B3020127
B3020127
    OKW
B3020127 数据手册
motec 67 Order data on page 156 l a rge inter f a ce p a nel Protection class IP 40 With front / rear panel or with sloping control panel and rear panel. Max. size of PCB (L x W in mm) S M L top / bottom part 128 x 90 178 x 125 208 x 150 H W D the product your advantage Generously dimensioned, comfortable control and interface panels distinguish the MOTEC desktop device from conventional systems. Modern and fashionable design. Different sizes and combinations offer a wide selection of attractive cases. Guide grooves for the vertical insertion of partitions and printed circuit boards. Thanks to an innovative snap-in system, you can minimise your assembly work and at the same time improve the visual attractiveness of your products. Sloping control panel with recessed area to protect membrane keyboards available as an accessory. Different heights of cases for individual configurations. High-quality material ABS, optionally in UL 94 HB or UL 94 V-0 flame-resistant. detailed drawings see our website www.okw.com Subject to technical modification without notice. Typographical and other errors do not justify any claim for damages. Stand: 10/12e Copyright © 2012 OKW Gehäusesysteme 156 motec Information on page 67 MOTEC MOTEC S M L Outside dim. in mm W D H Version / Equipment (dim. in mm) case shells base/top handle bar*1 155 105 155 105 155 105 205 140 205 140 205 140 205 140 235 165 235 165 235 165 235 165 flat / flat flat / high high / high flat / flat flat / high flat / high high / high flat / flat flat / high flat / high high / high 40 65 90 50 75 75 100 60 85 85 110 – – – – – • (Tilt/swivel handle adjustable in increments 30°) – – – • (Tilt/swivel handle adjustable in increments 30°) – Part-No. ABS (UL 94 HB) ABS (UL 94 V-0) off-white off-white RAL 9002 RAL 9002 B 30 15 117 B 30 15 127 B 30 15 137 B 30 20 117 B 30 20 127 B 30 20 147 B 30 20 137 B 30 23 117 B 30 23 127 B 30 23 147 B 30 23 137 B 30 15 217 B 30 15 227 B 30 15 237 B 30 20 217 B 30 20 227 – B 30 20 237 B 30 23 217 B 30 23 227 – B 30 23 237 MOTEC accessories Article For MOTEC Version / Application ① Sloping control panel flat / high S M flat / high L flat / high L high / high flat / flat S S flat / high S high / high flat / flat M M flat/ high M high / high L flat / flat L flat / high L high / high S, M, L off-white, RAL 9002, max. dim. keypad 137.80 x 46.80 mm, insertion into the guides off-white, RAL 9002, max. dim. keypad 186.70 x 54.40 mm, insertion into the guides off-white, RAL 9002, max. dim. keypad 214.70 x 62.90 mm, insertion into the guides off-white, RAL 9002, max. dim. keypad 214.60 x 90.60 mm, insertion into the guides matt anodised aluminium, 136 x 32 x 1.5 mm, insertion into the guides, 1 pc matt anodised aluminium, 136 x 57 x 1.5 mm, insertion into the guides, 1 pc matt anodised aluminium, 136 x 82 x 1.5 mm, insertion into the guides, 1 pc matt anodised aluminium, 185 x 42 x 1.5 mm, insertion into the guides, 1 pc matt anodised aluminium, 185 x 67 x 1.5 mm, insertion into the guides, 1 pc matt anodised aluminium, 185 x 92 x 1.5 mm, insertion into the guides, 1 pc matt anodised aluminium, 214 x 52 x 1.5 mm, insertion into the guides, 1 pc matt anodised aluminium, 214 x 77 x 1.5 mm, insertion into the guides, 1 pc matt anodised aluminium, 214 x 102 x 1.5 mm, insertion into the guides, 1 pc 4 x ø 2.5 x 6 mm, for mounting PCBs b Front / rear panel c Set of screws ① b Part-No. ABS (UL 94 HB) ABS (UL 94 V-0) B 31 15 167 B 31 15 267 B 31 20 167 B 31 20 267 B 31 23 167 B 31 23 267 B 31 23 177 B 31 23 277 B 31 15 100 B 31 15 110 B 31 15 120 B 31 20 100 B 31 20 110 B 31 20 120 B 31 23 100 B 31 23 110 B 31 23 120 A 91 99 008 c universal accessories on pages 178-187 *1 side arms and push button of reinforced polyamide, middle section aluminium profile; the mounting of the handle bar to the side panels with draft will hardly affect the load capacity and performance Subject to technical modification without notice. Typographical and other errors do not justify any claim for damages. Stand: 10/12e Copyright © 2012 OKW Gehäusesysteme
B3020127 价格&库存
很抱歉,暂时无法提供与“B3020127”相匹配的价格&库存,您可以联系我们找货
