AL6H-A24-W
AL6H-A24-W
    IDEC(日本和泉)
AL6H-A24-W 数据手册
Miniature Switches and Pilot Devices A6 Series: 16mm AL6 Illuminated Pushbuttons (Assembled) Part Numbers: LED Illuminated Pushbuttons Description Style Contact Part Numbers Momentary Maintained (Latching) Dustproof (IP40) Oiltight (IP65) Dustproof (IP40) Oiltight (IP65) 24V AC/DC ±10% SPDT DPDT AL6M-M14-➁ AL6M-M24-➁ AL6M-M14P-➁ AL6M-M24P-➁ AL6M-A14-➁ AL6M-A24-➁ AL6M-A14P-➁ AL6M-A24P-➁ 24V AC/DC ±10% SPDT DPDT AL6Q-M14-➁ AL6Q-M24-➁ AL6Q-M14P-➁ AL6Q-M24P-➁ AL6Q-A14-➁ AL6Q-A24-➁ AL6Q-A14P-➁ AL6Q-A24P-➁ 24V AC/DC ±10% SPDT DPDT AL6H-M14-➁ AL6H-M24-➁ AL6H-M14P-➁ AL6H-M24P-➁ AL6H-A14-➁ AL6H-A24-➁ AL6H-A14P-➁ AL6H-A24P-➁ 24V AC/DC ±10% SPDT DPDT – AL6M-M14P-M➁ AL6M-M24P-M➁ – AL6M-A14P-M➁ AL6M-A24P-M➁ 24V AC/DC ±10% SPDT DPDT – AL6Q-M14P-Q➁ AL6Q-M24P-Q➁ – AL6Q-A14P-Q➁ AL6Q-A24P-Q➁ Voltage A Round 18mm diameter Standard Lens Rectangular 18mm x 24mm Round 24mm diameter Square 24 mm Oversize Lens Rectangular 18mm x 24mm AL6Q-A14P-H➁ AL6Q-A24P-H➁ 24V AC/DC ±10% SPDT DPDT 1. In place of ➁, specify Lens/LED Color Code from table below. 2. Lamps also available in 5V DC, 6V AC/DC or 12 V AC/DC, change “4” using voltage/lamp codes (ie AL6M-M13-➁ uses 12V AC/DC LED). 3. LED lamp is included in unit and contains a current-limiting resistor and a protection diode. (External resistor not required.) 4. To order as sub-assembled, see page A-22. 5. For accessories, see page A-26. 6. For dimensions, see page A-28. A Green G Red R Blue S White W Yellow Y www.idec.com – Part Numbers: Replacement LED Lamps Appearance Rated Voltage Part Number 5V DC LATD-5➁ 6V AC/DC LATD-6➁ 12V AC/DC LATD-1➁ 24V AC/DC LATD-2➁ In place of ➁, specify LED Color Code from table at left. ➁ Lens/LED Color Code Color Code Amber AL6Q-M14P-H➁ AL6Q-M24P-H➁ – Voltage Code Voltage 5V DC Code 1 6V AC/DC 2 12V AC/DC 3 24V AC/DC 4 USA: (800) 262-IDEC or (408) 747-0550, Canada (888) 317-IDEC A-21 Switches & Pilot Devices Square 18mm Oiltight Switches and Pilot Devices TW Series: 22mm Non-Illuminated Pushbuttons (Assembled) con’t Part Numbers: Non-illuminated Pushbuttons Style Contacts Switches & Pilot Devices A ① Button Color Code Momentary Action Maintained Action Color Code 1NO 1NC 1NO-1NC 2NO 2NC ABW110-➀ ABW101-➀ ABW111-➀ ABW120-➀ ABW102-➀ AOW110-➀ AOW101-➀ AOW111-➀ AOW120-➀ AOW102-➀ Black B Green G Red R Blue S ABW210-➀ ABW201-➀ ABW211-➀ ABW220-➀ ABW202-➀ AOW210-➀ AOW201-➀ AOW211-➀ AOW220-➀ AOW202-➀ White W Extended 1NO 1NC 1NO-1NC 2NO 2NC Yellow Y Recessed 1NO 1NC 1NO-1NC 2NO 2NC ABFW110-➀ ABFW101-➀ ABFW111-➀ ABFW120-➀ ABFW102-➀ AOFW110-➀ AOFW101-➀ AOFW111-➀ AOFW120-➀ AOFW102-➀ Extended with Full Shroud 1NO 1NC 1NO-1NC 2NO 2NC ABFW210-➀ ABFW201-➀ ABFW211-➀ ABFW220-➀ ABFW202-➀ AOFW210-➀ AOFW201-➀ AOFW211-➀ AOFW220-➀ AOFW202-➀ Ø 29mm Mushroom Head 1NO 1NC 1NO-1NC 2NO 2NC ABW310-➀ ABW301-➀ ABW311-➀ ABW320-➀ ABW302-➀ AOW310-➀ AOW301-➀ AOW311-➀ AOW320-➀ AOW302-➀ Ø 40mm Mushroom Head 1NO 1NC 1NO-1NC 2NO 2NC ABW410-➀ ABW401-➀ ABW411-➀ ABW420-➀ ABW402-➀ AOW410-➀ AOW401-➀ AOW411-➀ AOW420-➀ AOW402-➀ Ø 40mm Mushroom Head with Full Shroud 1NO 1NC 1NO-1NC 2NO 2NC ABGW410-➀ ABGW401-➀ ABGW411-➀ ABGW420-➀ ABGW402-➀ AOGW410-➀ AOGW401-➀ AOGW411-➀ AOGW420-➀ AOGW402-➀ Square Flush 1NO 1NC 1NO-1NC 2NO 2NC ABQW110-➀ ABQW101-➀ ABQW111-➀ ABQW120-➀ ABQW102-➀ AOQW110-➀ AOQW101-➀ AOQW111-➀ AOQW120-➀ AOQW102-➀ Square Extended 1NO 1NC 1NO-1NC 2NO 2NC ABQW210-➀ ABQW201-➀ ABQW211-➀ ABQW220-➀ ABQW202-➀ AOQW210-➀ AOQW201-➀ AOQW211-➀ AOQW220-➀ AOQW202-➀ Keylock Push On/Off 1NO 1NC 1NO-1NC 2NO 2NC AKW210 AKW201 AKW211 AKW220 AKW202 Flush – 1. In place of ➀, specify the Button Color Code from table. 2. For sub-assembled part numbers, see page A-125. 3. For accessories, see page A-150. 4. For dimensions, see page A-152. 5. Keyed switches are supplied with two keys. All units are keyed alike. For custom keys, contact IDEC. A-124 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada (888) 317-IDEC A6 Series: 16mm Miniature Switches and Pilot Devices Accessories — A Series: 16mm Appearance Switches & Pilot Devices A Description Used With Part Number Ø 5/8" (16mm) units MT-001 Made of metal. Used for tightening plastic locking ring during installation. Tightening torque should not exceed 3kgfcm Ø 31/64" (12mm) AP2M units MT-002 Ø 13/32" (10mm) AP1M units MT-003 Lens Removal Tool Made of metal. Used for removing lens or button from the housing All pushbuttons and pilot lights MT-101 Lamp Holder Tool Made of rubber. Used for removing and replacing LED lamps in illuminated units All illuminated pushbuttons and pilot lights OR-77 Round/Square AL-K6 Switch Guard Prevents inadvertent switch operation. IP40 dust-tight rated. 90 degrees opening maintained Rectangular AL-KH6 Prevents inadvertent switch operation. IP65 oiltight rated 180 degrees opening, spring return Round/Square Rectangular AL-K6SP AL-KH6SP Terminal Cover Made of translucent nylon. Fits over and shields the terminals All 5/8" (16mm) units AL-V6 Dust Cover Fits over the lens or button to provide protection from dust. (not applicable for oversize lenses or buttons) All round units All square units AL-D6 AL-DQ6 All rectangular units AL-DH6 Locking Ring Wrench Plug-on terminal adaptor with solder terminal Adaptor Socket AL-C6 All 5/8" (16mm) units Plug-on terminal adaptor with PCB terminal Fills unused panel cutouts. Made of nitrile rubber. Push-in installation from front of panel. IP65 (oiltight) rated. Fills unused panel cutouts. Made of aluminum. Screw-on locking ring from inside of panel. IP65 (oiltight) rated. Mounting Hole Plug AL-C6V Rubber AL-B6 Aluminum AL-BM6 LATD-5➁ LATD-6➁ LATD-1➁ LATD-2➁ Replacement LED Lamps LED with built in current limiting resistor (with all illuminated assemblies). 5V DC 6V AC/DC 12V AC/DC 24V AC/DC Replacement Locking Ring Fastens operators to panel (included with all operators). All switches & pilot lights HA9Z-LN Anti-Rotation Ring Prevents rotation of switches in panel (included with all operators). All switches & pilot lights AL6-LP Engraving plates to allow legends underneath translucent lenses (included with all lenses). Round standard Square standard Rectangular standard Round oversize Square/rectangular oversize AL6M-W AL6Q-W AL6H-W AL6M-MW All key selectors AS6-SK-132PN02 Replacement Engraving Inserts Replacement Keys Pair of keys (#132). All key switches use same standard key. AL6Q-QW 1. In place of ➁ specify color code. A=Amber, W=White, G=Green, Y=Yellow, R=Red, S=Blue. A-26 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada (888) 317-IDEC Miniature Switches and Pilot Devices A6 Series: 16mm AL6 Illuminated Pushbuttons (Sub-Assembled) Operator + LED Lamp + Lens = Completed Unit Switches & Pilot Devices A Part Numbers: Operators Style Contact AL6 Illuminated Pushbuttons SPDT DPDT Part Numbers: Lenses Unit Degree of Dustproof (IP40) Protection Size Standard AL6M-LK1-➁ Part Number Operator Round Momentary AL6M-M100 Square Rectangular AL6Q-M100 AL6H-M100 Maintained AL6M-A100 AL6Q-A100 AL6H-A100 Momentary AL6M-M200 AL6Q-M200 AL6H-M200 Maintained AL6M-A200 AL6Q-A200 AL6H-A200 Part Number Oiltight (IP65) Standard Oversize AL6M-LK2-➁ AL6M-LK2-M➁ AL6Q-LK1-➁ AL6Q-LK2-➁ AL6Q-LK2-Q➁ AL6H-LK1-➁ AL6H-LK2-➁ AL6Q-LK2-H➁ Round Square Rectangular 1. In place of ➁, specify Lens Color Code from table below. 2. Lenses which are rated IP65 include a waterproof rubber gasket. 3. For accessories, see page A-26. ➁Lens/LED Color Code Color Code Part Numbers: Replacement LED Lamps Appearance Rated Voltage Part Number A 5V DC LATD-5➁ Green G 6V AC/DC LATD-6➁ Red R 12V AC/DC LATD-1➁ Blue S 24V AC/DC LATD-2➁ White W Yellow Y Amber A-22 In place of ➁, specify LED Color Code from table at left. www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada (888) 317-IDEC Miniature Switches and Pilot Devices A6 Series: 16mm AL6 Pilot Lights (Assembled) Part Numbers: LED Pilot Lights Description Voltage Part Number Dustproof (IP40) Oiltight (IP65) 24V AC/DC AL6M-P4-➁ AL6M-P4P-➁ 24V AC/DC AL6Q-P4-➁ AL6Q-P4P-➁ A Round (18mm Lens) Switches & Pilot Devices Square (18mm Lens) Rectangular (18mm x 24mm Lens) 24V AC/DC AL6H-P4-➁ AL6H-P4P-➁ ➁ Lens/LED Color Code Color Code Amber A Green G Red R Blue S White W Yellow Y 1. In place of ➁, specify LED/Lens Color Code. 2. Lamps also available in 5V DC, 6V AC/DC or 12 V AC/DC, change “4” using voltage codes (ie AL6M-P3-➁ uses 12V AC/DC lamp). 3. LED Lamp is included and contains built-in current limiting resistor and reverse polarity protection diode. (no external resistor required) 4. To order sub-assembled, see page A-24. 5. For accessories, see page A-26. 6. For dimensions, see page A-28. 7. For one piece pilot lights and/or dome lens pilot lights, see page A-31. Part Numbers: Replacement LED Lamps Appearance Rated Voltage Part Number 5V DC LATD-5➁ 6V AC/DC LATD-6➁ 12V AC/DC LATD-1➁ 24V AC/DC LATD-2➁ In place of ➁, specify LED Color Code from table at left. Voltage Code Voltage Code 5V DC 1 6V AC/DC 2 12V AC/DC 3 24V AC/DC 4 www.idec.com USA: (800) 262-IDEC or (408) 747-0550, Canada (888) 317-IDEC A-23
AL6H-A24-W 价格&库存
很抱歉,暂时无法提供与“AL6H-A24-W”相匹配的价格&库存,您可以联系我们找货
AL6H-A24-W
  • 1+221.71059
  • 10+215.25402
  • 25+206.80839
库存:26
