AT04000019
AT04000019
    TXC(台晶)
    HC-49S/SMD
    无源晶振 HC-49S/SMD
AT04000019 数据手册
TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com SPECIFICATION FOR APPROVAL CN: CUSTOMER : PRODUCT TYPE : HC-49/S SMD NOMINAL FREQ. : 4.000000MHz TXC P/N : AT04000019 REVISION : A1 CUSTOMER P/N : PM / SALES : DATE : 1508013446 CUSTOMER SIGNATURE & Date (1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance of the attached specifications. (2) Orders received and accepted by TXC after return of signed copy of specification will be produced per these specifications. (3) Any changes to these specifications must be agreed upon by both parties and new revision of the Product Specification Sheet will be issued. (4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. Attachment: Product Specification Sheet 1 2 3 4 5 RoHS Compliant FMT-DOC015 Issue Date: 03.18'14 VER.B TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com PRODUCT SPECIFICATION SHEET CN: PRODUCT TYPE : HC-49/S SMD NOMINAL FREQ. : 4.000000MHz TXC P/N : AT04000019 REVISION : A1 PE/RD QA Wen yuan Chang ZhongLin Wu PREPAPRE PR P PEPAR PREPA PREP P PR PREP 1508013446 MFG Zhi Wu PREP PjunPR PREP PREPAPRE P PREPA 27-Aug-14 27-Aug-14 27-Aug-14 NOTE: (1)The green product standard set by TXC is based upon the international standards. Related information is publicly described on the TXC's Website, and updated regularly. The document is compliant with the latest green product quality system directives at the time. (2)Revision "Sx" is for engineering samples only. PE/RD's approval required. (3)Revision "Ax" is production ready. PE, QA and MFG's approval required RoHS Compliant FMT-DOC015 Issue Date: 03.18'14 VER.B TXC CORPORATION Rev Revise page S1 N/A Initial Released A1 N/A S Turn A FMT-DOC015 TXC P/N: AT04000019 Revise contents REVISION:A1 PAGE: 1 Date Ref.No. Reviser 8-Oct-13 N/A Xiaoyan Jiang 27-Aug-14 N/A Xiaoyan Jiang Issue Date: 03.18'14 VER.B TXC CORPORATION TXC P/N: AT04000019 REVISION: A1 PAGE: 2 Spec Sheet Contents No. Content Page 1 ELECTRICAL SPECIFICATIONS P.3 2 FACTORY LOCATION P.3 3 DIMENSIONS P.4 4 SUGGESTED REFLOW PROFILE& MANUAL SOLDER CONDITION P.4 5 MARKING P.5 6 STRUCTURE ILLUSTRATION P.6 7 EMBOSS CARRIER TAPE & REEL P.7 8 PACKING P.7 9 RELIABILITY SPECIFICATIONS FMT-DOC015 P.8~9 Issue Date: 03.18'14 VER.B TXC CORPORATION TXC P/N: AT04000019 REVISION: A1 PAGE: 3 ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature : 25+/-5oC Relative humidity 40%~70% : If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature : 25+/-1oC Relative humidity 40%~70% : Measure equipment SAUNDERS 250A/250B CRYSTAL IMPEDANCE METER. Crystal cutting type The crystal is using AT CUT (thickness shear mode). Unit Weight: 0.58±0.050 g/pcs please refer to marking code page Parameters 1 Nominal Frequency SYM. Electrical Spec. MIN TYPE FL 4.000000 MAX Notes UNITS MHz - - Fundamental - - CL 17 pF - 4 Frequency Tolerance - ±25 ppm at 25 ℃ ± 3 ℃ 5 Frequency Stability - ±30 ppm Over Operating Temp. Range (Reference 25℃) 6 Operating Temperature - 7 Aging - 2 Oscillation Mode 3 Load Capacitance -40 ~ 85 ±3 ℃ ppm 1st Year 8 Drive Level DL - 100 - uW - 9 Effective Resistance Rr Rr - - 120 Ω - 10 Shunt Capacitance C0 C0 - - 7 pF 11 Insulation Resistance - 500 - - MΩ 12 Storage Temperature Range - -40 ~ 85 ℃ at DC 100V - ■ FACTORY LOCATION TXC (NINGBO) CORPORATION NO.189 Huang Shan West Road, Beilun District, Ningbo Zhejiang China FMT-DOC015 Issue Date: 03.18'14 VER.B TXC CORPORATION TXC P/N: AT04000019 DIMENSIONS REVISION: A1 PAGE: 4 UNIT:mm 11.4+/-0.5 3.8+/-0.3 0.3+/-0.1 0.5+/-0.2 0.8+/-0.2 4.8 Max. 4.5 Max 12.7+/-0.5 Solder Coating Suggested Layout (Sn-Ag-Cu Pb Free Coating) 4 5.5 (x2) 2.0 (x2) ■ SUGGESTED REFLOW PROFILE (℃) Solder melting point :220±10 ℃, 60 sec. Min. Peak Temperature: 260 ± 5 ℃, 10 sec. Max. 10 sec 260 220 180 ■ SUGGESTED MANUAL SOLDER CONDITION 150 Temperature: 350 ± 10 ℃ Time (sec) Time: 3 sec. Re-solder times: twice FMT-DOC015 120 sec 60 sec Issue Date: 03.18'14 VER.B TXC CORPORATION TXC P/N: AT04000019 REVISION: A1 PAGE: 5 MARKING Marking For Pb Free Parts: TXC TXC Logo Pb Free Product G Lot Code (2 digits) Frequency Code Production Line Code Date Code Date Code: MONTH JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC YEAR 2001 2005 2009 2013 2017 A B C D E 2002 2006 2010 2014 2018 N P Q R S 2003 2007 2011 2015 2019 a b c d e 2004 2008 2012 2016 2020 n p q r s *This date code will be cycled every four years. For example : F T f t G U g u H V h v J W j w K X k x L Y l y M Z m z Marking TXC G 4.00Mn01 FMT-DOC015 Pb Free Product Introduction: 49S/SMD 4.000000 MHz Made in NGB 2008/JAN 01Lot Issue Date: 03.18'14 VER.B TXC CORPORATION TXC P/N: AT04000019 REVISION: A1 PAGE: 6 ■ STRUCTURE ILLUSTRATION NO 1 COMPONENTS MATERIALS FINISH/SPECIFICATIONS CRYSTAL BLANK QUARTZ(SiO2) - SUPPORTER Nickel Silver(Cu/Zn/Ni) - HOLDER SPCC(Fe) Ni Plated GLASS GLASS - LEAD Kovar (Fe/Co/Ni) Ni Plated+Solder( Sn/Ag/Cu) Dipped 2 2 2 2 CRYSTAL BASE 2 3 CRYSTAL COVER Nickel Silver(Cu/Zn/Ni) Ni Plated 4 CONDUCTIVE ADHESIVE Resin + Ag - 5 ELECTRODE Noble Metal - 6 INSULATION PAD PPS - FMT-DOC015 Issue Date: 03.18'14 VER.B TXC CORPORATION TXC P/N: AT04000019 REVISION: A1 PAGE: 7 (A) Tape and reel configuration:(Unit:mm) ( a)Emboss taping configuration. (per EIA-481-2) 0.4+/-0.1 5o max. 5.0+/-0.1 5o max. H 11.5+/-0.1 2.0+/-0.1 24.0+/-0.3 +0.1 1.5 -0.0 4.0+/-0.1 15+/-0.5 1.75+/-0.1 40(10P)+/-0.2 +0.1 1.5 -0.0 12.0+/-0.2 Direction of start Products put in 1000 pcs Max. NONE H (+/-0.2) 4.35 3.5 22.0 Max. NONE TYP. S3 S2 COVER TAPE 160 Min. 160 Min. 390 Min. 230 Min. ( b)Reel configuration. (B) Packing & Label :(Unit:mm) COVER TAPE 120° 24.4+/-0.2 100+/-3 13.6+/-0.2 ● ● ● ● ● ● ● ● ● ● ● ● ● ● 24.0+/-0.4 330+/-1 B 2.3+/-0.2 1.8+/-0.2 1.8+/-0.2 PUT IN 330+/-5 Label B ( Example ) B 330+/-5 35+/-5 PUT IN Label C ( Example ) C B # Put in stuff between space. [STORAGE] 1.The storage time to be 1 year maximum. 2.Don't be caught in the rain. 3.The storage environment shall be 5℃ ~40℃ temperature and 30% ~ 75%RH humidity and free from the sun shine. 4.If customers have special requirements, we can paste labels according to it. FMT-DOC015 Issue Date: 03.18'14 VER.B Pro d u cts put F in 1000 ( ℃ ) 2 6 0 2 2 0 B 2 .0 1 8 0 1 5 0 U se r d i re cti o n of W p cs Emp ty W 1 G Se a l e d 1 0 Leader s 160 mm ( Mi n) e c L 1 L 230 mm ( Mi n ) fe e d C TXC CORPORATION D E MAR K A H Tra i l e r IN D EX 1 6 0 mm(Mi n ) TXC P/N: Tim 1 2 0 s e ( s e c ) Fe e d in g 6 0 s e c e c AT04000019 A1 REVISION: PAGE: ■ RELIABILITY SPECIFICATIONS (AEC-Q200 Compliant) 1.Mechanical Endurance No. 1.1 1.2 Test Item Mechanical Shock Vibration Test Methods Test Criteria 1000 G , 0.5 m Sec. , 3 times for all 3 directions. Frequency range 10 ~ 2000 Hz Acceleration 20 G Sweep time 20 minute Pendicular axes each test time 4 hours BC BC (Total test time 12 hours) 1.3 Terminal Strength 17.7N force for 60sec +/-1sec. 1.4 Board Flex Duration time:60 Sec Minimum,Deviation:3mm 1.5 Solderability F BC Temperature 245 oC +/- 5oC Immersing depth 0.5 mm minimum Immersion time 5 +/- 0.5 seconds Flux Rosin resin methyl alcohol E solvent ( 1 : 4 ) 2.Environmental Endurance No. Test Item Test Methods SPEC Resistance To Soldering Heat Test temperature 260 +/- 5 oC Test time 10 +/- 1 sec. 2.2 High Temp. Storage + 85℃ ± 3 ℃ for 1000 ± 12 Hrs ACD 2.3 Low Temp. Storage - 40 ℃ ± 3 ℃ for 1000 ± 12 Hrs ACD 2.1 ACD B C D -40℃~85℃,for 1000 cycles. 1 cycle 85+/-3 0C 2.4 Temperature cycle 25 0C -40+/-3 C ACD 0 15 min. 15 min. 2 min. 1000 hrs @ 85± 3°C. Rated VDD applied with 1 MΩ. 2.5 Operational Life 2.6 High Temp&Humidity 85℃ ± 3℃ , RH 85% , 1000 Hrs FMT-DOC015 ACD ACD Issue Date: 03.18'14 VER.B 8 put F in ( ℃ B 1 8 0 1 5 0 TXC CORPORATION d i re cti o n D 1000 ) 2 6 0 2 2 0 2 .0 U se r C of W p cs G Emp ty W 1 Se a l e d 1 0 Leader s e c E Pro d u cts 1 6 0 mm(Mi n ) H Tra i l e r IN D EX MAR K A 160 mm ( Mi n) L 1 L 230 mm ( Mi n ) fe e d 1 2 0 TXC P/N: Tim s e c e ( s e c ) Fe e d i n g 6 0 s e c AT04000019 REVISION: A1 PAGE: 9 RELIABILITY SPECIFICATIONS Specifications A Frequency change: Within ±20ppm or in customer's specification. B Frequency change: Within ±10ppm or in customer's specification. C Equivalent series resistance(E.S.R) change: Within ±15% or 10Ω(larger value). D After conditioning , quartz crystal units shall be subjected to standard atmospheric conditions for 24 hour, and measured. E Minimum 95% of immersed terminal shall be covered with new uniform solder. F No damage on specimen Measurement condition Measurements are carried out with Network-analyzer( S&A 250B or equivalent). FMT-DOC015 Issue Date: 03.18'14 VER.B
AT04000019 价格&库存
很抱歉,暂时无法提供与“AT04000019”相匹配的价格&库存,您可以联系我们找货
