Miniature Pilot Lights
Miniature ø8-16mm AP Series
AP Series — Miniature Pilot Lights
Miniature Pilot Lights with Super Bright LEDs
Specifications
AP8
AP1
CSA Certified
File No. LR92374
UL Recognized
File No. E68961
Optional Adaptors/Converters
Switches & Pilot Devices
A5
Key features of AP series include:
• Long service life, low maintenance
• Space saving miniature style
• Dome or flat lens models
• Built-in current-limiting resistor and reverse polarity protection diode
• Five illumination colors: red, green, amber, yellow, and white
• AC adaptor (120V AC and 240V AC) and DC-DC Converter (110V DC) options
on 12mm and 16mm units
Lamp
Built-in LED with current limiting resistor
Operational Voltage
6, 12, 24VDC (full voltage),
110/120, 220/240VAC, (transformer)
110VDC (with converter)
Current Ratings
AP8: 6VDC/18mA, 12VDC/18mA, 24VDC/12mA
AP1: 6VDC/18mA, 12VDC/18mA, 24VDC/12mA
AP2: 6VDC/33mA, 12VDC/22mA, 24VDC/11mA
AP6: 6VDC/33mA, 12VDC/22mA, 24VDC/11mA
Operating Temp.
-20°C to +55°C
Operating Humidity
45 to 85% RH
Insul. Resistance
100MΩ min. (500V DC megger)
Between live and dead parts
Rev. Withstand Voltage
AP2/AP6: 100V
AP1/AP8: 200V
Solder Terminal
Soldering 260°C maximum (5 sec.)
Degree of Protection
AP8: IP40 (dustproof)
Other Series: IP65 (oiltight)
AP2
AP6
AC Adaptor
DC-DC Converter
Applicable Units
AP2 & AP6 (with 6V LED only)
Operating Voltage
110/120VAC 50/60 Hz
220/240VAC 50/60 Hz
110V DC (90 to 140V DC)
Power Consumption
1.6 VA maximum
1W maximum
Insulation Voltage
250 V AC
140V DC
Insulation Resistance
10MΩ min. (500V DC megger) Between live and dead parts
Dielectric Strength
2,000V AC, 1 minute Between live/dead parts
2,000V AC, 1 minute Between terminals
1,500V AC, 1 minute Between terminals
Available as one piece only (replacement LEDs are not available).
A5-210
www.idec.com
USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC
Miniature Pilot Lights (Assembled)
Part Numbers: AP Miniature Pilot Lights
Appearance
Lens Style
AP8 Series - Ø 8mm
Part Numbers
Dome
6V DC +/- 5%
12V DC +/- 10%
24V DC +/- 10%
AP8M266-➁
AP8M211-➁
AP8M222-➁
Flat
6V DC +/- 5%
12V DC +/- 10%
24V DC +/- 10%
AP8M166-➁
AP8M111-➁
AP8M122-➁
Dome
6V DC +/- 5%
12V DC +/- 10%
24V DC +/- 10%
AP1M266-➁
AP1M211-➁
AP1M222-➁
6V DC +/- 5%
12V DC +/- 10%
24V DC +/- 10%
AP1M166-➁
AP1M111-➁
AP1M122-➁
AP1 Series - Ø 10mm
Flat
AP2 Series - Ø 12mm
6V DC +/- 5%
12V DC +/- 10%
24V DC +/- 10%
AP2M266-➁
AP2M211-➁
AP2M222-➁
Flat
6V DC +/- 5%
12V DC +/- 10%
24V DC +/- 10%
AP2M166-➁
AP2M111-➁
AP2M122-➁
Dome
6V DC +/- 5%
12V DC +/- 10%
24V DC +/- 10%
AP6M266-➁
AP6M211-➁
AP6M222-➁
Flat
6V DC +/- 5%
12V DC +/- 10%
24V DC +/- 10%
AP6M166-➁
AP6M111-➁
AP6M122-➁
Dome
AP6 Series - Ø 16mm
A5
Operating Voltage
➁ Color Code
Color
Code
Amber
A
Green
G
Red
R
White
W
Yellow
Y
1. In place of ➁, specify the color code.
2. For dimensions, see page A5-212
3. For accessories, see page A5-212.
Part Numbers: Optional AC Adaptors and DC-DC Converters (for AP2 and AP6 only)
Part Numbers
Appearance
Style
Voltage
Used with Used with
AP2 Series AP6 Series
AC
Adaptor
110/120V AC
220/240V AC
AP2-0126D
AP2-0246D
AP6-0126D
AP6-0246D
DC-DC
Converter
110V DC
(90–140V DC)
AP2-016DD
AP6-016DD
Secondary Voltage = 6V
1. Optional AC adaptors and DC-DC converters snap onto the back of AP2 or AP6 pilot lights.
2. AC Adaptors and DC-DC Converters step down to 6V.
3. For dimensions, see page A5-213.
www.idec.com
A5-211
Accessories — AP Series
Appearance
A5
Description
Locking Ring Wrench
Made of metal. Used for tightening plastic locking ring during installation. Tightening torque
should not exceed 3kgf-cm
Mounting Hole Plug
Made of rubber. Fills unused mounting holes to
provide IP65 protection
Transformer Removal Tool
Replacement Lenses
Lenses (included with all units).
Replacement Engraving Inserts
Allow legends under flat lenses (included with all
flat lens models).
Used With
Part Number
Ø 16mm units
MT-001
Ø 12mm units
MT-002
Ø 10mm units
MT-003
Ø 8mm units
MT-004
Unused 8mm panel cutouts
AL-B8
Unused 10mm panel cutouts
AL-B1
Unused 12mm panel cutouts
AL-B2
Unused 16mm panel cutouts
AL-B6
AP2 & AP6 snap on transformer & DC-DC
converter
MT-100
AP1M Flat
AP1M-L1-➁
AP1M Dome
AP1M-L2-➁
AP2M Flat
AP2M-L1-➁
AP2M Dome
AP2M-L2-➁
AP6M Flat
AP6M-L1-➁
AP6M Dome
AP6M-L2-➁
AP1M Flat
AP1M-P1-W
AP2M Flat
AP2M-P1-W
AP6M Flat
AP6M-P1-W
In place of ➁, specify the Lens Color Code.
➁ Lens Color Code
Color
Code
A5-212
www.idec.com
Amber
A
Green
G
Red
R
White
W
Yellow
Y
Dimensions — AP Series
Pilot Lights (AP Series)
Style
AP8
Dome
Flat
Dome
AP2
Flat
Dome
AP6
w/ Adaptor
or Converter
Flat
Ø 0.319" (+0.0118, –0)
8.1mm (+0.3, –0)
Ø 0.398" (+0.0118, –0)
10.1mm (+0.3, –0)
Ø 0.480" (+0.0118, –0) 12.2mm (+0.3, –0)
Outside
Dimension
Ø 0.386" (9.8mm)
Ø 0.472" (12mm)
Ø 0.551" (14mm)
❑ 0.709" (18mm)
Panel Thickness: 0.8 to 6 mm
Gasket
Round Extended
ø14
7
ø15.6
1.5
2.2
5
1.5
ø12
2.2
21.5
5.5
5.5
21.5
8
11.5
Panel Cut-out
ø15.6
29.5
Panel Cut-out
Round Flush
ø12
29.5
13.5
ø14
Round Flush
ø18
❑ 0.709" (18mm)
Ø 0.709" (18mm)
Gasket
Round Extended
ø18
Ø 0.638" (+0.0118, –0) 16.2mm (+0.3, –0)
+0
.2
+0 0
ø1
5.5
2
6.
2
ø1
5.5
.2
.2
9.5
When using the AC adapter unit
(When using the DC-DC converter unit)
M3 terminal
screw
AC adapter unit
(or DC-DC converter unit)
AC adapter unit
M3 terminal
screw
+ Terminal
+ Terminal
18
X2
X2
18
TOP
X1
TOP
X1
71
1.3
2.2
2.8
3
ø8
8
5.5
9.5
29.5
8
29.5
Panel Cut-out
+0
0 .2
ø9.8
Round Flush
5.5
ø1
0.
1
.1
+0
.2
ø10
21.5
ø8
Panel Cut-out
Round Flush
ø12
ø9.8
21.5
5.5
ø8
2.8
Gasket
Round Extended
4
ø10
ø12
5.5
– Terminal
1.5
2.2
1.5
Gasket
10
18
1.3
– Terminal
Round Extended
58.7
71
18
58.7
8.5
9.5
www.idec.com
A5-213
A5
Panel Cut-out
w/ Adaptor
or Converter
Dome
Flat
AP1
很抱歉,暂时无法提供与“AP2M122-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+125.261741+16.16882
- 10+97.6038210+12.59873
- 100+81.50766100+10.52103
- 500+74.51595500+9.61854
- 1000+72.249281000+9.32596
