A71X25AQFI/Q
A71X25AQFI/Q
    AMICCOM(笙科)
    QFN20_4X4MM_EP
    A71X25AQFI/Q
A71X25AQFI/Q 数据手册
A7125 2.4GHz FSK Transceiver Document Title A7125 Data Sheet, 2.4GHz FSK Transceiver with 2M / 1Mbps data rate Revision History History Issue Date Remark L Rev. No. 0.0 Initial issue. Aug. 31, 2007 0.1 0.2 Logo change. Modify PIN Configuration and Description, Block Diagram, Electrical Specifications, Diagram of State Machine. Add Control Register and Function Description. Oct. 18, 2007 July 31, 2008 Preliminary 0.3 Add Power Saving FIFO Mode. Rename GPIO1 and GPIO2 into GIO1 and GIO2. August 31, 2008 Preliminary 0.4 Modify register recommended value IGFI [2:0] = [000] Modify register recommended value IGFQ [2:0] = [000] Delete TWWS function October 06, 2008 Preliminary 0.5 Modify register recommended value Delay Register I (17h): PDL= [000] Delay Register II (18h): WSEL= [011] Battery Detect Register (2Ch): QDS = [1] Crystal Test Register (32h): XCP= [00] IFAT Register (36h): IGFI [2:0] = [111], IGFQ [2:0] = [111] Modify PLL to WPLL settling time when PDL=[000] If LO is changed, from 20 us to 30 us If LO is fixed, from 20 us to 10 us Delete Ext Voltage Measurement function Add EOPD output to GIO2 Add PASW output to GIO2 Add EOPDS Register Add section 16.5 Modify register recommended value ADC Control (1Fh): CDM= [0] Modify recommended timing of PASW FI D EN TI A Preliminary Preliminary Preliminary Feb., 2010 Full Production Nov., 2010 Full Production Nov. 30, 2010 Full Production Jul. 2011 Full Production M C O N June 11, 2009 C O 1.0 Change English Company Name A M 1.2 Add Note 8 (regulator settling time) in chapter 8. IC 1.1 1.3 Modify the tape reel information and the add Shenzhen office address. Important Notice: AMICCOM reserves the right to make changes to its products or to discontinue any integrated circuit product or service without notice. AMICCOM integrated circuit products are not designed, intended, authorized, or warranted to be suitable for use in life-support applications, devices or systems or other critical applications. Use of AMICCOM products in such applications is understood to be fully at the risk of the customer. Jul., 2011, v1.3 1 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver Table of Contents A M IC C O M C O N FI D EN TI A L 1. Typical Application ..................................................................................................................................................... 5 2. General Description ................................................................................................................................................... 5 3. Feature ..................................................................................................................................................................... 5 4. PIN Configuration ...................................................................................................................................................... 6 5. PIN Description (I: Input, O: Output, I/O: Input or Output, G: Ground, D: Digital)........................................................... 7 6. Block Diagram ........................................................................................................................................................... 8 7. Absolution Maximum Rating ....................................................................................................................................... 9 8. Electrical Specifications............................................................................................................................................ 10 General ................................................................................................................................................................ 10 Phase Locked Loop .............................................................................................................................................. 10 Transmitter ........................................................................................................................................................... 10 Receiver............................................................................................................................................................... 10 Regulator ............................................................................................................................................................. 10 Digital IO DC characteristics...................................................................................................................................11 9. Control Register....................................................................................................................................................... 12 9.1 Control Register Table..................................................................................................................................... 12 9.2 Control Register Description............................................................................................................................ 15 9.2.1 Mode Register (Address: 00h) ............................................................................................................... 15 9.2.2 Mode Control Register (Address: 01h) ................................................................................................... 15 9.2.3 Calibration Control Register (Address: 02h)............................................................................................ 16 9.2.4 FIFO Register I (Address: 03h) .............................................................................................................. 16 9.2.5 FIFO Register II (Address: 04h) ............................................................................................................. 16 9.2.6 FIFO DATA Register (Address: 05h)....................................................................................................... 16 9.2.7 ID DATA Register (Address: 06h) ........................................................................................................... 16 9.2.8 RC OSC Register I (Address: 07h)......................................................................................................... 17 9.2.9 RC OSC Register II (Address: 08h)........................................................................................................ 17 9.2.10 RC OSC Register III (Address: 09h)..................................................................................................... 17 9.2.11 CKO Pin Control Register (Address: 0Ah)............................................................................................. 17 9.2.12 GIO1 Pin Control Register (Address: 0Bh)............................................................................................ 17 9.2.13 GIO2 Pin Control Register (Address: 0Ch) ........................................................................................... 18 9.2.14 Data Rate Clock Register (Address: 0Dh)............................................................................................. 19 9.2.15 PLL Register I (Address: 0Eh).............................................................................................................. 21 9.2.16 PLL Register II (Address: 0Fh)............................................................................................................. 21 9.2.17 PLL Register III (Address: 10h) ............................................................................................................ 21 9.2.18 PLL Register IV (Address: 11h) ............................................................................................................ 21 9.2.19 PLL Register V (Address: 12h)............................................................................................................. 21 9.2.20 Channel Group Register I (Address: 13h) ............................................................................................. 21 9.2.21 Channel Group Register II (Address: 14h) ............................................................................................ 22 9.2.22 TX Register I (Address: 15h)................................................................................................................ 22 9.2.23 TX Register II (Address: 16h)............................................................................................................... 22 9.2.24 Delay Register I (Address: 17h) ........................................................................................................... 23 9.2.25 Delay Register II (Address: 18h) .......................................................................................................... 23 9.2.26 RX Register (Address: 19h) ................................................................................................................. 24 9.2.27 RX Gain Register I (Address: 1Ah)....................................................................................................... 24 9.2.28 RX Gain Register II (Address: 1Bh)...................................................................................................... 24 9.2.29 RX Gain Register III (Address: 1Ch)..................................................................................................... 25 9.2.30 RX Gain Register IV (Address: 1Dh) .................................................................................................... 25 9.2.31 RSSI Threshold Register (Address: 1Eh).............................................................................................. 25 9.2.32 ADC Control Register (Address: 1Fh)................................................................................................... 25 9.2.33 Code Register I (Address: 20h) ............................................................................................................ 26 9.2.34 Code Register II (Address: 21h)........................................................................................................... 26 9.2.35 Code Register III (Address: 22h) .......................................................................................................... 26 9.2.36 IF Calibration Register I (Address: 23h)................................................................................................ 26 9.2.37 IF Calibration Register II (Address: 24h)............................................................................................... 27 9.2.38 VCO Current Calibration Register (Address: 25h) ................................................................................. 27 9.2.39 VCO Bank Calibration Register I (Address: 26h)................................................................................... 27 9.2.40 VCO Bank Calibration Register II (Address: 27h).................................................................................. 28 9.2.41 VCO Deviation Calibration Register I (Address: 28h) ............................................................................ 28 9.2.42 VCO Deviation Calibration Register II (Address: 29h) ........................................................................... 28 9.2.43 VCO Deviation Calibration Register III (Address: 2Ah) .......................................................................... 28 9.2.44 VCO Modulation Delay Register (Address: 2Bh)................................................................................... 29 9.2.45 Battery Detect Register (Address: 2Ch)................................................................................................ 29 Jul., 2011, v1.3 2 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver A M IC C O M C O N FI D EN TI A L 9.2.46 TX test Register (Address: 2Dh)........................................................................................................... 29 9.2.47 RX DEM test Register I (Address: 2Eh)................................................................................................ 29 9.2.48 RX DEM test Register II (Address: 2Fh) ............................................................................................... 30 9.2.49 Charge Pump Current Register I (Address: 30h)................................................................................... 30 9.2.50 Charge Pump Current Register II (Address: 31h).................................................................................. 30 9.2.51 Crystal test Register (Address: 32h) ..................................................................................................... 30 9.2.52 PLL test Register (Address: 33h).......................................................................................................... 30 9.2.53 VCO test Register (Address: 34h) ........................................................................................................ 31 9.2.54 RF Analog test Register (Address: 35h)................................................................................................ 31 9.2.55 IFAT Register (Address: 36h) ............................................................................................................... 31 9.2.56 Channel Select Register (Address: 37h)............................................................................................... 32 9.2.57 VRB Register (Address: 38h) ............................................................................................................... 32 10. SPI........................................................................................................................................................................ 33 10.1 SPI Format ................................................................................................................................................... 34 10.2 SPI Timing Characteristic .............................................................................................................................. 34 10.3 SPI Timing Chart........................................................................................................................................... 34 10.3.1 Timing Chart of 3-wire SPI ................................................................................................................... 34 10.3.2 Timing Chart of 4-wire SPI ................................................................................................................... 35 10.4 Strobe Commands ........................................................................................................................................ 35 10.4.1 Strobe Command - Sleep Mode ........................................................................................................... 36 10.4.2 Strobe Command - ldle Mode............................................................................................................... 36 10.4.3 Strobe Command - Standby Mode........................................................................................................ 37 10.4.4 Strobe Command - PLL Mode.............................................................................................................. 37 10.4.5 Strobe Command - RX Mode ............................................................................................................... 38 10.4.6 Strobe Command - TX Mode................................................................................................................ 38 10.4.7 Strobe Command – FIFO Write Pointer Reset ...................................................................................... 38 10.4.8 Strobe Command – FIFO Read Pointer Reset ...................................................................................... 39 10.5 Reset Command........................................................................................................................................... 39 10.6 ID Accessing Command ................................................................................................................................ 39 10.6.1 ID Write Command.............................................................................................................................. 40 10.6.2 ID Read Command.............................................................................................................................. 40 10.7 FIFO Accessing Command............................................................................................................................ 40 10.7.1 TX FIFO Write Command .................................................................................................................... 40 10.7.2 Rx FIFO Read Command .................................................................................................................... 41 11. State machine........................................................................................................................................................ 42 11.1 Key states ..................................................................................................................................................... 42 11.1.1 Standby mode ..................................................................................................................................... 42 11.1.2 Sleep mode ......................................................................................................................................... 43 11.1.3 ldle mode ............................................................................................................................................ 43 11.1.4 PLL mode............................................................................................................................................ 43 11.1.5 TX mode ............................................................................................................................................. 43 11.1.6 RX mode............................................................................................................................................. 43 11.1.7 CAL mode ........................................................................................................................................... 44 11.2 Normal FIFO Mode........................................................................................................................................ 45 11.3 Quick FIFO Mode.......................................................................................................................................... 47 11.4 Power Saving FIFO Mode.............................................................................................................................. 48 11.5 Quick Direct Mode......................................................................................................................................... 51 12 Crystal Oscillator Circuit.......................................................................................................................................... 54 12.1 Use External Crystal...................................................................................................................................... 54 12.2 Use External Clock........................................................................................................................................ 54 13. System Clock ........................................................................................................................................................ 55 13.1 Derive System Clock ..................................................................................................................................... 55 13.2 Data Rate ..................................................................................................................................................... 56 14. Transceiver Frequency........................................................................................................................................... 57 14.1 LO Frequency Setting ................................................................................................................................... 58 14.2 IF Side Band Select ...................................................................................................................................... 61 14.2.1 Auto IF Exchange................................................................................................................................ 62 14.2.2 Fast Exchange .................................................................................................................................... 62 14.3 Band Edge Frequency Setting ....................................................................................................................... 63 14.4 Frequency Compensation.............................................................................................................................. 65 15. Calibration............................................................................................................................................................. 67 15.1 Calibration Procedure.................................................................................................................................... 67 15.2 IF Filter Bank Calibration ............................................................................................................................... 67 15.3 RSSI Calibration ........................................................................................................................................... 67 15.4 VCO Current Calibration................................................................................................................................ 68 15.5 VCO Bank Calibration ................................................................................................................................... 68 Jul., 2011, v1.3 3 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver A M IC C O M C O N FI D EN TI A L 15.6 VCO Deviation Calibration............................................................................................................................. 68 15.7 Channel Group Function ............................................................................................................................... 68 16. FIFO (First In First Out).......................................................................................................................................... 70 16.1 Packet Format of FIFO mode ........................................................................................................................ 70 16.2 Bit Stream Process........................................................................................................................................ 71 16.3 Transmission Time ........................................................................................................................................ 71 16.4 Usage of TX and RX FIFO............................................................................................................................. 72 16.4.1 Easy FIFO........................................................................................................................................... 72 16.4.2 Segment FIFO..................................................................................................................................... 73 16.4.3 FIFO Extension ................................................................................................................................... 76 16.5 Optimize Throughput..................................................................................................................................... 80 17. ADC (Analog to Digital Converter) .......................................................................................................................... 82 17.1 Temperature Measurement............................................................................................................................ 82 17.2 RSSI Measurement....................................................................................................................................... 82 17.3 Carrier Detect ............................................................................................................................................... 84 18. Battery Detect........................................................................................................................................................ 85 19. Application Circuit Example .................................................................................................................................... 86 20. Abbreviations......................................................................................................................................................... 87 20. Abbreviations......................................................................................................................................................... 88 21. Ordering Information .............................................................................................................................................. 88 22. Package Information .............................................................................................................................................. 89 23. Top Marking Information......................................................................................................................................... 90 24. Reflow Profile ........................................................................................................................................................ 91 25. Tape Reel Information............................................................................................................................................ 92 26. Product Status ....................................................................................................................................................... 93 Jul., 2011, v1.3 4 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 1. Typical Application n n n 2.4GHz ISM band Communication System 2.4GHz Remote Control Wireless Keyboard and Mouse ■ ■ ■ Wireless Intelligent sports Wireless Toy and Gaming Wireless Audio/Video Streaming 2. General Description TI A L A7125 is a high performance and low cost 2.4GHz ISM band wireless transceiver. It integrates high sensitivity receiver (-90dBm @2Mbps), high efficiency power amplifier (up to 3dBm), frequency synthesizer and base-band modem. In typical system, A7125 is used together with MCU (microcontroller) with very few external passive components. A7125 supports both FIFO mode and direct mode that contains clock recovery circuit CKO pin to MCU. EN A7125 supports very fast settling time (90 us) for frequency hopping system. For packet handling, A7125 has built-in separated 64-bytes TX/RX FIFO (could be extended to 256 bytes) for data buffering and burst transmission, CRC for error detection, FEC for 1-bit data correction per code word, RSSI for clear channel assessment, data whitening for data encryption/decryption, thermal sensor for monitoring relative temperature. Those functions are very easy to use while developing a wireless system. All features are integrated in a small QFN 4X4 20 pins package. FI D A7125’s data rate is up to 2Mbps and can be easily programmed to 1Mbps or 2 Mbps via 3-wire or 4-wire SPI bus. For power saving, A7125 supports sleep mode, idle mode, standby mode. For easy-to-use, A7125 has an unique SPI command set called Strobe command that are used to control A7125’s state machine. Based on Strobe commands, from power saving, TX delivery, RX receiving, channel monitoring, frequency hopping to auto calibrations, MCU only needs to define A7125’s control registers and send Strobe commands via SPI bus. In addition, A7125 supports two general purpose I/O pins, GIO1 and GIO2, to inform MCU its status so that MCU could use either polling or interrupt scheme to do radio control. Therefore, it is very easy to monitor transmission between MCU and A7125 because of its digital interface. O M C O Small size (QFN 4X4, 20 pins). Support 2400 ~ 2483.5 MHz ISM band. FSK modulation. Programmable data rate to 1Mbps or 2Mbps. Low current consumption: RX 17mA, TX 15.7mA (at 0dBm output power). Low sleep current (1.5uA). Programmable RF output power -20dBm ~ 3dBm. Very High sensitivity (-90dBm@2Mbps, -92dBm@1Mbps). On chip regulator, supports input voltage 2.0 ~ 3.6V. Easy to use u Support 3-wire or 4-wire SPI. u Unique Strobe command via SPI. u Change frequency channel by ONE register setting. u 8-bits Digital RSSI for clear channel indication. u Fast exchange mode during TRX role switching. u Auto RSSI measurement. u Auto Calibrations. u Auto IF function. u Auto CRC Check. u Auto FEC by (7, 4) Hamming code (1 bit error correction / code word). u Data Whitening for encryption and decryption. u Separated 64 bytes RX and TX FIFO. u Easy FIFO / Segment FIFO / FIFO Extension (up to 256 bytes). u Support direct mode with recovery clock output to MCU. u Support direct mode with frame sync signal to MCU. Support low cost crystal (6 / 8 /12 / 16MHz). Support low accuracy crystal within ± 50ppm. Support Auto Frequency Compensation. Support crystal sharing, (1 / 2 / 4 / 8MHz) to MCU. Fast settling time synthesizer for frequency hopping system. Built-in thermal sensor for monitoring relative temperature. Built-in Battery Detector. A M IC C n n n n n n n n n n N 3. Feature n n n n n n n Jul., 2011, v1.3 5 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver C O N FI D EN TI A L 4. PIN Configuration A M IC C O M Figure 4.1 A7125 QFN 4x4 Package Top View Jul., 2011, v1.3 6 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 5. PIN Description (I: Input, O: Output, I/O: Input or Output, G: Ground, D: Digital) L TI A G EN Back side plate Function Description O: RSSI bypass. Connect to bypass capacitor. Band-gap bypass. Connect to bypass capacitor. RF input. Connect to matching circuit. RF output. Connect to matching circuit. RF choke input. Connect to matching circuit. VCO supply voltage input. Charge-pump output. Connect to loop filter. PLL supply voltage input. Crystal oscillator input. Connect to tank capacitor. Crystal oscillator output. Connect to tank capacitor. SPI chip select input. SPI clock input. Digital supply voltage output. Connect to bypass capacitor. SPI data IO. Ground. Multi-function IO 1 / SPI data output. Multi-function IO 2 / SPI data output. Multi-function clock output. Regulator input. Connect to VDD supply. Analog supply voltage output. Connect to bypass capacitor. Ground. Back side plate shall be well-solder to ground; otherwise, it will impact RF performance. FI D I/O O O I O I I O O I O DI DI O DI/O G DI/O DI/O DO I O N Symbol BP_RSSI BP_BG RFI RFO RFC VDD_VCO CP VDD_PLL XI XO SCS SCK VDD_D SDIO GND GIO1 GIO2 CKO REGI VDD_A A M IC C O M C O Pin No. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Jul., 2011, v1.3 7 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver REGI CKO GIO2 GIO1 20 19 18 17 16 5 8 CP C O VDD_VCO 7 14 SDIO 13 VDD_D SPI XOSC 6 GND TI A RXFIFO TXFIFO PLL N RFC VCO FI D PA 15 EN 4 BSP RFO LNA 9 10 XO 3 MODEM RFI Radio Control XI 2 VDD_PLL BP_BG Regulator/ Thermal sensor ADC Packet Handler BP_RSSI 1 L VDD_A 6. Block Diagram 12 SCK 11 SCS A M IC C O M Figure 6.1 A7125 Block Diagram Jul., 2011, v1.3 8 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 7. Absolution Maximum Rating With respect to Rating Unit Supply voltage range (VDD) GND -0.3 ~ 3.6 V Digital I/O pins range GND -0.3 ~ VDD+0.3 V Voltage on the analog pins range GND -0.3 ~ 2.1 V Input RF level 14 dBm -55 ~ 125 °C HBM ± 2K V MM ± 100 ESD Rating V TI A Storage Temperature range L Parameter EN *Stresses above those listed under “Absolute Maximum Rating” may cause permanent damage to the device. These are stress ratings only; functional operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. A M IC C O M C O N FI D *Device is ESD sensitive. Use appropriate ESD precautions. HBM (Human Body Mode) is tested under MIL-STD-883F Method 3015.7. MM (Machine Mode) is tested under JEDEC EIA/JESD22-A115-A. *Device is Moisture Sensitivity Level III (MSL 3). Jul., 2011, v1.3 9 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 8. Electrical Specifications (Ta=25℃, VDD=3.3V, data rate= 2Mbps, FXTAL =16MHz, with Matching Network and low pass filter, On Chip Regulator = 1.8V, unless otherwise noted.) Parameter Description Minimum Typical Maximum Unit 85 °C V uA uA mA General -40 FI D Current Consumption Phase Locked Loop N X’TAL Start-up Time (2*) X’TAL Frequency (FXTAL) VCO Operation Frequency PLL Settling Time (4*) C O O IC Sensitivity @BER=0.001 Sensitivity @BER=0.001 IF Frequency (FIF) A M Interference (7*) Maximum Operating Input Power Spurious Emission (5*) RSSI Range RX Settling Time 300 , 8, 12, 16 (3*) 6 2483.5 0 1 2 500 40 mA mA mA mA mA mA mA us MHz MHz ms 30 @Loop BW =200 KHz C Receiver 3.6 9.8 17.0 16.2 21 15.7 13.7 13.3 30MHz~1GHz 1GHz~12.75GHz 1.8GHz~ 1.9GHz 5.15GHz~ 5.3GHz M TX Power Control Range Out Band Spurious Emission (5*) 3.3 1.5(1*) 300(1*) 2.9 2400 @Loop BW = 200 KHz Transmitter Data rate Frequency Deviation TX Settling Time (6*) 2.0 L Regulator supply input Sleep Mode Idle Mode (Regulator on) Standby Mode (XOSC on, Clock generator on) PLL Mode RX Mode (2Mbps) RX Mode (1 Mbps) TX Mode (@3dBm output) TX Mode (@0dBm output) TX Mode (@-10dBm output) TX Mode (@-20dBm output) TI A Supply Voltage (VDD) EN Operating Temperature -36 -30 -47 -47 2 dBm dBm Mbps KHz ms 2Mbps 1Mbps -90 -92 2 dBm dBm MHz Co-Channel (C/I0) 1 Adjacent Channel (C/I 1) 2nd Adjacent Channel (C/I2) 3rd Adjacent Channel (C/I3) Image (C/IIM) @RF input (BER=0.1%) 30MHz~1GHz 11 2 -18 -28 -12 dB dB dB dB dB dBm dBm st 1GHz~12.75GHz @RF input @Loop BW = 200 KHz 3 -57 -47 -50 -100 40 dBm ms 500 1.23 1.8 ms V V Regulator Regulator settling time (8*) Band-gap reference voltage Regulator output voltage Jul., 2011, v1.3 10 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver Digital IO DC characteristics High Level Input Voltage (VIH) Low Level Input Voltage (VIL) High Level Output Voltage (VOH) Low Level Output Voltage (VOL) @IOH= -0.5mA @IOL= 0.5mA 0.8*VDD 0 VDD-0.4 0 VDD 0.2*VDD VDD 0.4 V V V V A M IC C O M C O N FI D EN TI A L Note 1: When digital I/O pins are configured as input, those pins shall NOT be floating but pull either high or low (SCS shall be pulled high only); otherwise, more leakage current will be induced in all operation modes. Note 2: Refer to Delay Register II (18h) to set up crystal settling delay. Note 3: If 6MHz external crystal is selected, A7125 only supports 1Mbps data rate. Note 4: Refer to Delay Register I (17h) to set up PDL (PLL settling delay). Note 5: With external RF filter that provides minimum 17dB of attenuation in the band: 30MHz ~ 2GHz and 3GHz ~12.75GHz. Note 6: Refer to Delay Register I (17h) to set up TDL delay. Note 7: The power level of wanted signal is set at sensitivity +3dB. The modulation data for wanted signal and interferer are PN9 and PN15, respectively. Channel spacing is 2MHz. Note 8: When VDD < 2.1V and temperature < -30 degree C, the regulator settling time will arise up to 20ms. Jul., 2011, v1.3 11 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 9. Control Register A7125 has totally built-in 57 control registers that cover all radio control. MCU can access those control registers via 3-wire or 4-wire SPI (Support max. SPI data rate up to 10 Mbps). User can refer to chapter 10 for details of SPI bus. A7125 is simply controlled by registers and outputs its status to MCU by GIO1 and GIO2 pins. 9.1 Control Register Table Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 W R W R RESETN DDPC DDPC RESETN FECF ARSSI ARSSI RESETN CRCF AIF AIF RESETN CER DFCD CD RESETN XER WWSE WWSE RESETN PLLER FMT FMT RESETN TRSR FMS FMS RESETN TRER ADCM ADCM R/W - - - VCC VBC VDC FBC RSSC W FEP7 FEP6 FEP5 FEP4 FEP3 FEP2 FEP1 FEP0 W FPM1 FPM0 PSA5 PSA4 PSA3 PSA2 PSA1 PSA0 R/W FIFO7 FIFO6 FIFO5 FIFO4 FIFO3 FIFO2 FIFO1 FIFO0 R/W ID7 ID6 ID5 ID4 ID3 ID2 ID1 ID0 W R WWS_SL7 - WWS_SL6 WWS_SL5 WWS_SL4 WWS_SL3 WWS_SL2 WWS_SL1 WWS_SL0 RCOC5 RCOC4 RCOC3 RCOC2 RCOC1 RCOC0 W WWS_SL9 WWS_SL8 WWS_AC5 WWS_AC4 WWS_AC3 WWS_AC2 WWS_AC1 WWS_AC0 W BBCKS1 BBCKS0 W ECKOE CKOS3 W - W - W R R/W A M Jul., 2011, v1.3 TI A EN FI D N - RCOSC_E TSEL TWWS_E CKOS2 CKOS1 CKOS0 CKOI CKOE SCKI - GIO1S3 GIOS2 GIO1S1 GIO1S0 GIO1I GIO1OE - GIO2S3 GIO2S2 GIO2S1 GIO2S0 GIO2I GIO2OE SDR1 SDR1 SDR0 SDR0 GRC3 GRC3 GRC1 GRC2 GRC1 GRC1 GRC0 GRC0 CGS - XS - CHN7 CHN6 CHN5 CHN4 CHN3 CHN2 CHN1 CHN0 CHR0 CHR0 BIP1 IP1 BFP9 AC9-FP9 BFP1 AC1-FP1 IP8 BIP8 BIP0 IP0 BFP8 AC8-FP8 BFP0 AC0-FP0 O M C O - DBL DBL BIP7 IP7 BFP15 -FP15 BFP7 AC7-FP7 C W R W R W R W R - L R/W IC Address / Name 00h Mode 01h Mode control 02h Calc 03h FIFO I 04h FIFO II 05h FIFO Data 06h ID Data 07h RC OSC I 08h RC OSC II 09h RC OSC III 0Ah CKO Pin 0Bh GIO1 Pin I 0Ch GIO2 Pin II 0Dh Data Rate Clock 0Eh PLL I 0Fh PLL II 10h PLL III 11h PLL IV 12h PLL V 13h Channel Group I 14h Channel Group II 15h TX I 16h TX II 17h Delay I 18h Delay II 19h RX 1Ah RX Gain I RRC1 RRC0 CHR3 CHR2 CHR1 RRC1 RRC0 CHR3 CHR2 CHR1 BIP6 BIP5 BIP4 BIP3 BIP2 IP6 IP5 IP4 IP3 IP2 BFP14 BFP13 BFP12 BFP11 BFP10 AC14-FP14 AC13-FP13 AC12-FP12 AC11-FP11 AC10-FP10 BFP6 BFP5 BFP4 BFP3 BFP2 AC6-FP6 AC5-FP5 AC4-FP4 AC3-FP3 AC2-FP2 R/W CHGL7 CHGL6 CHGL5 CHGL4 CHGL3 CHGL2 CHGL1 CHGL0 R/W CHGH7 CHGH6 CHGH5 CHGH4 CHGH3 CHGH2 CHGH1 CHGH0 W SDMS TMDE TXDI TME - FDP2 FDP1 FDP0 W FD7 FD6 FD5 FD4 FD3 FD2 FD1 FD0 W EOPDS DPR1 DPR0 TDL1 TDL0 PDL2 PDL1 PDL0 W WSEL2 WSEL1 WSEL0 RSSC_D1 RSSC_D0 RS_DLY2 RS_DLY1 RS_DLY0 W - RXSM1 RXSM0 FC RXDI DMG RAW ULS R/W MVGS MRHL IGS MGS1 MGS0 LGS2 LGS1 LGS0 12 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver RH7 RH6 RH5 RH4 RH3 RH2 RH1 RH0 W RL7 RL6 RL5 RL4 RL3 RL2 RL1 RL0 W AVSEL1 AVSEL0 MVSEL1 MVSEL0 MHC LHC1 LHC0 AGCE W R RTH7 ADC7 RTH6 ADC6 RTH5 ADC5 RTH4 ADC4 RTH3 ADC3 RTH2 ADC2 RTH1 ADC1 RTH0 ADC0 W RSM1 RSM0 RADC1 RADC0 FSARS XADS RSS CDM W - - WHTS FECS CRCS IDL PML1 PML0 W - DCL2 DCL1 DCL0 ETH1 ETH0 PMD1 PMD0 W - WS6 WS5 WS4 WS3 WS2 WS1 WS0 W R - - - MFBS FBCF MFB3 FB3 MFB2 FB2 MFB1 FB1 MFB0 FB0 R - - - FCD4 W - - VCCS MVCS R - - - VCCF W DDC1 DDC0 MDAGS R - - - W MDAG7 MDAG6 MDAG5 R ADAG7 ADAG6 ADAG5 W DEVS3 DEVS2 R DEVA7 W Jul., 2011, v1.3 TI A FCD1 FCD0 VCOC3 VCOC2 VCOC1 VCOC0 VCB3 VCB2 VCB1 VCB0 - MVBS MVB2 MVB1 MVB0 - VBCF VB2 VB1 VB0 MDAG4 MDAG3 MDAG2 MDAG1 MDAG0 N EN FCD2 ADAG4 ADAG3 ADAG2 ADAG1 ADAG0 DEVS1 DEVS0 DAMR_M VMTE_M VMS_M MSEL DEVA6 DEVA5 DEVA4 DEVA3 DEVA2 DEVA1 DEVA0 MVDS MDEV6 MDEV5 MDEV4 MDEV3 MDEV2 MDEV1 MDEV0 R ADEV7 ADEV6 ADEV5 ADEV4 ADEV3 ADEV2 ADEV1 ADEV0 W VMG7 VMG5 VMG4 VMG3 VMG2 VMG1 VMG0 - DEVFD2 DEVFD1 DEVFD0 DEVD2 DEVD1 DEVD0 RGS - RGV1 - RGV0 - QDS BDF BVT2 - BVT1 - BVT0 - BD_E - W - - TXCS PAC1 PAC0 TBG2 TBG1 TBG0 W DMT DCM1 DCM0 MLP1 MLP0 SLF2 SLF1 SLF0 W DCV7 DCV6 DCV5 DCV4 DCV3 DCV2 DCV1 DCV0 W CPM3 CPM2 CPM1 CPM0 CPT3 CPT2 CPT1 CPT0 W CPTX3 CPTX2 CPTX1 CPTX0 CPRX3 CPRX2 CPRX1 CPRX0 W - - - - DBD XCC XCP1 XCP0 W - CPS PRRC1 PRRC0 PRIC1 PRIC0 SDPW NSDO W - - - TLB1 TLB0 RLB1 RLB0 VCBS W OLM VTBS CPH CPCS - RFT2 RFT1 RFT0 C O M VMG6 O C - W R FI D FCD3 W A M 2Fh Rx DEM test II 30h Charge Pump Current I 31h Charge Pump Current II 32h Crystal test 33h PLL test 34h VCO test 35h RF Analog test L W IC 1Bh RX Gain II 1Ch RX Gain III 1Dh RX Gain IV 1Eh RSSI Threshold 1Fh ADC Control 20h Code I 21h Code II 22h Code III 23h IF Calibration I 24h IF Calibration II 25h VCO current Calibration 26h VCO band Calibration I 27h VCO band Calibration II 28h VCO deviation Calibration I 29h VCO deviation Calibration II 2Ah VCO deviation Calibration III 2Bh VCO modulation Delay 2Ch Battery detect 2Dh TX test 2Eh Rx DEM test I 13 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver IGFI1 IGFI0 IGFQ2 IGFQ1 IGFQ0 IFBC LIMC CHI2 CHI1 CHI0 CHD3 CHD2 CHD1 CHD0 VTRB2 VTRB1 VTRB0 VMRB3 VMRB2 VMRB1 VMRB0 A M IC C O M C O N FI D EN TI A L 36h W IGFI2 IFAT 37h W CHI3 Channel Select 38h W VTRB3 VRB Legend: - = unimplemented Jul., 2011, v1.3 14 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 9.2 Control Register Description 9.2.1 Mode Register (Address: 00h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name R W -RESETN -- FECF RESETN -- CRCF RESETN -- CER RESETN -- XER RESETN -- PLLER RESETN -- TRSR RESETN -- TRER RESETN -- Reset RESETN: Write to this register by 0x00 to issue reset command, then it is auto clear L FECF: FEC flag. (FECF is read only, it is updated for each valid packet.) [0]: FEC pass. [1]: FEC error. TI A CRCF: CRC flag. (CRCF is read only, it is updated for each valid packet.) [0]: CRC pass. [1]: CRC error. CER: RF chip enable status. [0]: RF chip is disabled. [1]: RF chip is enabled. EN XER: Internal crystal oscillator enable status. [0]: Crystal oscillator is disabled. [1]: Crystal oscillator is enabled. PLLE: PLL enable status. [0]: PLL is disabled. [1]: PLL is enabled. TRSR: TRX Status Register. [0]: RX state. [1]: TX state. Serviceable if TRER=1 (TRX is enable). Bit R/W Bit 7 Name R W DDPC DDPC 0 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 ARSSI ARSSI 0 AIF AIF 0 CD DFCD 0 WWSE WWSE 0 FMT FMT 0 FMS FMS 0 ADCM ADCM 0 M Reset C O 9.2.2 Mode Control Register (Address: 01h) N FI D TRER: TRX state enable status. [0]: TRX is disabled. [1]: TRX is enabled. O DDPC (Direct mode data pin control): Direct mode modem data can be accessed via SDIO pin when this register is enabled. [0]: Disable. [1]: Enable. C ARSSI: Auto RSSI measurement while entering RX mode. [0]: Disable. [1]: Enable. IC AIF (Auto IF Offset): RF LO frequency will auto offset one IF frequency while entering RX mode. [0]: Disable. [1]: Enable. A M CD / DFCD: DFCD (Data Filter by CD): The received packet will be filtered out if Carrier Detector signal is inactive. [0]: Disable. [1]: Enable. CD (Read): Carrier detector signal. [0]: Input power below threshold. [1]: Input power above threshold. WWSE: Reserved for internal usage only. Shall be set to [0]. FMT: Reserved for internal usage only. Shall be set to [0]. FMS: Direct/FIFO mode select. [0]: Direct mode. [1]: FIFO mode. ADCM: ADC measurement enable (Auto clear when done). [0]: Disable measurement or measurement finished. [1]: Enable measurement. ADCM A7125 @ Standby mode [0] Disable ADC [1] Measure temperature Jul., 2011, v1.3 A7125 @ RX mode Disable ADC Measure RSSI, carrier detect 15 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver Refer to chapter 17 for details. 9.2.3 Calibration Control Register (Address: 02h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset R/W --- --- --- VCC 0 VBC 0 VDC 0 FBC 0 RSSC 0 VCC: VCO Current calibration enable (Auto clear when done). [0]: Disable. [1]: Enable. TI A L VBC: VCO Bank calibration enable (Auto clear when done). [0]: Disable. [1]: Enable. VDC: VCO Deviation calibration enable (Auto clear when done). [0]: Disable. [1]: Enable. FBC: IF Filter Bank calibration enable (Auto clear when done). [0]: Disable. [1]: Enable. EN RSSC: RSSI calibration enable (Auto clear when done). [0]: Disable. [1]: Enable. FI D 9.2.4 FIFO Register I (Address: 03h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W FEP7 0 FEP6 0 FEP5 1 FEP4 1 FEP3 1 FEP2 1 FEP1 1 FEP0 1 C O N FEP [7:0]: FIFO End Pointer for TX FIFO and Rx FIFO. Refer to chapter 16 for details. 9.2.5 FIFO Register II (Address: 04h) R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W FPM1 0 FPM0 1 PSA5 0 PSA4 0 PSA3 0 PSA2 0 PSA1 0 PSA0 0 M Bit FPM [1:0]: FIFO Pointer Margin C O PSA [5:0]: Used for Segment FIFO. Refer to chapter 16 for details. IC 9.2.6 FIFO DATA Register (Address: 05h) R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 R/W FIFO7 0 FIFO6 0 FIFO5 0 FIFO4 0 FIFO3 0 FIFO2 0 FIFO1 0 FIFO0 0 A M Bit Name Reset FIFO [7:0]: FIFO data. TX FIFO (Write only) and RX FIFO (Read only). TX FIFO and RX FIFO share the same address (05h). Refer to chapter 16 for details. 9.2.7 ID DATA Register (Address: 06h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset R/W ID7 0 ID6 0 ID5 0 ID4 0 ID3 0 ID2 0 ID1 0 ID0 0 ID [7:0]: ID data. Once this address is accessed, ID Data is input/output in sequence corresponding to Write or Read. Refer to section 10.6 for details. Jul., 2011, v1.3 16 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 9.2.8 RC OSC Register I (Address: 07h) Bit R/W Name R W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 RCOC5 RCOC4 RCOC3 RCOC2 RCOC1 RCOC0 WWS_SL7 WWS_SL6 WWS_SL5 WWS_SL4 WWS_SL3 WWS_SL2 WWS_SL1 WWS_SL0 Reset 0 0 0 0 0 0 0 0 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 RCOC [5:0]: Reserved for internal usage only. R/W W Bit 7 Bit 6 WWS_SL9 WWS_SL8 WWS_AC5 WWS_AC4 WWS_AC3 WWS_AC2 WWS_AC1 WWS_AC0 0 0 0 0 0 Bit 4 WWS_AC [5:0]: Reserved for internal usage only. Bit R/W Bit 7 Bit 6 Bit 5 Name Reset W BBCKS1 0 BBCKS0 0 --- Bit 3 FI D 9.2.10 RC OSC Register III (Address: 09h) 0 EN WWS_SL [9:0]: Reserved for internal usage only. TI A Bit Name Reset L 9.2.9 RC OSC Register II (Address: 08h) --- --- 0 1 Bit 2 Bit 1 Bit 0 RCOSC_E TSEL 0 TWWS_E 1 1 C O RCOSC_E: Reserved for internal usage only. N BBCKS [1:0]: Clock select for digital block. Recommend BBCKS = [00]. [00]: FSYCK / 8. [01]: FSYCK / 16. [10]: FSYCK / 32. [11]: FSYCK / 64. FSYCK is A7125’s System clock = 64MHz. TSEL: Reserved for internal usage only. TWWS_E: Reserved for internal usage only. M 9.2.11 CKO Pin Control Register (Address: 0Ah) R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 W ECKOE 1 CKOS3 0 CKOS2 1 CKOS1 1 CKOS0 1 CKOI 0 CKOE 1 SCKI 0 Bit 2 Bit 1 Bit 0 O Bit Name Reset C ECKOE: External Clock Output Enable for CKOS [3:0]= [0100] ~ [0111]. [0]: Disable. [1]: Enable. A M IC CKOS [3:0]: CKO pin output select. [0000]: DCK (TX data clock) in TX mode, RCK (RX recovery clock) in RX mode. [0001]: DCK (TX data clock) in TX mode, RCK (RX recovery clock) in RX mode. [0010]: FPF (FIFO pointer flag). [0011]: EOVBC, EOFBC, EOADC, EOVCC, OKADC (Internal usage only). [0100]: External clock output= FSYCK / 8. [0101]: External clock output / 2= FSYCK / 16. [0110]: External clock output / 4= FSYCK / 32. [0111]: External clock output / 8= FSYCK / 64. [1xxx]: Reserved. CKOI: CKO pin output signal invert. [0]: Non-inverted output. [1]: Inverted output. CKOE: CKO pin Output Enable. [0]: High Z. [1]: Enable. SCKI: SPI clock input invert. [0]: Non-inverted input. [1]: Inverted input. 9.2.12 GIO1 Pin Control Register (Address: 0Bh) Bit Jul., 2011, v1.3 R/W Bit 7 Bit 6 Bit 5 Bit 4 17 Bit 3 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver --- GIO1S3 0 GIO1S2 0 GIO1S [3:0]: GIO1 pin function select. GIO1S [3:0] TX state RX state [0000] WTR (Wait until TX or RX finished) [0001] (Reserved.) FSYNC(frame sync) [0010] TMEO(TX modulation enable) CD(carrier detect) [0011] Preamble Detect Output (PMDO) [0100] (Reserved.) [0101] In phase demodulator input(DMII) [0110] SDO ( 4 wires SPI data out) [0111] TRXD In/Out ( Direct mode ) [1000] RXD ( Direct mode ) [1001] TXD ( Direct mode ) [1010] In phase demodulator external input(EXDI0) [1011] External FSYNC input in RX direct mode [1100] EOP (End Of Packet) [1101]~[1111] Inhibited GIO1OE: GIO1pin output enable. [0]: High Z. [1]: Enable. 9.2.13 GIO2 Pin Control Register (Address: 0Ch) Bit 7 Bit 6 Name Reset W --- --- Bit 5 GIO2S3 0 GIO1S0 0 GIO1I 0 GIO1OE 1 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 GIO2S2 1 GIO2S1 0 GIO2S0 0 GIO2I 0 GIO2OE 1 N R/W C O Bit FI D GIO1I: GIO1 pin output signal invert. [0]: Non-inverted output. [1]: Inverted output. GIO1S1 0 L --- TI A W EN Name Reset A M IC C O M GIO2S [3:0]: GIO2 pin function select. GIO2S TX state RX state [0000] WTR (Wait until TX or RX finished) [0001] PASW (Output Signal to FSYNC(frame sync) switch off external PA ) * [0010] TMEO(TX modulation enable) CD(carrier detect) [0011] Preamble Detect Output (PMDO) [0100] (Reserved.) [0101] Quadrature phase demodulator input(DMIQ) [0110] SDO ( 4 wires SPI data out ) [0111] TRXD In/Out ( Direct mode ) [1000] RXD ( Direct mode ) [1001] TXD ( Direct mode ) [1010] Quadrature phase demodulator external input(EXDI1) [1011] External FSYNC input in RX direct mode [1100] EOPD (End Of Packet Delay) * [1101]~[1111] Inhibited * Refer to Section 14.3 for details. GIO2I: GIO2 pin output signal invert. [0]: Non-inverted output. [1]: Inverted output. GIO2OE: GIO2 pin Output Enable. [0]: High Z. [1]: Enable. In TX Mode. Timing diagram among WTR, EOP and EOPD are illustrated below when EOPDS = 1. However, if EOPDS = 0, T2~T4 is around 1 us only. Jul., 2011, v1.3 18 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver SPI (SCS,SCK,SDIO) Next Instruction No Command Required TX-Strobe PLL Mode (dummy bits) PDL+TDL RF Port Auto Back PLL Mode Preamble + ID Code + Payload + CRC GIO1 Pin - WTR (GIO1S[3:0]=0000) W L GIO1 Pin - EOP (GIO1S[3:0]=1100) GIO2 Pin - EOPD (GIO2S = 1100) T0 T2 T1 T3 T4 EN < 1us TI A 20 us CRC Enable 4 bytes (default) 4 bytes (recommend) Disable Payload (Byte) 64 32 16 W (us) 3.5 11.5 15.5 64 32 16 11.5 19.5 3.5 FI D ID 4 bytes (recommend) C O N Preamble 4 bytes (default) SPI (SCS,SCK,SDIO) M In RX Mode. WTR goes low when last bit is recieved. Compared to TX mode, there are no dummy bits in RX mode. Hence, user can monitor the falling edge of WTR (if EOPDS=1) to turn on RX mode ahead of tunning on counterpart to TX mode for stable transmission timeslot. TX-Strobe PLL Mode O Preamble + ID Code + Payload + CRC IC GIO1 Pin - WTR (GIO1S[3:0]=0000) Auto Back PLL Mode PDL+TDL C RF Port Next Instruction No Command Required A M GIO1 Pin - EOP (GIO1S[3:0]=1100) GIO2 Pin - EOPD (GIO2S = 1100) T0 T2 T1 < 1us 9.2.14 Data Rate Clock Register (Address: 0Dh) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name R W SDR1 SDR1 0 SDR0 SDR0 0 GRC3 GRC3 0 GRC2 GRC2 1 GRC1 GRC1 1 GRC0 GRC0 1 -CGS 1 -XS 1 Reset SDR [1:0]: Data rate setting. Jul., 2011, v1.3 19 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver Data Rate EN GRC [3:0]: Generator Reference Counter Due to A7125 supports different external crystals, GRC is used to get 2 MHz Clock Generator Reference (FCGR) for internal usage. . Clock Generation External Crystal (FXREF) GRC [3:0] Reference (CGR) 16 MHz Must be 2 MHz [0111] 12 MHz Must be 2 MHz [0101] 8 MHz Must be 2 MHz [0011] 6 MHz Must be 2 MHz [0010] Refer to chapter 13 for details. A M IC C O M C O N FI D CGS: Clock generator enable. Shall be set to [1]. [0]: Disable. [1]: Enable. XS: Crystal oscillator select. Recommend XS = [1] [0]: Use external clock. [1]: Use external crystal. L 2 Mbps 1 Mbps Reserved Reserved TI A FSYCK (Internal system clock) [00] 64 MHz [01] 64 MHz [10] 64 MHz [11] 64 MHz Refer to chapter 13 for details. SDR [1:0] Jul., 2011, v1.3 20 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 9.2.15 PLL Register I (Address: 0Eh) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset R/W CHN7 0 CHN6 0 CHN5 0 CHN4 0 CHN3 0 CHN2 0 CHN1 0 CHN0 0 CHN [7:0]: RF LO channel number. Change CHN to do frequency hopping. Refer to chapter 14 for details. R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Name R W DBL DBL 0 RRC1 RRC1 0 RRC0 RRC0 1 CHR3 CHR3 0 CHR2 CHR2 1 CHR1 CHR1 1 Reset RRC [1:0]: RF PLL reference counter setting. Refer to chapter 14 for details. IP8 BIP8 0 Bit R/W Bit 7 Bit 6 Bit 5 Bit 3 Bit 2 Bit 1 Bit 0 Name R W IP7 BIP7 1 IP6 BIP6 0 IP5 BIP5 0 IP4 BIP4 1 IP3 BIP3 0 IP2 BIP2 1 IP1 BIP1 1 IP0 BIP0 0 Bit 5 Bit 4 Bit 3 Bit 2 C O Bit 4 N 9.2.17 PLL Register III (Address: 10h) FI D CHR [3:0]: PLL channel step setting. Reset Bit 0 EN DBL: Crystal frequency doubler enable. [0]: Disable. FXREF = FXTAL. [1]: Enable. FXREF =2 * FXTAL. Bit 1 CHR0 CHR0 1 TI A Bit L 9.2.16 PLL Register II (Address: 0Fh) BIP [8:0]: LO base frequency integer part setting. BIP [8:0] are from address (0Fh) and (10h), O Refer to chapter 14 for details. M IP [8:0]: LO frequency integer part value. IP [8:0] are from address (0Fh) and (10h), Bit R/W Bit 7 R W --/FP15 IC Name C 9.2.18 PLL Register IV (Address: 11h) A M Reset BFP15 0 Bit 6 AC14/FP14 AC13/FP13 AC12/P12 AC11/ FP11 AC10/FP10 BFP14 0 Bit 1 Bit 0 AC9/FP9 AC8/FP8 BFP13 0 BFP12 0 BFP11 0 BFP10 0 BFP9 0 BFP8 0 9.2.19 PLL Register V (Address: 12h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name R W AC7/FP7 AC6/FP6 AC5/FP5 AC4/FP4 AC3/FP3 AC2/FP2 AC1/FP1 AC0/FP0 BFP7 0 BFP6 0 BFP5 0 BFP4 0 BFP3 0 BFP2 1 BFP1 0 BFP0 0 Bit 3 Bit 2 Bit 1 Bit 0 Reset BFP [15:0]: LO base frequency fractional part setting. BFP [15:0] are from address (11h) and (12h), AC [14:0] (Read): Frequency compensation value if AFC (19h) =1. FP [15:0] (Read): LO frequency fractional part setting. Refer to chapter 14 for details. 9.2.20 Channel Group Register I (Address: 13h) Bit Jul., 2011, v1.3 R/W Bit 7 Bit 6 Bit 5 Bit 4 21 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver Name Reset R/W CHGL7 0 CHGL6 0 CHGL5 1 CHGL4 1 CHGL3 1 CHGL2 1 CHGL1 0 CHGL0 0 CHGL [7:0]: PLL channel group low boundary setting. Refer to chapter 15 for details. 9.2.21 Channel Group Register II (Address: 14h) R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 R/W CHGH7 0 CHGH6 1 CHGH5 1 CHGH4 1 CHGH3 1 CHGH2 0 CHGH1 0 CHGH0 0 TI A CHGH [7:0]: PLL channel group high boundary setting. Refer to chapter 15 for details. L Bit Name Reset 9.2.22 TX Register I (Address: 15h) R/W Bit 7 Bit 6 Bit 5 Name Reset W SDMS 1 TMDE 1 TXDI 0 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 TME 1 --- FDP2 1 FDP1 1 FDP0 0 N Bit FI D EN PLL frequency is divided into 3 groups: Channel Group1 0 ~ CHGL-1 Group2 CHGL ~ CHGH-1 Group3 CHGH ~ 255 C O SDMS: Reserved for internal usage only. Shall be set to [1]. TMDE: TX data VCO modulation enable. [0]: Disable. [1]: Enable. TME: TX modulation enable. [0]: Disable. [1]: Enable. M TXDI: TX data invert. Recommend TXDI = [0]. [0]: Non-invert. [1]: Invert. O FDP [2:0]: Frequency deviation power setting. Refer to control register (16h). Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 FD7 1 FD6 1 FD5 0 FD4 0 FD3 0 FD2 0 FD1 0 FD0 0 R/W IC Bit C 9.2.23 TX Register II (Address: 16h) Name Reset W A M FD [7:0]: Frequency deviation setting. Frequency deviation: (FDP [2:0] + 1) 26 FDEV= FPFD * 127 * (FD [7:0] + 1) * 2 /2 . Recommend FDEV = 500 KHz. Jul., 2011, v1.3 22 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 9.2.24 Delay Register I (Address: 17h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W EOPDS 0 DPR1 0 DPR0 0 TDL1 1 TDL0 0 PDL2 0 PDL1 1 PDL0 0 L EOPDS: End Of Packet Delay Select. [0]: 1us. [1]: 20 us. Recommend EOPDS = [0] in external PA free requirement. Recommend EOPDS = [1] in external PA application. See below timing diagram. TI A G IO 1 P in (W T R ) EOPDS=1 (2 0 u s ) EN T X S tro b e C m d G IO 2 P in (E O P D ) T im e Z o n e to ind ic a te M C U to sw itch o ff e xt P A DPR [1:0]: Delay scale. Recommend DPR = [00]. FI D TDL [1:0]: Delay for TRX settling from WPLL to TX/RX. Delay= 20 * (TDL [1:0] + 1) * (DPR [1:0] + 1) us. DPR [1:0] TDL [1:0] WPLL to TX 00 00 20 us 00 01 40 us 00 10 60 us 00 11 80 us Note C O N Recommend C O M PDL [2:0]: Delay for TX settling from PLL to WPLL. Delay= 10+20 * (PDL [2:0] + 1) * (DPR [1:0] + 1) us. DPR [1:0] PDL [2:0] PLL to WPLL (LO freq. fixed) 00 000 10 us 00 001 10 us 00 010 10 us 00 011 10 us PLL M ode IC G IO 1 P in (W T R ) PLL to WPLL (LO freq changed) 30 us 50 us 70 us 90 us Note Recommend TX M ode T X S tro be R F O P in A M P a ck e t PDL TDL 9.2.25 Delay Register II (Address: 18h) Bit R/W Bit 7 Bit 6 Bit 5 Name Reset W WSEL2 0 WSEL1 1 WSEL0 0 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 RSSC_D1 RSSC_D0 RS_DLY2 RS_DLY1 RS_DLY0 0 0 0 0 1 WSEL [2:0]: XTAL settling delay setting (200us ~ 2.5ms). Recommend WSEL = [011]. [000]: 200us. [001]: 400us. [010]: 800us, [011]: 600us. [100]: 1ms. [101]: 1.5ms. [110]: 2ms. [111]: 2.5ms. Jul., 2011, v1.3 23 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver C ry s ta l O sc illa to r Id le m o de T X o r R X m od e W SEL 30 0 us G IO 1 P in (W T R ) P a ck e t ( P r e a m b le + ID + P a ylo a d ) PD L TD L TI A RSSC_D [1:0]: RSSI calibration switching time (10us ~ 40us). Recommend RSSC_D = [00]. [00]: 10us. [01]: 20us. [10]: 30us. [11]: 40us. L R F O P in 9.2.26 RX Register (Address: 19h) R/W Bit 7 Bit 6 Bit 5 Bit 4 Name Reset W --- RXSM1 1 RXSM0 0 FC 0 Bit 3 Bit 2 Bit 1 Bit 0 RXDI 0 DMG 0 RAW 1 ULS 0 FI D Bit EN RS_DLY [2:0]: RSSI measurement delay (10us ~ 80us). Recommend RS_DLY = [001]. [000]: 10us. [001]: 20us. [010]: 30us. [011]: 40us. [100]: 50us. [101]: 60us. [110]: 70us. [111]: 80us. RXSM0: Reserved for internal usage only. Shall be set to [1]. C O AFC: Auto Frequency compensation. [0]: Disable. [1]: Enable. Refer to section 14.4 for details. N RXSM1: Reserved for internal usage only. Shall be set to [1]. RXDI: RX data output invert. Recommend RXDI = [0]. [0]: Non-inverted output. [1]: Inverted output. DMG: Reserved for internal usage only. Shall be set to [0]. M RAW: Reserved for internal usage only. Shall be set to [1]. C O ULS: RX Up/Low side band select. [0]: Up side band, [1]: Low side band. Refer to section 14.2 for details. 9.2.27 RX Gain Register I (Address: 1Ah) R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 R/W MVGS 0 MRHL 0 IGS 0 MGS1 0 MGS0 0 LGS2 0 LGS1 0 LGS0 0 IC Bit A M Name Reset MVGS: Manual VGA setting. [0]: Auto. [1]: Manual. MRHL: Manual RH, RL setting. [0]: Auto. [1]: Manual. IGS: Reserved for internal usage only. Shall be set to [1]. MGS [1:0]: Mixer gain attenuation select. Recommend MGS = [00]. [00]: 0dB. [01]: -6dB. [10]: -12dB. [11]: -18dB. LGS [2:0]: LNA gain attenuation select. Recommend LGS = [000]. [000]: 0dB. [001]: -6dB. [010]: -12dB. [011]: -18dB. [1XX]: -24dB. 9.2.28 RX Gain Register II (Address: 1Bh) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset R/W RH7 1 RH 6 0 RH5 0 RH4 0 RH3 0 RH2 0 RH1 0 RH0 0 Jul., 2011, v1.3 24 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver RH [7:0]: AGC calibration high threshold. 9.2.29 RX Gain Register III (Address: 1Ch) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset R/W RL7 1 RL6 0 RL5 0 RL4 0 RL3 0 RL2 0 RL1 0 RL0 0 Bit 2 Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Name Reset W AVSEL1 0 AVSEL0 1 MVSEL1 0 MVSEL0 0 MHC 1 Bit 1 TI A 9.2.30 RX Gain Register IV (Address: 1Dh) L RL [7:0]: AGC calibration low threshold. LHC1 1 LHC0 1 Bit 0 AGCE 0 EN AVSEL [1:0]: ADC average times (AGC mode). Recommend AVSEL = [11]. [00]: No average. [01]: Average 2 times. [10]: Average 4 times. [11]: Average 8 times. MVSEL [1:0]: ADC average times (VCO calibration and RSSI measurement mode). Recommend MVSEL = [01]. [00]: Average 8 times. [01]: Average 16 times. [10]: Average 32 times. [11]: Average 64 times. FI D MHC: Reserved for internal usage only. Shall be set to [0]. LHC: Reserved for internal usage only. Shall be set to [01]. N AGCE: AGC active enable. [0]: End AGC. [1]: AGC active. Bit R/W Bit 7 Name R W ADC7 RTH7 1 Reset C O 9.2.31 RSSI Threshold Register (Address: 1Eh) Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 ADC6 RTH6 0 ADC5 RTH5 0 ADC4 RTH4 1 ADC3 RTH3 0 ADC2 RTH2 0 ADC1 RTH1 0 ADC0 RTH0 1 O M RTH [7:0]: Carrier detect threshold. Refer to chapter 17 for details. IC C ADC [7:0]: ADC output value of temperature, RSSI . ADC input voltage= 0.3 + 1.2 * ADC [7:0] / 256 V. Refer to chapter 17 for details. 9.2.32 ADC Control Register (Address: 1Fh) R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W RSM1 0 RSM0 1 RADC1 0 RADC0 0 FSARS 1 XADS 0 RSS 1 CDM 1 A M Bit RSM [1:0]: RSSI margin = RTH – RTL. Recommend RSM = [11]. [00]: 5. [01]: 10. [10]: 15. [11]: 20. Refer to chapter 17 for details. RADC: ADC read out average mode. [00]: No average. [01]: 1, 2, 4, 8 average mode. The average number is according to the setting of AVSEL (in RX Gain Register IV). [10]: 8, 16, 32, 64 average mode. The average number is according to the setting of MVSEL (in RX Gain Register IV). [11]: Reserved. FSARS: ADC clock select. [0]: 4MHz. [1]: 8MHz. XADS: ADC input signal select. [0]: Convert RSS signal. [1]: Reserved for internal usage. Jul., 2011, v1.3 25 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver RSS: Temperature / RSSI measurement select. [0]: Temperature. [1]: RSSI or carrier-detect measurement. CDM: RSSI measurement mode. Recommend CDM = [0]. [0]: Single mode. [1]: Continuous mode. 9.2.33 Code Register I (Address: 20h) R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W --- --- WHTS 0 FECS 0 CRCS 0 IDL 1 PML1 1 PML0 1 L Bit TI A WHTS: Data whitening (Data Encryption) select. [0]: Disable. [1]: Enable. FECS: FEC select. [0]: Disable. [1]: Enable. EN CRCS: CRC select. [0]: Disable. [1]: Enable. IDL: ID code length select. Recommend IDL= [1]. [0]: 2 bytes. [1]: 4 bytes. FI D PML [1:0]: Preamble length select. Recommend PML= [11]. [00]: 1 byte. [01]: 2 bytes. [10]: 3 bytes. [11]: 4 bytes. 9.2.34 Code Register II (Address: 21h) R/W Bit 7 Bit 6 Name Reset W --- DCL2 1 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 DCL1 1 DCL0 1 ETH1 0 ETH0 1 PMD1 1 PMD0 1 C O Bit N Refer to chapter 16 for details. DCL [2:0]: Demodulator DC estimation average mode. Refer to DCM (2Eh) for details. M DCL2: For payload average mode. Recommend DCL2 = [1]. [0]: 128 bits average. [1]: 256 bits average. O DCL1: For average and hold mode. Recommend DCL1 = [0]. [0]: 32 bits average. [1]: 64 bits average. C DCL0: Preamble detect delay. Count from preamble detected signal. Recommend DCL0 = [1]. [0]: 4 bits for DCL1=0, 8 bits for DCL1=1. [1]: 8 bits for DCL1=0, 16 bits for DCL1=1. IC ETH [1:0]: ID code error tolerance. Recommend ETH = [01]. [00]: 0 bit, [01]: 1 bit. [10]: 2 bit. [11]: 3 bit. A M PMD [1:0]: Preamble pattern detection length. Recommend PMD = [10]. [00]: 0bit. [01]: 4bits. [10]: 8bits. [11]: 16bits. Refer to chapter 16 for details. 9.2.35 Code Register III (Address: 22h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W --- WS6 0 WS5 1 WS4 0 WS3 1 WS2 0 WS1 1 WS0 0 WS [6:0]: Data Whitening seed setting (data encryption key). Refer to chapter 16 for details. 9.2.36 IF Calibration Register I (Address: 23h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name R -- -- -- FBCF FB3 FB2 FB1 FB0 Jul., 2011, v1.3 26 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver W Reset --- --- --- MFBS 0 MFB3 0 MFB2 1 MFB1 1 MFB0 0 MFBS: IF filter calibration value select. Recommend MFBS = [0]. [0]: Auto calibration value. [1]: Manual calibration value. MFB [3:0]: IF filter manual calibration value. FBCF: IF filter auto calibration flag. [0]: Pass. [1]: Fail. Refer to chapter 15 for details. 9.2.37 IF Calibration Register II (Address: 24h) R/W Bit 7 Bit 6 Bit 5 Bit 4 R --- --- --- FCD4 -- FCD3 -- FI D FCD [4:0]: IF filter auto calibration deviation. Bit 3 Bit 2 Bit 1 Bit 0 FCD2 -- FCD1 -- FCD0 -- EN Bit Name Reset TI A L FB [3:0]: IF filter calibration value. MFBS= 0: Auto calibration value (AFB), MFBS= 1: Manual calibration value (MFB). 9.2.38 VCO Current Calibration Register (Address: 25h) R/W Bit 7 Bit 6 Bit 5 Name R W ---- ---- -VCCS 1 Bit 3 Bit 2 Bit 1 Bit 0 VCCF MVCS 0 VCB3 VCOC3 1 VCB2 VCOC2 1 VCB1 VCOC1 0 VCB0 VCOC0 0 C O Reset Bit 4 N Bit VCCS: Reserved for internal usage only. Shall be set [0]. MVCS: VCO current calibration value select. Recommend MVCS = [0]. [0]: Auto calibration value. [1]: Manual calibration value. M VCOC [3:0]: VCO current manual calibration value. O FVCC: VCO current auto calibration flag. [0]: Pass. [1]: Fail. IC C VCB [3:0]: VCO current calibration value. MVCS= 0: Auto calibration value (AVCB). MVCS= 1: Manual calibration value (VCOC). Refer to chapter 15 for details. A M 9.2.39 VCO Bank Calibration Register I (Address: 26h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name R W -DDC1 1 -DDC0 1 -MDAGS 0 ---- VBCF MVBS 0 VB2 MVB2 1 VB1 MVB1 0 VB0 MVB0 0 Reset DDC [1:0]: VCO deviation calibration delay. Recommend DDC = [01]. Delay time = PLL delay time × ( DDC + 1 ). MDAGS: DAG calibration value select. Recommend MDAGS = [0]. [0]: Auto calibration value. [1]: Manual calibration value. MVBS: VCO bank calibration value select. Recommend MVBS = [0]. [0]: Auto calibration value. [1]: Manual calibration value. MVB [2:0]: VCO band manual calibration value. VBCF: VCO band auto calibration flag. [0]: Pass. [1]: Fail. Jul., 2011, v1.3 27 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver VB [2:0]: VCO bank calibration value. MVBS= 0: Auto calibration value (AVB). MVBS= 1: Manual calibration value (MVB). Refer to chapter 15 for details. 9.2.40 VCO Bank Calibration Register II (Address: 27h) R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name R W ADAG7 MDAG7 1 ADAG6 MDAG6 0 ADAG5 MDAG5 0 ADAG4 MDAG4 0 ADAG3 MDAG3 0 ADAG2 MDAG2 0 ADAG1 MDAG1 0 ADAG0 MDAG0 0 MDAG [7:0]: DAG manual calibration value. Recommend MDAG = [0x80]. 9.2.41 VCO Deviation Calibration Register I (Address: 28h) R/W Bit 7 Bit 6 Bit 5 Bit 4 Name R W DEVA7 DEVS3 0 DEVA6 DEVS2 1 DEVA5 DEVS1 1 DEVA4 DEVS0 1 Reset Bit 3 Bit 2 DEVA3 DEVA2 DAMR_M VMTE_M 0 0 FI D Bit EN ADAG [7:0]: DAG auto calibration value. TI A Reset L Bit Bit 1 Bit 0 DEVA1 VMS_M 0 DEVA0 MSEL 0 DEVS [3:0]: Deviation output scaling. Recommend DEVS = [0011]. N DAMR_M: DAMR manual enable. Recommend DAMR_M = [0]. [0]: Disable. [1]: Enable. C O VMTE_M: VMT manual enable. Recommend VMTE_M = [0]. [0]: Disable. [1]: Enable. VMS_M: VM manual enable. Recommend VMS_M = [0]. [0]: Disable. [1]: Enable. M MSEL: VMS, VMTE and DAMR control select. Recommend MSEL = [0]. [0]: Auto control. [1]: Manual control. C O DEVA [7:0]: Deviation output value. MVDS= 0: Auto calibration value ((ADEV / 8) × (DEVS + 1)), MVDS= 1: Manual calibration value (MDEV). 9.2.42 VCO Deviation Calibration Register II (Address: 29h) R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 R W ADEV7 MVDS 0 ADEV6 MDEV6 0 ADEV5 MDEV5 1 ADEV4 MDEV4 0 ADEV3 MDEV3 1 ADEV2 MDEV2 0 ADEV1 MDEV1 0 ADEV0 MDEV0 0 IC Bit Name A M Reset MVDS: VCO deviation calibration value select. Recommend MVDS = [0]. [0]: Auto calibration value. [1]: Manual calibration value. MDEV [6:0]: VCO deviation manual calibration value. ADEV [7:0]: VCO deviation auto calibration value. Refer to chapter 15 for details. 9.2.43 VCO Deviation Calibration Register III (Address: 2Ah) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W VMG7 1 VMG6 0 VMG5 0 VMG4 0 VMG3 0 VMG2 0 VMG1 0 VMG0 0 VMG [7:0]: Reserved for internal usage only. Shall be set to [0x80]. Jul., 2011, v1.3 28 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 9.2.44 VCO Modulation Delay Register (Address: 2Bh) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W --- --- DEVFD2 0 DEVFD1 0 DEVFD0 0 DEVD2 0 DEVD1 0 DEVD0 0 DEVFD [2:0]: Reserved for internal usage only. Shall be set to [000]. DEVD [2:0]: Reserved for internal usage only. Shall be set to [000]. R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Name R W -RGS 0 -RGV1 1 -RGV0 0 BDF QDS 0 -BVT2 0 -BVT1 1 Reset Bit 0 -BVT0 1 -BD_E 0 EN RGS: VDD_D voltage setting in Sleep mode. [0]: 3/5 * REGI. [1]: 3/4 * REGI. Bit 1 TI A Bit L 9.2.45 Battery Detect Register (Address: 2Ch) RGV [1:0]: VDD_D and VDD_A voltage setting in non-Sleep mode. Recommend RGV = [11]. [00]: 2.1V. [01]: 2.0V. [10]: 1.9V. [11]: 1.8V. FI D QDS: Reserved for internal usage only. Shall be set [1]. N BVT [2:0]: Battery voltage detect threshold. [000]: 2.0V. [001]: 2.1V. [010]: 2.2V. [011]: 2.3V. [100]: 2.4V. [101]: 2.5V. [110]: 2.6V. [111]: 2.7V. C O BD_E: Battery detect enable. [0]: Disable. [1]: Enable. It will be clear after battery detection done. BDF: Battery detect flag. [0]: Battery voltage less than threshold. [1]: Battery voltage greater than threshold. M Refer to chapter 19 for details. Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 O 9.2.46 TX test Register (Address: 2Dh) R/W Name Reset W --- TXCS 0 PAC1 1 PAC0 0 TBG2 1 TBG1 1 TBG0 1 --- C Bit TXCS: TX Current Setting. IC PAC [1:0]: PA Current Setting. A M TBG [2:0]: TX Buffer Setting. Typical Recommend setting Typical Output Power (dBm) TXCS TBG PAC TX current (mA) 3 1 7 2 21 0 1 7 0 15.7 -10 1 4 0 13.7 -20 1 0 0 13.3 Also, refer to App. Note for more setting of TX power level. 9.2.47 RX DEM test Register I (Address: 2Eh) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W DMT 0 DCM1 1 DCM0 1 MLP1 0 MLP0 0 SLF2 1 SLF1 0 SLF0 0 Jul., 2011, v1.3 29 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver DMT: Reserved for internal usage only. Shall be set to [0]. DCM [1:0]: Demodulator DC estimation mode. [00]: Fix mode (For ±10ppm crystal accuracy only). DC level is set by DCV [7:0]. [01]: Preamble hold mode. DC level is preamble average value at PMDO. [10]: Average and hold mode. DC level is the average value at PMDO with DCL0 delay. [11]: Payload average mode (For internal usage). DC level is payload data average. MLP [1:0]: Reserved for internal usage only. Shall be set to [00]. L SLF [2:0]: Reserved for internal usage only. Shall be set to [111]. Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Name Reset W DCV7 0 DCV6 1 DCV5 0 DCV4 0 DCV3 0 9.2.49 Charge Pump Current Register I (Address: 30h) R/W Bit 7 Bit 6 Bit 5 Bit 4 Name Reset W CPM3 1 CPM2 1 CPM1 1 CPM0 1 Bit 1 Bit 0 DCV2 0 DCV1 0 DCV0 0 Bit 3 Bit 2 Bit 1 Bit 0 CPT3 1 CPT2 1 CPT1 1 CPT0 1 FI D Bit Bit 2 EN DCV [7:0]: Demodulator fix mode DC value. Recommend DCV = [0x80]. TI A 9.2.48 RX DEM test Register II (Address: 2Fh) CPM [3:0]: Charge pump current setting for VM loop. Recommend CPM = [1111]. Charge pump current = (CPM + 1) / 16 mA. C O N CPT [3:0]: Charge pump current setting for VT loop. Recommend CPT = [0001]. Charge pump current = (CPT + 1) / 16 mA. 9.2.50 Charge Pump Current Register II (Address: 31h) R/W Bit 7 Name Reset W CPTX3 1 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 CPTX2 1 CPTX1 1 CPTX0 1 CPRX3 0 CPRX2 0 CPRX1 1 CPRX0 1 M Bit O CPTX [3:0]: Charge pump current setting for TX mode. Recommend CPTX = [0001]. Charge pump current = (CPTX + 1) / 16 mA. C CPRX [3:0]: Charge pump current setting for RX mode. Recommend CPRX = [0001]. Charge pump current = (CPRX + 1) / 16 mA. IC 9.2.51 Crystal test Register (Address: 32h) R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 W --- --- --- --- DBD 0 XCC 1 XCP1 0 XCP0 0 A M Bit Name Reset DBD: Reserved for internal usage only. Shall be set to [0]. XCC: Reserved for internal usage only. Shall be set to [1]. XCP [1:0]: Reserved for internal usage only. Shall be set to [00]. 9.2.52 PLL test Register (Address: 33h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W --- CPS 1 PRRC1 0 PRRC0 1 PRIC1 0 PRIC0 0 SDPW 0 NSDO 1 CPS: Reserved for internal usage only. Shall be set to [1]. PRRC [1:0]: Reserved for internal usage only. Shall be set to [00]. PRIC [1:0]: Reserved for internal usage only. Shall be set to [01]. Jul., 2011, v1.3 30 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver SDPW: Reserved for internal usage only. Shall be set to [0]. NSDO: Reserved for internal usage only. Shall be set to [1]. 9.2.53 VCO test Register (Address: 34h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W --- --- --- TLB1 1 TLB0 1 RLB1 0 RLB0 0 VCBS 0 L TLB [1:0]: Reserved for internal usage only. Shall be set to [11]. VCBS: Reserved for internal usage only. Shall be set to [0]. 9.2.54 RF Analog test Register (Address: 35h) R/W Bit 7 Bit 6 Bit 5 Bit 4 Name Reset W OLM 0 VTBS 0 CPH 0 CPCS 0 Bit 3 Bit 2 Bit 1 Bit 0 RFT2 0 RFT1 0 RFT0 0 EN Bit TI A RLB [1:0]: Reserved for internal usage only. Shall be set to [00]. --- FI D OLM: Reserved for internal usage only. Shall be set to [0]. VTBS: Reserved for internal usage only. Shall be set to [0]. CPH: Reserved for internal usage only. Shall be set to [0]. N CPCS: Reserved for internal usage only. Shall be set to [1]. C O RFT [2:0]: RF analog pin configuration. Recommend RFT= [000]. {XADS, RFT[2:0]} BP_BG [0000] Band-gap voltage [0001] Analog temperature voltage [0010] Band-gap voltage [0011] Analog temperature voltage [0100] BPF positive in phase output [0101] BPF positive quadrature phase output [0110] No connection [0111] No connection [1000] Band-gap voltage [1001] Analog temperature voltage [1010] Band-gap voltage [1011] Analog temperature voltage [1100] No connection [1101] No connection [1110] No connection [1111] No connection A M IC C O M BP_RSSI RSSI voltage RSSI voltage No connection No connection BPF negative in phase output BPF negative quadrature phase output No connection No connection External ADC input source External ADC input source External ADC input source External ADC input source External ADC input source External ADC input source External ADC input source External ADC input source 9.2.55 IFAT Register (Address: 36h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W IGFI2 1 IGFI1 0 IGFI0 0 IGFQ2 1 IGFQ1 0 IGFQ0 0 IFBC 1 LIMC 1 IGFI [2:0]: Reserved for internal usage only. Shall be set to [111]. IGFQ [2:0]: Reserved for internal usage only. Shall be set to [111]. IFBC: Reserved for internal usage only. Shall be set to [1]. LIMC: Reserved for internal usage only. Shall be set to [1]. Jul., 2011, v1.3 31 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 9.2.56 Channel Select Register (Address: 37h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W CHI3 0 CHI2 1 CHI1 0 CHI0 0 CHD3 0 CHD2 1 CHD1 0 CHD0 0 CHI [3:0]: Auto IF offset channel number setting. FCHSP * (CHI + 1) = 2MHz Refer to chapter 14 for FCHSP setting. 9.2.57 VRB Register (Address: 38h) R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 W VTRB3 0 VTRB2 0 VTRB1 0 VTRB0 0 VMRB3 0 Bit 1 Bit 0 VMRB1 0 VMRB0 0 A M IC C O M C O N FI D VTRB [3:0]: Reserved for internal usage only. Shall be set to [1111]. VMRB [3:0]: Reserved for internal usage only. Shall be set to [1111]. Bit 2 VMRB2 0 EN Bit Name Reset TI A L CHD [3:0]: The channel frequency offset for deviation calibration. If FCHSP = 500KHz, recommend CHD = [0111]. Offset channel number = +/- (CHD + 1). Jul., 2011, v1.3 32 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 10. SPI A7125 only supports one SPI bus with maximum data rate 10Mbps. MCU should assert SCS pin low (SPI chip select) to active accessing of A7125. Via SPI bus, user can access control registers and issue Strobe command. Figure 10.1 gives an overview of SPI access manners. 3-wire SPI (SCS, SCK and SDIO) or 4-wire SPI (SCS, SCK, SDIO and GIO1/GIO2) configuration is provided. For 3-wire SPI, SDIO pin is configured as bi-direction to be data input and output. For 4-wire SPI, SDIO pin is data input and GIO1 (or GIO2) pin is data output. In such case, GIO1S (0bh) or GIO2S (0ch) should be set to [0110]. TI A L For SPI write operation, SDIO pin is latched into A7125 at the rising edge of SCK. For SPI read operation, if input address is latched by A7125, data output is aligned at falling edge of SCK. Therefore, MCU can latch data output at the rising edge of SCK. To control A7125’s internal state machine, it is very easy to send Strobe command via SPI bus. The Strobe command is a unique command set with total 8 commands. See section 10.3, 10.4 and 10.5 for details. Data In Data Out 3-Wire SPI SCS pin = 0 SDIO pin SDIO pin 4-Wire SPI SCS pin = 0 SDIO pin GIO1 (GIO1S=0110) / GIO2 (GIO2S=0110) Read/Write ID register DataByte0 ADDRreg DataByte DataByte1 ADDRreg DataByte2 DataByte DataByte3 DataByten DataByte0 DataByte1 DataByte2 DataByte3 Strobe CommandSleep Mode M Strobe CommandIdle Mode Idle Mode Strobe CommandSTBY Mode O STBY Mode C Strobe CommandPLL Mode Strobe CommandRX Mode IC RX Mode ADDRFIFO ADDRID Sleep Mode PLL Mode DataByte N Read/Write RF FIFO ADDRreg C O Read/Write register FI D SCS EN SPI chip select A M TX Mode Strobe CommandTX Mode FIFO Write Reset Strobe CommandFIFO Write Reset FIFO Read Reset Strobe CommandFIFO Read Reset Figure 10.1 SPI Access Manners Jul., 2011, v1.3 33 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 10.1 SPI Format The first bit (A7) is critical to indicate A7125 the following instruction is “Strobe command” or “control register”. See Table 10.1 for SPI format. Based on Table 10.1, if A7=0, A7125 is informed for control register accessing. So, A6 bit is used to indicate read (A6=1) or write operation (A6=0). See Figure 10.2 and Figure 10.3 for details. CMD A7 R/W A6 Address Byte (8 bits) Address A5 A4 A3 A2 A1 A0 7 6 5 Data Byte (8 bits) Data 4 3 2 1 0 L Table 10.1 SPI Format TI A Address byte: Bit 7: Command bit [0]: Control register command. [1]: Strobe command. EN Bit 6: R/W bit [0]: Write data to control register. [1]: Read data from control register. Bit [5:0]: Address of control register FI D Data Byte: Bit [7:0]: SPI input or output data, see Figure 10.2 and Figure 10.3 for details. N 10.2 SPI Timing Characteristic A M IC C O M C O No matter 3-wire or 4-wire SPI bus is configured, the maximum SPI data rate is 10 Mbps. To active SPI bus, SCS pin must be set to low. For correct data latching, user has to take care hold time and setup time between SCK and SDIO. See Table 10.2 for details. Parameter FC TSE THE TSW THW TDR Description FIFO clock frequency. Enable setup time. Enable hold time. TX Data setup time. TX Data hold time. RX Data delay time. Min. 50 50 50 50 0 Max. 10 50 Unit MHz ns ns ns ns ns Table 10.2 SPI Timing Characteristic 10.3 SPI Timing Chart In this section, 3-wire and 4-wire SPI bus read / write timing are described. 10.3.1 Timing Chart of 3-wire SPI Jul., 2011, v1.3 34 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver SCS SCK SDIO A7 A6 A5 A4 A3 A2 A1 A0 DW7 RF IC will latch address bit at rising edge of SCK DW6 DW5 DW1 DW0 RF IC will latch data bit at the rising edge of SCK L 3-Wire serial interface - Write operation TI A SCS SCK A7 A6 A5 A4 A3 A2 A1 A0 DR7 DR5 DR1 DR0 DW1 DW0 MCU can latch data at rising edge of SCK RF IC will change the data when falling edge of SCK RF IC will latch address bit at rising edge of SCK DR6 EN SDIO FI D 3-Wire serial interface - Read operation Figure 10.2 Read/Write Timing Chart of 3-Wire SPI SCK SDIO A6 A5 A4 A3 A2 A1 A0 DW7 M A7 C O SCS N 10.3.2 Timing Chart of 4-wire SPI RF IC will latch data bit at rising edge of SCK 4-Wire serial interface - Write operation A M IC SCS SCK DW5 C O RF IC will latch address bit at rising edge of SCK DW6 SDI A7 A6 A5 A4 A3 A2 A1 x GIOx RF IC will latch address bit at rising edge of SCK x A0 DR7 RF IC will change the data when falling edge of SCK DR6 DR5 DR2 DR1 DR0 MCU can latch data at the rising edge of SCK 4-Wire serial interface - Read operation Figure 10.3 Read/Write Timing Chart of 4-Wire SPI 10.4 Strobe Commands A7125 supports 8 Strobe commands to control internal state machine for chip’s operations. Table 10.3 is the summary of Strobe commands. Jul., 2011, v1.3 35 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver Be notice, Strobe command could be defined by 4-bits (A7~A4) or 8-bits (A7~A0). If 8-bits Strobe command is selected, A3 ~ A0 are don’t care conditions. In such case, SCS pin can be remaining low for asserting next commands. A6 0 0 0 0 1 1 1 1 A5 0 0 1 1 0 0 1 1 A4 0 1 0 1 0 1 0 1 A3 x x x x x x x x A2 x x x x x x x x A1 x x x x x x x x A0 x x x x x x x x Description Sleep mode Idle mode Standby mode PLL mode RX mode TX mode FIFO write pointer reset FIFO read pointer reset EN Table 10.3 Strobe Commands by SPI bus L A7 1 1 1 1 1 1 1 1 TI A Strobe Command Strobe Command 10.4.1 Strobe Command - Sleep Mode A6 0 A5 0 A4 0 A3 0 A2 0 A1 0 Description A0 0 Sleep mode Figure 10.4 Sleep mode Command Timing Chart IC C O M C O A7 1 N Strobe Command Strobe Command FI D Refer to Table 10.3, user can issue 4 bits (1000) Strobe command directly to set A7125 into Sleep mode. Below are the Strobe command table and timing chart. A M 10.4.2 Strobe Command - ldle Mode Refer to Table 10.3, user can issue 4 bits (1001) Strobe command directly to set A7125 into Idle mode. Below are the Strobe command table and timing chart. Strobe Command Strobe Command A7 A6 A5 A4 A3 A2 A1 A0 1 0 0 1 x x x x Jul., 2011, v1.3 Description Idle mode 36 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver SCS SCS SCK SCK A7 SDIO A6 A5 A4 SDIO A7 A6 Idle mode A5 A3 A4 A2 A1 A0 Idle mode TI A L Figure 10.5 Idle mode Command Timing Chart 10.4.3 Strobe Command - Standby Mode Strobe Command Strobe Command A6 0 A5 1 A4 0 A3 x A2 x A1 x Description A0 x Standby mode C O N FI D A7 1 EN Refer to Table 10.3, user can issue 4 bits (1010) Strobe command directly to set A7125 into Standby mode. Below are the Strobe command table and timing chart. M Figure 10.6 Standby mode Command Timing Chart O 10.4.4 Strobe Command - PLL Mode C Refer to Table 10.3, user can issue 4 bits (1011) Strobe command directly to set A7125 into PLL mode. Below are the Strobe command table and timing chart. A6 0 A5 1 A M A7 1 IC Strobe Command Strobe Command A4 1 A3 x A2 x A1 x Description A0 x PLL mode Figure 10.7 PLL mode Command Timing Chart Jul., 2011, v1.3 37 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 10.4.5 Strobe Command - RX Mode Refer to Table 10.3, user can issue 4 bits (1100) Strobe command directly to set A7125 into RX mode. Below are the Strobe command table and timing chart. Strobe Command Strobe Command A6 1 A5 0 A4 0 A3 x A2 x A1 x Description A0 x RX mode EN TI A L A7 1 FI D Figure 10.8 RX mode Command Timing Chart N 10.4.6 Strobe Command - TX Mode Strobe Command Strobe Command A6 A5 A4 A3 A2 1 1 0 1 x x A1 A0 x x Description TX mode A M IC C O M A7 C O Refer to Table 10.3, user can issue 4 bits (1101) Strobe command directly to set A7125 into TX mode. Below are the Strobe command table and timing chart. Figure 10.9 TX mode Command Timing Chart 10.4.7 Strobe Command – FIFO Write Pointer Reset Refer to Table 10.3, user can issue 4 bits (1110) Strobe command directly to reset A7125 FIFO write pointer. Below are the Strobe command table and timing chart. Strobe Command Strobe Command A7 A6 A5 A4 A3 A2 A1 A0 1 1 1 0 x x x x Jul., 2011, v1.3 Description FIFO write pointer reset 38 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver TI A L Figure 10.10 FIFO write pointer reset Command Timing Chart 10.4.8 Strobe Command – FIFO Read Pointer Reset Strobe Command Strobe Command A6 A5 A4 A3 A2 A1 A0 1 1 1 1 x x x x Description FIFO read pointer reset C O N FI D A7 EN Refer to Table 10.3, user can issue 4 bits (1111) Strobe command directly to reset A7125 FIFO read pointer. Below are the Strobe command table and timing chart. O 10.5 Reset Command M Figure 10.11 FIFO read pointer reset Command Timing Chart A M SCS IC C In addition to power on reset (POR), MCU could issue software reset to A7125 by setting Mode Register (00h) through SPI bus as shown below. As long as 8-bits address (A7~A0) are delivered zero and data (D7~D0) are delivered zero, A7125 is informed to generate internal signal “RESETN” to initial itself. After reset command, A7125 is in standby mode. SCK SDIO A7 A6 A5 A4 A3 A2 A1 A0 DW 7 DW 6 DW5 DW1 DW 0 RESETN Reset RF chip Figure 10.12 Reset Command Timing Chart 10.6 ID Accessing Command A7125 has built-in 32-bits ID Registers for customized identification code. It is accessed via SPI bus. ID length is recommended to be 32 bits by setting IDL (20h). Figure 10.13 and 10.14 are timing charts of 32-bits ID accessing via 3-wire SPI. Jul., 2011, v1.3 39 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 10.6.1 ID Write Command User can refer to Figure 10.2 for SPI write timing chart. Below is the procedure of ID write command. EN TI A L Step1: Deliver A7~A0 = 00000110 (A7=0 for control register, A6=0 for write operation, ID addr = 06h). Step2: Via SDIO pin, 32-bits ID are written in sequence by Data Byte 0, 1, 2 and 3. Step3: Toggle SCS pin to high when step2 is completed. Figure 10.13 ID Write Command Timing Chart FI D 10.6.2 ID Read Command User can refer to Figure 10.2 for SPI read timing chart in details. Below is the procedure of ID read command. Figure 10.14 ID Read Command Timing Chart IC C O M C O N Step1: Deliver A7~A0 = 01000110 (A7=0 for control register, A6=1 for read operation, ID addr = 06h). Step2: Via SDIO pin, 32-bits ID are read in sequence by Data Byte 0, 1, 2 and 3. Step3: Toggle SCS pin to high when step2 is completed. 10.7 FIFO Accessing Command A M A7125 has separated TX / RX FIFO, user just needs to set FMS (01h) =1 to enable FIFO mode. In FIFO mode, before packet is delivered, write wanted data into TX FIFO and issue TX strobe command. Similarly, user can read RX FIFO once packet is received. User can choose polling or interrupt scheme for FIFO accessing. FIFO status is output via GIO1 (or GIO2) pin by setting GIO1 (0Bh) or GIO2 (0Ch). See Figure 10.15 and 10.16 for timing charts of FIFO accessing via 3-wire SPI. 10.7.1 TX FIFO Write Command User can refer to Figure 10.2 for SPI write timing chart. Below is the procedure of TX FIFO write command. Step1: Step2: Step3: Step4: Jul., 2011, v1.3 Deliver A7~A0 = 00000101 (A7=0 for control register, A6=0 for write operation, FIFO addr = 05h). Via SDIO pin, write (n+1) bytes TX data into TX FIFO in sequence by Data Byte 0, 1, 2 to n. Toggle SCS pin to high when step2 is completed. Send TX Strobe command for packet transmitting. Refer to Figure 10.9. 40 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver L Figure 10.15 TX FIFO Write Command Timing Chart TI A 10.7.2 Rx FIFO Read Command User can refer to Figure 10.2 for SPI read timing chart. Below is the procedure of RX FIFO read command. N FI D EN Step1: Deliver A7~A0 = 01000101 (A7=0 for control register, A6=1 for read operation, FIFO addr = 05h). Step2: Via SDIO pin, RX FIFO is read in sequence by Data Byte 0, 1, 2 to n. Step3: Toggle SCS pin to high when RX FIFO is read completely. A M IC C O M C O Figure 10.16 RX FIFO Read Command Timing Chart Jul., 2011, v1.3 41 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 11. State machine In chapter 9 and chapter 10, user can learn both accessing A7125’s control registers as well as issuing Strobe commands. From section 10.2 ~ 10.6, it is clear to know configurations of 3-wire SPI and 4-wire SPI, Strobe command, software reset, and how to access ID Registers and TX/RX FIFO. In section 11.1, built-in state machine is introduced. Then, combined with Strobe command, software reset and A7125’s control registers, section 11.2 , 11.3 and 11.4 demonstrate 3 state diagrams to explain how transitions of A7125’s operation. TI A L From accessing data point of view, if FMS=1 (01h), FIFO mode is enabled, otherwise, A7125 is in direct mode. If FMS=1 and FIFO Read/Write at standby mode, we call it is Normal FIFO mode. Otherwise, If FMS=1 and FIFO Read/Write at PLL mode, we called it is Quick FIFO mode due to the reduction of PLL settling time. If FMS=1 and FIFO Read/Write at IDLE mode, we called it is Power Saving FIFO mode due to the reduction of average current. Data In Data Out Operation Mode Clock Recovery for Direct Mode 3-Wire SPI SCS pin = 0 SDIO pin SDIO pin 4-Wire SPI SCS pin = 0 SDIO pin GIO1 (GIO1S=0110) / GIO2 (GIO2S=0110) FIFO (FMS=1) Direct(FMS=0) FIFO (FMS=1) Direct(FMS=0) CKO pin (CKOS = 0001) CKO pin (CKOS = 0001) (FMS=1 and FIFO R/W @ Standby mode) (FMS=1 and FIFO R/W @ PLL mode) (FMS=1 and FIFO R/W @ IDLE mode) (FMS=0 and FIFO ignored, write packet @ TX mode, read packet @ RX mode) FI D Normal FIFO Mode Quick FIFO Mode Power Saving FIFO Mode Quick Direct Mode 11.1 Key states M C O A7125 supports 7 key operation states. Those are, (1) Standby mode (2) Sleep mode (3) Idle mode (4) PLL mode (5) TX mode (6) RX mode (7) CAL mode N (1) (2) (3) (4) EN SPI chip select IC C O After power on reset or software reset, A7125 is automatically into standby mode. Then, user has to do calibration process because all control registers are in initial values. The calibration process of A7125 is very easy, user only needs to issue Strobe commands and enable calibration registers. If so, the calibrations are automatically completed by A7125’s internal state machine. See 11.2, 11.3, 11.4 and chapter 15 for details. After calibration, A7125 is ready to do TX and RX operation. User can start wireless transmission. A M 11.1.1 Standby mode When Standby Strobe is issued, A7125 enters standby mode automatically. Internal power management is listed below. Be noted that A7125 is in standby mode after power on reset or software reset. Standby mode On Chip Regulator Crystal Oscillator VCO PLL RX Circuitry TX Circuitry ON ON OFF OFF OFF OFF Jul., 2011, v1.3 42 Strobe Command (1010xxxx)b See Figure 10.6 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 11.1.2 Sleep mode When Sleep Strobe is issued, A7125 enters sleep mode automatically. In sleep mode, A7125 still can accept other strobe commands via SPI bus. But, A7125 can not support Read/Write FIFO in sleep mode. Internal power management is listed below. Sleep mode VCO PLL RX Circuitry TX Circuitry OFF OFF OFF OFF OFF OFF Strobe Command (1000xxxx)b See Figure 10.4 L Crystal Oscillator TI A On Chip Regulator 11.1.3 ldle mode ldle mode Crystal Oscillator VCO PLL RX Circuitry ON OFF OFF OFF OFF TX Circuitry OFF FI D On Chip Regulator EN When Idle Strobe is issued, A7125 enters idle mode automatically. In idle mode, A7125 can accept other strobe commands as well as supporting Read/Write FIFO. Internal power management is listed below. (1001xxxx)b See Figure 10.5 N 11.1.4 PLL mode Strobe Command C O When PLL Strobe is issued, A7125 enters PLL mode automatically. In PLL mode, internal PLL and VCO are both turned on to generate LO (local oscillator) frequency before TX and RX operation. Internal power management is listed below. According to PLL Register I, II, III, IV and V, PLL circuitry is easy to control by user’s definition. PLL mode Crystal Oscillator ON ON VCO M On Chip Regulator RX Circuitry TX Circuitry ON OFF OFF Strobe Command (1011xxxx)b See Figure 10.7 O ON PLL C 11.1.5 TX mode IC When TX Strobe is issued, A7125 enters TX mode automatically for data delivery. Internal power management is listed below. A M Be notice, (1) If A7125 is in FIFO mode, TX data packet (Preamble + ID + Payload) is delivered through TX circuitry. Then, A7125 supports auto-back function to previous state for the next packet. (2) If A7125 is in direct mode, TX data packet is also delivered through TX circuitry. Then, A7125 stays in TX mode. User has to issue Strobe command to back to previous state. TX mode On Chip Regulator Crystal Oscillator VCO PLL RX Circuitry TX Circuitry ON ON ON ON OFF ON Strobe Command (1101xxxx)b See Figure 10.9 11.1.6 RX mode When RX Strobe is issued, A7125 enters RX mode automatically for data receiving. Internal power management is listed below. Be notice, Jul., 2011, v1.3 43 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver (1) If A7125 is in FIFO mode, RX data packet is caught through RX circuitry. Then, A7125 supports auto-back function to previous state for next receiving packet. (2) If A7125 is in direct mode, RX data packet is also caught through RX circuitry. Then, A7125 stays in RX mode. User has to issue Strobe command to back to previous state. RX mode VCO PLL RX Circuitry TX Circuitry ON ON ON ON ON OFF Strobe Command (1101xxxx)b See Figure 10.9 L Crystal Oscillator TI A On Chip Regulator 11.1.7 CAL mode EN Calibration process shall be done after power on reset or software reset. Calibration items include VCO, IF Filter and RSSI. It is easy to implement calibration process by Strobe command and enable CALC (02h) control register. See chapter 15 for details. A M IC C O M C O N FI D Be noted that VCO Calibration is executed in PLL mode only. However, IF Filter and RSSI Calibration can be executed in Standby or PLL mode. Jul., 2011, v1.3 44 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 11.2 Normal FIFO Mode This mode is suitable for requirement of general purpose applications. After calibration, user can issue Strobe command to enter standby mode where write TX FIFO or read RX FIFO. From standby mode to packet data transceiving, only one Strobe command is needed. Once transmission is done, A7125 is auto back to standby mode. CAL CMD CMD Value Calibration Section AK CALC.0=1, RSSI 15.3 CALC.1=1, IF Filter 15.2 CALC.2=1, VCO Deviation 15.6 CALC.3=1, VCO Bank 15.5 CALC.4=1, VCO Current 15.4 Strobe CMD Value Note Section ST1 1011b Enter to PLL 10.4.4 ST2 1010b Enter to Standby 10.4.3 ST3 1000b Enter to SLEEP 10.4.1 ST4 1001b Enter to IDLE 10.4.2 ST5-TX 1101b Enter to TX 10.4.6 ST5-RX 1100b Enter to RX 10.4.5 RST-CMD 00000000b Software Reset 10.5 A M IC C O M C O N FI D EN TI A L If all packets are finished and deeper power saving is necessary, user can issue Strobe command to ask A7125 staying in sleep mode. Figure 11.1 is the state diagram of Normal FIFO mode. l Be notice, refer to chapter 16 for definition of RX FIFO Full and TX FIFO Empty. Figure 11.1 State diagram of Normal FIFO Mode From Figure 11.1, when ST5 command is issued for TX operation, see Figure 11.2 for detailed timing. A7125 status can be represented to GIO1 or GIO2 pin to MCU for timing control. Jul., 2011, v1.3 45 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver Strobe CMD (SCS,SCK,SDIO) Next Instruction ST5 90 us (auto delay) Pin Preamble + ID Code + Payload GIO1 Pin - WTR (GIO1S[3:0]=0000) Transmitting Time T0 Changed No Changed WPLL to TX (TDL) 60 us 60 us TX Ready Time EN Standby to WPLL (PDL) 30 us 30 us TI A T0-T1: Auto Delay by Register setting (PDL + TDL) LO Freq. Auto Back Standby Mode T2 T1 L RFO 90 us 90 us FI D Figure 11.2 Transmitting Timing Chart of Normal FIFO Mode From Figure 11.1, when ST5 command is issued for RX operation, see Figure 11.3 for detailed timing. A7125 status can be represented to GIO1 or GIO2 pin to MCU for timing control. Strobe CMD (SCS,SCK,SDIO) ST5 90 us Pin Preamble + ID Code + Payload C O RFI Next Instruction N Wait Packet GIO1 Pin - WTR (GIO1S[3:0]=0000) T1 M T0 Receiving Time T3 T2 Auto Back Standby Mode O T0-T1: RX Settling. T1-T2: RX is ready, Wait for valid packet Standby to WPLL WPLL to RX RX Ready Time Changed No Changed 30 us 30 us 60 us 60 us 90 us 90 us A M IC C LO Freq. Jul., 2011, v1.3 Figure 11.3 Receiving Timing Chart of Normal FIFO Mode 46 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 11.3 Quick FIFO Mode This mode is suitable for requirement of fast transceiving. After calibration flow, user can issue Strobe command to enter PLL mode where write TX FIFO or read RX FIFO. From PLL mode to packet data transceiving, only one Strobe command is needed. Once transmission is done, A7125 is auto back to PLL mode. CAL CMD CMD Value Calibration Section AK CALC.0=1, RSSI 15.3 CALC.1=1, IF Filter 15.2 CALC.2=1, VCO Deviation 15.6 CALC.3=1, VCO Bank 15.5 CALC.4=1, VCO Current 15.4 Strobe CMD Value Note Section ST 1 1011b Enter to PLL 10.4.4 ST 2 1010b Enter to Standby 10.4.3 ST 3 1000b Enter to SLEEP 10.4.1 ST 4 1001b Enter to ID LE 10.4.2 ST 5-TX 1101b Enter to TX 10.4.6 ST 5-R X 1100b Enter to R X 10.4.5 RST-CMD 00000000b Software Reset 10.5 A M IC C O M C O N FI D EN TI A L When packets are finished and deeper power saving is necessary, user can issue Strobe command to ask A7125 staying in sleep mode. Figure 11.4 is the state diagram of Quick FIFO mode. l l Be notice, refer to chapter 16 for definition of RX FIFO Full and TX FIFO Empty. Be notice, ST5 delay time is either 70 us (LO frequency changed) or 10 us (LO frequency NOT changed) Figure 11.4 State diagram of Quick FIFO Mode From Figure 11.4, when ST5 command is issued for TX operation, see Figure 11.5 for detailed timing. A7125 status can be represented to GIO1 or GIO2 pin to MCU for timing control. Jul., 2011, v1.3 47 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver Strobe CMD (SCS,SCK,SDIO) Next Instruction ST5 90 us / 70 us (auto delay) RF In/Out Pin Preamble + ID Code + Payload GIO1 Pin - WTR (GIO1S[3:0]=0000) Transmitting Time Changed No Changed WPLL to TX (TDL) 60 us 60 us TX Ready Time EN PLL to WPLL (PDL) 30 us 10 us TI A T0-T1: Auto Delay by Register setting(PDL+TDL) LO Freq. Auto Back PLL Mode T2 T1 L T0 90 us 70 us FI D Figure 11.5 Transmitting Timing Chart of Quick FIFO Mode From Figure 11.4, when ST5 command is issued for RX operation, see Figure 11.6 for detailed timing. A7125 status can be represented to GIO1 or GIO2 pin to MCU for timing control. Strobe CMD (SCS,SCK,SDIO) Wait Packet C O 90 us / 70 us RF In/Out Pin M GIO1 Pin - WTR (GIO1S[3:0]=0000) T1 Preamble + ID Code + Payload Receiving Time T3 T2 Auto Back PLL Mode O T0 Next Instruction N ST5 C T0-T1: RX Settling by register setting (PDL+TDL). T1-T2: RX is ready, Wait for valid packet IC LO Freq. A M Changed No Changed Standby to WPLL (PDL) 30 us 10 us WPLL to RX (TDL) 60 us 60 us RX Ready Time 90 us 70 us Figure 11.6 Receiving Timing Chart of Quick FIFO Mode 11.4 Power Saving FIFO Mode This mode is suitable for requirement of low power consumption. After calibration flow, user can issue Strobe command to enter idle mode where write TX FIFO or read RX FIFO. From idle mode to packet data transceiving, only one Strobe command is needed. Once transmission is done, A7125 is auto back to idle mode. When packets are finished and deeper power saving is necessary, user can issue Strobe command to ask A7125 staying in sleep mode. Figure 11.7 is the state diagram of Power Saving FIFO mode. Jul., 2011, v1.3 48 AMICCOM Electronics Corporation A7125 N FI D EN TI A L 2.4GHz FSK Transceiver CMD Value Calibration Section AK CALC.0=1, RSSI 15.3 CALC.1=1, IF Filter 15.2 CALC.2=1, VCO Deviation 15.6 CALC.3=1, VCO Bank 15.5 CALC.4=1, VCO Current 15.4 Strobe CMD Value Note Section ST 1 1011b Enter to PLL 10.4.4 ST 2 1010b Enter to Standby 10.4.3 ST 3 1000b Enter to SLEEP 10.4.1 ST 4 1001b Enter to IDLE 10.4.2 ST 5-TX 1101b Enter to TX 10.4.6 ST 5-RX 1100b Enter to RX 10.4.5 RST-CMD 00000000b Software Reset 10.5 Be notice, refer to chapter 16 for definition of RX FIFO Full and TX FIFO Empty. A M l IC C O M C O CAL CMD Figure 11.7 State diagram of Power Saving FIFO Mode From Figure 11.7, when ST5 command is issued for TX operation, see Figure 11.8 for detailed timing. A7125 status can be represented to GIO1 or GIO2 pin to MCU for timing control. Jul., 2011, v1.3 49 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver Strobe CMD (SCS,SCK,SDIO) Next Instruction ST5 990 us (auto delay) RF In/Out Pin Preamble + ID Code + Payload Crystal Ready (900 us) GIO1 Pin - WTR (GIO1S[3:0]=0000) Transmitting Time Changed No Changed PLL to WPLL (PDL) 30 us 30 us WPLL to TX (TDL) 60 us 60 us EN IDLE to PLL (WSEL, Crystal Ready) 300+600 us 300+600 us TI A T0-T1: Auto Delay by Register setting (WSEL+PDL+TDL) LO Freq. Auto Back IDLE Mode T2 T1 L T0 TX Ready Time 990 us 990 us FI D Figure 11.8 Transmitting Timing Chart of Power Saving FIFO Mode From Figure 11.7, when ST5 command is issued for RX operation, see Figure 11.9 for detailed timing. A7125 status can be represented to GIO1 or GIO2 pin to MCU for timing control. Strobe CMD (SCS,SCK,SDIO) Wait Packet C O 990 us RF In/Out Pin Next Instruction N ST5 Preamble + ID Code + Payload Crystal ready (900 us) M GIO1 Pin - WTR (GIO1S[3:0]=0000) T1 T3 T2 Auto Back IDLE Mode O T0 Receiving Time C T0-T1: Crystal Ready + RX settling by register setting (WSEL+PDL+TDL) T1-T2: RX is ready, Wait for valid packet IC LO Freq. A M Changed No Changed Jul., 2011, v1.3 IDLE to PLL (WSEL) 300+600 us 300+600 us WPLL to RX (TDL) 30 us 30 us WPLL to RX (TDL) 60 us 60 us RX Ready Time 990 us 990 us Figure 11.9 Receiving Timing Chart of Power Saving FIFO Mode 50 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 11.5 Quick Direct Mode This mode is suitable for fast transceiving. After calibration flow, for every state transition, user has to issue Strobe command to A7125.This mode is also suitable for the requirement of versatile packet format. Noted that user needs to take care the transition time by MCU’s timer. CAL CMD CMD Value Calibration Section AK CALC.0=1, RSSI 15.3 CALC.1=1, IF Filter 15.2 CALC.2=1, VCO Deviation 15.6 CALC.3=1, VCO Bank 15.5 CALC.4=1, VCO Current 15.4 Strobe CMD Value Note Section ST 1 1011b Enter to PLL 10.4.4 ST 2 1010b Enter to Standby 10.4.3 ST 3 1000b Enter to SLEEP 10.4.1 ST 4 1001b Enter to ID LE 10.4.2 ST 5-TX 1101b Enter to TX 10.4.6 ST 5-RX 1100b Enter to RX 10.4.5 RST-CMD 00000000b Software Reset 10.5 A M IC C O M C O N FI D EN TI A L When packets are finished and deeper power saving is necessary, user can issue Strobe command to ask A7125 staying in idle mode (or sleep mode). Figure 11.3 is the state diagram of Quick Direct mode. l l Be notice, Dummy stands for dummy preamble. Be notice, ST5 delay time is either 70 us (LO frequency changed) or 10 us (LO frequency NOT changed) Figure 11.10 State diagram of Quick Direct Mode Jul., 2011, v1.3 51 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver From Figure 11.10, when PLL mode transits to WPLL mode, LO (local oscillator) frequency changed or not will induce different PLL setting time by either 70us or 10 us. Therefore, MCU total delay time is different. See Table 11.1 for details. LO Freq. Changed No Changed PLL to WPLL 30 us 10 us WPLL to TX 50 us 50 us TX Ready Time 80 us 60 us Table 11.1 MCU total delay time from PLL to TX mode. A7125 Data Rate Dummy Preamble 1 Mbps 2 Mbps Packet TI A L From Figure 11.10, when A7125 enters TX mode, MCU should immediately deliver dummy preamble and defined packet to A7125’s GIO1 or GIO2 pin. Dummy preamble is used to stabilize TX circuitry. See Table 11.2 for details. Note ID Max Payload 10 bits 32 bits 32 bits 512 bytes Total Preamble = 42 bits 20 bits 32 bits 32 bits 512 bytes Total Preamble = 52 bits EN Preamble FI D Table 11.2 Format of dummy preamble and packet. Strobe CMD (SCS,SCK,SDIO) C O N From Figure 11.10, Table 11.1 and 11.2, MCU total delay time and dummy preamble are important for quick direct mode. When ST5 command is issued for TX operation, see Figure 11.4 for detailed timing. A7125 status can be represented to GIO1 and GIO2 pin to MCU for timing control. ST5 10 us 80 us / 60 us Transmitting Output C GIO2 Pin - TMEO (GPIO2S[3:0]=0010) Dummy Preamble O GIO2 Pin - WTR (GPIO2S[3:0]=0000) Dummy Preamble + Preamble + ID + Payload M GIO1 Pin - TRXD (GPIO1S[3:0]=0111) ST1 A M IC CKO Pin - DCK (CKOS[3:0]=0000) T0 T1 T2 T3 T0-T1: MCU Total Delay Time, Refer to Table 11.1 T1-T2: Dummy Preamble, Refer to Table 11.2 T2: TMEO (TX Modulation Enable) is auto triggered T2-T3: Transmitting Time Figure 11.11 Transmitting Timing Chart of Quick Direct Mode From Figure 11.3, Table 11.1 and 11.2, RX settling time is important for quick direct mode. When ST5 command is issued for RX operation, after RX settling and preamble detect, A7125 offers ID sync function (if 32 bits ID is stored in ID Register) to generate FSYNC signal to inform MCU. Figure 11.5 is the detailed timing. A7125 status can be represented to GIO1 and GIO2 pin to MCU for timing control. Jul., 2011, v1.3 52 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver Strobe CMD (SCS,SCK,SDIO) ST1 ST5 Wait Packet 90 us / 70 us GIO1 Pin - TRXD (GPIO1S[3:0]=0111) Preamble + ID + Payload GIO2 Pin - PMDO (GPIO2S[3:0]=0011) Payload Output TI A ID Sync. GIO2 Pin - FSYNC (GPIO2S[3:0]=0001) CKO Pin - RCK (CKOS[3:0]=0001) T1 T3 T2 EN T0 T4 T0-T1: RX Ready Time T1-T2: RX is ready, wait for valid packet T2-T3: Preamble Detect 30 us 10 us FI D Changed No Changed T5 T3-T4: ID Sync T4-T5: Payload Output WPLL to RX RX Ready Time 60 us 60 us 90 us 70 us N PLL to WPLL C O LO Freq. L Preamble Detect A M IC C O M Figure 11.12 Receiving Timing Chart of Quick Direct Mode Jul., 2011, v1.3 53 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 12 Crystal Oscillator Circuit A7125 needs external crystal or external clock that is either 6 or 8/12/16 MHz, to generate internal wanted clock. Be notice if 6MHz external crystal (clock) is selected, A7125 only supports 1Mbps data rate. Relative Control Register Data Rate Clock Register (Address: 0Dh) R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name R W SDR1 SDR1 0 SDR0 SDR0 0 GRC3 GRC3 0 GRC2 GRC2 1 GRC1 GRC1 1 GRC0 GRC0 1 -CGS 1 -XS 1 TI A Reset L Bit 12.1 Use External Crystal C O N FI D EN To use external crystal, user just sets XS= 1 (0Dh) to enable crystal oscillator. Figure 12.1 shows the connection of crystal network between XI and XO pins. C1 and C2 capacitance are used to adjust different crystal loading. A7125 support low cost crystal within ± 50ppmaccuracy. Be noted that crystal accuracy requirement includes initial tolerance, temperature drift, aging and crystal loading. i.e., Crystal = 16MHz (Cload =20pF), C1=C2=33pF. 12.2 Use External Clock M Figure12.1 Crystal network connection for using external crystal O A7125 has built-in AC couple capacitor to support external clock input. Figure 11.2 shows how to connect. In such case, XI pin is left opened. A M IC C To use external clock from MCU instead of external crystal, user just sets XS= 0 (0Dh) to active AC couple capacitor. Be notice, the frequency accuracy of external clock shall be controlled within ± 50ppm and the clock swing (peak-to-peak) shall be larger than 1.5V. (External clock is controlled within ± 50ppm and > 1.5Vpp.) Figure 12.2 Connect to external clock source Jul., 2011, v1.3 54 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 13. System Clock System clock (64MHz) is generated from crystal oscillator for internal digital circuitry. User can set “Data Rate Clock Register” (0Dh) to adapt different wanted crystal frequency (6/8/12/16MHz). Based on this, two important internal clocks FCGR and FSYCK are generated. (1) FCGR: Clock Generation Reference = 2MHz (Ref. clock of internal 64MHz PLL) (2) FSYCK: System Clock = 64 MHz (Main clock for internal digital circuit) Data Rate Clock Register (Address: 0Dh) Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Name R W SDR1 SDR1 0 SDR0 SDR0 0 GRC3 GRC3 0 GRC2 GRC2 1 GRC1 GRC1 1 Reset PLL Register II (Address: 0Fh) R/W Bit 7 Bit 6 Bit 5 Bit 4 Name R W DBL DBL 0 RRC1 RRC1 0 RRC0 RRC0 1 CHR3 CHR3 0 Reset Bit 1 Bit 0 -CGS 1 -XS 1 Bit 3 Bit 2 Bit 1 Bit 0 CHR2 CHR2 1 CHR1 CHR1 1 CHR0 CHR0 1 IP8 BIP8 0 N 13.1 Derive System Clock GRC0 GRC0 1 FI D Bit Bit 2 TI A R/W EN Bit L Relative Control Register FCGR = C O Because A7125 supports different external crystals, GRC [3:0] (0Dh) are used to get 2 MHz Clock Generation Reference (FCGR) for internal usage. FXREF . (GRC[3 : 0] + 1) IC C O M Below is block diagram of system clock. FXTAL is the crystal frequency. User can set registers to get FSYCK = 64MHz. FXREF is the reference clock of Clock Generator to generate F CGR = 2MHz and FSPLL = 64MHz. After delay circuitry, System clock is derived, FSYCK = 64MHz. ADC clock (FADC = 4MHz or 8MHz) is from FSYCK = 64MHz after frequency divider. XS A M XO System clock ÷ PLL (GRC+1) CE XI CGS CE FXREF CE GRC FSYCK= 64MHz 1 64MHz DBL X2 0 1 FCGR= 2MHz Delay 0 FSPLL= 64MHz Clock Generator FXTAL /2 /8 4MHz 8MHz 0 1 ADC clock (FADC) FSARS Figure 13.1 System Clock Block Diagram Recommend to set DBL (0Fh) = [0], then, FXREF = FXTAL Crystal Frequency (FXTAL) 16 MHz Jul., 2011, v1.3 Internal Crystal Reference (FXREF) 16 MHz Clock Generation Reference (FCGR) Must be 2 MHz 55 GRC [3:0] CGS [0111] 1 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 12 MHz 12 MHz Must be 2 MHz [0101] 8 MHz 8 MHz Must be 2 MHz [0011] 6 MHz 6 MHz Must be 2 MHz [0010] Be notice if 6MHz external crystal (clock) is selected, A7125 only supports 1Mbps data rate. 1 1 1 13.2 Data Rate EN TI A L A7125 supports programmable data rate by setting SDR [1:0] (0Dh). Data rate = (FIFCK / (SDR [1:0] +1)). The data rate clock is from IF clock (FIFCK) and FIFCK = FSYCK / 32 = 2 MHz FSYCK 1 × 32 SDR[1 : 0] + 1 FSYCK (system clock) 64 MHz 64 MHz 64 MHz 64 MHz FIFCK (IF clock) 2 MHz 2 MHz 2 MHz 2 MHz N A7125 Data Rate = FI D Figure 13.2 Data Rate Block Diagram Data Rate 2 Mbps 1 Mbps Reserved Reserved A M IC C O M C O SDR [1:0] (0Dh) [00] [01] [10] [11] Jul., 2011, v1.3 56 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 14. Transceiver Frequency A7125 is a half-duplex transceiver with embedded PA and LNA. For TX or RX frequency setting, user just needs to set up LO (Local Oscillator) frequency for two-way radio transmission. To target full range of 2.4GHz ISM band (2400 MHz to 2483.5 MHz), A7125 applies offset concept by LO frequency FLO = FLO_BASE + FOFFSET. Therefore, A7125 is easy to implement frequency hopping and multi-channels by ONE register setting, PLL Register I (CHN [7:0], 0Eh). In general, user can plan the wanted channels by a CHN Look-Up-Table to implement hopping table for two-way radio between master and slave. L Below is the LO frequency block diagram. F LO X (DBL+1) / (RRC[1:0]+1) AC[14:0]/ 2 16 1 AFC EN Divider 0 F LO_BASE + + F LO FI D CHN / [4*(CHR+1)] VCO PFD 0 BIP[8:0] + BFP[15:0]/ 2 16 TI A F PFD F XTAL F OFFSET Relative Control Register PLL Register I (Address: 0Eh) R/W Bit 7 Name Reset R/W CHN7 0 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 CHN6 0 CHN5 0 CHN4 0 CHN3 0 CHN2 0 CHN1 0 CHN0 0 M Bit C O N Figure 14.1 Block Diagram of Local Oscillator O PLL Register II (Address: 0Fh) R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name R W DBL DBL 0 RRC1 RRC1 0 RRC0 RRC0 1 CHR3 CHR3 0 CHR2 CHR2 1 CHR1 CHR1 1 CHR0 CHR0 1 IP8 BIP8 0 IC Reset C Bit PLL Register III (Address: 10h) R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name R W IP7 BIP7 1 IP6 BIP6 0 IP5 BIP5 0 IP4 BIP4 1 IP3 BIP3 0 IP2 BIP2 1 IP1 BIP1 1 IP0 BIP0 0 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 A M Bit Reset PLL Register IV (Address: 11h) Bit R/W Bit 7 Name R W --/FP15 Reset BFP15 0 AC14/FP14 AC13/FP13 AC12/P12 AC11/ FP11 AC10/FP10 Bit 1 Bit 0 AC9/FP9 AC8/FP8 BFP14 0 BFP13 0 BFP12 0 BFP11 0 BFP10 0 BFP9 0 BFP8 0 PLL Register V (Address: 12h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name R W AC7/FP7 AC6/FP6 AC5/FP5 AC4/FP4 AC3/FP3 AC2/FP2 AC1/FP1 AC0/FP0 BFP7 0 BFP6 0 BFP5 0 BFP4 0 BFP3 0 BFP2 1 BFP1 0 BFP0 0 Reset Jul., 2011, v1.3 57 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver RX Register (Address: 19h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W --- RXSM1 1 RXSM0 0 FC 0 RXDI 0 DMG 0 RAW 1 ULS 0 14.1 LO Frequency Setting Set the base frequency (FLO_BASE) by PLL Register II, III, IV and V (0Fh, 10h, 11h and 12h). Recommend to set FLO_BASE ~ 2400.001MHz. 2. Set the channel step (FCHSP) by PLL Register II (0Fh). A7125 supports different channel steps by 2M / 1M / 500K / 250K. (500K is recommended.) 3. Set CHN [7:0] to get offset frequency by PLL Register I (0Eh). FOFFSET = CHN [7:0] * FCHSP 4. LO frequency is equal to base frequency plus offset frequency. FLO = FLO_BASE + FOFFSET FI D EN TI A 1. L From Figure 14.1, FLO is not only for TX radio frequency but also to be RX LO frequency. To set up FLO, it is easy to implement by below 8 steps. FLO C O N FLO_BASE FOFFSET FXTAL BFP[15 : 0] BFP[15 : 0] × ( BIP[8 : 0] + ) = ( DBL + 1) × ) 16 RRC[1 : 0] + 1 2 216 M FLO_BASE = FPFD × ( BIP[8 : 0] + O Base on the above formula, for example, if F XTAL = 16 MHz and step FCHSP = 500 KHz, To get FLO_BASE and FLO ,see Table 14.1, 14.2, 14.3 and Figure 14.2 for details. A M IC C How to set FLO_BASE ~ 2400.001 MHz STEP ITEMS 1 FXTAL 2 DBL 3 RRC 4 BIP 5 BFP 6 FLO_BASE VALUE 16 MHz 0 0 0x96 0x0004 ~2400.001 MHz NOTE Crystal Frequency Disable double function If so, FPFD= 16MHz To get FLO_BASE =2400 MHz To get FLO_BASE ~ 2400.001 MHz LO Base frequency Table 14.1 How to set FLO_BASE How to set FLO = FLO_BASE + FOFFSET ~ 2405.001 MHz STEP ITEMS VALUE NOTE 1 FLO_BASE ~2400.001 MHz After set up BIP and BFP 2 CHR 7 To get FCHSP= 500 KHz 3 FCHSP 500 KHz Channel step = 500KHz 4 CHN 0x0A Set channel number = 10 5 FOFFSET 5 MHz FOFFSET= 500 KHz * (CHN) = 5MHz 6 FLO ~2405.001 MHz Get FLO= FLO_BASE + FOFFSET Table 14.2 How to set FLO Jul., 2011, v1.3 58 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver Figure 14.2 show FLO ~ 2405.001 MHz and its registers setting. F PFD =16M (DBL+1) / (RRC[1:0]+1) DBL = 0 AC[14:0]/ 2 16 BIP[8:0] + BFP[15:0]/ 2 16 PFD RRC = 0 1 0 VCO FL O= 2405.001M AFC 0 Divider F LO_BASE =2400.001M (BIP = 0x96) (BFP = 0x0004) + + F LO =2405.001M TI A X CHN / [4*(CHR+1)] (CH N=0x0A) (CHR = 7) L F XT AL=16M EN F O FFSET = 5M Figure 14.2 Block Diagram of FLO ~ 2405.001 MHz ( DBL + 1) × f XTAL RRC[1 : 0] + 1 C O FPFD = N FI D For different crystal frequency, 16MHz / 12MHz / 8 MHz / 6MHz, below are calculation details for (1) How to set FLO_BASE ~ 2400.001 MHz (2) How to set FLO ~ 2405.005 MHz C O M Recommend DBL = 0 FXTAL (MHz) DBL PRC FPFD (MHz) 16 0 0 16 12 0 0 12 8 0 0 8 6 0 0 6 Be notice if 6MHz external crystal (clock) is selected, A7125 only supports 1Mbps data rate. A M IC FLO _ BASE = FPFD × ( BIP[8 : 0] + FPFD (MHz) 16 12 8 6 FCHSP = BIP (integer part) 0x096 0x0C8 0x12C 0x190 BFP[15 : 0] ) 216 BFP (floating part) 0x0004 0x0005 0x0008 0x000A FLO_BASE (MHz) ~2400.001 ~2400.001 ~2400.001 ~2400.001 FPFD 4 × (CHR[3 : 0] + 1) FLO = FLO _ BASE + (CHN [7 : 0] × FCHSP ) Jul., 2011, v1.3 59 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver FCHSP (KHz) 2000 1000 500 250 CHN [7:0] 0x00 ~ 0x2A 0x00 ~ 0x54 0x00 ~ 0xA8 0x00 ~ 0xFF FOFFSET (MHz) 0 ~ 84 0 ~ 84 0 ~ 84 0 ~ 63.75 FLO (MHz) 2400 ~ 2484 2400 ~ 2484 2400 ~ 2484 Depends on FLO_BASE FXTAL = 12 MHz, How to set FCHSP FPFD (MHz) CHR [3:0] 12 2 12 5 12 11 FCHSP (KHz) 1000 500 250 CHN [7:0] 0x00 ~ 0x54 0x00 ~ 0xA8 0x00 ~ 0xFF FOFFSET (MHz) 0 ~ 84 0 ~ 84 0 ~ 63.75 FLO (MHz) 2400 ~ 2484 2400 ~ 2484 Depends on FLO_BASE FXTAL = 8 MHz, How to set FCHSP FPFD (MHz) CHR [3:0] 8 0 8 1 8 3 8 7 FCHSP (KHz) 2000 1000 500 250 CHN [7:0] 0x00 ~ 0x2A 0x00 ~ 0x54 0x00 ~ 0xA8 0x00 ~ 0xFF FOFFSET (MHz) 0 ~ 84 0 ~ 84 0 ~ 84 0 ~ 63.75 EN TI A L FXTAL = 16 MHz, How to set FCHSP FPFD (MHz) CHR [3:0] 16 1 16 3 16 7 16 15 FLO (MHz) 2400 ~ 2484 2400 ~ 2484 2400 ~ 2484 Depends on FLO_BASE A M IC C O M C O N FI D FXTAL = 6 MHz, How to set FCHSP FPFD (MHz) CHR [3:0] FCHSP (KHz) CHN [7:0] FOFFSET (MHz) FLO (MHz) 6 2 500 0x00 ~ 0xA8 0 ~ 84 2400 ~ 2484 6 5 250 0x00 ~ 0xFF 0 ~ 63.75 Depends on FLO_BASE Be notice if 6MHz external crystal (clock) is selected and DBL=0, A7125 only supports 1Mbps data rate. Jul., 2011, v1.3 60 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 14.2 IF Side Band Select In two ways radio, both master and slave have two roles, TX and RX. In general, slave usually has to reply an ACK-packet or status update. In such case, A7125 offers two methods to set up FLO while TRX exchanging. (1) Auto IF exchange (2) Fast exchange Relative Control Register R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Name R W DDPC DDPC 0 ARSSI ARSSI 0 AIF AIF 0 CD DFCD 0 WWSE WWSE 0 FMT FMT 0 Reset R/W Bit 7 Bit 6 Bit 5 Bit 4 W --- RXSM1 1 RXSM0 0 FC 0 Bit 0 FMS FMS 0 ADCM ADCM 0 Bit 3 Bit 2 Bit 1 Bit 0 RXDI 0 DMG 0 RAW 1 ULS 0 FI D Bit Name Reset EN RX Register (Address: 19h) Bit 1 TI A Bit L Mode Control Register (Address: 01h) FRXLO Formula FRXLO = FLO FRXLO = FLO FRXLO = FLO - 2MHz FRXLO = FLO + 2MHz AIF Function Disable (AIF=0) Enable (AIF=1) C O N Register Setting ULS=0 ULS=1 ULS=0 ULS=1 A M IC C O M Table 14.3 FRXLO Formula Jul., 2011, v1.3 61 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 14.2.1 Auto IF Exchange A7125 supports Auto IF offset function (AIF, 01h). If AIF is enabled, only one On-air frequency (Fcarrier) is occupied. In this case, user has no need to change FRXLO while TRX exchanging because FRXLO is auto shifted FIF. See below Figures and Table 14.4 for details. AIF=1 and ULS=0, FRXLO is auto shifted lower than FTXLO for 2MHz (FIF). FLO_BASE L FTXLO = FLO = FCarrier FOFFSET =5MHz TI A FRXLO AIF=1 and ULS=0, FRXLO is auto shifted lower than FTXLO for 2MHz (FIF). EN FIF 2MHz FLO_BASE N FRXLO FOFFSET =5MHz AIF Master TX 1 RX 1 TX 10 FCHSP (KHz) 500 FTXLO (KHz) 2405.001 0 0 10 500 - 1 0 10 500 2405.001 1 0 10 500 - FRXLO (MHz) - NOTE 2403.001 Up side band FRXLO is auto shifted 2403.001 Up side band FRXLO is auto shifted Above setting is the same to Master and Slave. A M IC Role Exchanging Switching Time CHN[7:0] C RX ULS O Slave C O Role FIF 2MHz M Item FI D FTXLO = FLO = FCarrier On air frequency Refer to Figure 11.4, If A7125 delivers one packet and receives one packet, FLO is changed from 2405.001 to 2403.001, longer switching time. Total Switching time = TX ready time + RX ready time =( 30 us + 60 us) + ( 30 us + 60 us) = 180 us Master FTXLO = 2405.001 MHz Slave FTXLO = 2405.001 MHz (ONE occupied frequency only.) Table 14.4 AIF function while TRX exchanging 14.2.2 Fast Exchange To reduce PLL settling time, user can disable AIF function. If AIF is disabled, two On-air frequency (FCarrier (master), FCarrier are occupied. In this case, user has to control ULS =0 (Master side) and ULS = 1 (Slave side) for fast exchange in two-way radio. See below Figures and Table 14.5 for details. (slave)) Jul., 2011, v1.3 62 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver AIF=0 and ULS=0, Master is set Up side band. FTXLO = FLO = FCarrier (Master) FLO_BASE L FRXLO TI A FOFFSET =5MHz FIF 2M AIF=0 and ULS=1, Slave is set Low side band. EN FTXLO= FLO = FCarrier (Slave) FLO_BASE FI D FRXLO N FOFFSET =7MHz Role AIF ULS CHN[7:0] Master TX 0 0 RX 0 TX 0 RX 0 0 10 500 - 1 14 500 2407.001 1 14 500 - M FRXLO (MHz) - NOTE 2405.001 Up side band 2407.001 Low side band O ULS and CHN setting are different in Master and Slave site. Refer to Figure 11.4, If A7125 delivers one packet and receives one packet, Master’s FLO is fixed at 2405.001MHz, shorter settling time. IC Role Exchanging Switching Time FTXLO (KHz) 2405.001 C Slave 10 FCHSP (KHz) 500 C O Item A M Total Settling time = TX ready time + RX ready time = ( 10 us + 60 us) + ( 10 us + 60 us) = 140 us On air frequency Master FTXLO = 2405.001 MHz Slave FTXLO = 2407.001 MHz (TWO occupied on-air frequency.) Table 14.5 Fast exchange function while TRX exchanging 14.3 Band Edge Frequency Setting For 2.4GHz ISM band, it is free licensed from 2400 MHz to 2483.5 MHz. Due to regulation criteria, in general, most of applications are avoided to use band edge of 2400MHz and 2483.5MHz. Therefore, in such cases, user can define specific band edges and set different FLO_BASE. Combined with different channel step FCHSP, user can gain different on air channel numbers. See table 14.1 for reference. User Defined User Defined (Low Band Edge) (High Band Edge) Cover Range (MHz) FLO_BASE (MHz) FCHSP (KHz) On air Channel NOTE (recommended) Jul., 2011, v1.3 63 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 2400 MHz 2483.5 MHz 83.5 MHz ~2400.001 2405 MHz 2477.0 MHz 72.0 MHz ~2405.001 2405 MHz 2467.0 MHz 62.0 MHz ~2405.001 2410 MHz 2463.0 MHz 52.0 MHz Numbers 42 2000 1000 500 2000 1000 500 2.0 MHz / on air channel step 2.0 MHz / on air channel step 2000 1000 500 32 2.0 MHz / on air channel step ~2410.001 2000 1000 500 27 FCHSP (KHz) Cover Range (MHz) FLO_BASE (MHz) 2405 MHz 2468.0 MHz 63.0 MHz ~2405.001 2410 MHz 2462.5 MHz 52.5 MHz ~2405.001 2.0 MHz / on air channel step TI A User Defined (High Band Edge) 250 On air Channel Numbers 37 250 31 EN User Defined (Low Band Edge) L 37 NOTE 1.75 MHz / on air channel step 1.75 MHz / on air channel step FI D Be notice, if FCHSP = 250 KHz, due to limitation of CHN [7:0], max cover range of FLO is 63.75MHz. Table 14.6 Band edge frequency setting vs. on air channel number C O N In long distance applications, user usually adds external PA (Ext-PA) to extend TX power level up 10dBm ~ 20 dBm. To gain the most available hopping channels under FCC / ETSI regulations, user has to switch off Ext-PA before A7125’s PA (Em-PA) to minimize spurious emission. In the other words, band edge becomes critical so that A7125 supports two methods (EOPD and PASW) to let user switch Ext-PA easily. A M IC C O M (1) EOPD (End Of Packet Delay) Set GIO2S = [1100] and EOPDS=1, then EOPD outputs 20 us pulse to GIO2 pin. Jul., 2011, v1.3 64 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver C O M C O N FI D EN TI A L (2) PASW (Ext-PA Switch) Set GIO2S = [0001] and EOPDS=1, then PASW outputs to GIO2 pin. However, GIO2S[3:0] shall be set different in TX mode [ 0001] and RX mode [0100] to avoid FSYNC conflict in RX mode. Therefore, before issue TX Strobe command, write GIO2S = [0001]. Before issue RX Strobe command, write GIO2S = [0100]. Then, PASW is only active in TX mode. In such case, user just needs to connect GIO2 pin to control external PA as shown below. Generally, this procedure could support sufficient band edge control. In more rigorous condition, it is recommended to switch GIO2S from [0100] to [0001] after delaying 30us counting from TX strobe command. IC 14.4 Frequency Compensation A M AFC (Auto Frequency Compensation) function supports low accuracy crystal without sensitivity degradation. If AFC=1 (19h), bit error rate is optimized because AFC circuitry adjusts RX LO frequency (FRXLO) to compensate crystal drift automatically. F LO F PFD F XTAL X (DBL+1) / (RRC[1:0]+1) AC[14:0]/ 2 16 0 BIP[8:0] + BFP[15:0]/ 2 16 F LO_BASE + CHN / [4*(CHR+1)] VCO PFD 1 Divider 0 AFC + F LO F OFFSET Figure 14.3 Block Diagram of enabling FC function Jul., 2011, v1.3 65 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver Relative Control Register RX Register (Address: 19h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W --- RXSM1 1 RXSM0 0 AFC 0 RXDI 0 DMG 0 RAW 1 ULS 0 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 PLL Register IV (Address: 11h) Bit 7 Name R W --/FP15 Reset BFP15 0 BFP14 0 BFP13 0 BFP12 0 BFP11 0 PLL Register V (Address: 12h) Bit 0 AC8/FP8 BFP9 0 BFP8 0 R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name R W AC7/FP7 AC6/FP6 AC5/FP5 AC4/FP4 AC3/FP3 BFP7 0 BFP6 0 BFP5 0 BFP4 0 AC2/FP2 AC1/FP1 AC0/FP0 BFP2 1 BFP1 0 BFP0 0 BFP10 0 EN Bit BFP3 0 A M IC C O M C O N FI D Reset Bit 1 AC9/FP9 AC14/FP14 AC13/FP13 AC12/P12 AC11/ FP11 AC10/FP10 L R/W TI A Bit Jul., 2011, v1.3 66 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 15. Calibration A7125 needs calibration process during initialization by below 5 items, they are, VCO Current, VCO Bank, VCO Deviation, IF Filter Bank and RSSI Calibration. 1. 2. 3. 4. 5. VCO Current Calibration is to find adequate VCO current. VCO Bank Calibration is to select best VCO frequency bank for the calibrated frequency. VCO Deviation Calibration is to calibrate 500 KHz deviation of VCO. IF Filter Bank Calibration is to calibrate IF filter bandwidth and center frequency. RSSI Calibration is to find the RSSI value corresponding to -70dBm RF input and RSSI curve. TI A L Be notice that VCO Current, Bank and Deviation is calibrated in PLL mode by sequence. IF Filter Bank and RSSI can be calibrated either in standby or PLL mode. User can set A7125 in PLL mode and enable 5 control registers together, then, all calibration procedures are automatically executed and its results are stored in calibration flags. Relative Control Register R/W Bit 7 Bit 6 Bit 5 Bit 4 Name Reset R/W --- --- --- VCC 0 15.1 Calibration Procedure Bit 1 Bit 0 VBC 0 VDC 0 FBC 0 RSSC 0 N Initialize all control registers (refer to A7125 reference code). Select auto value mode (set MFBS, MVCS, MVBS, MVDS= 0). Set A7125 in PLL mode. Enable IF Filter Bank and RSSI Calibration (set FBC, RSSC= 1) and Enable VCO Current, Bank and Deviation Calibration (VCC, VBC, VDC= 1). After calibration done, FBC, RSSC, VCC, VBC and VDC are auto clear. Check pass or fail by calibration flag (FBCF) and (VCCF, VBCF). M 5. 6. Bit 2 C O 1. 2. 3. 4. Bit 3 FI D Bit EN Calibration Control Register (Address: 02h) 15.2 IF Filter Bank Calibration R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name R W ---- ---- ---- FBCF MFBS 0 FB3 MFB3 0 FB2 MFB2 1 FB1 MFB1 1 FB0 MFB0 0 IC C Bit Reset Initialize all control registers (refer A7125 reference code). Set MFBS= 0 for auto calibration. Set A7125 in PLL mode. Set FBC= 1 (02h). The maximum calibration time for this calibration is about 64us. FBC is auto clear after calibration done. User can read calibration flay (FBCF, 23h) to check pass or fail. User also can read FB [3:0] (23h) to get the auto calibration value. A M 1. 2. 3. 4. 5. 6. 7. 8. O IF Calibration Register I (Address: 23h) 15.3 RSSI Calibration 1. 2. 3. Initialize all control registers (refer A7125 reference code). Set A7125 in PLL mode. Set RSSC= 1 (02h). RSSC is auto clear after calibration done. Jul., 2011, v1.3 67 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 4. No need to check calibration flag. 15.4 VCO Current Calibration VCO Current Calibration Register (Address: 25h) R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name R W ---- ---- -VCCS 1 VCCF MVCS 0 VCB3 VCOC3 1 VCB2 VCOC2 1 VCB1 VCOC1 0 VCB0 VCOC0 0 Reset VCO Bank Calibration Register I (Address: 26h) R/W Bit 7 Bit 6 Bit 5 Name R W -DDC1 1 -DDC0 1 -DAGS 0 Bit 3 Bit 2 Bit 1 Bit 0 ---- VBCF MVBS 0 VB2 MVB2 1 VB1 MVB1 0 VB0 MVB0 0 C O O M Initialize all control registers (refer A7125 reference code). Set MVBS= 0 for auto calibration. Set A7125 in PLL mode. Set VBC= 1 (02h). The maximum calibration time for VCO Bank Calibration is about 240 us (4 * PLL settling time). VBC is auto clear after calibration done. User can read calibration flag (VBCF, 26h) to check pass or fail. User can read VB [2:0] (26h) to get the auto calibration value. C 1. 2. 3. 4. 5. 6. 7. 8. Bit 4 N Bit Reset EN 15.5 VCO Bank Calibration TI A Initialize all control registers (refer A7125 reference code). Set MVCS= 0 for auto calibration. Set A7125 in PLL mode. Set VCC= 1 (02h). VCC is auto clear after calibration done. User can read calibration flag (VCCF, 25h) to check pass or fail. User can read VCB [3:0] (25h) to get the auto calibration value. FI D 1. 2. 3. 4. 5. 6. 7. L Bit 15.6 VCO Deviation Calibration IC VCO Deviation Calibration Register II (Address: 29h) R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name R W ADEV7 MVDS 0 ADEV6 MDEV6 0 ADEV5 MDEV5 1 ADEV4 MDEV4 0 ADEV3 MDEV3 1 ADEV2 MDEV2 0 ADEV1 MDEV1 0 ADEV0 MDEV0 0 A M Bit Reset 1. 2. 3. 4. 5. 6. 7. Initialize all control registers (refer A7125 reference code). Set MVDS= 0 for auto calibration. Set A7125 in PLL mode. Set VDC= 1 (02h). VDC is auto clear after calibration done. User can read ADEV [7:0] (29h) to get the auto calibration value. No need to check calibration flag. 15.7 Channel Group Function Channel group function is used for VCO calibration that supports to increase the accuracy of VCO Current, Bank and Deviation. By this function, user can easily set Channel Group Register I and II (13h, 14h) to get 2.4G ISM band into 3 groups as shown below. Then, choose middle frequency (2415MHz / 2445MHz / 2475MHz) of 3 groups to do the VCO Jul., 2011, v1.3 68 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver Current, Bank and Deviation Calibration. Below is an example of channel group distribution. 2415 M Hz 2445 M Hz 2475 M Hz IS M b a n d 2460 M Hz (C H G H ) 2 4 8 3 .5 M H z L 2430 M Hz (C H G L ) TI A 2400M H z Figure 15.1 Channel Group setting of VCO calibration Channel Group Register I (Address: 13h) Bit 7 Bit 6 Bit 5 Bit 4 Name Reset R/W CHGL7 0 CHGL6 0 CHGL5 1 CHGL4 1 Channel Group Register II (Address: 14h) Bit 3 R/W Bit 7 Bit 6 Bit 5 R/W CHGH7 0 CHGH6 1 CHGH5 1 Bit 1 Bit 0 CHGL3 1 CHGL2 1 CHGL1 0 CHGL0 0 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 CHGH4 1 CHGH3 1 CHGH2 0 CHGH1 0 CHGH0 0 N Bit Name Reset Bit 2 EN R/W FI D Bit BFP (floating part) 0x0004 0x0005 0x0008 0x000A FLO_BASE (MHz) FCHSP (KHz) CHGL[7:0] CHGH[7:0] ~2400.001 ~2400.001 ~2400.001 ~2400.001 500 500 500 500 0x3C 0x3C 0x3C 0x3C 0x78 0x78 0x78 0x78 A M IC C O 16 12 8 6 BIP (integer part) 0x096 0x0C8 0x12C 0x190 M FPFD (MHz) C O See below table for setting CHGL and CHGH to get 2430MHz and 2460MHz respectively. Jul., 2011, v1.3 69 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 16. FIFO (First In First Out) A7125 supports separated 64-bytes TX and RX FIFO by enabling FMS =1 (01h). For FIFO accessing, TX FIFO (write-only) and RX FIFO (read-only) share the same register address 05h. TX FIFO represents transmitted payload. On the other hand, once RX circuitry synchronizes ID Code, received payload is stored into RX FIFO. L In chapter 10 and 11, user can also find below FIFO information. (1) Figure 10.15 and 10.16 for FIFO accessing via 3-wire SPI. (2) Section 10.4.7 and 10.4.8 for FIFO pointer reset command. (3) Figure 11.2 and Figure 11.3 for Normal/Quick FIFO mode. TI A 16.1 Packet Format of FIFO mode P re a m b le ID c o d e 4 b yte s 4 b yte s EN D a ta w h ite n in g (o p tio n a l) F E C e n co d e d /d e c o de d (o p tio n a l) C R C -1 6 c a lcu la tio n (o p tio n a l) P a y lo a d M a x . 2 5 6 b y te s (C R C ) 2 b yte s FI D Figure 16.1 Packet Format of FIFO mode ID Byte 1 ID Byte 2 ID Byte 3 C O ID Byte 0 N ID code Figure 16.2 ID Code Format O M Preamble: The packet is led by preamble which is composed of alternate 0 and 1. If the first bit of ID code is 0, preamble shall be 0101…0101. In the contrast, if the first bit of ID code is 1, preamble shall be 1010…1010. Preamble length is recommended to set 4 bytes by PML [1:0] (20h). IC C ID code: ID code is recommended to set 4 bytes by IDL=1 (20h) and ID Code is sequenced by ID Byte 0, 1, 2 and 3. If RX circuitry check ID code is correct, payload will be written into RX FIFO. In special case, ID code could be set error tolerance (0~ 3bit error) by ETH [1:0] (21h) for ID synchronization check. A M Payload: Payload length is programmable by FEP [7:0] (03h). The physical FIFO depth is 64 bytes. A7125 also supports logical FIFO extension up to 256 bytes. See section 16.5 for details. CRC (option): In FIFO mode, if CRC is enabled (CRCS=1, 20h), 2-bytes of CRC value is transmitted automatically after payload. In the same way, RX circuitry will check CRC value and show the result to CRC Flag (00h).CRC Flag is updated by each received packet. Relative Control Register Mode Register (Address: 00h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name R W -RESETN -- FECF RESETN -- CRCF RESETN -- CER RESETN -- XER RESETN -- PLLER RESETN -- TRSR RESETN -- TRER RESETN -- Reset Jul., 2011, v1.3 70 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver FIFO Register I (Address: 03h) Bit R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W FEP7 0 FEP6 0 FEP5 1 FEP4 1 FEP3 1 FEP2 1 FEP1 1 FEP0 1 Code Register I (Address: 20h) R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 W --- --- WHTS 0 FECS 0 CRCS 0 IDL 1 PML1 1 PML0 1 L Bit Name Reset R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Name Reset W --- DCL2 1 DCL1 1 DCL0 1 ETH1 0 Code Register III (Address: 22h) R/W Bit 7 Bit 6 Bit 5 Bit 4 W --- WS6 0 WS5 1 WS4 0 Bit 1 Bit 0 ETH0 1 PMD1 1 PMD0 1 Bit 3 Bit 2 Bit 1 Bit 0 WS3 1 WS2 0 WS1 1 WS0 0 FI D Bit Name Reset Bit 2 EN Bit TI A Code Register II (Address: 21h) 16.2 Bit Stream Process C O N A7125 supports 3 optional bit stream process for payload, they are, (1) CCITT-16 CRC (2) (7, 4) Hamming FEC (3) Data Whitening by XOR PN7 (7-bits Pseudo Random Sequence). O M CRC (Cyclic Redundancy Check): 1. CRC is enabled by CRCS= 1 (20h). TX circuitry calculates the CRC value of payload (preamble, ID code excluded) and transmits 2-bytes CRC value after payload. 2. RX circuitry checks CRC value and shows the result to CRC Flag (00h). If CRCF=0, received payload is correct, else error occurred. (CRCF is read only, it is updated by each valid packet.) IC C FEC (Forward Error Correction): 1. FEC is enabled by FECS= 1 (20h). Payload and CRC value (if CRCS=1) are encoded by (7, 4) Hamming code. 2. Each 4-bits (nibble) of payload is encoded into 7-bits code word and delivered out automatically. (ex. 64 bytes payload will be encoded to 128 code words, each code word is 7 bits.) 3. RX circuitry decodes received code words automatically. FEC supports 1-bit error correction each code word. Once 1-bit error occurred, FEC flag=1 (00h). (FECF is read only, it is updated by each valid packet.) A M Data Whitening: 1. Data whitening is enabled by WHTS= 1 (20h). Payload and CRC value (if CRCS=1) or their encoded code words (if FECS=1) are encrypted by bit XOR operation with PN7. The initial seed of PN7 is set by WS [6:0] (22h). 2. RX circuitry decrypts received payload and 2-bytes CRC (if CRCS=1) automatically. Be notice, user shall set the same WS [6:0] (22h) to TX and RX. 16.3 Transmission Time Based on CRC and FEC options, the transmission time are different. See table 16.1 for details. Data Rate = 2 Mbps Data Rate Preamble (Mbps) (bits) 2 32 2 32 2 32 2 32 Jul., 2011, v1.3 ID Code Payload CRC FEC (bits) (bits) (bits) 32 512 Disable Disable 32 512 16 bits Disable 32 512 Disable 512 * 7 / 4 32 512 16 * 7 / 4 512 * 7 / 4 Table 16.1 Transmission time of 2 Mbps data rate 71 Transmission Time / Packet 576 bit * 0.5 us = 288 us 592 bit * 0.5 us = 296 us 960 bit * 0.5 us = 480 us 988 bit * 0.5 us = 494 us AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver Data Rate = 1 Mbps Data Rate Preamble (Mbps) (bits) 1 32 1 32 1 32 1 32 Transmission Time / Packet 576 bit * 1.0 us = 576 us 592 bit * 1.0 us = 592 us 960 bit * 1.0 us = 960 us 988 bit * 1.0 us = 988 us L ID Code Payload CRC FEC (bits) (bits) (bits) 32 512 Disable Disable 32 512 16 bits Disable 32 512 Disable 512 * 7 / 4 32 512 16 * 7 / 4 512 * 7 / 4 Table 16.2 Transmission time of 1 Mbps data rate TI A 16.4 Usage of TX and RX FIFO EN In application points of view, A7125 supports 3 options of FIFO arrangement. (1) Easy FIFO (2) Segment FIFO (3) FIFO Extension Strobe Command Strobe Command A7 A6 A5 A4 A3 A2 A1 A0 1 1 1 1 1 1 0 1 x x x x X X x x FI D For FIFO operation, A7125 supports Strobe command to reset TX and RX FIFO pointer as shown below. User can refer to section 10.5 for FIFO write pointer reset and FIFO read pointer reset. Description N FIFO write pointer reset (for TX FIFO) FIFO read pointer reset (for RX FIFO) C O FIFO Register I (Address: 03h) R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name Reset W FEP7 0 FEP6 0 FEP5 1 FEP4 1 FEP3 1 FEP2 1 FEP1 1 FEP0 1 M Bit O FIFO Register II (Address: 04h) R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 W FPM1 0 FPM0 1 PSA5 0 PSA4 0 PSA3 0 PSA2 0 PSA1 0 PSA0 0 R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 R/W FIFO7 0 FIFO6 0 FIFO5 0 FIFO4 0 FIFO3 0 FIFO2 0 FIFO1 0 FIFO0 0 IC C Bit Name Reset FIFO DATA Register (Address: 05h) A M Bit Name Reset 16.4.1 Easy FIFO In Easy FIFO, max FIFO length is 64 bytes. FIFO length is equal to (FEP [7:0] +1). User just needs to control FEP [7:0] (03h) and disable PSA and FPM as shown below. Register setting TX RX FIFO Length (byte) 1 FIFO Length (byte) 1 Jul., 2011, v1.3 Control Registers FEP[7:0] (03h) PSA[5:0] (04h) FPM[1:0] (04h) 0x00 0 0 72 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 8 16 32 64 8 16 32 64 0x07 0x0F 0x1F 0x3F 0 0 0 0 0 0 0 0 Table 16.3 Control registers of Easy FIFO TI A L Procedures of TX FIFO Transmitting 1. Initialize all control registers (refer A7125 reference code). 2. Set FEP [7:0] = 0x3F for 64-bytes FIFO. 3. Refer to Figure 11.2 and Figure 11.3 4. Send Strobe command – TX FIFO write pointer reset. 5. MCU writes 64-bytes data to TX FIFO. 6. Send TX Strobe Command. 7. Done. A M IC C O M C O N FI D EN Procedures of RX FIFO Reading 1. When RX FIFO is full, WTR (or FSYNC) can be used to trigger MCU for RX FIFO reading. 2. Send Strobe command – RX FIFO read pointer reset. 3. MCU read 64-bytes from RX FIFO. 4. Done. Figure 16.3 Easy FIFO 16.4.2 Segment FIFO In Segment FIFO, TX FIFO length is equal to (FEP [7:0] - PSA [5:0]+1). FPM [1:0] should be zero. This function is very useful for button applications. In such case, each button is used to transmit fixed code (data) every time. During initialization, each fixed code is written into corresponding segment FIFO once and for all. Then, if button is triggered, MCU just assigns corresponding segment FIFO (PSA [5:0] and FEP [7:0]) and issues TX strobe command. If TX FIFO is arranged into 8 segments, each TX segment and RX FIFO length are 8 bytes TX Segment Jul., 2011, v1.3 PSA Control Registers FEP FIFO Length PSA[5:0] (04h) 73 FEP[7:0] (03h) FPM[1:0] (04h) AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver PSA1 PSA2 PSA3 PSA4 PSA5 PSA6 PSA7 PSA8 (byte) 8 8 8 8 8 8 8 8 FEP1 FEP2 FEP3 FEP4 FEP5 FEP6 FEP7 FEP8 0x07 0x0F 0x17 0x1F 0x27 0x2F 0x37 0x3F 0 0 0 0 0 0 0 0 Control Registers FIFO Length (byte) 8 PSA[5:0] (04h) FEP[7:0] (03h) FPM[1:0] (04h) 0 0x07 0 TI A RX 0x00 0x08 0x10 0x18 0x20 0x28 0x30 0x38 L 1 2 3 4 5 6 7 8 EN Table 16.4 Segment FIFO is arranged into 8 segments M C O N FI D Procedures of TX FIFO Transmitting 1. Initialize all control registers (refer A7125 reference code). 2. Refer to Figure 11.2 and Figure 11.3 (in chapter 11). 3. Send Strobe command – TX FIFO write pointer reset. 4. MCU writes fixed code into corresponding segment FIFO once and for all. 5. To consign Segment 1, set PSA = 0x00 and FEP= 0x07 To consign Segment 2, set PSA = 0x08 and FEP= 0x0F To consign Segment 3, set PSA = 0x10 and FEP= 0x17 To consign Segment 4, set PSA = 0x18 and FEP= 0x1F To consign Segment 5, set PSA = 0x20 and FEP= 0x27 To consign Segment 6, set PSA = 0x28 and FEP= 0x2F To consign Segment 7, set PSA = 0x30 and FEP= 0x37 To consign Segment 8, set PSA = 0x38 and FEP= 0x3F 6. Send TX Strobe Command. 7. Done. A M IC C O Procedures of RX FIFO Reading 1. When RX FIFO is full, WTR (or FSYNC) is used to trigger MCU for RX FIFO reading. 2. Send Strobe command – RX FIFO read pointer reset. 3. MCU read 8-bytes from RX FIFO. 4. Done. Jul., 2011, v1.3 74 AMICCOM Electronics Corporation A7125 FI D EN TI A L 2.4GHz FSK Transceiver A M IC C O M C O N Figure 16.4 Segment FIFO Mode Jul., 2011, v1.3 75 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 16.4.3 FIFO Extension In FIFO Extension, FIFO length is equal to (FEP [7:0] +1). PSA [5:0] shall be zero, and FPM [1:0] is used to set FIFO Pointer Flag (FPF) to MCU. FIFO extension could be set up to 256 bytes by FEP [7:0] with different FPF trigger conditions. Be notice, setting of SPI data rate is important to prevent error operation of FIFO extension. The min. SPI data rate shall be equal or greater than (A125 data rate + 500Kbps) and refer Table 16.4 and 16.5 for max. SPI Data Rate. If A7125 data rate = 2Mbps and FIFO extension = 256 bytes. RX 256 FIFO Length (byte) Max. SPI Data Rate 10 Mbps 10 Mbps 10 Mbps 8 Mbps 256 FPF Trigger Condition Delta = 60 Delta = 56 Delta = 52 Delta = 48 Max. SPI Data Rate 10 Mbps 10 Mbps 10 Mbps 8 Mbps FEP[7:0] L FPF Trigger Condition Delta = 04 Delta = 08 Delta = 12 Delta = 16 0xFF EN FIFO Length (byte) Control Registers FPM[1:0] PSA[5:0] 00 01 10 11 0 0 0 0 TI A TX FI D Table 16.5 How to set FIFO extension when A7125 is at 2Mbps data rate If A7125 data rate = 1Mbps and FIFO extension = 256 bytes. FPF Trigger Condition Delta = 04 Delta = 08 Delta = 12 Delta = 16 10 Mbps 8 Mbps 5 Mbps 4 Mbps FIFO Length (byte) FPF Trigger Condition Delta = 60 Delta = 56 Delta = 52 Delta = 48 Max SPI Data Rate 256 10 Mbps 8 Mbps 5 Mbps 4 Mbps Control Registers FEP[7:0] FPM[1:0] PSA[5:0] 0xFF 00 01 10 11 0 0 0 0 M 256 Max SPI Data Rate C O FIFO Length (byte) RX N TX Table 16.6 How to set FIFO extension when A7125 is at 1Mbps data rate O Please refer to AMICCOM’s reference code (FIFO extension) for details. A M IC C Procedures of TX FIFO Extension 1. Initialize all control registers (refer A7125 reference code). 2. Set FEP [7:0] = 0xFF for 256-bytes FIFO extension. 3. Set FPM [1:0] = 11 for FPF trigger condition. 4. Set CKO Register = 0x12 5. Send Strobe command – TX FIFO write pointer reset. 6. MCU writes 1st 64-bytes TX FIFO. 7. Send TX Strobe command. 8. MCU monitors FPF from A7125’s CKO pin. 9. FPF triggers MCU to write 2nd 48-bytes TX FIFO. 10. Monitor FPF. 11. FPF triggers MCU to write 3rd 48-bytes TX FIFO. 12. Monitor FPF. 13. FPF triggers MCU to write 4th 48-bytes TX FIFO. 14. Monitor FPF. 15. FPF triggers MCU to write 5th 48-bytes TX FIFO. 16. Done. Jul., 2011, v1.3 76 AMICCOM Electronics Corporation A7125 A M IC C O M C O N FI D EN TI A L 2.4GHz FSK Transceiver Figure 16.5 TX FIFO Extension Jul., 2011, v1.3 77 AMICCOM Electronics Corporation A7125 TI A A M IC C O M C O N FI D EN Procedures of RX FIFO Reading 1. Initialize all control registers (refer A7125 reference code). 2. Set FEP [7:0] = 0xFF for 256-bytes FIFO extension. 3. Set FPM [1:0] = 11b for FPF trigger condition. 4. Set CKO Register = 0x12 5. Send Strobe command – RX FIFO read pointer reset. 6. Send RX Strobe command. 7. MCU monitors FPF from A7125’s CKO pin. 8. FPF triggers MCU to read 1st 48-bytes RX FIFO. 9. Monitor FPF. 10. FPF triggers MCU to read 2nd 48-bytes RX FIFO. 11. Monitor FPF. 12. FPF triggers MCU to read 3rd 48-bytes RX FIFO. 13. Monitor FPF. 14. FPF triggers MCU to read 4th 48-bytes RX FIFO. 15. Monitor FPF. 16. FPF triggers MCU to read 5th 48-bytes RX FIFO. 17. Monitor WTR falling edge or WTR = low, read the rest 16-bytes RX FIFO 18. Done. L 2.4GHz FSK Transceiver Jul., 2011, v1.3 78 AMICCOM Electronics Corporation A7125 FI D EN TI A L 2.4GHz FSK Transceiver A M IC C O M C O N Figure 16.6 RX FIFO Extension Mode Jul., 2011, v1.3 79 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 16.5 Optimize Throughput A M IC C O M C O N FI D EN TI A Pre-Conditions: 1. A7125’s data rate = 2Mbps. 2. Min. requirement of CPU SPI bus = 2.5 Mbps > A7125’s data rate. 3. If MCU SPI bus = 8Mbps and ignore guard time of SPI. i. Write TX-FIFO = (addr+data) * 0.125 us = (1+64) * 8 * 0.125 = 65 us. ii. Read RX-FIFO = (addr+data) * 0.125 us = (1+64) * 8 * 0.125 = 65 us. 4. CRC is enabled. 5. Use Easy FIFO mode (64 bytes). 6. One packet = Preamble + ID + Payload + CRC = (4+4+64+2) * 8 = 592 bit. 7. One packet transmission time = 592 bits * 0.5 = 296 us. 8. W=1 us if EOPDS = 0; W=23.5 us if EOPDS = 1 9. One frequency channel for n-packets. 10. MCU monitors WTR. L To get the best throughput during two-way radio transmission, user can use FIFO Extension mode, section 16.4.3, to reduce overhead of preamble, ID, settling time delay of PDL and TDL. The disadvantage of FIFO Extension is more MCU loading and overhead of retransmission time if packet lost. In another way, by Easy FIFO mode, If MCU’s SPI bus ≧ 2.5Mbps, user can use WTR signal to Read / Write FIFO during PDL+TDL settling time to gain more throughput. See below illustrations with pre-conditions. However, If MCU’s SPI bus < 2.5Mbps and EOPD =1 for band edge optimization in adding Ext-PA application, user can use EOP signal to Write FIFO to gain a few throughput. See below illustrations with pre-conditions. Jul., 2011, v1.3 80 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver TXStrobe Cmd TXStrobe Cmd Packet 2 70us 296 us (PDL+TDL) Packet n EN Packet 1 90us (PDL+TDL) GIO1 Pin - WTR (GIO1S[3:0]=0000) TI A TXStrobe Cmd L Pre-Conditions: 1. A7125’s data rate = 2Mbps. 2. If MPU SPI bus = 1Mbps and ignore guard time of SPI, CRCF Check and MCU’s ISR. i. Write TX-FIFO = (addr+data) * 1 us = (1+64) * 8 * 1 = 520 us. ii. Read RX-FIFO = (addr+data) * 1 us = (1+64) * 8 * 1 = 520 us. 3. CRC is enabled. 4. Use Easy FIFO mode (64 bytes). 5. One packet = Preamble + ID + Payload + CRC = (4+4+64+2) * 8 = 592 bit. 6. One packet transmission time = 592 bits * 0.5 = 296 us. 7. EOPDS = 1. 8. One frequency channel for n-packets. 9. MCU monitors EOP. 70us 296 us (PDL+TDL) 23.5 us 23.5 us 23.5 us FI D GIO1 Pin - EOP (GIO1S[3:0]=1100) 296 us 520 us 520 us Write TX-FIFO (64 bytes) N Write TX-FIFO (64 bytes) C O Total Transmitting Time (Master Site in TX Mode) RXStrobe Cmd M RXStrobe Cmd Packet 1 90us (PDL+TDL) 296 us Packet 2 70us (PDL+TDL) A M IC C 23.5 us GIO1 Pin - EOP (GIO1S[3:0]=1100) Jul., 2011, v1.3 Packet n 70us 296 us O GIO1 Pin - WTR (GIO1S[3:0]=0000) RXStrobe Cmd 520 us Read RX-FIFO (64 bytes) (PDL+TDL) 296 us 23.5 us 23.5 us 520 us 520 us Read RX-FIFO (64 bytes) Read RX-FIFO (64 bytes) Total Receiving Time (Slave Site in RX Mode) 81 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 17. ADC (Analog to Digital Converter) A7125 has built-in 8-bits ADC that supports multi-functions to do temperature measurement, RSSI, carrier detection. User can set FSARS (1Fh) to select 4MHz or 8MHz ADC clock (FADC). The converting time is 20 times of ADC clock periods. RX mode None RSSI / Carrier detect None Table 17.1 ADC Function List. Mode Control Register (Address: 01h) R/W Bit 7 Bit 6 Bit 5 Bit 4 Name R W DDPC DDPC 0 ARSSI ARSSI 0 AIF AIF 0 CD DFCD 0 RX Gain Register IV (Address: 1Dh) R/W Bit 7 Bit 6 Bit 5 W AVSEL1 0 AVSEL0 1 MVSEL1 0 Bit 7 Name R W ADC7 RTH7 1 Reset Bit 0 WWSE WWSE 0 FMT FMT 0 FMS FMS 0 ADCM ADCM 0 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 MVSEL0 0 LHC1 1 LHC0 1 AGCE 0 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 ADC6 RTH6 0 ADC5 RTH5 0 ADC4 RTH4 1 ADC3 RTH3 0 ADC2 RTH2 0 ADC1 RTH1 0 ADC0 RTH0 1 C O R/W Bit 1 MHC 1 M Bit Bit 2 N Bit Name Reset RSSI Threshold Register (Address: 1Eh) Bit 3 FI D Bit EN Relative Control Register Reset L RSS 0 1 X Description Standby mode Temperature None Reserved TI A Bit XADS 0 0 1 O ADC Control Register (Address: 1Fh) R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 W RSM1 0 RSM0 1 RADC1 0 RADC0 0 FSARS 1 XADS 0 RSS 1 CDM 1 IC C Bit Name Reset A M 17.1 Temperature Measurement A7125 has built-in thermal sensor. Combined with 8-bits ADC, it can be used to monitor the relative environment temperature. Below is the measurement procedure: 1. 2. 3. 4. 5. Set RSS= 0 (1Fh), FSARS= 0 (1Fh). Enter Standby mode. Set ADCM= 1 (01h). A7125 will enable relative temperature measurement automatically. After measurement done, ADCM is auto clear. User can read digital temperature value from ADC [7:0] (1Eh). 17.2 RSSI Measurement A7125 has built-in 8-bits digital RSSI to detect RF signal strength. After measurement done, RSSI is stored in ADC [7:0] (1Eh). The more signal power, the larger RSSI value. Below is the measurement procedure: Jul., 2011, v1.3 82 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver Auto RSSI measurement for TX Power: 1. Set wanted FRXLO (Refer to chapter 14). 2. Set ADCM=1 (01h), RSS= 1 (1Fh), FSARS= 1 (1Fh, 8MHz ADC clock). 3. Enable MVSEL = [00] (1Dh) and RADC = [10] (1Fh) to do 8-times average RSSI measurement. 4. Set ARSSI= 1 (01h). 5. Send RX Strobe command. 6. Once entering into RX mode, A7125 executes 8-times average measurement repeatedly. 7. Once A7125 leaves RX mode, user can read digital RSSI value from ADC [7:0] (1Eh) for TX power. Strobe CMD (SCS,SCK,SDIO) TI A L Be notice, in step 7, if A7125 is set in direct mode, once the received packet is completed, MCU shall ask A7125 to leave RX mode within 40 us to prevent RSSI inaccuracy. RX-Strobe MCU Read ADC[7:0] (1Eh) Received Packet GIO2 Pin - FSYNC (GPIO2S[3:0]=0001) T0 T2 T3 T4 T5 N Settling Time from PLL to RX mode Receiving Packet A7125 leaves RX mode MCU read RSSI value @ ADC [7:0](1Eh) C O T0-T1: T2-T3: T3: T4-T5: T1 FI D GIO1 Pin - WTR (GPIO1S[3:0]=0000) EN Read 8-bits RSSI value RFI Pin M Figure 17.1 Timing chart of Auto RSSI measurement for TX Power: A M IC C O Auto RSSI measurement for Background Power: 1. Set wanted FRXLO (Refer to chapter 14). 2. Set ADCM=1 (01h), RSS= 1 (1Fh), FSARS= 1 (1Fh, 8MHz ADC clock). 3. Enable MVSEL = [00] (1Dh) and RADC = [10] (1Fh) to do 8-times average RSSI measurement. 4. Set ARSSI= 1 (01h). 5. Send RX Strobe command. 6. MCU delays min. 140us. 7. Read digital RSSI value from ADC [7:0] (1Eh) to get background power. 8. Send Strobe command to ask A7125 to leave RX mode. Jul., 2011, v1.3 83 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver Strobe CMD (SCS,SCK,SDIO) RX-Strobe MCU Read ADC[7:0] (1Eh) No Packet RFI Pin Min. 140 us GIO1 Pin - WTR (GPIO1S[3:0]=0000) MCU can read 8-bits RSSI value that Is re-calculated every 20 us T0 T1 EN T0-T1: MCU Delay Loop from PLL to RX mode for RSSI measurment T1 : Auto RSSI Measurment is done by 8-times average. MCU can read RSSI value from ADC [7:0](1Eh) RSSI measurement Iis re-calculated every 20 us. TI A L GIO2 Pin - FSYNC (GPIO2S[3:0]=0001) FI D Figure 17.2 Timing chart of Auto RSSI measurement for Background Power: 17.3 Carrier Detect Set RTH (1Eh) for RSSI higher threshold by user’s definition (see below Table 17.2). Set RTL (RTL = RTH – RSM) by RSM = [11] (1Fh) (recommended). Set GIO1S = [0010] (0Bh) for GIO1 pin to output CD signal. Follow procedure of auto RSSI measurement. MCU checks GIO1 pin for carrier detect (CD) signal. M 1. 2. 3. 4. 5. C O N Base on RSSI measurement, user can extend its application to do carrier detect (CD). If CD is triggered, its output can be set to GIO1 or GIO2 pin to inform MCU the occupied channel. Below is the detection procedure: O In step 1, MCU can read RH and RL to calculate and store the RTH value corresponding to desired CD trigger level below. RH [7:0] IC C RSSI Range A M Max (-50 dBm) Min (-100 dBm) Address 1Bh RL [7:0] Address 1Ch CD Trigger Level (dBm) -58 -64 -70 -76 -82 RTH (Recommended) (3RH - RL) / 2 RH (RH + RL) / 2 RL (3RL - RH) / 2 Note Formula of digital RSSI values is just approximate for reference. Table 17.2 RTH Recommended Setting In step 5, CD=1 if measured RSSI ≧ RTH. That means this channel is occupied. CD=0 if measured RSSI ≦ RTL. That means this channel is clear. Jul., 2011, v1.3 84 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 18. Battery Detect A7125 has built-in battery detector to check supply voltage (REGI pin). The detect range is 2.0V ~ 2.7V in 8 levels. Relative Control Register Battery Detect Register (Address: 2Ch) R/W Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Name R W -RGS 0 -RGV1 1 -RGV0 0 BDF QDS 0 -BVT2 0 -BVT1 1 -BVT0 1 -BD_E 0 Reset EN TI A BVT [2:0]: Battery voltage detect threshold. [000]: 2.0V. [001]: 2.1V. [010]: 2.2V. [011]: 2.3V. [100]: 2.4V. [101]: 2.5V. [110]: 2.6V. [111]: 2.7V. L Bit Set A7125 in standby or PLL mode. Set BVT (2Ch) = [001] and enable BD_E (2Ch) = 1. After 5 us, BD_E is auto clear. MCU check BDF (2Ch). If REGI pin > 2.1V, BDF = 1. Else, BDF = 0. A M IC C O M C O N 1. 2. 3. 4. FI D Below is the procedure of battery detect for low voltage detection (ex., below 2.1V): Jul., 2011, v1.3 85 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 19. Application Circuit Example Below are AMICCOM’s ref. design module, MD7125-A04, circuit example and its PCB layout. C9 2.2uF VDD_A REGI CKO GIO2 GIO1 18 17 16 GIO1 CKO REGI GIO2 XO XI SDIO 12 C10 2.2uF SCK SCS 11 A7125PKG C O R1 2.7k C14 2.2nF 1 C16 180pF C17 VDD_A 33pF 2 Y1 16MHz C18 27pF C7 C19 0.1uF 100pF M A7125 schematic for RF layouts with single ended 50Ω RF output. C17 and C18 must be matched to the crystal’s load capacitance, Cload. Please see application note for detail. A M IC C O 1. 2. SCS 13 C6 0.1uF N C5 100pF SCK 15 14 10 VDD_A L3 1.5nH VDD_PLL L4 R2 1.2nH NC RFC 9 C15 1pF VDD_D A7125PKG RFO CP 5 C12 3.9pF RFI 8 4 L5 C8 2.2nH 1pF GND SDIO 6 C13 1pF BP_BG FI D ANT 3 BP_RSSI EN L1 2.7nH 2 U1 TI A 1 C11 3.9pF C1 NC 19 C3 100pF VDD_VCO C2 1nF VDD_A C4 4.7uF HEADER 4X2A/2.54 20 REGI SCS SDIO GIO2 2 4 6 8 7 SCK GIO1 1 3 5 7 L J1 GND Jul., 2011, v1.3 86 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver MD7125-A04 which size is 13mm x 20mm with PCB antenna is suitable for small form factor application. MD7125-A04 is based on a design by a double-sided FR-4 board of 0.8mm thickness. All passive components are 0402 size. This PCB has a ground plane on the bottom layer. Additionally, there are ground areas on the component side of the board to ensure sufficient grounding of critical components. Keep sufficient via holes to connect the top layer ground areas to the bottom layer ground plane. Be notice, IC back side plate shall be well-solder to ground; otherwise, it will impact RF performance. IC C O M C O N FI D EN TI A L To get a good RF performance, the well designed PCB is necessary. A poor layout can lead to loss of RF performance especially on matching networks as well as VDD bypass capacitors. PCB layout of critical traces shall follow AMICCOM’s recommended values and layout placement. Long power supply lines on the PCB should be avoided. Keep GND via holes as close as possible to A7125’s GND pad and IC back side plate (GND). A M Be Notice, 1. IC Back side plate shall be well-solder to ground (U1 area) for good RF performance. 2. Need at least 9 GND via holes at U1 area Jul., 2011, v1.3 87 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 20. Abbreviations C O N FI D EN TI A L Analog to Digital Converter Auto IF Frequency Compensation Automatic Gain Control Bit Error Rate Bandwidth Carrier Detect Channel Step Cyclic Redundancy Check Direct Current Forward Error Correction First in First out Frequency Shift Keying Identifier Intermediate Frequency Industrial, Scientific and Medical Local Oscillator Micro Controller Unit Phase Frequency Detector for PLL Phase Lock Loop Power on Reset Receiver Receiver Local Oscillator Received Signal Strength Indicator Serial to Parallel Interface System Clock for digital circuit Transmitter Transmitter Radio Frequency Voltage Controlled Oscillator Crystal Oscillator Crystal Reference frequency Crystal O M ADC AIF FC AGC BER BW CD CHSP CRC DC FEC FIFO FSK ID IF ISM LO MCU PFD PLL POR RX RXLO RSSI SPI SYCK TX TXLO VCO XOSC XREF XTAL IC Part No. C 21. Ordering Information Package Units Per Reel / Tray QFN20L, Pb Free, Tape & Reel, -40℃〜85℃ 3K A71X25AQFI QFN20L, Pb Free, Tray, -40℃〜85℃ 490EA A71X25AH Die form, -40℃〜85℃ 250EA A M A71X25AQFI/Q Jul., 2011, v1.3 88 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 22. Package Information QFN 20L (4 X 4 X 0.8mm) Outline Dimensions unit: inches/mm TOP VIEW BOTTOM VIEW 0.25 C D D2 11 11 15 L 15 10 L 16 10 e E E2 TI A 16 20 0.25 C 20 EN 6 6 5 5 e b 1 0.10 M C A B FI D 1 Symbol C Dimensions in inches Nom Max Min Nom Max 0.030 0.032 0.70 0.75 0.80 A1 0.000 0.001 0.002 0.00 0.02 0.05 M Min 0.028 O 0.008 REF 0.203 REF B 0.007 0.010 0.012 0.18 0.25 D 0.154 0.158 0.161 3.90 4.00 4.10 D2 0.075 0.079 0.083 1.90 2.00 2.10 E 0.154 0.158 0.161 3.90 4.00 4.10 E2 0.075 0.079 0.083 1.90 2.00 2.10 C IC A M Dimensions in mm A A3 Jul., 2011, v1.3 y C C O Seating Plane A3 A1 A N // 0.10 C 0.020 BSC e L Y 0.012 0.016 0.30 0.50 BSC 0.020 0.003 0.30 0.40 0.50 0.08 89 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 23. Top Marking Information A71X25AQFI L Part No. : A71X25AQFI Pin Count : 20 Package Type : QFN Dimension : 4*4 mm Mark Method : Laser Mark Character Type : Arial A M IC C O M C O N FI D EN TI A ¡ ¡ ¡ ¡ ¡ ¡ Jul., 2011, v1.3 90 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver A M IC C O M C O N FI D EN TI A L 24. Reflow Profile Jul., 2011, v1.3 91 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 25. Tape Reel Information 8±0.1 QFN 4*4 8±0.1 QFN 5*5 8±0.1 SSOP 12±0.1 B0 P0 P1 D0 D1 3.2 5±0.1 4.35 ±0.1 5.25 ±0.1 3.25 ±0.1 4.35 ±0.1 5.25 ±0.1 4±0.2 2±0.1 1.5±0.1 4±0.2 2±0.1 1.5±0.1 4±0.2 2±0.1 1.5±0.1 1.5 1.5 N QFN3*3 A0 1.5 C O P 8.2±1 8.8±1.5 4.0±0.1 2.0±0.1 1.5±0.1 1.5±0.1 E F 1.75 ±0.1 1.75 ±0.1 1.75 ±0.1 1.75 ±0.1 5.5 ±0.05 5.5 ±0.05 5.5 ±0.05 W Unit: mm Cover tape width t 0.3 9.3±0.1 ±0.05 0.3 12±0.3 9.3±0.1 ±0.05 0.3 12±0.3 9.3±0.1 ±0.05 0.3 13.3 7.5±0.1 16±0.1 2.1±0.4 ±0.05 ±0.1 1.25 ±0.1 1.2 5±0.1 1.25 ±0.1 T IC C O REEL DIMENSIONS K0 12±0.3 M TYPE FI D EN TI A L Cover / Carrier Tape Dimension R D A M L N K M G Unit: mm TYPE G N M D K L R QFN 12.9±0.5 102 REF±2.0 2.3±0.2 13.15±0.35 2.0±0.5 330±3.0 19.6±2.9 SSOP 16.3±1 102 REF±2.0 2.3±0.2 13.15±0.35 2.0±0.5 330±3.0 19.6±2.9 Jul., 2011, v1.3 92 AMICCOM Electronics Corporation A7125 2.4GHz FSK Transceiver 26. Product Status Product Status Planned or Under Development Definition This data sheet contains the design specifications for product development. Specifications may change in any manner without notice. Preliminary Engineering Samples and First Production This data sheet contains preliminary data, and supplementary data will be published at a later date. AMICCOM reserves the right to make changes at any time without notice in order to improve design and supply the best possible product. No Identification Noted Full Production Obsolete Not In Production This data sheet contains the final specifications. AMICCOM reserves the right to make changes at any time without notice in order to improve design and supply the best possible product. This data sheet contains specifications on a product that has been discontinued by AMICCOM. The data sheet is printed for reference information only. IC C O M C O N FI D EN TI A L Data Sheet Identification Objective A M RF ICs AMICCOM Headquarter A3, 1F, No.1, Li-Hsin Rd. 1, Hsinchu Science Park, Taiwan 30078 Tel: 886-3-5785818 Shenzhen Office Rm., 2003, DongFeng Building, No. 2010, Shennan Zhonglu Rd., Futian Dist., Shenzhen, China Post code: 518031 Web Site http://www.amiccom.com.tw Jul., 2011, v1.3 93 AMICCOM Electronics Corporation
A71X25AQFI/Q 价格&库存
很抱歉,暂时无法提供与“A71X25AQFI/Q”相匹配的价格&库存,您可以联系我们找货
