HG9Z-XCM2A
HG9Z-XCM2A
    IDEC(日本和泉)
HG9Z-XCM2A 数据手册
New Series High Performance OI Touchscreens Key Features 12.1” HG4G • New 5.7” Color TFT LCD Displays • New 8.4”, 10.4” and 12.1” Color TFT LCD Displays with Multi-Media • 65,536 Color LCD • High Resolution Display: 800 x 600 (8.4”, 10.4”, 12.1”) , 640 x 480 (5.7”) • Super Bright: up to 800cd/m2 • Mounts Portrait or Landscape • Remote Access, Monitor and Control • Audio and Video Interface (8.4”, 10.4”, 12.1”) • Supports Expansion I/O Modules • Serial, Ethernet and USB ports 8.4” HG3G 10.4” HG3G 5.7” HG2G Display Specifications 5.7" 8.4" 10.4" 12.1" Model HG2G-5FT22TF HG3G-8JT22MF HG3G-AJT22MF HG4G-CJT22MF Display Type Color TFT LCD Color TFT LCD Color TFT LCD Color TFT LCD Color Depth 65,536 65,536 65,536 65,536 √ √ √ √ Portrait or Landscape Mounting User Memory Display Resolution Backlight Backlight Life *1 12MB 12MB 12MB 12MB 640W × 480H pixels 800W × 600H pixels 800W × 600H pixels 800W × 600H pixels LED LED LED LED 50,000 hours 60,000 hours min. 60,000 hours min. 60,000 hours min. Brightness *2 800 cd/m2 600 cd/m2 700 cd/m2 550 cd/m2 Brightness Adjustment 48 scales 48 scales 48 scales 48 scales SD Card Slot √ √ √ √ MicroSmart Digital I/O Cards Supported 2 4 4 4 1 RJ-45 1 RJ-45 1 RJ-45 1 RJ-45 USB Port Ehternet Port 1 Type A & 1 mini-B 1 Type A & 1 mini-B 1 Type A & 1 mini-B 1 Type A & 1 mini-B Serial Ports 2 (RS-232, RS-485, RS-422 configurable) 2 (RS-232, RS-485, RS-422 configurable) 2 (RS-232, RS-485, RS-422 configurable) 2 (RS-232, RS-485, RS-422 configurable) Video In – Composite Video RCA connector (NTSC or PAL) Composite Video RCA connector (NTSC or PAL) Composite Video RCA connector (NTSC or PAL) Audio In/Out – 3.5mm audio mini-jack (Stereo) 3.5mm audio mini-jack (Stereo) 3.5mm audio mini-jack (Stereo) Remote Monitor & Control √ √ √ √ *1 The backlight life refers to the time until the surface brightness reduces by half after continuous use at 25°C. *2 Brightness of the LCD only. General Specifications Model Rated Power Voltage 5.7" 8.4" 10.4" 12.1" HG2G-5FT22TF HG3G-8JT22MF HG3G-AJT22MF HG4G-CJT22MF 24V DC 24V DC 24V DC Power Voltage Range 20.4 to 28.8V DC 20.4 to 28.8V DC 20.4 to 28.8V DC Power Consumption 19W maximum 10W maximum when not using USB interface (USB2) or expansion module interface (EXT) 25W maximum 15W maximum when not using USB interface (USB2) or expansion module interface (EXT) 27W maximum 18W maximum when not using USB interface (USB2) or expansion module interface (EXT) 10 ms maximum 10 ms maximum 10 ms maximum 30A maximum 30A maximum 30A maximum 1,000V AC, 10 mA, 1 minute between power and FG terminals 1,000V AC, 10 mA, 1 minute between power and FG terminals 1,000V AC, 10 mA, 1 minute between power and FG terminals 10 MΩ minimum between power and FG terminals (500V DC megger) 10 MΩ minimum between power and FG terminals (500V DC megger) 10 MΩ minimum between power and FG terminals (500V DC megger) 0 to +50°C (no freezing) 0 to 50°C (no freezing) 0 to +50°C (no freezing) 10 to 90% RH (no condensation) 10 to 90% RH (no condensation) 10 to 90% RH (no condensation) −20 to +60°C (no freezing) −20 to +60°C (no freezing) −20 to +60°C (no freezing) 10 to 90% RH (no condensation) 10 to 90% RH (no condensation) 10 to 90% RH (no condensation) Allowable Momentary Power Interruption Inrush Current Dielectric Strength Insulation Resistance Operating Temperature Operating Humidity Storage Temperature Storage Humidity Pollution Degree Vibration Resistance Shock Resistance Noise Immunity Electrostatic Discharge Corrosion Immunity Degree of Protection *1 Switching Element 2 2 2 5 to 8.4 Hz amplitude 3.5 mm, 8.4 to 150 Hz, acceleration 9.8 m/s2 10 cycles (100 minutes) on each of three mutually perpendicular axes 5 to 8.4 Hz amplitude 3.5 mm, 8.4 to 150 Hz, acceleration 9.8 m/s2 10 cycles (100 minutes) on each of three mutually perpendicular axes 5 to 8.4 Hz amplitude 3.5 mm, 8.4 to 150 Hz, acceleration 9.8 m/s2 10 cycles (100 minutes) on each of three mutually perpendicular axes 147 m/s2, 11 ms 5 shocks on each of three mutually perpendicular axes 147 m/s2, 11 ms 5 shocks on each of three mutually perpendicular axes 147 m/s2, 11 ms 5 shocks on each of three mutually perpendicular axes Fast transient/burst test, Power terminals: ±1 kV, Communication line: ±0.5 kV (IEC/EN61131-2: 2007) Fast transient/burst test, Power terminals: ±2 kV, Communication line: ±1 kV (IEC 61131-2: 2007) Fast transient/burst test, Power terminals: ±2 kV, Communication line: ±1 kV (IEC/EN61131-2: 2007) ESD-3 (RH-1), Level 3 (Contact ±6 kV, air ±8 kV) (IEC/EN61131-2: 2007) ESD-3 (RH-1), Contact ±6 kV, air ±8 kV (IEC 61131-2: 2007) ESD-3 (RH-1), Level 3 (Contact ±6 kV, air ±8 kV) (IEC/EN61131-2: 2007) Free from corrosive gases Free from corrosive gases Free from corrosive gases IP66 (IEC 60529) (front part when mounted) Type 4X, 13 IP66 (IEC 60529) (front part when mounted) TYPE 4X, 13 IP66 (IEC 60529) (front part when mounted) Type 4X, 13 Analog resistive membrane Analog resistive membrane Analog resistive membrane Operating Force 3N maximum Mechanical Life 1,000,000 operations 1,000,000 operations 1,000,000 operations Electronic buzzer Electronic buzzer or speaker output Electronic buzzer or speaker output Sound Acknowledgement Dimensions Weight (approx.) Approvals 0.55 to 2.3N 0.55 to 2.3N 3N maximum 167.2W × 134.7H × 54.4D mm 231W × 176H × 54.4D mm 270W × 212H × 52.7D mm 314W × 240H × 54.1D mm 0.65 kg 1.25 kg 1.65 kg 2.1 kg Safety Standards: UL508, CSA C22.2 No.142 Ship Classification Standards: ABS, LR, NK Safety Standards: UL508, CSA C22.2 No.142, CSA C22.2 No.213, ANSI/ISA-12.12.01-2007 Ship Classification Standards: ABS, LR, NK Do not use the touchscreen in an environment subject to strong ultraviolet rays, otherwise the LCD quality will deteriorate. *1 Protection degree of the front surface after mounting. Operation not guaranteed in certain environments. Safety Standards: UL508, CSA C22.2 No.142 Ship Classification Standards: ABS, LR, NK Touchscreen Part Numbers 5.7" 8.4" 10.4" 12.1" Light gray HG2G-5FT22TF-W HG3G-8JT22MF-W HG3G-AJT22MF-W – Black HG2G-5FT22TF-B HG3G-8JT22MF-B HG3G-AJT22MF-B HG4G-CJT22MF-B Silver HG2G-5FT22TF-S – – – Dimensions (mm) 5.7” HG2G-5FT22TF 8.4” HG3G-8JT22MF 49.4 167.2 40 152.5 32.6 35 20 55 163.5 176.0 50 40 30 35 11.4 Panel Cut-out 55 30 Panel Cut-out 219.0 +2.0 0 48.4 54.4 164.0 +2.0 0 6.0 38.2 40 5.0 121.0 +2.0 0 33.6 ※ 50 +2.0 0 54.4 153.0 218.5 15.2 231.0 120.0 134.7 40 10.4” HG3G-AJT22MF 12.1” HG4G-CJT22MF 30.9› 32.3› 10 257.5 10 240.0 6.0 48.1 54.1 226.5 +2.0 0 200.0 +2.0 0 37.9 301.5 +2.0 0 55 Panel Cut-out 30 46.7 52.7 50 6.0 36.5 258.0 +2.0 0 30 Panel Cut-out 55 50 11.4 11.4 212.0 199.5 44.4 301.0 44.4 314.0 227.0 270.0 Accessories Part Number Description Programming Software SW1A-W1C USB Maintenance Cable HG9Z-XCM2A Mounting Clip Host Communication Plug Applicable Model 5.7” 8.4” / 10.4” 12.1” Automation Organizer √ √ √ USB Programming Cable USB-miniB (2m) √ √ √ SLD-K02 Replacement clips (min. 10 pcs) (4 pcs are supplied with HMI) √ - - HG9Z-4K2 Replacement clips (min. 10 pcs) (4 pcs are supplied with HMI) - √ √ HG9Z-XT09V Replacement terminal block plug. (1 is supplied with HMI) √ - - HG9Z-XT09 Replacement terminal block plug. (1 is supplied with HMI) - √ √ Replacement Battery HG9Z-XR1 Lithium battery CR2032 (one battery is supplied with HMI) √ √ √ USB Cable Lock Pin HG9Z-XU1 Used to lock USB cable (for USB2). √ √ √ USB panel-mount extension cable HG9Z-XCE11 For USB-A port (1m) √ √ √ HG9Z-XCE21 For USB-mini B port (1m) √ √ √ Memory Card HG9Z-XMS2 SD Memory Card (2GB) √ √ √ Protective Cover HG9Z-2E2 Use with 5.7” HMI. Covers entire front of HMI. (min. 3 pcs) √ - - HG9Z-2D5 Use with 5.7" HMI. Sheet lays over LCD area. (min. 5 pcs) √ - - Protective Sheet *1 Expansion Module Clamp *2 L-shaped Terminal Block Connector for I/O Module Panel Mount Adaptor HG9Z-3D8 Use with 8.4” HMI. Sheet lays over LCD area. (min. 2 pcs) - √ - HG9Z-3DA2 Use with 10.4” HMI. Sheet lays over LCD area. (min. 2 pcs) - √ - HG9Z-4DC Use with 12.1” HMI. Sheet lays over LCD area. (min. 2 pcs) - - √ HG9Z-XJ3 Short type for installing expansion I/O modules (Total width 17.6 to 41.1mm) √ √ √ HG9Z-XJ4 Long type for installing expansion I/O modules (Total width 47 to 68.8mm) √ √ √ HG9Z-XJ5 Extra-Long type for installing expansion I/O modules (Total width 70.1 to 93.9mm) √ √ √ HG9Z-PMT10L For 10 pole MicroSmart I/O Module (min. 2 pcs) √ √ √ HG9Z-PMT11L For 11 pole MicroSmart I/O Module (min. 2 pcs) √ √ √ HG9Z-2A1 Adaptor for mounting HG2G to the panel cut-out of HG2F. √ - - HG9Z-2A2 Adaptor for mounting HG2G to 156 x 123.5 mm panel cut-out (other manufacturer). √ - - *1 The protective sheet is UV resistant, however, resistance against direct sunlight in outdoor usage is not guaranteed. *2 Use the expansion module clamp when using expansion modules. Order the module clamp by referring to the width of the module shown in the dimensions of each module. Note: When connecting more than 3 expansion modules to the HG3G/4G, note the limits shown below: -Current flow rate at 5V: 130 mA max. Total width: 92.3 mm max. -Current flow rate at 24V: 150 mA max. IDEC Corporation • 1175 Elko Drive • Sunnyvale, CA 94089 • 800-262-IDEC (4332) • Fax: 408-745-5258 • www.IDEC.com/usa ©2011 IDEC Corporation. All Rights Reserved. 07/11 PDF only.
HG9Z-XCM2A 价格&库存
很抱歉,暂时无法提供与“HG9Z-XCM2A”相匹配的价格&库存,您可以联系我们找货
HG9Z-XCM2A
  • 1+150.288041+19.53696
