A9257209
A9257209
    OKW
A9257209 数据手册
*Mounting angle ( ) on the adapter serves as a support to locate the case in the right position. After attachment of the adapter, the mounting angles can be easily removed. ACCESSORIES Tilt foot bar, Case feet T I LT F O O T B A R Universal tilt foot bar. Can be placed in any position to choose an ergonomical reading angle. Simple mounting with 2 self-tapping screws, ø 2.2 x 6 mm. Necessary location holes: 2 x ø 4.2 mm at a center distance of 20 mm. Suitable for the OKW cases: – SHELL-TYPE CASE 110 and 155 – HAND-HELD-BOX P and M – FLAT-PACK CASE »Special version of tilt foot bar suitable for DATECMOBIL-BOX M and S see page 30.« Part-No. A 92 50 807 A 92 50 809 A 92 07 150 CASE FEET Article / Version Tilt foot bar of ABS, off-white RAL 9002 Tilt foot bar of ABS, black RAL 9005 Clear non-slip pads Supply 1 tilt foot bar 2 self-tapping screws ø 2.2 x 6 mm 2 pieces ø 6.5 mm Version II Example of mounting: Available in 2 versions: Version I: Case feet for universal application. Version II: Same version as version I but for combination with the tilt foot bar (next item). Clip mechanism for two different canting angles. ACCESSORIES Part-No. A 92 01 008 A 92 02 008 Version I Article Case feet, polystyrene, basalt grey RAL 7012 Case feet, polystyrene, basalt grey RAL 7012 T I LT F O O T B A R Part-No. A 93 09 009 A 93 16 009 A 93 22 009 A 93 23 009 200 Dim. in mm A a 104 88 174 158 234 218 246 230 Version / Supply Galvanized steel 1 wire section Version I II Supply 2 feet with accessories 2 feet with accessories ACCESSORIES Case feet, Anti-slide feet, Self-tapping screws, Battery clips, Battery spacer CASE FEET Self-tapping screw Foot Location pillars Rubber insert Universal case feet for all types of plastic and metal enclosures with max. 4 mm wall thickness. Case panel Version I: Tilt leg 17 10 Ø3 Case drilling details 36 34 4,5 3 4 foot mouldings. 4 non-slip rubber inserts. 4 self-tapping screws. Version II: 16 13 Ø4 As above but also including 2 tilt legs. 16 127° 25 10 Version I II I II Colour off-white, RAL 9002, rubber inserts pebble grey off-white, RAL 9002, rubber inserts pebble grey black, RAL 9005, rubber inserts pebble grey black, RAL 9005, rubber inserts pebble grey Material ABS (UL 94 HB) ABS (UL 94 HB) ABS (UL 94 HB) ABS (UL 94 HB) Part-No. A 92 57 107 A 92 57 207 A 92 57 109 A 92 57 209 ANTI-SLIDE FEET Dim. in mm A=ø B 6.5 2 10 2.9 12 3.5 Colour transparent transparent transparent Material / Supply Silicon, 2 pcs. Silicon, 2 pcs. Silicon, 2 pcs. Self-tapping crosshead screw, specifically suitable for plastics. For fastening components, boards and PCBs onto pillars. Z (PZ1) Version 2.5 x 6 mm 3 x 6 mm 3 x 8 mm Supply 1 pc. 1 pc. 1 pc. For round cells only (AA type). Useful for DATEC-MOBIL-BOX, SHELL-TYPE-CASE, LUX CASE and HAND-HELD-BOX. Version / Supply large, double contact, tin plated, 1 pc. small, single contact, tin plated, 1 pc. large, double contact, nickel plated, 1 pc. small, single contact, nickel plated, 1 pc. Suitable for: – DATEC-POCKET-BOX L – DATEC-MOBIL-BOX S – HAND-HELD-BOX N – LUX-CASES 150 and 190 – SHELL-TYPE CASES Versions III and IV Version / Supply PE foam with one-sided adhesive coating, 1 pc. Part-No. A 92 07 150 A 92 10 290 A 92 12 330 S E L F - TA P P I N G SCREWS Part-No. A 03 05 031 A 03 06 031 A 03 08 031 B AT T E R Y C L I P S Part-No. A 91 93 003 A 91 93 004 A 91 93 005 A 91 93 006 B AT T E R Y S P A C E R It serves to compensate for the differences in height and to secure the mignon cells (AA) within the battery compartments, which can also hold a 9 V flat battery (PP3). Part-No. A 92 50 250 201 ACCESSORIES 2 x Ø 3,1 HANDLE BAR / BAIL ARM Possible to mount from the outside and inside – removable NEW: Universal handle – available in any width almost for any housing. The handle can be mounted from the outside and inside. It can be removed in the 135° position. Ratchet with 30° indexing. If the handle is overloaded the ratchet will automatically disengage to avoid damaging the mechanism! S TA N D A R D COLOURS Side arms: Off-white, RAL 9002. Push buttons: Volcano, NCS 5502-G. Center section: Silver, matt anodized. Extrusion length = Case width + 3 mm Supply: 2 side arms. Fastening elements. 1 aluminium center section (cut to your requested length). M AT E R I A L Case width Side arms glass reinforced polyamide. The center section extruded matt anodized aluminium. Stainless springs. Order data: Order the side arm kit and give us the width of your housing. We will supply the components as a set with the aluminium profile of the required length. ACCESSORIES disassembly position Part-No. A 93 00 722 202 Article Side arms kit Colour Side arms off-white RAL 9002 / push buttons volcano HANDLE BAR / BAIL ARM Possible to mount from the inside HANDLE BAR IN INJECTION MOULDED PLASTIC Universal handle – available in any width almost for any housing. S TA N D A R D COLOURS Extrusion length Case width One-coloured: Off-white, RAL 9002 or black, RAL 9005. Two-coloured: Side arms off-white, RAL 9002 and push buttons pebble grey, RAL 7032 or Side arms pebble grey, RAL 7032 and push button off-white, RAL 9002. M AT E R I A L Side arms glass reinforced polyamide. The middle section extruded matt anodized aluminium. Strong ratchet with 30° indexing. Order data: Order the side arm kit and give us the width of your housing. We will supply the components as a set with the aluminium profile of the required length. Supply: 2 side arms 2 fastening screws 1 requested aluminium center section Article Side arms kit Side arms kit Side arms kit Side arms kit Colour combination off-white RAL 9002 / push buttons pebble grey RAL 7032 off-white RAL 9002 / push buttons pebble grey RAL 9002 pebble grey RAL 7032 / push buttons off-white RAL 9002 black RAL 9005 Part-No. A 93 00 016 A 93 00 017 A 93 00 018 A 93 00 015 HANDLE BAR IN DIECAST ZINC Universal robust handle – available in any width almost for any housing. Strong ratchet with 30° indexing. S TA N D A R D COLOURS Extrusion length Side arms and mechanism off-white, RAL 9002, push button pebble grey, RAL 7032. Anti-glide rubber inserts black. Case width M AT E R I A L In order to improve the stability, we recommend glueing the aluminium profiles with the lateral parts. ACCESSORIES Side arms and mechanism diecast zinc. Push button plastic moulded glass reinforced polyamide. Extruded center section matt anodized aluminium. Anti-glide inserts in rubber. Order data: Order the side arm kit and give us the width of your housing. We will supply the components as a set with the aluminium profile of required length. Supply: 2 side arms 2 fastening screws 1 requested aluminium center section Article Side arms kit Colour combination Side arms off-white RAL 9002 / push buttons pebble grey RAL 7032 Part-No. A 93 00 014 203 ACCESSORIES Cable glands CABLE GLANDS WITH PULL RELIEF Part-No. C 23 12 418 C 23 16 418 C 23 20 418 C 23 20 428 C 23 25 418 C 23 32 418 M12 M16 M20 M20 M25 M32 CABLE GLANDS WITH PULL RELIEF AND BENDING PROTECTION Part-No. C 23 12 518 C 23 16 518 C 23 20 518 C 23 20 528 C 23 25 518 M12 M16 M20 M20 M25 Cable glands of the best material for shake and twistproof cable lead-in for OKW housings. High protection class IP 68. COUNTERNUTS S TA N D A R D COLOURS Part-No. C 23 12 117 C 23 16 117 C 23 20 117 C 23 25 117 C 23 32 117 Cable glands silver grey, RAL 7001. Counternuts light grey, RAL 7035. Sealing ring naturalcoloured. M12 M16 M20 M25 M32 M AT E R I A L SEALING RING FOR EXTERNAL THREAD Mounting between housing and gland flange to preserve the high protection class IP 68 of the OKW cable glands. ACCESSORIES Part-No. C 23 12 126 C 23 16 126 C 23 20 126 C 23 25 126 C 23 32 126 External thread M12 M16 M20 M25 M32 M12 M16 M20 M20 M25 M32 206 Sealing ring Case wall Cable glands and counternuts polyamide. Sealing ring of polyethylene. Comparison between PG and metric thread: Mounting drills (ø in mm) KEY WIDTH Dim. in mm SW1 SW2 15 17 22 22 24 26 27 26 33 32 42 41 CLAMP RANGES of all cable glands D 12.5 16.5 20.5 20.5 25.5 32.5 L 8 8 11 15 15 15 H 5 5 6 6 6 7 ø 3 - 6.5 ø 5 - 10 ø 6 - 12 ø 10 - 14 ø 13 - 18 ø 18 - 25 PG7 PG9 PG11 PG16 PG13,5 19 23 13 15,5 20,5 PG21 28,5 12,5 16,5 20,5 25,5 32,5 M12 M16 M20 M25 M32
A9257209 价格&库存
很抱歉,暂时无法提供与“A9257209”相匹配的价格&库存,您可以联系我们找货
A9257209
    • 1+180.08923
    库存:76
