A9167017
A9167017
    OKW
A9167017 数据手册
18 SMART-CASE Order data on pages 122-123 NeW good to hold THE PRODUCT The idea of giving greater expression to ergo­nomic requirements was the starting point of the development of the SMART-CASE. And so the design follows the touch sensation of the human being, thus facilitating natural sequences of hand movements. Benefit from the outstanding balance between design and technical sophistication. your advantage Convincing ergonomics; unique design. Ideal for remote controls, with cables or with battery compartment. Cable glands for sizes M, L and XL for cables ø 3.4 - 5.9 mm. Cable gland already included. NEW: enclosures in colour black with black cable gland. Max. size of PCB (L x W/W2 in mm) bottom part 46 x 29/18 58 x 38/30 88 x 50/42 127 x 60/50 top part – 63 x 40/31 117 x 51/37 78 x 60/56 + 50 x 55/47 (cutouts of pillars not taken into consideration) XS M L XL W H L W2 detailed drawings see our website www.okw.com Subject to technical modification without notice. Typographical and other errors do not justify any claim for damages. Stand: 10/12e Copyright © 2012 OKW Gehäusesysteme SMART-CASE 19 Order data on pages 122-123 NeW A P P L I C AT I O N P E R F E C T E D your advantage Optionally in material permeable to infra-red signals from stock. For utmost efficiency the front face is polished. Recessed operating area to protect the membrane keyboard (M/L/XL). applications Remote controls of all types, wireless or with cable connection. Especially suitable for use in hospitals and social fields as well as in industry and households. Fastening pillars and fixing supports for PCBs and components. Protection class up to IP 65 With sealing (accessories) sizes L and XL versions without battery compartment. Subject to technical modification without notice. Typographical and other errors do not justify any claim for damages. Stand: 10/12e Copyright © 2012 OKW Gehäusesysteme 122 SMART-CASE Information on pages 18-19 SMART-CASE ABS (UL 94 HB) off-white black RAL 9002 RAL 9005 (cable gland: volcano vers. III-V) PMMA plexiglass® black RAL 9005*1 Outside dim. in mm L W H Version / Equipment (dim. in mm) battery cable gland compartment approx. ø XS 58 35.6 19 – – – –*2 A 90 64 107 A 90 64 109 M 96 47 96 47 96 47 96 47 96 47 96 47 I 2 x AAA II 2 x AAA III – IV – V – VI – – – 5.0 - 5.9 4.2 - 5.0 3.4 - 4.2 – –*2 A 90 66 107 A 90 66 117 A 90 66 127 A 90 66 137 A 90 66 147 A 90 66 317 A 90 66 109 A 90 66 119 A 90 66 129 A 90 66 139 A 90 66 149 A 90 66 319 – – A 90 66 329 A 90 66 339 A 90 66 349 – A 90 66 209 A 90 66 219 – – – A 90 66 419 140 62.7 30.5 140 62.7 30.5 140 62.7 30.5 140 62.7 30.5 140 62.7 30.5 I 2 x AA / 1 x 9 V II – III – IV – V – – – 5.0 - 5.9 4.2 - 5.0 3.4 - 4.2 103.95 x 50.95 A 90 67 107 A 90 67 117 A 90 67 127 A 90 67 137 A 90 67 147 A 90 67 109 A 90 67 119 A 90 67 129 A 90 67 139 A 90 67 149 – – A 90 67 329 A 90 67 339 A 90 67 349 A 90 67 209 A 90 67 219 – – – 168 74.4 35.4 168 74.4 35.4 168 74.4 35.4 168 74.4 35.4 168 74.4 35.4 I 2 x AA / 1 x 9 V II – III – IV – V – – – 5.0 - 5.9 4.2 - 5.0 3.4 - 4.2 110.60 x 61.05 A 90 68 107 A 90 68 117 A 90 68 127 A 90 68 137 A 90 68 147 A 90 68 109 A 90 68 119 A 90 68 129 A 90 68 139 A 90 68 149 – – A 90 68 329 A 90 68 339 A 90 68 349 A 90 68 209 A 90 68 219 – – – SMART-CASE L XL 24 24 24 24 24 24 max. dim. keypad 74.60 x 39.85 black RAL 9005 (gland black) – NeW A 90 64 209 *1 sizes L & XL only the bottom parts made of PMMA, top part is made of ABS (UL 94 HB); cases made of PMMA plexiglass® not comparable to cases made of ABS when comparing mechanical load-bearing capacity *2 without recessed area Subject to technical modification without notice. Typographical and other errors do not justify any claim for damages. Stand: 10/12e Copyright © 2012 OKW Gehäusesysteme smart-case 123 Information on pages 18-19 smart-case accessories Article For SMART-CASE Version / Application ① Set of battery clips M L, XL M M L, XL L XL M, L, XL & station XS tin-plated, for 2 x 1.5 V micro cells (AAA) tin-plated, for 2 x 1.5 V mignon cells (AA) tin-plated, for a serial connection when using the set of batt. clips (AAA) clamps down securely 2 x AAA for one 9 V flat battery for versions II-V, for a higher protection class (IP 65) for versions II-V, for a higher protection class (IP 65) for strain relief of cable connected applications nickel-plated, ø 20.5 mm ② Battery contact c Battery holder d Plug-in contact e Sealing f Set of strain relief g Key ring Part-No. A 91 66 001 A 91 90 002 A 91 66 002 A 91 66 003 A 91 60 003 A 91 67 002 A 91 68 002 A 91 66 004 A 91 64 001 off-white h Belt /pocket clip i Holding clamp j Holder k Adhesive foil for holder l Holder with adapter (4-claws system)*2 m Station n Contacts (bore holes necessary) o Ring eyelet M, L, XL M, L, XL M L XL holder M holder L holder XL M L XL M L XL M, L, XL M, L, XL M, L XL PA 6, 2 mounting holes ø 4.2 mm necessary up to ø 32 mm, ABS, 2 mounting holes ø 4.2 mm necessary ABS, also suitable for cable connected applications ABS, also suitable for cable connected applications ABS, also suitable for cable connected applications double-sided adhesive foil with foam carrier double-sided adhesive foil with foam carrier double-sided adhesive foil with foam carrier NeW ABS, also suitable for cable connected applications, adapter in black ABS, also suitable for cable connected applications, adapter in black ABS, also suitable for cable connected applications, adapter in black ABS, desk case application ABS, desk case application ABS, desk case application contact pin, gold-plated, < 15 A spring contact, gold-plated, load-carrying cap. up to 3 A, 1.5 mm stroke, 0.3 N plastic, volcano, inside ring ø 2.5 mm, location hole ø 4 mm required plastic, volcano, inside ring ø 4 mm, location hole ø 5 mm required ① b c d i j k l n o e f m g black A 91 67 017 A 91 67 019 A 91 67 027 A 91 67 029 A 91 66 307 A 91 66 309 A 91 67 307 A 91 67 309 A 91 68 307 A 91 68 309 A 91 66 005 A 91 67 005 A 91 68 005 A 91 66 327 A 91 66 329 A 91 67 327 A 91 67 329 A 91 68 327 A 91 68 329 A 91 66 037 A 91 66 039 A 91 67 037 A 91 67 039 A 91 68 037 A 91 68 039 A 91 93 030 A 91 93 032 A 91 00 001 A 91 00 002 h n universal accessories on pages 178-187 *2 for attaching to holding devices; with 4-hole grid pattern to match the grid plates of the holding devices with the 4-claws system A9220029, A9220039, A9220049 and A9220059 (separate article see page 179) Subject to technical modification without notice. Typographical and other errors do not justify any claim for damages. Stand: 10/12e Copyright © 2012 OKW Gehäusesysteme
A9167017 价格&库存
很抱歉,暂时无法提供与“A9167017”相匹配的价格&库存,您可以联系我们找货
