A9066117F
A9066117F
    OKW
A9066117F 数据手册
good to hold the product SMART-CASE The idea of giving greater expression to ergo­ nomic requirements was the starting point of the development of the SMART-CASE. And so the design follows the touch sensation of the human being, thus facilitating natural sequences of hand movements. Benefit from the outstanding balance between design and technical sophistication. your advantage Convincing ergonomics; unique design. Ideal for remote controls, with cables or with battery compartment. Cable glands for sizes M, L and XL for cables ø 3.4 - 5.9 mm. Cable gland already included (TPE, standard colour volcano, NCS S 5502-G). Optionally in material permeable to infra-red signals from stock. For utmost efficiency the front face is polished. Recessed operating area to protect the membrane keyboard (M/L/XL). Fastening pillars and fixing supports for PCBs and components. Applications Remote controls of all types, wireless or with cable connection. Off-white, RAL 9002 Black, RAL 9005 XS Especially suitable for use in hospitals and social fields as well as in industry and households. M protection class IP 65 With sealing (accessories) sizes L and XL versions without battery compartment. max. size of pcb L/XL W H L W2 SMARTCASE XS M L XL L x W/W2 in mm base part 46 x 29/18 58 x 38/30 88 x 50/42 127 x 60/50 top part – 63 x 40/31 117 x 51/37 78 x 60/56 + 50 x 55/47 (cutouts of pillars and battery compartment not taken into consideration) www.okw.com 14 Subject to technical modification without notice. Typographical and other errors do not justify any claim for damages. Stand: 11/09 e Copyright © 2009 OKW Gehäusesysteme detailed drawings see our website S M A R T- C A S E SMARTCASE Outside dim. in mm L W H Version / Equipment (dim. in mm) battery comp. cable gland ø max. dim. keypad XS M 58 96 96 96 96 96 140 140 140 140 140 168 168 168 168 168 – I II III IV V I II III IV V I II III IV V – 2 x AAA 2 x AAA – – – 2 x AA / 1 x 9 V – – – – 2 x AA / 1 x 9 V – – – – L XL 35,6 47 47 47 47 47 62.7 62.7 62.7 62.7 62.7 74.4 74.4 74.4 74.4 74.4 19 24 24 24 24 24 30.5 30.5 30.5 30.5 30.5 35.4 35.4 35.4 35.4 35.4 – – – approx. 5.0 - 5.9 approx. 4.2 - 5.0 approx. 3.4 - 4.2 – – approx. 5.0 - 5.9 approx. 4.2 - 5.0 approx. 3.4 - 4.2 – – approx. 5.0 - 5.9 approx. 4.2 - 5.0 approx. 3.4 - 4.2 Part-No. ABS (UL 94 HB) PMMA (plexiglass®) black black*1 ABS (UL 94 HB) off-white A 90 64 107 A 90 66 107 A 90 66 117 A 90 66 127 A 90 66 137 A 90 66 147 A 90 67 107 A 90 67 117 A 90 67 127 A 90 67 137 A 90 67 147 A 90 68 107 A 90 68 117 A 90 68 127 A 90 68 137 A 90 68 147 without recessed area without recessed area 74.60 x 39.85 74.60 x 39.85 74.60 x 39.85 74.60 x 39.85 103.95 x 50.95 103.95 x 50.95 103.95 x 50.95 103.95 x 50.95 103.95 x 50.95 110.60 x 61.05 110.60 x 61.05 110.60 x 61.05 110.60 x 61.05 110.60 x 61.05 A 90 64 109 A 90 66 109 A 90 66 119 A 90 66 129 A 90 66 139 A 90 66 149 A 90 67 109 A 90 67 119 A 90 67 129 A 90 67 139 A 90 67 149 A 90 68 109 A 90 68 119 A 90 68 129 A 90 68 139 A 90 68 149 A 90 64 209 A 90 66 209 A 90 66 219 – – – A 90 67 209 A 90 67 219 – – – A 90 68 209 A 90 68 219 – – – accessories Article a Set of battery clips b Battery contact c Battery holder d Plug-in contact e Sealing f Set of strain relief g Key ring For enclosure SMART-CASE Version / Application Part-No. M L, XL M M L, XL L XL M, L, XL & station XS tin-plated, for 2 x 1.5 V micro cells (AAA) tin-plated, for 2 x 1.5 V mignon cells (AA) tin-plated, for a serial connection when using the set of batt. clips clamps down securely 2 x AAA for one 9 V flat battery (PP3) for versions II-V, for a higher protection class (IP 65) for versions II-V, for a higher protection class (IP 65) for strain relief of cable connected applications nickel-plated, ø 20.5 mm A 91 66 001 A 91 90 002 A 91 66 002 A 91 66 003 A 91 60 003 A 91 67 002 A 91 68 002 A 91 66 004 A 91 64 001 M, L, XL M, L, XL M L XL holder M holder L holder XL M L XL M, L, XL M, L, XL PA 6, 2 mounting holes ø 4.2 mm necessary up to ø 32 mm, ABS, mounting holes ø 4.2 mm necessary ABS, also suitable for cable connected applications ABS, also suitable for cable connected applications ABS, also suitable for cable connected applications double-sided adhesive foil with foam carrier double-sided adhesive foil with foam carrier double-sided adhesive foil with foam carrier ABS, desk case application (available from December 2009) ABS, desk case application (available from December 2009) ABS, desk case application (available from January 2010) contact pin, female for the case, gold-plated, < 15 A, 1-pole spring contact, male for the station, gold-plated, < 15 A, 1-pole h Belt / pocket clip i Holding clamp j Holder k Adhesive foil for holder l Station mC  ontacts (bore holes necessary)  b c d i j k l e f off-white black A 91 67 017 A 91 67 019 A 91 67 027 A 91 67 029 A 91 66 307 A 91 66 309 A 91 67 307 A 91 67 309 A 91 68 307 A 91 68 309 A 91 66 005 A 91 67 005 A 91 68 005 A 91 66 037 A 91 66 039 A 91 67 037 A 91 67 039 A 91 68 037 A 91 68 039 A 91 93 030 A 91 93 031 g h m for ring eyelet see page 104 *1 sizes M, L & XL only the bottom parts made of PMMA, top part is made of ABS (UL 94 HB); cases made of PMMA (plexiglass®) not comparable to cases made of ABS in terms of mechanical load-bearing capacity universal accessories see pages 102-109 15 NEW PRODUCT Customising Services see pages 110-117 SMART-CASE enclosures
A9066117F 价格&库存
很抱歉,暂时无法提供与“A9066117F”相匹配的价格&库存,您可以联系我们找货
