7X40000019
7X40000019
    TXC(台晶)
    SMD3225-4P
    频率:40MHz;频率稳定度:±20ppm;工作电压:3.3V;
7X40000019 数据手册
TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com SPECIFICATION FOR APPROVAL CUSTOMER : PRODUCT TYPE : SMD SEAM SEALING CXO 3.2 × 2.5 NOMINAL FREQ. : 40.000000MHz TXC P/N : 7X40000019 REVISION : A1 CUSTOMER P/N : PM / SALES : DATE : CUSTOMER SIGNATURE & Date (1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance of the attached specifications. (2) Orders received and accepted by TXC after return of signed copy of specification will be produced per these specifications. (3) Any changes to these specifications must be agreed upon by both parties and new revision of the Product Specification Sheet will be issued. (4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. Attachment: Product Specification Sheet 1 2 3 4 5 FMT-DOC024 RoHS Compliant Issue Date: 12.15'08 VER.E TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com PRODUCT SPECIFICATION SHEET PRODUCT TYPE : SMD SEAM SEALING CXO 3.2 × 2.5 NOMINAL FREQ. : 40.000000MHz TXC P/N : 7X40000019 REVISION : A1 PE/RD QA MFG Mike Chiu Chester Ho Leye Tang NOTE: (1)Lead Free Products are "Directive 2002/95/EC of The European Parliament of 27 January 2003 on the restriction of the use of certain hazardous substances (RoHS) in electrical and electronic equipment" Compliant (Attachment: SGS Test Report). (2)Revision "Sx" is for engineering samples only. PE/RD's approval required. (3)Revision "Ax" is production ready. PE, QA and MFG's approval required. RoHS Compliant FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION Rev Revise page A1 N/A FMT-DOC024 TXC P/N: 7X40000019 Revise contents Initial released REVISION: A1 PAGE: 1 Date Ref.No. Reviser 12-Apr-13 N/A Yachuan Miao Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 7X40000019 REVISION: A1 PAGE: 2 ■ ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature : 25±5℃ Relative humidity 40%~70% : If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature : 25±3℃ Relative humidity 40%~70% : Measure equipment Electrical characteristics measured by MD 37WX-05M or equivalent. Crystal cutting type The crystal is using AT CUT (thickness shear mode). Unit Weight: 0.025±0.002 g/pcs Parameters Symbol Electrical Spec. Min. Typ. Max. Notes Units 1 Nominal Frequency - 40.000000 MHz - 2 Frequency Stability - ±20 ppm - Topr -10 4 Storage Temperature Tstg -55 5 Supply Voltage VDD 3 Operating Temperature Icc 6 Input Current CMOS 85 ℃ - ~ 125 ℃ - V - mA - 3.3 ±10% - - 7 Enable Control 25 - 9 Yes - 15 pF - 9 Output Voltage High VoH 90%Vdd - - V - 10 Output Voltage Low VoL - - 10%Vdd V - Tr - - 5 ns 10%→90%VDD Level 90%→10%VDD Level 8 Output Load : 11 Rise Time CL Pad 1 Tf - - 5 ns 13 Symmetry (Duty ratio) TH/T 45 ~ 55 % - 14 Start-up Time Tosc - - 10 ms - 15 Enable Voltage High Vhi 70%Vdd - - V - 16 Disable Voltage Low Vlo - - 30%Vdd V - 12 Fall Time 17 Aging - ±3 ppm/yr. 1st. Year at 25℃ 18 Output Disable Delay Time T off - - 150 us - 19 Output Enable Delay Time T on - - 150 us - FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 7X40000019 REVISION: A1 PAGE: 3 ■ DIMENSIONS (Unit:mm) 1.00±0.10 3.20±0.10 3 PAD FUNCTION: 2.50±0.10 4 1: ENABLE CONTROL 2: GND 3: OUT 4: VDD 1 2 4 3 0.80 1.40 1.20 0.50 1 1.40 1.20 1.20±0.15 Suggested Layout 1.00±0.15 0.90±0.15 0.65±0.15 2 ■ MARKING   T □□□ TXC Logo Pin 1 Location ■ Frequency Code ex:14.318180 MHz=143 □□□□ Lot Code Date Code Output Level Output Level: VDD(V) 5.00 3.30 2.80 2.50 1.80 2.90 3.00 2.85 2.60 2.55 2.00 1.50 2.70 3.40 1.90 1.20 1.00 CODE A B C D E F G H J K L M N P Q R S 1 2 3 4 5 6 7 8 9 10 11 Date Code: MONTH YEAR JAN FEB MAR APR MAY 12 JUN JUL AUG SEP OCT NOV DEC 2005 2009 2013 2017 A B C D E F G H J K L M 2006 2010 2014 2018 N P Q R S T U V W X Y Z 2007 2011 2015 2019 a b c d e f g h j k l m 2008 2012 2016 2020 n p q r s t u v w x y z *This date code will be cycled every four years Production location:Taiwan FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 7X40000019 REVISION: A1 PAGE: 4 ■ TEST DIAGRAM Control input (output enable/disable) Logic 1 or open on pad 1: Oscillator output Logic 0 on pad 1 : Disable output to high impedance ■ WAVEFORM CONDITIONS Waveform measurement system should have a min. bandwidth of 5 times the frequency being tested. FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 7X40000019 REVISION: A1 PAGE: 5 ■ OUTPUT ENABLE / DISABLE DELAY The following figure shows the oscillator timing during normal operation . Note that when the device is in standby, the oscillator stops. When standby is released, the oscillator starts and stable oscillator output occurs after a short delay. ■ SUGGESTED REFLOW PROFILE Total time : 200 sec. Max. Solder melting point :220 ℃ FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 7X40000019 REVISION: A1 PAGE: 6 ■ STRUCTURE ILLUSTRATION 6 5 3 4 NO 1 7 COMPONENTS 8 2 MATERIALS FINISH/SPECIFICATIONS 1 Lid Kovar (Fe/Co/Ni) 2 Base (Package) Ceramic (AI2O3) + Kovar (Fe/Co/Ni)+Pad(Au) - 3 IC chip - - 4 Crystal blank SiO2 - 5 Conductive adhesive Ag - Silicon resin 6 Electrode Noble Metal - 7 Die attached Conductive (Ag) Epoxy resin 8 Bonding wire Au FMT-DOC024 Pad 1 options : NC is 5 wires , EN is 6 wires. Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 7X40000019 REVISION: A1 PAGE: 7 ■ PACKING REMARK : FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 7X40000019 REVISION: A1 PAGE: 8 ■ RELIABILITY SPECIFICATIONS 1.Mechanical Endurance No. Test Item 1 Drop Test REF. DOC Test Methods JIS C6701 75 cm height,3 times on concrete floor . 1 Mechanical Shock 1 Vibration Device are shocked to half sine wave ( 1000 G ) three mutually perpendicular axes each 3 times. 0.5m sec. duration time Frequency range 10 ~ 2000 Hz Amplitude 1.52 mm/20G Sweep time 20 minutes perpendicular axes each test time 4 Hrs MIL-STD-202 MIL-STD-883 (Total test time 12 Hrs) 1 Gross Leak Standard Sample For Automatic Gross Leak Detector, Test Pressure: 2kg / cm2 MIL-STD-883 2 2 Fine Leak Helium Bombing 4.5 kgf / cm for 2 Hrs 2 Solderability Temperature 245 ℃ ± 5℃ Immersing depth 0.5 mm minimum Immersion time 5 ± 1 seconds Flux Rosin resin methyl alcohol MIL-STD-883 solvent ( 1 : 4 ) 2.Environmental Endurance No. Test Item 2 Resistance To Soldering Heat Test Methods Pre-heat temperature 125 ℃ Pre-heat time 60 ~ 120 sec. Test temperature 260 ± 5 ℃ Test time 10 ± 1 sec. 2 High Temp. Storage + 125 ℃ ± 3 ℃ for 1000 ± 12 Hrs 2 Low Temp. Storage - 40 ℃ ± 3 ℃ for 1000 ± 12 Hrs REF. DOC MIL-STD-202 MIL-STD-883 Total 100 cycles of the following temperature cycle 2 Thermal Shock MIL-STD-883 3 High Temp&Humidity 85℃ ± 3℃, RH 85% , 1000 Hrs EIA-JESD22 3 Pressure Cooker Storage 121 ± 3℃ , RH100% , 2 bar , 240 Hrs EIA-JESD22 FMT-DOC024 Issue Date: 12.15'08 VER.E
7X40000019
物料型号: 7X40000019
器件简介: 这是一个SMD SEAM SEALING CXO,尺寸为3.2 x 2.5 mm,主要应用于需要小型化和高可靠性的场合。
引脚分配: 1. ENABLE CONTROL 2. GND 3. OUT 4. VDD
参数特性: - 标称频率: 40.000000MHz - 频率稳定性: +20ppm - 工作温度范围: -10°C 至 85°C - 存储温度范围: -55°C 至 125°C - 供电电压: 3.3V+10% - 输入电流: 9mA - 使能控制: 是,通过PAD 1
功能详解: - 该振荡器采用AT CUT(厚度剪切模式)的晶体切割类型。 - 输出负载为CMOS 15pF。 - 输出高电平电压VoH为90%Vdd,输出低电平电压VoL为10%Vdd。 - 上升时间Tr和下降时间Tf均为5ns。 - 占空比(对称性)TH/T为45%至55%。 - 启动时间Tosc为10ms。
应用信息: - 适用于需要小型化和高可靠性的电子设备。
封装信息: - 尺寸: 3.20±0.10mm x 2.50±0.10mm x 1.00±0.10mm。 - 标记包含TXC标志、频率代码、批次代码和日期代码。
7X40000019 价格&库存
很抱歉,暂时无法提供与“7X40000019”相匹配的价格&库存,您可以联系我们找货
