AOLW29911D-A-120V
AOLW29911D-A-120V
    IDEC(日本和泉)
AOLW29911D-A-120V 数据手册
Oiltight Switches & Pilot Devices ø22mm - TW Series TW Series — 22mm NEMA Style Pushbuttons Switches & Pilot Devices A3 TW NEMA Style Switches with snap-on contacts Key features include: IDEC has your 22mm switching needs covered. • Corrosion resistant octagonal chrome plated locking bezel • Snap-on 10A contact blocks • Transformer or full voltage • Incandescent or LED illumination • Slow make, double break, self cleaning contacts •Modular construction for maximum flexibility •NEMA 4X and IP65 watertight/oiltight panel •Available assembled or as sub-components •Large M3.5 screw terminals with captive sems plate Button styles include flush, extended, mushroom, or square and all bodies are crafted from fracture-resistant nylon. UL Listed File No. E70646 A3-126 File No. 9561116E01 www.idec.com CSA Certified File No.LR48366 All illuminated units feature two lense styles, one that maximizes light dispersion, the other accommodates direct lense engraving. Self cleaning contact mechanisms allow for a wide current rating, 5mA to 10A, which reduces the need for various contact materials. When looking for a 22mm switch that is durable, easy to use, and versatile, then IDEC's TW series is your solution. File No. DK95-01696 Certificate No. 2030010305027380 USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices Conforming to Standards Approvals File No. E68961 EN60947-1, EN60947-5-1, VDE0660-200, UL508, CSA C22-2 No.14 File No. LR21451 Certificate No. 2030010305027380 Specifications CSA: pushbuttons and selector switches: A600 pilot lights and illuminated pushbuttons, direct supply pilot lights and illuminated pushbuttons with integral transformer (100/110, 115, 120, 200/220, 230, 240, 380, 400/440, 480V) UL: pushbuttons and selector switches: A600 pilot lights and illuminated pushbuttons, direct supply pilot lights and illuminated pushbuttons with integral transformer (100/110, 115, 120, 200/220, 230, 240, 380, 400/440, 480V) TÜV: pushbuttons and selector switches: A600=P600 (NO, NC)/Q600 (NO-EM, NC-LB) pilot lights and illuminated pushbuttons, direct supply pilot lights and illuminated pushbuttons with integral transformer (100/110, 115, 120, 200/220, 230, 240, 380, 400/440, 480V) Operating Temperature Operation: –25 to +50°C (without freezing) Storage: –40 to +80°C (without freezing) Vibration Resistance Shock Resistance Electric Shock Protection Degree of Protection (conforming to IEC60529) (conforming to NEMA ICS6-110) 5 to 55Hz, 100m/sec2 (10g) conforming to IEC6068-2-6 Mechanical Life Momentary pushbuttons: 5,000,000 (900 operations per hour) All other switches: 500,000 3 for switches not using a transformer 2 for switches using a transformer AC-15: A600 or Ue = 250V, le = 3A (NO, NC, NO-EM, NC-LB) DC-13: P600 or Ue = 125V, le = 1.1A (NO, NC) DC-13: Q600 or Ue = 125V, le = 0.9A (NO-EM, NC-LB) Pollution Degree (conforming to IEC60947-1) Rated Operational Characteristics A3 Switches & Pilot Devices Registration No: J9551802 (E-Stops) Registration No: J9551803 (All other switches) Registration No: J9551804 (Pilot Lights) Contact Ratings ø22mm - TW Series 1000m/sec2 (100g) conforming to IEC6068-2-7 Class 0 conforming to IEC60536 IP65 from front of the panel; (IP54 for key switches) IP20 (Type HW-F contact block) NEMA 1, 2, 3, 3R, 3S, 4, 4X, 5, 12, 13 (NEMA 1, 2, 3R, 5, 12, 13 for key switches) Rated Insulation Voltage Rated Switching Over-Voltage 600V Rated Impulse Withstanding Voltage 4kV for contact circuit 2.5kV for lamp circuit Rated Thermal Current Minimum Switching Capacity Contact Operation Recommended Terminal Torque External Short-Circuit Protection Applicable Wire Size Contact Resistance 10 Amp Contact Gap 4mm (NO and NC) 2mm (NO-EM and NC-LB) Electrical Reliability MTBF < 1 fault for 10 million operation cycles (3V DC, 5mA) Lamp Ratings Incandescent: 1 W LEDs: 6V: 17mA max, 12/24V: 11mA max, 120/240V: 10mA max Horsepower Rating Maximum Inrush Current Contact Material 1/4 HP @ 120V (single-phase, non-reversing motor); 1 HP @ 240V (3 phase, non-reversing motor) Pushbuttons Illuminated Pushbuttons Selector Switches Illuminated Selector Switches Pushbutton Selectors Less than 4kV, conforming to IEC60947-1 5 mA at 3V AC/DC Slow break NC or slow make NO, self-cleaning 0.8 N m (7.1 in lb.) 10A 250V fuse conforming to IEC60269-1 Minimum 1 x 22 AWG, max. 2 x 14 AWG or 1 x 12 AWG Initial contact resistance of 50mΩ or less 40 A (40 ms) Silver Contact Block Type HW-C/HW-F Rated Insulation Voltage 600V Rated Continuous Current 10A Contact Ratings by Utilization Category IEC 60947-5-1 AC-15 (A600) DC-13 (P600) Contact Ratings by Utilization Category Characteristics Operational Voltage Operational Current www.idec.com AC 50/60 Hz DC 24V 48V 50V 110V 220V 440V AC-12 Control of resistive loads & solid state loads 10A — 10A 10A 6A 2A AC-15 Control of electromagnetic loads (> 72VA) 10A — 7A 5A 3A 1A DC-12 Control of resistive loads & solid state loads 8A 5A — 2.2A 1.1A — DC-13 Control of electromagnets 5A 2A — 1.1A 0.6A — USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-127 ø22mm - TW Series Oiltight Switches & Pilot Devices Non-Illuminated Pushbuttons (Assembled) Switches & Pilot Devices A3 Assembled Pushbuttons A B ( ) W 1 10 ( ) - B Function B: Momentary O: Maintained K: Key On/Off Lock Button Color B: Black G: Green W: White R: Red S: Blue Y: Yellow Terminal Style Blank: Standard N: Fingersafe (IP20) Bezel Shape Blank: Octagonal F: Full Shroud G: Mushroom Shroud Q: Square Contact Arrangement 10: 1NO 01: 1NC 20: 2NO 02: 2NC 11: 1NO-1NC 22: 2NO-2NC Button Shape 1: Flush 2: Extended 3: Mushroom Head Ø 29mm 4: Mushroom Head Ø 40mm Series Designation W: TW Series To be used for interpreting part numbers only, not for part number development. A3-128 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - TW Series Non-Illuminated Pushbuttons (Assembled) con’t Part Numbers: Non-illuminated Pushbuttons Style Contacts ① Button Color Code Maintained Action Color Code 1NO 1NC 1NO-1NC 2NO 2NC ABW110-➀ ABW101-➀ ABW111-➀ ABW120-➀ ABW102-➀ AOW110-➀ AOW101-➀ AOW111-➀ AOW120-➀ AOW102-➀ Black B Green G Red R Extended 1NO 1NC 1NO-1NC 2NO 2NC ABW210-➀ ABW201-➀ ABW211-➀ ABW220-➀ ABW202-➀ AOW210-➀ AOW201-➀ AOW211-➀ AOW220-➀ AOW202-➀ Recessed 1NO 1NC 1NO-1NC 2NO 2NC ABFW110-➀ ABFW101-➀ ABFW111-➀ ABFW120-➀ ABFW102-➀ AOFW110-➀ AOFW101-➀ AOFW111-➀ AOFW120-➀ AOFW102-➀ Extended with Full Shroud 1NO 1NC 1NO-1NC 2NO 2NC ABFW210-➀ ABFW201-➀ ABFW211-➀ ABFW220-➀ ABFW202-➀ AOFW210-➀ AOFW201-➀ AOFW211-➀ AOFW220-➀ AOFW202-➀ Ø 29mm Mushroom Head 1NO 1NC 1NO-1NC 2NO 2NC ABW310-➀ ABW301-➀ ABW311-➀ ABW320-➀ ABW302-➀ AOW310-➀ AOW301-➀ AOW311-➀ AOW320-➀ AOW302-➀ Ø 40mm Mushroom Head 1NO 1NC 1NO-1NC 2NO 2NC ABW410-➀ ABW401-➀ ABW411-➀ ABW420-➀ ABW402-➀ AOW410-➀ AOW401-➀ AOW411-➀ AOW420-➀ AOW402-➀ Ø 40mm Mushroom Head with Full Shroud 1NO 1NC 1NO-1NC 2NO 2NC ABGW410-➀ ABGW401-➀ ABGW411-➀ ABGW420-➀ ABGW402-➀ AOGW410-➀ AOGW401-➀ AOGW411-➀ AOGW420-➀ AOGW402-➀ Square Flush 1NO 1NC 1NO-1NC 2NO 2NC ABQW110-➀ ABQW101-➀ ABQW111-➀ ABQW120-➀ ABQW102-➀ AOQW110-➀ AOQW101-➀ AOQW111-➀ AOQW120-➀ AOQW102-➀ Square Extended 1NO 1NC 1NO-1NC 2NO 2NC ABQW210-➀ ABQW201-➀ ABQW211-➀ ABQW220-➀ ABQW202-➀ AOQW210-➀ AOQW201-➀ AOQW211-➀ AOQW220-➀ AOQW202-➀ Keylock Push On/Off 1NO 1NC 1NO-1NC 2NO 2NC AKW210 AKW201 AKW211 AKW220 AKW202 Flush Blue S White W Yellow Y A3 Switches & Pilot Devices Momentary Action – 1. In place of ➀, specify the Button Color Code from table. 2. For sub-assembled part numbers, see page A3-130. 3. For accessories, see page A3-156. 4. For dimensions, see page A3-158. 5. Keyed switches are supplied with two keys. All units are keyed alike. For custom keys, contact IDEC. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-129 Oiltight Switches & Pilot Devices ø22mm - TW Series Non-Illuminated Pushbuttons (Sub-Assembled) Contact Blocks + Operator + Button = Complete Part Switches & Pilot Devices A3 Part Numbers: Operators Style Part Number Momentary Maintained Part Numbers: Buttons Style Part Number Round Flush Round Flush/Extended ABW1B-➀ ABW-100 Part Numbers: Contact Blocks Description Part Number AOW-100 Round Extended Round with Full Shroud 1NO 1NC HW-C10 HW-C01 HW-C10R (early make) HW-C01R (late break) HW-F10 HW-F01 HW-F10R (early make) HW-F01R (late break) Standard Exposed Screw ABW2B-➀ ABFW-200 Fingersafe (IP20), CE marked AOFW-200 Ø 29mm Mushroom ABW3B-➀ Ø 40mm, Ø 29mm Mushroom Head ABW-300 AOW-300 Dummy Block Ø 40mm Mushroom TW-DB ABW4B-➀ Ø 40mm Mushroom Head with Full Shroud ABGW-400 AOGW-400 1. Dummy blocks (no contacts) are used with an odd number of contact blocks. 2. Use of early and late break contacts creates a make before break function Square Flush ABQW1B-➀ ① Button Color Code Square Flush/Extended Square Extended ABQW-100 AOQW-100 ABQW2B-➀ In place of ➀, specify the Button Color Code from table. Keylock Push On/Off Color Code Black B Green G Red R Blue S White W Yellow Y AKW-200 A3-130 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - TW Series E-Stops (Assembled) A3 A V (L) W 4 (B) (99) 11 (D) (N) - R - (24V) Function V: Pushlock Turn Reset Y: Push-Pull X: Pushlock Key Reset Lamp Voltage (full voltage illuminated units only) 6V: 6V AC/DC 12V: 12V AC/DC 24V: 24V AC/DC 120V: 120V AC (LED only) 240V: 240V AC (LED only) Illumination Blank: None L: Illuminated Button/Lens Color A: Amber R: Red G: Green S: Blue B: Black Series Designation W: TW Series Button/Lens Size 3: 29mm Mushroom 4: 40mm Mushroom W: White Y: Yellow Contact Terminal Style Blank: Standard N: Fingersafe (IP20) Lens Type (illuminated units only) Blank: Standard (ribbed) B: Engravable (smooth with insert) Illuminated Circuit (illuminated unit only) 99: Full Voltage (lamp determines voltage) 126:120V AC Step Down Transformer 246: 240V AC Step Down Transformer 486: 480V AC Step Down Transformer Lamp Type (illuminated units only) Blank: Incandescent D: LED Contact Arrangement 10: 1NO 01: 1NC 20: 2NO 02: 2NC 11: 1NO/1NC 22: 2NO/2NC Use only for interpreting part numbers. Do not use for developing part numbers. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-131 Switches & Pilot Devices Assembled E-Stops Oiltight Switches & Pilot Devices ø22mm - TW Series E-Stops (Assembled) con’t Part Numbers: Non-Illuminated E-Stops Style Contacts Part Number Ø 40mm Pushlock Turn Reset* Switches & Pilot Devices A3 Part Numbers: Illuminated E-Stops Style Type Ø 40mm Pushlock Turn Reset Type 1NO 1NC 1NO-1NC 2NO 2NC AVW410-R* AVW401-R* AVW411-R* AVW420-R* AVW402-R* 1NO 1NC 1NO-1NC 2NO 2NC AVW310-R* AVW301-R* AVW311-R* AVW320-R* AVW302-R* Ø 29mm Pushlock Turn Reset Ø 29mm Pushlock Turn Reset* Ø 40mm Push-Pull Ø 40mm Push-Pull 1NO 1NC 1NO-1NC 2NO 2NC AYW410-➀ AYW401-➀ AYW411-➀ AYW420-➀ AYW402-➀ Ø 40mm Pushlock Key Reset * 1NO 1NC 1NO-1NC 2NO 2NC AXW410AXW401AXW411AXW420AXW402- R* R* R* R* R* 1. *Available in Red only. 2. In place of ➀, specify the Button Color Code from table. 3. For sub-assembled part numbers, see page A3-130. 4. For accessories, see page A3-156. 5. For dimensions, see page A3-158. ① Button Color Code Color Code ➁ LED/Lens Color Code Color Voltage Code 6V B Amber A Green G Green G 12V AC/DC 12V 24V Red R Red R 24V AC/DC Blue S Blue S 120V AC 120V (LED only) W 240V AC 240V (LED only) Yellow Y White ➃ Transformer Voltage Codes Voltage Code 120VAC 240VAC 480VAC 126 246 486 Transformer 1NO-1NC 2NO 2NC AVLW4 ➃ 11⑤-R* AVLW4 ➃ 20⑤-R* AVLW4 ➃ 02⑤-R* Full Voltage 1NO-1NC 2NO 2NC AVLW49911➄-R*-➂ AVLW49920➄-R*-➂ AVLW49902➄-R*-➂ Transformer 1NO-1NC 2NO 2NC AVLW3➃11➄-R* AVLW3➃20➄-R* AVLW3➃02➄-R* Full Voltage 1NO-1NC 2NO 2NC AVLW39911➄-R*-➂ AVLW39920➄-R*-➂ AVLW39902➄-R*-➂ Transformer 1NO-1NC 2NO 2NC AYLW4 ➃ 11➄-➁ AYLW4 ➃ 20➄-➁ AYLW4 ➃ 02➄-➁ Full Voltage 1NO-1NC 2NO 2NC AYLW49911➄-➁-➂ AYLW49920➄-➁-➂ AYLW49902➄-➁-➂ ➂ Full Voltage Code Code Black W Part Number 1. *Available in red only. 2. In place of ➁, specify the Lens Color Code (see table above). 3. In place of ➂, specify the Full Voltage Code (lamp voltage) (see table above). 4. In place of ➃, specify the Transformer Voltage Code (see table above). 5. In place of ⑤, specify the Lamp Type Code from table above. 6. For sub-assembly part numbers, see page A3-134. 7. For accessories, see page A3-156. 8. For dimensions, see page A3-158. 6V AC/DC White Contacts ➄ Lamp Type Code Lamp Code Incandescent Blank LED D Transformers step down to 6V. A3-132 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - TW Series E-Stops (Sub-Assembled) Transformer/ + Adaptor* Contacts + Lamp Holder + Operator + Lamp + Button or Lens = Complete Part A3 Switches & Pilot Devices * Not applicable for full voltage units Part Numbers: Operators Style Part Number Non-illuminated Part Numbers: Buttons Style Illuminated Part Number Ø 40mm Pushlock Turn Reset Ø 29/Ø 40mm Pushlock Turn Reset AVW4B-R* AVW-300 AVLW3-0600 Ø 29mm Pushlock Turn Reset Ø 40mm Push-Pull AVW3B-R* AYW-400 AYLW4-0600 Ø 40mm Push-Pull Ø 40mm Pushlock Key Reset AYW4B-➀ AXW-300 — Ø 40mm Pushlock Key Reset Part Numbers: Lamps Type Voltage LED Incandescent AXW4B-R* Part Number 6V AC/DC LSTD-6➁ 12V AC/DC LSTD-1➁ 24V AC/DC LSTD-2➁ 120V AC LSTD-H2➁ 240V AC LSTD-M4➁ 6V AC/DC IS-6 12V AC/DC IS-12 24V AC/DC IS-24 1. In place of ➁, specify the LED color code. 2. The LED contains a current-limiting resistor and a protection diode. www.idec.com 1. *Available in Red only 2. In place of ➀, specify the button color code from table below. ① Button Color Code ➁ LED/Lens Color Code Color Code Color Code Black B Amber A Green G Green G Red R Red R Blue S Blue S White W White W Yellow Y USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-133 Oiltight Switches & Pilot Devices ø22mm - TW Series Illuminated E-Stops (Sub-Assembled) con’t Part Numbers: Lenses Style Switches & Pilot Devices A3 Part Numbers: Transformers/Full Voltage Modules Style Description Part Number Part Number Standard Engravable Full Size Transformer Standard Ø 29mm Head Pushlock Turn Reset AVLW3LU-R* AVLW3BLU-R* Fingersafe Half Size Transformer Ø 40mm Head Pushlock Turn Reset AVLW4LU-R* AVLW4BLU-R* Full voltage model (use with even number of contacts) Ø 40mm Head Push Pull AYLW4LU-➁ AYLW4BLU-➁ Full voltage model (use with odd number of contacts) 1. In place of ➁, specify the lens color code from table on the bottom right. 2. *Available only in red 3. Standard lenses have ribbed pattern, Engravable lenses are smooth and include an engravable insert. Part Numbers: Lamp Circuit Components Style Application Used with a Half-size Transformer and one contact block Long Lamp Holder TW-T126B TW-T246B TW-T486B TW-F126B TW-F246B TW-F486B 120V AC TW-T126SB 240V AC TW-T246SB Standard TW-DA1B Fingersafe TW-DA1FB Standard HW-DA1B Fingersafe HW-DA1FB All Transformers step down to 6V (use 6V lamp). Part Number Short Lamp Holder 120V AC 240V AC 480V AC 120V AC 240V AC 480V AC Part Numbers: Contact Blocks Description Part Number TW-LH1 1NO 1NC HW-C10 HW-C01 HW-C10R (early make) HW-C01R (late break) HW-F10 HW-F01 HW-F10R (early make) HW-F01R (late break) Standard Exposed Screw Used with Full-size Transformer and two contact blocks Used with Half-size Transformer and three contact blocks Used with Full Voltage Adaptor and two contact blocks TW-LH2 Used with TW-LH2 holder when using four contact blocks HW-LH3 Fingersafe (IP20), CE marked Lead Holder Dummy Block TW-DB 1. Dummy blocks (no contacts) are used with an odd number of contact blocks. 2. Use of early and late break contacts creates a make before break function A3-134 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - TW Series Pilot Lights (Assembled) A3 A P (Q) W 1 ( B) 99 Function P: Pilot Light (D) - R - (24V) Lamp Voltage (Full Voltage Units Only) 6V: 6V AC/DC 12V: 12V AC/DC 24V: 24V AC/DC 120V: 120V AC (LED only) 240V: 240V AC (LED only) Bezel Shape Blank: Octagonal (round lenses) Q: Square Series Designation W: TW Series Lens Shape 1: Flat 2: Dome Lens Type Blank: Standard (ribbed) B: Engravable (smooth with insert included) Illumination Circuit 99: Full Voltage (lamp determines voltage) 126:120V AC Step Down Transformer 246:240V AC Step Down Transformer 486:480V AC Step Down Transformer Lens Color Code A: Amber G: Green R: Red S: Blue W:White Y: Yellow Lamp Type Blank: Incandescent D: LED 1. Use only when interpreting part numbers. Do not use for developing part numbers. 2. All transformers step down to 6V. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-135 Switches & Pilot Devices Assembled Pilot Lights Oiltight Switches & Pilot Devices ø22mm - TW Series Pilot Lights (Assembled) con’t Part Numbers: Pilot Lights Style Switches & Pilot Devices A3 Round Flat Dome Square Flat Operating Voltage Part Number Transformer 120VAC 240VAC 480VAC APW1126➃-➁ APW1246➃-➁ APW1486➃-➁ Full Voltage — APW199➃-➁-➂ Transformer 120VAC 240VAC 480VAC APW2126➃-➁ APW2246➃-➁ APW2486➃-➁ Full Voltage — APW299➃-➁-➂ Transformer 120VAC 240VAC 480VAC APQW1B126➃-➁ APQW1B246➃-➁ APQW1B486➃-➁ Full Voltage — APQW1B99➃-➁-➂ 1. In place of ➁, specify the Lens Color Code from table below. 2. In place of ➂, specify the Full Voltage Code from table below. 3. In place of ➃, specify the Lamp Type Code from table below. 4. For accessories, see page A3-156. 5. For dimensions, see page A3-158. 6. For sub-assembly part numbers, see next page. ➁ Lens Color Code A3-136 Color Code Amber A Green G ➂ Full Voltage Code Lamp Code 6V AC/DC 6V Incandescent Blank 12V AC/DC 12V LED D Red R 24V AC/DC 24V Blue S 120V AC 120V (LED only) White W 240V AC 240V (LED only) Yellow Y www.idec.com ➃ Lamp Type Code Code Voltage USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - TW Series Pilot Lights (Sub-Assembled) Transformer + Operator + Lamp + Lens = Complete Part A3 Switches & Pilot Devices * Transformer not required for full voltage units. Part Numbers: Operators Style Part Number Part Numbers: Lamps Type Voltage Round Dome/Flat LED APW-199 Incandescent Square UPQW-199 Part Number 6V AC/DC LSTD-6➁ 12V AC/DC LSTD-1➁ 24V AC/DC LSTD-2➁ 120V AC LSTD-H2➁ 240V AC LSTD-M4➁ 6V AC/DC IS-6 12V AC/DC IS-12 24V AC/DC IS-24 30V AC/DC IS-30 1. In place of ➁, specify the LED Color Code from table below. 2. The LED contains a current-limiting resistor and diode bridge. Same operator is used for full voltage as for transformer completed units. Part Numbers: Transformers Description Style Part Numbers: Lenses Part Number Style Standard Engravable Dome APW2LU-➁ — Round Flat APW1LU-➁ APW1BLU-➁ Square Flat — APQW1BLU-➁ 1. In place of ➁, specify the Lens Color Code from table below. 2. Standard lenses have a ribbed lens to enhance light dispersion. Marking lenses are smooth and include an engravable insert. Standard Fingersafe 120V AC 240V AC 480V AC 120V AC 240V AC 480V AC Part Number TW-T126B TW-T246B TW-T486B TW-F126B TW-F246B TW-F486B All Transformers step down to 6V (use 6V lamp). ➁ Lens/LED Color Code Color Code Amber A Green G Red R Blue S White W Yellow Y If clear lens is desired, use white marking lens and remove engraving insert www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-137 Oiltight Switches & Pilot Devices ø22mm - TW Series Illuminated Pushbuttons (Assembled) Switches & Pilot Devices A3 Assembled Illuminated Pushbuttons A L (F ) W 2 (B) 99 11 (D) (N) - R - (24V) Lamp Voltage (Full Voltage Units Only) 6V: 6V AC/DC 12V: 12V AC/DC 24V: 24V AC/DC 120V:120V AC (LED only) 240V: 240V AC (LED only) Function L: Momentary Action OL: Maintained Action Bezel Shape Blank: Octagonal (round lenses) F: Full Shroud (round lenses) Q: Square Lens Code A: Amber G: Green R: Red S: Blue W: White Y: Yellow Series Designation W: TW series Lens Shape/Size 2: Standard Extended (round or square) 3: 29mm Mushroom 4: 40mm Mushroom Contact Terminal Style Blank: Standard N: Fingersafe Lens Type Blank: Standard (ribbed) B: Engravable (smooth with insert) Lamp Type Blank: Incandescent Lamp D: LED Lamp Illumination Circuit 99: Full Voltage (lamp determines voltage) 126:120V AC Step Down Transformer 246:240V AC Step Down Transformer 486:480V AC Step Down Transformer Contact Arrangement 10: 1NO 01: 1NC 20: 2NO 02: 2NC 11: 1NO-1NC 22:2NO-2NC 1. Use only when interpreting part numbers. Do not use for developing part numbers. 2. Transformers step down to 6V. A3-138 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - TW Series Illuminated Pushbuttons (Assembled) Part Numbers: Illuminated Pushbuttons Style Contacts Maintained 1NO-1NC 2NO 2NC ALW2 ➃ 11⑤-➁ ALW2 ➃ 20⑤-➁ ALW2 ➃ 02⑤-➁ AOLW2 ➃ 11⑤-➁ AOLW2 ➃ 20⑤-➁ AOLW2 ➃ 02⑤-➁ Full Voltage 1NO-1NC 2NO 2NC ALW29911⑤-➁-➂ ALW29920⑤-➁-➂ ALW29902⑤-➁-➂ AOLW29911⑤-➁-➂ AOLW29920⑤-➁-➂ AOLW29902⑤-➁-➂ Transformer Type 1NO-1NC 2NO 2NC ALFW2 ➃ 11⑤-➁ ALFW2 ➃ 20⑤-➁ ALFW2 ➃ 02⑤-➁ AOLFW2 ➃ 11⑤-➁ AOLFW2 ➃ 20⑤-➁ AOLFW2 ➃ 02⑤-➁ Full Voltage 1NO-1NC 2NO 2NC ALFW29911⑤-➁-➂ ALFW29920⑤-➁-➂ ALFW29902⑤-➁-➂ AOLFW29911⑤-➁-➂ AOLFW29920⑤-➁-➂ AOLFW29902⑤-➁-➂ Transformer Type 1NO-1NC 2NO 2NC ALW3 ➃ 11⑤-➁ ALW3 ➃ 20⑤-➁ ALW3 ➃ 02⑤-➁ AOLW3 ➃11⑤-➁ AOLW3 ➃20⑤-➁ AOLW3 ➃ 02⑤-➁ Full Voltage 1NO-1NC 2NO 2NC ALW39911⑤-➁-➂ ALW39920⑤-➁-➂ ALW39902⑤-➁-➂ AOLW39911⑤-➁-➂ AOLW39920⑤-➁-➂ AOLW39902⑤-➁-➂ Transformer Type 1NO-1NC 2NO 2NC ALW4 ➃ 11⑤-➁ ALW4 ➃ 20⑤-➁ ALW4 ➃ 02⑤-➁ AOLW4 ➃11⑤-➁ AOLW4 ➃20⑤-➁ AOLW4 ➃ 02⑤-➁ Full Voltage 1NO-1NC 2NO 2NC ALW49911⑤-➁-➂ ALW49920⑤-➁-➂ ALW49902⑤-➁-➂ AOLW49911⑤-➁-➂ AOLW49920⑤-➁-➂ AOLW49902⑤-➁-➂ Transformer Type 1NO-1NC 2NO 2NC ALQW2B ➃11⑤-➁ ALQW2B ➃20⑤-➁ ALQW2B ➃02⑤-➁ AOLQW2B ➃11⑤-➁ AOLQW2B ➃20⑤-➁ AOLQW2B ➃02⑤-➁ Full Voltage 1NO-1NC 2NO 2NC ALQW2B9911⑤-➁-➂ ALQW2B9920⑤-➁-➂ ALQW2B9902⑤-➁-➂ AOLQW2B9911⑤-➁-➂ AOLQW2B9920⑤-➁-➂ AOLQW2B9902⑤-➁-➂ Ø 40mm Mushroom Lens Square Extended A3 Switches & Pilot Devices Ø 29mm Mushroom Lens Momentary Transformer Type Extended Lens Extended Lens with Full Shroud Part Number 1. In place of ➁, specify the Lens Color Code (see table above). Mushroom lenses not available in yellow. 2. In place of ➂, specify the Full Voltage Code (lamp voltage) (see table above). 3. In place of ➃, specify the Transformer Voltage Code (see table above). 4. In place of ⑤, specify the Lamp Type Code from table above. 5. For sub-assembly part numbers, see page A3-140. 6. For accessories, see page A3-156. 7. For dimensions, see page A3-158. ➁ Lens/LED Color Code ➂ Full Voltage Code Voltage Code ➃ Transformer Voltage Codes Voltage Code Color Code Amber A 6V AC/DC 6V Green G 12V AC/DC 12V 120VAC 126 246 486 Red R 24V AC/DC 24V 240VAC Blue S 120V AC 120V (LED only) 480VAC White W 240V AC 240V (LED only) Yellow Y ⑤ Lamp Type Code Lamp Code Incandescent Blank LED D Transformers step down to 6V (use 6V lamp). Mushroom lenses not available in yellow. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-139 Oiltight Switches & Pilot Devices ø22mm - TW Series Illuminated Pushbuttons (Sub-Assembled) Transformer/ + Adaptor* Contacts + Lamp Holder + Operator + Lamp + Lens = Complete Part Switches & Pilot Devices A3 * Not applicable for full voltage units Part Numbers: Operators Part Number Style Momentary Maintained Part Numbers: Lamps Type Voltage LED Part Number 6V AC/DC LSTD-6➁ LSTD-1➁ Extended ALW-0600 AOLW-0600 12V AC/DC Extended with Full Shroud ALFW-0600 AOLFW-0600 24V AC/DC LSTD-2➁ LSTD-H2➁ ø29mm/ø40mm Mushroom ALW3-0600 AOLW3-0600 120V AC Square/Extended ALQW-2B0600 AOLQW-2B0600 240V AC LSTD-M4➁ 6V AC/DC IS-6 12V AC/DC IS-12 24V AC/DC IS-24 Incandescent Part Numbers: Lenses Part Number Style Standard Engravable Round Extended ALW2LU-➁ ALW2BLU-➁ 1. In place of ➁, specify the LED Color Code. 2. The LED contains a current-limiting resistor and a protection diode. Part Numbers: Lamp Circuit Components Style Application Ø 29mm Mushroom Head* ALW3LU-➁ ALW3BLU-➁ Part Number Short Lamp Holder Used with a Half-size Transformer and one contact block TW-LH1 Used with Full-size Transformer and two contact blocks Used with Half-size Transformer and three contact blocks Used with Full Voltage Adaptor and two contact blocks TW-LH2 Used with TW-LH2 holder when using four contact blocks HW-LH3 Ø 40mm Mushroom Head* ALW4LU-➁ ALW4BLU-➁ Long Lamp Holder Square Extended — ALQW2BLU-➁ 1. In place of ➁, specify the lens color code from table on the bottom right. 2. * Mushroom lens not available in yellow. 3. Standard lenses have ribbed pattern, Engravable lenses are smooth and include an engravable insert. A3-140 www.idec.com Lead Holder ➁ LED/Lens Color Code Color Code Amber A Green G Red R Blue S White W Yellow Y USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - TW Series Illuminated Pushbuttons (Sub-Assembled) con’t Part Numbers: Contact Blocks Description Part Number 1NO 1NC A3 Standard Exposed Screw HW-C01 HW-C10R (early make) HW-C01R (late break) HW-F10 HW-F01 HW-F10R (early make) HW-F01R (late break) Switches & Pilot Devices HW-C10 Fingersafe (IP20) Dummy Block TW-DB 1. Dummy blocks (no contacts) are used with an odd number of contact blocks. 2. Use of early and late break contacts creates a make before break function. Part Numbers: Transformers/Full Voltage Modules Style Description Part Number Full Size Transformer Standard Fingersafe Half Size Transformer Full voltage model (use with even number of contacts) Full voltage model (use with odd number of contacts) 120V AC 240V AC 480V AC 120V AC 240V AC 480V AC TW-T126B TW-T246B TW-T486B TW-F126B TW-F246B TW-F486B 120V AC TW-T126SB 240V AC TW-T246SB Standard TW-DA1B Fingersafe TW-DA1FB Standard HW-DA1B Fingersafe HW-DA1FB All Transformers step down to 6V (use 6V lamp). www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-141 Oiltight Switches & Pilot Devices ø22mm - TW Series Non-Illuminated Selector Switches (Assembled) Switches & Pilot Devices A3 Assembled Selector Switches A S W 3 (1) (L) 20 (N) - 304 Circuit Number Function S: Selector Switch (Standard circuits shown on following pages and A3-150.) Series Designation W: TW Series Contacts Terminal Style Blank: standard N: Fingersafe (IP20) Number of Positions 2: 2-Position 3: 3-Position 4: 4-Position 5: 5-Position Contact Arrangement Code 10: 1NO 01: 1NC 20: 2NO 02: 2NC 40: 4NO 04: 4NC 11: 1NO-1NC 22: 2NO-2NC Spring Return Action Blank: Maintained 1: Spring return from Right (2 or 3 position) 2: Spring return from Left (2 or 3 position) 3: 2-Way spring return from Left and Right (3 position only) Operator Style Code Blank: Knob Operator L: Lever Operator K: Key Operator 1. Use only when interpreting part numbers. Do not use for developing part numbers. 2. Custom contact configurations available, contact IDEC for details. 3. Portions of part number inside ( ) are optional. A3-142 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - TW Series Non-Illuminated Selector Switches (Assembled) con’t Part Numbers: 2–Position Selector Switches Style Part Number Part Number Spring Return from Left Mounting Spring Return from Right Contact Operator Position Part Number 1NO 1 2 O O X O Knob Lever Key ASW210 ASW2L10 ASW2K10 ASW2110 ASW21L10 ASW21K10 ASW2210 ASW22L10 ASW22K10 1NC 1 2 X O O O Knob Lever Key ASW201-116 ASW2L01-116 ASW2K01-116 ASW2101-116 ASW21L01-116 ASW21K01-116 ASW2201-116 ASW22L01-116 ASW22K01-116 1NO 1NC 1 2 X O O X Knob Lever Key ASW211 ASW2L11 ASW2K11 ASW2111 ASW21L11 ASW21K11 ASW2211 ASW22L11 ASW22K11 2NO 1 2 O O X X Knob Lever Key ASW220 ASW2L20 ASW2K20 ASW2120 ASW21L20 ASW21K20 ASW2220 ASW22L20 ASW22K20 2NC 1 2 X X O O Knob Lever Key ASW202-104 ASW2L02-104 ASW2K02-104 ASW2102-104 ASW21L02-104 ASW21K02-104 ASW2202-104 ASW22L02-104 ASW22K02-104 2NO 2NC 1 2 3 4 O X O X X O X O Knob Lever Key ASW222 ASW2L22 ASW2K22 ASW2122 ASW21L22 ASW21K22 ASW2222 ASW22L22 ASW22K22 2NO 2NC 1 2 3 4 O O X X X X O O Knob Lever Key ASW222-111 ASW2L22-111 ASW2K22-111 ASW2122-111 ASW21L22-111 ASW21K22-111 ASW2222-111 ASW22L22-111 ASW22K22-111 L R Maintained L R L Operator Position Part Number Spring Return from Left Spring Return Two-Way Mounting Spring Return from Right Part Number Contact Maintained Part Number A3 R Switches & Pilot Devices Part Numbers: 3–Position Selector Switches Style Part Number L R L 2NO 1 2 X O O O O X Knob Lever Key ASW320 ASW3L20 ASW3K20 ASW3120 ASW31L20 ASW31K20 ASW3220 ASW32L20 ASW32K20 ASW3320 ASW33L20 ASW33K20 2NC 1 2 O X X X X O Knob Lever Key ASW302 ASW3L02 ASW3K02 ASW3102 ASW31L02 ASW31K02 ASW3202 ASW32L02 ASW32K02 ASW3302 ASW33L02 ASW33K02 2NO 2NC 1 2 3 4 X O O X O O X X O X X O Knob Lever Key ASW322 ASW3L22 ASW3K22 ASW3122 ASW31L22 ASW31K22 ASW3222 ASW32L22 ASW32K22 ASW3322 ASW33L22 ASW33K22 2NO 2NC 1 2 3 4 X X O O O X X O X O O X Knob Lever Key ASW322-309 ASW3L22-309 ASW3K22-309 ASW3122-309 ASW31L22-309 ASW31K22-309 ASW3222-309 ASW32L22-309 ASW32K22-309 ASW3322-309 ASW33L22-309 ASW33K22-309 2NO 2NC 1 2 3 4 O O O O X O X O O X O X Knob Lever Key ASW322-310 ASW3L22-310 ASW3K22-310 ASW3122-310 ASW31L22-310 ASW31K22-310 ASW3222-310 ASW32L22-310 ASW32K22-310 ASW3322-310 ASW33L22-310 ASW33K22-310 4NO 1 2 3 4 X O X O O O O O O X O X Knob Lever Key ASW340 ASW3L40 ASW3K40 ASW3140 ASW31L40 ASW31K40 ASW3240 ASW32L40 ASW32K40 ASW3340 ASW33L40 ASW33K40 4NC 1 2 3 4 O X O X X X X X X O X O Knob Lever Key ASW304 ASW3L04 ASW3K04 ASW3104 ASW31L04 ASW31K04 ASW3204 ASW32L04 ASW32K04 ASW3304 ASW33L04 ASW33K04 www.idec.com C C R L R C L C C R L R L R USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC 1. The truth table indicates the operating position of contact block when the operator is switched to that position. X = On (closed contacts) O = Off (open contacts) X X = Overlapping Contacts: Remain on (closed contacts) when switch is moved between these two positions. 2. All knob and lever selector switches come in black. Other colors are available by ordering the knob or lever separately. 3. Every key selector switch uses an identical key. The key is removable in any maintained position. If a different configuration is required, contact an IDEC representative for more information. 4. Custom contact configurations are available, see page A3-150 or contact IDEC for details. A3-143 Oiltight Switches & Pilot Devices ø22mm - TW Series Non-Illuminated Selector Switches (Assembled) con’t Part Numbers: 4–Position Selector Switch Maintained Part Number Contact 1 1 2 3 4 X O O O 2NO 2NC 2 3 4 2 1 3 4 O X O O O O X O O O O X Knob Lever ASW422-411 ASW4L22-411 Part Numbers: 5–Position Selector Switch Maintained Part Number Mounting Operator Position Contact Switches & Pilot Devices A3 Mounting Operator Position 1 1 2 3 4 X O O O 2NO 2NC A3-144 2 3 4 5 2 1 O X O O O O O O O O X O O O O X Knob Lever www.idec.com 3 4 5 ASW522-501 ASW5L22-501 USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - TW Series Non-Illuminated Selector Switches (Sub-Assembled) Contact Blocks + Operator + Knob or Lever * + Color Insert * Complete Part † = A3 Switches & Pilot Devices 1. * Not needed with key type switches. 2. † Knob type shown. Part Numbers: Operators Style Positions Description 2 Knob/Lever 3 4 5 2 Key 3 Part Number Maintained Spring return from right Spring return from left Maintained, Cam 1 Maintained, Cam 2 Maintained, Cam 3 Spring return from right, Cam 1 Spring return from right, Cam 2 Spring return from left, Cam 1 Spring return from left, Cam 2 Spring return from left/right, Cam 1 Spring return from left/right, Cam 2 Maintained, Standard Cam Maintained, Cam 1 Maintained, Standard cam Maintained, Cam 1 ASW200 ASW2100 ASW2200 ASW300-1 ASW300-2 ASW300-3 ASW3100-1 ASW3100-2 ASW3200-1 ASW3200-2 ASW3300-1 ASW3300-2 ASW400 ASW400-1 ASW500 ASW500-1 Maintained Spring return from right Spring return from left Maintained, Cam 1 Maintained, Cam 2 Maintained, Cam 3 Spring return from right, Cam 1 Spring return from right, Cam 2 Spring return from left, Cam 1 Spring return from left, Cam 2 Spring return from left/right, Cam 1 Spring return from left/right, Cam 2 ASW2K00 ASW21K00 ASW22K00 ASW3K00-1 ASW3K00-2 ASW3K00-3 ASW31K00-1 ASW31K00-2 ASW32K00-1 ASW32K00-2 ASW33K00-1 ASW33K00-2 1. Two keys are supplied with every switch, all are keyed alike, and removable from any maintained position. For other configurations, consult your IDEC representative. 2. Locking rings are included with all operators. Order knobs, levers, and color inserts separately. 3. Different cams produce different contact actions. For details, see contact arrangement charts, page A3-150. Part Numbers: Handles and Inserts Style Part Number Knob ASWHHY-① Lever ASWHHL-① Color Insert TW-HC1-① Part Numbers: Contact Blocks Style Part Number 1NO 1NC Standard HW-C10 HW-C01 HW-C10R (early make) HW-C01R (late break) HW-F10 HW-F01 HW-F10R (early make) HW-F01R (late break) Fingersafe (IP20) Dummy Block TW-DB ① Handle/Insert Color Code Color Code Black* B Blue S Green G Red R Yellow Y White† W 1. Push rod color code:Green = NO contact block Red = NC contact block. 2. Dummy blocks (no contacts) are used with an odd number of contact blocks. * Color inserts not available in black. † Knob and lever not available in white. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-145 Oiltight Switches & Pilot Devices ø22mm - TW Series Illuminated Selector Switches (Assembled) Switches & Pilot Devices A3 Assembled Illuminated Selector Switches A SL W 2 (2) 99 11 (D) (N) - (202) - R - (24V) Function SL: Illuminated Selector Switch Lamp Voltage (Full Voltage Units Only) 6V: 6V AC/DC 12V: 12V AC/DC 24V: 24V AC/DC 120V: 120V AC (LED only) 240V: 240V AC (LED only) Series Designation W: TW Series Number of Positions 2: 2-Position 3: 3-Position Spring Return Action Blank: Maintained 1: Spring return from Right 2: Spring return from Left 3: Two-Way spring return from Left & Right Lens Color Code A: Amber G: Green R: Red S: Blue W: White Y: Yellow Illumination Circuit 99: Full Voltage (lamp determines voltage) 126: 120V AC Step Down Transformer 246: 240V AC Step Down Transformer 486: 480V AC Step Down Transformer Contact Circuit No. Standard circuits are listed on the following pages and A3-150. Contacts Terminal Style Blank: standard N: Fingersafe (IP20) Lamp Type Blank: Incandescent D: LED Contact Arrangement Code 10: 1NO 01: 1NC 20: 2NO 02: 2NC 40: 4NO 04: 4NC 11: 1NO-1NC 22: 2NO-2NC 1. Use only when interpreting part numbers. Do not use for developing part numbers. 2. All transformers step down to 6V (use 6V lamp). A3-146 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - TW Series Illuminated Selector Switches (Assembled) con’t Contact Operator Position L R Spring Return from Right Maintained Lamp Circuit Type L ➀ Transformer Voltage Code Spring Return from Left R L L R R Code 120V AC 126 240V AC 246 480V AC 486 A3 Transformers step down to 6V (use 6V lamp). 1NO 1NC 1 2 O X X O Transformer Full Voltage ASLW2 ➀ 11➃-➁ ASLW29911➃-➁-➂ ASLW21 ➀ 11➃-➁ ASLW219911➃-➁-➂ ASLW22 ➀ 11➃-➁ ASLW229911➃-➁-➂ 2NO 1 2 O O X X Transformer Full Voltage ASLW2 ➀ 20➃-➁ ASLW29920➃-➁-➂ ASLW21 ➀ 20➃-➁ ASLW219920➃-➁-➂ ASLW22 ➀ 20➃-➁ ASLW229920➃-➁-➂ 2NC 1 2 X X O O Transformer Full Voltage ASLW2 ➀ 02➃-104-➁ ASLW21 ➀ 02➃-104-➁ ASLW29902➃-104-➁-➂ ASLW219902➃-104-➁-➂ 1 2 3 4 O X O X X O X O Transformer Full Voltage ASLW2 ➀ 22➃-➁ ASLW29922➃-➁-➂ 2NO 2NC Voltage ASLW21 ➀ 22➃-➁ ASLW219922➃-➁-➂ ➁ Lens Color Code Color Code Color ASLW22 ➀ 02➃-104-➁ ASLW229902➃-104-➁-➂ Amber A Blue S Green G White W ASLW22 ➀ 22➃-➁ ASLW229922➃-➁-➂ Red R Yellow Y Part Numbers: Illuminated 3–Position Selector Switches Maintained and Spring Return from Right Style Part Number Part Number Part Number Operator Position Spring Return From Right Part Number Spring Return Two-Way Mounting Spring Return from Left Contact Maintained Code L 2NO 1 2 X O O O O X Transformer Full Voltage ASLW3 ➀ 20➃-➁ ASLW39920➃-➁-➂ ASLW31 ➀ 20➃-➁ ASLW319920➃-➁-➂ ASLW32 ➀ 20➃-➁ ASLW329920➃-➁-➂ ASLW33 ➀ 20➃-➁ ASLW339920➃-➁-➂ 2NC 1 2 O X X X X O Transformer Full Voltage ASLW3 ➀ 02➃-➁ ASLW39902➃-➁-➂ ASLW31 ➀ 02➃-➁ ASLW319902➃-➁-➂ ASLW32 ➀ 02➃-➁ ASLW329902➃-➁-➂ ASLW33 ➀ 02➃-➁ ASLW339902➃-➁-➂ 2NO 2NC 1 2 3 4 X O O X O O X X O X X O Transformer Full Voltage ASLW3 ➀ 22➃-➁ ASLW39922➃-➁-➂ ASLW31 ➀ 22➃-➁ ASLW319922➃-➁-➂ ASLW32 ➀ 22➃-➁ ASLW329922➃-➁-➂ ASLW33 ➀ 22➃-➁ ASLW339922➃-➁-➂ 2NO 2NC 1 2 3 4 X X O O O X X O X O O X Transformer Full Voltage ASLW3 ➀ 22➃-309-➁ ASLW39922➃-309-➁-➂ ASLW31 ➀ 22➃-309-➁ ASLW319922➃-309-➁-➂ ASLW32 ➀ 22➃-309-➁ ASLW329922➃-309-➁-➂ ASLW33 ➀ 22➃-309-➁ ASLW339922➃-309-➁-➂ 2NO 2NC 1 2 3 4 O O O O X O X O O X O X Transformer Full Voltage ASLW3 ➀ 22➃-310-➁ ASLW39922➃-310-➁-➂ ASLW31 ➀ 22➃-310-➁ ASLW319922➃-310-➁-➂ ASLW32 ➀ 22➃-310- ➁ ASLW329922➃-310- ➁ -➂ ASLW33 ➀ 22➃-310-➁ ASLW339922➃-310-➁-➂ 4NO 1 2 3 4 X O X O O O O O O X O X Transformer Full Voltage ASLW3 ➀ 40➃-➁ ASLW39940➃-➁-➂ ASLW31 ➀ 40➃-➁ ASLW319940➃-➁-➂ ASLW32 ➀ 40➃-➁ ASLW329940➃-➁-➂ ASLW33 ➀ 40➃-➁ ASLW339940➃-➁-➂ 4NC 1 2 3 4 O X O X X X X X X O X O Transformer Full Voltage ASLW3 ➀ 04➃-➁ ASLW39904➃-➁-➂ ASLW31 ➀ 04➃-➁ ASLW319904➃-➁-➂ ASLW32 ➀ 04➃-➁ ASLW329904➃-➁-➂ ASLW33 ➀ 04➃-➁ ASLW339904➃-➁-➂ C R Lamp Circuit Type 1. In place of ➀, specify the Transformer Voltage Code. 2. In place of ➁, specify the Lens/LED Color Code. 3. In place of ➂, specify the Full Voltage Code. 4. In place of ➃ specify Lamp Type Code 5. For custom contact configuration, see page A3-150. Contact IDEC for details. www.idec.com C L C R L R ➂ Full Voltage Code C L C R L R ➃ Lamp Type Code Voltage Code Lamp Code 6V AC/DC 6V Incandescent Blank 12V AC/DC 12V LED D 24V AC/DC 24V 120V AC 120V (LED only) 240V AC 240V (LED only) USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-147 Switches & Pilot Devices Mounting Part Numbers: Illuminated 2–Position Selector Switches Style Part Number Oiltight Switches & Pilot Devices ø22mm - TW Series Illuminated Selector Switches (Sub-Assembled) Transformer* + Contact Block + Operator + Lamp/Lead Holder † + Lamp + Lens = Complete Part Switches & Pilot Devices A3 1.* Full voltage units use a full voltage adaptor (TW-DA1B) instead of a transformer. 2. † Lamp holder is not included with operators, order separately. Lead holder is used when using 3 or more contact blocks. Order separately. Part Numbers: Operators Positions 2 3 Part Number Description Maintained ASLW200 Spring return from right ASLW2100 Spring return from left ASLW2200 Maintained, cam 1 Maintained, cam 2 Maintained, cam 3 ASLW300-1 ASLW300-2 ASLW300-3 Spring return from right, cam 1 Spring return from right, cam 2 ASLW3100-1 ASLW3100-2 Spring return from left, cam 1 Spring return from left, cam 2 ASLW3200-1 ASLW3200-2 Spring return from left/right, cam 1 Spring return from left/right, cam 2 ASLW3300-1 ASLW3300-2 Part Numbers: Lamps (LED) Type Voltage LED Incandescent Knob ASLWLU-➁ In place of ➁ specify Lens Color Code. A3-148 www.idec.com 6V AC/DC LSTD-6➁ 12V AC/DC LSTD-1➁ 24V AC/DC LSTD-2➁ 120V AC LSTD-H2➁ 240V AC LSTD-M4➁ 6V AC/DC IS-6 12V AC/DC IS-12 24V AC/DC IS-24 1. In place of ➁, specify the LED Color Code. 2. The LED contains a current-limiting resistor and a protection diodes. Different cams produce different contact action. For details, Contact Arrangements on page A3-150. Part Numbers: Lenses (Knobs) Description Part Number Part Number ➁ LED/Lens Color Code Color Code Amber A Green G Red R Blue S White W Yellow Y USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - TW Series Illuminated Selector Switches (Sub-Assembled) con’t Part Numbers: Contact Blocks Description Part Numbers: Transformers/Full Voltage Modules Style Description Part Number Part Number 1NO 1NC Full Size Transformer Standard HW-C01 HW-C10R (early make) HW-C01R (late break) Fingersafe Half Size Transformer 120V AC 240V AC 480V AC 120V AC 240V AC 480V AC TW-T126B TW-T246B TW-T486B TW-F126B TW-F246B TW-F486B 120V AC TW-T126SB 240V AC TW-T246SB Standard TW-DA1B Fingersafe TW-DA1FB Standard HW-DA1B Fingersafe HW-DA1FB Fingersafe (IP20) HW-F10 HW-F01 HW-F10R (early make) HW-F01R (late break) Full voltage model (use with even number of contacts) Dummy Block TW-DB Full voltage model (use with odd number of contacts) 1. Dummy blocks (no contacts) are used with an odd number of contact blocks. 2. Use of early and late break contacts creates a make before break function All Transformers step down to 6V (use 6V lamp). Part Numbers: Lamp Circuit Components Style Application Part Number Short Lamp Holder Long Lamp Holder Used with a Half-size Transformer and one contact block TW-LH1 Used with a Full-size Transformer and two contact blocks Used w/Half-size Transformer and three contact blocks Used w/Full Voltage Adaptor and two contact blocks TW-LH2 Used w/TW-LH2 holder when using four contact blocks HW-LH3 Lead Holder www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-149 A3 Switches & Pilot Devices HW-C10 Standard Oiltight Switches & Pilot Devices ø22mm - TW Series Contact Arrangement Charts How to Read Contact Arrangement Charts To determine contact block mounting position, first make sure the selector switch is oriented as shown on the right Switches & Pilot Devices A3 Contact Arrangement Mounting Positions Type and quantity of switch contacts Circuit Number L R 4 2 3 * N/D = No designation required 1 Contact Block Mounting Position Position or mounting contact blocks on operator Operator Position Truth table indicates the operating position of contact block when operator is switched to that position. Contact Block Part Number Part number to use when ordering subassembly contact blocks, as required for use with corresponding mounting position Contact Arrangement Chart: 2-Position Selector Switches Style Mounting Operator Contact Block Description Circuit Position Position Part Number Contact Number L R Operator Part Number Spring Ret. Spring Ret. Maintained from Rt. from Lt. L 1NO N/D 1NC 116 N/D 1NO 1NC 103 600 1NO-EM 1NC-LB 601 2NO N/D 2NC 104 N/D 2NO 2NC 111 1 O X HW-C10 2 O O TW-DB 1 X O HW-C01 2 O O TW-DB 1 O X HW-C10 2 X O HW-C01 1 X O HW-C01 2 O X HW-C10 1 O X HW-C10R 2 X O HW-C01R 1 X O HW-C01R 2 O X HW-C10R 1 O X HW-C10 2 O X HW-C10 1 X O HW-C01 2 X O HW-C01 1 2 3 4 1 2 3 4 O X O X O O X X X O X O X X O O HW-C10 HW-C01 HW-C10 HW-C01 HW-C10 HW-C10 HW-C01 HW-C01 R L R L R Knob/Lever Key Illuminated Knob ASW200 ASW2K00 ASLW200 ASW2100 ASW21K00 ASLW2100 ASW2200 ASW22K00 ASLW2200 Knob/Lever Key Illuminated Knob ASW200 ASW2K00 ASLW200 ASW2100 ASW21K00 ASLW2100 ASW2200 ASW22K00 ASLW2200 Knob/Lever Key Illuminated Knob ASW200 ASW2K00 ASLW200 ASW2100 ASW21K00 ASLW2100 ASW2200 ASW22K00 ASLW2200 Knob/Lever Key Illuminated Knob ASW200 ASW2K00 ASLW200 ASW2100 ASW21K00 ASLW2100 ASW2200 ASW22K00 ASLW2200 Knob/Lever Key Illuminated Knob ASW200 ASW2K00 ASLW200 ASW2100 ASW21K00 ASLW2100 ASW2200 ASW22K00 ASLW2200 Knob/Lever Key Illuminated Knob ASW200 ASW2K00 ASLW200 ASW2100 ASW21K00 ASLW2100 ASW2200 ASW22K00 ASLW2200 Knob/Lever Key Illuminated Knob ASW200 ASW2K00 ASLW200 ASW2100 ASW21K00 ASLW2100 ASW2200 ASW22K00 ASLW2200 Knob/Lever Key Illuminated Knob ASW200 ASW2K00 ASLW200 ASW2100 ASW21K00 ASLW2100 ASW2200 ASW22K00 ASLW2200 Knob/Lever Key Illuminated Knob ASW200 ASW2K00 ASLW200 ASW2100 ASW21K00 ASLW2100 ASW2200 ASW22K00 ASLW2200 Knob/Lever Key Illuminated Knob ASW200 ASW2K00 ASLW200 ASW2100 ASW21K00 ASLW2100 ASW2200 ASW22K00 ASLW2200 1. NO-EM, NC-LB = Early Make, Late Break. N/D = No circuit number designation required in assembled selector switch part number. 2. X = On (closed contacts) O = Off (Open contacts) A3-150 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices Contact Arrangement Chart: 3-Position Selector Switches Style Mounting Operator Contact Block Circuit Position Position Part Number Contact Number L C Description Maintained R 1NO 1NC 302 303 N/D 2NO 301 304 2NC N/D N/D 210 2NO 2NC 308 309 310 N/D 4NO 305 N/D 4NC 314 1 X 0 0 HW-C10 2 X X O HW-C01 1 0 X X HW-C01 2 O 0 X HW-C10 1 X 0 X HW-C10 2 X X O HW-C01 1 0 X O HW-C01 2 O 0 X HW-C10 1 X 0 0 HW-C10 2 O 0 X HW-C10 1 X 0 X HW-C10 2 O 0 X HW-C10 1 0 X O HW-C01 2 X X O HW-C01 1 0 X X HW-C01 2 X X O HW-C01 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 X 0 0 X 0 0 0 0 X X X X X X 0 O 0 O 0 0 X 0 X 0 X 0 X 0 0 X 0 X 0 X 0 X 0 0 X X X 0 X 0 0 X 0 X 0 X X 0 X 0 X 0 0 0 0 0 0 0 0 0 X X X X X X X X 0 X X 0 X X X X X 0 X O X 0 O X O X O X 0 X 0 X X X X X X 0 X O O 0 O 0 HW-C10 HW-C10 HW-C01 HW-C01 HW-C01 HW-C10 HW-C01 HW-C10 HW-C10 HW-C01 HW-C10 HW-C01 HW-C10 HW-C01 HW-C01 HW-C10 HW-C01 HW-C10 HW-C01 HW-C10 HW-C10 HW-C10 HW-C10 HW-C10 HW-C10 HW-C10 HW-C10 HW-C10 HW-C01 HW-C01 HW-C01 HW-C01 HW-C01 HW-C01 HW-C01 HW-C01 C R L Two-Way C C R L R L R Knob/Lever Key Illuminated Knob ASW300-1 ASW3K00-1 ASLW300-1 ASW3100-1 ASW31K00-1 ASLW3100-1 ASW3200-1 ASW32K00-1 ASLW3200-1 ASW3300-1 ASW33K00-1 ASLW3200-1 A3 Knob/Lever Key Illuminated Knob ASW300-1 ASW3K00-1 ASLW300-1 ASW3100-1 ASW31K00-1 ASLW3100-1 ASW3200-1 ASW32K00-1 ASLW3200-1 ASW3300-1 ASW33K00-1 ASLW3200-1 Knob/Lever Key Illuminated Knob ASW300-2 ASW3K00-2 ASLW300-2 ASW3100-2 ASW31K00-2 ASLW3100-2 ASW3200-2 ASW32K00-2 ASLW3200-2 ASW3300-2 ASW33K00-2 ASLW3200-2 Knob/Lever Key Illuminated Knob ASW300-2 ASW3K00-2 ASLW300-2 ASW3100-2 ASW31K00-2 ASLW3100-2 ASW3200-2 ASW32K00-2 ASLW3200-2 ASW3300-2 ASW33K00-2 ASLW3200-2 Knob/Lever Key Illuminated Knob ASW300-1 ASW3K00-1 ASLW300-1 ASW3100-1 ASW31K00-1 ASLW3100-1 ASW3200-1 ASW32K00-1 ASLW3200-1 ASW3300-1 ASW33K00-1 ASLW3200-1 Knob/Lever Key Illuminated Knob ASW300-2 ASW3K00-2 ASLW300-2 ASW3100-2 ASW31K00-2 ASLW3100-2 ASW3200-2 ASW32K00-2 ASLW3200-2 ASW3300-2 ASW33K00-2 ASLW3200-2 Knob/Lever Key Illuminated Knob ASW300-2 ASW3K00-2 ASLW300-2 ASW3100-2 ASW31K00-2 ASLW3100-2 ASW3200-2 ASW32K00-2 ASLW3200-2 ASW3300-2 ASW33K00-2 ASLW3200-2 Switches & Pilot Devices 203 Operator Part Number Spring Ret. Spring Ret. from Rt. from Lt. C L 202 ø22mm - TW Series Knob/Lever Key Illuminated Knob ASW300-1 ASW3K00-1 ASLW300-1 ASW3100-1 ASW31K00-1 ASLW3100-1 ASW3200-1 ASW32K00-1 ASLW3200-1 ASW3300-1 ASW33K00-1 ASLW3200-1 Knob/Lever Key Illuminated Knob ASW300-1 ASW3K00-1 ASLW300-1 ASW3100-1 ASW31K00-1 ASLW3100-1 ASW3200-1 ASW32K00-1 ASLW3200-1 ASW3300-1 ASW33K00-1 ASLW3200-1 Knob/Lever Key Illuminated Knob ASW300-1 ASW3K00-1 ASLW300-1 ASW3100-1 ASW31K00-1 ASLW3100-1 ASW3200-1 ASW32K00-1 ASLW3200-1 ASW3300-1 ASW33K00-1 ASLW3200-1 Knob/Lever Key Illuminated Knob ASW300-2 ASW3K00-2 ASLW300-2 ASW3100-2 ASW31K00-2 ASLW3100-2 ASW3200-2 ASW32K00-2 ASLW3200-2 ASW3300-2 ASW33K00-2 ASLW3200-2 Knob/Lever Key Illuminated Knob ASW300-2 ASW3K00-2 ASLW300-2 ASW3100-2 ASW31K00-2 ASLW3100-2 ASW3200-2 ASW32K00-2 ASLW3200-2 ASW3300-2 ASW33K00-2 ASLW3200-2 Knob/Lever Key Illuminated Knob ASW300-2 ASW3K00-2 ASLW300-2 ASW3100-2 ASW31K00-2 ASLW3100-2 ASW3200-2 ASW32K00-2 ASLW3200-2 ASW3300-2 ASW33K00-2 ASLW3200-2 Knob/Lever Key Illuminated Knob ASW300-1 ASW3K00-1 ASLW300-1 ASW3100-1 ASW31K00-1 ASLW3100-1 ASW3200-1 ASW32K00-1 ASLW3200-1 ASW3300-1 ASW33K00-1 ASLW3200-1 Knob/Lever Key Illuminated Knob ASW300-2 ASW3K00-2 ASLW300-2 ASW3100-2 ASW31K00-2 ASLW3100-2 ASW3200-2 ASW32K00-2 ASLW3200-2 ASW3300-2 ASW33K00-2 ASLW3200-2 Knob/Lever Key Illuminated Knob ASW300-1 ASW3K00-1 ASLW300-1 ASW3100-1 ASW31K00-1 ASLW3100-1 ASW3200-1 ASW32K00-1 ASLW3200-1 ASW3300-1 ASW33K00-1 ASLW3200-1 Knob/Lever Key Illuminated Knob ASW300-2 ASW3K00-2 ASLW300-2 ASW3100-2 ASW31K00-2 ASLW3100-2 ASW3200-2 ASW32K00-2 ASLW3200-2 ASW3300-2 ASW33K00-2 ASLW3200-2 1. Each operator sub-assembly is available as a “-1" and a “-2" for 3-position selector switches. The internal cam of a “-1" is different from that of a “-2". This results in designated combinations of open and closed contacts in the various operator positions. 2. N/D = No circuit number designation required in assembled part number. 3. X = On (closed contacts) O = Off (open contacts). X X Overlapping contacts remain on (closed) when switch is moved between these two positions. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-151 Oiltight Switches & Pilot Devices ø22mm - TW Series Custom Selector Switch Building Guide To build a custom selector switch, follow these steps. Step1: How many positions of the switch are needed? # of positions (2, 3, 4, 5) Switches & Pilot Devices A3 Mounting Positions L R 4 2 3 Step 2: How many contacts should there be? # of isolated contacts (maximum 6) 1 Step 3: Fill in the Truth Table (X = closed, O = open) Knob Position 1 2 3 4 5 1 C o n t a c t s 2 3 4 5 6 Step 4: If building a 2 position selector, skip this step. (2 position selectors have only one cam) If building a 3, 4, or 5 position selector, determine appropriate cam as follows: -Look at Row 1 from above table and locate an identical row in the operator truth tables (See next page). -Repeat for all rows. The user must find one operator that contains all rows from above table. -Record the operator cam version. Operator CAM Version (-1, -2, -3 for 3 position) (“blank”, -1 for 4 position) (“blank”, -1 for 5 position) Step 5: Build by placing appropriate contact in appropriate mounting position for each desired row on operator cam truth table. “L” and “R” refer to mounting on left or right side of operator as viewed from the front of the panel. Step 6: Develop an assembly part number (if necessary) as follows: follow standard numbering nomenclature for selector switches (see pages A3-142 or A3-146). In place of the “Circuit Number” indicate the cam number and contact arrangement as such ASW322-3-OELCSS, where “3” is the cam number, and contact arrangement “OELCXX” calls out individual contact mounting locations in order (see diagram above). O=NO, C=NC, E=NO-EM, L=NC-LB, X= no contact. Part number must designate all 6 possible mounting locations. Caution: Before putting any custom selector switch into use, the user should use an ohmmeter to test for desired performance. 1. For Operator Truth Tables, see next page. 2. For examples of how to assemble selector switches, see A3-82. A3-152 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - TW Series Operator Truth Tables Use the following tables to build custom selector switches. 2 Position Selector Switches 4 Position Selector Switches Mounting Operator Position Contact Position Left Right ASW200 ASLW200 ASW2K00 HW-C01 (NC) HW-C10R (NO-EM) HW-C01R (NC-LB) L O X R O X L X O R X O L 0 X R O X L X O R X O Contact HW-C10 (NO) ASW300-1 ASW3K00-1 ASLW300-1 HW-C01 (NC) HW-C10R (NO-EM) HW-C01R (NC-LB) 1 2 3 4 L X O O O R O X O O L O X X X R X O X X L X O O O R O X O O L O X X X R X O X X HW-C10 (NO) HW-C01 (NC) ASW400 HW-C10R (NO-EM) HW-C01R (NC-LB) 3 Position Selector Switches L X O O R O O X L O X X R X X O L X O O R O O X L O X X R X X O A3 Operator Position Mounting Position Contact Mounting Operator Position Position Left Center Right Operator Position Mounting Position 1 2 3 4 HW-C10 (NO) L X O O O R O O O X HW-C01 (NC) L O O X O R O X O O HW-C10R (NO-EM) L X X O X R X O X X HW-C01R (NC-LB) L O X X X R X X X O ASW400-1 Switches & Pilot Devices HW-C10 (NO) Contact 5 Position Selector Switches Contact ASW300-2 ASW3K00-2 ASLW300-2 Mounting Position Left Center Right HW-C10 (NO) L X O X R O O X HW-C01 (NC) L O X O R X X O HW-C10R (NO-EM) L X O X R O O X HW-C01R (NC-LB) L O X O R X X O Contact HW-C10 (NO) ASW300-3 ASW3K00-3 ASLW300-3 Operator Position HW-C01 (NC) HW-C10R (NO-EM) HW-C01R (NC-LB) www.idec.com Contact L X O O R O O X L O X O R O X O L X O X R X O X L O X X R X X O Operator Position 1 2 3 4 5 HW-C10 (NO) L X O O O O R O X O O O HW-C01 (NC) L O O X X X R O O O X X HW-C10R (NO-EM) L X O O O O R O X O O O HW-C01R (NC-LB) L O X X X X R X O X X X ASW500 Mounting Operator Position Position Left Center Right Mounting Position Contact HW-C10 (NO) HW-C01 (NC) ASW500-1 HW-C10R (NO-EM) HW-C01R (NC-LB) Operator Position Mounting Position 1 2 3 4 5 L X O O O O R O O O O X L O O O X O R O X O O O L X X X O X R X O X X X L O X X X X R X X X X O USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-153 Oiltight Switches & Pilot Devices ø22mm - TW Series Nameplates — TW Series Part Numbers: Nameplates NWAL NWAQL A3 NWAS 1.13" (29mm) 1.76" (45mm) Ø 70 1.76" (45mm) (25mm) 0.975" 0.566" (14.5mm) 1.0" Part Number GENC ER M E Y (25.4mm) 1.13" (29mm) Switches & Pilot Devices EMERGENCY STOP ST OP Yellow Part Number Part Number Part Number Nameplate (blank) NWAL-OB (black) NWAL-OR (red) NWAQL-OB (black) NWAQL-OR (red) NWAS-OB NWAR-O Nameplate (engraved) NWAL-➀ NWAQL-➀ NWAS-➀ NWAR-27† 1. In place of ➀, insert either the Standard Legend Code from table below or custom engraving delimited by “ “. 2. Standard engravings are available at no charge. 3 NWAR-27 comes marked “Emergency Stop” as shown in drawing. Standard Legend Codes Pushbuttons Pushbuttons/Selector Switches Legend Code Legend Code Legend Code AUTO CLOSE DOWN EMERG.STOP* FAST FORWARD HAND HIGH IN INCH JOG LOW LOWER OFF ON 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 OPEN OUT RAISE RESET REVERSE RUN SLOW START STOP* STOP TEST UP I (Int’l On) O (Int’l Off) EMO 116 117 118 119 120 121 122 123 124 125 126 127 150 151 152 AUTO-MAN CLOSE-OPEN DOWN-UP FAST-SLOW FOR-REV HAND-AUTO HIGH-LOW JOG-RUN LEFT-RIGHT LOWER-RAISE MAN-AUTO OFF-ON ON-OFF OPEN-CLOSE RAISE-LOWER 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 Legend REV-FOR RUN-JOG RUN-SAFE SAFE-RUN SLOW-FAST START-STOP STOP-START UP-DOWN Selector Switches Code Legend Code 216 217 218 219 220 221 222 223 AUTO-MAN-OFF AUTO-OFF-MAN CLOSE-OFF-OPEN DOWN-OFF-SLOW FAST-OFF-SLOW FOR-OFF-REV LEFT-OFF-RIGHT LOWER-OFF-RAISE OFF-MAN-AUTO OFF-SLOW-FAST OFF-1-2 OPEN-OFF-CLOSE SLOW-OFF-FAST SUMMER-OFF-WINTER UP-OFF-DOWN 1-OFF-2 HAND-OFF-AUTO 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 1. To order engraved nameplates, add legend code to nameplate part number. Character height based on the number of characters and size of nameplate. Standard character size is 3/16". 2. Nameplates with standard legends are the same list price as blank nameplates. 3. * Available in red as standard. Nameplate Order Form on next page. A3-154 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - TW Series Custom Engraved Nameplates Order Form — TW Series Copy this order form and use it to specify Letter Height, Custom Engravings, Location of Engraving on Nameplate, and Quantity Desired. To insure engraving accuracy, fax it to your IDEC representative. or Distributor. Your Company Name: IDEC Rep/Distributor Contact: Your Name: PO number (if known): Telephone: IDEC Rep/Distributor Phone: Fax & Email IDEC Rep/Distributor Fax & Email A3 Engraving Location Step 1. Choose Letter Size - 7/64” or 1/8”. Check the box for the letter size you want. Then write your lettering in box below checkboxes. Note: 1/8” size letters cannot exceed 9 characters. Step 2. Specify Quantity. Enter the number of nameplates desired in the box on the right. 7/64” Letter Size 11 characters max (for 7/64” size letters) 1/8” Letter Size 9 characters max (for 1/8” size letters) Sample Letter Sizes 7/64” Letters: A B C D 1/8” Letters: A B C D Qty 1 2 3 4 5 6 7 8 9 10 11 NWAQL Engraving Location Step 1. Choose Letter Size - 7/64” or 1/8”. Check the box for the letter size you want. Then write your lettering in box below checkboxes. Note: 1/8” size letters cannot exceed 9 characters. Step 2. Specify Quantity. Enter the number of nameplates desired in the box on the right. 7/64” Letter Size 11 characters max (for 7/64” size letters) 1/8” Letter Size 9 characters max (for 1/8” size letters) Sample Letter Sizes 7/64” Letters: A B C D 1/8” Letters: Qty 1 2 3 4 5 6 7 ABCD 8 9 10 11 NWAS Engraving Location A Step 1. Choose Letter Size - 1/8” or 3/32”. Check the box for the letter size you want. Then write your lettering in box below checkboxes. Note: 1/8” size letters cannot exceed 14 characters. 3/32” Letter Size 1/8” Letter Size 20 characters maximum (for 3/32” size letters) 14 characters maximum (for 1/8” size letters) Engraving Location B 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Step 2. Specify Quantity. Enter the number of nameplates desired in box on the right. www.idec.com Qty Step 3. Specify Location. Enter the location of engraving (A or B), in box on the right. Sample Letter Sizes 3/32” Letters: A B C D 1/8” Letters: A B C D Location USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-155 Switches & Pilot Devices NWAL ø22mm - TW Series Oiltight Switches & Pilot Devices Accessories — TW Series Part Numbers: TW Series Accessories Appearance Switches & Pilot Devices A3 Description/Usage Part Number Lamp Removal Tool Rubber tool used to install LED’s and incandescent lamps OR-55 Contact Block Remover Used to remove contact blocks, transformers, lenses, and adaptors. Can also be used to determine panel thickness adjustment. TW-KC1 Nut Locking Wrench Used in OR-14 locking wrench to tighten locking nuts inside square bezel TW-KQ2 Metal Bezel Chrome plated bezels tighten onto operator (replacement for damaged bezels) Black plastic bezels for square buttons (replacement for damaged bezels) Plastic Bezel Used to cover and protect pushbuttons Boot/Cover Standard octagonal units (chrome-pl.) AW-R8 Full shroud octagonal units (chrome-pl.) AW-RF8 Full shroud (chrome plated) mushroom head units Ø 40mm AW-G4 Round flush units (black plastic) AW-RP1B Round extended units (black plastic) AW-FP1B Square units (black plastic) AW-Q1B Square bezel with round hole (black plastic) AW-H1B Square units with full shroud (black plastic) AW-QF1B Waterproof lens cover for square pilot lights APW00LN Waterproof lens cover for square illuminated buttons APW00L Clear boot for round flush units (EPR) OC-31 Clear boot for round extended units (EPR) OC-32 *In place of asterisk, specify Rubber Boot color: B (black), G (green), R (red), Y (yellow) - (nitril rubber) OCW-11* Ring to prevent operator base from rotating in the mounting hole. Anti-Rotation Ring OGL-31 Used when nameplate is not used Mounting Hole Plug Metallic Mounting Hole Plug Black rubber plug fills unused mounting holes in panel. OB-31 For plugging unused mounting holes in the panel. Tighten the attached locking ring to a torque of 12 kfg-cm maximum LW9Z-BM Degree of protection: IP66 Replacement Keys Pair of keys (#0) TW-SK For information on replacement engraving inserts, see page A3-164. A3-156 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - TW Series Accessories con’t Part Numbers: TW Series Accessories Appearance Description/Usage Part Number Metal Button Guard OLW-C Quick- connect terminals TW-FA1 A3 Switches & Pilot Devices Used on flush buttons to prevent inadvertent actuation Terminal Tab Adaptor #250 (17/64" x 3/64") single tab Lock-out Adaptor Used to provide lock-out protection for pushbuttons and knob selector switches: • Up to Ø 40mm mushroom head size (Padlock not included.) HW9Z-KL1 Used to mount TW series control unit (except square units) Ø 7/8" (22mm) into a Ø 1-13/64" (30mm) panel cut-out. Includes 2 pieces shown on the right TWN-A1R8 TW to TWTD Adaptor Adaptor Fits on TW unit base Replacement Marking Plates Round Pushbutton (Ø14mm) White plastic engraving plate for use on all illuminated units (included in each lens). May be used to capture printed mylar insert (not supplied by IDEC) under lens face. HW-VL3 APS-PVL Part Numbers: Fingersafe Covers for TW Series Appearance Description HW VL6 HW VL5 www.idec.com ALW2B Round Pilot Light (Ø 14mm) APW2B Mushroom Pushbutton (Ø 14mm) ALW3B Square Pilot Light (❑ 21mm) APQW1B Square Pushbutton (❑ 21mm) ALQW2B Used with Part Number Fingersafe terminal cover, adds 6mm to overall depth APW and UPQW full voltage pilot lights APS-PVL Fingersafe terminal cover, adds 3.5mm to overall depth. One required for each contact, only for rear- most terminals Non-illuminated pushbuttons and selectors HW-VL2 Fingersafe terminal cover, adds 3mm to overall depth APW and UPQW transformer pilot lights, and illuminated pushbuttons and illuminated selectors HW-VL3 Fingersafe terminal cover for contacts. Full voltage illuminated pushbuttons and selectors HW-VL4 Fingersafe terminal cover for full voltage adaptor, adds 3 mm to depth Full voltage illuminated pushbuttons and selectors HW-VL5 Fingersafe terminal cover for half size transformer adaptor, adds 3 mm to depth Illuminated pushbuttons and selectors HW-VL6 USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-157 Oiltight Switches & Pilot Devices ø22mm - TW Series Dimensions — TW Series Pushbuttons 22.5 37 37 ø24 ø29 ø46 Keylock Push On/Off Panel Thickness: 1 to 6 mm Resetting (Unlock) M3.5 Terminal Screw Panel Thickness: 1 to 6 mm Resetting angle 75° ø40 Resetting angle 75° 30 23 45° ø29 M3.5 Terminal Screw Panel Thickness: 1 to 6 mm ø29 48.5 (2 blocks) 68.5 (4 blocks) 30 40mm Push-Lock-Turn-Reset 29mm Push-Lock-Turn-Reset M3.5 Terminal Screw 13 68.5 (4 blocks) 30 Panel Thickness: 1 to 6 mm 37 ø40 37 48.5 (2 blocks) 13 22.5 M3.5 Terminal Screw Panel Thickness: 1 to 6 mm 37 M3.5 Terminal Screw ø29 48.5 (2 blocks) 68.5 (4 blocks) Mushroom with Full Shroud 40mm Mushroom Panel Thickness: 1 to 6 mm 30 68.5 (4 blocks) 30 37 M3.5 Terminal Screw 19 37 29mm Mushroom 19.5 48.5 (2 blocks) 13 68.5 (4 blocks) Panel Thickness: 1 to 6 mm 37 ø24 30 M3.5 Terminal Screw Panel Thickness: 1 to 6 mm 37 ø29 48.5 (2 blocks) 13 68.5 (4 blocks) 13 48.5 (2 blocks) M3.5 Terminal Screw Panel Thickness: 1 to 6 mm 13 13 25 48.5 (2 blocks) 47 68.5 (4 blocks) Square Flush Panel Thickness: 1 to 6 mm 37 ø40 45° 30 37 M3.5 Terminal Screw 30 Panel Thickness: 1 to 6 mm Resetting (Unlock) 47 68.5 (4 blocks) 30 40mm Push-Pull 40mm Pushlock Key Reset M3.5 Terminal Screw 22.5 25 25 68.5 (4 blocks) 30 22.5 48.5 (2 blocks) 13 37 68.5 (4 blocks) 48.5 (2 blocks) 13 ø40 48.5 (2 blocks) 68.5 (4 blocks) 30 25 48.5 (2 blocks) 30 30.5 13 30 68.5 (4 blocks) Square Extended Panel Thickness: 1 to 6 mm 48.5 (2 blocks) 68.5 (4 blocks) 37 30 M3.5 Terminal Screw 25 13 30 20 Selector Switches 68.5 (4 blocks) A3-158 13 25 30 www.idec.com 48.5 (2 blocks) 68.5 (4 blocks) 48.5 (2 blocks) 13 25 30 68.5 (4 blocks) 37 37 ø29 37 ø25 48.5 (2 blocks) Panel Thickness 1 to 6 mm ø29 M3.5 Terminal Screw Panel Thickness 1 to 6 mm ø24 M3.5 Terminal Screw Panel Thickness: 1 to 6 mm ø29 M3.5 Terminal Screw ø24 Switches & Pilot Devices 48.5 (2 blocks) Extended with Full Shroud M3.5 Terminal Screw Panel Thickness: 1 to 6 mm ø24 A3 Extended M3.5 Terminal Screw ø29 Flush 13 19 41 30 USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - TW Series Dimensions con’t Illuminated Pushbuttons Extended Extended with Full Shroud 30 37 Marking Plate: ø15.5 mm Marking Plate: ø15.5 mm Square Extended 29mm Push-Turn Reset Panel Thickness: 1 to 6 mm Resetting Angle: 75° Panel Thickness: 1 to 6 mm 13 21 mm Ø 1.13" (29mm) Ø 1.56" (40mm) Ø 1.56" (40mm) Ø 1.56" (40mm) Push-Pull Mushroom Panel Thickness: 1 to 6 mm 37 13 13 30 13 30 25 22.5 Marking Plate: ø13.9 mm Marking Plate: ø13.9 mm 1 Contact Block with Half Size Transformer Transformer (2 blocks) Panel Thickness: 1 to 6 mm M3.5 Terminal Screw X1 30 30.5 Marking Plate: ø13.9 mm Illuminated Selector Switches 1 Contact Block with Full Voltage Adaptor 37 37 ø29 Panel Thickness: 1 to 6 mm ø40 Panel Thickness: 1 to 6 mm Resetting angle: 75° ø40 0.858" (22mm) 0.858" (22mm) *0.936" (24mm) † 0.975" (25mm) Marking Plate: ø13.9 mm 40mm Push-Turn Reset M3.5 Terminal Screw 0.761" (19.5mm) Ø 0.936" (Ø24mm) ❏0.975" (❏25mm) 30 22.5 Marking Plate: 22.5 0.741" (19mm) 13 30 20 Dimension B 1. * Dimension when operator is in reset position. 2. † Dimension when operator is in pull position. 37 ø29 37 30 25 ø29 ø24 ø29 ø24 37 30 20 Dimension A Panel Thickness: 1 to 6 mm Panel Thickness: 1 to 6 mm X1 X1 X2 X2 X2 48.5 86.5 64.5 2 Contact Blocks with Full Voltage Adaptor M3.5 Terminal Screw 2 Contact Blocks with Half Size Transformer Transformer (4 blocks) M3.5 Terminal Screw X1 Panel Thickness: 1 to 6 mm Panel Thickness: 1 to 6 m Panel Thickness: 1 to 6 mm X1 X1 X2 X2 X2 106.5 63.5 68.5 4 Contact Blocks with Full Voltage Adaptor 3 Contact Blocks with Full Voltage Adaptor M3.5 Terminal Screw Panel Thickness: 1 to 6 mm M3.5 Terminal Screw 3 Contact Blocks with Half Size Transformer Panel Thickness: 1 Panel Thickness: 1 to 6 mm X1 X1 X1 X2 X2 X2 68.5 83.5 M3.5 Terminal Screw 84.5 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-159 A3 Switches & Pilot Devices 13 19 Illuminated Pushbuttons Extended (Same for Square) w/Full Shroud Ø 1.13" (29mm) Mushroom Ø 1.56" (40mm) Mushroom, Pushlock Turn Reset, Push-Pull Panel Thickness: 1 to 6 mm Panel Thickness: 1 to 6 mm Oiltight Switches & Pilot Devices ø22mm - TW Series Dimensions con’t Pilot Lights Round Flush APW1 Full Voltage 30 28.5 28.5 37 30 Marking plate: ø15.5 mm Dome APW2 Transformer 30 28.5 66.5 Square Flush Marking Type APQW1B Full Voltage Panel Thickness 1 to 6 30 25 Square Flush Marking Type APQW1B Transformer M3.5 Terminal Screw 25 Panel Thickness 1 to 6 37 30 13 13 30 16 28.5 Marking plate: 66.5 22 mm 13 37 25 37 ø23.6 37 13 ø29 Panel Thickness 1 to 6 M3.5 Terminal Screw ø29 ø23.6 Panel Thickness 1 to 6 25 13 17 66.5 37 ø24 30 Marking plate: ø15.5 mm Dome APW2 Full Voltage 28.5 Panel Thickness 1 to 6 37 13 17 28.5 Round Flush Marking Type APW1B Transformer M3.5 Terminal Screw ø29 ø24 Panel Thickness 1 to 6 30 17 ø29 Round Flush Marking Type APW1B Full Voltage 28.5 13 66.5 17 ø29 ø24 37 13 30 28.5 Panel Thickness 1 to 6 M3.5 Terminal Screw ø29 ø24 A3 30 16 Marking plate: 22 mm Illuminated Selector Switches Panel Thickness: 1 to 6 mm A: 63.5 (2 blocks) 83.5 (4 blocks) B: 86.5 (2 blocks), 106.5 (4 blocks) A3-160 37 ø29 M3.5 Terminal Screw ø24 Switches & Pilot Devices Round Flush APW1 Transformer Panel Thickness 1 to 6 13 25 30 A: Rated voltage 24V AC/DC B: Rated voltage 100/110V AC, 200/220V AC www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - TW Series Dimensions con’t Panel Cut-Out Diagram Dimensions Part A B C D Pushbuttons A Pilot Light Illuminated Pushbutton C B Ø 0.137" (3.5mm) Selector Switches 1.95" (50mm); 1.76" (45mm) minimum Ø 0.878" (22.3mm) 1.17" (30mm) *See note. Illuminated Selector Switches D 1.The Ø 0.137" (Ø 3.5mm) recess is necessary when either the nameplate or anti-rotation ring is used. 2. * >1.404" (36mm) for 2- or 3-position. >1.95" (50mm) for 4- or 5-position. Accessory Dimensions OGL-31 Anti-Rotation Ring OLW-C Metal Button Guard 0.398" (10.2mm) Minimum Mounting Centers 1.95" (50mm) Ø0.858" Ø1.07" (Ø27.4mm) (22mm) OCW-11 Pushbutton Rubber Boot Ø1.29" (Ø33mm) Ø0.897" (Ø23mm) OB-31 Mounting Hole Rubber Plug 0.137" (3.5mm) 0.429" (11mm) 0.741" (19mm) AW-RP1B Round Plastic Bezel 82.5 0.507" (13mm) Panel Thickness: 0.8 to 3.2 mm Ø1.13" (Ø29mm) 0.137" (3.5mm) Ø0.975" (Ø25mm) R1.66" (R42.5mm) HW9Z-KL1 (TW) Lock-out Adaptor Ø1.13" (Ø29mm) AW-FP1B Round Plastic w/Full Shroud 0.772" (19.8mm) R6 Ø1.13" (Ø29mm) 70 30 5 93 6. ID: 24 2 2. ø2 0 ø5 .4) 44 ø : (ID Lock Hole ø8 29.5 30 Waterproof Gasket 0.5t AW-QF1B Square Full Shroud AW-H1B Square Bezel w/ Round Hole 0.78" (20mm) ❏1.17" (❏30mm) www.idec.com 0.507" (13mm) ❏1.17" (❏30mm) USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-161 A3 Switches & Pilot Devices 1.17" (30mm) Std. Octagonal > 1.56" (40mm) Large Mushroom Oiltight Switches & Pilot Devices ø22mm - TW Series Dimensions con’t Finger-Safe Cover Dimensions HW-VL6 0.69" (17.4mm) 1.57" (39.8mm) m ) 0.90" (22.8mm) 5" 5m 6. 0.34" (8.7mm) 0. 27 "( 0.61" (15.5mm) HW VL5 HW VL6 0.58" (14.8mm) 26 0. (7 m m ) 0.28" (7.2mm) 1.06" (27mm) 1.54" (39.1mm) 1.41" (10.4mm) 1.58" (40mm) HW-VL3 1.02" (26mm) A3-162 m (1.57" 39.8mm) .055" (14.1mm) 0.12" (3mm) 0.61" (15.5mm) www.idec.com 0.41" (10.4mm) .748" (19mm) 2" 12 ) 0. m R .1m (3 APS-PVL .271" (6.9mm) 8 .24 ) mm 6.3 "( 1.02" (26mm) .2 .244" (6.2mm) (6 APS-PVL HW-VL2 ) 1.42" (36mm) HW-VL3 4" m 0.79" (20mm) 2 0. 1.49" (37.8mm) Switches & Pilot Devices A3 HW-VL4 HW-VL5 .228" (5.8mm) .421" (10.7mm) 1.16" (29.4mm) USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - TW Series Component Construction & Instructions — TW Series Lens or Button TW Series: Adjustment for Panel Thickness The panel thickness ring provides adjustment from 0.04" to 0.24" (1 to 6mm) in 0.004" (0.1mm) increments. Rotate the ring until the markings around the periphery are aligned for the desired thickness, as shown below. Adjustment 0mm 0.9mm 0.8mm 0.7mm 0.6mm 0.5mm 0.4mm 0.3mm (Round lens used on square pushbuttons and pilot lights only). Waterproof Gasket Adjustment Ring Panel Thickness) 0.2mm Waterproof Lens Examples Zero Point One Complete Revolution 0.1mm (Panel) 0mm Operator Zero Point 0.1mm panel thickness Base 0.5mm panel thickness Note: When a nameplate or an anti-rotation ring is used, add 0.03" (0.8mm) to the panel thickness dimension. Lamp Lamp Holder Inspection Window Lead Holder LED or Incandescent Panel Thickness: 0.08" (2mm) Panel Thickness: 0.1" (2.6mm) An adjustment for panel thicknesses shown below can be made quickly by using the contact block remover tool. 0.06" Contact Block (1.6mm) Tool TW-KC1 0.09" (2.3mm) 0.14" (3.5mm) 0.04" (1mm) 0.08" (2mm) 0.125" (3.2mm) Options Full Voltage Full-Size Adaptor: Transformer: Half-Size Transformer: Used with incandescent/LED – even number of contact blocks. Used with incandescent – odd number of contact blocks. Used with full voltage LED or incandescent. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3-163 A3 Switches & Pilot Devices Bezel Option: Nameplate Instructions for Switches and Pilot Devices Oiltight Switches & Pilot Devices ø22mm - TW Series Instructions con’t Pilot Lights and Pushbuttons IMPORTANT: Install the body of the TW control unit with the panel thickness scale facing up. Switches & Pilot Devices A3 Octagonal and Round Bezels Octagonal and round bezels screw into the operator. Use the locking ring wrench (optional) for secure tightening and easy removal. Round flush and extended buttons snap onto the operator base. Mushroom buttons screw onto the operator base. Every round lens can be used with or without legend markings. Engraving can be done on a white translucent plate which is placed in the lens, or clear mylar can be printed and placed in the lens. Round Marking Unit Insert marking plate under lens. Press in round flush and extended lens. Screw in mushroom lens. Square Bezels Square bezels are installed in a 3-step procedure. First install the base plate from the front. Then install the lock nut using the nut locking wrench (optional). Finally, install the square bezel, which snap-fits onto the base plate. Square buttons also snap onto the operator base. Every square lens can be used with or without legend markings. Engraving can be done on a white translucent plate which is placed in the lens, or clear mylar can be printed and placed in the lens. Square units include a round waterproof lens which screws into the operator. The square outer lens snaps on. Square Marking Units Pilot Light Insert marking plate under lens. Illuminated Pushbutton Insert marking plate under lens. To remove square lens from operator, place a screwdriver under the indentation on the side of the lens. To remove the marking plate, place a screwdriver under the indentation and lift out the plate. The lens retainer can be removed by pressing a 3/16" screwdriver into one of the recesses. Marking Plate Engraving Area Shape Engraving Area Used With Part Number Ø 0.55" (14mm) Illuminated pushbuttons ALW2B Ø 0.55" (14mm) Pilot lights APW2B Mushroom Ø 0.55" (14mm) Illuminated mushroom ALW3B Square ❑ 0.83" (21mm) Square pilot lights APQW1B Square ❑ 0.83" (21mm) Square illuminated pushbuttons ALQW2B Round A3-164 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Oiltight Switches & Pilot Devices ø22mm - TW Series Instructions con’t Selector Switches The operator shaft of each unit has a recess to identify in which direction to install the handle. Align the handle with the recess. Press color insert (TW-HC1) into the handle and then press handle into the operator, as shown below. Recess Press in handle . Illuminated Selector Switch Remove color insert before pulling out the handle. Non-Illuminated Selector Switch Standard Operating Positions 2-Position, 90° 3-Position, 45° 1 1 4-Position, 45° 0 2 5-Position, 30° 2 2 1 3 2 3 4 5 1 4 Positions: Non-illuminated 3-Position Operators 1 0 1 2 1 0 0 2 2 Installation TW Pilot Lights Terminal X1 = Positive Terminal X2 = Negative Make sure slot is facing up TW Illuminated Pushbuttons, TW Selector Switches (AC Transformer or Full Voltage) Lamp holder is installed as shown, due to polarity. Lead holder (used with two stacks of contact blocks) does not have polarity. Installation of LED Illuminated Units AC transformers are recommended for use in areas subjected to inductive noise. When using full voltage types, install a protection diode as shown below. (Diode with DC power supply to protect against surges and noise.) Terminal X1 LED Terminal X2 Diode . Make sure that LED illuminated units are installed with correct polarity, as indicated at the terminals. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A3 Switches & Pilot Devices Press in color insert A3-165
AOLW29911D-A-120V 价格&库存
很抱歉,暂时无法提供与“AOLW29911D-A-120V”相匹配的价格&库存,您可以联系我们找货
