HE5B-M2PY
HE5B-M2PY
    IDEC(日本和泉)
HE5B-M2PY 数据手册
Enabling Switches HE5B Interlock Switches XW Series E-Stops Overview HE5B ø16mm Redundant Contact Pushbutton Enabling Switch Key features: • Ergonomically-designed OFF-ON-OFF 3-position operation • Easy recognition of position 1 2 transition, made possible by snap action switch • Sufficient load difference is provided for shifting from position 2 3 • Light force needed to maintain position 2, so that operators can easily use the enabling switch • The switch does not turn ON when being released from position 3 (OFF when pressed) to position 1 (OFF when released) (IEC60204-1, 9.2.5.8) • Two contacts are provided for safety • IP65 (using the waterproof rubber cover) • Mounts in a 16mm (5/8”) round hole Accessories Replacement Rubber Cover Part Numbers Style Color Yellow Appearance Part Number HE5B-M2PY Enabling Switches Safety Control Relays Gray Yellow HE9Z-D5Y Black HE9Z-D5B NBR/PVC Polyblend Gray HE9Z-D5N1 Part Number Material MT-001 Metal Lock Nut Tool HE5B-M2PB Appearance NBR/PVC Material Silicon Rubber Silicon Rubber Black Part Number HE5B-M2PN1 Grip Housing NBR/PVC cover comes in gray only. Appearance Part Number HE9Z-GSH51 See page 417 for more information. AS-Interface Safety at Work Light Curtains Specifications Conforming to Standards UL508 (UL recognized), CSA C22.2, No. 14 (c-UL recognized) IEC/EN 60947-5-1, IEC/EN 60947-5-8 (TÜV approval) Application Standards ISO 12100-1, -2, EN 12100-1, 2 / EN292, IEC 60204-1 / EN 60204-1, ISO 11161 / prEN 11161, ISO 10218 / EN 775, ANSI/RIA R15.06, ANSI B11.19 Operating Temperature Silicon rubber boot: –25 to 60°C (no freezing) NBR/PVC Polyblend rubber boot: –10 to 60°C (no freezing) Relative Humidity 45 to 85% RH (no condensation) Storage Temperature –40 to +80°C (no freezing) Operating Environment Degree of pollution: 2 (panel inside/terminal side) Degree of pollution: 3 (panel outside/operator side) Contact Resistance 50 mΩ maximum (initial value) Insulation Resistance (DC megger) Between live and dead metal parts: 100 MΩ minimum Between terminals of different pole: 100 MΩ minimum Impulse Withstand Voltage 1.5 kV 400 www.IDEC.com 1705151129 Enabling Switches HE5B Specifications con’t 1200 operations per hour Mechanical Life Position 1 Position 1 Electrical Life 100,000 operations minimum Shock Resistance Operating extremes: 150 m/s2 (15 G) Damage limits: 500 m/s2 (50 G) Vibration Resistance Operating extremes: 5 to 55 Hz, amplitude 0.5 mm minimum Damage limits: 5 to 55 Hz, amplitude 0.5 mm minimum Terminal Style Solder Terminal Recommended Wire Size 0.5 mm2 maximum per line (20AWG) Solder Heat Resistance 310 ~ 350°C, 3 seconds maximum Terminal Pulling Strength 20 N minimum Recommended Tightening Torque of Locking Ring 0.29 to 0.49 N·m Degree of Protection IP65 Conditional Short-circuit Current 50A (250V) (Use 250V/10A fast acting type fuse for short circuit protection.) Operator Strength 250N minimum (when pressing the entire surface of the operator) Weight (approx.) 9g 2 2 Overview Operating Frequency 1: 1,000,000 operations minimum 3 1: 100,000 operations minimum XW Series E-Stops Interlock Switches Current Ratings Rated Insulation Voltage (Ui) 125V Thermal Current (lth) 3A Rated Operating Voltage (Ue) DC 125V Resistive Load (AC-12) – 0.5A Inductive Load (AC-15) – 0.3A Resistive Load (DC-12) 1A – Inductive Load (DC-13) 0.7A – Contact Configuration Enabling Switches Rated Operating Current (le) AC 30V 2 contacts (DPDT) Minimum applicable load (reference): 5V AC/DC, 5mA. Safety Control Relays Circuit Diagrams Terminal Arrangement (Bottom View) NC1 NC2 NO1 NO2 C1 C2 Light Curtains 1. 3 position switch: 2 contacts, terminal no. = between NO1-C1, between NO2-C2 2. Use between NO-C for OFF On OFF 3 position switch (NC is not used). AS-Interface Safety at Work 1705151129 800-262-IDEC (4332) • USA & Canada 401 Enabling Switches HE5B Operating Characteristics Operating Characteristics (without rubber cover/center of button being pushed) Overview Position 1 Part B Position 2 Position 3 Part A: Approx. 56N Part B: Approx. 14N Part A Part A: Approx. 50N Part B: Approx. 12N Operating Force (reference value) (without rubber boot) (when part A or B is pressed) XW Series E-Stops : ON (closed) : OFF (open) Part A: Approx. 10N Part B: Approx. 2N Travel (mm) Pressing (position 1 to 2 to 3) Releasing Interlock Switches (position 2 to 1) Releasing (position 3 to 1) Part A 0 0.8 –0.2 +0.7 1.0 –0.2 +0.7 1.7 –0.2 +0.7 1.9 –0.2 Part B 0 2.3 –0.3 +0.7 3.0 –0.3 +0.7 4.2 –0.3 +0.7 5.0 –0.3 +0.7 +0.4 NO1-C1 NO2-C2 NO1-C1 NO2-C2 NO1-C1 NO2-C2 Operating load depends on ambient temperature. Dimensions (mm) With Rubber Cover Panel Thickness 0.5 to 4 3 2.5 Enabling Switches Locking Ring Anti-rotation Ring Rubber Boot 5 8 15 16 Mounting Hole Layout Panel Thickness 0.5∼4mm Light Curtains Safety Control Relays 5 ø20 Solder Terminal Width 2.8 ¥ 0.5t .2 +0 0 .0 6 φ1 1. Recommended tightening torque for Locking Ring: 0.29 to 0.49 N·mm. 2. Use a lock nut tool to screw on the lock nut (see page 400). Anti-rotation ring AS-Interface Safety at Work Lock nut 402 www.IDEC.com 1705151129
HE5B-M2PY 价格&库存
很抱歉,暂时无法提供与“HE5B-M2PY”相匹配的价格&库存,您可以联系我们找货
HE5B-M2PY
    • 1+280.47588
    • 5+272.05108
    • 10+263.89705
    • 25+255.82632
    库存:33
