
1 cycle
105+/-3℃
2.4
Temperature cycle
BCD
25 ℃
-40+/-3 ℃
15 min.
15 min.
2min Max.
2.5
Operational Life
2.6
High Temp&Humidity 85℃ ± 3℃ , RH 85% , 1000 Hrs
FMT-DOC015
1000 hrs @ 105± 3°C. Rated VDD applied with 1 MΩ.
BCD
BCD
TXC CORPORATION
TXC P/N:
AV24070003
REVISION
S1
PAGE: 9
Specifications
A
Frequency change: Within ±5ppm or in customer's specification.
B
Frequency change: Within ±10ppm or in customer's specification.
C
Equivalent series resistance(E.S.R) change: Within ±15% or 10Ω(larger value).
D
After conditioning , quartz crystal units shall be subjected to standard atmospheric conditions for 24 hour, and
measured.
E
Minimum 95% of immersed terminal shall be covered with new uniform solder.
F
No damage on specimen
Measurement condition
FMT-DOC015
很抱歉,暂时无法提供与“AV24070003”相匹配的价格&库存,您可以联系我们找货
