AS04000003
AS04000003
    TXC(台晶)
    HC49S
    无源晶振 HC49S
AS04000003 数据手册
TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com SPECIFICATION FOR APPROVAL CN: CUSTOMER : PRODUCT TYPE : HC-49/S NOMINAL FREQ. : 4.000000MHz TXC P/N : AS04000003 REVISION : A1 CUSTOMER P/N : PM / SALES : DATE : 1306000567 CUSTOMER SIGNATURE & Date (1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance of the attached specifications. (2) Orders received and accepted by TXC after return of signed copy of specification will be produced per these specifications. (3) Any changes to these specifications must be agreed upon by both parties and new revision of the Product Specification Sheet will be issued. (4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. Attachment: Product Specification Sheet 1 2 3 4 5 RoHS Compliant FMT-DOC015 Issue Date: 03.01'13 VER.A TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com PRODUCT SPECIFICATION SHEET CN: PRODUCT TYPE : HC-49/S NOMINAL FREQ. : 4.000000MHz TXC P/N : AS04000003 REVISION : A1 PE/RD QA Shih-Yung Pao Samson Xiong 25-Feb-13 25-Feb-13 1306000567 MFG Jake Liu 25-Feb-13 NOTE: (1)Lead Free Products are "Directive 2002/95/EC of The European Parliament of 27 January 2003 on the restriction of the use of certain hazardous substances (RoHS) in electrical and electronic equipment" Compliant (Attachment: SGS Test Report). (2)Revision "Sx" is for engineering samples only. PE/RD's approval required. (3)Revision "Ax" is production ready. PE, QA and MFG's approval required RoHS Compliant FMT-DOC015 Issue Date: 03.01'13 VER.A TXC CORPORATION Rev Revise page S1 N/A Initial Released A1 N/A S Turn A FMT-DOC015 TXC P/N: AS04000003 Revise contents REVISION A1 PAGE: 1 Date Ref.No. Reviser 3-Jul-11 N/A Jun Wei 25-Feb-13 N/A Xiaoyan Jiang Issue Date: 03.01'13 VER.A TXC CORPORATION TXC P/N: AS04000003 REVISION: A1 PAGE: 2 Spec Sheet Contents No. Content Page 1 ELECTRICAL SPECIFICATIONS P.3 2 FACTORY LOCATION P.3 3 DIMENSIONS P.4 4 SUGGESTED REFLOW PROFILE& MANUAL SOLDER CONDITION P.4 5 MARKING P.5 6 STRUCTURE ILLUSTRATION P.6 7 PACKING P.7 8 RELIABILITY SPECIFICATIONS FMT-DOC015 P.8~9 Issue Date: 03.01'13 VER.A TXC CORPORATION TXC P/N: AS04000003 REVISION: A1 PAGE: 3 ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature : 25+/-5oC Relative humidity 40%~70% : If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature : 25+/-1oC Relative humidity 40%~70% : Measure equipment SAUNDERS 250A/250B CRYSTAL IMPEDANCE METER. Crystal cutting type The crystal is using AT CUT (thickness shear mode). Unit Weight: 0.58±0.050 g/pcs please refer to marking code page Parameters 1 Nominal Frequency SYM. Electrical Spec. MIN TYPE FL 4.000000 MAX Notes UNITS MHz - - Fundamental - - CL 20 pF - 4 Frequency Tolerance - ±30 ppm at 25 ℃ ± 3 ℃ 5 Frequency Stability - ±30 ppm Over Operating Temp. Range (Reference 25℃) 6 Operating Temperature - 7 Aging - 2 Oscillation Mode 3 Load Capacitance -40 ~ 85 ±5 - ℃ ppm 1st Year 8 Drive Level DL - 100 - uW - 9 Effective Resistance Rr Rr - - 100 Ω - 10 Shunt Capacitance C0 C0 - - 7 pF 11 Insulation Resistance - 500 - - MΩ 12 Storage Temperature Range - -40 ~ 85 ℃ at DC 100V - ■ FACTORY LOCATION TXC (NINGBO) CORPORATION NO.189 Huang Shan West Road, Dagong Industrial City, Ningbo Economics & Technical Development Zone, Ningbo Zhejiang China FMT-DOC015 Issue Date: 03.01'13 VER.A TXC CORPORATION TXC P/N: AS04000003 REVISION: A1 PAGE: 4 UNIT:mm DIMENSIONS TXC 3.8 max. 3.68 max. 0.43+/-0.125 13.2+/-0.5 11.5 Max. Solder Coating 5.0 Max. (Sn-Ag-Cu Pb Free Coating) 4.88+/-0.25  ■ SUGGESTED REFLOW PROFILE Solder melting point :220±10 ℃, 60 sec. Min. Peak Temperature: 260 ± 5 ℃, 10 sec. Max. (℃) 10 sec 260 220 180 ■ SUGGESTED MANUAL SOLDER CONDITION 150 Temperature: 350 ± 10 ℃ Time: 3 sec. Re-solder times: twice FMT-DOC015 Time (sec) 120 sec 60 sec Issue Date: 03.01'13 VER.A TXC P/N: AS04000003 TXC CORPORATION REVISION: A1 PAGE: 5 MARKING Marking For Pb Free Parts: TXC TXC Logo Frequency Code G Pb Free Product Lot Code (2 digits) Production Line Code Date Code Date Code: MONTH YEAR 2001 2005 2002 2006 2003 2007 2004 2008 For example : 2009 2013 2017 A B C D E F G 2010 2014 2018 N P Q R S T U 2011 2015 2019 a b c d e f g 2012 2016 2020 n p q r s t u *This date code will be cycled every four years. H J K V W X h j k v w x L Y l y M Z m z Marking TXC G 4.00MA01 FMT-DOC015 JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC Pb Free Product Introduction: 49S 4.000 MHz Made in 2009/JAN. 01Lot Issue Date: 03.01'13 VER.A TXC CORPORATION TXC P/N: AS04000003 REVISION A1 PAGE: 6 ■ STRUCTURE ILLUSTRATION NO 1 COMPONENTS MATERIALS FINISH/SPECIFICATIONS CRYSTAL BLANK QUARTZ(SiO2) - HOLDER SPCC(Fe) Ni Plated SUPPORTER Nickel Silver(Cu/Zn/Ni) - GLASS GLASS - LEAD Kovar (Fe/Co/Ni) Ni Plated+Solder( Sn/Ag/Cu) Dipped 2 2 2 2 2 CRYSTAL BASE 3 CRYSTAL COVER Nickel Silver(Cu/Zn/Ni) Ni Plated 4 CONDUCTIVE ADHESIVE Resin + Ag - 5 ELECTRODE Noble Metal - FMT-DOC015 Issue Date: 03.01'13 VER.A TXC P/N: AS04000003 TXC CORPORATION REVISION: A1 PAGE: 7 Packing For Pb Free Parts : 5bagx200pcs =1000pcs/box 1.INNER BOX:(Unit:mm) 200pcs/bag PUT IN PUT 2.LOGO STICKER(CARTON and INNER BOX):(Unit:mm) Label B 150+/-10 ( Example ) B 190+/-10 42+/-10 PUT IN Label C ( Example ) C B # Put in stuff between space. [STORAGE] 1.The storage time to be 1 year maximum. 2.Don't be caught in the rain. 3.The storage environment shall be 5℃ ~40℃ temperature and 30% ~ 75%RH humidity and free from the sun shine. 4.If customers have special requirements, we can paste labels according to it. FMT-DOC015 Issue Date: 03.01'13 VER.A TXC P/N: TXC CORPORATION AS04000003 A1 REVISION: PAGE: 8 ■ RELIABILITY SPECIFICATIONS (AEC-Q200 Compliant) 1.Mechanical Endurance Test Item No. 1.1 Mechanical Shock Test Methods 1000 G , 0.5 m Sec. , 3 times for all 3 directions. Frequency range 1.2 Vibration Test Criteria BC 10 ~ 2000 Hz Acceleration 20G Sweep time 20 minute Pendicular axes each test time 4 hours BC (Total test time 12 hours) A: 10N force in axes of terminal, 10±1sec. 1.3 Terminal Strength B: A bend through 90°and return to normal position shall be defined as one bend , for a total of three ,the rate of bending shall be approximately 3sec per bend in F each direction. 1.4 Board Flex 1.5 Solderability Duration time:60 Sec Minimum,Deviation:3mm BC Temperature 245 oC +/- 5oC Immersing depth 0.5 mm minimum Immersion time 5 +/- 0.5 seconds Flux Rosin resin methyl alcohol E solvent ( 1 : 4 ) 2.Environmental Endurance Test Item No. 2.1 Resistance To Soldering Heat SPEC Test Methods Test temperature 260 +/- 5 oC Test time 10 +/- 1 sec. ACD 2.2 High Temp. Storage + 85℃ ± 3 ℃ for 1000 ± 12 Hrs ACD 2.3 Low Temp. Storage - 40 ℃ ± 3 ℃ for 1000 ± 12 Hrs ACD -40℃~85℃,for 1000 cycles. B C D 1 cycle 85+/-3 0C 2.4 Temperature cycle ACD 25 0C -40+/-3 C 0 15 min. 15 min. 2min. 2.5 Operational Life 1000 hrs @ 85± 3°C. Rated VDD applied with 1 MΩ. ACD 2.6 High Temp&Humidity 85℃ ± 3℃ , RH 85% , 1000 Hrs ACD ■HANDING CAUTIONS Prohibit the use of ultrasonic welding in Assemblying FMT-DOC015 Issue Date: 03.01'13 VER.A TXC CORPORATION TXC P/N: AS04000003 REVISION: A1 PAGE: 9 RELIABILITY SPECIFICATIONS Specifications A Frequency change: Within ±20ppm or in customer's specification. B Frequency change: Within ±10ppm or in customer's specification. C Equivalent series resistance(E.S.R) change: Within ±15% or 10Ω(larger value). D After conditioning , quartz crystal units shall be subjected to standard atmospheric conditions for 24 hour, and measured. E Minimum 95% of immersed terminal shall be covered with new uniform solder. F No damage on specimen Measurement condition Measurements are carried out with Network-analyzer( S&A 250B or equivalent). FMT-DOC015 Issue Date: 03.01'13 VER.A
AS04000003 价格&库存
很抱歉,暂时无法提供与“AS04000003”相匹配的价格&库存,您可以联系我们找货
