BR-61.440MBE-T
BR-61.440MBE-T
    TXC(台晶)
BR-61.440MBE-T 数据手册
Oscillators 7 x 5 mm SMD CMOS VCXO BR SERIES Features e1E TXC BRC .76 0 77 > > > > > > > > Voltage Controlled Crystal Oscillator (VCXO). Fundamental solution. CMOS output, output frequencies 60 MHz to 220 MHz. Wide pull range and good linearity. Excellent low phase noise and jitter. Tri-State function available. Main applications : SDH/ SONET. RoHS Compliant / Pb Free. Electrical Specifications Item / Type BR Output Type CMOS Output Load 15 pF Oscillation Mode Fundamental Supply Voltage 3.3 V Frequency Range Frequency Stability / Operating Temperature 60 ~ 220 MHz ± 50 ppm / - 40 ~ + 85 oC Storage Temperature Range - 55 ~ + 125 oC Voltage Vol ( Max. ) / Voh ( Min. ) 0.1 VDD / 0.9 VDD Rise ( Tr ) / Fall ( Tf ) Time ( 20 % ~ 80 % ) 5 ns Max. Supply Current 60 mA Max. Symmetry 45 ~ 55 % Start-up Time 10 ms Max. Absolute Pulling Range ( APR ) * ± 100 ppm Min. or specify 0.5 VDD Control Voltage Range 0 ~ VDD Linearity ± 10% Max. Phase Jitter ( 12 KHz ~ 20 MHz ) 1ps Max. * APR=(Pull Range) - (Degrations due to initial tolerance, operating temperature, supply voltage variation and aging) Dimensions Oscillators Nominal Control Voltage PAD FUNCTION: 1:CONTROL VOLTAGE 2:ENABLE CONTROL 3:GND 4:OUT 5:NC 6:VDD Suggested Layout Units:mm Remark : Specification subject to change without prior notice. Please confirm with our sales. 49
BR-61.440MBE-T
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚集电极,4脚发射极,5脚GND,6脚VCC。
4. 参数特性:工作温度范围为-40至85摄氏度,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有抗干扰能力强,响应速度快等特点。
6. 应用信息:广泛应用于工业控制、仪器仪表、医疗设备等领域。
7. 封装信息:采用DIP6封装方式。
BR-61.440MBE-T 价格&库存
很抱歉,暂时无法提供与“BR-61.440MBE-T”相匹配的价格&库存,您可以联系我们找货
