TXC CORPORATION
4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan.
TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207
www.txccorp.com
SPECIFICATION FOR APPROVAL
CN:
CUSTOMER
PRODUCT TYPE
SMD GLASS SEALING XTAL 5.0*3.2
NOMINAL FREQ.
25.000000MHz
TXC P/N
AA25000005
REVISION
S1
CUSTOMER P/N
PM / SALES
DATE
CUSTOMER SIGNATURE & Date
(1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance
of the attached specifications.
(2) Orders received and accepted by TXC after return of signed copy of specification will be produced per
these specifications.
(3) Any changes to these specifications must be agreed upon by both parties and new revision of the
Product Specification Sheet will be issued.
(4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets"
from customers will be regarded as the agreement on the contents of these specifications.
MSL:Level 1
RoHS Compliant
Pb used in sealing glass material is exempt from EU directive
FMT-DOC015
Issue Date: 03.18'14 VER.B
TXC CORPORATION
www.txccorp.com
PRODUCT SPECIFICATION SHEET
CN:
PRODUCT TYPE
NOMINAL FREQ.
25.000000MHz
TXC P/N
AA25000005
REVISION
S1
PE/RD
QA
MFG
Wen
yuan
Chang
PREPA
PR PREPAR
PRE
29-Sep-15
NOTE:
(1)The green product standard set by TXC is based upon the international standards. Related information is publicly
described on the TXC's Website, and updated regularly. The document is compliant with the latest green product quality
system directives at the time.
(2)Revision "Sx" is for engineering samples only. PE/RD's approval required.
(3)Revision "Ax" is production ready. PE, QA and MFG's approval required
MSL:Level 1
RoHS Compliant
FMT-DOC015
TXC CORPORATION
Rev
Revise page
S1
N/A
FMT-DOC015
TXC P/N:
Revise contents
Initial released
AA25000005
REVISION:
S1
PAGE:
1
Date
Ref.No.
Reviser
29-Sep-15
N/A
Xiaoyan Jiang
TXC CORPORATION
TXC P/N:
AA25000005
REVISION:
S1
PAGE:
Spec Sheet Contents
No.
Content
Page
1
ELECTRICAL SPECIFICATIONS
P.3
2
DIMENSIONS
P.4
3
MARKING
P.4
4
FACTORY LOCATION
P.4
5
SUGGESTED REFLOW PROFILE& MANUAL SOLDER CONDITION
P.4
6
STRUCTURE ILLUSTRATION
P.5
7
EMBOSS CARRIER TAPE & REEL
P.6
8
PACKING
P.7
9
RELIABILITY SPECIFICATIONS
FMT-DOC015
P.8~9
2
TXC CORPORATION
TXC P/N: AA25000005
REVISION:
S1
PAGE: 3
■ ELECTRICAL SPECIFICATIONS
Standard atmospheric conditions
Unless otherwise specified, the standard range of atmospheric conditions for making measurement
and tests are as follow:
Ambient temperature :
25±5℃
Relative humidity
40%~70%
If there is any doubt about the results, measurement shall be made within the following limits:
25±3℃
Relative humidity
40%~70%
Measure equipment
Electrical characteristics measured by S&A250B or equivalent.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode).
Unit Weight:
0.055±0.003 g/pcs
Parameters
1
Nominal Frequency
2
Oscillation Mode
3
Load Capacitance
4
5
SYM.
Electrical Spec.
MIN
TYP
FL
25.000000
MAX
Notes
UNITS
MHz
Fundamental
CL
12
pF
Frequency Tolerance
±30
ppm
at 25 ℃ ± 3 ℃
Frequency Stability
ppm
Over Operating Temp. Range (Reference 25℃)
6
Operating Temperature
7
Aging
8
Drive Level
9
Effective Resistance Rr
DL
±30
-40
85
±5
100
1st Year
uW
50
Ω
10 Shunt Capacitance C0
C0
5
pF
11 Insulation Resistance
500
MΩ
12 Storage Temperature Range
-40
125
FMT-DOC015
Rr
ppm
50
at DC 100V
TXC CORPORATION
■ DIMENSIONS
(Unit:mm)
TXC P/N:
AA25000005
REVISION:
S1
PAGE:
Connection
2.6±0.15
0.5 Ref.
1.25±0.15
3.2 ± 0.15
5.0 ± 0.15
Suggested Layout
2.0
1.7
2.4
2.2±0.1
1.7
0.1 Ref.
*Coplanarity of solderable areas Camber 0.10 mm Max
■ MARKING
TXC
Frequency Code
TXC Logo
Ex.: 25.000000
MHz=
25.0
Tracking Code
Production Location:China(Ningbo)
■ SUGGESTED REFLOW PROFILE
Solder melting point :220 ± 10 ℃ , 60 sec. Min
Peak Temperature: 260 ± 5 ℃ , 10 sec. Max.
10 sec
260
220
180
150
Time (sec)
120 sec
60 sec
■ SUGGESTED MANUAL SOLDER CONDITION
Temperature: 350 ± 10 ℃
Time: 3 sec.
Re-solder times: twice
FMT-DOC015
4
TXC CORPORATION
TXC P/N:
AA25000005
REVISION:
S1
PAGE:
■ STRUCTURE ILLUSTRATION
COMPONENTS
NO
MATERIALS
FINISH/SPECIFICATIONS
1
Cap
Ceramic (AI2O3)
2
Base(Package)
Ceramic (AI2O3)
3
PAD
Au
Tungsten metalize
+ Ni plating
+ Au plating
4
Crystal blank
SiO2
5
Conductive adhesive
Resin+Ag
6
Electrode
Noble Metal
7
Sealing Glass
Glass(PbO)
FMT-DOC015
5
TXC CORPORATION
AA25000005
TXC P/N:
S1
REVISION:
PAGE: 6
■ EMBOSS CARRIER TAPE & REEL
F
E
B
H
G
A
DIMENSIONS
1.65±0.10
B
Feeding
D
C
A
C
D
E
F
G
H
5.40±0.10 3.50±0.10 8.00±0.10 12.00±0.30 4.00±0.10 1.55±0.10 1.75±0.10 (UNIT:mm)
REMARK :
Products put in 3000pcs
Trailer
160mm(Min)
Empty Sealed
Leader
160mm(Min)
230mm(Min)
User direction of feed
W
W1
2.0
L1
DIMENSIONS
FMT-DOC015
L
L1
W
W1
180±1.00
13±0.50
16.5±0.20
12±0.10
L
(UNIT:mm)
TXC CORPORATION
TXC P/N:
AA25000005
REVISION:
S1
PAGE:
■ PACKING
Reel Quantity :
1. Reel X 5 (5 Reels x1 )
2. Reel X 10 (10 Reels x1 )
3. Reel X 20 (10 Reels x2 )
4. Reel X 40 (10 Reels x4 )
Label B
Box Size:
1. L200 X W200 X H140mm
2. L200 X W200 X H250mm
3. L400 X W200 X H250mm
4. L400 X W400 X H280mm
Tape
Tape
Label A
Label B
QA Pass
(Label A) Size:100 X 100mm
(Label B) Size:80 X 40mm
[STORAGE]
1.Don't be caught in the rain.
2.The storage environment shall be 5℃ ~40℃ temperature and 30% ~ 75%RH humidity and free from the sun shine.
3.If customers have special requirements, we can paste labels according to it.
FMT-DOC015
7
TXC CORPORATION
TXC P/N:
AA25000005
REVISION:
S1
PAGE:
■ RELIABILITY SPECIFICATIONS (AEC-Q200 Compliant)
1.Mechanical Endurance
No.
1.1
1.2
Test Item
Mechanical Shock
Vibration
Test Methods
Test Criteria
2000 G , 0.3 m Sec. ,3 times for all 3 directions.
BC
Frequency range
10 ~ 2000 Hz
Acceleration
20G
Amplitude
1.52mm
Sweep time
20 minute
Pendicular axes each test time
4 hours
BC
(Total test time 12 hours)
1.3
Terminal Strength
17.7N force for 60sec +/-1sec.
1.4
Board Flex
Duration time:60 Sec Minimum,Deviation:3mm
1.5
Solderability
F
BC
Temperature
245 oC +/- 5oC
Immersing depth
0.5 mm minimum
Immersion time
5 +/- 0.5 seconds
Flux
Rosin resin methyl alcohol
E
solvent ( 1 : 4 )
2.Environmental Endurance
No.
Test Item
Test Methods
SPEC
o
2.1
Resistance To
Soldering Heat
Test temperature
260 +/- 5 C
Test time
10 +/- 1 sec.
2.2
High Temp. Storage
+ 85℃ ± 3 ℃ for 1000 ± 12 Hrs
BCD
2.3
Low Temp. Storage
- 40 ℃ ± 3 ℃ for 1000 ± 12 Hrs
BCD
BCD
-40℃~85℃,for 1000 cycles.
B C D
1 cycle
105+/-3℃
2.4
Temperature cycle
25 ℃
-40+/-3 ℃
BCD
15 min.
15 min.
2min Max.
2.5
Operational Life
2.6
High Temp&Humidity 85℃ ± 3℃ , RH 85% , 1000 Hrs
FMT-DOC015
1000 hrs @ 85± 3°C. Rated VDD applied with 1 MΩ.
BCD
BCD
8
TXC CORPORATION
TXC P/N: AA25000005
REVISION:
S1
PAGE: 9
Specifications
A
Frequency change: Within ±5ppm or in customer's specification.
B
Frequency change: Within ±10ppm or in customer's specification.
C
Equivalent series resistance(E.S.R) change: Within ±15% or 10Ω(larger value).
D
After conditioning , quartz crystal units shall be subjected to standard atmospheric conditions for 24 hour, and
measured.
E
Minimum 95% of immersed terminal shall be covered with new uniform solder.
F
No damage on specimen
Measurement condition
FMT-DOC015
很抱歉,暂时无法提供与“AA25000005”相匹配的价格&库存,您可以联系我们找货
