ø22 Flush Silhouette Switches
CW Series
USB/RJ45 Ports
USB / RJ45 ports with flat stylish design
New product addition for the flush silhouette switches
RJ45
USB2.0
Flush silhouette
Cable attached
Accessories with IP65/67 protection
Flush bezel projects only 2mm from the
front of the panel. Ideal for applications
where a safe and hygienic surface is
required.
Plasticencapsulatedstructureoftherear
part prevents the cable from falling off.
(USB port only)
Rubber and transparent plastic covers
available. Water- and dust-proof.
Specification / Performance
USB2.0
RJ45
Part No.
CW1X-USB20-1M
Connector standard
USB2.0 compliant
CW4X-USB20-1M
Part No.
CW1X-RJ45
No. of contacts
8 pin
CW4X-RJ45
Operating temperature –25 to +70˚C (no freezing)
Storage temperature
Storage temperature
Storage temperature
(when packaged)
–10 to +50˚C (no freezing)
Storage temperature
(when packaged)
Relative humidity
0 to 90%RH (Max) (no condensation)
Relative humidity
Connecting cycles
1,500 times
Connecting cycles
750 times
Connecting force
35N max.
Removal force
10N min.
ISO/IEC 11 801: 2002
EN 50 173-1: Cat.6 Class EA
Transmission performance
10/100 Mbit Ethernet
1/10 Gbit Ethernet
Locking screw
recommended tightening 1.2 to 1.5 N·m
torque
Locking screw
torque
Bezel material
PBT
Cable
AWG28, USB2.0, Standard cable,
PVC shield (black)
Bezel material
PBT
Protection degree
IP20
IP65/67 (accessory attached)
Protection degree
IP20
Ports
Accessories
Shape
Bezel color
Part No.
Remarks
Black
CW1X-USB20-1M
Name / Shape
USB2.0
Material
Color
Part No.
Protection Degree
Black
CW9Z-D1X1
IP65/67
[Lens]
Polycarbonate
[Main body]
Translucent CW9Z-D1X2
Polyamide
[Gasket]
NBR
IP65/67
Rubber cap
Metallic CW4X-USB20-1M
TPE
Cable length:
1m
Plastic cover
USB2.0 TypeA
RJ45
Black
CW1X-RJ45
No. of contacts:
8 pin
Note 1) Accessories can only be used for CW series ports (CW1X / CW4X).
Note 2) F or the instruction sheet, read the QR code.
Metallic CW4X-RJ45
Dimensions
All dimensions in mm.
USB2.0
RJ45
2
24
+0.2
1000
2
2.2 0
R0.
8m
a
33.9
Potting MAX10
ø28
12 ±0.2
x.
ø28
ø4.2
ø20
.4
+0 0
.3
ø22
ø24.1
+0.4
37 ±0.5
Panel thickness
1.5 to 5
Panel thickness
1.5 to 5
Panel cut-out
Dimensions for Accessories
Rubber cap
CW9Z-D1X1
77.9
67.75
43
22
35
0.2
17.6
ø3
59
52.65
Plastic cover
CW9Z-D1X2
4.3
5.1
6
29.9
Gasket
(Thickness 0.4mm)
• Panel thickness when
CW9Z-D1X1/D1X2 is
mounted: 1.5 to 5 mm
12.5
Recommended for use with the following products:
Programmable Logic Controller
Micro Smart FC6A Plus
LB/LBW
LW
CW
FC6A
ø18.2 ø22.3
ø25.3
ø22
All-in-one
18.2 22.5
24.5
15 8.4
inch
Flush bezel projecting
only2.5mmfrompanel
front, with short, 39.9
mm depth behind the
panel.Third-generation
safety structure.
IDEC Corporation
IDEC Izumi Asia Pte. Ltd.
IDEC Asia (Thailand) Co., Ltd
IDEC Australia Pty. Ltd.
IDEC Taiwan Corporation
Tel: +1-408-747-0550
Tel: +65-6746-1155
Tel: +66-2-392-9765
Tel: +61-3-8523-5900
Tel: +886-2-2577-6938
opencontact@idec.com
info@sg.idec.com
sales@th.idec.com
sales@au.idec.com
service@tw.idec.com
inch
10.4 4.3
inch
Create stylish panel with
flushbezelsprojectingonly
2.0 mm from panel front.
Easytoinstall/remove,and
idealforpanelsthatrequire
cleanliness and safety.
inch
12.1 5.7
Plus
The MicroSmart FC6A series is available
in two types of CPUs: Plus and All-in-One.
The Plus type has a dual RJ45 Ethernet
port, embedded web server functions
and the capability to expand up to 2060
I/O, while the All-in-One type has an
embedded serial port and RJ45 Ethernet
port capable of expanding up to 520 I/O.
inch
Excellent visibility by super-bright
LED backlight. Withstands harsh
environments, and suitable for use in a
wide temperature range from cold to
hot environment.
www.idec.com
Head Office
6-64, Nishi-Miyahara-2-Chome, Yodogawa-ku, Osaka 532-0004, Japan
Hong Kong
China/Shanghai
China/Shenzhen
China/Beijing
Japan
Specifications and other descriptions in this brochure are subject to change without notice.
Information in this brochure is current as of September, 2019.
2019 IDEC Corporation, All Rights Reserved.
EP1723-0
HG
inch
18.2×24.2
LB series: Slim 2mm-thick
bezels for stylish panels.
LBW series: Projects only
2mm from the panel. Smart
appearancewithlargesurface
for secure operation.
USA
Singapore
Thailand
Australia
Taiwan
Operator Interface
IDEC Izumi (H.K.) Co., Ltd. Tel: +852-2803-8989
IDEC (Shanghai) Corporation Tel: +86-21-6135-1515
IDEC (Shenzhen) Corporation Tel: +86-755-8356-2977
IDEC (Beijing) Corporation Tel: +86-10-6581-6131
IDEC Corporation
Tel: +81-6-6398-2527
info@hk.idec.com
idec@cn.idec.com
idec@cn.idec.com
idec@cn.idec.com
marketing@idec.co.jp
很抱歉,暂时无法提供与“CW9Z-D1X2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+253.378081+32.93833
