7W50000020
7W50000020
    TXC(台晶)
    4-SMD, No Lead
    XTAL OSC XO 50.0000MHZ CMOS SMD
7W50000020 数据手册
TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com SPECIFICATION FOR APPROVAL CUSTOMER : PRODUCT TYPE : SMD SEAM SEALING CXO 7.0×5.0 NOMINAL FREQ. : 50.000000MHz TXC P/N : 7W50000020 REVISION : A1 CUSTOMER P/N : PM / SALES : DATE : CUSTOMER SIGNATURE & Date (1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance of the attached specifications. (2) Orders received and accepted by TXC after return of signed copy of specification will be produced per these specifications. (3) Any changes to these specifications must be agreed upon by both parties and new revision of the Product Specification Sheet will be issued. (4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. Attachment: Product Specification Sheet 1 2 3 4 5 RoHS Compliant FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com PRODUCT SPECIFICATION SHEET PRODUCT TYPE : SMD SEAM SEALING CXO 7.0×5.0 NOMINAL FREQ. : 50.000000MHz TXC P/N : 7W50000020 REVISION : A1 PE/RD QA MFG NOTE: (1)Lead Free Products are "Directive 2002/95/EC of The European Parliament of 27 January 2003 on the restriction of the use of certain hazardous substances (RoHS) in electrical and electronic equipment" Compliant (Attachment: SGS Test Report). (2)Revision "Sx" is for engineering samples only. PE/RD's approval required. (3)Revision "Ax" is production ready. PE, QA and MFG's approval required. RoHS Compliant FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION Rev Revise page A1 N/A FMT-DOC024 TXC P/N: 7W50000020 Revise contents Initial released REVISION: A1 PAGE: 1 Date Ref.No. Reviser 23-Mar-10 N/A Yachuan Miao Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 7W50000020 REVISION: A1 PAGE: 2 ■ ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature : 25±5℃ Relative humidity 40%~70% : If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature : 25±3℃ Relative humidity 40%~70% : Measure equipment Electrical characteristics measured by MD 37WX-05M or equivalent. Crystal cutting type The crystal is using AT CUT (thickness shear mode). Unit Weight: 0.152±0.001 g/pcs Parameters Symbol Electrical Spec. Min. Typ. Max. Notes Units 1 Nominal Frequency - 50.000000 MHz - 2 Frequency Stability - ±25 ppm - Topr -40 4 Storage Temperature Tstg -55 5 Supply Voltage VDD 3 Operating Temperature Icc 6 Input Current CMOS 85 ℃ - ~ 125 ℃ - V - mA - 3.3 ±10% - - 15 Yes - 7 Enable Control 25 - 15 Pad 1 pF - 9 Output Voltage High VoH 90%Vdd - - V - 10 Output Voltage Low VoL - - 10%Vdd V - Tr - - 4 ns 10%→90%VDD Level 90%→10%VDD Level 8 Output Load : 11 Rise Time CL Tf - - 4 ns 13 Symmetry (Duty ratio) TH/T 45 ~ 55 % - 14 Start-up Time Tosc - - 10 ms - 15 Enable Voltage High Vhi 70%Vdd - - V - 16 Disable Voltage Low Vlo - - 30%Vdd V - 12 Fall Time 17 Aging - ±3 ppm/yr. 1st. Year at 25℃ 18 Output Disable Delay Time T off - - 150 μS - 19 Output Enable Delay Time T on - - 150 μS - FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 7W50000020 A1 REVISION: PAGE: 3 ■ DIMENSIONS (Unit:mm) 1.30± 0.115 7.00±0.20 4 3 PAD FUNCTION: 1: ENABLE CONTROL 2: GND 3: OUT 4: VDD 5.00±0.20 Crystal DLD2 measurement terminal (Note: #1) 1.40±0.20 1.10±0.20 2 1 Suggested Layout 1.80 3.28 1.80 4 3 5.08±0.20 2.60±0.20 4.20 2.00 2.20 2.00 2 1 5.08 Note: #1. DLD2 / Drive Level Dependency 2 Maximum resistance minus minimum resistance. ■ MARKING Output Level Line Code Date Code   TXC Logo TXC □□□□□ Lot Code Pin 1 Location ■ □□□□□□ Frequency Code ex:14.318180 MHz=14.318 Output Level: VDD(V) 5 CODE A 3.3 2.8 2.5 1.8 2.9 3.0 B C D E F G 2.85 2.6 2.55 2 H J K L 1.5 2.7 M N Date Code: MONTH YEAR JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC 2005 2009 2013 2017 A B C D E F G H J K L M 2006 2010 2014 2018 N P Q R S T U V W X Y Z 2007 2011 2015 2019 a b c d e f g h j k l m 2008 2012 2016 2020 n p q r s t u v w x y z *This date code will be cycled every four years Production location:Taiwan FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 7W50000020 REVISION: A1 PAGE: 4 ■ TEST DIAGRAM Control input (output enable/disable) Logic 1 or open on pad 1: Oscillator output Logic 0 on pad 1 : Disable output to high impedance ■ WAVEFORM CONDITIONS Waveform measurement system should have a min. bandwidth of 5 times the frequency being tested. FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 7W50000020 REVISION: A1 PAGE: 5 ■ OUTPUT ENABLE / DISABLE DELAY The following figure shows the oscillator timing during normal operation . Note that when the device is in standby, the oscillator stops. When standby is released, the oscillator starts and stable oscillator output occurs after a short delay. ■ SUGGESTED REFLOW PROFILE Total time : 200 sec. Max. Solder melting point :220 ℃ FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 7W50000020 REVISION: A1 PAGE: 6 ■ STRUCTURE ILLUSTRATION 5 6 4 1 7 9 2 8 3 NO COMPONENTS MATERIALS FINISH/SPECIFICATIONS 1 LID Kovar (Fe/Co/Ni) - 2 Base(Package) Ceramic (AI2O3) + Kovar (Fe/Co/Ni)+ Ag/Cu Color black 3 PAD Au Tungsten metalize + Ni plating + Au plating 4 Crystal blank SiO2 - 5 Conductive adhesive Ag Silicon resin 6 Electrode Noble Metal - 7 IC chip - - 8 Bonding wire Au Pad 1 options : NC is 5 wires , 9 Die attached Conductive (Ag) Epoxy resin EN is 6 wires. FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 7W50000020 REVISION: A1 PAGE: 7 ■ PACKING DIMENSIONS A B C D E F G H 2.30 7.90 5.45 8.00 16.00 4.00 1.50 1.75 (UNIT : mm) REMARK : DIMENSIONS FMT-DOC024 L L1 W W1 pcs / Reel (UNIT : mm) 180 13 20.5 16 Standard Reel Quantity is 1,000 pcs per reel Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 7W50000020 REVISION: A1 PAGE: 8 ■ RELIABILITY SPECIFICATIONS 1.Mechanical Endurance No. Test Item 1 Drop Test Test Methods REF. DOC JIS C6701 75 cm height,3 times on concrete floor . 1 Mechanical Shock 1 Vibration Device are shocked to half sine wave ( 1000 G ) three mutually perpendicular axes each 3 times. 0.5m sec. duration time Frequency range 10 ~ 2000 Hz Amplitude 1.52 mm/20G Sweep time 20 minutes Perpendicular axes each test time 4 Hrs MIL-STD-202 MIL-STD-883 (Total test time 12 Hrs) 1 Gross Leak Standard Sample For Automatic Gross Leak Detector, Test Pressure: 2kg / cm2 2 Fine Leak Helium Bomging 4.5 kgf / cm 2 for 2 Hrs 2 Solderability Temperature 245 ℃ ± 5℃ Immersing depth 0.5 mm minimum Immersion time 5 ± 1 seconds Flux Rosin resin methyl alcohol MIL-STD-883 MIL-STD-883 solvent ( 1 : 4 ) 2.Environmental Endurance No. Test Item 2 Resistance To Soldering Heat Test Methods Pre-heat temperature 125 ℃ Pre-heat time 60 ~ 120 sec. Test temperature 260 ± 5 ℃ Test time 10 ± 1 sec. 2 High Temp. Storage + 125 ℃ ± 3 ℃ for 1000 ± 12 Hrs 2 Low Temp. Storage - 40 ℃ ± 3 ℃ for 1000 ± 12 Hrs REF. DOC MIL-STD-202 MIL-STD-883 Total 100 cycles of the following temperature cycle 2 Thermal Shock MIL-STD-883 3 Pressure Cooker Storage 121 ± 3℃ , RH100% , 2 bar , 240 Hrs JIS C6701 3 High Temp&Humidity 85℃ ± 3℃, RH 85% , 1000 Hrs JIS C5023 FMT-DOC024 Issue Date: 12.15'08 VER.E
7W50000020 价格&库存
很抱歉,暂时无法提供与“7W50000020”相匹配的价格&库存,您可以联系我们找货
