AB10000301
AB10000301
    TXC(台晶)
    SMD5032_4P
AB10000301 数据手册
TXC CORPORATION www.txccorp.com SPECIFICATION FOR APPROVAL CN: 1702001982 CUSTOMER : PRODUCT TYPE : SMD SEAM SEALING XTAL 5.0 × 3.2 NOMINAL FREQ. : 10.000000MHz TXC P/N : AB10000301 REVISION : S1 CUSTOMER P/N : PM / SALES : DATE : CUSTOMER CONFIRMATION : (1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance of the attached specifications. (2) Orders received and accepted by TXC after return of signed copy of specification will be produced per these specifications. (3) Any changes to these specifications must be agreed upon by both parties and new revision of the Product Specification Sheet will be issued. (4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. MSL:Level 1 RoHS Compliant (for glass crystal only:Pb used in sealing glass material is exempt from EU directive) FMT-DOC015 VER.C TXC confidential and proprietary document TXC CORPORATION www.txccorp.com PRODUCT SPECIFICATION SHEET CN: 1702001982 PRODUCT TYPE : SMD SEAM SEALING XTAL 5.0 × 3.2 NOMINAL FREQ. : 10.000000MHz TXC P/N : AB10000301 REVISION : S1 PE/RD QA MFG Wen yuan Chang 20-Nov-16 NOTE: (1)The green product standard set by TXC is based upon the international standards. Related information is publicly described on the TXC's Website, and updated regularly. The document is compliant with the latest green product quality system directives at the time. (2)Revision "Sx" is for engineering samples only. PE/RD's approval required. (3)Revision "Ax" is production ready. PE, QA and MFG's approval required MSL:Level 1 RoHS Compliant (for glass crystal only:Pb used in sealing glass material is exempt from EU directive) FMT-DOC015 VER.C TXC confidential and proprietary document TXC CORPORATION Rev Revise page S1 N/A FMT-DOC015 VER.C TXC P/N: Revise contents Initial released AB10000301 REVISION: S1 Date Ref.No. 20-Nov-16 N/A TXC confidential and proprietary document PAGE: Revise Xiaoyan J TXC CORPORATION TXC P/N: AB10000301 REVISION: S1 PAGE: ■ ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature : 25±5℃ Relative humidity : 40%~70% If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature : 25±3℃ Relative humidity : 40%~70% Measure equipment Electrical characteristics measured by S&A 250B or equivalent. Crystal cutting type The crystal is using AT CUT (thickness shear mode). Unit Weight: 0.046±0.002 g/pcs Parameters SYM. Electrical Spec. MIN TYPE MAX Notes UNITS FL 10.000000 MHz - - Fundamental - - CL 12 pF - 4 Frequency Tolerance - ±30 ppm at 25 ℃ ± 3 ℃ 5 Frequency Stability - ±100 ppm Over Operating Temp. Range (Reference 25℃ 6 Operating Temperature - -40 ~ 125 ℃ 7 Aging - -3 ~ 3 ppm 1 Nominal Frequency 2 Oscillation Mode 3 Load Capacitance 1st Year 8 Drive Level DL - 50 100 μW - 9 Effective Resistance Rr - - 80 Ω - 10 Shunt Capacitance C0 C0 - - 5 pF - 11 Insulation Resistance - 500 - - MΩ 12 Storage Temperature Range - -40 ~ 125 ℃ FMT-DOC015 VER.C TXC confidential and proprietary document at DC 100V - TXC CORPORATION ■ DIMENSIONS TXC P/N: AB10000301 0.9 ± 0.15 5.0 ± 0.15 3 GND 4 3.2 ± 0.15 1 PAGE: Connection 3 4 S1 REVISION: GND 1 2 2 1 4 2.0 1.7 2.0 1.2 1.0 1.2 2 0.9± 0.15 2.4 ± 0.15 1.3 ± 0.15 1.4 ± 0.15 Suggested Layout 3 *Coplanarity of solderable areas Camber 0.10 mm Max ■ MARKING   TXC Logo Pin 1 Location TXC □□□□□ ■ Frequency Code ex: 10.000000 MHZ = 10.00 □□□□ Tracking Code Production location: China or Taiwan ■ SUGGESTED REFLOW PROFILE Total time : 200 sec. Max. (℃) 10 sec 260 Solder melting point :220 ℃ 220 180 150 Time (sec) 120 sec FMT-DOC015 VER.C TXC confidential and proprietary document 60 sec TXC CORPORATION AB10000301 TXC P/N: REVISION: S1 PAGE: ■ STRUCTURE ILLUSTRATION 5 4 6 1 2 3 NO COMPONENTS MATERIALS FINISH/SPECIFICATIONS 1 Lid Kovar (Fe/Co/Ni) - 2 Package Ceramic (AI2O3) + Kovar (Fe/Co/Ni)+ Ag/Cu - 3 PAD Au Tungsten metalize + Ni plating + Au plating 4 Crystal blank SiO2 - 5 Conductive adhesive Ag+Silicon - 6 Electrode Noble Metal - FMT-DOC015 VER.C TXC confidential and proprietary document TXC CORPORATION AB10000301 TXC P/N: REVISION: S1 PAGE: ■ PACKING F G E B H INDEX MARK C A DIMENSIONS A B D C D Feeding E 1.65±0.10 5.40±0.10 3.50±0.10 8.00±0.10 12.00±0.30 F G 4.00±0.10 1.55±0.10 H 1.75±0.10 (UNIT : m REMARK : W W1 2.0 L1 DIMENSIONS FMT-DOC015 VER.C L L1 W W1 180±1.00 13±0.50 16.5±0.20 12±0.10 L pcs / Reel (UNIT : mm) Standard Reel Quantity is 1,000 pcs per reel TXC confidential and proprietary document TXC CORPORATION AB10000301 TXC P/N: REVISION: S1 PAGE: ■ RELIABILITY SPECIFICATIONS (AEC-Q200 Compliant) 1.Mechanical Endurance No. Test Item Test Methods 1.1 Drop Test 120 cm height, 20 times on Stainless Plate . Device are shocked to half sine wave ( 5000 G ) three mutually 1.2 Mechanical Shock perpendicular axes each 3 times. 0.3m sec. duration time 1.3 Vibration Frequency range 10 ~ 2000 Hz~10 Hz Amplitude 1.52 mm/20G Sweep time 20 minute Perpendicular axes each test time 4 Hrs Temperature 245 ℃ ± 5℃ Immersing depth 1.25 mm Immersion time 5 ± 1 seconds Flux Rosin resin methyl alcohol REF.DO JIS C 67 MIL-STDMethod 2 MIL-STDMethod 2 (Total test time 12 Hrs) 1.4 Solderability J-STD-0 solvent ( 1 : 4 ) 1.5 Terminal Strength Mount on PCB board and shear strength 1.8kg for 60 sec. AEC-Q200 1.6 Board Flex Duration Time: 60 sec, Deviation: 3mm AEC-Q200 2.Environmental Endurance No. Test Item Test Methods Pre-heat temperature 2.1 Resistance To Soldering Heat Pre-heat time 60 ~ 120 sec. Test temperature 260 ± 5 ℃ Test time 10 ± 1 sec. 2.2 High Temp. Storage + 125 ℃ ± 3 ℃ for all 1000 Hrs. 2.3 Low Temp. Storage - 40 ℃ ± 3 ℃ for all 1000 Hrs. REF. DO 125 ℃ MIL-STD Method 2 MIL-STDMethod 1 JIS C 67 Total 1000 cycles of the following Thermal Shock : MIL-STDMethod 1 2.4 Thermal Shock 2.5 Temperature Cycle Total 1000 cycles of the following temperature cycle : - 40℃ ± 3 to 125℃ ± 3 , Dwell time:15min. JESD 2 Method JA 2.6 Biased Humidity + 85℃ ± 3℃ , RH 85% , 1000 Hrs. MIL-STDMethod 1 2.7 Moisture Resistance 20 cycles ( +25℃~65℃ , 80%~100% RH) , 24hrs/cycle. MIL-STD Method 1 2.8 Operational Life + 125 ℃ ± 3 ℃ for 1000 Hrs. MIL-STDMethod 1 FMT-DOC015 VER.C TXC confidential and proprietary document 1 er iang FMT-DOC015 VER.C TXC confidential and proprietary document 2 ℃) FMT-DOC015 VER.C TXC confidential and proprietary document 3 FMT-DOC015 VER.C TXC confidential and proprietary document 4 FMT-DOC015 VER.C TXC confidential and proprietary document 5 mm) FMT-DOC015 VER.C TXC confidential and proprietary document 6 OC 701 -202 213 -202 204 002 0-006 0-005 OC 202 210 -202 108 701 -202 107 22 A-104 -202 103 202 106 -202 108 FMT-DOC015 VER.C TXC confidential and proprietary document
AB10000301 价格&库存
很抱歉,暂时无法提供与“AB10000301”相匹配的价格&库存,您可以联系我们找货
AB10000301
    • 1+4.10400
    • 10+3.31560
    • 30+2.97000
    库存:1
