AV12200001
AV12200001
    TXC(台晶)
    SMD3225_4P
    无源晶振 SMD3225_4P
AV12200001 数据手册
TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com SPECIFICATION FOR APPROVAL CUSTOMER : PRODUCT TYPE : SMD GLASS SEALING X'TAL 3.2*2.5 NOMINAL FREQ. : 12.288000MHz TXC P/N : AV12200001 REVISION : A1 CUSTOMER P/N : PM / SALES : DATE : CUSTOMER SIGNATURE & Date (1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance of the attached specifications. (2) Orders received and accepted by TXC after return of signed copy of specification will be produced per these specifications. (3) Any changes to these specifications must be agreed upon by both parties and new revision of the Product Specification Sheet will be issued. (4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. MSL:Level 1 RoHS Compliant Pb used in sealing glass material is exempt from EU directive FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com PRODUCT SPECIFICATION SHEET PRODUCT TYPE : SMD GLASS SEALING X'TAL 3.2*2.5 NOMINAL FREQ. : 12.288000MHz TXC P/N : AV12200001 REVISION : A1 PE/RD QA MFG 7-Sep-11 7-Sep-11 7-Sep-11 NOTE: (1)Lead Free Products are "Directive 2002/95/EC of The European Parliament of 27 January 2003 on the restriction of the use of certain hazardous substances (RoHS) in electrical and electronic equipment" Compliant (Attachment: SGS Test Report). (2)Revision "Sx" is for engineering samples only. PE/RD's approval required. (3)Revision "Ax" is production ready. PE, QA and MFG's approval required MSL:Level 1 RoHS Compliant Pb used in sealing glass material is exempt from EU directive FMT-DOC024 Issue Date: 12.15'08 VER.E TXC P/N: TXC CORPORATION Rev Revise page S1 N/A A1 N/A FMT-DOC024 AV12200001 REVISION: A1 PAGE: 1 Date Ref.No. Reviser Initial released 3-Jul-11 N/A Jun Wei S Turn A 7-Sep-11 N/A Xiaoyan Jiang Revise contents Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: AV12200001 REVISION: A1 PAGE: 2 Spec Sheet Contents No. Content Page 1 ELECTRICAL SPECIFICATIONS P.3 2 FACTORY LOCATION P.3 3 DIMENSIONS P.4 4 MARKING P.4 5 SUGGESTED REFLOW PROFILE& MANUAL SOLDER CONDITION P.4 6 STRUCTURE ILLUSTRATION P.5 7 EMBOSS CARRIER TAPE & REEL P.6 8 PACKING P.7 9 RELIABILITY SPECIFICATIONS FMT-DOC024 P.8~9 Issue Date: 12.15'08 VER.E TXC P/N: AV12200001 TXC CORPORATION REVISION: A1 PAGE: 3 ■ ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature : 25±5℃ Relative humidity 40%~70% : If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature : 25±3℃ Relative humidity 40%~70% : Measure equipment Electrical characteristics measured by S&A250B or equivalent. Crystal cutting type The crystal is using AT CUT (thickness shear mode). Unit Weight: 0.018±0.001 g/pcs Parameters 1 Nominal Frequency SYM. Electrical Spec. MIN TYP FL 12.288000 MAX Notes UNITS MHz - - Fundamental - - CL 18 pF - Frequency Tolerance - ±20 ppm at 25 ℃ ± 3 ℃ Frequency Stability - ±30 ppm Over Operating Temp. Range (Reference 25℃) 6 Operating Temperature - 7 Aging - 8 Drive Level 9 Series Resonant Resistance 2 Oscillation Mode 3 Load Capacitance 4 5 -40 ~ 85 ±3 DL - 50 - - ℃ ppm 1st Year uW - Rr - - 150 Ω - C0 - - - pF - 11 Insulation Resistance - 500 - - MΩ 12 Storage Temperature Range - -40 ~ 85 ℃ 10 Shunt Capacitance at DC 100V - ■ FACTORY LOCATION TXC (NINGBO) CORPORATION NO.189 Huang Shan West Road, Beilun District, Ningbo Zhejiang China FMT-DOC024 Issue Date: 12.15'08 VER.E AV12200001 TXC P/N: TXC CORPORATION ■ DIMENSIONS (Unit:mm) REVISION: A1 PAGE: 4 Connection ± #2 & #4 are not internally connected Suggested Layout *Coplanarity of solderable areas Camber 0.10 mm Max ■ MARKING   T□□□ TXC Logo Frequency Code Ex.: 12.288000 MHz = 122 □□□ Lot Code Date Code Line Code Date Code: MONTH YEAR JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC 2005 2009 2013 2017 A B C D E F G H J K L M 2006 2010 2014 2018 N P Q R S T U V W X Y Z 2007 2011 2015 2019 a b c d e f g h j k l m 2008 2012 2016 2020 n p q r s t u v w x y z *This date code will be cycled every four years (℃) ■ SUGGESTED REFLOW PROFILE Solder melting point :220±10 ℃, 60 sec. Min. Peak Temperature: 260 ± 5 ℃, 10 sec. Max. 10 sec 260 220 180 150 ■ SUGGESTED MANUAL SOLDER CONDITION Temperature: 350 ± 10 ℃ Time: 3 sec. Time (sec) 120 sec 60 sec Re-solder times: twice FMT-DOC024 Issue Date: 12.15'08 VER.E TXC P/N: TXC CORPORATION AV12200001 REVISION: A1 PAGE: ■ STRUCTURE ILLUSTRATION 5 6 4 1 7 2 3 COMPONENTS NO MATERIALS FINISH/SPECIFICATIONS - Package Ceramic (AI2O3) Ceramic (AI2O3) PAD Au Tungsten metalize 1 Cap 2 3 + Ni plating + Au plating 4 Crystal blank SiO2 - 5 Conductive adhesive Resin+Ag - 6 Electrode Noble Metal - 7 Sealing Glass Glass(PbO) - FMT-DOC024 Issue Date: 12.15'08 VER.E 5 TXC P/N: TXC CORPORATION AV12200001 REVISION: A1 PAGE: 6 ■ EMBOSS CARRIER TAPE & REEL F E B H G DIMENSIONS A 1.65±0.10 B Feeding D C A C D E F G H 3.40±0.10 2.70±0.10 4.00±0.10 8.00±0.20 4.00±0.10 1.55±0.10 1.75±0.10 (UNIT:mm) REMARK : Products put in 3000pcs Trailer 160mm(Min) Empty Sealed Leader 160mm(Min) 230mm(Min) User direction of feed DIMENSIONS FMT-DOC024 L L1 W W1 178±1.00 13±0.50 11.5±0.20 8±0.10 (UNIT:mm) Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: AV12200001 REVISION: A1 PAGE: 7 ■ PACKING Reel Quantity : 1. Reel X 6 (6 Reels) 2. Reel X 12 (12 Reels) 3. Reel X 25 (12 Reels + 13 Reels) 4. Reel X 50 ( 12 Reelsx2 + 13 Reelsx2 ) Label B Box Size: 1. L200 X W200 X H140mm 2. L200 X W200 X H250mm 3. L400 X W200 X H250mm 4. L400 X W400 X H280mm Tape Tape Label A Label B QA Pass (Label A) Size:100 X 100mm (Lable B) Size:80 X 40mm [STORAGE] 1.The storage time to be 1 year maximum. 2.Don't be caught in the rain. 3.The storage environment shall be 5℃ ~40℃ temperature and 30% ~ 75%RH humidity and free from the sun shine. 4.If customers have special requirements, we can paste labels according to it. FMT-DOC024 Issue Date: 12.15'08 VER.E AV12200001 TXC P/N: TXC CORPORATION REVISION: A1 PAGE: 8 ■ RELIABILITY SPECIFICATIONS 1.Mechanical Endurance No. 1.1 1.2 Test Item Mechanical Shock Vibration Test Methods Test Criteria 2000 G , 0.3 m Sec. ,3 times for all 3 directions. BC Frequency range 10 ~ 2000 Hz Acceleration 5G Sweep time 20 minute Pendicular axes each test time 4 hours BC (Total test time 12 hours) 1.3 Terminal Strength 17.7N force for 60sec +/-1sec. 1.4 Board Flex Duration time:60 Sec Minimum,Deviation:3mm F BC 2.Environmental Endurance No. 2.1 Test Item Solderability SPEC Test Methods o o Temperature 245 C +/- 5 C Immersing depth 0.5 mm minimum Immersion time 5 +/- 0.5 seconds Flux Rosin resin methyl alcohol E solvent ( 1 : 4 ) 2.2 Resistance To Soldering Heat Test temperature 260 +/- 5 oC Test time 10 +/- 1 sec. Emersion Rate 25 ± 6 mm/s Immersed of specimen 1.5mm BCD 2.3 High Temp. Storage + 85℃ ± 3 ℃ for 1000 ± 12 Hrs BCD 2.4 Low Temp. Storage BCD - 40 ℃ ± 3 ℃ for 1000 ± 12 Hrs -40℃~85℃,for 1000 cycles. B C D 1 cycle 85+/-3 0C 2.5 Thermal Shock 25 0C -40+/-3 0C BCD 5 min. 5 min. 10 Sec. 2.6 Operational Life 2.7 High Temp&Humidity85℃ ± 3℃ , RH 85% , 1000 Hrs FMT-DOC024 1000 hrs @ 85± 3°C. Rated VDD applied with 1 MΩ. BCD BCD Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: AV12200001 REVISION A1 PAGE: 9 RELIABILITY SPECIFICATIONS Specifications A Frequency change: Within ±5ppm or in customer's specification. B Frequency change: Within ±10ppm or in customer's specification. C Equivalent series resistance(E.S.R) change: Within ±15% or 10Ω(larger value). D After conditioning , quartz crystal units shall be subjected to standard atmospheric conditions for 24 hour, and measured. E Minimum 95% of immersed terminal shall be covered with new uniform solder. F No damage on specimen Measurement condition Electrical characteristics measured by S&A250B or equivalent. FMT-DOC024 Issue Date: 12.15'08 VER.E
AV12200001 价格&库存
很抱歉,暂时无法提供与“AV12200001”相匹配的价格&库存,您可以联系我们找货
