CW4P-2EQ4G
CW4P-2EQ4G
    IDEC(日本和泉)
CW4P-2EQ4G 数据手册
Switches & Pilot Devices ø22 Flush Mount CW Switches & Pilot Devices Flush bezel projects only 2.5mm from front of panel and as little as 39.9mm behind the panel! Key features: • ø22.3mm mounting hole compliant with IEC 60947-5-1 • 3.5-mm operator travel for pushbuttons ensures comfortable and reliable operation • Up to 6 contacts per switch are possible with use of dual contact blocks • Black and metallic bezels available • Illuminated pushbuttons, pushbuttons, pilot lights, selector switches and key selector switches are available • Direct opening NC contact • Seven different keys can be chosen for key selector switches • 10A contact rating; up to three contact blocks for non-illuminated and two contact blocks for illuminated models can be connected • Contact blocks can be removed by locking lever • IP20 finger-safe screw terminals • UL Type 4X rating Signaling Lights Switches & Pilot Devices ø22mm - CW Series Relays & Sockets Applicable Standards Mark UL508 CSA C22.2 No.14 File No. or Organization UL/c-UL File No. E68961 TÜV SÜD EN60947-5-1 EC Low Voltage Directive Circuit Breakers Terminal Blocks Contactors Timers Specifications Contact Ratings Operating Temperature Non-illuminated: –25 to +60°C (no freezing) LED illuminated: –25 to +55°C (no freezing) Operating Humidity 45 to 85% RH (no condensation) Storage Temperature –40 to +80°C Contact Resistance 50 mΩ maximum (initial value) Insulation Resistance 100 MΩ minimum (500V DC megger) Overvoltage Category II (IEC 60664-1) Impulse Withstand Voltage 2.5 kV (IEC60664-1/60947-5-1) 3 (IEC60947-5-1) Vibration Resistance Operating extremes: 5 to 55Hz, amplitude 0.5 mm Shock Resistance Operating extremes: 100 m/s2 Damage limits: 1000 m/s2 Mechanical Life (minimum operations) Pushbutton, illuminated pushbutton: 2,000,000 Selector switch: 250,000 Key selector switch: 250,000 Electrical Life (minimum operations) 50,000 (see Contact Ratings) 100,000 (see Contact Ratings) (switching frequency 1800 operations/h) Degree of Protection (IEC60529) Panel front: IP65 Terminals: IP20 10A Rated Operating Voltage (Ue) 24V 120V 240V Resistive Load (AC-12) 10A 10A 6A Inductive Load (AC-15) 10A 6A 3A Resistive Load (DC-12) 8A 2.2A 1.1A Inductive Load (DC-13) 4A 1.1A 0.55A Resistive Load (AC-12) 5A 5A 3A Inductive Load (AC-15) 5A 3A 1.5A Resistive Load (DC-12) 4A 1.1A 0.55A Inductive Load (DC-13) 2A 0.55A 0.27A AC 50/60 Hz DC Rated Operating Current (Ie) Electrical Life 100,000 operations AC 50/60 Hz Contact Material Type 4X 250V/10A fuse, (Type aM IEC60269-1, IEC602069-2) Electrical Shock Protection Class II (IEC61140) Terminal Style Screw terminal (M3.5 slotted Phillips screw) Bezel Material Polyamide Applicable Wire Size Up to 2 wires of 2 mm2 (solid wire ø1.6) maximum (AWG14 to 16) (Ring terminal cannot be used) Recommended Tightening Torque Terminal: Locking ring: Rated Thermal Current (Ith) DC Short-circuit Protection 562 300V Electrical Life 50,000 operations Pollution Degree 1.0 to 1.3 N·m 1.2 N·m Rated Insulation Voltage (Ui) Silver 1. Minimum applicable load (reference value): 3V AC/DC, 5 mA (Applicable range is subject to the operating conditions and load.) 2. The operational current represents the classification by making and breaking currents (IEC 60947-5-1). 3. UL, c-UL rating: A300 Direct Opening of Key Selector Switch 2-position (3NC) 3-position (2NC) Operator Angle for Direct Opening Action 90° 45° Minimum Operator Torque for Direct Opening Action 0.2 N·m 0.3 N·m Maximum Operator Angle 90° 45° www.IDEC.com Switches & Pilot Devices ø22mm - CW Series Switches & Pilot Devices Weights Illuminated Pushbutton Pushbutton Pilot Light Selector Switch Key Selector Switch 46g (CW1L-M1E02QH, 2 contacts) 62g (CW1L-M1E22QH, 4 contacts) 45g (CW1B-M1E03, 3 contacts) 52g (CW1B-M1E22, 4 contacts) 27g (CW1P-1EQH) 48g (CW1S-2E03, 3 contacts) 55g (CW1S-2E22, 4 contacts) 61g (CW1K-2AE03, 3 contacts) 68g (CW1K-2AE22, 4 contacts) Signaling Lights LED Module Rated Insulation Voltage (Ui) 250V Rated Operating Voltage (Ue) 6V AC/DC 12V AC/DC Operating Voltage Range 6V AC/DC±10% 12V AC/DC±10% 24V AC/DC 100/120V AC 230/240V AC 24V AC/DC±10% 100/120V AC±10% 230/240V AC±10% A (amber), G (green), PW (white), R (red), S (blue) Illumination Color Code k CW-EAQ2k CW-EAQ3k CW-EAQ4k CW-EAQHk CW-EAQM4k 15 mA 15 mA 16.5 mA 18 mA 18 mA Life (reference value) Relays & Sockets LED Module Part Number Current Draw Approx. 30,000 hours R X1 R X1 LED Chip Internal Circuit R Rectifying Diode X2 Resistor X2 R R Zener Diode C LED Chip Rectifying Diode Zener Diode Resistor Capacitor Timers 1. Specify an illumination color code in place of k in the part number. 2. Use the white (PW) LED module for yellow illumination. Contact Blocks Contact Block Single Contact Block Double Contact Block Contact 1NO 1NC 2NO 2NC 1NO-1NC Part No. YW-E10R YW-E01 YW-EW2R0 YW-EW02 YW-EW1R1 Housing Color Blue/Black Reddish Purple Blue/Black Reddish Purple Reddish Purple/Blue Push Rod Color Black Red Terminal No. 3-4 Black 1st tier: 13-14 2nd tier: 23-24 1-2 Weight (approx.) Red 1st tier: 11-12 2nd tier: 21-22 19g 11g Contactors Shape Gray 1st tier: (NO) 13-14 2nd tier: (NC) 21-22 IP67 UL Type 4X Illuminated Pushbutton Yes Yes * Yes * Yes * Pilot Light Yes Yes No Yes Pushbutton Yes Yes * Yes * Yes * Selector Switch Yes Yes Yes Yes Key Selector Switch Yes Yes No Yes 3.2 +0.2 0 R0.8 max. ø22 .3 +0.4 0 24.1+0.4 0 IP66 50 IP65 Circuit Breakers Rating Terminal Blocks Mounting Hole Layout IEC 60947-5-1 compliant Degree of Protection *When used with rubber boot (CW9Z-D11, -D12) 30 800-262-IDEC (4332) • USA & Canada Note: Determine mounting centers to ensure proper spacing. 563 Switches & Pilot Devices Switches & Pilot Devices ø22mm - CW Series Illuminated Pushbuttons (Assembled) Operating Voltage Style 6V AC/DC CW4L-1E10Q2k CW4L-1E01Q2k CW4L-1E11Q2k CW4L-1E20Q2k CW4L-1E02Q3k CW4L-1E22Q2k 12V AC/DC 1NO 1NC 1NO-1NC 2NO 2NC 2NO-2NC CW1L-1E10Q3k CW1L-1E01Q3k CW1L-1E11Q3k CW1L-1E20Q3k CW1L-1E02Q3k CW4L-1E10Q3k CW4L-1E01Q3k CW4L-1E11Q3k CW4L-1E20Q3k CW4L-1E02Q3k 24V AC/DC 1NO 1NC 1NO-1NC 2NO 2NC 2N0-2NC CW1L-1E10Q4k CW1L-1E01Q4k CW1L-1E11Q4k CW1L-1E20Q4k CW1L-1E02Q4k CW1L-1E22Q4k CW4L-1E10Q4k CW4L-1E01Q4k CW4L-1E11Q4k CW4L-1E20Q4k CW4L-1E02Q4k CW4L-1E22Q4k 100/120V AC 1NO 1NC 1NO-1NC 2NO 2NC 2N0-2NC CW1L-1E10QHk CW1L-1E01QHk CW1L-1E11QHk CW1L-1E20QHk CW1L-1E02QHk CW1L-1E22QHk CW4L-1E10QHk CW4L-1E01QHk CW4L-1E11QHk CW4L-1E20QHk CW4L-1E02QHk CW4L-1E22QHk 230/240V AC 1NO 1NC 1NO-1NC 2NO 2NC 2N0-2NC CW1L-1E10QM4k CW1L-1E01QM4k CW1L-1E11QM4k CW1L-1E20QM4k CW1L-1E02QM4k CW4L-1E22QM4k CW4L-1E10QM4k CW4L-1E01QM4k CW4L-1E11QM4k CW4L-1E20QM4k CW4L-1E02QM4k CW4L-1E22QM4k 6V AC/DC 1NO 1NC 1NO-1NC 2NO 2NC 2N0-2NC CW1L-2E10Q2k CW1L-2E01Q2k CW1L-2E11Q2k CW1L-2E20Q2k CW1L-2E02Q2k CW1L-2E22Q2k CW4L-2E10Q2k CW4L-2E01Q2k CW4L-2E11Q2k CW4L-2E20Q2k CW4L-2E02Q2k CW4L-2E22Q2k 12V AC/DC 1NO 1NC 1NO-1NC 2NO 2NC 2N0-2NC CW1L-2E10Q3k CW1L-2E01Q3k CW1L-2E11Q3k CW1L-2E20Q3k CW1L-2E02Q3k CW1L-2E22Q3k CW4L-2E10Q3k CW4L-2E01Q3k CW4L-2E11Q3k CW4L-2E20Q3k CW4L-2E02Q3k CW4L-2E22Q3k 24V AC/DC 1NO 1NC 1NO-1NC 2NO 2NC 2N0-2NC CW1L-2E10Q4k CW1L-2E01Q4k CW1L-2E11Q4k CW1L-2E20Q4k CW1L-2E02Q4k CW1L-2E22Q4k CW4L-2E10Q4k CW4L-2E01Q4k CW4L-2E11Q4k CW4L-2E20Q4k CW4L-2E02Q4k CW4L-2E22Q4k 100/120V AC 1NO 1NC 1NO-1NC 2NO 2NC 2N0-2NC CW1L-2E10QHk CW1L-2E01QHk CW1L-2E11QHk CW1L-2E20QHk CW1L-2E02QHk CW1L-2E22QHk CW4L-2E10QHk CW4L-2E01QHk CW4L-2E11QHk CW4L-2E20QHk CW4L-2E02QHk CW4L-2E22QHk 230/240V AC 1NO 1NC 1NO-1NC 2NO 2NC 2N0-2NC CW1L-2E10QM4k CW1L-2E01QM4k CW1L-2E11QM4k CW1L-2E20QM4k CW1L-2E02QM4k CW1L-2E22QM4k CW4L-2E10QM4k CW4L-2E01QM4k CW4L-2E11QM4k CW4L-2E20QM4k CW4L-2E02QM4k CW4L-2E22QM4k Signaling Lights Relays & Sockets Timers (metallic bezel) Contactors Terminal Blocks Circuit Breakers (metallic bezel) 564 Metallic Bezel CW1L-1E10Q2k CW1L-1E01Q2k CW1L-1E11Q2k CW1L-1E20Q2k CW1L-1E02Q2k CW1L-1E22Q2k (black bezel) (black bezel) Black Bezel 1NO 1NC 1NO-1NC 2NO 2NC 2N0-2NC Round Flush CW0L-01 Round Extended CW0L-02 Contact Configuration www.IDEC.com Illumination Color Code k A: G: PW: R: S: Y: amber green white red blue yellow A: G: PW: R: S: Y: amber green white red blue yellow 1. Specify an illumination color code in place of k in the Part Number. 2. Specify function code in place of  in the Part Number. M: momentary, A: maintained 3. See page 578 for dimensions. 4. See next page for replacement LED modules. 5. A dummy block is installed when one contact block is used. 6. Additional contact configurations available, contact IDEC for more details Switches & Pilot Devices ø22mm - CW Series Switches & Pilot Devices Illuminated Pushbuttons (Sub-assembled) Contact Blocks + LED Module + Mounting Adapter Style + Lens = Operators Contacts Contact Contact Part Block Configuration Number YW-E10R 1NC YW-E01 2NO YW-EW2R0 Round Flush Finger-safe Screw terminal Double 2NC Round Extended Round Flush CW-DB Round Extended LED Module Part Number CW-EAQ kj Round Extended CW1L-A20 CW4L-A20 Code Amber A Green G Red R Blue S White* PW or C Yellow Y *Use PW for LED module, use C for lens. CW9Z-L11j Voltage Code 6V AC/DC 2 12V AC/DC 3 24V AC/DC 4 100/120V AC H 230/240V AC M4 CW9Z-L12j 1. In place of j, specify the Lens/LED Color Code from table. Contactors 1. In place of j, specify the Lens/LED Color Code from table. 2. In place of k, specify the Voltage Code from table. 3. Use PW LED for yellow lens. CW4L-A10 Color Timers Round Flush Part Number CW1L-A10 j Lens/LED Color Code k Voltage Code Lens Style CW1L-M20 CW4L-M20 Maintained YW-EW1R1 Dummy block CW1L-M10 CW4L-M10 Momentary YW-EW02 1N0-1NC Metallic Bezel Completed Unit Relays & Sockets 1NO Black Bezel Style Single Style Operator Signaling Lights Contact Blocks + Contact Block Mounting Adaptor Style Part Number Terminal Blocks CW-CN Circuit Breakers 800-262-IDEC (4332) • USA & Canada 565 Switches & Pilot Devices Signaling Lights Switches & Pilot Devices ø22mm - CW Series Non-Illuminated Pushbuttons (Assembled) Contact Configuration Style Round Flush CW0B-01 (black bezel) Relays & Sockets Round Extended CW0B-02 1NO CW1B-1E10j CW4B-1E10j CW1B-1E01j CW4B-1E01j 1NO-1NC CW1B-1E11j CW4B-1E11j 2NO CW1B-1E20j CW4B-1E20j 2NC CW1B-1E02j CW4B-1E02j 2NO-1NC* CW1B-M1E21j CW4B-M1E21j 1NO-2NC* CW1B-M1E12j CW4B-M1E12j 3NO* CW1B-M1E30j CW4B-M1E30j 3NC* CW1B-M1E03j CW4B-M1E03j 2NO-2NC CW1B-1E22j CW4B-1E22j 1NO CW1B-2E10j CW4B-2E10j 1NC CW1B-2E01j CW4B-2E01j 1NO-1NC CW1B-2E11j CW4B-2E11j 2NO CW1B-2E20j CW4B-2E20j 2NC CW1B-2E02j CW4B-2E02j 2NO-1NC* CW1B-M2E21j CW4B-M2E21j 1NO-2NC* CW1B-M2E12j CW4B-M2E12j 3NO* CW1B-M2E30j CW4B-M2E30j 3NC* CW1B-M2E03j CW4B-M2E03j 2NO-2NC CW1B-M2E22j CW4B-2E22j Button Color Code j B: G: R: S: W: Y: black green red blue white yellow 1. Specify a button color code in place of j in the part number. 2. Specify function code in place of  in the Part Number. M: momentary, A: maintained 3. See page 579 for dimensions. 4. Two or one dummy block is installed when one or two contact blocks are used, respectively. 5. *These contact configurations are not available in maintained action 6. Additional contact configurations available; contact IDEC for more details. Non-Illuminated Pushbuttons (Sub-assembled) Contact Blocks Contactors Metallic Bezel 1NC Timers (metallic bezel) Black Bezel Contact Blocks Style Contacts + Mounting Adaptor Contact Contact Part Block Configuration Number 1NO Terminal Blocks Double Dummy block Operator 1NC YW-E01 2NO YW-EW2R0 2NC YW-EW02 1N0-1NC YW-EW1R1 CW-DB = Completed Unit Operators* j Button Color Code Style Black Bezel Round Flush YW-E10R Single Finger-safe Screw terminal + CW1B-M1j Metallic Bezel CW4B-M1j Momentary Round Extended CW1B-M2j CW4B-M2j Round Flush CW1B-A1j CW4B-A1j Round Extended CW1B-A2j CW4B-A2j Maintained 1. Specify a button color code in place of j. 2. *Operator button is not removable from operator. Code Black B Green G Red R Blue S White W Yellow Y Contact Block Mounting Adaptor Style Circuit Breakers Color Part Number CW-CN 566 www.IDEC.com Switches & Pilot Devices ø22mm - CW Series Switches & Pilot Devices Pilot Lights (Assembled) Black Bezel Metallic Bezel Round Flush Lens CW0P-1 6V AC/DC CW1P-1EQ2k CW4P-1EQ2k 12V AC/DC CW1P-1EQ3k CW4P-1EQ3k 24V AC/DC CW1P-1EQ4k CW4P-1EQ4k 100/120V AC CW1P-1EQHk CW4P-1EQHk (black bezel) 230/240V AC CW1P-1EQM4k CW4P-1EQM4k Round Dome Lens CW0P-2 6V AC/DC CW1P-2EQ2k CW4P-2EQ2k 12V AC/DC CW1P-2EQ3k CW4P-2EQ3k 24V AC/DC CW1P-2EQ4k CW4P-2EQ4k 100/120V AC CW1P-2EQHk CW4P-2EQHk 230/240V AC CW1P-2EQM4k CW4P-2EQM4k (metallic bezel) Illumination Color Code k A: G: R: S: PW: Y: amber green red blue white yellow 1. Specify an illumination color code in place of k in the Part Number 2. See page 579 for dimensions. 3. See page 577 for replacement LED modules. 4. Two dummy blocks are installed. Relays & Sockets Operating Voltage Signaling Lights Style Pilot Lights (Sub-assembled) Contact Blocks* + LED Module + Mounting Adapter + Operator + Lens = Completed Unit Timers * 2 dummy blocks are required for each completed pilot light. Contact Block Contacts Dummy Block Part Number Style Part Number Lens Style Part Number CW-DB CW-CN LED Module Style Part Number Round Dome CW9Z-L15j Black Bezel CW1P-00 Metallic Bezel CW4P-00 j Lens/LED Color Code Terminal Blocks 1. In place of j, specify the Lens/LED Color Code from table. 2. In place of k, specify the Voltage Code from table. 3. Use PW LED for yellow lens. Style CW9Z-L11j 1. In place of j, specify the Lens/LED Color Code from table. Operators CW-EAQ kj Round Flush Contactors Style Contact Block Mounting Adaptor k Voltage Code Code Code 6V AC/DC 2 Amber A 12V AC/DC 3 Green G 24V AC/DC 4 Red R 100/120V AC H Blue S 230/240V AC M4 White* PW or C Yellow Y Circuit Breakers Voltage Color *Use PW for LED module, use C for lens. 800-262-IDEC (4332) • USA & Canada 567 Switches & Pilot Devices Switches & Pilot Devices ø22mm - CW Series Selector Switches (Assembled) CW0S (Knob Operator) Shape (black bezel) Signaling Lights No. of Positions Contact Configuration 1NO (10) Relays & Sockets 1NC (01) 1NO-1NC (11) 2NO (20) Timers 90° 2-position 2NC (02) 2NO-1NC (21) 1NO-2NC (12) Contactors 3NO (30) 3NC (03) Contact Block Terminal Blocks Circuit Breakers 4NO (40) Type 1 NO 2 — L R Dummy L R L R Maintained Spring return from right CW0S-2E10 CW0S-21E10 3 — Dummy 1 — Dummy 2 — Dummy CW0S-2E01 CW0S-21E01 Dummy CW0S-2E11 CW0S-21E11 Dummy CW0S-2E20 CW0S-21E20 Dummy CW0S-2E02 CW0S-21E02 CW0S-2E21 CW0S-21E21 CW0S-2E12 CW0S-21E12 CW0S-2E30 CW0S-21E30 CW0S-2E03 CW0S-21E03 Dummy CW0S-2E22 CW0S-21E22 Dummy CW0S-21E40 CW0S-21E40 3 NC 1 NO 2 — 3 NC 1 NO 2 — 3 NO 1 NC 2 — 3 NC 1 NO 2 NO 3 NC 1 NO 2 NC 3 NC 1 NO 2 NO 3 NO 1 NC 2 NC 3 NC NC NO/ NC NC 2 — 3 NO/ NO NC NC 1 2NO 2 3 568 Operator Position Mounting Position 1 2NO-2NC (22) (metallic bezel) NO NO — 2NO NO NO www.IDEC.com Switches & Pilot Devices ø22mm - CW Series Switches & Pilot Devices Selector Switches (Assembled) con’t No. of Positions Contact Configuration 1NO-1NC (11) 1NO-1NC (11N2) 1NO-1NC (11N3) 2NO (20) 2NO (20N1) 2NC (02) 2NC (02N1) 2NO-1NC (21) 1NO-2NC (12) 3NO (30) 3NC (03) — NC NC — 3 NO 1 NO 2 NC 3 1 — — 2 NC 3 NO 1 — 2 NO 3 NC 1 NO 2 — 3 NO 1 — 2 NO 3 NO 1 2 3 1 NC — NC — 2 NC 3 NC 1 NO 2 NO 3 NC 1 NO 2 NC 3 NO 1 NO 2 NC 3 1 NC NC 2 NO 3 NC 1 NO 2 NO 3 NO 1 NC 2 NC 3 NC C R L C R L C R Maintained Spring return from right Spring return from left Spring return two-way Dummy CW0S-3E11 CW0S-31E11 CW0S-32E11 CW0S-33E11 Dummy CW0S-3E11N1 CW0S-31E11N1 CW0S-32E11N1 CW0S-33E11N1 CW0S-3E11N2 CW0S-31E11N2 CW0S-32E11N2 CW0S-33E11N2 CW0S-3E11N3 CW0S-31E11N3 CW0S-32E11N3 CW0S-33E11N3 CW0S-3E11N4 CW0S-31E11N4 CW0S-32E11N4 CW0S-33E11N4 CW0S-3E20 CW0S-31E20 CW0S-32E20 CW0S-33E20 CW0S-3E20N1 CW0S-31E20N1 CW0S-32E20N1 CW0S-33E20N1 CW0S-3E02 CW0S-31E02 CW0S-32E02 CW0S-33E02 CW0S-3E02N1 CW0S-31E02N1 CW0S-32E02N1 CW0S-33E02N1 CW0S-3E21 CW0S-31E21 CW0S-32E21 CW0S-33E21 CW0S-3E21N1 CW0S-31E21N1 CW0S-32E21N1 CW0S-33E21N1 CW0S-3E12 CW0S-31E12 CW0S-32E12 CW0S-33E12 CW0S-3E12N1 CW0S-31E12N1 CW0S-32E12N1 CW0S-33E12N1 CW0S-3E30 CW0S-31E30 CW0S-32E30 CW0S-33E30 CW0S-3E03 CW0S-31E03 CW0S-32E03 CW0S-33E03 C R Dummy Dummy Dummy Dummy Dummy Dummy Dummy Terminal Blocks 1NO-2NC (12N1) NO 2 3 1 2 L Contactors 2NO-1NC (21N1) 1 L R Timers 45° 3-position Type C Relays & Sockets 1NO-1NC (11N4) Mounting Position L Signaling Lights 1NO-1NC (11N1) Operator Position Contact Block Circuit Breakers 800-262-IDEC (4332) • USA & Canada 569 Switches & Pilot Devices Switches & Pilot Devices ø22mm - CW Series Selector Switches (Assembled) con’t No. of Positions Contact Configuration Mounting Position 1 2NO-2NC (22) 1 45° 3-position 4NO (40) 2NO-2NC (22N2) Type NO/ NC 2 3 Relays & Sockets Signaling Lights Operator Position Contact Block NO/ NC 2NO 2NO 1 2NC 2 C R R Spring return from left Spring return two-way Dummy CW0S-3E22 CW0S-31E22 CW0S-32E22 CW0S-33E22 Dummy CW0S-3E40 CW0S-31E40 CW0S-32E40 CW0S-33E40 Dummy CW0S-3E22N2 CW0S-31E22N2 CW0S-32E22N2 CW0S-33E22N2 NO NC NC NC NC Contact Block Mounting Position Timers C Spring return from right Left Center Right L NO 2 NC 3 NC Terminal Blocks Contactors 1 C Circuit Breakers L NO 1 2 3 570 R NC Lever Operator CW4S-0L (metallic bezel) C Maintained 1. Specify a bezel color code in place of 0 in the Part Number, 1 (black bezel), 4 (metallic bezel) 2. For the contact block mounting position, see below. 3. Lever operator is also available. For dimensions, see page 579. 4. To order a lever operator selector switch, insert L before E in the knob operator part number. Example: Knob Operator part number CW1S-3E11 becomes CW1S-3LE11 for Lever Operator. CW1S-0L (black bezel) L NO NO — 2NO R L R NO — 3 C C NO NC — 2 3 L L www.IDEC.com R Operator Position Switches & Pilot Devices ø22mm - CW Series Switches & Pilot Devices Selector Switches (Sub-assembled) Contact Block + Mounting Adaptor + Operator = Completed Unit Signaling Lights Contact Blocks Style Contact Contact Part Block Configuration Number Contacts 1NO YW-E10R 1NC YW-E01 2NO YW-EW2R0 2NC YW-EW02 1N0-1NC YW-EW1R1 Single Double Dummy block Relays & Sockets Finger-safe Screw terminal CW-DB Contact Block Mounting Adaptor Part Number Timers Style CW-CN Contactors Operators Style Position Handle Knob 2 position Lever 3 position (knob operator shown) Lever Metallic Bezel Maintained CW1S-2 CW4S-2 Spring return from right CW1S-21 CW4S-21 Maintained CW1S-2L CW4S-2L Spring return from right CW1S-21L CW4S-21L Maintained CW1S-3 CW4S-3 Spring return from right CW1S-31 CW4S-31 Spring return from left CW1S-32 CW4S-32 Spring return two-way CW1S-33 CW4S-33 Maintained CW1S-3L CW4S-3L Spring return from right CW1S-31L CW4S-31L Spring return from left CW1S-32L CW4S-32L Spring return two-way CW1S-33L CW4S-33L Circuit Breakers Black Bezel Terminal Blocks Knob Description Lever or knob is supplied with operator. 800-262-IDEC (4332) • USA & Canada 571 Switches & Pilot Devices Switches & Pilot Devices ø22mm - CW Series Key Selector Switches (Assembled) CW0K Shape (black bezel) Signaling Lights Contact Block No. of Positions Contact Configuration 1NO (10) Relays & Sockets 1NC (01) 1NO-1NC (11) 2NO (20) 2NC (02) Timers 2NO-1NC (21) 90° 2-position 1NO-2NC (12) Contactors 3NO (30) 3NC (03) Terminal Blocks 2NO-2NC (22) 4NO (40) (metallic bezel) Operator Position L Mounting Position Type 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 NO — — — — NC NO — NC NO — NO NC — NC NO NO NC NO NC NC NO NO NO NC NC NC 1 NO/NC 2 NO/NC 1 2NO 2 Dummy Dummy Dummy Dummy CW0K-2AE10 CW0K-21BE10 CW0K-2AE01 CW0K-21BE01 Dummy CW0K-2AE11 CW0K-21BE11 Dummy CW0K-2AE20 CW0K-21BE20 Dummy CW0K-2AE02 CW0K-21BE02 CW0K-2AE21 CW0K-21BE21 CW0K-2AE12 CW0K-21BE12 CW0K-2AE30 CW0K-21BE30 CW0K-2AE03 CW0K-21BE03 Dummy CW0K-2AE22 CW0K-21BE22 Dummy CW0K-2AE40 CW0K-21BE40 NO NC NO NC NO NO — 2NO 572 R Spring return from right R NO NO Circuit Breakers 3 L Maintained L — 3 R www.IDEC.com Switches & Pilot Devices ø22mm - CW Series Switches & Pilot Devices Key Selector Switches (Assembled) con’t No. of Positions Contact Configuration 1NO-1NC (11) 1NO-1NC (11N2) 1NO-1NC (11N3) 2NO (20) 2NO (20N1) 2NC (02) 2NC (02N1) 2NO-1NC (21) 1NO-2NC (12) 3NO (30) 3NC (03) R L C R L C R Maintained Spring return from right Spring return from left Spring return two-way Dummy CW0K-3AE11 CW0K-31BE11 CW0K-32CE11 CW0K-33DE11 Dummy CW0K-3AE11N1 CW0K-31BE11N1 CW0K-32CE11N1 CW0K-33DE11N1 CW0K-3AE11N2 CW0K-31BE11N2 CW0K-32CE11N2 CW0K-33DE11N2 CW0K-3AE11N3 CW0K-31BE11N3 CW0K-32CE11N3 CW0K-33DE11N3 CW0K-3AE11N4 CW0K-31BE11N4 CW0K-32CE11N4 CW0K-33DE11N4 CW0K-3AE20 CW0K-31BE20 CW0K-32CE20 CW0K-33DE20 CW0K-3AE20N1 CW0K-31BE20N1 CW0K-32CE20N1 CW0K-33DE20N1 CW0K-3AE02 CW0K-31BE02 CW0K-32CE02 CW0K-33DE02 CW0K-3AE02N1 CW0K-31BE02N1 CW0K-32CE02N1 CW0K-33DE02N1 C R 1 NO 2 3 1 2 NC — — NC 3 1 2 3 1 2 3 1 2 NO — NO NC NO — NO — NO 3 1 2 3 1 2 3 1 NO NC — NC — NC NC NO 2 3 1 NO NC NO CW0K-3AE21 CW0K-31BE21 CW0K-32CE21 CW0K-33DE21 2 NC CW0K-3AE21N1 CW0K-31BE21N1 CW0K-32CE21N1 CW0K-33DE21N1 3 NO 1 NO 2 3 1 2 3 1 NC NC NC NO NC NO CW0K-3AE12 CW0K-31BE12 CW0K-32CE12 CW0K-33DE12 CW0K-3AE12N1 CW0K-31BE12N1 CW0K-32CE12N1 CW0K-33DE12N1 2 NO CW0K-3AE30 CW0K-31BE30 CW0K-32CE30 CW0K-33DE30 3 1 2 3 NO NC NC NC CW0K-3AE03 CW0K-31BE03 CW0K-32CE03 CW0K-33DE03 Dummy Dummy Dummy Dummy Dummy Dummy Dummy Terminal Blocks 1NO-2NC (12N1) NO — NC NC — NO C Contactors 2NO-1NC (21N1) 1 2 3 1 2 3 L L R Timers 45° 3-position Type C Relays & Sockets 1NO-1NC (11N4) Mounting Position L Signaling Lights 1NO-1NC (11N1) Operator Position Contact Block Circuit Breakers 800-262-IDEC (4332) • USA & Canada 573 Switches & Pilot Devices Switches & Pilot Devices ø22mm - CW Series Key Selector Switches (Assembled) con’t Operator Position Contact Block No. of Positions Contact Configuration Mounting Position 1 Signaling Lights 2NO-2NC (22) 1 Relays & Sockets 90° 2-position 2NO-2NC (22N2) NO/NC 2 3 4NO (40) Type NO/NC 2NO 2NO 1 2NC 2 Timers Contactors L C R Spring return two-way Dummy CW0K-3AE22 CW0K-31BE22 CW0K-32CE22 CW0K-33DE22 Dummy CW0K-3AE40 CW0K-31BE40 CW0K-32CE40 CW0K-33DE40 Dummy CW0K-3AE22N2 CW0K-31BE22N2 CW0K-32CE22N2 CW0K-33DE22N2 NO NO NO NC NC NC NC Standard key (0H, reversible) Reversible key Non-reversible key Contact Block Mounting Position 1 2 3 Left Center Right L 1 NO 2 NC 3 NC Note: Key number is indicated on the key cylinder. Standard keys do not have a key number indication. 3-position A: Removable in all positions B: Removable in left and center C: Removable in right and center D: Removable in center only E: Removable in right and left G: Removable in left only H: Removable in right only Circuit Breakers Terminal Blocks R Spring return from left Note: Key is retained in all spring-returned positions. C L NC Key removal position code 2-position A: Removable in all positions B: Removable in left only C: Removable in right only 574 R Spring return from right R 1. Specify a bezel color code in place of 0 in the Part Number: 1 (black bezel), 4 (metallic bezel). 2. On the spring-returned models, the key can be released only from the maintained position. On the maintained models, the key can be released from any position. Key retained positions are also available. See below. 3. Two keys are supplied. 4. Key cylinder material: Metal 5. Besides the standard key (key number 0H), six other keys are also available. See below. 6. For the contact block mounting position, see right. 7. For dimensions, see page 581. 8. When ordering an optional key or optional key retained positions, specify designation codes as shown below: Example: CW1K-2AE10-1H (blank): 1H to 2H: 3H to 6H: C NO — 2NC L R NO — 3 C Maintained C NO NC — 2 3 L L www.IDEC.com C R Operator Position Switches & Pilot Devices ø22mm - CW Series Switches & Pilot Devices Key Selector Switches (Sub-assembled) Contact Block + Mounting Adaptor + Style Contacts = Completed Unit Signaling Lights Contact Blocks Operator Contact Block Mounting Adaptor Contact Contact Part Block Configuration Number 1NO YW-E10R 1NC YW-E01 2NO YW-EW2R0 2NC YW-EW02 1N0-1NC YW-EW1R1 Style Part Number Single Double Dummy block Relays & Sockets Finger-safe Screw terminal CW-CN CW-DB Style Position 2 position Black Bezel Metallic Bezel Maintained, key removable all positions CW1K-2A CW4K-2A Maintained, key removed left only CW1K-2B CW4K-2B Maintained, key removed right only CW1K-2C CW4K-2C Spring return from right CW1K-21B CW4K-21B Maintained, key removable all positions CW1K-3A CW1K-3A Maintained, key removed left and center only CW1K-3B CW4K-3B Maintained, key removed right and center only CW1K-3C CW4K-3C Maintained, key removed center only CW1K-3D CW4K-3D Maintained, key removed left and right only CW1K-3E CW4K-3E Maintained, key removed left only CW1K-3G CW4K-3G Maintained, key removed right only CW1K-3H CW4K-3H CW1K-31B CW4K-31B CW1K-31D CW4K-31D Spring return from right, key removed left only CW1K-31G CW4K-31G Spring return from left, key removed right and center only CW1K-32C CW4K-32C Spring return from left, key removed center only CW1K-32D CW4K-32D Spring return from left, key removed right only CW1K-32H CW4K-32H Spring return two-way, key removed center only CW1K-33D CW4K-33D Terminal Blocks Spring return from right, key removed left and center only Spring return from right, key removed center only Contactors 3 position Description Timers Operator Circuit Breakers 2 keys supplied with operator. 800-262-IDEC (4332) • USA & Canada 575 Switches & Pilot Devices Signaling Lights Switches & Pilot Devices ø22mm - CW Series Accessories Item Appearance Material Part Number Remarks Locking Ring Wrench Brass MW9Z-T1 • Used to tighten the locking ring when installing the CW series control unit in a panel cut-out • Weight: Approx 150g Mounting Hole Plug Polyamide (black) LW9Z-BP1 • Used to plug an unnecessary ø22.3mm hole in the panel • Degree of protection: IP65 • Panel thickness: 0.8 to 6.0mm Replacement Parts 1 Relays & Sockets Material Part Number 1 Round Flush Polyalylate CW9Z-L11k 2 Round Extended Polyalylate CW9Z-L12k 3 Round Dome Polyalylate CW9Z-L15k 1NO YW-E10R 1NC YW-E01 2NO YW-EW2R0 2NC YW-EW02 1NO, 1NC YW-EW1R1 Shape Lens 2 3 Single Contact Block Push rod Housing Timers Double Contact Block Push rod Contactors Rubber Boot (clear) Housing Round Flush Terminal Blocks Remarks Color code k: A (amber), C (clear), G (green), R (red), S (blue), Y (yellow) Use a clear (C) lens for white (PW) illumination. 1: For illuminated pushbutton, pilot light 2: For illuminated pushbutton 3: For pilot light Push rod color: Black Housing color: Blue/black Terminal No.: 3-4 Push rod color: Red Housing color: Reddish purple Terminal No.: 1-2 Push rod color: black Housing color: blue and black Terminal No. 1st tier: 13-14, 2nd tier: 23-24 Push rod color: red Housing color: reddish purple Terminal No. 1st tier: 11-12, 2nd tier: 21-22 Push rod color: gray Housing color: reddish purple/blue Terminal No. 1st tier: 13-14, 2nd tier: 21-22 CW9Z-D11 CW9Z-D12 Round Extended Dummy Block Locking Ring Circuit Breakers 110 Polyamide (black) CW-DB Polyamide (black) CW9Z-LN Nitrile rubber CW9Z-WM Plastic CWAM-OB Gasket Waterproof gasket between CW control unit bezel and the mounting panel. Nameplate Spare Key Non-reversible Zinc (nickel-plated) Reversible 576 LA9Z-SK-0 Specify a key No. in place of 0. 0H: Standard key (reversible) 1H to 2H: Reversible key 3H to 6H: Non-reversible key For dimensions, see page 581. www.IDEC.com 8 ø2 Switches & Pilot Devices ø22mm - CW Series Switches & Pilot Devices LED Modules Shape Operating Voltage Range Current Draw Part Number Illumination Color Code k Specify an illumination color code in place of k in the Part Number A: amber G: green PW: white R: red S: blue 6V AC/DC±10% 15 mA CW-EAQ2k 12V AC/DC±10% 15 mA CW-EAQ3k 24V AC/DC±10% 16.5 mA CW-EAQ4k 100/120V AC±10% 18 mA CW-EAQHk 230/240V AC±10% 18 mA CW-EAQM4k Standard Legend Codes Pushbuttons CWAM–Black Plastic Nameplate CWAM-j (engraved) HWNP-j 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 HWNP Dimensions Pushbuttons/Selector Switches Legend Code OPEN OUT RAISE RESET REVERSE RUN SLOW START STOP TEST UP I (Int’l On) O (Int’l Off) EMO 116 117 118 119 120 121 122 123 125 126 127 150 151 152 Legend AUTO-MAN CLOSE-OPEN DOWN-UP FAST-SLOW FOR-REV HAND-AUTO HIGH-LOW JOG-RUN LEFT-RIGHT LOWERRAISE MAN-AUTO OFF-ON ON-OFF OPEN-CLOSE RAISELOWER Code 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 Legend Selector Switches Code Legend REV-FOR RUN-JOG RUN-SAFE SAFE-RUN SLOW-FAST START-STOP STOP-START UP-DOWN OI (Int’l OFF ON) 216 217 218 219 220 221 222 223 250 AUTO-MAN-OFF AUTO-OFF-MAN CLOSE-OFF-OPEN DOWN-OFF-SLOW FAST-OFF-SLOW FOR-OFF-REV LEFT-OFF-RIGHT LOWER-OFF-RAISE OFF-MAN-AUTO OFF-SLOW-FAST OFF-1-2 OPEN-OFF-CLOSE SLOW-OFF-FAST SUMMER-OFFWINTER UP-OFF-DOWN 1-OFF-2 HAND-OFF-AUTO Code 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 1. To order engraved nameplates, add legend code to nameplate part number. 2. Character height based on the number of characters and size of nameplate. Standard character size is 3/16”. 3. Nameplates with standard legends are the same list price as blank nameplates. 27 Timers Additional Insert (engraved) AUTO CLOSE DOWN EMERG. STOP FAST FORWARD HAND HIGH IN INCH JOG LOW LOWER OFF ON 12 Additional Insert HWNP-O (blank) Code Relays & Sockets Nameplate (blank engravCWAM-OB ing plate included) Legend Signaling Lights Nameplate 1. In place of j, insert either the standard legend code from table below or custom engraving delimited by “ “. 2. Standard engravings are available at no charge. Nameplates Order Form — CW Series Contactors Copy this order form and use it to specify Letter Height, Custom Engravings, Location of Engraving on Nameplate, and Quantity Desired. To ensure engraving accuracy, fax it to your IDEC representative or Distributor. IDEC Rep/Distributor Contact: Name: PO number (if known): Telephone: IDEC Rep/Distributor Phone: Fax & Email: IDEC Rep/Distributor Fax & Email: Terminal Blocks Your Company: CWAM Nameplate Engraving Location Step 2. Specify Quantity. Enter the number of nameplates desired in the box on the right. 7/64” Letter Size 11 characters maximum (for 7/64” size letters) 1/8” Letter Size 9 characters maximum (for 7/8” size letters) Circuit Breakers Step 1. Choose Letter Size - 7/64” or 1/8”. Check the box for the letter size you want. Then write your lettering in box below the check boxes. Note: 1/8” size letters cannot exceed 9 characters. Sample Letter Sizes 7/64” Letters: A B C D Qty 1 2 3 4 5 6 7 8 9 10 11 800-262-IDEC (4332) • USA & Canada 1/8” Letters: A BCD 577 Switches & Pilot Devices Dimensions (mm) Illuminated Pushbuttons 1 to 3 Contacts Round Extended Panel Thickness 0.8 to 3.2 M3.5 0.5 Terminal Screw LED Module Locking Ring Gasket LO 28.5 CK ø28 41.4 ø19.5 28.5 ø28 ø19.5 (Lens Diameter) 41.4 CK 10 10 10 Signaling Lights Relays & Sockets LO 1 Locking Ring Gasket 2 0.5 3 M3.5 Terminal Screw LED Module 10 M3.5 Terminal Screw Contact Block Panel Thickness 0.8 to 3.2 10 M3.5 Terminal Screw Contact Block (Lens Diameter) Round Flush 10 Switches & Pilot Devices ø22mm - CW Series 2.5 Momentary: 39.9 Maintained: 44.6 2.5 Momentary: 39.9 Maintained: 44.6 30 30 5.2 4 to 6 Contacts Round Flush Round Extended 10 10 10 2nd-tier 1st-tier contact block (NC) contact block (NO) 0.5 28.5 ø28 ø19.5 (Lens Diameter) 28.5 2.5 30 Momentary: 59.9 Maintained: 64.6 Circuit Breakers CK CK ø28 (Lens Diameter) 41.4 ø19.5 2.5 LO LO Terminal Blocks Momentary: 59.9 Maintained: 64.6 0.5 Locking Ring Gasket Locking Ring Gasket 578 Panel Thickness 0.8 to 3.2 41.4 2nd-tier 1st-tier contact block (NC) contact block (NO) Contactors M3.5 Terminal Screw Contact Block Panel Thickness 0.8 to 3.2 10 10 10 Timers M3.5 Terminal Screw Contact Block www.IDEC.com 5.2 30 Switches & Pilot Devices ø22mm - CW Series Switches & Pilot Devices Pushbuttons 1 to 3 Contacts Round Flush Round Extended M3.5 Terminal Screw Contact Block M3.5 Terminal Screw Contact Block Panel Thickness 0.8 to 3.2 10 10 10 10 10 10 Panel Thickness 0.8 to 3.2 LO Momentary ø19.5 41.4 Maintained LO LO CK 28.5 28.5 CK ø28 CK 28.5 28.5 CK Locking Ring Gasket ø28 ø19.5 (Button Diameter) 41.4 0.5 Maintained LO Signaling Lights Momentary (Button Diameter) 0.5 Locking Ring Gasket 2.5 2.5 30 30 5.2 Momentary: 39.9 Maintained: 44.6 30 30 Relays & Sockets Momentary: 39.9 Maintained: 44.6 4 to 6 Contacts Round Flush Round Extended M3.5 Terminal Screw Contact Block M3.5 Terminal Screw Contact Block Panel Thickness 0.8 to 3.2 41.4 30 Momentary: 59.9 Maintained: 64.6 30 Maintained LO LO CK CK 28.5 28.5 28.5 28.5 CK ø28 ø19.5 41.4 (Button Diameter) 2.5 Momentary Locking Ring Gasket LO CK Timers Momentary: 59.9 Maintained: 64.6 Maintained LO 0.5 ø28 Momentary Locking Ring Gasket 2nd-tier 1st-tier contact block (NC) contact block (NO) ø19.5 0.5 2nd-tier 1st-tier contact block (NC) contact block (NO) (Button Diameter) 10 10 10 10 10 10 Panel Thickness 0.8 to 3.2 2.5 5.2 30 30 Contactors Pilot Lights Round Flush Round Dome Panel Thickness 0.8 to 3.2 10 10 0.5 28.5 K ø28 ø19.5 41.4 LOC Gasket (Lens Diameter) Locking Ring 28.5 ø28 ø19.5 (Lens Diameter) 10 10 10 41.4 K Terminal Blocks LOC Gasket 1 1 M3.5 Terminal Screw LED Module 0.5 Locking Ring 2 2 M3.5 Terminal Screw LED Module 3 3 10 Panel Thickness 0.8 to 3.2 2.5 30 800-262-IDEC (4332) • USA & Canada 39.9 4.1 Circuit Breakers 2.5 39.9 30 579 Switches & Pilot Devices Selector Switches 1 to 3 Contacts Knob Operator Lever Operator M3.5 Terminal Screw Contact Block 10 10 10 1 10 2 1 3 2 10 Panel Thickness 0.8 to 3.2 10 Panel Thickness 0.8 to 3.2 M3.5 Terminal Screw Contact Block 3 0.5 0.5 Signaling Lights Operator Angle Operator Angle 45° Gasket LOC K Locking Ring 45 ° Gasket Relays & Sockets 13.1 39.9 30 30 Lever Operator M3.5 Terminal Screw Contact Block M3.5 Terminal Screw Contact Block Panel Thickness 0.8 to 3.2 10 10 10 10 Panel Thickness 0.8 to 3.2 10 10 Timers 17.1 4 to 6 Contacts Knob Operator 2nd-tier 1st-tier contact block (NC) contact block (NO) 0.5 2nd-tier 1st-tier contact block (NC) contact block (NO) 0.5 Operator Angle Operator Angle LOC K 45 º Locking Ring Gasket Circuit Breakers 580 K ø28 41.4 ø28 41.4 28.5 59.9 30 Terminal Blocks 13.1 LOC 2.5 2.5 59.9 45º 28.5 45º Locking Ring Gasket Contactors ° K 2.5 2.5 39.9 45 LOC ø28 41.4 ø28 41.4 28.5 Locking Ring 45° 28.5 Switches & Pilot Devices ø22mm - CW Series www.IDEC.com 17.1 30 45 º Switches & Pilot Devices ø22mm - CW Series Switches & Pilot Devices Key Selector Switches 1 to 3 Contacts Keys Reversible Key Panel Thickness 0.8 to 3.2 1 Operator Angle 0.5 45° LOC K 45 Logo Stamping Logo Stamping Key No. ° Key No. 0 H0 H Key No. Stamping Key No. Stamping ø28 41.4 28.5 Gasket Signaling Lights Locking Ring 22 22 14 14 10 2 8.8 8.8 4.84.8 10 3 10 M3.5 Terminal Screw Contact Block Non-reversible Key 2.5 30 31.5 39.9 22 22 1.5 14 14 6.36.3 Key No.: 0H to 2H (reversible key) Relays & Sockets 8.8 8.8 10.4 Logo Stamping Logo Stamping Key No. Key No. 3 H3 H 31.5 Key No. Stamping Key No. Stamping Key No.: 3H to 6H (non-reversible key) Timers 4 to 6 Contacts M3.5 Terminal Screw Contact Block 10 10 10 Panel Thickness 0.8 to 3.2 0.5 Operator Angle 45º LOC K 45 º ø28 41.4 28.5 Locking Ring Gasket Contactors 2nd-tier 1st-tier contact block (NC) contact block (NO) Terminal Blocks 2.5 10.4 59.9 31.5 30 Circuit Breakers 800-262-IDEC (4332) • USA & Canada 581 Switches & Pilot Devices Signaling Lights Switches & Pilot Devices ø22mm - CW Series Safety Precautions Turn off the power to CW series switches before installation, removal, wiring and maintenance. Failure to turn power off may cause electrical shocks or fire hazard. When wiring, use wires of a proper size to meet the voltage and current requirements. Tighten the M3.5 terminal screws to a tightening torque of 1.0 to 1.3 N·m. Failure to tighten the terminal screws may cause overheating and fire. Operating Instructions Notes for Operation Removing and Installing the Contact Unit Illuminated Pushbuttons and Pilot Lights When using the CW series switches in a safetyrelated circuit of a control system, observe safety rules and regulations of each country concerning particular applications of the actual machines and facilities. Perform risk assessment before operation to ensure safety. 1. To remove the contact block from the operator, push the yellow locking lever and turn it to the left. Removing the Lens To remove the lens from an illuminated pushbutton or pilot light, insert a flat screwdriver under the flange of the lens at 90° from the TOP marking and twist the screwdriver. Locking Lever Do not insert the screwdriver too far and do not apply excessive force to the lens, otherwise the bezel surface may be damaged. Timers Relays & Sockets Operating Conditions In corrosive gas or high-temperature, high-humidity environments, contact failure due to corrosion or color change or breakage of the housing may occur. Main parts of the CW series switches are made of plastic. Do not scratch the surface with a sharp object or apply excessive electric shock or load, otherwise the switches may be damaged. In particular, keep the button, lens and bezel from such damage, otherwise appearance and function may be impaired. Do not apply detergents, cutting oils, or chemicals which may impair the function and appearance of the CW series switches. First remove the contact block and then the locking ring from the operator. Insert the operator into the panel cut-out from the front, tighten the locking ring from the back, then install the contact block to the operator. Mounting Hole Installation in Panel Cut-out Remove the locking ring from the operator. With the anti-rotation projection on the operator aligned with the recess in the mounting hole, insert the operator into the mounting hole. Tighten the locking ring from the rear of the panel. Anti-rotation projection Recess in mounting hole TOP Marking TOP Marking Screwdriver Insertion Angle Panel Approx. 30° Panel Surface TOP marking on illuminated pushbuttons, pushbuttons and pilot lights Locking Ring Installing the Lens Turn the groove in the lens to the TOP marking on the operator housing. With the groove aligned with the ridge, press the lens in. TOP Marking Ridge TOP marking on selector and key selector switches 1. Mounting hole dimensions are in compliance with IEC60947-5-1. 2. If the anti-rotation projection is removed from the bezel, CW series switches can be mounted in ø22.3mm mounting holes. To remove the antirotation projection, remove the gasket and use cutting pliers to break the projection. Groove in the Lens Note for Panel Mounting When installing the operator in a panel cut-out, use the optional locking ring wrench (MW9Z-T1) to tighten the locking ring to a recommended tightening torque of 1.2 N·m. Do not use pliers and do not tighten excessively, otherwise the operator may be damaged. Circuit Breakers Terminal Blocks Contactors Panel Mounting Screwdriver Insertion Direction 2. To install, align the TOP marking on the operator with the TOP marking on the contact block mounting adaptor, and turn the locking lever to the right. Marking Marking film can be applied for inscriptions or identification. Applicable Marking Film Size Illuminated Pushbutton (Round Flush) Pilot Light (Round Flush, Round Extended) Illuminated Pushbutton (Round Extended) 13.8 9 5. ø1 12.6 9 5. ø1 Thickness: 0.2 mm maximum Film material: Polyester (recommended) Note: Film is not supplied and must be provided by the user. 582 www.IDEC.com Switches & Pilot Devices ø22mm - CW Series Switches & Pilot Devices Operating Instructions, con’t Contact Blocks and LED Modules Applicable Crimping Terminals Pushbutton caps cannot be removed. Do not tamper with the cap using a screwdriver or pliers, otherwise it may be damaged. To remove the contact block from the operator, insert a flat screwdriver under the latch and push the screwdriver down as shown below. Before removing the LED module, first remove all contact blocks, and then remove the LED module in the same manner. Spade terminal When using crimping terminals, be sure to use insulating tubes or insulated crimping terminals. Key Selector Switches 8.1 max. Insulation Tube Crimping Terminal Wire To prevent malfunction and damage, take the following precautions. 0.5 min. Stranded wire: 2.0 mm2 maximum (14AWG) Solid wire: ø1.6 mm maximum Ferrule When connecting two ferrules to one terminal, use ferrules without insulation. Insulation 8.0 max. 8.0 max. 8.0 max. When using spade terminals or ferrules, ensure that they are inserted completely. Ring terminals cannot be used. Timers One or two wires can be connected to the terminal. Relays & Sockets • Besides the standard key (0H), six other keys are available. Use only a key with a number that matches the number on the switches’ key cylinder. (The standard key does not have a key number.) Applicable Wires ø1.6 max. • Do not remove the key while turning. 1.7 max. Wiring 1.7 max. • Completely insert the key before turning. • Keys are available in two shapes. -0H (standard), 1H, 2H: reversible keys -3H, 4H, 5H, 6H: non-reversible keys Make sure of correct insertion direction. Signaling Lights Turn the selector operator or key to the detent positions. 11.5 max. 3.6 min. Selector Switches 6.9 max. Pushbuttons Screw Tightening Torque Tighten the M3.5 terminal screws to a recommended torque of 1.0 to 1.3 N·m. Contactors Terminal Blocks Circuit Breakers 800-262-IDEC (4332) • USA & Canada 583 Switches & Pilot Devices Signaling Lights Switches & Pilot Devices ø22mm - HW Series HW Series — 22mm IEC Style Global Pushbuttons Key features: • Locking lever removable contact blocks • Finger-safe IP20 contacts as standard, other terminal styles available • Tamperproof construction • All E-stops meet EN418 and are compliant with SEMI S2 standards • Worldwide approvals • Easy to assemble • Choice of black plastic or metallic front bezels • Incandescent or LED illumination • Transformer or full voltage • Slow make double break self cleaning contacts Relays & Sockets HW: The Best Engineered Switch in the World IDEC’s HW switches are “The best engineered switch in the world” for a reason. Carrying the CE mark, UL, CSA, CCC (Chinese), and TUV approvals, these switches are designed for use in almost any part of the world. Complete with finger-safe contact blocks offering IP20 protection, these 7/8” Certificate No. 2005010305145656 File No. LR92374 Electrical Timers Specifications Mechanical Contactors Terminal Blocks Circuit Breakers All switches also incorporate mechanically keyed safety locking levers, ensuring correct installation and maintaining safety in high-vibration applications. Registration No. R9551089 (E-stops) Registration No. R50054316 (Dual Pushbuttons) Registration No. J9650511 (Pilot Lights) Registration No. J9551458 (all other switches) ® File No. E68961 (22mm) switches include illuminated and non-illuminated pushbuttons, pilot lights, selector switches, and emergency stop switches. Rated Operational Characteristics AC-15: A600 or Ue = 250V, le = 3A (NO, NC, NO-EM, NC-LB) DC-13: P600 or Ue = 125V, le = 1.1A (NO, NC) DC-13: Q600 or Ue = 125V, le = 0.9A (NO-EM, NC-LB) Maximum Inrush Current 40 A (40 ms) Rated Insulation Voltage 600V Rated Switching Over-Voltage Less than 4kV, conforming to IEC60947-1 Rated Impulse Withstanding Voltage 4kV for contact circuit, 2.5kV for lamp circuit Rated Thermal Current 10 Amp Minimum Switching Capacity 5 mA at 3V AC/DC Electrical Reliability MTBF < 1 fault for 10 million operation cycles (3V DC, 5mA) Lamp Ratings Incandescent: 1 W LEDs: 6V/17mA max, 12V & 24V/11mA max, 120 & 240V/10mA max Contact Operation Slow break NC or NO, self-cleaning Positive Action Operation (Emergency Stops with NC contacts) 5.5mm to 10mm travel to latch, 45N minimum force to latch 10mm maximum travel, 1,800 operations per hour maximum for a Pushlock Turn Reset 900 operations per hour maximum for a Push-Pull Operating Force Flush and extended pushbuttons—with 1NO or 1NC contact: 6.2±2N (momentary), 7.0±2N (maintained) Additional contacts—1NO or 1NC: +3.2N (momentary), + 3.3N (maintained) Recommended Terminal Torque 0.8 N m (7.1 in lb.) Applicable Wire Size Minimum 1 x 22 AWG, max. 2 x 14 AWG or 1 x 12 AWG Contact Resistance Initial contact resistance of 50mΩ or less Contact Gap 4mm (NO and NC), 2mm (NO-EM and NC-LB) Horsepower Rating Reference Value: 1/4 HP @ 120V (1ø non-reversing), 1HP @ 240V (3ø non-reversing) Contact Material Silver (gold plated contacts available - contact IDEC) Operating Temperature Operation: –25 to +50°C (without freezing), Storage: –40 to +70°C (without freezing) Vibration Resistance 10 to 55Hz, 98m/sec2 (10G) conforming to IEC6068-2-6 Shock Resistance 980m/sec2 (100G) conforming to IEC6068-2-7 Mechanical Life Momentary pushbuttons: 5,000,000 (900 operations per hour), All other switches: 500,000 584 www.IDEC.com
CW4P-2EQ4G 价格&库存
很抱歉,暂时无法提供与“CW4P-2EQ4G”相匹配的价格&库存,您可以联系我们找货
CW4P-2EQ4G
    • 1+317.042911+41.21456
