HE1B Enabling Switch
3-position enabling switch to avoid hazards.
Ideal for installing in teach pendants and other enabling devices.
• Ergonomically-designed OFF-ON-OFF.
• Direct opening action mechanism for shifting from position 2 (ON)
to position 3 (OFF) (EN 60947-5-1/IEC 60947-5-1, Annex K).
• The switch does not turn ON while being released from position 3
(OFF when pressed) to position 1 (OFF when released)
(IEC60204-1, 9.2.5.8).
• Reliable performance in compact and lightweight package.
Direct Opening
Action
Types
Mounting Style
Side Mounting
Top Mounting
Contact Configuration
1 contact (3-position)
Type No.
HE1B-M1
HE1B-M1N
Ordering Type No.
HE1B-M1PN10
HE1B-M1NPN10
Package Quantity
10
• Minimum applicable load (reference value): 3V AC/DC, 5 mA
Ratings
• Contact Ratings
Rated Insulation Voltage (Ui)
250V
Rated Thermal Current (Ith)
5A
Rated Voltage (Ue)
AC 50/60 Hz
Rated Current (Ie)
DC
30V
125V
Resistive Load (AC-12)
3A
1.5A
Inductive Load (AC-15)
1.5A
0.75A
Resistive Load (DC-12)
2A
0.4A
0.2A
Inductive Load (DC-13)
1A
0.22A
0.1A
Contact Configuration (3-position switch)
250V
1 contact
Specifications
Applicable Standards
IEC 60947-5-1, EN 60947-5-1 (DEMKO approval)
UL508 (UL recognized), CSA C22.2, No. 14 (c-UL recognized), JIS C8201-5-1
Applicable Standards for Use
ISO 12100 / EN 292, IEC 60204-1 / EN 60204-1
ISO 11161 / prEN 11161, ISO 10218 / EN 775, ANSI/RIA R15.06, ANSI B11.19
Operating Temperature
–25 to +60°C (no freezing)
Relative Humidity
45 to 85% (no condensation)
Storage Temperature
–40 to +80°C (no freezing)
Pollution Degree
2
Contact Resistance
50 mΩ maximum (initial value)
Insulation Resistance
100 MΩ minimum
Impulse Withstand Voltage
2.5 kV
Operating Frequency
1,200 operations per hour
Mechanical Durability
Position 1 → 2 → 1:
1,000,000 operations
Position 1 → 2 → 3 → 1: 100,000 operations
Electrical Durability
100,000 operations minimum
Shock Resistance
Operating extremes: 150 m/s2
Damage limits:
1,000 m/s2
Vibration Resistance
Operating extremes: 5 to 55 Hz, amplitude 0.5 mm
Damage limits:
16.7 Hz, amplitude 1.5 mm
Terminal Style
Solder terminal
Applicable Wire
1 cable, 0.5 mm2 maximum
Solder Terminal Heat Resistance
310 to 350°C, 3 seconds maximum
Terminal Tensile Strength
20N minimum
Mounting Screw Recommended Tightening Torque
HE1B-M1: M3 screw / 0.5 to 0.8 N·m
HE1B-M1N: M2.6 screw / 0.4 to 0.6 N·m
Degree of Protection
IP40, except terminals
Conditional Short-circuit Current
50A (250V) (Use 250V/10A fast acting type fuse for short-circuit protection.)
Direct Opening Force
30N minimum (position 2 → 3)
Operator Strength
250N minimum
Weight (approx.)
6g
6
(05/12/07)
Operation Characteristics
Position 1
Position 2
Position 3
Approx. 15N
Operating Force (Reference Value)
(When pressing the center of operator)
Approx. 3N
1.4±0.3
Travel (mm) 0
: ON (Closed)
: OFF (Open)
Pressing (
Releasing (
2.2±0.3
2.7±0.5
5.0
Dimensions
30
13.6
12
7.6
4
4
13
5
7
When pressed to
position 3: 2
2.8
24
4
8
Solder Terminal
Mounting Hole Layout
ø2
.8
24±0.2
Mounting Panel
Thickness
24±0.5
15 min.
9 min.
3
M
• HE1B-M1N (top mounting type)
Mounting screw: M2.6
Mounting Screw Length:
Mounting panel thickness + 5 to 6
• HE1B-M1 (side mounting type)
Mounting screw: M3
Insert the nuts supplied with the switch.
Note: When installed on a mounting panel thicker than 2
mm, the actuator surface is below the panel when
the button is pressed to position 3.
All dimensions in mm.
(05/12/07)
7
很抱歉,暂时无法提供与“HE1B-M1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+213.580491+27.56903
- 10+176.4300410+22.77364
- 25+163.6688625+21.12642
- 50+154.9531050+20.00139
- 100+147.06999100+18.98383
- 250+137.91585250+17.80222
- 500+131.90922500+17.02688
- 国内价格
- 1+97.21080
- 200+38.79360
- 500+37.49760
- 国内价格
- 1+195.03777
- 5+189.21647
- 10+183.73054
