GP300SL
GP300SL
    OTHER
    GP300SL
GP300SL 数据手册
Page 1 GP300 Gap Pad GP300 is a silicone, thermally conductive material for use at a thermal interface. GP300 is specifically developed as a low thermal resistance gap pad.     Works well under low pressure Good thermal conductivity; 3.0 W/m.K Excellent electrical insulation High heat dissipation; low thermal resistance Approvals RoHS-2 Compliant (2015/863/EU): Yes Typical Properties Colour: Density @ 20°C (g/ml): Thickness (mm) Hardness (Shore C) Tensile Strength (MPa): Thermal Conductivity: Temperature Range: Thermal Resistance (°C.in2/W): Elongation (%): Volume Resistivity (Ω·cm): Dielectric Strength (kV/mm): Dielectric Constant @1MHz: Dielectric Loss: Compression Ratio (% @ 50psi): Weight Loss (120°C, 7 days): Sky Blue 3.0 0.5 – 1.0 40 0.30 3.0 W/m.K -50°C to +160°C 0.99 86.5 2.3 x 1011 7.5 6.33 0.0021 52 0.68% Description Order Code Dimension of Gap Pad Gap Pad Gap Pad GP300S GP300SL 200 x 200 x 0.5 mm 200 x 200 x 1.0 mm Revision 2: October 2017
GP300SL 价格&库存
很抱歉,暂时无法提供与“GP300SL”相匹配的价格&库存,您可以联系我们找货
