EA5070FA18-24.000M TR
    COMUS(康姆斯)
    n/a
EA5070FA18-24.000M TR 数据手册
EA5070 Series REGULATORY COMPLIANCE 2011/65 + 2015/863 191 SVHC ITEM DESCRIPTION Quartz Crystal Resonator 5.0mm x 7.0mm x 1.3mm 4 Pad Ceramic Surface Mount (SMD) ELECTRICAL SPECIFICATIONS Nominal Frequency 6MHz to 66MHz Frequency Tolerance/Stability ±50ppm at 25°C, ±100ppm over 0°C to +70°C ±50ppm at 25°C, ±100ppm over -20°C to +70°C ±50ppm at 25°C, ±100ppm over -40°C to +85°C ±30ppm at 25°C, ±50ppm over 0°C to +70°C ±30ppm at 25°C, ±50ppm over -20°C to +70°C ±30ppm at 25°C, ±50ppm over -40°C to +85°C ±15ppm at 25°C, ±30ppm over 0°C to +70°C ±15ppm at 25°C, ±30ppm over -20°C to +70°C ±15ppm at 25°C, ±30ppm over -40°C to +85°C ±15ppm at 25°C, ±20ppm over 0°C to +70°C ±15ppm at 25°C, ±20ppm over -20°C to +70°C ±15ppm at 25°C, ±20ppm over -40°C to +85°C ±10ppm at 25°C, ±15ppm over 0°C to +70°C ±10ppm at 25°C, ±15ppm over -20°C to +70°C Aging at 25°C ±3ppm/year Maximum Load Capacitance Series Resonant, 12pF Parallel Resonant to 50pF Parallel Resonant Shunt Capacitance 7pF Maximum Equivalent Series Resistance See the Equivalent Series Resistance (ESR), Mode of Operation, and Crystal Cut Table Below Mode of Operation AT-Cut Fundamental (Only available over Nominal Frequency range of 6MHz to 40MHz) AT-Cut Third Overtone (Only available over Nominal Frequency range of 35.328MHz to 66MHz) Drive Level 50µWatts Maximum Spurious Response Measured from Fo to Fo +5000ppm -3dB Minimum -40°C to +85°C Storage Temperature Range Insulation Resistance Measured at 100Vdc 500 Megaohms Minimum EQUIVALENT SERIES RESISTANCE (ESR), MODE OF OPERATION AND CRYSTAL CUT Frequency Range ESR (Ohms Max) Mode Frequency Range ESR (Ohms Max) Mode 6MHz to 9.999999MHz 90 AT-Cut Fundamental 16MHz to 40MHz 30 AT-Cut Fundamental 10MHz to 10.999999MHz 60 AT-Cut Fundamental 35.328MHz to 39.999999MHz 100 11MHz to 13.999999MHz 50 AT-Cut Fundamental 40MHz to 59.999999MHz 80 AT-Cut Third Overtone 14MHz to 15.999999MHz 40 AT-Cut Fundamental 60MHz to 66MHz 80 AT-Cut Third Overtone Revised B: 12/1/2015 Page 2 of 10 AT-Cut Third Overtone www.ecliptek.com EA5070 Series PART NUMBERING GUIDE Revised B: 12/1/2015 Page 3 of 10 www.ecliptek.com EA5070 Series MECHANICAL DIMENSIONS SUGGESTED SOLDER PAD LAYOUT PIN CONNECTION 1 Crystal 2 Cover/Ground 3 Crystal 4 Cover/Ground All Tolerances are ±0.1 All Dimensions in Millimeters Revised B: 12/1/2015 Page 4 of 10 www.ecliptek.com EA5070 Series TAPE & REEL DIMENSIONS Quantity per Reel: 1,000 Units All Dimensions in Millimeters Compliant to EIA-481 Revised B: 12/1/2015 Page 5 of 10 www.ecliptek.com EA5070 Series RECOMMENDED SOLDER REFLOW METHOD HIGH TEMPERATURE INFRARED/CONVECTION TS MAX to TL (Ramp-up Rate) 3°C/Second Maximum Preheat - Temperature Minimum (TS MIN) - Temperature Typical (TS TYP) - Temperature Maximum(TS MAX) - Time (tS) 150°C 175°C 200°C 60 - 180 Seconds Ramp-up Rate (TL to TP) Time Maintained Above: - Temperature (TL) - Time (tL) 3°C/Second Maximum Peak Temperature (TP) 260°C Maximum for 10 Seconds Maximum Target Peak Temperature(TP Target) 250°C +0/-5°C Time within 5°C of actual peak (tp) 20 - 40 Seconds Ramp-down Rate 6°C/Second Maximum Time 25°C to Peak Temperature (t) 8 Minutes Maximum Moisture Sensitivity Level Level 1 Additional Notes Temperatures shown are applied to body of device. 217°C 60 - 150 Seconds High Temperature Manual Soldering 260°C Maximum for 5 Seconds Maximum, 2 times Maximum. (Temperatures shown are applied to body of device.) Revised B: 12/1/2015 Page 6 of 10 www.ecliptek.com EA5070 Series RECOMMENDED SOLDER REFLOW METHOD LOW TEMPERATURE INFRARED/CONVECTION TS MAX to TL (Ramp-up Rate) 5°C/Second Maximum Preheat - Temperature Minimum (Ts MIN) - Temperature Typical (Ts TYP) - Temperature Maximum(Ts MAX) - Time (ts) N/A 150°C N/A 30 - 60 Seconds Ramp-up Rate (TL to TP) Time Maintained Above: - Temperature (TL) - Time (tL) 5°C/Second Maximum Peak Temperature (TP) 245°C Maximum Target Peak Temperature (TP Target) 245°C Maximum 2 Times / 230˚C Maximum 1 Time Time within 5°C of actual peak (tp) 10 Seconds Maximum 2 Times / 80 Seconds Maximum 1 Time Ramp-down Rate 5°C/Second Maximum Time 25°C to Peak Temperature (t) N/A Moisture Sensitivity Level Level 1 Additional Notes Temperatures shown are applied to body of device. 150°C 200 Seconds Maximum Low Temperature Manual Soldering 185°C Maximum for 10 Seconds Maximum, 2 times Maximum. (Temperatures shown are applied to body of device.) Revised B: 12/1/2015 Page 7 of 10 www.ecliptek.com
EA5070FA18-24.000M TR 价格&库存
很抱歉,暂时无法提供与“EA5070FA18-24.000M TR”相匹配的价格&库存,您可以联系我们找货
