TXC CORPORATION
www.txccorp.com
SPECIFICATION FOR APPROVAL
CUSTOMER
PRODUCT TYPE
SMD SEAM SEALING CXO 3.2 × 2.5
NOMINAL FREQ.
33.333000MHz
TXC P/N
7X33300007
REVISION
A1
CUSTOMER P/N
PM / SALES
DATE
CUSTOMER
CONFIRMATION
(Singnature)
(Date)
(1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance
of the attached specifications.
(2) Orders received and accepted by TXC after return of signed copy of specification will be produced per
these specifications.
(3) Any changes to these specifications must be agreed upon by both parties and new revision of the
Product Specification Sheet will be issued.
(4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets"
from customers will be regarded as the agreement on the contents of these specifications.
MSL:Level 1
RoHS Compliant
(for glass crystal only:Pb used in sealing glass material is exempt from EU directive)
FMT-DOC024
Issue Date:04.17'15 VER.G
TXC CORPORATION
www.txccorp.com
PRODUCT SPECIFICATION SHEET
PRODUCT TYPE
NOMINAL FREQ.
33.333000MHz
TXC P/N
7X33300007
REVISION
A1
PE/RD
QA
MFG
Oscar Chen
Alex Huang
Leye Tang
19-Jan-16
19-Jan-16
19-Jan-16
NOTE:
(1) The green product standard set by TXC is based upon the international standards. Related information is publicly
described on the TXC's Website, and updated regularly. The document is compliant with the latest green product
quality system directives at the time.
(2) Revision "Sx" is for engineering samples only. PE/RD's approval required.
(3) Revision "Ax" is production ready. PE, QA and MFG's approval required.
MSL:Level 1
RoHS Compliant
FMT-DOC024
TXC CORPORATION
TXC P/N: 7X33300007
Rev
Revise page
A1
N/A
FMT-DOC024
REVISION: A1
Revise contents
Initial released
PAGE: 1
Date
Ref.No.
Reviser
19-Jan-16
N/A
Yachuan Miao
TXC CORPORATION
TXC P/N: 7X33300007
REVISION: A1
PAGE: 2
■ ELECTRICAL SPECIFICATIONS
Standard atmospheric conditions
Unless otherwise specified, the standard range of atmospheric conditions for making measurement
and tests are as follow:
Ambient temperature :
25±5℃
Relative humidity
40%~70%
If there is any doubt about the results, measurement shall be made within the following limits:
25±3℃
Relative humidity
40%~70%
Measure equipment
Electrical characteristics measured by MD 37WX-05M or equivalent.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode).
Unit Weight:
0.025±0.002 g/pcs
Parameters
Symbol
Electrical Spec.
Min.
Typ.
Max.
Notes
Units
1 Nominal Frequency
33.333000
MHz
2 Frequency Stability
±25
ppm
Topr
-40
4 Storage Temperature
Tstg
-55
5 Supply Voltage
VDD
3 Operating Temperature
Icc
6 Input Current
125
V
mA
13
Yes
Pad 1
pF
10 Output Voltage High
VoH
90%Vdd
V
11 Output Voltage Low
VoL
10%Vdd
V
Tr
5
ns
10%→90%VDD Level
90%→10%VDD Level
8 Output Load :
CMOS
85
3.3 ±10%
7 Enable Control
25
11 Rise Time
15
CL
Tf
5
ns
13 Symmetry (Duty ratio)
TH/T
45
55
14 Start-up Time
Tosc
10
ms
16 Enable Voltage High
Vhi
70%Vdd
V
17 Disable Voltage Low
Vlo
30%Vdd
V
12 Fall Time
18 Aging
±3
ppm/yr. 1st. Year at 25℃
18 Output Disable Delay Time
T off
150
μS
19 Output Enable Delay Time
T on
150
μS
FMT-DOC024
TXC CORPORATION
TXC P/N: 7X33300007
REVISION: A1
PAGE: 3
■ DIMENSIONS
(Unit:mm)
1.00±0.10
3.20±0.10
3
PAD FUNCTION:
1: ENABLE CONTROL
2.50±0.10
4
2: GND
3: OUT
4: VDD
1
2
4
3
0.80 1.40
1.20
0.50
1
1.40
1.20
1.20±0.15
Suggested Layout
1.00±0.15
0.90±0.15
0.65±0.15
2
■ MARKING
T □□□
TXC Logo
Pin 1 Location
Frequency Code
ex:14.318180 MHz=143
Output Level
Tracking Code
Output Level:
VDD(V)
CODE
5.00 3.30 2.80 2.50 1.80 2.90 3.00 2.85 2.60 2.55 2.00 1.50 2.70 3.40 1.90 1.20 1.00
A
B
C
D
E
F
G
H
J
K
L
M
N
P
Q
R
S
Production location:Taiwan
FMT-DOC024
TXC CORPORATION
TXC P/N: 7X33300007
REVISION: A1
PAGE: 4
■ TEST DIAGRAM
Pad 1 : Tri-State control
Pad 1(OE)
Pad 3 (Output)
Oscillator
High (or open)
OSC out
Normal operation
Low
High impedance
Stop oscillation
■ WAVEFORM CONDITIONS
Waveform measurement system should
have a min. bandwidth of 5 times the
frequency being tested.
FMT-DOC024
TXC CORPORATION
TXC P/N: 7X33300007
REVISION: A1
PAGE: 5
■ OUTPUT ENABLE / DISABLE DELAY
The following figure shows the oscillator timing during normal operation . Note that when the device is in standby,
the oscillator stops. When standby is released, the oscillator starts and stable oscillator output occurs after a
short delay.
■ SUGGESTED REFLOW PROFILE
Total time : 200 sec. Max.
Solder melting point :220 ℃
FMT-DOC024
TXC CORPORATION
TXC P/N: 7X33300007
REVISION: A1
PAGE: 6
■ STRUCTURE ILLUSTRATION
6
5
3
4
NO
COMPONENTS
1
7
8
2
MATERIALS
FINISH/SPECIFICATIONS
1 Lid
Kovar (Fe/Co/Ni)
2 Base (Package)
Ceramic (AI2O3) + Kovar (Fe/Co/Ni)+Pad (Au)
3 IC chip
4 Crystal blank
SiO2
5 Conductive adhesive Ag
Silicon resin
6 Electrode
Noble Metal
7 Die attached
Conductive (Ag)
Epoxy resin
8 Bonding wire
Au
FMT-DOC024
Pad 1 options : NC is 5 wires ,
EN is 6 wires.
TXC CORPORATION
TXC P/N: 7X33300007
REVISION: A1
PAGE: 7
■ EMBOSS CARRIER TAPE & REEL
A
DIMENSIONS
B
C
D
E
F
G
H
1.65
3.40
2.70
4.00
8.00
4.00
1.55
1.75
±0.10
±0.10
±0.10
±0.10
±0.20
±0.10
±0.05
±0.10
(UNIT:mm)
REMARK :
DIMENSIONS
FMT-DOC024
L
178
±1.00
L1
60.2
±0.50
W
11.5
±0.2
W1
8
+1/-0
Standard Reel Quantity is 3,000 pcs per reel
(UNIT:mm)
TXC CORPORATION
TXC P/N: 7X33300007
REVISION: A1
PAGE: 8
■ RELIABILITY SPECIFICATIONS
1.Mechanical Endurance
No.
Test Item
Test Methods
REF. DOC
1 Drop Test
75 cm height,3 times on concrete floor .
1 Mechanical Shock
Device are shocked to half sine wave ( 1000 G ) three mutually
perpendicular axes each 3 times. 0.5m sec. duration time
1 Vibration
Frequency range
10 ~ 2000 Hz
Amplitude
1.52 mm/20G
Sweep time
20 minutes
perpendicular axes each test time
4 Hrs
JIS C6701
MIL-STD-202
MIL-STD-883
(Total test time 12 Hrs)
1 Gross Leak
Standard Sample For Automatic Gross Leak Detector, Test
Pressure: 2kg / cm2
MIL-STD-883
2 Fine Leak
Helium Bomging 4.5 kgf / cm 2 for 2 Hrs
MIL-STD-883
2 Solderability
Temperature
245 ℃ ± 5℃
Immersing depth
0.5 mm minimum
Immersion time
5 ± 1 seconds
Flux
Rosin resin methyl alcohol
MIL-STD-883
solvent ( 1 : 4 )
2.Environmental Endurance
No.
Test Item
2 Resistance To Soldering Heat
Test Methods
Pre-heat temperature
125 ℃
Pre-heat time
60 ~ 120 sec.
Test temperature
260 ± 5 ℃
Test time
10 ± 1 sec.
2 High Temp. Storage
+ 125 ℃ ± 3 ℃ for 1000 ± 12 Hrs
2 Low Temp. Storage
- 40 ℃ ± 3 ℃ for 1000 ± 12 Hrs
REF. DOC
MIL-STD-202
MIL-STD-883
Total 100 cycles of the following temperature cycle
2 Thermal Shock
MIL-STD-883
3 High Temp&Humidity
85℃ ± 3℃, RH 85% , 1000 Hrs
EIA-JESD22
3 Pressure Cooker Storage
121 ± 3℃ , RH100% , 2 bar , 240 Hrs
EIA-JESD22
FMT-DOC024
很抱歉,暂时无法提供与“7X33300007”相匹配的价格&库存,您可以联系我们找货
