A0612107
A0612107
    OKW
A0612107 数据手册
58 comtec Order data on page 150 pleasant to use the product your advantage Modern, attractive, flat styling characterises the COMTEC family of cases. This makes desktop units easy to operate, and applications on the wall – then rotated by 180° – can be optimally mounted for the user. Ergonomic design. A real asset when operating and reading. The new “Softline” design gives the cases a high-quality appearance for housing equipment that needs to look good. Flat or raised bottom part for largevolume components. Large area for interfaces at the top. Ideal for D-sub-plug connectors, round connectors etc. Protection class IP 40 Max. size of PCB (D x W in mm) 120 F 120 H 150 F/H 200 F/H 290 H bottom part version I 94 x 123 94 x 128 124 x 175 174 x 123 264 x 167 top part 105 x 137 105 x 137 130 x 187 185 x 137 270 x 187 H W D detailed drawings see our website www.okw.com Subject to technical modification without notice. Typographical and other errors do not justify any claim for damages. Stand: 10/12e Copyright © 2012 OKW Gehäusesysteme comtec 59 Order data on page 150 table top or wall mounted Advantages for wall mounted applications your advantage The ergonomically inclined front panel allows the case to be mounted within the operator’s reach. Displays and readouts are easily legible for all users involved – be it the mechanical engineer, the operator etc. Version I with closed bottom part. In version II the battery compartment can be fitted in the bottom parts (150 F/H, 200 F/H). Lid of battery compartment snapped-on. Wall suspension element for rational wall mounting (accessory). Recessed operating area for the ­protection of the membrane keyboard. Self-adhesive case feet ensure ­reliable desk-top positioning. applications Systems for data collection on the job and machines. Communications equipment. Access and security controls and data systems engineering. Medical field and laboratory technologies. Measuring and controlling. Industrial regulation. Subject to technical modification without notice. Typographical and other errors do not justify any claim for damages. Stand: 10/12e Copyright © 2012 OKW Gehäusesysteme 150 comtec Information on pages 58-59 COMTEC COMTEC 120 F 120 H 150 F 150 H 200 F 200 H 290 H Outside dim. in mm W D H Version / Equipment (dim. in mm) battery compartment max. dim. keypad Material 120 150 120 150 150 200 150 200 150 200 150 200 200 150 200 150 200 150 200 150 290 200 I I I II I II I II I II I ABS (UL 94 HB) ABS (UL 94 HB) ABS (UL 94 HB) ABS (UL 94 HB) ABS (UL 94 HB) ABS (UL 94 HB) ABS (UL 94 HB) ABS (UL 94 HB) ABS (UL 94 HB) ABS (UL 94 HB) ABS (UL 94 HB) 20/42.8 40/62.8 20/51.5 20/51.5 40/71.5 40/71.5 20/42.8 20/42.8 40/62.8 40/62.8 44/75.5 – – – • (see accessory) – • (see accessory) – • (see accessory) – • (see accessory) – 87.85 x 109.85 87.85 x 109.85 117.85 x 159.80 117.85 x 159.80 117.85 x 159.80 117.85 x 159.80 167.75 x 109.85 167.75 x 109.85 167.75 x 109.85 167.75 x 109.85 257.85 x 159.80 Part-No. off-white black RAL 9002 RAL 9005 A 06 12 007 A 06 12 107 A 06 15 007 A 06 15 017 A 06 15 107 A 06 15 117 A 06 20 007 A 06 20 017 A 06 20 107 A 06 20 117 A 06 29 107 A 06 12 009 A 06 12 109 A 06 15 009 A 06 15 019 A 06 15 109 A 06 15 119 A 06 20 009 A 06 20 019 A 06 20 109 A 06 20 119 A 06 29 109 COMTEC accessories Article For COMTEC Version / Application ① Battery cradle kit b Battery cradle 150 F/H, 200 F/H 150 F/H, 200 F/H 150 F/H, 200 F/H 150 F/H, 200 F/H 150 F/H, 200 F/H 150 F/H, 200 F/H all sizes ABS, off-white, for 4 x 1.5 V mignon cells (AA), battery clips nickel-plated* ABS, off-white, for 1 x 9 V flat battery (PP3) ABS, off-white, for 2 x 9 V flat battery (PP3) tin-plated, for 1 x 9 V flat battery (PP3) tin-plated, for 2 x 9 V flat battery (PP3) for 1 x 9 V flat battery (PP3) 4 x ø 2.5 x 6 mm, for mounting PCBs c Set of battery clips d Plug-in contact e Set of screws ① b Part-No. 1 c d A 93 45 217 A 91 74 003 A 91 74 002 A 91 74 006 A 91 61 002 A 91 60 003 A 91 99 008 e universal accessories on pages 178-187 *1 complies with DIN EN 60601 (short circuit caused by incorrect insertion of batteries impossible) Subject to technical modification without notice. Typographical and other errors do not justify any claim for damages. Stand: 10/12e Copyright © 2012 OKW Gehäusesysteme
A0612107 价格&库存
很抱歉,暂时无法提供与“A0612107”相匹配的价格&库存,您可以联系我们找货
