DGC3300001
DGC3300001
    TXC(台晶)
    SMD3225_6P
DGC3300001 数据手册
Programing Differential Quartz Crystal Oscillator General Specification Think of Frequency, Think of TXC Product Features 1. 2. 3. 4. 5. 6. 7.  Output Frequency: 15~2100 MHz (LVPECL / LVDS /CML) 15~700 MHz (HCSL) Frequency Stability : ± 30 ppm @ (-40 ~ 85℃) ± 50 ppm @ (-40 ~ 105℃) Supply Voltage : 1.8 , 2.5 , 3.3V (Typ.) Output Type : LVPECL / LVDS / HCSL /CML Phase Jitter: 0.15fs (Typ.) @156.25MHz LVPECL, 25℃ High Power Supply Noise Rejection Performance Industry Standard Package: 7.0 x 5.0 x 1.7 mm ( BC/BG/BX Series ) 5.0 x 3.2 x 1.2mm ( CC/CG/CX Series ) 3.2 x 2.5 x 1.1 mm ( DC/DG/DH Series ) 2.5 x 2.0 x 1.2 mm ( EC Series ) Table 1 . Electrical Specifications Parameters Symbol Min. Application:  Optical Modules  High Speed Network Interface Cards  Data Center Switch Test condition Ambient temperature:25 ± 5℃ Relative humidity: 40% ~ 70% Typ. Max. Units Conditions & Notes LVPECL / LVDS / HCSL /CML Common Electrical Characteristics Nominal Frequency F Frequency Stability ST 15~2100 MHz 15~700 ± 30 ppm ± 50 -40 - 85 -40 - 105 LVPECL / LVDS /CML HCSL @ -40~85℃ , Note 1 @ -40~105℃ , Note 1 Operating Temperature Topr Supply Voltage Vdd Symmetry TH/T 45 50 55 % Start-up Time Tosc - - 10 ms To 90% of Final Amplitude 1.8 , 2.5 , 3.3 (± 10%) ℃ V Note 2 LVPECL Electrical Characteristics Current Consumption Icc - 93 106 mA RL=50Ω to VDD-2V Icc(ST) - 91 104 uA OE = Low Output Voltage High VoH VDD-1.165 - VDD-0.8 V Output Voltage Low VoL VDD-2.0 - VDD-1.555 V Output Voltage Range Vdiff 600 1400 2000 mV Differential Peak-to-Peak Rise / Fall Time Tr / Tf - - 0.5 ns 20% ~ 80% Output Swing Enable Voltage High - 0.7VDD - - V Note 3 , (Logic 1) Enable Voltage Low - - - 0.3VDD V Note 3 , (Logic 0) Output Enable Delay Time - - - 5 ms Output Disable Delay Time - - - 200 ns RMS Phase Jitter PJ - 0.15~0.2 0.25 ps Standby Current Rev. A (2022.09.05) Page 1 of 7 Integrated from 12KHz ~ 20MHz @156.25MHz , 3.3V , Note4 www.txc.com.tw Programing Differential Quartz Crystal Oscillator General Specification Think of Frequency, Think of TXC  Test condition Ambient temperature:25 ± 5℃ Relative humidity: 40% ~ 70% Table 1 . Electrical Specifications (continued) Parameters Symbol Min. Typ. Max. Units Notes LVDS Electrical Characteristics Current Consumption Icc - 69 80 mA RL=100Ω Icc(ST) - 67 78 uA OE = Low Offset Voltage - 1.125 1.250 1.375 V Output Swing (Single) - 247 330 454 mV Single Peak-to-Peak Output Swing (Differential) Vdiff 494 660 908 mV Differential Peak-to-Peak Rise / Fall Time Tr / Tf - - 0.35 ns 20% ~ 80% Output Swing Enable Voltage High - 0.7VDD - - V Note 3 Enable Voltage Low - - - 0.3VDD V Note 3 Output Enable Delay Time - - - 5 ms Output Disable Delay Time - - - 200 ns RMS Phase Jitter PJ - 0.15 0.25 ps Integrated from 12KHz ~ 20MHz @150MHz , 3.3V , Note 4 Standby Current HCSL Electrical Characteristics Current Consumption Icc - - 30 mA RL=50Ω to VDD-2V Standby Current Icc(ST) - - 10 uA OE = Low Rise / Fall Time Tr / Tf - - 0.5 ns 20% ~ 80% Output Swing Enable Voltage High - 0.7VDD - - V Note 3 Enable Voltage Low - - - 0.3VDD V Note 3 Output Enable Delay Time - - - 5 ms Output Disable Delay Time - - - 200 ns RMS Phase Jitter PJ - 0.2 0.25 ps Integrated from 12KHz ~ 20MHz @100MHz , 3.3V , Note 4 CML Electrical Characteristics Current Consumption Icc - - 99 mA RL=50Ω to VDD-2V Icc(ST) - - 97 uA OE = Low Output Voltage High VoH VDD-0.085 VDD-0.01 VDD mV Output Voltage Low VoL VDD-0.6 VDD-0.4 150 mV Tr / Tf - - 0.5 ns 20% ~ 80% Output Swing Enable Voltage High - 0.7VDD - - V Note 3 Enable Voltage Low - - - 0.3VDD V Note 3 Output Enable Delay Time - - - 5 ms Output Disable Delay Time - - - 200 ns RMS Phase Jitter PJ - 0.2 0.25 ps Standby Current Rise / Fall Time @12KHz ~ 20MHz , Note 4 Note 1 : Inclusive of frequency tolerance at 25℃ , variation over temperature , supply voltage variation , 10 years aging and vibration. Note 2 : LVPECL can not support VDD 1.8V . Note 3 : Output will be enable if OE is Logic 1 or open ; Output will be disable if OE is Logic 0. Note 4 : Phase Jitter will be slightly different according to output frequency and supply voltage. Rev. A (2022.09.05) Page 2 of 7 www.txc.com.tw Think of Frequency, Think of TXC  Programing Differential Quartz Crystal Oscillator General Specification Test Diagram • LVPECL • LVDS • HCSL • CML Testing Circuit Note: 1. Above testing circuits cover all the specifications except temperature test & Jitter measurement. 2. All of the testing equipment are 50 Ohm terminal. 3. OE terminal is open connection except OE function test. 4. HCSL RS= 0 Ohm for test. 0 Ohm to 33 Ohm to minimize overshoot and ringback effect in application. Rev. A (2022.09.05) Page 3 of 7 www.txc.com.tw Think of Frequency, Think of TXC Programing Differential Quartz Crystal Oscillator General Specification  Waveform Conditions  Dimensions & Footprint(Recommended) • Size : 7.0x5.0 mm LVPECL- BC Series LVDS - BG Series HCSL - BX Series • Size : 5.0x3.2 mm LVPECL- CC Series LVDS - CG Series HCSL - CX Series Rev. A (2022.09.05) Page 4 of 7 www.txc.com.tw Think of Frequency, Think of TXC Programing Differential Quartz Crystal Oscillator General Specification Dimensions & Footprint(Continued)  • Size :3.2 x 2.5 mm LVPECLLVDS HCSL CML - • DC Series DG Series DH Series DL Series Size : 2.5x2.0 mm LVPECL- EC Series LVDS - EC Series HCSL - EC Series Rev. A (2022.09.05) Page 5 of 7 www.txc.com.tw Programing Differential Quartz Crystal Oscillator General Specification Think of Frequency, Think of TXC  Marking Date Code: MONTH JAN FEB YEAR MAR APR MAY JUN JUL AUG SEP OCT NOV DEC 2021 2025 2029 2033 2037 A B C D E F G H J K L M 2022 2026 2030 2034 2038 N P Q R S T U V W X Y Z 2023 2027 2031 2035 2039 a b c d e f g h j k l m 2024 2028 2032 2036 2040 n p q r s t u v w x y z *This date code will be cycled every four years Rev. A (2022.08.01) Page 6 of 7 www.txc.com.tw Think of Frequency, Think of TXC  Programing Differential Quartz Crystal Oscillator General Specification Table 2 . Revision History Rev. Revise Contents Release Date A Initial released 2022.09.05 Rev. A (2022.08.01) Page 7 of 7 www.txc.com.tw
DGC3300001 价格&库存
很抱歉,暂时无法提供与“DGC3300001”相匹配的价格&库存,您可以联系我们找货
