A0224070
A0224070
    OKW
A0224070 数据手册
EURO CASES H W D EURO CASES EVERYTHING SNAPS INTO PLACE THE PRODUCT YOUR ADVANTAGE The EURO CASE is extremely assemblyfriendly. The case shells, side panels and snap-in panels all have a strong clip together mechanism, without a single screw. It is possible to customise the EURO CASE to your own corporate appearance by selecting the side panels and snap-in panels in your company's colours. Minimum amount of assembly required thanks to the special OKW snap-lock mechanism. APPLICATIONS Peripheral equipment for computers. Feedback control. Medical devices. Injection-moulded reinforcing ribs ensure that these conveniently light cases have a high degree of torsional resistance and rigidity. Variable case heights for individual installation configuration – depending on space requirements. Any problems in ventilation are solved by snap-in panels with ventilation slots. VARIABLE CASE HEIGHTS 42 TE / 63 TE 84 TE 1 HE 1.5 HE 2 HE 2.5 HE 3 HE MAX. SIZE OF PCB PROTECTION CLASS < IP 40 STANDARD COLOURS Off-white, RAL 9002 (complete cases). Pebble grey, RAL 7032 (side panels, handle bar and tilt foot optionally). www.okw.com EURO W x D in mm CASES case shell 42 TE 243 x 220 63 TE 350 x 220 84 TE 454 x 220 Detailed drawings see our website. 60 Subject to technical modification without notice. Typographical and other errors do not justify any claim for damages. Stand: 01/04 e Copyright © 2004 OKW Gehäusesysteme GmbH, Buchen/Germany 4 HE 6 HE EURO CASES COMPLETE ENCLOSURES* 1 Heightunit Version ventilation*2 Material Colour Part-No. EURO CASE 42 TE width = 260 mm, depth = 250 mm height without handle 1 HE ABS, off-white ABS, off-white ABS, off-white ABS, off-white ABS, off-white ABS, off-white ABS, off-white ABS, off-white ABS, off-white ABS, off-white ABS, off-white ABS, off-white ABS, off-white ABS, off-white ABS, off-white 2 HE 3 HE 4 HE 6 HE 54 54 54 98.5 98.5 98.5 143 143 143 A 02 14 070 A 02 14 170 A 02 14 270 A 02 24 070 A 02 24 170 A 02 24 270 A 02 34 070 A 02 34 170 A 02 34 270 with handle – – – A 02 24 470 A 02 24 570 A 02 24 670 A 02 34 470 A 02 34 570 A 02 34 670 Part-No. EURO CASE 63 TE width = 367 mm, depth = 250 mm height without handle with handle 54 54 54 98.5 98.5 98.5 143 143 143 A 02 16 070 A 02 16 170 A 02 16 270 A 02 26 070 A 02 26 170 A 02 26 270 A 02 36 070 A 02 36 170 A 02 36 270 – – – A 02 26 470 A 02 26 570 A 02 26 670 A 02 36 470 A 02 36 570 A 02 36 670 276.5 276.5 276.5 A 02 66 070 A 02 66 170 A 02 66 270 – – – Part-No. EURO CASE 84 TE width = 473,5 mm, depth = 250 mm height without handle 100 100 100 144.5 144.5 144.5 189 189 189 278 278 278 A 02 28 070 A 02 28 170 A 02 28 270 A 02 38 070 A 02 38 170 A 02 38 270 A 02 48 070 A 02 48 170 A 02 48 270 A 02 68 070 A 02 68 170 A 02 68 270 with handle – – – A 02 38 470 A 02 38 570 A 02 38 670 A 02 48 470 A 02 48 570 A 02 48 670 – – – Article supply each 1 pc  Case shell, ABS  Side panel 0,5 HE, ABS  Side panel 1 HE, ABS  Side panel 2 HE, ABS  Side panel 0,5 HE for handle mounting, ABS  Side panel 1 HE for handle mounting, ABS  Side panel 2 HE for handle mounting, ABS  Snap-in panel without slots, ABS  Snap-in panel with slots, ABS  Snap-in panel without slots, with feet, ABS  Snap-in panel with slots, with feet, ABS Handle bar*3, off-white, push-button off-white Handle bar*3, pebble grey, push-button off-white Handle bar*3, off-white, push-button pebble grey Tilt foot, ABS, off-white, snaps into the feet section Part-No. 42 TE off-white 42 TE pebble grey Part-No. 63 TE off-white 63 TE pebble grey Part-No. 84 TE off-white 84 TE pebble grey A 01 14 170 – A 01 05 270 A 01 05 280 A 01 10 270 A 01 10 280 A 01 20 270 A 01 20 280 A 01 06 270 A 01 06 280 A 01 11 270 A 01 11 280 A 01 21 270 A 01 21 280 A 01 14 370 – A 01 24 370 – A 01 34 370 – A 01 44 370 – A 03 44 217 A 03 44 218 A 03 44 216 A 03 50 007 A 01 16 170 – A 01 05 270 A 01 05 280 A 01 10 270 A 01 10 280 A 01 20 270 A 01 20 280 A 01 06 270 A 01 06 280 A 01 11 270 A 01 11 280 A 01 21 270 A 01 21 280 A 01 16 370 – A 01 26 370 – A 01 36 370 – A 01 46 370 – A 03 46 317 A 03 46 318 A 03 46 316 A 03 50 007 A 01 28 170 – A 01 05 270 A 01 05 280 A 01 10 270 A 01 10 280 A 01 20 270 A 01 20 280 A 01 06 270 A 01 06 280 A 01 11 270 A 01 11 280 A 01 21 270 A 01 21 280 A 01 18 370 – A 01 28 370 – A 01 38 370 – A 01 48 370 – A 03 48 417 A 03 48 418 A 03 48 416 A 03 50 007 Part-No. for EURO CASE 63 TE Part-No. for EURO-CASE 84 TE ACCESSORIES Article Part-No. for EURO CASE 42 TE supply each 1 pc Front / rear panel, matt anodized Al, R6 Front / rear panel, matt anodized Al, R6 Front / rear panel, matt anodized Al, R6 Front / rear panel, matt anodized Al, R6 Front / rear panel, matt anodized Al, R6 Front / rear panel, matt anodized Al, R6 1 HE 1.5 HE 2 HE 3 HE 4 HE 6 HE To achieve one EURO-CASE from separate parts, for a special combination, please order: 2 case shells 4 snap-in panels 2 side panels (if needed) 1 handle bar (if needed) 2 tilt feet (if needed) 2 front /rear panels (if needed) universal accessories see pages 82-87 250.8 x 46.3 x 2 250.8 x 68.5 x 2 250.8 x 90.7 x 2 250.8 x 135.2 x 2 – –     A 03 14 270 A 03 54 270 A 03 24 270 A 03 34 270 – – Explanation of the parts see order data of the separate parts in the table. 357.8 x 46.3 x 2 – 357.8 x 90.7 x 2 357.8 x 135.2 x 2 – 357.8 x 268.6 x 2 A 03 16 370 – A 03 26 370 A 03 36 370 – A 03 66 370 – – 464.3 x 90.5 x 2 464.3 x 135 x 2 464.3 x 179.3 x 2 464.3 x 268.1 x 2 – – A 03 28 470 A 03 38 470 A 03 48 470 A 03 68 470 *1 front / rear panel and tilt feet must be ordered separtely *2 ventilation provided with each enclosure (snap-in panel at the base additionally with foot): version without ventilation slots version with ventilation slots at rear, top and base  version with ventilation slots at front, rear top and base  * the adjustment mechanism allows increments of 30°; load capacity see Info-Box page 87, illustration no. . 3 61 Service-Centre see pages 88-91 EURO CASES SEPARATE PARTS (FOR INDIVIDUAL COMBINATIONS)
A0224070 价格&库存
很抱歉,暂时无法提供与“A0224070”相匹配的价格&库存,您可以联系我们找货
