TXC CORPORATION
www.txccorp.com
SPECIFICATION FOR APPROVAL
CN:
1701000769
CUSTOMER
PRODUCT TYPE
SMD GLASS SEALING X'TAL 3.2*2.5
NOMINAL FREQ.
8.000000MHz
TXC P/N
AV08000301
REVISION
S1
CUSTOMER P/N
PM / SALES
DATE
CUSTOMER SIGNATURE & Date
(1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance
of the attached specifications.
(2) Orders received and accepted by TXC after return of signed copy of specification will be produced per
these specifications.
(3) Any changes to these specifications must be agreed upon by both parties and new revision of the
Product Specification Sheet will be issued.
(4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets"
from customers will be regarded as the agreement on the contents of these specifications.
MSL:Level 1
RoHS Compliant
Pb used in sealing glass material is exempt from EU directive
FMT-DOC015
Issue Date: 03.18'15 VER.C
TXC CORPORATION
www.txccorp.com
PRODUCT SPECIFICATION SHEET
CN:
1701000769
PRODUCT TYPE
NOMINAL FREQ.
8.000000MHz
TXC P/N
AV08000301
REVISION
S1
PE/RD
QA
MFG
Wen
yuan
Chang
PREPAPRE
P PREPA
24-Jan-17
NOTE:
(1)The green product standard set by TXC is based upon the international standards. Related information is
publicly described on the TXC's Website, and updated regularly. The document is compliant with the latest green
product quality system directives at the time.
(2)Revision "Sx" is for engineering samples only. PE/RD's approval required.
(3)Revision "Ax" is production ready. PE, QA and MFG's approval required
MSL:Level 1
RoHS Compliant
FMT-DOC015
TXC CORPORATION
Rev
Revise page
S1
N/A
FMT-DOC015
TXC P/N:
Revise contents
Initial released
AV08000301
REVISION:
S1
PAGE: 1
Date
Ref.No.
Reviser
24-Jan-17
N/A
Xiaohua Zhang
TXC CORPORATION
TXC P/N:
AV08000301
REVISION:
S1
PAGE: 2
Spec Sheet Contents
No.
Content
Page
1
ELECTRICAL SPECIFICATIONS
P.3
2
DIMENSIONS
P.4
3
MARKING
P.4
4
FACTORY LOCATION
P.4
5
SUGGESTED REFLOW PROFILE& MANUAL SOLDER CONDITION
P.4
6
STRUCTURE ILLUSTRATION
P.5
7
EMBOSS CARRIER TAPE & REEL
P.6
8
PACKING
P.7
9
RELIABILITY SPECIFICATIONS
FMT-DOC015
P.8~9
TXC CORPORATION
TXC P/N:
AV08000301
REVISION:
S1
PAGE: 3
■ ELECTRICAL SPECIFICATIONS
Standard atmospheric conditions
Unless otherwise specified, the standard range of atmospheric conditions for making measurement
and tests are as follow:
Ambient temperature :
25±5℃
Relative humidity
40%~70%
If there is any doubt about the results, measurement shall be made within the following limits:
25±3℃
Relative humidity
40%~70%
Measure equipment
Electrical characteristics measured by S&A250B or equivalent.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode).
Unit Weight:
0.020±0.002 g/pcs
Parameters
1 Nominal Frequency
2 Oscillation Mode
SYM.
Electrical Spec.
MIN
TYP
MAX
Notes
UNITS
FL
8.000000
MHz
Fundamental
CL
12
pF
4 Frequency Tolerance
±30
ppm
at 25 ℃ ± 3 ℃
5 Frequency Stability
±100
ppm
Over Operating Temp. Range (Reference 25℃)
6 Operating Temperature
3 Load Capacitance
7 Aging
-40
125
±3
ppm
1st Year
8 Drive Level
DL
10
100
uW
9 Series Resonant Resistance
Rr
300
Ω
10 Shunt Capacitance
C0
3
pF
11 Insulation Resistance
500
MΩ
12 Storage Temperature Range
-40
125
FMT-DOC015
at DC 100V
TXC CORPORATION
TXC P/N:
AV08000301
REVISION:
S1
PAGE: 4
■ DIMENSIONS
(Unit:mm)
2
1
Suggested Layout
2
1
*Phrototype, The drawing just for reference only.
*Coplanarity of solderable areas Camber 0.10 mm Max
■ MARKING
T
TXC Logo
Frequency Code
Ex.:
8.000000
MHz =
080
Tracking Code
Production Location:China(Ningbo)
■ SUGGESTED REFLOW PROFILE
Solder melting point :220±10 ℃, 60 sec. Min.
Peak Temperature: 260 ± 5 ℃, 10 sec. Max.
10 sec
260
220
180
150
Time (sec)
120 sec
60 sec
■ SUGGESTED MANUAL SOLDER CONDITION
Temperature: 350 ± 10 ℃
Time: 3 sec.
Re-solder times: twice
FMT-DOC015
TXC CORPORATION
TXC P/N:
AV08000301
REVISION:
S1
PAGE: 5
■ STRUCTURE ILLUSTRATION
NO
COMPONENTS
MATERIALS
FINISH/SPECIFICATIONS
1 Cap
Ceramic (AI2O3)
2 Package
Ceramic (AI2O3)
3 PAD
Au
Tungsten metalize
+ Ni plating
+ Au plating
4 Crystal blank
SiO2
5 Conductive adhesive
Resin+Ag
6 Electrode
Noble Metal
7 Sealing Glass
Glass(PbO)
FMT-DOC015
TXC CORPORATION
AV08000301
TXC P/N:
REVISION:
S1
PAGE: 6
■ EMBOSS CARRIER TAPE & REEL
F
E
B
H
G
DIMENSIONS
Feeding
D
C
A
A
B
C
D
E
F
G
H
1.65
±0.10
3.40
±0.10
2.70
±0.10
4.00
±0.10
8.00
±0.20
4.00
±0.10
1.55
±0.10
1.75
(UNIT:mm)
±0.10
REMARK :
160mm min
160mm min
T
T
T
T
Empty Sealed
3000pcs Products
Trailer
400mm min
Leader
User Direction of Feeding
W
W1
2.0
L1
DIMENSIONS
FMT-DOC015
L
L1
W
W1
178±1.00
13±0.50
11.5±0.20
8±0.10
L
(UNIT:mm)
TXC CORPORATION
TXC P/N:
AV08000301
REVISION:
S1
PAGE:
7
■ PACKING
Reel Quantity :
1. Reel X 6 (6 Reels)
2. Reel X 12 (12 Reels)
3. Reel X 25 (12 Reels + 13 Reels)
4. Reel X 50 ( 12 Reelsx2 + 13 Reelsx2 )
Label B
Box Size:
1. L200 X W200 X H140mm
2. L200 X W200 X H250mm
3. L400 X W200 X H250mm
4. L400 X W400 X H280mm
Tape
Tape
Label B
Label A
QA Pass
(Label A) Size:100 X 100mm
(Lable B) Size:80 X 40mm
[STORAGE]
1.Don't be caught in the rain.
2.The storage environment shall be 5℃ ~40℃ temperature and 30% ~ 75%RH humidity and free from the sun shine.
3.If customers have special requirements, we can paste labels according to it.
FMT-DOC015
TXC CORPORATION
REVISION: S1
TXC P/N: AV08000301
PAGE:
8
■ RELIABILITY SPECIFICATIONS (AEC-Q200 Compliant)
1.Mechanical Endurance
No.
Test Item
1 Mechanical Shock
1 Vibration
Test Methods
Test Criteria
2000 G , 0.3 m Sec. ,3 times for all 3 directions.
Frequency range
10 ~ 2000 Hz
Acceleration
20G
Amplitude
1.52mm
Sweep time
20 minute
Pendicular axes each test time
4 hours
BC
BC
(Total test time 12 hours)
1 Terminal Strength
17.7N force for 60sec +/-1sec.
1 Board Flex
Duration time:60 Sec Minimum,Deviation:3mm
2 Solderability
F
BC
Temperature
245 oC +/- 5oC
Immersing depth
0.5 mm minimum
Immersion time
5 +/- 0.5 seconds
Flux
Rosin resin methyl alcohol
E
solvent ( 1 : 4 )
2.Environmental Endurance
No.
2
Test Item
Resistance To
Soldering Heat
Test Methods
SPEC
Test temperature
260 +/- 5 oC
Test time
10 +/- 1 sec.
BCD
2 High Temp. Storage +125℃ ± 3 ℃ for 1000 ± 12 Hrs
BCD
2 Low Temp. Storage - 40 ℃ ± 3 ℃ for 1000 ± 12 Hrs
BCD
B C D
-40℃~125℃,for 1000 cycles.
1 cycle
125+/-3℃
2 Temperature cycle
BCD
25 ℃
-40+/-3 ℃
15 min.
15 min.
2min
3 Operational Life
3
High Temp&
Humidity
FMT-DOC015
1000 hrs @ 125± 3°C. Rated VDD applied with 1 MΩ.
BCD
85℃ ± 3℃ , RH 85% , 1000 Hrs
BCD
Pro d u cts
put
in
F
1000
2
6
2
B
2
.0
TXC CORPORATION
1
8
5
U se r
C
d i re cti o n
of
D
W
p cs
Emp ty
G
Se a l e d
W 1
1
Leader
s
e
c
E
MAR K
1 6 0 mm(Mi n )
H
Tra i l e r
IN D EX
A
L
1
160
mm ( Mi n)
L
230
mm (
Mi n
fe e d
1
2
TXC P/N:
Tim
s
e
c
e
s
e
c
Fe e
d
in
g
6
s
e
c
AV08000301
REVISION:
S1
PAGE: 9
Specifications
A
Frequency change: Within ±5ppm or in customer's specification.
B
Frequency change: Within ±10ppm or in customer's specification.
C
Equivalent series resistance(E.S.R) change: Within ±15% or 10Ω(larger value).
D
After conditioning , quartz crystal units shall be subjected to standard atmospheric conditions for 24 hour,
and measured.
E
Minimum 95% of immersed terminal shall be covered with new uniform solder.
F
No damage on specimen
Measurement condition
FMT-DOC015
很抱歉,暂时无法提供与“AV08000301”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+2.44761
- 100+2.22508
- 500+2.02268
- 1000+1.92643
- 2000+1.83469
- 3000+1.74735
- 国内价格
- 1+3.36960
- 10+2.78640
- 30+2.49480
- 100+2.20320
