AL8H-M11-R
AL8H-M11-R
    IDEC(日本和泉)
    按动开关
AL8H-M11-R 数据手册
Switches & Pilot Devices Terminal Blocks Contactors Timers Relays & Sockets Signaling Lights Switches & Pilot Devices Miniature ø8mm A8 Series A8 Series — Miniature Switches and Pilot Devices: 8mm Key features: • 21/64” (8mm) round mounting hole • Compact Design Saves Space • Bright and Vivid Illumination • Choice of Shapes and Functions • Gold Clad Silver Contacts for reliable low level switching • Snap action contacts • IP40 (Dustproof) Construction UL Listed File No. E55996 Specifications LED Lamp Life 50,000 hours approximately (reduced to half of original intensity) Contact Configuration SPDT Maximum Voltage 250V AC/DC Thermal Current 3A Contact Material Gold-clad Silver Terminal Style Solder Tab Terminal Operating Temperature –25º to +55ºC (no freezing) Operating Humidity 45 to 85% RH Contact Resistance 50mΩ maximum (initial value) Insulation Resistance 100MΩ minimum (500V DC megger) Vibration Resistance 5 to 55Hz, 0.75mm amplitude Shock Resistance Damage limits: 500m/sec2 (approx. 50G) Operating extremes: 200m/sec2 (approx. 20G) Electrical Life 100,000 operations minimum Mechanical Life Maintained: 100,000 (1200 operations/hour) Momentary: 200,000 minimum Degree of Protection IP40 Enclosed/Dustproof Soldering Temperature 20W/5 seconds or 260ºC/3 seconds Dielectric Strength Switch Unit: 2,000V AC, 1 min. between live/dead part and terminals of different poles; 1,000V AC, 1 minute between terminals of the same pole; 1,500V AC, 1 minute between contact and lamp terminals. Illumination Unit: 2,000V AC, 1 min. between live part/ground Contact Ratings Operating Voltage 24V 120V Resistive — 1.0A 0.5A Inductive — 0.7A 0.5A AC 50/60Hz Circuit Breakers CSA Certified File No. LR21451 DC 240V Resistive 1.0A 0.2A — Inductive 0.7A 0.1A — 1. AC Inductive Load, PF = 0.6 – 0.7; DC Inductive Load, L/R = 7. 2. Minimum applicable load (reference value) is 5V AC/DC 3mA (applicable range is subject to the operating conditions and load). 456 www.IDEC.com Switches & Pilot Devices Miniature ø8mm A8 Series Switches & Pilot Devices AB8 Non-Illuminated Pushbuttons (Assembled) Non-Illuminated Pushbuttons Style Contact SPDT Round Part Numbers Momentary Maintained AB8M-M1-j AB8M-A1-j Signaling Lights j Button Color Codes Square SPDT Rectangular SPDT AB8Q-M1-j AB8H-M1-j AB8Q-A1-j AB8H-A1-j Color Code Black B Green G Red R S W Yellow Y Relays & Sockets Blue White 1. In place of j, specify button color code from the table below. 2. For accessories, see page 459. 3. For dimensions, see page 460. Timers Contactors Terminal Blocks Circuit Breakers 800-262-IDEC (4332) • USA & Canada 457 Switches & Pilot Devices Switches & Pilot Devices Miniature ø8mm A8 Series AL8 Illuminated Pushbuttons & Pilot Lights (Assembled) Illuminated Pushbuttons Style SPDT Signaling Lights Round Relays & Sockets Part Numbers Contact Momentary Maintained Pilot Light Part Number AL8M-M11-k AL8M-A11-k AL8M-P1-k k LED/Lens Color Codes Square SPDT Rectangular AL8Q-M11-k SPDT AL8H-M11-k AL8Q-A11-k AL8H-A11-k Amber A Green G Red R White W Yellow Y LED Voltage and Recommended Current Limiting Resistor LED Lamp Part Number Voltage External Resistor Amber Amber LAD-SA Green Green LAD-SG Red Red LAD-SR 5V DC 6V DC 12V DC 24V DC 150Ω, 1/2W 200Ω, 1/2W 510Ω, 1W 1.1kΩ, 1W White Yellow* LAD-SY Yellow Yellow LAD-SY Timers Lens Color * White units use a white lens and a yellow LED. Contactors AL8H-P1-k Code 1. In place of k, specify lens color code from table on the right. 2. A replaceable LED lamp is included with the operator. 3. Because the LED lamp does not contain an internal current limiting resistor, an external resistor must be added. For recommended values, see table below. 4. For accessories, see page 459. 5. For dimensions, see page 460. Replacement LEDs LED Lamp Ratings: LED Specifications LED Lamp Forward Current If Forward Voltage (Nominal) Vf Reverse Voltage Vr Amber 20mA 2.2V 4V Green 20mA 2.1V 4V Red 20mA 1.7V 4V 20mA 2.2V 4V Yellow Operating Voltage & External Current Limiting Resistor (Recommended Value) 5V DC: 150Ω, 1/2W 6V DC: 200Ω, 1/2W 12V DC: 510Ω, 1W 24V DC: 1.1kΩ, 1W When LED lamps are used at voltages other than those stated above, external resistor value, R, is determined by the following formula: R = (Operating Voltage – Vf) / If Circuit Breakers Terminal Blocks AL8Q-P1-k Color 458 www.IDEC.com Switches & Pilot Devices Miniature ø8mm A8 Series Switches & Pilot Devices Accessories Description Item Locking Ring Wrench Used With Made of metal. Used for tightening plastic locking ring during installation. Tightening torque should not exceed 3kgf-cm Part Number All units MT-004 Lens Removal Tool MT-101 Made of rubber. Used for removing and replacing LED lamps in illuminated units Illuminated pushbuttons and pilot lights OR-66 Round & square units AL-K8 Rectangular units AL-KH8 All units AL-V8 Switch Guard Used to avoid operating the pushbutton inadvertently. Cover flips open 90˚. Provides IP40 protection Signaling Lights Lamp Holder Tool Made of metal. Used for removing lens or button from the housing Illuminated pushbuttons and pilot lights Terminal Cover Made of translucent nylon. Fits over and shields the terminals AL-C8 AL-C8V shown attached Mounting Hole Plug AL-C8 All units AL-C8V Made of rubber. Fills unused mounting holes to provide IP65 protection Extra panel cutouts AL-B8 LAD-SR (red) LED lamp is included in every illuminated control unit. Replacement lamp is ordered separately. External current limiting resistor required. LAD-SG (green) Illuminated units and pilot lights Timers Replacements LEDs Plug-on adaptor with PCB terminals, allows easy control unit replacement. Relays & Sockets Plug-on adaptor with solder terminals, allows easy control unit replacement. Adaptor Socket LAD-SA (amber) LAD-SY (yellow) Replacement Lenses Illuminated pushbuttons and pilot lights Replacement Buttons 1. In place of j, specify Button Color Code from the table. 2. In place of k, specify Lens Color Code from table. j Button Color Codes Color AL8M-LK1-k Square AL8Q-LK1-k Rectangular AL8H-LK1-k Round AB8M-BK1-j Square AB8Q-BK1-j Rectangular AB8H-BK1-j Contactors Non-Illuminated buttons Round k LED/Lens Color Codes Code Color Code B Amber A G Green G Red R Red R Blue S White W White W Yellow Y Yellow Y Terminal Blocks Black Green Circuit Breakers 800-262-IDEC (4332) • USA & Canada 459 Switches & Pilot Devices Dimensions A∆8 Panel Cut-Out (not drawn to scale) Panel Thickness 0.5 to 6 Rectangular Round (TOP) c9 ø9 Signaling Lights 2.5 ø9 5 5.5 5.5 7 22 +0.2 0 ø8 9 2.5 Terminal Width 1.8 × 0.4t Square (TOP) 9 min. Rectangular (TOP) Locking Ring 12 9 12 min. (TOP) Round/Square NC ø8 +0.2 0 COM Lamp Terminal (–) Terminal Sockets 9 min. Terminal 0.8 × 0.3t 6.3 33 For Round/Square Units (AL-K8) 2.5 33 Terminal Arrangement (TOP) 6.3 For Rectangular Units (AL-KH8) Switch Guard, Ø 21/64" (8mm) 2.5 Relays & Sockets Lamp Terminal (+) 9 min. NO 10 NC 21.5 12 Panel Thickness 0.5 to 5 2.5 Terminal Arrangement (TOP) PC Board Terminal (AL-C8V) 8.5 2.5 +0.2 0 14.5 5-1.0 Holes (PC Board Terminal Mounting Hole Layout) 11 min. COM Lamp Terminal (+) 6 3 Lamp Terminal (–) 17.5 min. Solder Terminal (AL-C8) 17 17.5 min. 8.8 8.5 5 6 Timers 17 2.5 14.5 NO (Bottom View) 12.5 For Round/Square Units (AL-K8) 13 min. NC For Rectan (AL-KH8) 10 (Bottom View) Terminal Cover www.IDEC.com 8.5 21.5 12 8.5 6 14.5 8.5 Circuit Breakers 11 min. 460 For Rectangular Units (AL-KH8) 10 17.5 min. 17.3 6 Terminal Blocks 33.5 14.5 11 min. For Round/Square Units (AL-K8) ø9.1 AL-V8, Ø 21/64" (8mm) 6 17.5 min. Lamp Terminal (–) 17.5 min. ard Terminal g Hole Layout) COM 6 Lamp Terminal (+) 14.5 Holes 14.5 +0.2 0 8.5 NO Contactors 2.5 0 Switches & Pilot Devices Miniature ø8mm A8 Series 13 min. 12.5
AL8H-M11-R 价格&库存
很抱歉,暂时无法提供与“AL8H-M11-R”相匹配的价格&库存,您可以联系我们找货
