B5011207
B5011207
    OKW
B5011207 数据手册
GEOMETRIC PERFECTION the product The ART-CASE series of cases with the basic shapes “round”, “square”, “oval” and “rectangular” sets new standards in design and function. Different versions of the bottom and top parts as well as of the base create interesting combinations and geometrical arrangements – for first-class visual pleasure! art-case your advantage Ergonomically shaped case design, ideal for wall mounting and desktop applications. Bayonet locking technology in ART-CASE R110 F/H – rational and invisible from the outside. If required, it can be additionally secured using the enclosed screws – in this case the markings on the top and bottom parts must match, on account of the alignment of the screw domes. Case assembly for ART-CASE types S, O and E with snap-in locking and screw fixture. Flat top part with recessed operating area for the protection of the membrane keyboard. Available with or without battery operation. Battery compartment for 2 x AAA batteries or base with integrated supports for 2 x AA in the base c. 3 different bases. Practical for wall and desktop applications. applications Ideal for indoor electrical and electronic applications, e.g. for transmission and reception units in building services management systems and building installations. art-case Also in medical technology, computer peripherals, security technology etc. protection class IP 40 Off-white, RAL 9002 Black, RAL 9005 max. size of pcb H W L ARTCASE R110 F/H S110 F O160 F/H E160 F L x W in mm bottom parts “flush” “desk” ø 86 ø 86 – – – – – – top parts ø 82 / 58 x 58 94 x 78 107 x 64 144 x 78 (cutouts for pillars not taken into consideration) www.okw.com 80 Subject to technical modification without notice. Typographical and other errors do not justify any claim for damages. Stand: 11/09 e Copyright © 2009 OKW Gehäusesysteme detailed drawings see our website A R T- ca s e DESIGN SELECTION R110 F H S110 F O160 “level” R110 F F H O160 “inclined” H E160 F “level” F H “inclined” Outside dim. in mm ART-CASE R110 S110 O160 E160 Equipment L W bottom part 110 110 110 160 160 160 110 110 110 110 110 110 Material height “level” “inclined” “inclined” “level” “inclined” “inclined” ABS (UL 94 HB) ABS (UL 94 HB) ABS (UL 94 HB) ABS (UL 94 HB) ABS (UL 94 HB) ABS (UL 94 HB) 30 38 38 30 38 38 End piece required for bottom part! (article a - e depending on the application) article version/application a Lid bB  attery compartment lid c Base d Base 30° e Base 55° suitable for all bottom parts, screw-down (not suitable for use with battery compartment), ABS (UL 94 HB) suitable for all bottom parts, screw-down (battery compartment 2 x AAA and set of battery clips as accessories), ABS (UL 94 HB) suitable for all bottom parts, spacer for ceiling/wall mounting, with contact supports for 2 x AA, ABS (UL 94 HB) suitable for bottom parts “inclined”, for user-friendly installation and assembly angles, ABS (UL 94 HB) suitable for bottom parts “inclined”, for user-friendly installation and assembly angles, ABS (UL 94 HB) Part-No. F*1 off-white B 50 10 007 B 50 10 207 B 50 12 207 B 50 15 007 B 50 15 207 B 50 17 207 black height B 50 10 009 B 50 10 209 B 50 12 209 B 50 15 009 B 50 15 209 B 50 17 209 38 41 38 41 Part-No. H off-white B 50 10 107 B 50 10 307 – B 50 15 107 B 50 15 307 – black B 50 10 109 B 50 10 309 – B 50 15 109 B 50 15 309 – Part-No. off-white Part-No. black B 50 11 847 B 50 11 849 B 50 11 857 B 50 11 859 B 50 11 117 B 50 11 119 B 50 11 217 B 50 11 219 B 50 11 317 B 50 11 319 art-case ENCLOSURES ACCESSORIES For enclosure ART-CASE f Battery compartment g Set of battery clips h Battery contact i Battery holder j Strain relief k Wall mounting set l Anti-rotation device m Anti-slide feet n Set of screws bottom part “level”/ “inclined” battery comp. f base c battery comp. f battery comp. f base c lid / all bases all bases all all a b c i j k Version / Application ABS, off-white, for 2 x 1.5 V (AAA), incl. assembly kit, battery compartment lid (b) or base (c), base 30° (d) resp. base 55° (e) necessary tin-plated, for 2 x 1.5 V micro cells (AAA) tin-plated, for 2 x 1.5 V mignon cells (AA) tin-plated, for a serial connection of the micro cells (AAA) clamps down securely 2 x AA (for enclosures with base 30°/55° necessary) 1 strain relief, 2 screws for the safe and secure wall mounting (machining lid/bases necessary) to prevent the base from being removed, ABS, off-white, incl. screws transparent, self-adhesive, ø 6.5 x 2 mm, for desk applications, 1 pair 4 x ø 2.5 x 5 mm, for mounting PCBs d e f g l m n *1 max. dim. keypad ART-CASE R110 F: ø 72,00 mm · ART-CASE O160 F: 121,80 x 71,80 mm (max. dim. keypad of ART-CASE S110 F and E160 F see our website) universal accessories see pages 102-109 81 Part-No. B 51 11 107 A 91 66 001 A 91 90 002 A 91 66 002 A 91 66 003 A 91 99 005 B 51 11 307 B 51 11 707 A 92 07 150 B 51 11 201 h ART-CASE with integrated Euro plug see page 82 ▸ NeW PRODUCT Customising Services see pages 110-117 art-case Article A R T- C A S E WITH INTEGRATED EURO PLUG R110 S110 F H F “level” R110 F H “inclined” ENCLOSURE SET art-case Part-No. F*1 off-white black B 50 11 027 B 50 11 227 B 50 13 227 B 50 11 029 B 50 11 229 B 50 13 229 height 30 38 38 Part-No. H off-white black B 50 11 127 B 50 11 327 – B 50 11 129 B 50 11 329 – ART-CASE height 38 41 R110 S110 Outside dim. in mm L W bottom part plug-in module 110 110 110 With integrated Euro plug in accordance with DIN VDE 0620 part 101 110 110 110 Equipment “level” “inclined” “inclined” Material ABS (UL 94 HB), live parts in ABS/PC (UL 94 V-0) ACCESSORIES Part-No. B 51 11 201 Article a Set of screws For enclosure ART-CASE Version / Application all 4 x ø 2.5 x 5 mm, for mounting PCBs art-case a New product www.okw.com *1 max. dim. keypad ART-CASE R110 F: ø 72 mm (ART-CASE S110 F see our website) 82 detailed drawings see our website
B5011207 价格&库存
很抱歉,暂时无法提供与“B5011207”相匹配的价格&库存,您可以联系我们找货
