A9093107
A9093107
    OKW
A9093107 数据手册
GUIDES THE DIALOGUE THE PRODUCT You can hardly present your communication and network components in a more attractive way. The new DIATEC is an attractive eye-catcher in your direct living and working environment. But this innovative range of cases also offers many functional benefits. DIATEC All details are designed to match each other perfectly. Depending on requirements, different equipment options and connections are possible. YOUR ADVANTAGE Modern, flat enclosure design, ideal for table top and wall-mounting applications. Plain, recessed area on the bottom part for installation and protection of interfaces, screwed cable glands, plug-in connections etc. Easy, invisible wall-mounting. Recessed operating area for the protection of the membrane keyboards and operating elements. Hinged lid in case colour or transparent for covering the dialogue zone as accessory. DIATEC Alternatively without/with battery operation for 2 x 1.5 V mignon-cells (AA) or 1 x 9 V flat battery (PP3). Separate slot-in panels can be used as interior partitions, for example to guard the electronics when changing batteries. Off-white, RAL 9002 APPLICATIONS Systems for data collection on the job. Access and security controls. Peripheral equipment for computers, data system engineering. Measuring and controlling. Medical field and laboratory technology. PROTECTION CLASS IP 40 H MAX. SIZE OF PCB W L DIATEC S M www.okw.com 28 Subject to technical modification without notice. Typographical and other errors do not justify any claim for damages. Stand: 12/05 e Copyright © 2005 OKW Gehäusesysteme GmbH, Buchen/Germany L x W in mm bottom part 120 x 180 180 x 180 top part 120 x 180 180 x 180 detailed drawings see our website D I AT E C INFO-BOX Innovative technology DIATEC The bottom part can be mounted directly on the wall. It is secured either using elongated holes or by the corners of the case. A particular advantage is the separation of the electronics area using optional slot-in panels. This allows the complete pre-assembly of the electronics unit. The technician on site only has to mount the unit on the wall and connect up the relevant leads. Connection can be effected from the left and/or from the righthand side. The actual case does not have to be opened to do this, only the snap-on side trims. If required, the trims can also be locked, thus preventing unauthorised access. ENCLOSURES* 1 DIATEC L S M Outside dim. in mm W H 200 200 210 270 Equipment (dim. in mm) max. dim. keypad Material 127.60 x 119.70 127.60 x 179.60 48 48 ABS (UL 94 HB) ABS (UL 94 HB) Part-No. A 90 93 107 A 90 94 107 ACCESSORIES For enclosure DIATEC 햲 Hinged lid S M S, M S, M S, M S, M S, M 햳 Slot-in panel 햴 Set of battery clips 햵 Plug-in contact 햶 Non-slip pads 햷 Self-tapping screw 햲 햳 햴 Version / Application 2 mounting holes ø 4.2 mm necessary, 1 set 2 mounting holes ø 4.2 mm necessary, 1 set ABS, off-white, 156 x 30 x 3 mm, 1 pc tin-plated, for 2 x 1.5 V mignon cells (AA) for one 9 V flat battery (PP3) transp., self-adhesive, ensure reliable desk-top positioning, 1 pair ø 3 x 6 mm, for mounting PCBs, 1 pc 햵 햶 *1 Supply: Each 1 bottom and top part, each 1 trim left and right side incl. 2 locking elements, assembly kit. universal accessories see pages 92-97 29 Part-No. ABS, off-white PC, transparent A 91 93 127 A 91 93 121 A 91 94 127 A 91 94 121 A 91 94 007 A 91 90 002 A 91 60 003 A 92 12 330 A 03 06 031 햷 NEW PRODUCT Service-Centre see pages 98-101 DIATEC Article
A9093107 价格&库存
很抱歉,暂时无法提供与“A9093107”相匹配的价格&库存,您可以联系我们找货
