FB1W-XW1E-BV422MR
FB1W-XW1E-BV422MR
    IDEC(日本和泉)
FB1W-XW1E-BV422MR 数据手册
Safety Overview ø22mm XW E-Stops.................................... 263 XW Series E-Stops Interlock Switches E-Stops Enabling Switches XW Series Safety Control Light Curtains AS-Interface Safety at Work www.IDEC.com/usa/estop Table of Contents LED Machine Lighting - Pg. 1 Automation & Sensing - Pg. 27 Safety - Pg. 255 Switching & Controls - Pg. 449 Index - Pg. 933 X Series E-Stops X Series E-Stops Overview Revolutionary “Safe Break Action” Design The IDEC Emergency Stop switches, the XA, XW, and XN series, include revolutionary new technology that will change the way E-Stop switches are designed. This “safe break action” concept provides greater levels of human safety and is the first of its kind in the world! Conventional E-Stop switches are designed with spring pressure on the Normally Closed (NC) contacts, keeping them in the closed position and allowing the machine to operate. Improper installation or excessive force to the stop button in an emergency may break or dislodge a vital part, causing the spring loaded contact to stay closed. This situation renders the E-Stop incapable of stopping the machine, and can lead to catastrophic events, personal injury and possible loss of life. Safe Break Action Design This one-of-a-kind “safe break action” design, found only in the IDEC XA, XW, and XN series, reverses the energy direction and uses the spring-pressure to assure that the NC contacts will open if the emergency switch is damaged or the contact blocks separate due to excessive force. The NC contacts will reliably open, even if they are welded, and stop the machine. Combined with IDEC quality, this is the E-Stop switch you want in a life threatening situation. Level 4 Safety XA, XW & XN Series, The Safe Break Action E-Stops! 1 Internal view while removing the contact block 2 3 Enabling Switches Operator Contact Block NC Contact Closed (On) NC Contact Open (Off) When the contact block is removed from the operator the main contact (NC) is forced to open (OFF). When removing the contact block, the cam provides a direct opening action to open the contact. IDEC’s new E-Stop switches are secured from the rear of the control panel so that the E-Stop cannot be removed from the front. Another unique feature of the XA & XW E-Stop switches is that either a push-turn or push-pull reset method can be used to reset the switches. This eliminates any possible confusion for operators when resetting the switch. The durability and quality of these new E-Stop switches make them extremely reliable. They can withstand the increased high stress caused by panic or a reaction to an emergency situation. Padlock E-Stops As shown in the diagram, upon latching a traditional E-stop, it is up to the technician to verify and confirm that the machine area is clear and there are no other technicians working before resetting the E-stop and turning on the machine. There is always a chance that the technician might miss someone in the work area before resetting the E-stop, potentially causing injury to that person. The solution is XN4E series padlock E-Stops, which allow technicians to install their personal padlocks at the spot of actuation of the E-Stop ensuring their own safety. The diagram shows how personal padlocks can be installed. Each one blocks the resetting of the E-stop until all the padlocks are removed. This provides added safety and prevents unauthorized or accidental resetting of the E-stops. A maximum of 20 padlocks can be installed by using lockout hasps. AS-Interface Safety at Work Light Curtains Safety Control Reach for the “Safe Break Action” The X Series of E-Stop switches include up to four contacts in a very compact package. In today’s automated world, more customers are requiring E-Stop switches with at least three contacts. (Two of the contacts trip the power and the third contact is used to alert a safetymonitoring relay.) Both the XA and XW series switches offer up to four “safe-break” contacts with a depth behind the panel that is half the size of conventional E-Stop switches. This means that there is an additional contact available and the switches can be used in Level 4 safety category applications. Press the button. When using as a general emergency stop switch Button Latched Safety Confirmed When preventing unauthorized resetting Install the padlock. Hasp can be used. 260 www.IDEC.com Turn the button to reset. Remove the padlock. Operation allowed Interlock Switches XW Series E-Stops Innovative Design X Series E-Stops X Series E-Stops Important Safety Information Overview X Series E-Stops have lower internal energy in the “Locked” (Latching) position than in the “Normal” (Reset) position. When the switch is damaged from an excessive shock, the main contact (NC) moves toward the OFF (Safe) position. Direct Opening Action XW Series E-Stops Even if the contacts are welded, the force applied on the button directly opens the contact. Rated Insulation Voltage: 250V Rated Thermal Current: 2.5A Safety Interlock Mechanism Contacts are opened when the operator is locked, and remain opened until the operator is unlocked intentionally. (IEC60947-5; 6:2) Interlock Switches Two E-Stops in One Pushlock Pull or Turn Reset Pull Reset Turn Reset Enabling Switches The X Series E-Stops can be reset either by pulling or turning the button. This ensures that the reset action will always be different from the make action. With traditional E-Stops, you need to choose between Push-Pull or Pushlock Turn Reset. With the IDEC X Series E-Stops you get both in one switch. XN4E, padlock type is Turn Reset only. Compact Body with Four Contacts Traditional E-Stop 22mm XW and 16mm XA Series Safety Control Compact XN Series 48.7mm Light Curtains 47.7 mm 27.9mm ~20mm AS-Interface Safety at Work 800-262-IDEC (4332) • USA & Canada 261 X Series E-Stops X Series E-Stops Interlock Switches XW Series E-Stops Overview Selection Guide Series XA XW XN see Switches & Pilot Devices section 263 see Switches & Pilot Devices section 16mm 22mm 30mm Appearance Page Mounting Hole Operator Type Illuminated & Non-Illuminated E-Stops: Pushlock/Turn Reset, Push-Pull Reset Action Pushlock Pull or Turn Reset (both actions available in each switch, except XN4E) Enabling Switches Contact Configuration 1NO - 1NC, 2NC, 1NO-3NC, 4NC Electrical Life 100,000 Minimum Mechanical Life 250,000 Minimum Termination Degree of Protection PCB & Solder Terminals Screw Terminals IP65 (IEC60529) Operator: IP65 (IEC60529) Terminal: IP20 (when XW9Z-VL2MF is installed) Approvals AS-Interface Safety at Work Light Curtains Safety Control XA series UL recognized. 262 www.IDEC.com XW Series E-Stops 22mm XW E-Stops 22mm XW E-Stops Overview Key features: 45 to 85% RH (no condensation) Storage Temperature –45 to +80°C Operating Force Push-to-lock: 32N Pull-to-reset: 21N Turn-to-reset: 0.27N·m Minimum Force Required for Direct Opening Action 80N Min Operator Stroke Required for Direct Opening Action 4mm Maximum Operator Stroke 4.5mm Contact Resistance 50mΩ maximum (initial value) Contact Material Gold plated silver Insulation Resistance 100MΩ minimum (500V DC megger) Impulse Withstand Voltage 2.5kV Pollution Degree 3 Operation Frequency 900 operations/hour Shock Resistance Operating extremes: 150m/s2 (15G), Damage limits: 1000m/s2 (100G) Vibration Resistance Operating extremes: 10 to 500Hz, amplitude 0.35mm acceleration 50m/s2 Damage limits: 10 to 500Hz, amplitude 0.35mm acceleration 50m/s2 Mechanical Life 250,000 operations minimum Electrical Life 100,000 operations minimum, (250,000 operations minimum @ 24V AC/DC, 100mA) Degree of Protection Operator: IP65 (IEC60529) Terminal: IP20 (when XW9Z-VL2MF is installed) Terminal Style M3.0 screw terminal Recommended Tightening Torque for Locking Ring 2.0N·m Wire Size 16 AWG max Weight ø40mm: 72g ø60mm: 81g 800-262-IDEC (4332) • USA & Canada AS-Interface Safety at Work Operating Humidity Light Curtains Non-illuminated: –25 to +60°C (no freezing), Illuminated: –25 to +55°C (no freezing) Safety Control IEC60947-5-1, EN60947-5-1, IEC60947-5-5, EN60947-5-5, UL508, UL991, CSA C22.2 No. 14 Operating Temperature CCC No. 2005010305150897 Enabling Switches Applicable Standards Interlock Switches UL File #E68961 Specifications XW Series E-Stops • The depth behind the panel is only 48.7 mm for 1 to 4 contacts (with terminal cover) for illuminated and non-illuminated units. • IDEC’s original “Safe break action” ensures that the NC contacts open when the contact block is detached from the operator. • 1 to 4NC main contacts and 1 or 2NO monitor contacts • Push-to-lock, Pull or Turn-to-reset operator • Safety lock mechanism (IEC60947-5-5, 6.2) • Degree of protection IP65 (IEC60529) • Fingersafe (IP20) terminals • Two button sizes: ø40 and ø60 mm • Push-ON illumination type available (40mm mushroom head) • Direct opening action mechanism (IEC60947-5-5, 5.2, IEC60947-5-1, Annex K) • RoHS compliant (EU directive 2002/95/EC). • UL c-UL listed. EN compliant • UL NISD category emergency stop device (File# E305148) 263 XW Series E-Stops 22mm XW E-Stops Part Numbers Overview Style Operator Type Monitor Contact Non-Illuminated XW Series E-Stops 40mm Mushroom 60mm Mushroom Illuminated 1 Interlock Switches 40mm Mushroom LED with built-in 24V AC/DC LED 40mm Mushroom Push-ON LED 2 Main Contact Part Number 1NO 1NC XW1E-BV411M-R – 2NC XW1E-BV402M-R 2NO 2NC XW1E-BV422M-R 1NO 3NC XW1E-BV413M-R – 4NC XW1E-BV404M-R 1NO 1NC XW1E-BV511M-R – 2NC XW1E-BV502M-R 2NO 2NC XW1E-BV522M-R 1NO 3NC XW1E-BV513M-R – 4NC XW1E-BV504M-R 1NO 1NC XW1E-LV411Q4M-R – 2NC XW1E-LV402Q4M-R 2NO 2NC XW1E-LV422Q4M-R 1NO 3NC XW1E-LV413Q4M-R – 4NC XW1E-LV404Q4M-R 1NO 2NC XW1E-TV412Q4M-R 1. The light is independent of the position of the switch, except for push-on LED type. 2. The light only operates when the switch is pressed as it is internally wired. Safety Control Enabling Switches XW Series EMO Switches Style NC Main Contact NO Monitor Contact Part Number 1NC - XW1E-BV401M-RH-EMO 40mm Mushroom 2NC - XW1E-BV402M-RH-EMO 3NC - XW1E-BV403M-RH-EMO 4NC - XW1E-BV404M-RH-EMO 1NC 1NO XW1E-BV411M-RH-EMO 2NC 1NO XW1E-BV412M-RH-EMO 3NC 1NO XW1E-BV413M-RH-EMO 2NC 2NO XW1E-BV422M-RH-EMO FB Enclosures with XW E-Stops Style Style Light Curtains 40mm Push-lock Turn/Pull Reset Non-Illuminated AS-Interface Safety at Work 40mm Push-lock Turn/Pull Reset Illuminated* 60mm Push-lock Turn/Pull Reset Non-Illuminated 264 NC Contact NO Contact Part Number 2NC – FB1W-XW1E-BV402MR 1NC 1NO FB1W-XW1E-BV411MR 2NC 2NO FB1W-XW1E-BV422MR 3NC 1NO FB1W-XW1E-BV413MR 4NC – FB1W-XW1E-BV404MR 2NC – FB1W-XW1E-LV402MR 1NC 1NO FB1W-XW1E-LV411MR 2NC 2NO FB1W-XW1E-LV422MR 3NC 1NO FB1W-XW1E-LV413MR 4NC – FB1W-XW1E-LV404MR 2NC – FB1W-XW1E-BV502MR 1NC 1NO FB1W-XW1E-BV511MR 2NC 2NO FB1W-XW1E-BV522MR 3NC 1NO FB1W-XW1E-BV513MR 4NC – FB1W-XW4E-BV504MR www.IDEC.com For added safety, Switch Guards and Nameplates can be used with E-Stop Enclosures *LED illumination voltage: 24V AC/DC XW Series E-Stops Contact Ratings Mounting Hole Layout Rated Current (Ith) 5A 5A 3A Inductive Load (AC-15) – 3A 1.5A Resistive Load (DC-12) 2A 0.4A 0.2A Inductive Load (DC-13) 1A 0.22A 0.1A Resistive Load (AC-12) – 1.2A 0.6A – 0.6A 0.3A Panel to 6 2AThickness 0.80.4A 0.2A Inductive Load (AC-14) Illuminated Resistive Load (DC-12) 20.1 Inductive Load (DC-13) 1A 0.22A Panel Cutout R0. ax. ø22 *4 *3 X1 *4 *3 *2 X1 R *4 *3 X2 TO P 11 12 41 • Contact Type 1-2: NC main contact 3-4: NO monitor contact • Contact Number (1-4) Starting with the contact on TOP in a counterclockwise direction. Note: 1: contact on the TOP 2: contact on the Left 3: contact on the Bottom 4: contact on the Right 22 *2 LED L X2 *4 L R 42 X2 R R Terminal Marking Description *2 L LED ∗1 *1 *2 *1 LED *3 *1 *2 R *4 L ∗4 X1 X2 *3 TOP *1 X1 *4 *3 *2 X2 *1 *2 *1 L *1 *3 R LED *3 TOP ∗3 *4 R TOP *4 Push-ON L *2 *4 1NO-2NC 21 *3 *2 *4 *3 *1 *1 X1 *2 *2 *2 *1 X2 R *1 *2 *1 *4 *3 L TOP LED L *2 *1 *1 R *2 *1 *2 *1 *3 *2 32 Voltage Code Blank: Non-illuminated Q4: Illuminated 24V AC/DC Light Curtains LED *1 TOP *1 R TOP *2 TOP *4 L *2 *1 *2 *4 TOP *2 *3 R Illuminated *2 *2 L *1 2NO-2NC TOP *2 *1 *2 *1 *2 1NO-1NC Color R: red RH-EMO: red with EMO engraving Safety Control *1 0.5 Enabling Switches TOP R 24.1 32 Terminal Arrangements (Bottom View) 4NC 1NO-3NC 2NC L Contact Configuration 11: 1NO - 1NC 02: 2NC 13: 1NO - 3NC Terminal 04: 4NC Cover 47.2 XW9Z-VL2M 48.7 22: 2NO-2NC Mushroom Size 12: 1NO-2NC (Push-ON 4: ø40mm LED only) 5: ø60mm 01: 1NC (EMO switch only) (non-illuminated only) 03: 3NC (EMO switch only) *1 48.7 XW9Z-VL2MF *2 Illumination B: Non-Illuminated L: Illuminated LED T: Illuminated Push-ON LED *1 1 - 4 contacts, both illuminated IP20 Protection Cover and non-illuminated TOP Gasket Locking Ring XW1E - L V 4 11 Q4M - R 37 48.7 Non-Illuminated M3 Terminal Screw Interlock Switches Description *1 Part Number Key 0.5 ø40 Depth (mm) X1 +0.4 0 +0.2 0 R Gasket Locking Ring 15mA Depth Behind the Panel L 3.2 R M3 Terminal Screw Current 24V AC/DC ±10% *1 Panel Thickness 0.8 to 6 8m 0.1A Panel Cut-out Illuminated Unit LED Ratings Push-ON 20.1 70mm min X Minimum applicable load: 5V AC/DC, 1mA (reference value). The rated operating currents are measured at resistive/inductive load types specified in IEC 60947-5-1. Operating Voltage18.5 22.3 X&Y +0.4 Y .3 40mm ∗2 18.5 – Resistive Load (AC-12) øA 37 AC 50/60Hz 250V ∗2 DC 125V ∗1 Main Monitor Contacts (NO) Contacts (NC) AC 50/60Hz 30V Size XW Series E-Stops Rated Operating Current Rated Operating Voltage (Ue) Measurements øA +0.4 0 250V Overview Rated Insulation Voltage (Ui) DC 22mm XW E-Stops 34 33 (Example: 1NO-3NC contact) AS-Interface Safety at Work 800-262-IDEC (4332) • USA & Canada 265 XW Series E-Stops 22mm XW E-Stops XW LED Illuminated/Push-ON (with terminal cover) Illuminated R0. ø22 8m ax. .3 +0.4 0 R0. 8 +0.218.5 3.2ma0x. ø22 .3 +0.4 Gasket M3 Terminal Locking Ring Screw 18.5 R0. ax. .3 Push-ON 0.5 18.5 3.2 +0.4 0 M3 M3Terminal Terminal Screw Screw 20.1 +0.2 0 Gasket Gasket LockingRing Ring Locking M3 Terminal Screw 0.5 ø40 47.2 48.7 37 37 37 37 +0.4 0 Interlock Switches ø40 32 32 Terminal Cover IP20 Protection Cover XW9Z-VL2M XW9Z-VL2MF 0 IP20 Protection Cover XW9Z-VL2MF ø6 0.5 48.7 32 47.2 48.7 32 ø40mm Button ø40mm Button ø60mm Button 32 EMO R0 .8 0.5 .8 x. ø2 2.3 3.2 0.5 +0.2 0 ø2 ma x. 2.3 +0 0 .4 3.2 +0.2 0 +0 0 .4 24.1+0.4 0 Enabling Switches R0 ma 24.1+0.4 0 32 Panel Cut-out 47.2 48.7 18.5 Panel Cut-out 47.2 48.7 32.2 M3 Terminal Screw Rubber Gasket 18.5 M3 Terminal Screw 20.1 32.2 Rubber Gasket Locking Ring Terminal Cover XW9Z-VL2MF Panel Thickness 0.8 to 6 Terminal Cover XW9Z-VL2M Accessories: Terminal Covers Locking Ring Panel Thickness 0.8 to 6 Accessories: Shrouds Description Light Curtains Appearance 21 37 21 ø4 ø4 0 0 20.1 37 Safety Control +0.4 0 +0.2 0 ø40 Terminal Cover XW9Z-VL2M Panel Cut-out Part Numbers Appearance Part Numbers Appearance HW9Z-KG1 40mm Mushroom Head SEMI S2-0703, 12.5.1 Compliant IP20 Fingersafe Cover XW9Z-VL2MF HW9Z-KG2 40mm, and 60mm Mushroom Head SEMI S2-0703, 12.5.1 & SEMATECH Compliant HW9Z-KG3 40mm Mushroom Head SEMI S2 Compliant (Approved by TUV) HW9Z-KG4 40mm Mushroom Head SEMI S2 Compliant (Approved by TUV) & SEMATECH Legend Part Number Inner Ø Outer Ø HWAV-0 22mm 60mm “Emergency Stop” HWAV-27 22mm 60mm (blank) HWAV5-0 22mm 80mm “Emergency Stop” HWAV5-27 22mm 80mm Use 60mm nameplates for 40mm mushroom buttons and 80mm nameplates for 60mm mushroom buttons. 266 Applicable Standards XW9Z-VL2M (blank) E-Stop Types Terminal Cover for contact block Accessories: Nameplates AS-Interface Safety at Work 3.2 Panel Cut-out ø6 0 ø40 Gasket Locking Ring 20.1 .3 Panel Cut-out 0.5 37 ø22 8m 24.1 XW Series E-Stops 20.1 LED Push-ON Type ax. R 24.1 R 18.5 8m +0.4 0 R Panel Cut-out R0. ø22 0 M3 Terminal Screw PanelThickness Thickness0.8 0.8toto6 6 Panel 20.1+0.2 3.2 0 24.1 Panel Thickness 0.8Thickness to 6 Panel 0.8 to 6 20.1 24.1 18.5 +0.4 0 XW Non-Illuminated (with terminal cover) +0.4 0 Overview Dimensions (mm) www.IDEC.com Terminal Cover XW9Z-VL2M XW Series E-Stops 22mm XW E-Stops Operating Instructions Installing the Contact Block First unlock the operator button. Grab the bayonet ring j and pull back the bayonet ring until the latch pin clicks k, then turn the contact block counterclockwise and pull out l. First unlock the operator button. Align the small t marking on the edge of the operator with the small s marking on the yellow bayonet ring. Hold the contact block, not the bayonet ring. Press the contact block onto the operator and turn the contact block clockwise until the bayonet ring clicks. k Turn counterclockwise Bayonet Ring q marking Overview Removing the Contact Block p marking XW Series E-Stops j Grab k Turn clockwise j Grab k Pull j Push Notes for installing the contact block Notes for removing the contact block Make sure that the bayonet ring is in the locked position. Check that the two projections on the bayonet ring are securely in place. Latched 2. While removing the contact block, do not exert excessive force, otherwise the switch may be damaged. Interlock Switches 1. When the contact block is removed, the monitor contact (NO contact) is closed. Unlatched Projections 3. An LED lamp is built into the contact block for illuminated pushbuttons. When removing the contact block, pull the contact block straight to prevent damage to the LED lamp. If excessive force is exerted, the LED lamp may be damaged and fail to light. Remove the locking ring from the operator and check that the rubber gasket is in place. Insert the operator from panel front into the panel hole. Face the side without thread on the operator with TOP marking upward, and tighten the locking ring using ring wrench MW9Z-T1 to a torque of 2.0 N·m maximum. Enabling Switches Wiring Panel Mounting The applicable wire size is 16 AWG maximum. Operator without thread TOP marking Safety Control Locking Ring Rubber Gasket Notes for Panel Mounting To prevent the XW emergency stop switch from rotating when resetting from the latched position, use of an anti-rotation ring (HW9Z-RL) or a nameplate is recommended. Light Curtains AS-Interface Safety at Work 800-262-IDEC (4332) • USA & Canada 267 XW Series E-Stops 22mm XW E-Stops IP20 Protection Terminal Cover XW9Z-VL2MF Overview Screw Terminal 1. Wire thickness: AWG18 to 16 To install the IP20 protection cover, align the TOP marking on the cover with the TOP marking on the contact block, and press the cover toward the contact block. 2. Tighten the M3 terminal screw to a tightening torque of 0.6 to 1.0 N·m. Installing and Removing Terminal Covers Enabling Switches Interlock Switches XW Series E-Stops XW9Z-VL2M (Press) To install the terminal cover, align the TOP marking on the terminal cover with the TOP marking on the contact block. Place the two projections on the bottom side of the contact block into the slots in the terminal cover. Press the terminal cover toward the contact block. TOP marking TOP marking TOP marking 1. 2. 3. 4. k Press the terminal cover Once installed, the XW9Z-VL2MF cannot be removed. The XW9Z-VL2MF cannot be installed after wiring. With the XW9Z-VL2MF installed, crimping terminals cannot be used. Make sure that the XW9Z-VL2MF is securely installed. IP20 protection cannot be achieved when installed loosely, and electric shocks may occur. Contact Bounce When the button is reset by pulling or turning, the NC main contacts will bounce. When pressing the button, the NO monitor contacts will bounce. j Place the projections on the contact block To remove the terminal cover, pull out the two latches on the top side of the terminal cover. Do not exert excessive force to the latches, otherwise the latches may break. TOP Markings Pull out the latches When designing a control circuit, take the contact bounce time into consideration (reference value: 20 ms). LED Illuminated Switches LED lamp is built into the contact block and cannot be replaced. Installing the Anti-rotation Ring HW9Z-RL Align the side without thread on the operator with TOP marking, the small s marking on the anti-rotation ring, and the recess on the mounting panel. Safety Control Without thread  marking on the anti-rotation ring TOP marking AS-Interface Safety at Work Light Curtains Anti-rotation Ring (HW9Z-RL) 268 www.IDEC.com
FB1W-XW1E-BV422MR 价格&库存
很抱歉,暂时无法提供与“FB1W-XW1E-BV422MR”相匹配的价格&库存,您可以联系我们找货
FB1W-XW1E-BV422MR
  • 1+820.71392
  • 5+802.18079
  • 10+783.64766
  • 25+746.49834
库存:12
