EC3625ETTS-100.00MTR
    COMUS(康姆斯)
    Oscillator XO 100MHz ±25ppm 15pF (Stability) LVHCMOS 60% 3.3V 4-Pin CSMD T/R
EC3625ETTS-100.00MTR 数据手册
ECLIPTEK PART NUMBER DATA SHEET CORPORATION EC3645TTS-66.666M REGULATORY COMPLIANCE R (Data Sheet downloaded on Nov 22, 2015) 2011/65 + 2015/863 163 SVHC ITEM DESCRIPTION Quartz Crystal Clock Oscillators XO (SPXO) LVCMOS (CMOS) 3.3Vdc 4 Pad 3.2mm x 5.0mm Ceramic Surface Mount (SMD) 66.666MHz ±50ppm -10°C to +70°C ELECTRICAL SPECIFICATIONS Nominal Frequency 66.666MHz Frequency Tolerance/Stability ±50ppm Maximum (Inclusive of all conditions: Calibration Tolerance at 25°C, Frequency Stability over the Operating Temperature Range, Supply Voltage Change, Ouput Load Change, First Year Aging at 25°C, Shock, and Vibration) Operating Temperature Range -10°C to +70°C Supply Voltage 3.3Vdc ±10% Input Current 35mA Maximum Output Voltage Logic High (Voh) 90% of Vdd Minimum (IOH = -4mA) Output Voltage Logic Low (Vol) 10% of Vdd Maximum (IOL = +4mA) Rise/Fall Time 4nSec Maximum (Measured at 20% to 80% of waveform) Duty Cycle 50 ±5(%) (Measured at 50% of waveform) Load Drive Capability 15pF Maximum Output Logic Type CMOS Pin 1 Connection Tri-State (High Impedance) Tri-State Input Voltage (Vih and Vil) 90% of Vdd Minimum or No Connect to Enable Output, 10% of Vdd Maximum to Disable Output (High Impedance) Standby Current 10µA Maximum (Disabled Output: High Impedance) RMS Phase Jitter 1pSec Maximum (12kHz to 20MHz offset frequency) Start Up Time 10mSec Maximum Storage Temperature Range -55°C to +125°C ENVIRONMENTAL & MECHANICAL SPECIFICATIONS ESD Susceptibility MIL-STD-883, Method 3015, Class 1, HBM: 1500V Fine Leak Test MIL-STD-883, Method 1014, Condition A Flammability UL94-V0 Gross Leak Test MIL-STD-883, Method 1014, Condition C Mechanical Shock MIL-STD-883, Method 2002, Condition B Moisture Resistance MIL-STD-883, Method 1004 Moisture Sensitivity J-STD-020, MSL 1 Resistance to Soldering Heat MIL-STD-202, Method 210, Condition K Resistance to Solvents MIL-STD-202, Method 215 Solderability MIL-STD-883, Method 2003 Temperature Cycling MIL-STD-883, Method 1010, Condition B Vibration MIL-STD-883, Method 2007, Condition A www.ecliptek.com | Specification Subject to Change Without Notice | Revision M 03/12/2015 | Page 1 of 4 Ecliptek Corporation 3545 Cadillac Ave., Costa Mesa, CA 92626 1-800-ECLIPTEK or 714.433.1200 ECLIPTEK PART NUMBER DATA SHEET R CORPORATION EC3645TTS-66.666M MECHANICAL DIMENSIONS (all dimensions in millimeters) 3.20 ±0.20 1.00 ±0.20 (x4) MARKING ORIENTATION 5.00 ±0.20 1.3 MAX 2 3 1.20 ±0.20 CONNECTION 1 Tri-State 2 Ground 3 Output 4 Supply Voltage LINE MARKING 2.54 ±0.15 1 PIN 4 1 E66.666 E=Ecliptek Designator 2 XXXXX XXXXX=Ecliptek Manufacturing Identifier 1.20 ±0.20 (x4) Suggested Solder Pad Layout All Dimensions in Millimeters 1.20 (X4) 1.40 (X4) Solder Land (X4) 1.14 1.00 All Tolerances are ±0.1 www.ecliptek.com | Specification Subject to Change Without Notice | Revision M 03/12/2015 | Page 2 of 4 Ecliptek Corporation 3545 Cadillac Ave., Costa Mesa, CA 92626 1-800-ECLIPTEK or 714.433.1200 ECLIPTEK PART NUMBER DATA SHEET R CORPORATION EC3645TTS-66.666M CLOCK OUTPUT TRI-STATE INPUT OUTPUT WAVEFORM & TIMING DIAGRAM VIH VIL VOH 80% of Waveform OUTPUT DISABLE (HIGH IMPEDANCE STATE) 50% of Waveform 20% of Waveform VOL tPLZ Fall Time Rise Time tPZL TW T Duty Cycle (%) = TW/T x 100 www.ecliptek.com | Specification Subject to Change Without Notice | Revision M 03/12/2015 | Page 3 of 4 Ecliptek Corporation 3545 Cadillac Ave., Costa Mesa, CA 92626 1-800-ECLIPTEK or 714.433.1200 ECLIPTEK PART NUMBER DATA SHEET R CORPORATION EC3645TTS-66.666M Test Circuit for CMOS Output Frequency Counter Oscilloscope + + Power Supply _ Current Meter _ Supply Voltage (VDD) Probe (Note 2) Output + Voltage Meter _ 0.01µF (Note 1) 0.1µF (Note 1) Ground CL (Note 3) No Connect or Tri-State Note 1: An external 0.1µF low frequency tantalum bypass capacitor in parallel with a 0.01µF high frequency ceramic bypass capacitor close to the package ground and VDD pin is required. Note 2: A low capacitance (10Mohms), and high bandwidth (>300MHz) passive probe is recommended. Note 3: Capacitance value CL includes sum of all probe and fixture capacitance. www.ecliptek.com | Specification Subject to Change Without Notice | Revision M 03/12/2015 | Page 4 of 4 Ecliptek Corporation 3545 Cadillac Ave., Costa Mesa, CA 92626 1-800-ECLIPTEK or 714.433.1200
EC3625ETTS-100.00MTR 价格&库存
很抱歉,暂时无法提供与“EC3625ETTS-100.00MTR”相匹配的价格&库存,您可以联系我们找货
