FT1A-M12RA-W
FT1A-M12RA-W
    IDEC(日本和泉)
FT1A-M12RA-W 数据手册
New tion Genera PLC FT1A Series - Touch Key Features • 3.8” (3.7” monochrome) HMI with embedded 12 I/O PLC • Available in Monochrome or 65K TFT color • 740 cd/m2 monochrome, 400 cd/m2 color • 8 inputs, 4 relay outputs • Embedded 2pt 0-10V analog input • 10 Amp Relay contacts • Embedded Ethernet port • USB Mini-B Programming Port • USB Type A port for data logging and recipe functions • RS232C/RS485 interface • IP66f (water and oiltight) General Specifications Part Numbers FT1A-C12RA-W FT1A-C12RA-B Light Gray Dark Gray FT1A-C12RA-S FT1A-M12RA-W Silver Light Gray FT1A-M12RA-B FT1A-M12RA-S Appearance LCD Screen Bezel Color TFT Color STN Monochrome Operating Temperature Dark Gray Silver 0 to +50°C Storage Temperature –20 to +60°C (no freezing) Rated Power Voltage 24V DC Allowable Voltage Range 20.4 to 28.8V DC (including ripple) Maximum Power Consumption 9.2W maximum (when USB2 is not used: 5.8W max.) Weight Approx. 300g Display Specifications Part Number FT1A-C12RA-* FT1A-M12RA-* Display Element TFT color LCD STN monochrome LCD Colors/Shades 65,536 colors Monochrome 8 shades Effective Display Area 88.92 W x 37.05 H mm Display Resolution View Angle Contrast Adjustment Backlight Left/right 40°, top 20°, bottom 60° Left/right/top/bottom: 45° Not possible 32 levels LED Backlight Life Brightness Note 2 Brightness Adjustment Backlight Control Backlight Replacement Graphics Window Display 87.59 W x 35.49 H mm 240 W x 100 H pixels LED (white, red, pink) 50,000 hours Note 1 400 cd/m2 740 cd/m2 32 levels Auto off function Not possible Line, polyline, polygon, rectangle, circle, ellipse, arc, pie, equilateral polygons (3, 4, 5, 6, 8), fill, picture 3 popup screens + 1 system screen 1. The backlight life refers to the time until the brightness reduces by half after use at 25°C. 2. Brightness of LCD only (monochrome LCD: when lit white). Specifications con’t on next page Function Specifications Part Numbers FT1A-C12RA-*, M12RA-* Program Capacity Input Program size: 48 KB, Configuration memory capacity: 5 MB Points Output Points User Program Storage 128KB Buzzer Output Single tone (tone length is adjustable) Backup Duration Charging Time Battery Life Replaceability Approx. 30 days (typical) at 25°C after backup battery fully charge Lithium Approx. 15 hours for charging from 0% to 90% of full charge 5 years Not possible Clock accuracy: ±30 sec/month (typical) at 25°C Clock Function Note 2 Control System Processing Time Backup data: Internal relay, shift register, counter current value, data register Note 1, clock data (year, month, and day) Backup Data Battery Instruction Words 4 Flash ROM (100,000 times) RAM Backup Function 8 Stored program system Basic Instructions 42 Advanced Instructions 97 Basic Instruction 1850μs/1000 steps END Processing 5 msec minimum Internal Relay 1024 Shift Register 128 Data Register 2000 Counter (adding, reversible) 200 Timer (1-sec, 100ms,10ms, 1ms) 200 Input Filter Catch Input/Interrupt Input Without filter, 3 to 15ms (selectable in increments of 1ms) Input Points 4 Keep data, Power failure, Clock error, Watchdog timer, Timer/counter preset value change error, User program syntax, User program execution, System error, Memory cartridge transfer error Self-diagnostic Function Points High-speed Counter Analog Voltage Input Maximum Counter Frequency Counting Range 0 to 4,294,967,295 (32 bits) Operation Mode Rotary encoder mode and adding counter mode Points (Terminal No.) 2 Input voltage Range 0 to 10V DC Digital Resolution USB Port Single/two-phase selectable: 1 (5 kHz, multiple 2/4, single-phase cannot be used) Single-phase: 4 (x 10 kHz) USB Standard Connector Ethernet Port 10-bit( 0 to 1000) USB 2.0 Mini-B type 1 1. Among data registers D0 to D1999, only D0 to D999 are backed up. 2. Set the calendar/clock using the clock function in WindLDR. Dimensions on next page Dimensions (mm) When using mounting bracket (HG9Z-4K2PN04) 77.0 Y 65.5 Panel thickness: 1.0 to 5.0 (Note) Note: Waterproof characteristic may not be obtained depending on the panel material and size. LCD Active Area 4.0 X 116.0 53.7 (57.7) 104.5 LCD Type X Y TFT 88.92 37.05 STN 87.59 35.49 When using rear mount adapter (FT9Z-1A01) 125.0 70.0 4-M3 4-R tapped hole 77.0 90.0 4.25 4.0 4-ø 97.0 98.0 105.0 116.0 100.0 4.0 11.8 57.7 Mounting Hole Layout 100 (90) 144 (160) IDEC Corporation • 1175 Elko Drive • Sunnyvale, CA 94089 • 800-262-IDEC (4332) • Fax: 408-745-5258 • www.IDEC.com/usa ©2013 IDEC Corporation. All Rights Reserved. 03/13 PDF only
FT1A-M12RA-W 价格&库存
很抱歉,暂时无法提供与“FT1A-M12RA-W”相匹配的价格&库存,您可以联系我们找货
