HW1M-F0202-20
HW1M-F0202-20
    IDEC(日本和泉)
HW1M-F0202-20 数据手册
Oiltight Switches & Pilot Devices ø22mm - HW Series Key features include: • Locking lever removable contact blocks • Finger-safe IP20 contacts as standard, other terminal styles available • Tamperproof construction • All E-stops meet EN418 and are compliant with SEMI S2 standards • Worldwide approvals • Easy to assemble • Choice of black plastic or metallic front bezels • Incandescent or LED illumination • Transformer or full voltage • Slow make double break self cleaning contacts Display Lights Switches & Pilot Lights HW Series — 22mm IEC Style Global Pushbuttons HW: The Best Engineered Switch in the World Relays & Sockets IDEC’s HW switches are “The best engineered switch in the world” for a reason. Carrying the CE mark, UL, CSA, CCC (Chinese), and TUV approvals, these switches are designed for use in almost any part of the world. lights, selector switches, and emergency stop switches. All switches also incorporate mechanically keyed safety locking levers, ensuring correct installation and maintaining safety in high-vibration applications. Complete with finger-safe contact blocks offering IP20 protection, these 7/8” (22mm) switches include illuminated and non-illuminated pushbuttons, pilot Registration No. R9551089 (E-stops) Registration No. R50054316 (Dual Pushbuttons) Registration No. J9650511 (Pilot Lights) Registration No. J9551458 (all other switches) ® File No. E68961 Certificate No. 2005010305145656 File No. LR92374 Electrical Mechanical Circuit Breakers Terminal Blocks Timers Specifications 500 Rated Operational Characteristics AC-15: A600 or Ue = 250V, le = 3A (NO, NC, NO-EM, NC-LB) DC-13: P600 or Ue = 125V, le = 1.1A (NO, NC) DC-13: Q600 or Ue = 125V, le = 0.9A (NO-EM, NC-LB) Maximum Inrush Current 40 A (40 ms) Rated Insulation Voltage 600V Rated Switching Over-Voltage Less than 4kV, conforming to IEC60947-1 Rated Impulse Withstanding Voltage 4kV for contact circuit, 2.5kV for lamp circuit Rated Thermal Current 10 Amp Minimum Switching Capacity 5 mA at 3V AC/DC Electrical Reliability MTBF < 1 fault for 10 million operation cycles (3V DC, 5mA) Lamp Ratings Incandescent: 1 W LEDs: 6V/17mA max, 12V & 24V/11mA max, 120 & 240V/10mA max Contact Operation Slow break NC or NO, self-cleaning Positive Action Operation (Emergency Stops with NC contacts) 5.5mm to 10mm travel to latch, 45N minimum force to latch 10mm maximum travel, 1,800 operations per hour maximum for a Pushlock Turn Reset 900 operations per hour maximum for a Push-Pull Operating Force Flush and extended pushbuttons—with 1NO or 1NC contact: 6.2±2N (momentary), 7.0±2N (maintained) Additional contacts—1NO or 1NC: +3.2N (momentary), + 3.3N (maintained) Recommended Terminal Torque 0.8 N m (7.1 in lb.) Applicable Wire Size Minimum 1 x 22 AWG, max. 2 x 14 AWG or 1 x 12 AWG Contact Resistance Initial contact resistance of 50mΩ or less Contact Gap 4mm (NO and NC), 2mm (NO-EM and NC-LB) Horsepower Rating Reference Value: 1/4 HP @ 120V (1ø non-reversing), 1HP @ 240V (3ø non-reversing) Contact Material Silver (gold plated contacts available - contact IDEC) Operating Temperature Operation: –25 to +50°C (without freezing), Storage: –40 to +70°C (without freezing) Vibration Resistance 10 to 55Hz, 98m/sec2 (10G) conforming to IEC6068-2-6 Shock Resistance 980m/sec2 (100G) conforming to IEC6068-2-7 Mechanical Life Momentary pushbuttons: 5,000,000 (900 operations per hour), All other switches: 500,000 www.idec.com Courtesy of Steven Engineering, Inc.-230 Ryan Way, South San Francisco, CA 94080-6370-Main Office: (650) 588-9200-Outside Local Area: (800) 258-9200-www.stevenengineering.com Oiltight Switches & Pilot Devices Conforming to Standards EN60947-1, EN60947-5-1, VDE0660-200, UL508, CSA C22-2 No.14 ® Standards & Approvals File No. LR92374 Registration No. R9551089 (E-stops) Registration No. R50054316 (Dual Pushbuttons) Registration No. J9650511 (Pilot Lights) Registration No. J9551458 (all other switches) Certificate No. 2005010305145656 Class 0 conforming to IEC60536 Degree of Protection (conforming to IEC60529) (conforming to NEMA ICS6-110) IP65 (from front of the panel) IP20 (Type HW-F contact block) NEMA 1, 2, 3, 3R, 3S, 4, 4X, 5, 12, 13 (from front of panel) Pollution Degree (conforming to IEC60947-1) 3 for switches not using a transformer, 2 for switches using a transformer External Short-Circuit Protection 10A 250V fuse conforming to IEC60269-1 Contact Ratings Display Lights Conforming to CENELEC EN50005 Contact Block Pushbuttons Illuminated Pushbuttons Selector Switches Illuminated Selector Switches Pushbutton Selectors Type HW-C/HW-F /HW-G Rated Insulation Voltage 600V Rated Continuous Current 10A Contact Ratings by Utilization Category IEC 60947-5-1 AC-15 (A600) DC-13 (P600) Operational Voltage 24V AC 50/60 Hz Operational Current DC 48V 50V 110V 220V Relays & Sockets Characteristics CSA: pushbuttons and selector switches: A600 pilot lights and illuminated pushbuttons, direct supply pilot lights and illuminated pushbuttons with integral transformer (100/110, 115, 120, 200/220, 230, 240, 380, 400/440, 480V) UL: pushbuttons and selector switches: A600 pilot lights and illuminated pushbuttons, direct supply pilot lights and illuminated pushbuttons with integral transformer (100/110, 115, 120, 200/220, 230, 240, 380, 400/440, 480V) TÜV: pushbuttons and selector switches: A600=P600 (NO, NC)/Q600 (NO-EM, NC-LB) pilot lights and illuminated pushbuttons, direct supply pilot lights and illuminated pushbuttons with integral transformer (100/110, 115, 120, 200/220, 230, 240, 380, 400/440, 480V) Electric Shock Protection Terminal Referencing Switches & Pilot Lights Approvals File No. E68961 ø22mm - HW Series 440V AC-12 Control of resistive loads & solid state loads 10A — 10A 10A 6A 2A AC-15 Control of electromagnetic loads (> 72VA) 10A — 7A 5A 3A 1A DC-12 Control of resistive loads & solid state loads 8A 5A — 2.2A 1.1A — DC-13 Control of electromagnets 5A 2A — 1.1A 0.6A — For dimensions, see page 551. LED Lamp Ratings (LSTD Type) Model No. LSTD-6k LSTD-1k Rated Voltage 6V AC/DC Voltage Range Current Draw LSTD-2k LSTD-H2k LSTD-M4k 24V AC/DC 120V AC 240V AC BA9S/13 12V AC/DC 6V AC/DC ±10% 12V AC/DC ±10% 24V AC/DC ±10% 120V AC ±5% 240V AC ±5% AC A, R, W: G, S: 17mA 8mA 11mA 11mA 10mA 10mA DC A, R, W: G, S: 14mA 5.5mA 10mA 10mA – – A (amber), G (green), R (red), S (blue), W (white) Lamp Base Color Same as illumination color Voltage Marking Life (reference value) Die stamped on the base Approx. 50,000 hours (The luminance reduces to 50% the initial intensity when used on complete DC.) A, R, W A, R, W In place of k, specify the Lens/LED Color Code. Circuit Breakers Internal Circuit Terminal Blocks Color Code Timers Lamp Base G, S LED Chip Protection Diode Zener Diode USA: 800-262-IDEC Canada: 888-317-IDEC 501 Courtesy of Steven Engineering, Inc.-230 Ryan Way, South San Francisco, CA 94080-6370-Main Office: (650) 588-9200-Outside Local Area: (800) 258-9200-www.stevenengineering.com Oiltight Switches & Pilot Devices ø22mm - HW Series 2-Position Mono Lever Switches Description HW1M Standard Lever Relays & Sockets Display Lights Switches & Pilot Lights Mono Lever Switches 2-Position (Assembled) Timers HW1M-L Interlocking Lever Part Number Description HW1M-F1010-20 Maintained up and down Circuit Diagrams 2 Position Left/Right Circuit Number Contact Mounting No. Position Left Center Right HW1M-F2020-20 Spring return up and down HW1M-F1010-40 Maintained up and down 1 HW-F10 X 0 0 HW1M-F2020-40 Spring return up and down 2 HW-F10 0 0 X HW1M-F0101-20 Maintained right and left 1 HW-F10 X 0 0 HW1M-F0202-20 Spring return right and left 2 HW-F10 0 0 X HW-F10 X 0 0 HW-F10 0 0 X 20 40 HW1M-F0101-40 Maintained right and left 3 HW1M-F0202-40 Spring return right and left 4 HW1M-LF1010-20 Maintained up and down HW1M-LF2020-20 Spring return up and down HW1M-LF1010-40 Maintained up and down HW1M-LF2020-40 Spring return up and down HW1M-LF0101-20 Maintained right and left HW1M-LF0202-20 Spring return right and left HW1M-LF0101-40 Maintained right and left HW1M-LF0202-40 Spring return right and left 2 Position Up/Down Circuit Number 20 40 Position Down Center Up 1 HW-F10 X 0 0 2 HW-F10 0 0 X 1 HW-F10 X 0 0 2 HW-F10 0 0 X 3 HW-F10 X 0 0 4 HW-F10 0 0 X Circuit Breakers Terminal Blocks 1. All assembled part numbers in catalog include standard (HW-F...) contacts. 2. Assembled units with spring-up terminals (HW-G...) can be ordered by removing an “F” from the part number (Ex. HW1B-M1F11-R becomes HW1B-M111-R). 3. Units with exposed screw terminals (HW-C...) must be ordered as sub-components. 4. Additional contact configurations available (up to 6 total contacts). Contact Mounting No. 534 www.idec.com Courtesy of Steven Engineering, Inc.-230 Ryan Way, South San Francisco, CA 94080-6370-Main Office: (650) 588-9200-Outside Local Area: (800) 258-9200-www.stevenengineering.com Oiltight Switches & Pilot Devices ø22mm - HW Series Part Number Structure W 1 M - L F 0 1 0 1 20 up right down left blank: Standard L: Interlocking Switches & Pilot Lights H Type Circuit Number 20 or 40 (see contact arrangement on previous page) Lever Action 1: Maintained 2: Spring 0: Blocked Mono Lever Switches 2-Position (Sub-assembled) Part Numbers Adaptor & Safety Lever Lock + Contact Blocks + Operator = Completed Unit Anti-Rotation Ring Contacts 1NO 1NC Standard Fingersafe (IP20) HW-F10 HW-F01 HW-F10R (early make) HW-F01R (late break) HW-G10 HW-G01 HW-G10R (early make) HW-G01R (late break) HW-C10 HW-C01 Spring-Up Terminal HW-C10R (early make) Dummy Block Appearance HW-C01R (late break) TW-DB Part Number HW9Z-RL Use with notched panel cutout to prevent unit rotation. Operators Description Part Number Standard Maintained Up/Down HW1M-1010 Spring return Up/Down HW1M-2020 Maintained Left/Right HW1M-0101 Spring return Left/Right HW1M-0202 Maintained Up/Down HW1M-L1010 Spring return Up/Down HW1M-L2020 Maintained Left/Right HW1M-L0101 Spring return Left/Right HW1M-L0202 Interlocking Contact Block Mounting Adaptor Terminal Blocks Appearance Timers Exposed Screw Terminal Style Anti-Rotation Ring Relays & Sockets Style + Display Lights Contact Assembly Replacement Parts Part Number Item Part Number Black Cap HW-CB2C HW9Z-CPM Boot USA: 800-262-IDEC Circuit Breakers 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock (included) to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. HW9Z-BLM (fits standard operator only) Canada: 888-317-IDEC 535 Courtesy of Steven Engineering, Inc.-230 Ryan Way, South San Francisco, CA 94080-6370-Main Office: (650) 588-9200-Outside Local Area: (800) 258-9200-www.stevenengineering.com Oiltight Switches & Pilot Devices ø22mm - HW Series Dimensions (mm) Without Pilot Light Mounting Hole Layout R0.8 max. HW 0 49.4 (2 contacts) Without Button Locking Ring Markings 55 ∗∗ 69.4 (3 or 4 contacts) With Button Markings (I/ON and O/OFF) 30 ON 54.8 41.4 Display Lights +0.2 0 24.1 +0.4 0 .3 +0.4 Panel Thickness 0.8 to 6 Safety Lever Lock OFF Rubber Gasket 0.5 29.8 14.5 20 29.8 With Pilot Light Full Voltage The depth of a 3-contact model depends on the combination of contact blocks at top and bottom pushbuttons. Full Voltage Adapter HW Relays & Sockets ∗3.2 ø22 54.8 Switches & Pilot Lights Dual Pushbutton (Bottom Button) (Top Button) Top Button 1 contact block 2 contact blocks Bottom Button 2 contact blocks 1 contact block Depth 89.4 mm 69.4 mm -The 3.2 mm recess is for preventing rotation and is not necessary when a nameplate or anti-rotation ring is not used. -When using the safety lever lock, determine the vertical spacing in consideration of convenience for installing and removing the safety lever lock. -Recommended vertical spacing: 100 mm -The minimum mounting centers are applicable to switches with one layer of contact blocks (two contact blocks). When two layers of contact blocks are mounted, determine the minimum mounting centers for ease of wiring. 69.4 (2 contacts), 89.4 (4 contacts) (Note) Transfomer (240V minimum) Transformer (480V) Transformer HW HW Timers Transformer, DC-DC Converter 89.5 (2 contacts), 109.5 (4 contacts) Monolever Locking Ring CK ø3 LO 4. 2 Panel Thickness 0.8 to 6 41.4 25 M3.5 Terminal Screw Dimensions (mm) 8 29.4 556 24° 45.5 36 max. Circuit Breakers 72 24° 49.4 (2 blocks) 69.4 (4 blocks) 36 max. Terminal Blocks 79.5 (2 contacts), 99.5 (4 contacts) www.idec.com Courtesy of Steven Engineering, Inc.-230 Ryan Way, South San Francisco, CA 94080-6370-Main Office: (650) 588-9200-Outside Local Area: (800) 258-9200-www.stevenengineering.com
HW1M-F0202-20 价格&库存
很抱歉,暂时无法提供与“HW1M-F0202-20”相匹配的价格&库存,您可以联系我们找货
HW1M-F0202-20
  • 1+774.554841+99.97973
  • 5+675.675185+87.21632
  • 10+636.9800710+82.22155
  • 25+589.1375625+76.04602
  • 50+555.2748450+71.67502
  • 100+523.28772100+67.54611
库存:7
