320123
    BOSTIK
    Adhesive, Hard & Fast, Epoxy - 2 Part, Grey, Stick
320123 数据手册
PRODUCT DATA Date: 17 December 2005 Information Sheet No.: ZE0146 EVO-STIK HARD & FAST TWO PART EPOXY RESIN ADHESIVE STICK. Evo-Stik Hard & Fast is an easily worked, cold setting two-part epoxy resin putty. On curing, the putty provides a tough, durable grey coloured material which is dimensionally stable, resistant to chemical attack and can be painted. The usable life of the mixed putty is up to 3 minutes at 25°C. USES Evo-Stik Hard & Fast will form a strong bond with most structural materials such as metal, glass, most plastics, wood, dry concrete etc. LIMITATIONS ♦ It is not intended for repairing or making items that are used for storing food or drink. ♦ Not suitable for bonding oven doors or car mirrors. ♦ Do not use on polyolefins (e.g. polythene or polypropylene). BONDING INSTRUCTIONS 1. Always open and use adhesive products over a protected surface, and avoid contact with clothing. Preferably wear gloves to avoid contact with the skin. 2. Make sure surfaces are dry, clean and free from dust, corrosion, dirt and grease. For even better bonding slightly roughen surfaces with sandpaper. 3. Following the instructions on the back of the blister card. Twist or cut off the required amount of putty. 4. To mix, knead with fingers (gloves recommended) until the material is uniform in colour and streak free. If mixing is difficult, warm to room temperature. 5. Apply to a clean, dry surface, firmly working into any gaps. 6. For a smooth appearance hand rub with water or a damp cloth prior to the material hardening. A simple method to produce a smooth gloss finish is to press polythene sheet onto the tacky surface. Allow the putty to cure and then peel off the sheet. 7. After 5 – 10* minutes the putty will harden like metal and start to form a strong repair. After 30 – 60 minutes the putty is cured and can be drilled or sanded. We recommend eye and respiratory protection if the material is being ground, drilled or sanded. CLEANING ♦ Uncured resin/hardener mixtures can be cleaned from tools using cellulose thinners, acetone or Evo-Stik Adhesive Cleaner. ♦ Please note that solvents may attack some rubbers, plastics, painted surfaces, fabrics, etc. ♦ Bear this in mind if intending to use solvent to remove excess adhesive, and carry out a preliminary test first. ♦ Cured adhesive residues can usually be dissolved from tools by soaking in commercial paint stripper. Refer to the paint stripper manufacturer’s instructions for use and safe handling. ♦ The adhesive may be removed from the skin using a suitable proprietary hand cleaner. ♦ Do not use solvents in contact with the skin. *Exact setting times depend on temperature, quantity mixed and the temperature of the materials being bonded. Bostik Limited, Common Road, Stafford, England. Tel: +44 (0)1785 272727 Fax: +44 (0)1785 272867 BOSTIK, EVO-STIK, CEMENTONE, VALLANCE & IDENDEN ARE REGISTERED TRADEMARKS OF BOSTIK LIMITED. www.Bostik.co.uk Page 1 of 2 PRODUCT DATA Date: 17 December 2005 Information Sheet No.: ZE0146 SHELF LIFE: . STORAGE: Two years when stored in the original unopened containers COLOUR: Grey (When mixed) PACKAGING Code: 320123 HEALTH AND SAFETY Available separately in file named as the packaging code above. Store under dry conditions between 5OC and 25OC. Blister Pack x6 TYPICAL ADHESIVE CHARACTERISTICS RESIN HARDENER Physical form: Extruded Stick Extruded Stick Chemical type: Epoxy Resin Formulated Polyamine Solids content: 100% 100% Colour: Grey Black/Grey Density (SG): Set time (pot life): Colour: 2.0 (When mixed) About 3 minutes @ 25OC Grey (When mixed) TYPICAL PERFORMANCE CHARACTERISTICS Temperature: Water: Oil & Petrol: Chemicals: Sandability: Paintability: -40OC to +120OC depending on conditions of use Good resistance. Good resistance. Good resistance. Sandable when set. Please wear dust mask. Good. Sales & Technical contacts at Bostik Sales Technical advice Technical Data & COSHH (MSDS) sheets Telephone 01785 272700 01785 272727 01785 272827 Facsimile 01785 241818 01785 272867 01785 212962 Email addresses customer.service@bostik.com technical.service@bostik.com gatehouse@bostik.com This Product Data Sheet covers just one of a large range of products supplied by Bostik Limited. Full information on these products and advice on application is freely available from our fully trained staff throughout the country. In addition, specialist technical advice is available from our Technical Services Department. This Product Data Sheet supersedes all previous technical information on this product, and users of it are cautioned to ensure that it is the current issue. Destroy all previous Product Data Sheets, and if any doubt, contact Bostik Limited, quoting the code number in the top right hand corner on the front of this document. This leaflet is for general guidance only and may contain inappropriate information under particular conditions of use. The company cannot accept any responsibility for loss or damage that may result from the use of this information, due to the possibility of variations of processing or working conditions and of workmanship outside our control. Users are advised to confirm the suitability of this product by their own tests. Bostik Limited, Common Road, Stafford, England. Tel: +44 (0)1785 272727 Fax: +44 (0)1785 272867 BOSTIK, EVO-STIK, CEMENTONE, VALLANCE & IDENDEN ARE REGISTERED TRADEMARKS OF BOSTIK LIMITED. www.Bostik.co.uk Page 2 of 2
320123 价格&库存
很抱歉,暂时无法提供与“320123”相匹配的价格&库存,您可以联系我们找货
