ASLD22211DNUG
ASLD22211DNUG
    IDEC(日本和泉)
    30MM SS IL 2POS 24V 1NO1NC GRN
ASLD22211DNUG 数据手册
Switches & Pilot Devices Switches & Pilot Devices ø30mm - TWND Series Relays & Sockets Signaling Lights New TWND Series — Full Size NEMA Pushbuttons New! TWND Series: Heavy duty switches built to last Key features: Timers • Variety of button sizes up to 2 9/16” (65mm) • Rugged construction includes chrome plated zinc locking ring die cast zinc mounting thread • LED illumination The rugged series of TWND switches offers both variety and durability in an attractive design. With button sizes up to 2 9/16” (65mm), chrome plated zinc locking rings, die cast zinc mounting threads, steel anti-rotation rings, and self cleaning contacts, the TWNDs are here to stay. The TWND series also offers LED illumination in full voltage and transformer models. • Transformer or full voltage • Slow make, double break wiping contacts Regardless of your switching needs, the NEW TWND series provides the kind of long lasting, industrial strength quality you’ve come to expect from IDEC. • Modular construction for maximum flexibility • UL Type 4X, 13 and IP65 watertight/oiltight panel Terminal Blocks Contactors • Available assembled or as sub-components File No. LR21451 R 50363567 Certificate No. 2016010305902410 Circuit Breakers UL Listed File No. E68961 720 www.IDEC.com 1804301445 Switches & Pilot Devices ø30mm - TWND Series Switches & Pilot Devices Specifications EN60947-5-1, UL508, CSA C22-2 No.14 Approvals CSA: pushbuttons and selector switches: A600 pilot lights and illuminated pushbuttons, direct supply pilot lights and illuminated pushbuttons with integral transformer (100/110, 115, 120, 200/220, 230, 240, 380, 400/440, 480V) UL: pushbuttons and selector switches: A600 pilot lights and illuminated pushbuttons, direct supply pilot lights and illuminated pushbuttons with integral transformer (100/110, 115, 120, 200/220, 230, 240, 380, 400/440, 480V) TÜV: pushbuttons and selector switches: A600 pilot lights and illuminated pushbuttons, direct supply pilot lights and illuminated pushbuttons with integral transformer (100/110, 115, 120, 200/220, 230, 240, 380, 400/440, 480V) Operating Temperature Operation: –25 to +50°C (illuminated versions) -25 ~ +70C non-illuminated Storage: –40 to +80°C (without freezing) C-> °C Vibration Resistance 5 to 55Hz, 98m/sec2 (10g) conforming to IEC60068-2-6 Shock Resistance 980m/sec2 (100g) conforming to IEC60068-2-27 Electric Shock Protection Class 2 conforming to IEC60664-1 Degree of Protection IP65 (from front of the panel) (conforming to IEC60529) UL Type 1, 2, 3, 3R, 3S, 4, 4X, 5, 12, 13 (conforming to NEMA ICS6-110) Mechanical Life Momentary pushbuttons: 5,000,000 (1800 operations per hour) All other switches: 500,000 Pollution Degree (conforming to IEC60947-1) 3 Signaling Lights Conforming to Standards Relays & Sockets Mechanical-Electrical Specifications Rated Operational Characteristics Rated Insulation Voltage Rated Impulse Withstanding Voltage øDielectric Strength Rated Thermal Current Minimum Switching Capacity Contact Operation Operating Force AC-15: A600 600V Between live and dead metal parts 2.5kV AC, 1 minute 10 Amp 5 mA at 3V AC/DC (applicable range may vary with operating conditions and load types) Slow break NC or NO Flush and extended pushbuttons—with 1NO or 1NC contact: 6.2±2N (momentary), 9.0±1.5N Additional contacts—1NO or 1NC: +3.0N Recommended Terminal Torque HW-U Contact Block Illuminated Unit (*1) Pilot Light 2 1.0 to 1.3 M3.5 Number of Wires Crimping Terminal ø0.5 to 1.6 mm (AWG14 to 22) Solid Wire ø1.7 to 2.0 mm (AWG12) 0.3 to 2.0 mm2 (AWG14 to 22) Stranded Wire 2.1 to 3.5 mm2 (AWG12) Crimping Terminal Solid Wire ø0.5 to 1.6 mm (AWG14 to 22) Stranded Wire 0.3 to 2.0 mm (AWG14 to 22) Crimping Terminal Solid Wire ø0.5 to 1.6 mm (AWG14 to 22) Stranded Wire ø0.3 to 2.0 mm (AWG14 to 22) M3.5 Contactors Applicable Wire Size Terminal Screw 2 2 1 2 1 Recommended Tightening Torque (Nm) 1.0 to 1.3 1.0 to 1.3 1.2 to 1.3 1.0 to 1.3 1.2 to 1.3 Wire Timers Unit 0.6 to 1.0 (M3.0) 2 1.0 to 1.3 (M3.5) 1. * refers to the lamp terminals of the illuminated push buttons and selector switches. Contact Resistance Contact Gap LED Ratings Contact Material Terminal Blocks Initial contact resistance of 50mΩ or less 4mm (NO and NC) 2mm (NO-EM and NC-LB) LEDs: 6V: 8mA, 12V: 11mA, 24V: 11mA, 120V: 8.8mA, 240V: 8.6mA Silver Contact Ratings AC-15 (A600) Contact Ratings by Utilization Category IEC 60947-5-1 DC-13 (P600) Contact Ratings by Utilization Category Operational Voltage AC 50/60 Hz DC 1804301445 48V 50V 110V 220V 440V 10A — 10A 10A 6A 2A AC-15 Control of electromagnetic loads (> 72VA) 10A — 7A 5A 3A 1A DC-12 Control of resistive loads & solid state loads 10A 5A — 2.2A 1.1A — DC-13 Control of electromagnets 5A 2A — 1.1A 0.6A — 800-262-IDEC (4332) • USA & Canada Circuit Breakers Operation Current 24V AC-12 Control of resistive loads & solid state loads 721 Switches & Pilot Devices Switches & Pilot Devices ø30mm - TWND Series Timers Relays & Sockets Signaling Lights Non-Illuminated Pushbuttons (Assembled) Assembled Pushbuttons A B ( ) D 1 10 R Function Button Color B: Momentary O: Maintained V: Pushlock Turn Reset Y: Push-Pull B: Black R: Red G: Green S: Blue W: White Y: Yellow Contact Arrangement 10: 1NO 01: 1NC 20: 2NO 02: 2NC 11: 1NO-1NC 22: 2NO-2NC Bezel Shape Blank: Octagonal F: Full Shroud G: Mushroom Shroud P: Neoprene Boot Button Shape 1: Flush 2: Extended 3: Mushroom ø 40mm 4: Jumbo Mushroom ø 65mm Series Designation Contactors NU D: TWND Series Circuit Breakers Terminal Blocks 1. Use only when interpreting part numbers. Do not use for developing part numbers. 2. Custom contact configurations available, contact IDEC for details. 722 www.IDEC.com 1804301445 Switches & Pilot Devices ø30mm - TWND Series Switches & Pilot Devices Non-Illuminated Pushbuttons (Assembled) Non-Illuminated Pushbuttons Style j Button Color Codes AOD110NUj AOD101NUj AOD111NUj AOD120NUj AOD102NUj 1NO 1NC 1NO-1NC 2NO 2NC ABD210NUj ABD201NUj ABD211NUj ABD220NUj ABD202NUj AOD210NUj AOD201NUj AOD211NUj AOD220NUj AOD202NUj Extended with Neoprene Boot† 1NO 1NC 1NO-1NC 2NO 2NC ABPD210NUj ABPD201NUj ABPD211NUj ABPD220NUj ABPD202NUj AOPD210NUj AOPD201NUj AOPD211NUj AOPD220NUj AOPD202NUj Recessed 1NO 1NC 1NO-1NC 2NO 2NC ABFD110NUj ABFD101NUj ABFD111NUj ABFD120NUj ABFD102NUj AOFD110NUj AOFD101NUj AOFD111NUj AOFD120NUj AOFD102NUj Extended with Full Shroud 1NO 1NC 1NO-1NC 2NO 2NC ABFD210NUj ABFD201NUj ABFD211NUj ABFD220NUj ABFD202NUj AOFD210NUj AOFD201NUj AOFD211NUj AOFD220NUj AOFD202NUj ø 40mm Mushroom Head 1NO 1NC 1NO-1NC 2NO 2NC ABD310NUj ABD301NUj ABD311NUj ABD320NUj ABD302NUj AOD310NUj AOD301NUj AOD311NUj AOD320NUj AOD302NUj ø 40mm Mushroom Head with Full Shroud 1NO 1NC 1NO-1NC 2NO 2NC ABGD310NUj ABGD301NUj ABGD311NUj ABGD320NUj ABGD302NUj AOGD310NUj AOGD301NUj AOGD311NUj AOGD320NUj AOGD302NUj ø 65mm Jumbo Mushroom Head 1NO 1NC 1NO-1NC 2NO 2NC ABD410NUj ABD401NUj ABD411NUj ABD420NUj ABD402NUj AOD410NUj AOD401NUj AOD411NUj AOD420NUj AOD402NUj ø 65mm Jumbo Mushroom Head with Shallow Shroud 1NO 1NC 1NO-1NC 2NO 2NC ABGD410NUj ABGD401NUj ABGD411NUj ABGD420NUj ABGD402NUj AOGD410NUj AOGD401NUj AOGD411NUj AOGD420NUj AOGD402NUj ø 65mm Jumbo Mushroom Head With Deep Shroud 1NO 1NC 1NO-1NC 2NO 2NC ABFD410NUj ABFD401NUj ABFD411NUj ABFD420NUj ABFD402NUj AOFD410NUj AOFD401NUj AOFD411NUj AOFD420NUj AOFD402NUj Flush Extended Color Code Black B Green G Red R Blue S Yellow Y White W 1. 65mm Jumbo mushroom not available in white. 2. Neoprene boot is not available in blue or white. Terminal Blocks ABD110NUj ABD101NUj ABD111NUj ABD120NUj ABD102NUj Contactors 1NO 1NC 1NO-1NC 2NO 2NC Timers Maintained Relays & Sockets Momentary Signaling Lights Contacts 1804301445 800-262-IDEC (4332) • USA & Canada Circuit Breakers 1. In place of j, specify the Button Color Code. 2. For sub-assembly part numbers, see next page. 4. †Neoprene boot available only in Black (B), Green (G), Red (R) and Yellow (Y). 723 Switches & Pilot Devices Signaling Lights Switches & Pilot Devices ø30mm - TWND Series Non-Illuminated Pushbuttons (Sub-Assembled) Contact Block Relays & Sockets Operator + Operators Part Number Maintained ABD1200T8 AOD1200T8 ALFD2300T8 AOLFD2300T8 ø 40mm Mushroom/ø 65mm Jumbo Mushroom ABD3400T8 AOD3400T8 AOGD-300T Contactors ABGD-300T Extended ABD2BN-j ø 40mm Mushroom ABD3BN-j ø 65mm Jumbo Mushroom ABD4BN-j AOGD-400T In place of j, specify the Button Color Code. (See table previous page) Contact Blocks ABFD-400T AOFD-400T All Control Units Dummy Block Circuit Breakers Terminal Blocks ABGD-400T Part Number ABD1BN-j Style ø 65mm Jumbo Mushroom with Deep Shroud Complete Part Flush ø 65mm Jumbo Mushroom with Shallow Shroud = Style Momentary Extended with Full Shroud ø 40mm Mushroom with Full Shroud Button Buttons and Lenses Style Flush/Extended Timers + Part Number 1NO 1NC HW-U10 HW-U01 HW-U10R (early make) HW-U01R (late break) HW-DB 1. Dummy blocks (no contacts) are used with an odd number of contact blocks. 2. Combining HW-U10R and HW-U01R result in overlapping contacts (remain on, or closed, when switch is moved between two positions). 724 www.IDEC.com 1804301445 Switches & Pilot Devices ø30mm - TWND Series Switches & Pilot Devices Stop Switches (Assembled) Signaling Lights Assembled Stop Switches V (L) D 3 22 11 D NU R Function Button/Lens Color Code V: Pushlock Turn Reset Y: Push-Pull A: Amber G: Green R: Red S: Blue W: White Y: Yellow Illumination Timers Blank: None L: Illuminated Relays & Sockets A (illuminated units only) Series Designation D: LED D: TWND Series Contact Arrangement Button/Lens Size Illumination Circuit Contactors 10: 1NO 01: 1NC 20: 2NO 02: 2NC 11: 1NO-1NC 22: 2NO-2NC 3: 40mm Mushroom Full Voltage: 66: 6VAC/DC 11: 12VAC/DC 22: 24AC/DC QH2: 120VAC Terminal Blocks QM4: 240VAC Transformer: 126: 120VAC step down transformer 246: 240VAC step down transformer 486: 480VAC step down transformer 1804301445 800-262-IDEC (4332) • USA & Canada Circuit Breakers 1. Use only when interpreting part numbers. Do not use for developing part numbers. 2. Custom contact configurations available, contact IDEC for details. 725 Switches & Pilot Devices Switches & Pilot Devices ø30mm - TWND Series Stop Switches (Assembled) Stop Switches j Button Color Codes Style Contacts ø 40mm Pushlock Turn Reset 1NO 1NC 1NO-1NC 2NO 2NC AVD310NUR* AVD301NUR* AVD311NUR* AVD320NUR* AVD302NUR* 1NO-1NC 2NO 2NC AVLD3l11DNUR* AVLD3l20DNUR* AVLD3l02DNUR* Transformer 1NO-1NC 2NO 2NC AVLD3 m 11DNUR* AVLD3 m 20DNUR* AVLD3 m 02DNUR* Non-Illuminated 1NO 1NC 1NO-1NC 2NO 2NC AYD310NUj AYD301NUj AYD311NUj AYD320NUj AYD302NUj Relays & Sockets Signaling Lights Non-Illuminated ø 40mm Illuminated Pushlock Turn Reset Full Voltage ø 40mm Push-Pull ø 40mm Illuminated Push-Pull Timers Full Voltage Transformer 1. 2. 3. 4. 5. 6. 7. 8. 9. 1NO-1NC 2NO 2NC AYLD3l11DNUk ** AYLD3l20DNUk ** AYLD3l02DNUk ** 1NO-1NC 2NO 2NC AYLD3 m 11DNUk ** AYLD3 m 20DNUk ** AYLD3 m 02DNUk ** In place of j, specify the button color code In place of k, specify the lens color code. In place of l, specify the Full Voltage (lamp voltage) Code. * Only available in red. In place of m, specify the transformer voltage code. **Not available in blue. For sub-assembly part numbers, see next page. For nameplates and accessories, see page 744 and page 742. For dimensions, see page 747. Color Code Black B Green G Red R Blue S Yellow Y k Lens Color Codes Color Code Amber Green Red Blue White Yellow A G R S W Y l Full Voltage Codes Voltage Code 6V AC/DC 66 12V AC/DC 11 24V AC/DC 22 120V AC QH2 240V AC QM4 m Transformer Voltage Codes Voltage Code 120VAC 126 240VAC 246 480VAC 486 Transformers step down to 6V. Circuit Breakers Terminal Blocks Contactors Part Number 726 www.IDEC.com 1804301445 Switches & Pilot Devices ø30mm - TWND Series Switches & Pilot Devices Stop Switches (Sub-Assembled) Transformer* + Operator + Lamp + Button/Lens = Complete Part * Not required for full voltage units. Operators Lamps Style Part Number Voltage 6V AC/DC 12V AC/DC 24V AC/DC 120V AC 240V AC LED ø40mm Illuminated and Non-illuminated Pushlock Turn Reset AVD000T8 1. In place of k, specify the LED color code. 2. The LED contains a current-limiting resistor and a protection diode. AYD000T8 Style Part Number Button for Pushlock Turn Reset Stop Switches (ø40mm, red only) AVN3B-R AVLN3LU-R Button for Push-Pull Stop Switches (ø40mm) AYD3BN-j Code Black Green Red Blue Yellow B G R S Y AYLD3L-k Part Number 1NO 1NC All Control Units HW-U10R (early make) HW-U01R (late break) Transformers Style Primary Voltage (50/60Hz) Part Number 120V AC HW-T126 240V AC HW-T246 480V AC HW-L486 Part Number Used with Full-size Transformer and two contact blocks Used with TW-LH2 holder when using four contact blocks 6V secondary voltage (uses 6V LED). Full Voltage Modules Style TW-LH2 HW-LH3 Full voltage model (mounted directly to the operator on the first deck) 800-262-IDEC (4332) • USA & Canada Description Part Number Spring-Up HW-GA1N Circuit Breakers Used with Full Voltage Adaptor and two contact blocks TW-LH1 Terminal Blocks Application Used with a one contact block 1804301445 HW-U01 HW-DB Short Lamp Holder Lead Holder HW-U10 Dummy Block Lamp Circuit Components Long Lamp Holder A G R S W 1. Dummy blocks (no contacts) are used with an odd number of contact blocks. 2. Combining HW-U10R and HW-U01R result in overlapping contacts. 1. In place of j, specify the Button Color Code. (See table below) 2. In place of k, specify the LED Color Code. 3. *Not available in blue. Style Code Contactors 2 pos* Color Amber Green Red Blue White Contact Blocks Style Lens for Illuminated Push-Pull Stop Switches (ø40mm) A G R S W Timers Lens for Illuminated Pushlock Turn Reset Stop Switches (ø40mm, red only) Color Code l LED Color Codes j Button Color Codes Buttons and Lenses Color Amber Green Red Blue White Relays & Sockets ø 40mm Illuminated and Non-illuminated Push-Pull Part Number LSTD-6l LSTD-1l LSTD-2l LSTD-H2l LSTD-M4l Signaling Lights Style k Lens Color Codes All Transformers step down to 6V (use 6V lamp). This is needed for full voltage models, and must be mounted on the first deck (closest to the operator). 727 Switches & Pilot Devices Switches & Pilot Devices ø30mm - TWND Series Signaling Lights Pilot Lights (Assembled) Assembled Pilot Lights Relays & Sockets A Function P: P D 1 126 D NU R Lens Color Code Pilot Light A: Amber G: Green R: Red S: Blue W: White Y: Yellow Series Designation D: TWND Series Lens Shape 1: Dome D: LED Contactors Timers Rated Operational Voltage (Primary) Transformer Type 126: 120V AC 246: 240V AC 486: 480V AC Full Voltage Type 66: 6VAC/DC 11: 12VAC/DC 22: 24VAC/DC QH2: 120VAC QM4: 240VAC Use only when interpreting part numbers. Do not use for developing part numbers. LED Pilot Lights Style k Lens Color Codes Operating Voltage Part Number Color Code LED Amber A Green G Terminal Blocks Transformer Dome 120V AC 240V AC 480V AC APD1126DNUk APD1246DNUk APD1486DNUk — Circuit Breakers R S White W Yellow Y l Full Voltage Codes Full Voltage Dome APD1lDNk 1. In place of k, specify the Lens/LED Color Code. 2. In place of l, specify the Full Voltage Code (LED voltage). 3. Yellow pilot light comes with white LED. 728 Red Blue Voltage Code 6V AC/DC 66 12V AC/DC 11 24V AC/DC 22 120V AC QH2 240V AC QM4 www.IDEC.com 1804301445 Switches & Pilot Devices ø30mm - TWND Series Switches & Pilot Devices Pilot Lights (Sub-Assembled) Transformer* + Operator + Lamp + Lens = Complete Part * Not required for full voltage units. plus Operators Signaling Lights One Each from Left Column One Selection from Right Column Full Voltage Clips Style Part Number Part Number APD-F APD09ST8 Relays & Sockets Transformer or FULL Voltage Primary Voltage (50/60Hz) Required for all full voltage models. Two pieces each. 2 clips required for full voltage pilot lights Transformers (only for Pilot Lights) Lenses Style Style Primary Voltage (50/60Hz) Part Number Part Number TWD-0126 240V AC TWD-0246 480V AC TWD-0486 Timers LED Dome Lens 120V AC APN106LN-k 6V secondary voltage (use 6V lamp). 1. In place of k, specify the Lens Color Code. k Lens Color Codes Style LED Voltage Part Number 6V AC/DC LSTD-6l 12V AC/DC LSTD-1l LSTD-2l 120V AC LSTD-H2l 240V AC LSTD-M4l Color Code Color Code Amber Green Red Blue White Yellow A G R S W Y Amber Green Red Blue White A G R S W Yellow LED not available, use white LED with Yellow lens. Terminal Blocks 24V AC/DC l LED Color Codes Contactors Lamps 1. In place of k, specify the LED color code. 2. The LED contains a current-limiting resistor and a protection diode. Circuit Breakers 1804301445 800-262-IDEC (4332) • USA & Canada 729 Switches & Pilot Devices Switches & Pilot Devices ø30mm - TWND Series Timers Relays & Sockets Signaling Lights Illuminated Pushbuttons (Assembled) Assembled Illuminated Pushbuttons A L ( ) D 2 126 11 NU R Function Lens Color Code L: Momentary Action OL: Maintained Action A: Amber G: Green R: Red S: Blue W: White Y: Yellow Bezel Shape Blank: Octagonal F: Full Shroud Series Designation D: LED D: TWND Series Contactors D Contact Arrangement Lens Shape 20: 2NO 02: 2NC 11: 1NO-1NC 2: Extended 3: Mushroom ø 40mm Terminal Blocks Rated Operational Voltage (Primary) Transformer Type 126: 120V AC 246: 240V AC 486: 480V AC Full Voltage Type 66: 6VAC/DC 11: 12VAC/DC 22: 24VAC/DC QH2: 120VAC QM4: 240VAC Circuit Breakers 1. Use only when interpreting part numbers. Do not use for developing part numbers. 2. All transformers step down to 6V. 730 www.IDEC.com 1804301445 Switches & Pilot Devices ø30mm - TWND Series Switches & Pilot Devices Illuminated Pushbuttons (Assembled) Illuminated Pushbuttons k Lens Color Codes Style Contacts Extended Lens Full Voltage Momentary Maintained ALD2l11DNUk ALD2l20DNUk ALD2l02DNUk AOLD2l11DNUk AOLD2l20DNUk AOLD2l02DNUk Color Code Amber Green Red Blue White Yellow A G R S W Y Signaling Lights 1NO-1NC 2NO 2NC Part Number l Full Voltage Codes 1NO-1NC 2NO 2NC ALD2 m 11DNUk ALD2 m 20DNUk ALD2 m 02DNUk AOLD2 m 11DNUk AOLD2 m 20DNUk AOLD2 m 02DNUk Full Voltage 1NO-1NC 2NO 2NC ALFD2l11DNUk ALFD2l20DNUk ALFD2l02DNUk AOLFD2l11DNUk AOLFD2l20DNUk AOLFD2l02DNUk Extended Lens with Full Shroud Transformer 1NO-1NC 2NO 2NC ALFD2 m 11DNUk ALFD2 m 20DNUk ALFD2 m 02DNUk AOLFD2 m 11DNUk AOLFD2 m 20DNUk AOLFD2 m 02DNUk Voltage Code 6V AC/DC 12V AC/DC 24V AC/DC 120V AC 240V AC 66 11 22 QH2 QM4 Relays & Sockets Transformer m Transformer Voltage Codes Voltage Code 120VAC 126 240VAC 246 480VAC 486 6V secondary voltage (uses 6V LED). ø 40mm Mushroom Lens 1NO-1NC 2NO 2NC ALD3l11DNUk ALD3l20DNUk ALD3l02DNUk AOLD3l11DNUk AOLD3l20DNUk AOLD3l02DNUk Transformer 1NO-1NC 2NO 2NC ALD3 m 11DNUk ALD3 m 20DNUk ALD3 m 02DNUk AOLD3 m 11DNUk AOLD3 m 20DNUk AOLD3 m 02DNUk Timers Contactors 1. 2. 3. 4. 5. Full Voltage In place of k, specify the Lens Color Code. In place of l, specify the Full Voltage Code (LED voltage). In place of m, specify the Transformer Voltage Code. Light is independent of switch position. Yellow pushbutton comes with white LED only. Terminal Blocks Circuit Breakers 1804301445 800-262-IDEC (4332) • USA & Canada 731 Switches & Pilot Devices Switches & Pilot Devices ø30mm - TWND Series Illuminated Pushbuttons (Sub-Assembled) Transformer* + Contact Block + Operator + LED + Lens = Complete Part Signaling Lights *Not required for full voltage types. Operators Lamps Extended Relays & Sockets Style Part Number Style Momentary Maintained ALD2300T8 AOLD2300T8 LED k Lens Color Codes Voltage 6V AC/DC 12V AC/DC 24V AC/DC 120V AC 240V AC Part Number LSTD-6l LSTD-1l LSTD-2l LSTD-H2l LSTD-M4l 1. In place of k, specify the LED color code. 2. The LED contains a current-limiting resistor and a protection diode. Extended with Full Shroud ALFD2300T8 Color Code Amber Green Red Blue White Yellow A G R S W Y Color Amber Green Red Blue White Code A G R S W l LED Color Codes AOLFD2300T8 Timers 40mm Mushroom ALD2300T8 Contact Blocks Lenses Part Number Extended ALN06LU-k All Control Units HW-U10 HW-U01 HW-U10R (early make) HW-U01R (late break) Dummy Block ø 40mm Mushroom ALN3LU-k 1. Dummy blocks (no contacts) are used with an odd number of contact blocks. 2. Combining HW-U10R and HW-U01R result in overlapping contacts (remain on, or closed, when switch is moved between two positions). Style Lamp Circuit Components Style HW-DB Transformers In place of k, specify the Lens Color Code. Terminal Blocks Part Number 1NO 1NC Style Style Contactors AOLD2300T8 Yellow lens only. Yellow LED not available, use white LED. Application Part Number Transformers Short Lamp Holder Used with a one contact block TW-LH1 Primary Voltage (50/60Hz) Part Number 120V AC HW-T126 240V AC HW-T246 480V AC HW-L486 Description Part Number Spring-Up HW-GA1N 6V secondary voltage (use 6V LED). Circuit Breakers Long Lamp Holder Used with Full-size Transformer and two contact blocks Used with Full Voltage Adaptor and two contact blocks Lead Holder Used with TW-LH2 holder when using four contact blocks TW-LH2 HW-LH3 Transformers/Full Voltage Modules Style Full voltage model (mounted directly to the operator on the first deck) All Transformers step down to 6V (use 6V lamp). This is needed for full voltage models, and must be mounted on the first deck (closest to the operator). 732 www.IDEC.com 1804301445 Switches & Pilot Devices ø30mm - TWND Series Switches & Pilot Devices Non-Illuminated Selector Switches (Assembled) Signaling Lights Relays & Sockets Assembled Selector Switches A S D 2 ( ) ( ) 11 NU – ( ) Function Circuit Number S: Selector Switch (See Circuit # column of Selector Switch Contact Arrangement Chart on beginning on page 739.) Series Designation D: TWND Series 01: 1NC 02: 2NC 04: 4NC 22: 2NO-2NC Spring Return Action Operator Style Code Blank: Maintained 1: Spring return from Right 2: Spring return from Left 3: 2-Way spring return from Left and Right Blank: Knob Operator L: Lever Operator K: Key Operator Contactors 2: 2-Position 3: 3-Position 10: 1NO 20: 2NO 40: 4NO 11: 1NO-1NC Number of Positions Timers Contact Arrangement Code Terminal Blocks 1. Use only when interpreting part numbers. Do not use for developing part numbers. 2. Custom key removal codes available. Please contact IDEC for details. Circuit Breakers 1804301445 800-262-IDEC (4332) • USA & Canada 733 Switches & Pilot Devices Non-Illuminated Selector Switches (Assembled) Non-Illuminated 2-Position Selector Switches Style Mounting L 1NO 1 2 O O X O 1NC 1 2 X O O O 1NO 1NC 1 2 O X X O 2NO 1 2 O O X X 2NC 1 2 X X O O 1 2 3 4 1 2 3 4 O X O X O O X X X O X O X X O O 2NO 2NC R Spring Return from Right Maintained L L R Spring Return from Left L R R Knob Lever Key Knob Lever Key Knob Lever Key Knob Lever Key Knob Lever Key ASD210NU ASD2L10NU ASD2K10NU ASD201NU ASD2L01NU ASD2K01NU ASD211NU ASD2L11NU ASD2K11NU ASD220NU ASD2L20NU ASD2K20NU ASD202NU ASD2L02NU ASD2K02NU ASD2110NU ASD21L10NU ASD21K10NU ASD2101NU ASD21L01NU ASD21K01NU ASD2111NU ASD21L11NU ASD21K11NU ASD2120NU ASD21L20NU ASD21K20NU ASD2102NU ASD21L02NU ASD21K02NU ASD2210NU ASD22L10NU ASD22K10NU ASD2201NU ASD22L01NU ASD22K01NU ASD2211NU ASD22L11NU ASD22K11NU ASD2220NU ASD22L20NU ASD22K20NU ASD2202NU ASD22L02NU ASD22K02NU Knob Lever Key ASD222NU ASD2L22NU ASD2K22NU ASD2122NU ASD21L22NU ASD21K22NU ASD2222NU ASD22L22NU ASD22K22NU Knob Lever Key ASD222NU-111 ASD2L22NU-111 ASD2K22NU-111 ASD2122NU-111 ASD21L22NU-111 ASD21K22NU-111 ASD2222NU-111 ASD22L22NU-111 ASD22K22NU-111 1. The truth table indicates the operating position of contact block when the operator is switched to that position. X = On (closed contacts) O = Off (open contacts) X X = Overlapping Contacts: Remain on (closed contacts) when switch is moved between these two positions. 2. All knob and lever selector switches come in black. Other colors are available by ordering the knob or lever separately. 3. Custom contact arrangements available, see page 739. Non-Illuminated 3-Position Selector Switches Style Part Number Maintained Spring Return from Right Spring Return from Left L C C C C Spring Return Two-Way Mounting Operator Position Contact Terminal Blocks Contactors Timers 2NO 2NC 2NO 1 2 X O O O O X Knob Lever Key ASD320NU ASD3L20NU ASD3K20NU ASD3120NU ASD31L20NU ASD31K20NU ASD3220NU ASD32L20NU ASD32K20NU ASD3320NU ASD33L20NU ASD33K20NU 2NC 1 2 O X X X X O Knob Lever Key ASD302NU ASD3L02NU ASD3K02NU ASD3102NU ASD31L02NU ASD31K02NU ASD3202NU ASD32L02NU ASD32K02NU ASD3302NU ASD33L02NU ASD33K02NU 2NO 2NC 1 2 3 4 X O O X O O X X O X X O Knob Lever Key ASD322NU ASD3L22NU ASD3K22NU ASD3122NU ASD31L22NU ASD31K22NU ASD3222NU ASD32L22NU ASD32K22NU ASD3322NU ASD33L22NU ASD33K22NU 1 2 3 4 1 2 3 4 1 2 3 4 X X O O O O O O X O X O X O O X O X O X O X O X Knob Lever Key ASD322NU-309 ASD3L22NU-309 ASD3K22NU-309 ASD3122NU-309 ASD31L22NU-309 ASD31K22NU-309 ASD3222NU-309 ASD32L22NU-309 ASD32K22NU-309 ASD3322NU-309 ASD33L22NU-309 ASD33K22NU-309 Knob Lever Key ASD322NU-310 ASD3L22NU-310 ASD3K22NU-310 ASD3122NU-310 ASD31L22NU-310 ASD31K22NU-310 ASD3222NU-310 ASD32L22NU-310 ASD32K22NU-310 ASD3322NU-310 ASD33L22NU-310 ASD33K22NU-310 Knob Lever Key ASD340NU ASD3L40NU ASD3K40NU ASD3140NU ASD31L40NU ASD31K40NU ASD3240NU ASD32L40NU ASD32K40NU ASD3340NU ASD33L40NU ASD33K40NU 1 2 3 4 O X O X O X X O X O X O O O O O X X X X Knob Lever Key ASD304NU ASD3L04NU ASD3K04NU ASD3104NU ASD31L04NU ASD31K04NU ASD3204NU ASD32L04NU ASD32K04NU ASD3304NU ASD33L04NU ASD33K04NU 2NO 2NC 2NO 2NC 4NO Circuit Breakers Part Number Operator Position Contact Relays & Sockets Signaling Lights Switches & Pilot Devices ø30mm - TWND Series 4NC 734 R X O X O L R L www.IDEC.com R L R L C R 1804301445 Switches & Pilot Devices ø30mm - TWND Series Switches & Pilot Devices Non-Illuminated Selector Switches (Sub-Assembled) Contact Blocks + Operator + Knob or Lever* + Color Insert* = Complete Part† Operators Style Signaling Lights 1. *Not needed with key type switches. 2. †Knob type shown. Handles and Inserts Position Description 2 3 Key 3 Spring return from right ASD0213T8 Spring return from left ASD0224T8 Maintained, Cam 1 Maintained, Cam 2 ASD0302T8 ASD0306T8 Spring return from right, Cam 1 Spring return from right, Cam 2 ASD0314T8 ASD0310T8 Spring return from left, Cam 1 Spring return from left, Cam 2 ASD0323T8 ASD0328T8 Spring return from left/right, Cam 1 Spring return from left/right, Cam 2 ASD0335T8 ASD0339T8 Maintained ASD0201KT8 Spring return from right ASD0213KT8 Spring return from left ASD0224KT8 Maintained, Cam 1 Maintained, Cam 2 ASD0302KT8 ASD0306KT8 Spring return from right, Cam 1 Spring return from right, Cam 2 ASD0302KT8B ASD0310KT8B Spring return from left, Cam 1 Spring return from left, Cam 2 ASD0323KT8 ASD0310KT8B Spring return from left/right, Cam 1 Spring return from left/right, Cam 2 ASD0335KT8 ASD3K339KT8 1. Order knobs, levers, color inserts separately (see below). 2. For key switches, keys are removable in all maintained positions. Other options available, contact IDEC for details. 3. See page 741 “Operator Truth Tables” for details of difference between cams. j Color Codes Code Black B Blue S Green G Red R Yellow Y White W Part Number Knob ASDHHY-j Lever ASDHHL-j* Color Insert TW-HC1-j 1. In place of j, specify the Color Code. *Not available in yellow. Contact Blocks Style All Control Units Dummy Block Part Number 1NO 1NC HW-U10 HW-U01 HW-U10R (early make) HW-U01R (late break) HW-DB 1. Dummy blocks (no contacts) are used with an odd number of contact blocks. 2. Combining HW-U10R and HW-U01R result in overlapping contacts (remain on, or closed, when switch is moved between two positions). Terminal Blocks Knob/Lever Color Style Contactors ASD0201T8 Timers 2 Maintained Relays & Sockets Knob/Lever Part Number 1804301445 Circuit Breakers 1. Knob/Lever not available in white. 2. Color inserts not available in Black. 3. Lever not available in yellow. 800-262-IDEC (4332) • USA & Canada 735 Switches & Pilot Devices ø30mm - TWND Series Signaling Lights Switches & Pilot Devices Illuminated Selector Switches (Assembled) Relays & Sockets Assembled Illuminated Selector Switches A SL D 2 (2) 22 11 DN U – 111 – R Function Lens Color Code SL: Illuminated Selector Switch A: Amber G: Green R: Red S: Blue W: White Y: Yellow Series Designation D: TWND series Timers Number of Positions Circuit Code Number 2: 2-Position 3: 3-Position See Circuit # column of Selector Switch Contact Arrangement Charts on page 739. Spring Return Action Circuit Breakers Terminal Blocks Contactors Blank: Maintained 1: Spring return from Right 2: Spring return from Left 3: Two-Way spring return from Left and Right D: LED Lamp Rated Operational Voltage (Primary) Transformer Type 136: 120V AC 256: 240V AC 486: 480V AC Full Voltage Type 66: 6VAC/DC 11: 12VAC/DC 22: 24VAC/DC QH2: 120VAC QM4: 240VAC Contact Arrangement Code 20: 2NO 02: 2NC 40: 4NO 04: 4NC 11: 1NO-1NC 22: 2NO-2NC Use only when interpreting part numbers. Do not use for developing part numbers. 736 www.IDEC.com 1804301445 Switches & Pilot Devices ø30mm - TWND Series Switches & Pilot Devices Illuminated Selector Switches (Assembled) Illuminated 2-Position Selector Switches k Lens Color Codes Mounting 1 2 1 2 1 2 1 2 3 4 1 2 3 4 2NO 2NC 2NO 2NC 2NO 2NC L R O X O O X X O X O X O O X X X O X X O O X O X O X X O O Maintained Lamp Circuit Type L Spring Return from Left Spring Return from Right L R L R R Transformer Full Voltage Transformer Full Voltage Transformer Full Voltage ASLD2 m11DNUk ASLD2l11DNUk ASLD2 m20DNUk ASLD2l20DNUk ASLD2 m02DNU-k ASLD2l02DNU-104-k ASLD21 m11DNUk ASLD21l11DNUk ASLD21 m20DNUk ASLD21l20DNUk ASLD21 m02DNU-k ASLD21l02DNU-k ASLD22 m11DNUk ASLD22l11DNUk ASLD22 m20DNUk ASLD22l20DNUk ASLD22 m02nDNU-k ASLD22l02DNU-k Transformer Full Voltage ASLD2 m22DNUk ASLD2l22DNUk ASLD21 m22DNUk ASLD21l22DNUk ASLD22 m22DNUk ASLD22l22DNUk Transformer Full Voltage ASLD2 m22DNU-111-k ASLD2l22DNU-111-k ASLD21 m22DNU-111-k ASLD21l22DNU-111-k Color Code Amber A Green G Red R Blue S White W Yellow Y l Full Voltage Codes ASLD22 m22DNU-111-k ASLD22l22DNU-111-k Voltage Code 6V AC/DC 66 12V AC/DC 11 24V AC/DC 22 120V AC QH2 240V AC QM4 Relays & Sockets 1NO 1NC Part Number Operator Position Signaling Lights Contact Style Illuminated 3-Position Selector Switches, Maintained and Spring Return 2NC 2NO 2NC 2NO 2NC 4NC C X O O X O O X X O O X X O X X O X O X O O O O O X X X X X O O X X X O O O O O O X O X O O X O X R O X X O O X X O X O O X O X O X O X O X X O X O Lamp Circuit Type L C R Spring Return From Right L C Spring Return from Left L R C R Spring Return Two-Way L C R Transformer Full Voltage Transformer Full Voltage ASLD3 m 20DNUk ASLD3l20DNUk ASLD3 m 02DNUk ASLD3l02DNUk ASLD31 m 20DNUk ASLD31l20DNUk ASLD31 m 02DNUk ASLD31l02DNUk ASLD32 m 20DNUk ASLD32l20DNUk ASLD32 m 02DNUk ASLD32l02DNUk ASLD33 m 20DNUk ASLD33l20DNUk ASLD33 m 02DNUk ASLD33l02DNUk Transformer Full Voltage ASLD3 m 22DNUk ASLD3l22DNUk ASLD31 m 22DNUk ASLD31l22DNUk ASLD32 m 22DNUk ASLD32l22DNUk ASLD33 m 22DNUk ASLD33l22DNUk Transformer Full Voltage ASLD3 m 22DNU-309-k ASLD3l22DNU-309-k ASLD31 m 22DNU-309-k ASLD31l22nDNU-309-k ASLD32 m 22DNU-309-k ASLD32l22DNU-309-k ASLD33 m 22DNU-309-k ASLD33l22DNU-309-k Transformer Full Voltage ASLD3 m 22DNU-310-k ASLD3l22DNU-310-k ASLD31 m 22DNU-310-k ASLD31l22DNU-310-k ASLD32 m 22DNU-310-k ASLD32l22DNU-310-k ASLD33 m 22DNU-310-k ASLD33l22DNU-310-k Transformer Full Voltage ASLD3 m 40DNUk ASLD3l40DNUk ASLD31 m 40DNUk ASLD31l40DNUk ASLD32 m 40DNUk ASLD32l40DNUk ASLD33 m 40DNUk ASLD33l40DNUk Transformer Full Voltage ASLD3 m 04DNUk ASLD3l04DNUk ASLD31 m 04DNUk ASLD31l04DNUk ASLD32 m 04DNUk ASLD32l04DNUk ASLD33 m 04DNUk ASLD33l04DNUk m Transformer Voltage Codes Voltage Code 120VAC 240VAC 480VAC 136 256 486 Circuit Breakers 1. In place of k, specify the Lens/LED Color Code, in place of l, specify the Full Voltage (LED voltage) Code, in place of m, specify the Transformer Voltage Code. 2. The truth table indicates the operating position of contact block when the operator is switched to that position. X = On (Closed Contacts) O = Off (Open Contacts) X X = Overlapping Contacts: Remain on (closed contacts) when switch is moved between these positions 3. Yellow selector switch comes with white LED. Terminal Blocks 4NO L Maintained Contactors 2NO 2NC 1 2 1 2 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 Part Number Operator Position Timers 2NO Mounting Contact Style Transformers step down to 6V (use 6V LED). 1804301445 800-262-IDEC (4332) • USA & Canada 737 Switches & Pilot Devices Signaling Lights Switches & Pilot Devices ø30mm - TWND Series Illuminated Selector Switches (Sub-Assembled) Transformer* + Contact Block + Operator + Operators Style Lens Description Part Number 2 Maintained ASLD0201T8 3 Maintained, Cam 1 Maintained, Cam 2 ASLD0302T8 ASLD0306T8 Spring return from right ASLD0213T8 Relays & Sockets 2 3 Spring return from left ASLD0224T8 Spring return from right, Cam 1 Spring return from right, Cam 2 ASLD0314T8 ASLD0310T8 Spring return from left, Cam 1 Spring return from left, Cam 2 ASLD0323T8 ASLD0328T8 Spring return from left/right, Cam 1 Spring return from left/right, Cam 2 ASLD0335T8 ASLD0339T8 Complete Part Part Number Knob ASLNHU-l k Lamps Style LED Style Application Short Lamp Holder Used with a one contact block Voltage Part Number 6V AC/DC LSTD-6l 12V AC/DC LSTD-1l 24V AC/DC LSTD-2l 120V AC LSTD-H2l 240V AC LSTD-M4l Lead Holder Used with TW-LH2 holder when using four contact blocks Terminal Blocks HW-LH3 Style Description Part Number Spring-Up HW-GA1N Full voltage model (mounted directly to the operator on the first deck) Transformers Style Transformers Primary Voltage (50/60Hz) Part Number 120V AC HW-T126 240V AC HW-T246 480V AC HW-L486 6V secondary voltage. Style Part Number k Lens Color Codes l LED Color Codes 1NO 1NC Color Code Color Code HW-U10 HW-U10 Amber A Amber A HW-U10R (early make) HW-U10R (late break) Green G Green G Red R Red R HW-DB Blue S Blue S White W White W Yellow Y 1. Dummy blocks (no contacts) are used with an odd number of contact blocks. 2. Combining HW-U10R and HW-U01R result in overlapping contacts (remain on, or closed, when switch is moved between two positions). 738 TW-LH2 Used with Full Voltage Adaptor and two contact blocks All Transformers step down to 6V (use 6V lamp). Contact Blocks Dummy Block TW-LH1 Used with Full-size Transformer and two contact blocks Long Lamp Holder 1. In place of k, specify the LED color code. 2. The LED contains a current-limiting resistor and a protection diode. All Control Units Part Number Transformers/Full Voltage Modules Style Circuit Breakers = Lamp Circuit Components Position Lenses Timers + *Not required for full voltage units. Operator Contactors Lamp www.IDEC.com Yellow lens only. Yellow LED not available, use white LED. 1804301445 Switches & Pilot Devices ø30mm - TWND Series Switches & Pilot Devices Contact Arrangement Charts How to Read Contact Arrangement Charts To determine contact block mounting position, first make sure the selector switch is oriented as shown on the right Contact Block Mounting Position Contact Arrangement Type and quantity of switch contacts Circuit Number * N/D = No designation Operator Position Truth table indicates the operating position of contact block when operator is switched to that position. Contact Block Part Number X = On (Closed Contacts) O = Off (Open Contacts) X X = Overlapping Contacts: Remain on (closed) when switch is moved between these two positions Part number to use when ordering sub-assembly contact blocks, as required for use with corresponding mounting position Contact Arrangement Chart: 2-Position Selector Switches Style 1NO N/D 1NC N/D 1NO 1NC 103 600 601 N/D 2NC N/D N/D 2NO 2NC 110 4NO 1804301445 N/D 1 O X HW-U10 2 O O HW-DB 1 X O HW-U01 2 O O HW-DB 1 O X HW-U10 2 X O HW-U01 1 X O HW-U01 2 O X HW-U10 1 O X HW-U10R 2 X O HWW-U01R 1 X O HW-U01R 2 O X HW-U10R 1 O X HW-U10 2 O X HW-U10 1 X O HW-U01 2 X O HW-U01 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 O X O X X O X O O O X X O O O O X O X O O X O X X X O O X X X X HW-U10 HW-U01 HW-U10 HW-U01 HW-U01 HW-U10 HW-U01 HW-U10 HW-U10 HW-U10 HW-U01 HW-U01 HW-U10 HW-U10 HW-U10 HW-U10 L R L R Spring Return from Left L R Knob/Lever Key Illuminated Knob ASD0201T8 ASD0201KT8 ASLD0201T8 ASD0213T8 ASD0213KT8 ASLD0213T8 ASD0224T8 ASD0224KT8 ASLD0224T8 Knob/Lever Key Illuminated Knob ASD0201T8 ASD0201KT8 ASLD0201T8 ASD0213T8 ASD0213KT8 ASLD0213T8 ASD0224T8 ASD0224KT8 ASLD0224T8 Knob/Lever Key Illuminated Knob ASD0201T8 ASD0201KT8 ASLD0201T8 ASD0213T8 ASD0213KT8 ASLD0213T8 ASD0224T8 ASD0224KT8 ASLD0224T8 Knob/Lever Key Illuminated Knob ASD0201T8 ASD0201KT8 ASLD0201T8 ASD0213T8 ASD0213KT8 ASLD0213T8 ASD0224T8 ASD0224KT8 ASLD0224T8 Knob/Lever Key Illuminated Knob ASD0201T8 ASD0201KT8 ASLD0201T8 ASD0213T8 ASD0213KT8 ASLD0213T8 ASD0224T8 ASD0224KT8 ASLD0224T8 Knob/Lever Key Illuminated Knob ASD0201T8 ASD0201KT8 ASLD0201T8 ASD0213T8 ASD0213KT8 ASLD0213T8 ASD0224T8 ASD0224KT8 ASLD0224T8 Knob/Lever Key Illuminated Knob ASD0201T8 ASD0201KT8 ASLD0201T8 ASD0213T8 ASD0213KT8 ASLD0213T8 ASD0224T8 ASD0224KT8 ASLD0224T8 Knob/Lever Key Illuminated Knob ASD0201T8 ASD0201KT8 ASLD0201T8 ASD0213T8 ASD0213KT8 ASLD0213T8 ASD0224T8 ASD0224KT8 ASLD0224T8 Knob/Lever Key Illuminated Knob ASD0201T8 ASD0201KT8 ASLD0201T8 ASD0213T8 ASD0213KT8 ASLD0213T8 ASD0224T8 ASD0224KT8 ASLD0224T8 Knob/Lever Key Illuminated Knob ASD0201T8 ASD0201KT8 ASLD0201T8 ASD0213T8 ASD0213KT8 ASLD0213T8 ASD0224T8 ASD0224KT8 ASLD0224T8 Knob/Lever Key Illuminated Knob ASD0201T8 ASD0201KT8 ASLD0201T8 ASD0213T8 ASD0213KT8 ASLD0213T8 ASD0224T8 ASD0224KT8 ASLD0224T8 Knob/Lever Key Illuminated Knob ASD0201T8 ASD0201KT8 ASLD0201T8 ASD0213T8 ASD0213KT8 ASLD0213T8 ASD0224T8 ASD0224KT8 ASLD0224T8 800-262-IDEC (4332) • USA & Canada Circuit Breakers 111 R Spring Return from Right Terminal Blocks 2NO L Maintained Description Contactors 1NO-EM 1NC-LB Contact Block Part Number Timers N/D Mounting Position Operator Part Number Relays & Sockets Contact Circuit Number Operator Position Signaling Lights Position or mounting contact blocks on operator , for full voltage illuminated selectors, full voltage adaptor, HW-GA1N, is always mounted on the first deck connected to the operators 739 Switches & Pilot Devices Switches & Pilot Devices ø30mm - TWND Series Contact Arrangement Chart: 3-Position Selector Switches Style Operator Position Contact Circuit Number Signaling Lights 202 203 1NO 1NC Relays & Sockets 302 303 N/D 2NO 301 Timers 304 2NC N/D Contactors N/D 210 2NO 2NC Terminal Blocks 308 309 Circuit Breakers 310 Mounting Position Contact Block Part Number L C 1 X O O HW-U10 2 X X O HW-U01 1 O X X HW-U01 2 O O X HW-U10 1 X O X HW-U10 2 X X O HW-U10 1 O X O HW-U01 2 O O X HW-U10 1 X O O HW-U10 2 O O X HW-U10 1 X O X HW-U10 2 O O X HW-U10 1 O X O HW-U01 2 X X O HW-U01 1 O X X HW-U01 2 X X O HW-U01 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 X O O X O O X O X X O X X X X X O X O X O O X O X O X HW-U10 HW-U10 HW-U01 HW-U01 HW-U01 HW-U10 HW-U01 HW-U10 HW-U10 HW-U01 HW-U10 HW-U01 HW-U10 HW-U01 HW-U01 HW-U10 HW-U01 HW-U10 HW-U01 HW-U10 O O O O X X X X X X O O O O O O X X O X O O X O X O X X O X O X O R Maintained Description L C R Operator Part Number Spring Return Spring Return from Right from Left L C R L C R Two-Way L C R Knob/Lever Key Illuminated Knob ASD0302T8 ASD0302KT8 ASLD0302T8 ASD0314T8 ASD0314KT8 ASLD0314T8 ASD0323T8 ASD0323KT8 ASLD0323T8 ASD0335T8 ASD0335KT8 ASD0335T8 Knob/Lever Key Illuminated Knob ASD0302T8 ASD0302KT8 ASLD0302T8 ASD0314T8 ASD0314KT8 ASLD0314T8 ASD0323T8 ASD0323KT8 ASLD0323T8 ASD0335T8 ASD0335KT8 ASD0335T8 Knob/Lever Key Illuminated Knob ASD0306T8 ASD0306KT8 ASLD0306T8 ASD0310T8 ASD0301KT8 ASLD310T8 ASD0328T8 ASD0328KT8 ASLD0328T8 ASD0339T8 ASD0339KT8 ASLD0339T8 Knob/Lever Key Illuminated Knob ASD0306T8 ASD0306KT8 ASLD0306T8 ASD0310T8 ASD0301KT8 ASLD310T8 ASD0328T8 ASD0328KT8 ASLD0323T8 ASD0339T8 ASD0339KT8 ASLD0339T8 Knob/Lever Key Illuminated Knob ASD0302T8 ASD0302KT8 ASLD0302T8 ASD0314T8 ASD0314KT8 ASLD0314T8 ASD0323T8 ASD0323KT8 ASLD0323T8 ASD0335T8 ASD0335KT8 ASD0335T8 Knob/Lever Key Illuminated Knob ASD0306T8 ASD0306KT8 ASLD0306T8 ASD0310T8 ASD0301KT8 ASLD310T8 ASD0328T8 ASD0328KT8 ASLD0328T8 ASD0339T8 ASD0339KT8 ASLD0339T8 Knob/Lever Key Illuminated Knob ASD0306T8 ASD0306KT8 ASLD0306T8 ASD0310T8 ASD0301KT8 ASLD310T8 ASD0328T8 ASD0328KT8 ASLD0328T8 ASD0339T8 ASD0339KT8 ASLD0339T8 Knob/Lever Key Illuminated Knob ASD0302T8 ASD0302KT8 ASLD0302T8 ASD0314T8 ASD0314KT8 ASLD0314T8 ASD0323T8 ASD0323KT8 ASLD0323T8 ASD0335T8 ASD0335KT8 ASD0335T8 Knob/Lever Key Illuminated Knob ASD0302T8 ASD0302KT8 ASLD0302T8 ASD0314T8 ASD0314KT8 ASLD0314T8 ASD0323T8 ASD0323KT8 ASLD0323T8 ASD0335T8 ASD0335KT8 ASD0335T8 Knob/Lever Key Illuminated Knob ASD0302T8 ASD0302KT8 ASLD0302T8 ASD0314T8 ASD0314KT8 ASLD0314T8 ASD0323T8 ASD0323KT8 ASLD0323T8 ASD0335T8 ASD0335KT8 ASD0335T8 Knob/Lever Key Illuminated Knob ASD0306T8 ASD0306KT8 ASLD0306T8 ASD0310T8 ASD0301KT8 ASLD310T8 ASD0328T8 ASD0328KT8 ASLD0328T8 ASD0339T8 ASD0339KT8 ASLD0339T8 Knob/Lever Key Illuminated Knob ASD0306T8 ASD0306KT8 ASLD0306T8 ASD0310T8 ASD0301KT8 ASLD310T8 ASD0328T8 ASD0328KT8 ASLD0328T8 ASD0339T8 ASD0339KT8 ASLD0339T8 Knob/Lever Key Illuminated Knob ASD0306T8 ASD0306KT8 ASLD0306T8 ASD0310T8 ASD0301KT8 ASLD310T8 ASD0328T8 ASD0328KT8 ASLD0328T8 ASD0339T8 ASD0339KT8 ASLD0339T8 1. Each operator sub-assembly is available as an “02” and an “06” for 3-position selector switches. The internal cam of an “02” is different from that of an “06”. This results in designated combinations of open and closed contacts in the various operator positions. 2. N/D = No circuit number designation required in assembled part number. 3. X = On (closed contacts) O = Off (open contacts). X X Overlapping contacts remain on (closed) when switch is moved between these two positions. 740 www.IDEC.com 1804301445 Switches & Pilot Devices ø30mm - TWND Series Switches & Pilot Devices Contact Arrangement Chart: 3-Position Selector Switches Style Operator Position Contact Circuit Number Mounting Position N/D 305 N/D 314 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 X O X O X O X O O X O O O O O O O O X 4 X L X X X X O X O X X X X X X O X O O O O HW-U10 HW-U10 HW-U10 HW-U10 HW-U10 HW-U10 HW-U10 HW-U10 HW-U01 HW-U01 HW-U01 HW-U01 HW-U01 HW-U01 HW-U01 X O HW-U01 X X O X O X O R C R L C L R C R Two-Way C L R Knob/Lever Key Illuminated Knob ASD0302T8 ASD0302KT8 ASLD0302T8 ASD0314T8 ASD0314KT8 ASLD0314T8 ASD0323T8 ASD0323KT8 ASLD0323T8 ASD0335T8 ASD0335KT8 ASD0335T8 Knob/Lever Key Illuminated Knob ASD0306T8 ASD0306KT8 ASLD0306T8 ASD0310T8 ASD0301KT8 ASLD0310T8 ASD0328T8 ASD0328KT8 ASLD0328T8 ASD0339T8 ASD0339KT8 ASLD0339T8 Knob/Lever Key Illuminated Knob ASD0302T8 ASD0302KT8 ASLD0302T8 ASD0314T8 ASD0314KT8 ASLD0314T8 ASD0323T8 ASD0323KT8 ASLD0323T8 ASD0335T8 ASD0335T8 ASD0335T8 Knob/Lever Key Illuminated Knob ASD0306T8 ASD0306KT8 ASLD0306T8 ASD0310T8 ASD0301KT8 ASLD0301T8 ASD0328T8 ASD0328KT8 ASLD0328T8 ASLD0339T8 ASD0339KT8 ASLD0339T8 Relays & Sockets 4NC C Maintained Description Signaling Lights 4NO L Contact Block Part Number Operator Part Number Spring Return Spring Return from Right from Left 1. Each operator sub-assembly is available as an “02” and an “06” for 3-position selector switches. The internal cam of an “02” is different from that of an “06”. This results in designated combinations of open and closed contacts in the various operator positions. 2. N/D = No circuit number designation required in assembled part number. 3. X = On (closed contacts) O = Off (open contacts). X X Overlapping contacts remain on (closed) when switch is moved between these two positions. Timers Operator Truth Tables Use the following tables to build custom selector switches. 2 Position Selector Switches Contact HW-U10 (NO) ASLD0201T8 HW-U10R (NO-EM) HW-U01R (NC-LB) Mounting Position Operator Position Left Right L O X R O X L X O R X O L O X R O X L X O R X O Contact HW-U10 (NO) ASD0302T8 ASLD0302T8 ASD0302KT8 HW-U01 (NC) HW-U10R (NO-EM) HW-U01S (NC-LB) HW-U10 (NO) ASD0306T8 ASLD0306T8 ASD0306KT8 HW-U01 (NC) HW-U01R (NC-LB) 1804301445 800-262-IDEC (4332) • USA & Canada Center Right L X O O R O O X L O X X R X X O L X O O R O O X L O X X R X X O Operator Position Mounting Position Left L X O R O O X L O X O R X X O L X O X R O O X L O X O R X X O Center Right X Circuit Breakers HW-U10R (NO-EM) Operator Position Left Terminal Blocks Contact Mounting Position Contactors HW-U01 (NC) 3 Position Selector Switches 741 Switches & Pilot Devices Relays & Sockets Signaling Lights Switches & Pilot Devices ø30mm - TWND Series Accessories — TWND Series TWND Series Accessories Item Lamp Removal Tool Metal Bezel Plastic Bezel Timers Boot/Cover Contactors Terminal Blocks Description/Usage Rubber tool used to install or remove LED’s Replacement locking ring/ bezel OR-55 Standard octagonal units (chrome-pl.). OG-81 Extended, non-illuminated (chrome-pl.). OG-82 Extended, illuminated (chrome-pl.). OG-83L Jumbo Mushroom Shallow Shroud ABN4G Jumbo Mushroom Deep Shroud ABN4F Black plastic locking ring/bezel Used to cover and protect pushbuttons Part Number OGP11B In place of j, specify Neoprene Rubber Boot color: B (black), G (green), R (red), Y (yellow) OC-11 j Flush units (clear plastic -40˚ to +60˚C). OC-121 Extended units (clear plastic -40˚ to +60˚C). OC-122 Plastic washer For nameplates or panels that should not be scratched. OGL-D1T Thrust washer/Anti-rotation ring for use with notched panel cutout. OGL-D1S Anti-Rotation Ring Mounting Hole Plug Circuit Breakers Appearance Plugs used to fill unused 30mm panel cutouts. Plastic with locking nut attached. OBP-11 Metal with locking nut attached OB-11 Grey rubber (-5˚ to +60˚C) OB-13 Terminal Tab Adaptor Tab #250 17/64” x 3/64” (6.35mm x 0.8mm): Single tab TW-FA4 Short Lamp Holder Used with a one contact block TW-LH1 Long Lamp Holder Used with Transformer and two contact blocks Used with Full Voltage Adaptor and two contact blocks TW-LH2 Lead Holder Used with TW-LH2 holder when using four contact blocks HW-LH3 Lock Out Adaptor Used to provide lockout protection for TWTD pushbuttons and knob selectors. ø 1-13/64” (30mm) OL-KL1 Full Voltage Clips Primary Voltage (50/60Hz) Required for all full voltage pilot lights. Two pieces each. 2 clips required for full voltage pilot lights. APD-F Replacement Keys Pair of keys (#0) TW-SK 742 www.IDEC.com 1804301445 Switches & Pilot Devices ø30mm - TWND Series Switches & Pilot Devices Fingersafe Covers for TWND Series Item Description Used with Part Number Full voltage pilot lights APD-PVL Fingersafe terminal cover, adds 1.5mm to overall depth Transformer pilot lights N-VL3 Signaling Lights Fingersafe terminal cover, for full voltage pilot lights, adds 3mm to overall depth Relays & Sockets Timers Contactors Terminal Blocks Circuit Breakers 1804301445 800-262-IDEC (4332) • USA & Canada 743 Switches & Pilot Devices Nameplates — TWND Series Faceplates NALD NAKD Ø1.19" (30.5mm) Ø1.19" (30.5mm) 5mm Description Relays & Sockets 1.95" (50mm) 1.95" (50mm) Ø1.19" (30.5mm) 2.24" (57.5mm) Dimensions NAQD 2.03" (52mm) 1.56" (40mm) 1.85" (47.5mm) Signaling Lights Switches & Pilot Devices ø30mm - TWND Series Part Number Nameplate (blank) NALD-B (black) NALD-R (red) NAKD-B (black) NAKD-R (red) NAQD-B (black) NAQD-R (red) Nameplate (engraved) NALD-j NAKD-j NAQD-j 1. Nameplates are made of 0.031” aluminum. Lettering is white letters engraved on black background. 2. In place of j, insert either the standard legend code from table below or custom engraving delimited by “ “. Standard Legend Codes Pushbuttons Terminal Blocks Contactors Timers Legend AUTO CLOSE DOWN EMERG.STOP* FAST FORWARD HAND HIGH IN INCH JOG LOW LOWER OFF ON Code 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 Pushbuttons/Selector Switches Legend OPEN OUT RAISE RESET REVERSE RUN SLOW START STOP* STOP TEST UP I (Int’l On) O (Int’l Off) EMO Code 116 117 118 119 120 121 122 123 124 125 126 127 150 151 152 Legend AUTO-MAN CLOSE-OPEN DOWN-UP FAST-SLOW FOR-REV HAND-AUTO HIGH-LOW JOG-RUN LEFT-RIGHT LOWER-RAISE MAN-AUTO OFF-ON ON-OFF OPEN-CLOSE RAISE-LOWER Code 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 Legend REV-FOR RUN-JOG RUN-SAFE SAFE-RUN SLOW-FAST START-STOP STOP-START UP-DOWN Selector Switches Code 216 217 218 219 220 221 222 223 Legend AUTO-MAN-OFF AUTO-OFF-MAN CLOSE-OFF-OPEN DOWN-OFF-SLOW FAST-OFF-SLOW FOR-OFF-REV LEFT-OFF-RIGHT LOWER-OFF-RAISE OFF-MAN-AUTO OFF-SLOW-FAST OFF-1-2 OPEN-OFF-CLOSE SLOW-OFF-FAST SUMMER-OFF-WINTER UP-OFF-DOWN 1-OFF-2 HAND-OFF-AUTO Code 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 1. *Available in Red as standard legend code 104 and 124. To order engraved nameplate and codes, add legend code to nameplate part number. Character height based on the number of characters, space and size of nameplate. Standard character size is 3/16”. 2. Nameplates with standard legends are the same list price as blank nameplates. Special engravings, additional cost. Circuit Breakers To specify engraving instructions, use the Nameplate order form on next page. 744 www.IDEC.com 1804301445 Switches & Pilot Devices ø30mm - TWND Series Copy this order form and use it to specify Letter Height, Custom Engravings, Location of Engraving on Nameplate, and Quantity Desired. To ensure engraving accuracy, fax it to your IDEC representative. or Distributor. Your Company Name:__________________________________________ IDEC Rep/Distributor Contact:__________________________________ PO number (if known):__________________________________ Telephone:__________________________________________ IDEC Rep/Distributor Phone:__________________________________ IDEC Rep/Distributor Fax & Email:__________________________________ Fax & Email:__________________________________________ NALD Nameplate Step 1. Choose Letter Size - 7/64” or 1/8”. Check the box for the letter size you want. Then write your lettering in box below checkboxes. Note: 1/8” size letters cannot exceed 13 characters. Engraving Location Sample Letter Sizes 7/64” 16 characters max (for 7/64” size letters) 1/8” 13 characters max (for 1/8” size letters) Letter Size 7/64” Letters: 1/8” Letters: Letter Size Relays & Sockets Step 2. Specify Quantity. Enter the number of nameplates desired in the box on the right. NAKD Nameplate Signaling Lights Your Name:__________________________________________ Switches & Pilot Devices Custom engraved Nameplates Order Form — TWND Series Qty 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 Step 1. Choose Letter Size - 7/64” or 1/8”. Timers Check the box for the letter size you want. Then write your lettering in box below checkboxes. Note: 1/8” size letters cannot exceed 9 characters. Engraving Location Step 2. Specify Quantity. 1 Sample Letter Sizes Qty Contactors Enter the number of nameplates desired in the box on the right. 1/8” Letters: NAQD Nameplate Step 1. Choose Letter Size - 7/64” or 1/8”. 1 2 3 20 characters max (for 7/64” size letters) 1/8” 16 characters max (for 1/8” size letters) Letter Size 4 5 Step 2. 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Sample Letter Sizes Enter the number of nameplates desired in the box on the right. 3/32” Letters: Circuit Breakers Specify Quantity. 1804301445 Terminal Blocks Check the box for the letter size you want. Then write your lettering in box below checkboxes. Note: 1/8” size letters cannot exceed 16 characters. Engraving Location 7/64” Letter Size 1/8” Letters: Qty 800-262-IDEC (4332) • USA & Canada 745 Switches & Pilot Devices Signaling Lights Switches & Pilot Devices ø30mm - TWND Series Switch Engraving Order Form – TWND Series Copy this order form and use it to specify Letter Height, Maximum Number of Lines and Text to be engraved. To insure engraving accuracy, fax it to your IDEC representative or Distributor. Your Company: Telephone: Name: Fax: Address: Email: PO: Part Number to be Engraved: Please check one of the boxes below to indicate your choice of engraving options: ø29mm, ø40mm Mushroom Head 65mm Jumbo Mushroom Relays & Sockets Square Switch Engraving Engraving Area 1 Area 2† # of Lines Letter Height Max. Characters Per Line 5/32 7 # of Lines 1 Letter Height Max. Characters Per Line 3/4 4 1 1/8 8 5/32 7 5/16 5/16 5 5 Timers 2 3 1/8 8 1/8 8 4 2 Custom* Contactors Round Switch 4 Letter Height Max. Characters Per Line 5/32 7 1/8 8 1 6 5/32 8 5/32 8 1/8 9 1/8 9 3 *Engraving is possible, but character size will be smaller than standard sizes. # of Lines 1/4 Terminal Blocks 3 4 Engraving Area 1 1 Engraving Area 2 1 Letter Height Max. Characters Per Line 5/32 5 1/8 5 5/32 7 1/8 7 1. Above mentioned specifications hold true for standard size pushbuttons (round and square). 2. †Engraving Area 2 can be engraved for 40mm mushroom head non-Illuminated pushbutton only. 3. Engraving is done on the button itself for non-Illuminated push buttons and on marking plate for illuminated push buttons and pilot lights. 4. Please enter text exactly how you want it engraved, take care to emphasize capital or small letters. Enter text to be engraved: Sample Letter Sizes 1/8 Letters: Line 1: 5/32 7 1/8 8 Line 3: 1/8 8 Line 4: 2 # of Lines 5/32 Letters: Line 2: All engraving is 5/8mm wide. Custom* Circuit Breakers *Engraving is possible, but character size will be smaller than standard sizes. For IDEC Internal Use Only: Work Order #: 746 www.IDEC.com 1804301445 Switches & Pilot Devices ø30mm - TWND Series Switches & Pilot Devices Dimensions (mm) Pushbutton Pushbuttons Dimension B 0.351” (9mm) 0.566” (14.5mm) 0.663” (17mm) ø 0.975” (25mm) ø 0.975”(25mm) ø 1.11” (28.5mm) Mushroom Mushroom w/Full Shroud Jumbo Mushroom ø 1.56” (40mm) 0.858” (22mm) 0.936” (24mm) 1.13” (29mm) ø 1.56” (40mm) ø 1.87” (48mm) ø 2.54” (65mm) Mushroom, Pushlock Turn Reset and Push-Pull ø 1.56” (40mm) *0.975” (25mm) **0.975” (25mm) ø 1.56” (40mm) ø 1.56” (40mm) 41.4 ø35 Flush Extended Extended w/Full Shroud 45.4 (1 or 2 blocks) 29.6 ø39 9 65.4(3 or 4 blocks) Mushroom Pushbutton w/Full Shroud 29.6 ø48 41.4 Panel Thickness 0.8 to 6.5 43.9 (1 or 2 blocks) 63.9 (3 or 4 blocks) Signaling Lights Dimension A Panel Thickness 0.8 to 7.5 *Dimension when operator is in reset position. **Dimension when operator is in pull position. 23.5 Relays & Sockets Illuminated Pushbuttons Full Voltage Dimension B Flush w/Full Shroud 0.975” (25mm) 0.995” (25.5mm) ø 0.936” (24mm) ø 0.936” (24mm) Extended w/Full Shroud 0.741” (19mm) 0.761” (19.5mm) ø 0.936” (24mm) ø 0.936” (24mm) ø 1.56” (40mm) Mushroom Pushlock Turn Reset, Push-Pull *0.975” (25mm) **0.975” (25mm) ø 1.56” (40mm) ø 1.56” (40mm) ø24 ø35 29.4 40 23.6 Pilot Lights M3 Terminal Screw Panel Thickness 0.8 to 7.5 46 5 21.5 23.5 36 Dimension A 45.4 (1block) 65.4 (2 or 3 blocks) 85.4 (4 blocks) Timers Illuminated Pushbuttons 29.6 ø39 23.6 38 45.4 65.4 75.5 (2 blocks), 95.5 (4 blocks) Panel Thickness 0.8 to 7.5 41.4 ø24 ø35 41.4 Panel Thickness 0.8 to 7.5 ø24.6 ø35 w/Transformer 40 Contactors *Dimension when operator is in reset position. **Dimension when operator is in pull position. Selector Switches Lever Panel Thickness 0.8 to 7.5 90° 2-position (3-position) 45° 45° ø35 41.4 25.1 ø25 ø35 90° 2-position (3-position) 45° 45° ø35 Panel Thickness 0.8 to 7.5 Terminal Blocks 41.4 Key 90° 2-position (3-position) 45° 45° Panel Thickness 0.8 to 7.5 41.4 Knob 45.4 (1 or 2 blocks) 65.4 (3 or 4 blocks) 45.4 (1 or 2 blocks) 29.4 40 21.1 65.4 (3 or 4 blocks) 21.1 29.4 40 45.4 (1 or 2 blocks) 65.4 (3 or 4 blocks) 16.5 37.1 29.4 40 Illuminated Knob (3-position) 45° 27.6 29.6 40 Circuit Breakers 45.4 65.4 75.5 (2 blocks), 95.5 (4 blocks) 1804301445 90° 2-position 45° ø25 ø35 41.4 Panel Thickness 0.8 to 7.5 800-262-IDEC (4332) • USA & Canada 747 Switches & Pilot Devices Selector Switches Panel Cut-Out R0.8 max. 4.8 ø3 0.5 + +0.2 0 33 +0.5 0 1. *Jumbo Mushroom < 2.61” (66mm) 2. Minimum mounting centers are applicable to switches with one stack of contact blocks. When mounting two stacks of contact blocks, minimum centers should allow for access to wiring. 3. The ø 0.195” (ø 5mm) recess is necessary when either the nameplate or anti-rotation ring is used. Square: 55 Round: 42 (*1) 0 0 .5 50 (*1) IlluminatedSelector Switches OC-31 Lock-Out Adaptor Pushbutton Clear Boot OGL-31 ø32.6 93 30 70 ø3 4 ø30 .5 ø3 9 18 (OC-31) 22 (OC-32) ø34 24.8 Waterproof Rubber Gasket Key Hole ø8 29.5 0.5t 30 0. ø4 Timers 6.5 Outside diameter: ø50 Inside diameter: ø44 ø40 ø30 R6 Relays & Sockets 82.5 Mounting Hole Rubber Plug 0.8 10 2.8 Panel Thickness 0.8 to 3. 2 OB-31 Anti-Rotation Ring 5 OL-KL1 5 Signaling Lights Switches & Pilot Devices ø30mm - TWND Series 2 Finger-Safe Cover N-VL3 Contactors 0 (6 .24” .2m  m ) 1.20” (30.4mm) 0.63” (16mm) NVL3 0.19” (4.7mm) 0.94” 0.68” (17.2mm) (24mm) 0.41” (10.5mm) .413” (10.5mm) APDPVL 748 (6 1.73” (44mm) 6” .25 Circuit Breakers .354” (9mm) m) .2m 1.45” (37mm) 1.26” (32mm) Terminal Blocks APD-PVL www.IDEC.com 1804301445 Switches & Pilot Devices ø30mm - TWND Series Switches & Pilot Devices Operating Instructions Adjustment for Panel Thickness Insallation of LED Illuminated Units Each unit is shipped with several waterproof gaskets which are 0.06” (1.5mm) and 0.12” (3mm) thick. Combine the gaskets for a dimension approximately equal to panel thickness and install between the bezel and the body of the unit. Transformer units are recommended for use in areas subjected to inductive noise. Application Example For Push-To-Test Pilot Light A typical application of illuminated pushbuttons is a push-to-test pilot light which can be used to check the lamp/LED circuit. Start Panel Cut-Out Unit Stop Trim Washer M2 L Thrust Washer Signaling Lights Transformer/AC-Adapter Circuit C NC M2 Nameplate NO T Relays & Sockets Test Pilot Light L Full Voltage Circuit Start Stop M A trim washer must be used with a thrust washer or a nameplate to prevent the control unit from rotating in the mounting hole. When using anti-rotation rings (trim washer with thrust washer or nameplate), install as shown below. Selector Switches L M NC NO T C L Timers The operator shaft of each unit has a recess to identify in which direction to install the handle. Align the handle with the recess. Press color insert (TW-HC1) into the Standard Operating Positions. OLS Test Pilot Light Standard Operation Positions 2-Position, 90° 3-Position, 45° 1 1 0 2 2 Contactors Non-Illuminated 3-Position Operators 1 0 2 1 1 0 0 2 2 Terminal Blocks Circuit Breakers 1804301445 800-262-IDEC (4332) • USA & Canada 749
ASLD22211DNUG
物料型号:TWND系列
器件简介:TWND系列提供了重型工业级按钮开关,具有耐用性和长久的使用寿命。这些开关设计坚固,提供了多种尺寸和功能,包括LED照明,并有全电压和变压器模型可供选择。
引脚分配:文档中没有提供具体的引脚分配图,但提到了开关的接触类型,例如1NO(单极单通)、1NC(单极双断开)、2NO(双极双通)等。
参数特性: - 操作温度:-25至+50°C(照明版本);-25至+70°C(非照明版本) - 振动抵抗:5至55Hz,98m/s²(10g) - 冲击抵抗:980m/s²(100g) - 电气冲击保护:符合IEC60664-1的2类 - 防护等级:IP65(面板前部),符合IEC60529;UL Type 4X, 13 和 IP65水密/油密面板
功能详解: - 提供了多种按钮尺寸,最大可达2 9/16”(65mm) - 镀铬锌锁定环、压铸锌安装螺纹、钢防旋转环和自清洁接触点 - 模块化构造,提供最大的灵活性 - 可组装或作为子部件提供 - 多种认证,包括UL Listed、Tuv Rheinland等
应用信息:TWND系列适用于需要长期稳定运作和工业强度质量的场合,例如在工业控制和自动化系统中。
封装信息:提供了多种安装选项和防护等级,以适应不同的应用环境和需求。
ASLD22211DNUG 价格&库存
很抱歉,暂时无法提供与“ASLD22211DNUG”相匹配的价格&库存,您可以联系我们找货
ASLD22211DNUG
    • 1+656.017511+84.87338
