AP6M111-R
AP6M111-R
    IDEC(日本和泉)
AP6M111-R 数据手册
Miniature Pilot Lights Miniature ø8-16mm AP Series AP Series — Miniature Pilot Lights Miniature Pilot Lights with Super Bright LEDs Specifications AP8 AP1 CSA Certified File No. LR92374 UL Recognized File No. E68961 Optional Adaptors/Converters Switches & Pilot Devices A5 Key features of AP series include: • Long service life, low maintenance • Space saving miniature style • Dome or flat lens models • Built-in current-limiting resistor and reverse polarity protection diode • Five illumination colors: red, green, amber, yellow, and white • AC adaptor (120V AC and 240V AC) and DC-DC Converter (110V DC) options on 12mm and 16mm units Lamp Built-in LED with current limiting resistor Operational Voltage 6, 12, 24VDC (full voltage), 110/120, 220/240VAC, (transformer) 110VDC (with converter) Current Ratings AP8: 6VDC/18mA, 12VDC/18mA, 24VDC/12mA AP1: 6VDC/18mA, 12VDC/18mA, 24VDC/12mA AP2: 6VDC/33mA, 12VDC/22mA, 24VDC/11mA AP6: 6VDC/33mA, 12VDC/22mA, 24VDC/11mA Operating Temp. -20°C to +55°C Operating Humidity 45 to 85% RH Insul. Resistance 100MΩ min. (500V DC megger) Between live and dead parts Rev. Withstand Voltage AP2/AP6: 100V AP1/AP8: 200V Solder Terminal Soldering 260°C maximum (5 sec.) Degree of Protection AP8: IP40 (dustproof) Other Series: IP65 (oiltight) AP2 AP6 AC Adaptor DC-DC Converter Applicable Units AP2 & AP6 (with 6V LED only) Operating Voltage 110/120VAC 50/60 Hz 220/240VAC 50/60 Hz 110V DC (90 to 140V DC) Power Consumption 1.6 VA maximum 1W maximum Insulation Voltage 250 V AC 140V DC Insulation Resistance 10MΩ min. (500V DC megger) Between live and dead parts Dielectric Strength 2,000V AC, 1 minute Between live/dead parts 2,000V AC, 1 minute Between terminals 2,000V AC, 1 minute Between live/dead parts 1,500V AC, 1 minute Between terminals Available as one piece only (replacement LEDs are not available). A5-210 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Miniature Pilot Lights Miniature ø8-16mm AP Series Miniature Pilot Lights (Assembled) Part Numbers: AP Miniature Pilot Lights Appearance Lens Style AP8 Series - Ø 8mm Part Numbers Dome 6V DC +/- 5% 12V DC +/- 10% 24V DC +/- 10% AP8M266-➁ AP8M211-➁ AP8M222-➁ Flat 6V DC +/- 5% 12V DC +/- 10% 24V DC +/- 10% AP8M166-➁ AP8M111-➁ AP8M122-➁ Dome 6V DC +/- 5% 12V DC +/- 10% 24V DC +/- 10% AP1M266-➁ AP1M211-➁ AP1M222-➁ 6V DC +/- 5% 12V DC +/- 10% 24V DC +/- 10% AP1M166-➁ AP1M111-➁ AP1M122-➁ AP1 Series - Ø 10mm Flat AP2 Series - Ø 12mm 6V DC +/- 5% 12V DC +/- 10% 24V DC +/- 10% AP2M266-➁ AP2M211-➁ AP2M222-➁ Flat 6V DC +/- 5% 12V DC +/- 10% 24V DC +/- 10% AP2M166-➁ AP2M111-➁ AP2M122-➁ Dome 6V DC +/- 5% 12V DC +/- 10% 24V DC +/- 10% AP6M266-➁ AP6M211-➁ AP6M222-➁ Flat 6V DC +/- 5% 12V DC +/- 10% 24V DC +/- 10% AP6M166-➁ AP6M111-➁ AP6M122-➁ Dome AP6 Series - Ø 16mm A5 Switches & Pilot Devices Operating Voltage ➁ Color Code Color Code Amber A Green G Red R White W Yellow Y 1. In place of ➁, specify the color code. 2. For dimensions, see page A5-212 3. For accessories, see page A5-212. Part Numbers: Optional AC Adaptors and DC-DC Converters (for AP2 and AP6 only) Part Numbers Appearance Style Voltage Used with Used with AP2 Series AP6 Series AC Adaptor 110/120V AC 220/240V AC AP2-0126D AP2-0246D AP6-0126D AP6-0246D DC-DC Converter 110V DC (90–140V DC) AP2-016DD AP6-016DD Secondary Voltage = 6V 1. Optional AC adaptors and DC-DC converters snap onto the back of AP2 or AP6 pilot lights. 2. AC Adaptors and DC-DC Converters step down to 6V. 3. For dimensions, see page A5-213. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A5-211 Miniature Pilot Lights Miniature ø8-16mm AP Series Accessories — AP Series Appearance Switches & Pilot Devices A5 Description Locking Ring Wrench Made of metal. Used for tightening plastic locking ring during installation. Tightening torque should not exceed 3kgf-cm Mounting Hole Plug Made of rubber. Fills unused mounting holes to provide IP65 protection Transformer Removal Tool Replacement Lenses Lenses (included with all units). Replacement Engraving Inserts Allow legends under flat lenses (included with all flat lens models). Used With Part Number Ø 16mm units MT-001 Ø 12mm units MT-002 Ø 10mm units MT-003 Ø 8mm units MT-004 Unused 8mm panel cutouts AL-B8 Unused 10mm panel cutouts AL-B1 Unused 12mm panel cutouts AL-B2 Unused 16mm panel cutouts AL-B6 AP2 & AP6 snap on transformer & DC-DC converter MT-100 AP1M Flat AP1M-L1-➁ AP1M Dome AP1M-L2-➁ AP2M Flat AP2M-L1-➁ AP2M Dome AP2M-L2-➁ AP6M Flat AP6M-L1-➁ AP6M Dome AP6M-L2-➁ AP1M Flat AP1M-P1-W AP2M Flat AP2M-P1-W AP6M Flat AP6M-P1-W In place of ➁, specify the Lens Color Code. ➁ Lens Color Code Color Code A5-212 www.idec.com Amber A Green G Red R White W Yellow Y USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Miniature Pilot Lights Miniature ø8-16mm AP Series Dimensions — AP Series Pilot Lights (AP Series) Style AP8 Dome Flat Dome AP2 Flat Dome AP6 w/ Adaptor or Converter Flat Ø 0.319" (+0.0118, –0) 8.1mm (+0.3, –0) Ø 0.398" (+0.0118, –0) 10.1mm (+0.3, –0) Ø 0.480" (+0.0118, –0) 12.2mm (+0.3, –0) Outside Dimension Ø 0.386" (9.8mm) Ø 0.472" (12mm) Ø 0.551" (14mm) ❑ 0.709" (18mm) Panel Thickness: 0.8 to 6 mm Gasket Round Extended ø14 7 ø15.6 + 1.5 2.2 5 1.5 ø12 2.2 - 21.5 5.5 5.5 21.5 8 11.5 Panel Cut-out ø15.6 29.5 Panel Cut-out Round Flush ø12 29.5 13.5 ø14 Round Flush ø18 ❑ 0.709" (18mm) Ø 0.709" (18mm) Panel Thickness: 0.8 to 6 mm Gasket Round Extended ø18 Ø 0.638" (+0.0118, –0) 16.2mm (+0.3, –0) +0 .2 +0 0 ø1 5.5 2 6. 2 ø1 5.5 .2 .2 0 9.5 9.5 When using the AC adapter unit (When using the DC-DC converter unit) M3 terminal screw AC adapter unit (or DC-DC converter unit) AC adapter unit (or DC-DC converter unit) M3 terminal screw + Terminal + Terminal 18 X2 X2 18 TOP X1 TOP X1 When using the AC adapter unit (When using the DC-DC converter unit) 71 1.3 2.2 Panel Thickness: 0.8 to 6 mm 2.8 3 ø8 + 8 5.5 9.5 29.5 8 29.5 Panel Cut-out +0 0 .2 ø9.8 Round Flush 5.5 ø1 0. 1 .1 +0 .2 0 ø10 21.5 ø8 Panel Cut-out Round Flush ø12 ø9.8 - 21.5 5.5 ø8 2.8 Gasket Round Extended 4 ø10 ø12 5.5 – Terminal 1.5 2.2 1.5 Gasket 10 18 1.3 – Terminal Panel Thickness: 0.8 to 6 mm Round Extended 58.7 71 18 58.7 8.5 9.5 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A5-213 A5 Switches & Pilot Devices Panel Cut-out w/ Adaptor or Converter Dome - + Flat AP1
AP6M111-R 价格&库存
很抱歉,暂时无法提供与“AP6M111-R”相匹配的价格&库存,您可以联系我们找货
AP6M111-R
    • 1+128.143641+16.66221
