AL6H-LK2-W
AL6H-LK2-W
    IDEC(日本和泉)
AL6H-LK2-W 数据手册
Miniature Switches & Pilot Devices ø16mm - L6 Series L6 Series — Miniature Switches and Pilot Devices Registration No. R9551089 (E-stops) Registration No. J9551458 (all other switches) Registration No. J9650511 (Pilot Lights) Conforming to Standards Operating Temperature Vibration Resistance Mechanical Life Degree of Protection IP65 (conforming to IEC 60529) Dielectric Strength Contact Ratings EN60947-1, EN60947-5-1, VDE0660-200, UL508, CSA C22-2 N0.14 Operation: –25 to +55°C (without freezing), 45 to 85% rh Storage: -30 to +80°C (without freezing) 5 to 55Hz, 1.0 peak-peak amplitude max Operating limit: 100 m/sec2 (approximately 10G) Damage limit: 1000 m/sec2 (approximately 100G) Momentary pushbuttons 2,000,000 operations minimum All others: 250,000 operations minimum Shock Resistance Insulation Resistance Rated Insulation Voltage Rated Thermal Current Contact Resistance Rated Operating Current Switch unit: between live and ground: 2500 volt AC, 1 minute between terminals of different poles: 2500 volt AC, 1 minute between terminals of same pole: 1000 volt AC, 1 minute Illumination unit: between live part and ground: 2500 volt AC, 1 minute 100 MΩ minimum (using 500V DC megger) 250 V AC/DC Gold Contacts (pcb): 3A Silver Contacts (solder): 5A 50 Ω maximum initial value Silver Contacts Gold Clad Contacts (Solder Terminals) (PCB terminals) 30V 125V 250V 30V 125V AC resistive 3A 2A AC inductive 0.1A AC inductive 2A 1.5A DC resistive 0.1A DC resistive DC inductive Lamp Ratings Minimum Recommended Load (reference value for silver contacts) Terminal Style Contact Form Contact Material Electrical Life (at full load) Buzzer Ratings Switches & Pilot Devices A2 Key features of the 5/8” L6 Series include: • 5/8” (16mm) mounting holes • Locking lever removable contact blocks • Solder terminal or PCB terminal options • Available assembled or as sub-components • Worldwide approvals • Incandescent or LED illumination • Snap action contacts CSA Certified UL Recognized File No. LR21451 File No. E55996 Lamp Current Draw 2A 1A 0.4A 0.2A - 5 VAC/DC, 1mA 0.110” Solder Tab /PCB Snap Action, Double Throw Solder Tab: Pure Silver /PCB thermal Gold Plated Silver Momentary pushbuttons: 100,000 operations minimum (1800 operations / hour) All others: 100,000 operations minimum (1200 operations / hour) 5V DC LED: 8mA 6V LED: 7mA 6V incandescent: 100 mA 12V LED: 8mA 12V incandescent: 50 mA 24V LED: 8mA 24V incandescent: 25 mA Lamp Life Incandescent: 2000 hours./LED: 50,000 hours. (on pure DC, half-life intensity) Frequency Amplitude Operating Voltage Adjustable Cycle 2 khz ± 500 HZ 80db @ 0.1m (at rated voltage) 6V AC/DC or 12 - 24V AC/DC ± 10% 55 to 600 cycles per minute DC: 7mA AC: 20mA 1000 hrs. minimum 60V AC/DC -20 to 55 C (no freezing), 45 to 85% rh Current Draw Life Insulation Voltage Operating Temperature A2-30 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Miniature Switches & Pilot Devices ø16mm - L6 Series Non-Illuminated Pushbuttons (Assembled) Part Numbers: Non-Illuminated Pushbuttons Style Operation Contact Momentary SPDT DPDT LA1B-M1C5-➀ LA1B-M1C6-➀ Round Square LA1B-A1C1V-➀ LA1B-A1C2V-➀ SPDT DPDT LA2B-M1C5-➀ LA2B-M1C6-➀ LA2B-M1C1V-➀ LA2B-M1C2V-➀ Maintained SPDT DPDT LA2B-A1C5-➀ LA2B-A1C6-➀ LA2B-A1C1V-➀ LA2B-A1C2V-➀ Momentary SPDT DPDT LA3B-M1C5-➀ LA3B-M1C6-➀ LA3B-M1C1V-➀ LA3B-M1C2V-➀ Maintained SPDT DPDT LA3B-A1C5-➀ LA3B-A1C6-➀ LA3B-A1C1V-➀ LA3B-A1C2V-➀ Momentary SPDT DPDT HA1B-M1C5-➀ HA1B-M1C6-➀ HA1B-M1C1V-➀ HA1B-M1C2V-➀ Maintained SPDT DPDT HA1B-A1C5-➀ HA1B-A1C6-➀ HA1B-A1C1V-➀ HA1B-A1C2V-➀ Momentary SPDT DPDT HA1B-M2C5-➀ HA1B-M2C6-➀ HA1B-M2C1V-➀ HA1B-M2C2V-➀ Maintained SPDT DPDT HA1B-A2C5-➀ HA1B-A2C6-➀ HA1B-A2C1V-➀ HA1B-A2C2V-➀ Momentary SPDT DPDT HA2B-M1C5-➀ HA2B-M1C6-➀ HA2B-M1C1V-➀ HA2B-M1C2V-➀ Maintained SPDT DPDT HA2B-A1C5-➀ HA2B-A1C6-➀ HA2B-A1C1V-➀ HA2B-A1C2V-➀ Momentary SPDT DPDT HA2B-M2C5-➀ HA2B-M2C6-➀ HA2B-M2C1V-➀ HA2B-M2C2V-➀ Maintained SPDT DPDT HA2B-A2C5-➀ HA2B-A2C6-➀ HA2B-A2C1V-➀ HA2B-A2C2V-➀ Momentary SPDT DPDT HA1B-M3C5-➀ HA1B-M3C6-➀ HA1B-M3C1V-➀ HA1B-M3C2V-➀ Maintained SPDT DPDT HA1B-A3C5-➀ HA1B-A3C6-➀ HA1B-A3C1V-➀ HA1B-A3C2V-➀ Oversize Round Flush Oversize Square Extended LA1B-A1C5-➀ LA1B-A1C6-➀ Momentary Rectangular Oversize Square Flush SPDT DPDT LA1B-M1C1V-➀ LA1B-M1C2V-➀ Mushroom Color Code Black B Green G Red R Blue S White W Yellow Y A2 Switches & Pilot Devices Maintained Oversize Round Extended Button Color Codes Terminal Style Solder Tab PCB 1. In place of ➀ specify Button Color Code from table on right. 2. Illuminated (translucent) style lenses also available, specify as such: instead of LA1B-M1C5-➀ use LA1B-M1C5L-➁ in place of ➁ specify Lens Color Code from next page.) 3. PCB terminal models also available with silver contacts (change “1” or “2” to “5” or “6” respectively, ie LA1B-M1C1V-➀ becomes LA1B-M1C5V-➀. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A2-31 Miniature Switches & Pilot Devices ø16mm - L6 Series Non-Illuminated Pushbuttons (Sub-Assembled) Contact + Safety Lever Lock + Operator + Button = Complete Part Part Numbers: Operators Part Numbers: Buttons/Lenses Style Style Button Appearance Round Round LA1L-MO AB6M-BK2-① LA1L-AO Square Terminal Style Contacts Solder PCB Tab Lens AL6M-LK2-➁ Gold Momentary Maintained Part Numbers: Contacts SPDT DPDT HA-C1 HA-C2 HA-C1V HA-C2V Silver Switches & Pilot Devices A2 SPDT DPDT HA-C5 HA-C6 HA-C5V HA-C6V Square LA2L-MO AB6Q-BK2-① LA2L-AO Rectangular AL6Q-LK2-➁ Rectangular LA3L-MO AB6H-BK2-① LA3L-AO AL6H-LK2-➁ Part Number: Safety Lever Lock Appearance Oversize Round Part Number Oversize Round Flush HA1B-MO HA1B-AO Oversize Square HA1A-B1-① HA1A-L1-➁* HA1A-B2-① – Oversize Round Extended HA2B-MO HA2B-AO Mushroom ① Button Color Code Oversize Square Flush HA1B-MOL HA2A-B1-① HA1B-A0L HA9Z-LS HA2A-L1-➁** Color Code Black B Green G Red R Blue S White W Yellow Y Oversize Square Extended HA2A-B2-① 1. In place of ① specify Button Color Code from table on right. 2. In place of ➁ specify Lens Color Code from table on right. 3. *requires HA1L-M0 or HA1L-A0 operator instead of HA1B-M0 or HA1B-A0. 4. **requires HA2L-M0 or HA2L-A0 instead of HA2B-M0 or HA2B-A0. A2-32 www.idec.com – Mushroom HA1A-B3-① HA1A-L3-➁ ➁ Lens Color Code Color Code Amber A Green G Red R Blue S Yellow Y White W USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Miniature Switches & Pilot Devices ø16mm - L6 Series HA1B/HA1E E-Stop Miniature Switches and Pilot Devices: 5/8"(16mm) Key features of HA1B/HA1E Push lock Turn Reset include: • PCB or Solder Terminals • Quick Release Contact Blocks • Positive Action Contacts • 1 or 2 form B (SPST-NC) Contacts • IP65 Protection • 16mm Mounting Hole • Tamper Proof Construction 120VAC/3A Part Numbers: Nameplates HAAV–Yellow Plastic Contact Form 1 or 2 form B (2-SPST-NC) Termination PCB or Solder Terminal Contact Material Silver Applicable Standards EN60947-5-1, UL-508, CSA 22.2. No. 14 Rated Insulation Voltage 250V Degree of Protection IP65, when mounted in an enclosure Conditional Short-Circuit Current &Short-Circuit Protective Device 50 A (at 250V) 10A 250V Fuse, operation class aM according to IEC269-1 and IEC269-2 Positive opening travel 3.4mm Minimum force required to achieve positive opening operation of all break contacts. 10.3 N (2 form B contacts) Maximum travel including travel beyond the minimum travel position 5.5mm Maximum frequency of actuation 1,200 operations/hour Pollution Degree Ø 60mm ERGENCY EM STOP Part Number Blank HAAV-0 Engraved Emergency Stop HAAV-27 3 Part Numbers: Positive Action E-Stop Terminal Style Appearance Operation Contact Solder Tab DPST(NC) (2 form B) Pushlock/ Turn Reset E-Stop Short Body PCB HA1B-V2E2R SPST-NC (1 form B) DPST-NC (2 form B) HA1E-V2S1R HA1E-V2S2R HA1B-V2E2VR Button is nonremovable, available in red and as complete assembled unit only. – Part Number: Buzzers (IP40) Appearance Operating Voltage Terminal Style Solder/Tab PCB 6V AC/DC ± 10% LA3Z-1X2 LA3Z-1X2V 12V to 24 AC/DC ± 10% LA3Z-1X4 LA3Z-1X4V Buzzer-Rectangular www.idec.com Frequency: 2khz ± 500 hz Amplitude: 80db at 0.1m Beeping: Adjustable from steady tone to 600 beeps per minute. USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A2-33 Switches & Pilot Devices 24VDC/2A Contact Ratings Positive Opening Operation Direct Opening Action UL Recognized File No. E55996 CSA approved File No. LR21451 File No. DK95-00138 Specifications A2 Miniature Switches & Pilot Devices ø16mm - L6 Series Pilot Lights (Assembled) ➁ Lens/LED Color Codes Color Code Part Numbers: Pilot Lights (LED) Switches & Pilot Devices A2 Style Voltage Solder Tab Terminal Style PCB Round 24V AC/DC LED 24VAC/DC Incandescent LA1P-1C04-➁ LA1P-1C07-➁ LA1P-1C04V-➁ LA1P-1C07V-➁ Amber A Green G Red R Blue S Yellow Y White W Square 24V AC/DC LED 24V AC/DC Incandescent LA2P-1C04-➁ LA2P-1C07- ➁ LA2P-1C04V-➁ LAZP-1C07V-➁ Rectangle 24V AC/DC LED 24V AC/DC Incandescent LA3P-1C04-➁ LA3P-1C07-➁ LA3P-1C04V-➁ LA3P-1C07V-➁ Oversize Round 24V AC/DC LED 24V AC/DC Incandescent HA1P-1C04-➁ HA1P-1C07-➁ HA1P-1C04V-➁ HA1P-1C07V-➁ 24V AC/DC LED 24V AC/DC Incandescent HA2P-1C04-➁ HA2P-1C07-➁ HA2P-1C04V-➁ HA2P-1C07V-➁ 24V AC/DC LED 24V AC/DC Incandescent HA1P-14-➁ HA1P-17-➁ – 24V AC/DC LED 24V AC/DC Incandescent HA2P-14-➁ HA2P-17-➁ – Voltage/Lamp Code Voltage Code 5V DC LED 1 6V AC/DC LED 2 12V AC/DC LED 3 24V AC/DC LED 4 120 V AC LED 8 6V AC/DC Incandescent 5 12V AC/DC Incandescent 6 24V AC/DC Incandescent 7 Oversize Square Oversize Round Unibody Oversize Square Unibody 1. In place of ➁ specify Lens/LED Color Code from table. 2. Lamps also available in 5VDC, 6V AC/DC, 12V AC/DC or 120V AC, change “4” or “7” using Voltage/Lamp Codes (ie LA1P-1C03-➁ uses 12V AC/DC LED). A2-34 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Miniature Switches & Pilot Devices ø16mm - L6 Series Pilot Lights (Sub-Assembled) Terminals + Safety Lever Lock + Lamp Holder + Lamp + Operator + Lens = Completed Unit A2 Style Part Number Part Numbers: Lenses Style Part Number Round Round Part Numbers: Lamps Style Voltage LED Square Incandescent Square 6V AC/DC 12V AC/DC 24V AC/DC AL6Q-LK3-➁ LA2P-0 AL6H-LK3-➁ LA3P-0 LH-06 LH-14 LH-28 In place of ➁ specify LED color code from table below. Rectangular Rectangular 5V DC 6V AC/DC 12V AC/DC 24V AC/DC 120 V AC AL6M-LK3-➁ LA1P-0 Part Number LFTD-5➁ LFTD-6➁ LFTD-1➁ LFTD-2➁ LFTD-H2➁ Part Numbers: Terminals Solder Tab Appearance PCB Oversize Round Oversize Round HA-C00 Not required for unibody models. Oversize Square Oversize Square HA2A-P1-➁ HA2P-0 Part Number: Lamp Holder Appearance Oversize Round Unibody HA1P-00 In place of ➁ specify lens color S t code. y l e Part Number Part Number HA9Z-AH Part Number: Safety Lever Lock Appearance Part Number HA9Z- LS Oversize Square Unibody HA2P-00 ➁ Lens/LED Color Codes Color Code Amber Green Red Blue Yellow www.idec.com HA-C00V HA1A-P1-➁ HA1P-0 A G R S Y USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A2-35 Switches & Pilot Devices Part Numbers: Operators Miniature Switches & Pilot Devices ø16mm - L6 Series Illuminated Pushbuttons (Assembled) Part Numbers: Illuminated Pushbuttons Style A2 Operation Round Switches & Pilot Devices Momentary Maintained Square Momentary Maintained Rectangular Momentary Maintained Oversize Round Momentary Maintained Oversize Square Momentary Maintained Mushroom Momentary Maintained Lamp Voltage Contact 24V AC/DC LED SPDT DPDT 24V AC/DC Incandescent SPDT DPDT 24V AC/DC LED SPDT DPDT 24V AC/DC Incandescent SPDT DPDT 24V AC/DC LED SPDT DPDT 24V AC/DC Incandescent SPDT DPDT 24V AC/DC LED SPDT DPDT 24V AC/DC Incandescent SPDT DPDT 24V AC/DC LED SPDT DPDT 24V AC/DC Incandescent SPDT DPDT 24V AC/DC LED SPDT DPDT 24V AC/DC Incandescent SPDT DPDT 24V AC/DC LED SPDT DPDT 24V AC/DC Incandescent SPDT DPDT 24V AC/DC LED SPDT DPDT 24V AC/DC Incandescent SPDT DPDT 24V AC/DC LED SPDT DPDT 24V AC/DC Incandescent SPDT DPDT 24V AC/DC LED SPDT DPDT 24V AC/DC Incandescent SPDT DPDT 24V AC/DC LED SPDT DPDT 24V AC/DC Incandescent SPDT DPDT 24V AC/DC LED SPDT DPDT 24V AC/DC Incandescent SPDT DPDT Terminal Style Solder Tab PCB LA1L-M1C14V-➁ LA1L-M1C54-➁ LA1L-M1C64-➁ LA1L-M1C24V-➁ LA1L-M1C17V-➁ LA1L-M1C57-➁ LA1L-M1C67-➁ LA1L-M1C27V-➁ LA1L-A1C14V-➁ LA1L-A1C54-➁ LA1L-A1C64-➁ LA1L-A1C24V-➁ LA1L-A1C17V-➁ LA1L-A1C57-➁ LA1L-A1C67-➁ LA1L-A1C27V-➁ LA2L-M1C14V-➁ LA2L-M1C54-➁ LA2L-M1C64-➁ LA2L-M1C24V-➁ LA2L-M1C17V-➁ LA2L-M1C57-➁ LA2L-M1C67-➁ LA2L-M1C27V-➁ LA2L-A1C14V-➁ LA2L-A1C54-➁ LA2L-A1C64-➁ LA2L-A1C24V-➁ LA2L-A1C17V-➁ LA2L-A1C57-➁ LA2L-A1C67-➁ LA2L-A1C27V-➁ LA3L-M1C14V-➁ LA3L-M1C54-➁ LA3L-M1C64-➁ LA3L-M1C24V-➁ LA3L-M1C17V-➁ LA3L-M1C57-➁ LA3L-M1C67-➁ LA3L-M1C27V-➁ LA3L-A1C14V-➁ LA3L-A1C54-➁ LA3L-A1C64-➁ LA3L-A1C24V-➁ LA3L-A1C17V-➁ LA3L-A1C57-➁ LA3L-A1C67-➁ LA3L-A1C27V-➁ HA1L-M1C14V-➁ HA1L-M1C54-➁ HA1L-M1C64-➁ HA1L-M1C24V-➁ HA1L-M1C17V-➁ HA1L-M1C57-➁ HA1L-M1C67-➁ HA1L-M1C27V-➁ HA1L-A1C14V-➁ HA1L-A1C54-➁ HA1L-A1C64-➁ HA1L-A1C24V-➁ HA1L-A1C17V-➁ HA1L-A1C57-➁ HA1L-A1C67-➁ HA1L-A1C27V-➁ HA2L-M1C14V-➁ HA2L-M1C54-➁ HA2L-M1C64-➁ HA2L-M1C24V-➁ HA2L-M1C17V-➁ HA2L-M1C57-➁ HA2L-M1C67-➁ HA2L-M1C27V-➁ HA2L-A1C14V-➁ HA2L-A1C54-➁ HA2L-A1C64-➁ HA2L-A1C24V-➁ HA2L-A1C17V-➁ HA2L-A1C57-➁ HA2L-A1C67-➁ HA2L-A1C27V-➁ HA1L-M3C14V-➁ HA1L-M3C54-➁ HA1L-M3C64-➁ HA1L-M3C24V-➁ HA1L-M3C17V-➁ HA1L-M3C57-➁ HA1L-M3C67-➁ HA1L-M3C27V-➁ HA1L-A3C14V-➁ HA1L-A3C54-➁ HA1L-A3C64-➁ HA1L-A3C24V-➁ HA1L-A3C17V-➁ HA1L-A3C57-➁ HA1L-A3C67-➁ HA1L-A3C27V-➁ ➁ Lens Color Codes Color Code Amber A Green G Red R Blue S Yellow Y White W Voltage/Lamp Code Voltage Code 5V DC LED 1 6V AC/DC LED 2 12V AC/DC LED 3 24V AC/DC LED 4 120V AC LED 8 6V AC/DC Incandescent 5 12V AC/DC Incandescent 6 24V AC/DC Incandescent 7 1. In place of➁ specify lens color code from table at right. 2. Lamps also available in 5V DC, 6V AC/DC, 12 V AC/DC or 120V AC, change “4” or “7” using voltage/lamp codes (ie LA1P-1C03-➁ uses 12V AC/DC LED). 3. PCB terminal models also available with silver contacts (change “1” or “2” to “5” or “6” respectively, ie LA1L-M1C14V-➀ becomes LA1L-M1C54V-➀. A2-36 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Miniature Switches & Pilot Devices ø16mm - L6 Series Illuminated Pushbuttons (Sub-Assembled) Contacts + Safety Lever Lock + Lamp Holder + Lamp + Operator + Lens = Completed Unit A2 Style Momentary Maintained Part Numbers: Lenses Style Part Number Round Round LA1L-MO Part Numbers: Lamps Appearance Voltage Part Number LED 5V DC 6V AC/DC 12V AC/DC 24V AC/DC 120V AC LFTD-5➁ LFTD-6➁ LFTD-1➁ LFTD-2➁ LFTD-H2➁ 6V AC/DC 12V AC/DC 24V AC/DC LH-06 LH-14 LH-28 AL6M-LK2-➁ LA1L-AO Incandescent Square Square LA2L-MO In place of ➁ specify LED color code from table below. AL6Q-LK2-➁ LA2L-AO Switches & Pilot Devices Part Numbers: Operators Part Numbers: Contacts Solder Tab PCB Gold LA3L-MO Contacts SPDT DPDT HA-C10 HA-C20 HA-C10V HA-C20V Silver Terminal Style Rectangular Appearance Rectangular SPDT DPDT HA-C50 HA-C60 HA-C50V HA-C60V AL6H-LK2-➁ LA3L-AO Oversize Round Oversize Round HA1L-MO HA1A-L1-➁ HA1L-A0 Oversize Square Oversize Square HA2L-MO Part Number:Lamp Holder HA2A-L1-➁ HA2L-AO Appearance Part Number HA9Z-AH Mushroom Mushroom Part Number: Safety Lever Lock HA1B-MOL HA1B-AOL HA1A-L3-➁ Appearance Part Number HA9Z-LS In place of ➁ specify Lens Color Code from table. ➁ Lens/LED Color Codes Color Code Amber Green Red Blue Yellow White www.idec.com A G R S Y W USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A2-37 Miniature Switches & Pilot Devices ø16mm - L6 Series Selector Switches (Assembled) Part Numbers: Selector Switches Round Maintained L R Contact DPDT LA1S-2C6 Contact Operations (for all selectors) Contacts Operator Position and Contact Operation LA1S-2C2V Left Left Spring return from right L R DPDT LA1S-21C6 LA1S-21C2V 2-pos. (DPDT) Maintained C L R DPDT LA1S-3C6 NO Right NC NO NO Right NO NC Right 45˚ 3-Position Left Spring return from right L R C DPDT DPDT LA1S-31C6 LA1S-32C6 LA1S-31C2V LA1S-32C2V Spring return from left L 2-Way spring return L R DPDT LA1S-33C6 LA1S-33C2V L R DPDT LA2S-2C6 LA2S-2C2V Spring return from right L R DPDT LA2S-21C6 LA2S-21C2V Maintained L R DPDT LA2S-3C6 LA2S-3C2V R DPDT LA2S-31C6 LA2S-31C2V R DPDT LA2S-32C6 LA2S-32C2V R 3-pos. (DPDT) NO NC NO Left Center NO NC Oversize Round 90˚ 2-Position 90˚ 2-Position 45˚ 3-Position Rectangular 90˚ 2-Position 45˚ 3-Position Square A2-38 Maintained Spring return from right C C L C Spring return from left L 2-Way spring Return L R DPDT LA2S-33C6 LA2S-33C2V L R DPDT LA3S-2C6 LA3S-2C2V Spring return from right L R DPDT LA3S-21C6 LA3S-21C2V Maintained L R DPDT LA3S-3C6 LA3S-3C2V R DPDT LA3S-31C6 LA3S-31C2V R DPDT LA3S-32C6 LA3S-32C2V Maintained Spring return from right C C C L C Spring return from left L 2-Way spring Return L R DPDT LA3S-33C6 LA3S-33C2V L R DPDT HA1S-2C6 HA1S-2C2V Spring return from right L R DPDT HA1S-21C6 HA1S-21C2V Maintained L R DPDT HA1S-3C6 HA1S-3C2V R DPDT HA1S-31C6 HA1S-31C2V R DPDT HA1S-32C6 HA1S-32C2V R DPDT HA1S-33C6 HA1S-33C2V Maintained Spring return from right C C C L C Spring return from left L 2-Way spring Return L www.idec.com C Right NO NC Right NO Left C NC LA1S-3C2V Left C NC Left Right 45˚ 3-Position Switches & Pilot Devices A2 Position 90˚ 2 -Position Style Terminal Style Solder Tab PCB NC NC Right NO NC As viewed from front of switch. 1. All assembled selector switches use DPDT contacts. 2. For SPDT contacts see sub-components on next page. 3. PCB terminal models also available with silver contacts (change “1” or “2” to “5” or “6” respectively, ie LA1S-21C2V becomes LA1S-21C6V. USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Miniature Switches & Pilot Devices ø16mm - L6 Series Selector Switches (Sub-Assembled) Contacts + Safety Lever Lock + Operator = Complete Part A2 Switches & Pilot Devices Part Numbers: Operators Style Position Round Square Rectangular Oversize Round Function Part Number 2 Maintained Spring from right LA1S-2Y LA1S-21Y 3 Maintained Spring from right Spring from left Spring from both LA1S-3Y LA1S-31Y LA1S-32Y LA1S-33Y 2 Maintained Spring from right LA2S-2Y LA2S-21Y 3 Maintained Spring from right Spring from left Spring from both LA2S-3Y LA2S-31Y LA2S-32Y LA2S-33Y 2 Maintained Spring from right LA3S-2Y LA3S-21Y 3 Maintained Spring from right Spring from left Spring from both LA3S-3Y LA3S-31Y LA3S-32Y LA3S-33Y 2 Maintained Spring from right HA1S-2Y HA1S-21Y 3 Maintained Spring from right Spring from left Spring from both HA1S-3Y HA1S-31Y HA1S-32Y HA1S-33Y Part Numbers: Contacts Contacts Silver Gold Appearance Terminal Style Solder Tab PCB SPDT DPDT HA-C1 HA-C2 HA-C1V HA-C2V SPDT DPDT HA-C5 HA-C6 HA-C5V HA-C6V 1. All assembled switches listed on previous page use DPDT contacts. 2. SPDT Contacts for use on 2 position selector switch only Part Number: Safety Lever Lock Appearance Part Number HA9Z-LS www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A2-39 Miniature Switches & Pilot Devices ø16mm - L6 Series Key Switches (Assembled) Part Numbers: Key Switches Style 90 2-Position Maintained Spring return from right L R L R Contacts DPDT LA1K-2C6➂ DPDT C Maintained L R DPDT LA1K-21C6B LA1K-3C6➂ Contact Operations (for all selectors) Contacts LA1K-2C2V➂ LA1K-21C2VB Operator Position and Contact Operation Left Left 2-pos. (DPDT) NO NC Right NO NO Left NO NC 45 ˚3-Position Spring return from right Spring return from left Square 90˚ 2-Position 2-Way spring return Maintained Spring return from right C L R DPDT NO R DPDT 45 ˚3-Position 90 ˚2-Position Rectangular Spring return from right Right R DPDT LA1K-33C6D LA1K-33C2VD L R DPDT LA2K-2C6➂ LA2K-2C2V➂ L R DPDT LA2K-21C6B LA2K-21C2VB R DPDT LA2K-3C6➂ LA2K-3C2V➂ L C L L R DPDT C 45 ˚3-Position 90 ˚2-Position LA2K-31C2V➂ R DPDT LA2K-32C6➂ LA2K-32C2V➂ R DPDT LA2K-33C6D LA2K-33C2VD NC Right NO NO NC NC Right NO NC ➂ Key Retention Option Codes Code Description A B C E G C H L R DPDT LA3K-2C6➂ LA3K-2C2V➂ L R DPDT LA3K-21C6B LA3K-21C2VB R DPDT LA3K-3C6➂ LA3K-3C2V➂ R DPDT LA3K-31C6➂ LA3K-31C2V➂ R DPDT LA3K-32C6➂ LA3K-32C2V➂ L Spring return from right L Spring return from left L 2-Way spring return L R DPDT LA3K-33C6D LA3K-33C2VD L R DPDT HA1K-2C6➂ HA1K-2C2V➂ L R DPDT HA1K-21C6B HA1K-21C2VB R DPDT HA1K-3C6➂ HA1K-3C2V➂ R DPDT HA1K-31C6➂ HA1K-31C2V➂ R DPDT HA1K-32C6➂ HA1K-32C2V➂ R DPDT HA1K-33C6D HA1K-33C2VD C C Key not retained in any position (removable in all positions) Key retained in right position only Key retained in left position only Key retained in left and right (3 position only) Key retained in center only (3 position only) Key retained right and center (3 position only) Key retained left and center (3 position only) Key cannot be removed from a spring-return position. C C A2-40 LA2K-31C6➂ Maintained Spring return from right NO As viewed from front of switch. D 2-Way spring return Maintained NC C C Oversize Round Left Center LA1K-32C2V➂ L L Spring return from right NO Left Spring return from left Maintained NC LA1K-31C2V➂ Right C Maintained LA1K-32C6➂ NC LA1K-3C2V➂ 3-pos. (DPDT) C L LA1K-31C6➂ NC Right Left Right Left 45 ˚3-Position Switches & Pilot Devices A2 Round Operation Terminal Type Solder Tab PCB Maintained L Spring return from right L Spring return from left L 2-Way spring return L C C 1. In place of ➂ specify Key Retention Code from next page. 2. All assembled key switches have DPDT contacts. For SPDT see subassembled on next page. 3. PCB terminal models also available with silver contacts (change “1” or “2” to “5” or “6” respectively, ie LA1K-2C2V➂ becomes LA1K-2C6V➂. C www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Miniature Switches & Pilot Devices ø16mm - L6 Series Key Switches (Sub-Assembled) Contacts + Safety lever lock + Operator = Complete Part A2 Square Operation Part Number 2 Maintained Spring from right LA1K-2➂ LA1K-21B 3 Maintained Spring from right Spring from left Spring from both LA1K-3➂ LA1K-31➂ LA1K-32➂ LA1K-33D 2 Maintained Spring from right LA2K-2➂ LA2K-21B 3 Maintained Spring from right Spring from left Spring from both LA2K-3➂ LA2K-31➂ LA2K-32➂ LA2K-33D Terminal Style Contacts Solder PCB Tab Appearance Gold Round Positions SPDT DPDT HA-C1 HA-C2 HA-C1V HA-C2V Silver Style Part Numbers: Contacts SPDT DPDT HA-C5 HA-C6 HA-C5V HA-C6V 1. All assembled selectors listed on previous page use DPDT contacts. 2. SPDT contacts are for use on 2 position key switches only. Part Number: Safety Lever Lock Appearance Rectangular 2 Maintained Spring from right Part Number LA3K-2➂ LA3K-21B HA9Z-LS 3 Oversize Round 2 3 Maintained Spring from right Spring from left Spring from both Maintained Spring from right Maintained Spring from right Spring from left Spring from both LA3K-3➂ LA3K-31➂ LA3K-32➂ LA3K-33D ➂ Key Retention Option Codes Code Description HA1K-2➂ HA1K-21B A HA1K-3➂ HA1K-31➂ HA1K-32➂ HA1K-33D B C D E G H 1. In place of ➂ specify key removable code from table on right. Key not retained in any position (removable in all positions) Key retained in right position only Key retained in left position only Key retained in left and right (3 position only) Key retained in center only (3 position only) Key retained right and center (3 position only) Key retained left and center (3 position only) Key cannot be removed from a spring-return position. 2. Operator includes two keys. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A2-41 Switches & Pilot Devices Part Numbers: Operators Miniature Switches & Pilot Devices ø16mm - L6 Series Illuminated Selector Switches Part Numbers: Illuminated Selectors Switches A2 Round Maintained Spring return from right Contact Voltage L R L DPDT Maintained L 24V LED 24V Incand. DPDT 24V LED 24V Incand. LA1F-21C64-➁ LA1F-21C24V-➁ LA1F-21C67-➁ LA1F-21C27V-➁ DPDT 24V LED 24V Incand. LA1F-3C64-➁ LA1F-3C67-➁ R DPDT 24V LED 24V Incand. LA1F-31C64-➁ LA1F-31C24V-➁ LA1F-31C67-➁ LA1F-31C27V-➁ R DPDT 24V LED 24V Incand. LA1F-32C64-➁ LA1F-32C24V-➁ LA1F-32C67-➁ LA1F-32C27V-➁ R C R Contact Operations (for all selectors) Operator Position and Contact Operation Contacts Left Left 2-pos. (DPDT) LA1F-3C24V-➁ LA1F-3C27V-➁ NO NC Right NO NO Left NO NC 45˚ 3-Position Spring return from right L Spring return from left L NO C Maintained Spring return from right C L R DPDT 24V LED 24V Incand. LA1F-33C64-➁ LA1F-33C24V-➁ LA1F-33C67-➁ LA1F-33C27V-➁ L R DPDT 24V LED 24V Incand. LA2F-2C64-➁ LA2F-2C67-➁ L R DPDT 24V LED 24V Incand. LA2F-21C64-➁ LA2F-21C24V-➁ LA2F-21C67-➁ LA2F-21C27V-➁ R DPDT 24V LED 24V Incand. LA2F-3C64-➁ LA2F-3C67-➁ R DPDT 24V LED 24V Incand. LA2F-31C64-➁ LA2F-31C24V-➁ LA2F-31C67-➁ LA2F-31C27V-➁ R DPDT 24V LED 24V Incand. LA2F-32C64-➁ LA2F-32C24V-➁ LA2F-32C67-➁ LA2F-32C27V-➁ Square 90˚ 2-Position 45˚ 3-Position C Rectangular 45˚ 3-Position 90˚ 2-Position NC Right LA2F-2C24V-➁ LA2F-2C27V-➁ LA2F-3C24V-➁ LA2F-3C27V-➁ Right NO Right NO NC Spring return from left L 2-Way spring return L R DPDT 24V LED 24V Incand. LA2F-33C64-➁ LA2F-33C24V-➁ LA2F-33C67-➁ LA2F-33C27V-➁ L R DPDT 24V LED 24V Incand. LA3F-2C64-➁ LA3F-2C67-➁ 5V DC LED 1 DPDT 24V LED 24V Incand. LA3F-21C64-➁ LA3F-21C24V-➁ LA3F-21C67-➁ LA3F-21C27V-➁ 6V AC/DC LED 2 12V AC/DC LED 3 R DPDT 24V LED 24V Incand. LA3F-3C64-➁ LA3F-3C67-➁ 24V AC/DC LED 4 R DPDT 24V LED 24V Incand. LA3F-31C64-➁ LA3F-31C24V-➁ LA3F-31C67-➁ LA3F-31C27V-➁ R DPDT 24V LED 24V Incand. LA3F-32C64-➁ LA3F-32C24V-➁ LA3F-32C67-➁ LA3F-32C27V-➁ Maintained Spring return from right C L R LA3F-2C24V-➁ LA3F-2C27V-➁ LA3F-3C24V-➁ LA3F-3C27V-➁ Maintained L Spring return from right L Spring return from left L 2-Way spring return L R DPDT 24V LED 24V Incand. LA3F-33C64-➁ LA3F-33C24V-➁ LA3F-33C67-➁ LA3F-33C27V-➁ L R DPDT 24V LED 24V Incand. HA1F-2C64-➁ HA1F-2C67-➁ L R DPDT 24V LED 24V Incand. HA1F-21C64-➁ HA1F-21C24V-➁ HA1F-21C67-➁ HA1F-21C27V-➁ R DPDT 24V LED 24V Incand. HA1F-3C64-➁ HA1F-3C67-➁ R DPDT 24V LED 24V Incand. HA1F-31C64-➁ HA1F-31C24V-➁ HA1F-31C67-➁ HA1F-31C27V-➁ R DPDT 24V LED 24V Incand. HA1F-32C64-➁ HA1F-32C24V-➁ HA1F-32C67-➁ HA1F-32C27V-➁ DPDT 24V LED 24V Incand. HA1F-33C64-➁ HA1F-33C24V-➁ HA1F-33C67-➁ HA1F-33C27V-➁ Maintained Spring return from right C C C C Maintained L Spring return from right L Spring return from left L C C C L www.idec.com R HA1F-2C24V-➁ HA1F-2C27V-➁ HA1F-3C24V-➁ HA1F-3C27V-➁ NO NC ➁ Lens/LED Color Code Color Code L C NC As viewed from front of switch. Spring return from right C NC Right L 2-Way spring return A2-42 NO NC NO Left Center Maintained C Oversize Round 3-pos. (DPDT) NC Left 2-Way spring return 90˚ 2-Position C NC Right Left Right Left 45˚ 3-Position Switches & Pilot Devices Operation 90˚ 2-Position Style Terminal Style Solder Tab PCB LA1F-2C64-➁ LA1F-2C24V-➁ LA1F-2C67-➁ LA1F-2C27V- ➁ Amber Green Red Blue Yellow White A G R S Y W Voltage/Lamp Code Voltage Code 120V AC LED 8 6V AC/DC Incandescent 5 12V AC/DC Incandescent 6 24V AC/DC Incandescent 7 1. In place of ➁ specify Lens/LED Color Code from table above. 2. Lamps also available in 5V DC, 6V AC/DC or 12 V AC/DC, change “4” or “7” using voltage/lamp codes (ie LA1F-2C63-➁ uses 12V AC/DC LED). 3. All switches listed have DPDT contacts. For SPDT see sub-assembled on next page. 4. PCB terminal models also avail- able with silver contacts (change “1” or “2” to “5” or “6” respectively, ie LA1F-2C24V-➁ becomes LA1F-2C64V-➁. USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Miniature Switches & Pilot Devices ø16mm - L6 Series Illuminated Selector Switches (Sub-Assembled) Contacts + Safety lever lock + Lamp Holder + Lamp + Operator + Lens/Handle = Completed Unit A2 Style Part Numbers: Lenses/Handles Positions Round Square Rectangular Oversize Round Function Part Number 2 Maintained Spring from right LA1F-20 LA1F-210 3 Maintained Spring from right Spring from left Spring from both LA1F-30 LA1F-310 LA1F-320 LA1F-330 2 Maintained Spring from right LA2F-20 LA2F-210 3 Maintained Spring from right Spring from left Spring from both LA2F-30 LA2F-310 LA2F-320 LA2F-330 2 Maintained Spring from right LA3F-20 LA3F-210 3 Maintained Spring from right Spring from left Spring from both LA3F-30 LA3F-310 LA3F-320 LA3F-330 2 Maintained Spring from right HA1F-20 HA1F-210 3 Maintained Spring from right Spring from left Spring from both HA1F-30 HA1F-310 HA1F-320 HA1F-330 Part Numbers: Contacts Appearance Gold SPDT DPDT HA-C1 HA-C2 HA-C10V HA-C20V Silver SPDT DPDT HA-C50 HA-C60 HA-C50V HA-C60V LA1A-F-➁ Oversize HA1A-F-➁ In place of ➁ specify Lens Color Code from table. Part Number: Safety Lever Lock Appearance A G R S Y W www.idec.com Part Number HA9Z-LS Appearance Part Number HA9Z-AH Part Numbers: Lamps Appearance 1. All assembled selectors on previous pages use DPDT contacts. SPDT contacts are for use only on two position selectors. Amber Green Red Blue Yellow White Part Number Standard Part Number: Lamp Holder Terminal Style Solder Contacts PCB Tab Appearance ➁ LED/Lens Color Code Color Code Switches & Pilot Devices Part Numbers: Operators LED Voltage 5V DC 6V AC/DC 12V AC/DC 24V AC/DC 120V AC Part Numbers LFTD-5➁ LFTD-6➁ LFTD-1➁ LFTD-2➁ LFTD-H2➁ Incandescent 6V AC/DC 12V AC/DC 24V AC/DC LH-06 LH-14 LH-28 In place of ➁ specify LED Color Code from table. USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A2-43 Miniature Switches & Pilot Devices ø16mm - L6 Series Pushbutton Selectors (Assembled) Part Numbers: Pushbutton Selectors ① Button Color Code Terminal Style Style 2 Position PCB HA1R-2C6-① 3 Position HA1R-2C2V-① HA1R-3C6-① HA1R-3C2V-① Color Code Black B Green G Red R Blue S Yellow Y 1. In place of ① specify Button Color Code. 2. PCB terminal models also available with silver contacts (change “1” or “2” to “5” or “6” respectively, ie HA1R-2C2V-① becomes HA1R-2C6V-①). Contact Operation Operator Position Style Left Normal 2 Position Left NO NO Center Depressed Left Right NC NO Left 3 Position NO NC NO NO NC NC Depressed Normal Right NO Left Right NC NC Normal Right Left – NC Right NO Left NC NO NC – NO Right NO NC NC Left Blocked NO NC Depressed Right NO NC Right NO NC Right Left NO NO NC Left NO NC NC Right NO NC Lever Switch (Assembled) Part Numbers: Lever Switches Style Operation Contacts Terminal Type Solder Tab PCB DPDT LA1T-2C6 LA1T-2C2V DPDT LA1T-21C6 LA1T-21C2V DPDT LA1T-22C6 LAIT-22C2V DPDT LA1T-3C6 LA1T-3C2V DPDT LA1T-31C6 LA1T-31C2V DPDT LA1T-32C6 LA1T-32C2V DPDT LA1T-33C6 LA1T-33C2V U Maintained 2-Position D U Spring return from top D U Spring Return from bottom D U Maintained C D U Spring return from top 3-Position Switches & Pilot Devices A2 Solder Tab C D U Spring return from bottom C PCB terminal models also available with silver contacts (change “1” or “2” to “5” or “6” respectively, ie LA1T-2C2V becomes LA1T-2C6V). D U Spring return from both C D Contact Operation Contacts Operator Position & Contact Operation 2-pos. Maintained (DPDT) Spring from Top 2-pos Spring Return (DPDT). from Bottom 3-pos. (DPDT) All models A2-44 Down Left NO NC Left NO Up Left NO NO NC NC NO NC NO Right NO NC NC Left Right NC Left NO Center Right Left NO NC www.idec.com Right NO NC NC Left NO NC Right NO NC Right NO NC Right NO NC As viewed from front of switch. USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Miniature Switches & Pilot Devices ø16mm - L6 Series Accessories Part Specifications Part Number Notes Ring Wrench Made of metal MT-001 Used for tightening the plastic locking ring when installing the L6 series unit on a panel. Tightening torque should not exceed 9kgf cm when tightening a locking ring. Made of rubber. Used for removing and replacing LED and incandescent lamps in illuminated units. OR-44 Rubber tool used for replacing LED and incandescent lamps. Lens Removal Tool For Illuminated pushbuttons and pilot lights. MT-101 Used for removing the lens or button from the housing. LED Lamp 5V DC 6V AC/DC 12V AC/DC 24V AC/DC 120V AC LFTD-5➁ LFTD-6➁ LFTD-1➁ LFTD-2➁ LFTD-H2➁ T 1-3/4 miniature flange base. In place of ➁ specify LED Color Code (see page A2-43). Incandescent Lamp 6V AC/DC 12V AC/DC 24V AC/DC LH-06 LH-14 LH-28 0.5W, T 1-3/4 miniature flange base 90 degrees opening maintained Switch Guard Dust-proof Cover 180 degrees opening, spring return Round/Square AL-K6 Rectangular AL-KH6 Round/Square AL-K6SP Rectangular AL-KH6SP Oversize Round/Sq Terminal Cover AL-D6 For square units AL-DQ6 H6-VL2 Unibody Pilot Lights H6-PVL Made of white nylon Covers terminals to prevent possible electric shock. Rubber AL-B6 Aluminum AL-BM6 for LA1K (#132) AS6-SK for HA1K (#231) KG9Z-SK Replacement Keys Round Square Rectangle Oversize Round Oversize Square Mushroom All models AL6M-W AL6Q-W AL6H-W HA9Z-P1-W HA9Z-P2-W HA9Z-P13-W HA9Z-LN L6 standard AL6-LP L6 oversize HA9Z-LP Replacement Selector Inserts HA9Z-HC1-① Replacement Safety Lever Lock HA9Z-LS www.idec.com Fills unused panel cutouts. Made of nitrile rubber. Push-in installation from front of panel. IP65 (oiltight) rated. Fills unused panel cutouts. Made of aluminum. Screwon locking ring from inside of panel. IP65 (oiltight) rated. Pair of keys. Replacement Engraving Inserts Replacement Anti-Rotation Ring Provides extra level of sealing for “front-panel” portion of switches. (Not applicable for units with oversize lenses or buttons). AL-DH6 All removable contacts Mounting Hole Plug Replacement Locking Ring Prevents inadvertent switch operation. IP65 oiltight rated. HA9Z-K1 For round units For rectangular units Prevents inadvertent switch operation. IP40 dust-tight rated. Prevents rotation of switches in panel. (included with all assembled switches) Applicable to round oversize selectors only ① = (G, R, S, W, Y) USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A2-45 Switches & Pilot Devices Lamp Holder Tool (Made of Rubber) A2 Miniature Switches & Pilot Devices ø16mm - L6 Series Dimensions Non -Illuminated Pushbuttons (LA*B) 0.11 (2.8) 0.24 (6.0) 0.71 (18.0) 0.71 (18.0) 0.27 (6.8) 0.35 (9.0) 1.39 (35.4) 0.71 (18.0) 0.38 (9.6) 0.98 (24.8) 0.94 (24.0) 0.71 (18.0) Emergency Stop Switch (HA1B) LOC " .61 ) RO m .5m (15 Switches & Pilot Devices A2 Rubber Washer K Panel Thickness 0.02"-0.24" (0.5~6.0mm) Stopper Locking Ring " 98 ) 0. m Ø .9m 4 (2 PCB Terminal 0.34" + (8.7mm) NC NC - 0.21" (5.4mm) ø0.70" ø0.83" (17.8mm) 0.20" 0.41" (5.2mm) (10.5mm) 0.43" (11mm) 0.62" (15.8mm) (21mm) 0.53" (13.5mm) 1.42" (36mm) 0.98" (25mm) Emergency Stop Switch (HA1E) - Short Body Style Buzzer (LA3Z) 0.11 (2.8) 0.71 (18.0) 0.24 (6.0) 1.39 (35.4) 0.35 (9.0) 0.62 (15.7) 0.35 (9.0) 0.98 (24.8) 0.94 (24.0) Pilot Lights (LA*P) 0.11 (2.8) 0.24 (6.0) 0.71 (18.0) 0.71 (18.0) 0.27 (6.8) A2-46 0.35 (9.0) 1.39 (35.4) www.idec.com 0.38 (9.6) 0.71 (18.0) 0.71 (18.0) 0.98 (24.8) 0.94 (24.0) USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Miniature Switches & Pilot Devices ø16mm - L6 Series Dimensions con’t Illuminated Pushbuttons (LA*L) 0.11 (2.8) A2 0.24 (6.0) 0.27 (6.8) 0.35 (9.0) 1.39 (35.4) 0.38 (9.6) 0.71 (18.0) Switches & Pilot Devices 0.71 (18.0) 0.71 (18.0) 0.98 (24.8) 0.94 (24.0) 0.71 (18.0) Key Switches (LA*K) 0.11 (2.8) 0.24 (6.0) 0.71 (18.0) 0.71 (18.0) 0.27 (6.8) 0.35 (9.0) 1.39 (35.4) .98 (24.9) 0.71 (18.0) 0.98 (24.8) 0.94 (24.0) 0.71 (18.0) Selector Switches (LA*S) 0.11 (2.8) 0.24 (6.0) 0.71 (18.0) 0.71 (18.0) 0.27 (6.8) Panel Cut-Out 0.35 (9.0) 1.39 (35.4) 0.66 (16.8) 0.71 (18.0) 0.94 (24.0) 0.71 (18.0) PCB Layout (except for Buzzer and E-Stop) 0.20 (5.0) PCB Pins Acess Hole for Locking Lever 0.36 (9.3) 0.20 (5.0) 0.98 (24.8) 0.03 (0.8) 0.24 (6.0) Ø0.05 (1.2) 0.42 (10.7) 0.04 (1.0) 0.27 (6.8) 0.20 (5.0) 0.06 (1.5) 0.25 (6.4) 0.94 (24.0) HA1B E-Stop PCB Mounting Pattern 0.21" (5.3mm) 0.21" (5.3mm) 0.21" (5.4mm) 0.34" (8.7mm) " 05 ) 0. m Ø .2m (1 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A2-47 Miniature Switches & Pilot Devices ø16mm - L6 Series Dimensions con’t NC X1 X2 NO NO C C 1.02 [25.9] X2 0.94 [24.0] 0.43 [11.0] NO C NC NO NC Oversize Extended Non-Illuminated Pushbutton C 0.59 [15.1] Oversize Unibody PIlot Lights 1.48 [37.5] NC NC NO C NO Mushroom Pushbuttons 1.18 [30.0] ÿ1.18 [ÿ30.0] 0.79 [20.0] NO C NC NO NC Oversize Selector Switch C Switches & Pilot Devices A2 NC Oversize Flush Pushbutton and Pilot Lights 0.94 [23.8] ÿ0.94 [ÿ23.8] 0.77 [19.5] A2-48 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Miniature Switches & Pilot Devices ø16mm - L6 Series Dimensions con’t NO C NC NO C NC Oversize Key Switch A2 Switches & Pilot Devices 1.54 [39.0] NC NC NO C NO Lever Switch 0.94 [23.8] Terminal Configurations .94 (24.) 1.30 (33) .41 (10.5) Steady Slow Quick Input Terminal (X1) Buzzer Sound Switch AL-K6SP .51 (13) 1.34 (34) .93 (23.5) X1 X1 AL-KH6SP .51 (13) X2 Input Terminal (X2) X2 NO NC Buzzer C NC NO X1 X2 X2 C C C X2 Lamp Terminal (–) Lamp Terminal (–) X2 Lamp Terminal (+) X1 NC Lamp Terminal (+) NO NC NO Illuminated Pushbuttons Pilot Lights Non Illuminated Pushbutton R2 Panel Thickness: .20 max. (5 max) .71 (18) .93 (23.5) 2 .41 (10.5) 1.79 (45.5) .98 (25) 1.79 (45.5) .75 (19) AL-DH6 AL-DQ6 AL-D6 .94 (24) 1.18 (30) ø24 .94" .94 (24) .51 (13) .30 (7.5) .51 (13) .30 (7.5) .51 (13) .01 (0.3) www.idec.com Water-proof Gasket .01 (0.3) Water-proof Gasket .01 (0.3) .30 (7.5) Water-proof Gasket USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A2-49 Miniature Switches & Pilot Devices ø16mm - L6 Series Dimensions con’t AL-B6 H6-VL2 1.85 (47) .24 (6) .08 (2) .69 (17.6) .59 (15) .16 (4) .83 (21) .47 (12) .10 (2.5) .70 (17.8) Switches & Pilot Devices A2 AL-BM6 TOP Marking Side .70 (18) .65 (16.5) Gasket Locking Ring LED Lamp Internal Circuit LED Chip Protective Diode Zener Diode A2-50 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC Miniature Switches & Pilot Devices ø16mm - L6 Series General Instructions Pushbutton Assembly Lamp Installation Lamps can be replaced in two ways: A2 Switches & Pilot Devices 1. If contacts are accessible (or pushbutton not installed in a panel) then it is easiest to first remove the contacts from the operator. This will allow easy access to the lamp/lamp-holder assembly. Grab lamp, depress slightly, and turn counter clockwise. Lamp can then be removed by pushing it back through the lamp holder. 2. If contacts are not accessible, then the lamp can be replaced by first removing the lens from the operator. Just pull lens straight out either with a fingernail or optional lens removal tool (MT-101). Lamp/lampholder assembly can then be removed with lamp removal tool (OR-44). Insert lamp removal tool through operator, depress slightly, turn counter clockwise, then pull lamp/lamp-holder assembly out. Lamp can then be removed by pushing it back through the lamp holder. Engraving Lenses All buttons and lenses can be engraved directly on the outside surface. Illuminated lenses also allow for engraving on a plate that is underneath the colored section of the lens. Remove the colored section of the lens by pulling on the edge while simultaneously unhooking it from the latches on the lens holder. The marking plate will then be accessible. It can then be engraved or a thin marked insert (such as mylar or paper) can be sandwiched between the marking plate and colored section of the lens. Latches Recess Engraving Area Color Lens Marking Plate Lens Holder Panel Mounting Before any unit can be mounted into a panel, the contact block must be removed. Slide metal locking lever and pull contact off. Loosen and remove the locking ring and square anti-rotation ring from the operator and insert operator through panel cutout from the front of the panel. Slide on anti-rotation ring and tighten locking ring, using locking ring wrench (MT-001). Slide contact block onto operator, observing TOP marking on both parts. Slide metal locking lever in direction indicated by LOCK. The yellow plastic safety lever lock can then be snapped onto the locking lever; this will prevent vibration or maintenance actions from releasing the contact from the operator. PCB Mounting Being able to separate the contacts from the operator allows for assembly of the front panel components (operator and lens) to be performed in tandem with the PC board assembly and soldering. For applications where multiple rows of pushbuttons are mounted closely together, or where other components may obstruct access to the contact locking lever, be sure to include access holes in the PC board (refer to PC board layout dimensions for location). Also be sure to allow for space above and to the side of contact to ensure that no components block the contact block locking lever. PC board pins are designed to rest on the PCB, take this into consideration to ensure that pins do not short closely spaced traces. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC A2-51
AL6H-LK2-W 价格&库存
很抱歉,暂时无法提供与“AL6H-LK2-W”相匹配的价格&库存,您可以联系我们找货
AL6H-LK2-W
  • 1+36.605021+4.73542
  • 10+33.1276010+4.28556
  • 25+31.8411225+4.11914
  • 50+30.9068850+3.99828
  • 100+29.99695100+3.88057
  • 250+28.83628250+3.73042
  • 500+27.98765500+3.62063
  • 1000+27.163721000+3.51405
